  4. Server Cannot start inMem-objects on port 9001
429 Beiträge 40 Kommentatoren 132.6k Aufrufe 39 Beobachtet
  • B bot1000
    System aktualisiert -> Fehler ist gleich
    boo hatte ich abgeschnittenb es ist "boot"
    DJMarc75D Offline
    DJMarc75D Offline
    DJMarc75
    #405
    @bot1000 sagte in Server Cannot start inMem-objects on port 9001:
    keine Nacherzählungen sonder auch jetzt wieder zeigen:
    iob diag
    Lehrling seit 1975 !!!
    • apollon77A apollon77
      @bot1000 Die Ausgabe von iob fix würde mich echt interessieren bei so einem großen objects file ... lass nochmal fixlaufen und schon ob das kleiner wird.
      bot1000
      #406
      @apollon77
      System upgedatet
      Und dann "iob fix" nochmal ausgeführt. Object file immer noch so groß:
      iob fix Ausgabe:
      library: loaded
      Library version=2022-12-09
          Welcome to the ioBroker installation fixer!
          Script version: 2023-04-02
          You might need to enter your password a couple of times.
          Installing prerequisites (1/5)
      Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
      Get:4 https://repos.influxdata.com/debian stable InRelease [6,892 B]
      Get:5 https://packages.grafana.com/oss/deb stable InRelease [5,984 B]
      Err:4 https://repos.influxdata.com/debian stable InRelease
        The following signatures couldn't be verified because the public key is not av        ailable: NO_PUBKEY D8FF8E1F7DF8B07E
      Err:5 https://packages.grafana.com/oss/deb stable InRelease
        The following signatures couldn't be verified because the public key is not av        ailable: NO_PUBKEY 9E439B102CF3C0C6
      Fetched 6,892 B in 4s (1,829 B/s)
      Reading package lists... Done
      W: An error occurred during the signature verification. The repository is not up        dated and the previous index files will be used. GPG error: https://repos.influx        data.com/debian stable InRelease: The following signatures couldn't be verified        because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
      W: An error occurred during the signature verification. The repository is not up        dated and the previous index files will be used. GPG error: https://packages.gra        fana.com/oss/deb stable InRelease: The following signatures couldn't be verified        because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
      W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease        The following signatures couldn't be verified because the public key is not avai        lable: NO_PUBKEY 9E439B102CF3C0C6
      W: Failed to fetch https://repos.influxdata.com/debian/dists/stable/InRelease  T        he following signatures couldn't be verified because the public key is not avail        able: NO_PUBKEY D8FF8E1F7DF8B07E
      W: Some index files failed to download. They have been ignored, or old ones used        instead.
      Installed gcc-c++
          Checking ioBroker user and directory permissions (2/5)
          Check and cleanup npm temporary directories (3/5)
      Done.
          Database maintenance (4/5)
      Checking for uncompressed JSONL databases... This might take a while!
      Compressing /opt/iobroker/iobroker-data/states.jsonl
      Compressing /opt/iobroker/iobroker-data/objects.jsonl
      Cannot compress objects.jsonl: Error: Failed to lock DB file "/opt/iobroker/iobr        oker-data/objects.jsonl"!
          at JsonlDB.open (/home/iobroker/.npm/_npx/36bee06d4228a674/node_modules/@alc        alzone/jsonl-db/build/lib/db.js:185:19)
          at async compressDB (/home/iobroker/.npm/_npx/36bee06d4228a674/node_modules/        @iobroker/jsonltool/index.js:37:9)
          at async main (/home/iobroker/.npm/_npx/36bee06d4228a674/node_modules/@iobro        ker/jsonltool/index.js:93:17)
      Compressed 1 JSONL files. Done
          Checking autostart (5/5)
      Enabling autostart...
      Autostart enabled!
          Your installation was fixed successfully
          Run iobroker start to start ioBroker again!
      iob diag Ausgabe "Summary":
                           v.2023-04-16
      Operatingsystem:        Raspbian GNU/Linux 11 (bullseye)
      Kernel:                 6.1.21-v7+
      Installation:           Native
      User-ID:                1000
      X-Server:               false
      Boot Target:            multi-user.target
      Pending OS-Updates:     0
      Pending iob updates:    0
      Nodejs-Installation:    /usr/bin/nodejs         v16.20.0
                              /usr/bin/node           v16.20.0
                              /usr/bin/npm            8.19.4
                              /usr/bin/npx            8.19.4
      Recommended versions are nodejs 18.x.y and npm 9.x.y
      MEMORY:
      Mem:            921M        213M        101M        0.0K        606M        684M
      Swap:            99M         32M         67M
      Total:          1.0G        245M        169M
      Active iob-Instances:   0
      Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
      ioBroker Core:          js-controller           4.0.23
                              admin                   6.2.22
      ioBroker Status:        Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
      Objects:                1
      States:                 1
      Size of iob-Database:
      628M    /opt/iobroker/iobroker-data/objects.jsonl
      88K     /opt/iobroker/iobroker-data/states.jsonl
      • B bot1000
        @apollon77
        System upgedatet
        iob fix Ausgabe:
        library: loaded
        Installed gcc-c++
        Done.
