  4. Server Cannot start inMem-objects on port 9001
429 Beiträge 40 Kommentatoren 132.6k Aufrufe 39 Beobachtet
  • B bot1000
    @apollon77
    System upgedatet
    Und dann "iob fix" nochmal ausgeführt. Object file immer noch so groß:
    iob fix Ausgabe:
    library: loaded
    Library version=2022-12-09
        Welcome to the ioBroker installation fixer!
        Script version: 2023-04-02
        You might need to enter your password a couple of times.
        Installing prerequisites (1/5)
    Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
    Get:4 https://repos.influxdata.com/debian stable InRelease [6,892 B]
    Get:5 https://packages.grafana.com/oss/deb stable InRelease [5,984 B]
    Err:4 https://repos.influxdata.com/debian stable InRelease
      The following signatures couldn't be verified because the public key is not av        ailable: NO_PUBKEY D8FF8E1F7DF8B07E
    Err:5 https://packages.grafana.com/oss/deb stable InRelease
      The following signatures couldn't be verified because the public key is not av        ailable: NO_PUBKEY 9E439B102CF3C0C6
    Fetched 6,892 B in 4s (1,829 B/s)
    Reading package lists... Done
    W: An error occurred during the signature verification. The repository is not up        dated and the previous index files will be used. GPG error: https://repos.influx        data.com/debian stable InRelease: The following signatures couldn't be verified        because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    W: An error occurred during the signature verification. The repository is not up        dated and the previous index files will be used. GPG error: https://packages.gra        fana.com/oss/deb stable InRelease: The following signatures couldn't be verified        because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
    W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease        The following signatures couldn't be verified because the public key is not avai        lable: NO_PUBKEY 9E439B102CF3C0C6
    W: Failed to fetch https://repos.influxdata.com/debian/dists/stable/InRelease  T        he following signatures couldn't be verified because the public key is not avail        able: NO_PUBKEY D8FF8E1F7DF8B07E
    W: Some index files failed to download. They have been ignored, or old ones used        instead.
    Installed gcc-c++
        Checking ioBroker user and directory permissions (2/5)
        Check and cleanup npm temporary directories (3/5)
    Done.
        Database maintenance (4/5)
    Checking for uncompressed JSONL databases... This might take a while!
    Compressing /opt/iobroker/iobroker-data/states.jsonl
    