        Autostart enabled!
                             v.2023-04-16
        Kernel:                 6.1.21-v7+
        User-ID:                1000
        X-Server:               false
                                /usr/bin/npm            8.19.4
                                /usr/bin/npx            8.19.4
        MEMORY:
        Swap:            99M         32M         67M
                                admin                   6.2.22
        Objects:                1
        States:                 1
        bot1000
        #407
        Jemand noch ne Idee?
        • B bot1000
          DJMarc75D Offline
          DJMarc75D Offline
          DJMarc75
          #408
          ja, wie wäre es wenn Du tatsächlich Deine Installation auf den aktuellen Stand bringen würdest ?
          Also Node auf die empfohlene Version bringen.
          https://forum.iobroker.net/topic/64032/update-nodejs-best-practise-supported-16-und-18
          • B bot1000
            @crunchip
            Timeout beide auf 30000 gesetzt. Immer noch der gleiche Fehler
            crunchipC Abwesend
            crunchipC Abwesend
            #409
            @bot1000 dann probier spasseshalber mal mit 60000
            Ausserdem musst du deine keys für grafana und influx anpassen
              bot1000
              #410
              @crunchip
              Kurzen Tipp wo ich weitere Infos bekomme wie das funktioniert?
              • B bot1000
                @crunchip
                #411
                @bot1000
                https://forum.iobroker.net/topic/62040/linux-debian-grafana-repo-muss-aktualisiert-werden
                Für influx steht auch was im weiteren Verlauf des Threads dabei.
                W 1 Antwort Letzte Antwort
                  @bot1000
                  W Offline
                  W Offline
                  Worn
                  #412
                  Moin, ich hatte den Fehler heute auch wieder. Es hat also 3 Monate gedauert, bis das wieder aufgetreten ist. Der iob Fixer hat geholfen. Mein System ist stark veraltet, der neue PI etc. ist in Arbeit, aber es läuft wieder alles.
                  Compressed 2 JSONL files. Done
                  Meine Frage: Die JSON Files sollen doch automatisch komprimiert werden, richtig? JS Controller ist die 4.0.23 aktuell. Wie könnte ich denn mal prüfen, wieso das automatische Komprimieren nicht funktioniert. Vielleicht "muss" man das irgendwo mal enablen?
                  • W Worn
                    #413
                    @worn sagte in Server Cannot start inMem-objects on port 9001:
                    Vielleicht muss man sein System auch nur aktuell halten?
                    js-controller
                    latest:	4.0.24 for 5 months
                    stable:	4.0.24 for 5 months
                      js-controller
                      W Offline
                      W Offline
                      Worn
                      #414
                      Da hast du absolut Recht. Mich wunderte nur, dass irgendwo stand, die Komprimierung sollte bei JS 4.0.23 schon drin sein (meine ich hier gelesen zu haben), daher interessiert mich, ob da woanders ein Fehler steckt. Aktualisieren mache ich natürlich jetzt. Mal sehen, was dann in ~3 Monaten passiert (bzw. dann ist sicher der neue Raspi mit allem neu im Einsatz).
                      • W Worn
                        #415
                        Wo stehst du denn im Moment?
                        iob diag
                        hilft dir da evtl. weiter.
                          iob diag
                          W Offline
                          W Offline
                          Worn
                          #416
                          Wie gesagt ist veraltet :). Dennoch läuft alles noch einwandfrei.
                          • W Worn
                            #417
                            @worn
                            Keine Screenshots von Text.
                            • W Worn
                              crunchipC Abwesend
                              crunchipC Abwesend
                              #418
                              @worn also mit stretch und nodejs12 haste aber Glück bzw die passenden Adapter am laufen, denn einige bzw viele Adapter unterstützen dies in der aktuellen Version gar nicht mehr
                                W Offline
                                W Offline
                                Worn
                                #419
                                @crunchip : Raspi befindet sich eh in Ablöse :).
                                @Thomas-Braun : Danke für die Info.
                                • DJMarc75D DJMarc75
                                  bot1000
                                  #420
                                  @djmarc75 Nach dem Update funktioniert alles wieder!
                                  • B bot1000
                                    bot1000
                                    #421
                                    @bot1000 Was wird eigentlich in iobroker-data/objects.jsonl gespeichert? Wenn die Datei weiter so wächst, habe ich da früher oder später Probleme. Würde das gerne verhinden
                                    Thomas BraunT apollon77A 2 Antworten Letzte Antwort
                                    • B bot1000
                                      #422
                                      Ein aktueller js-controller, der auf jsonl/jsonl läuft macht das von alleine.
                                      Alternativ regelmäßig den iob fix laufen lassen, der macht das u. a. auch.
                                      • B bot1000
                                        #423
                                        @bot1000 wie Thomas sagt. Js-Controller 4.0.24 is your friend.
                                          #424
                                          @apollon77 @bot1000
                                          Soviel dann zu
                                          Ich sag's ja wieder und wieder: Haltet einfach die Kisten immer auf Stand...
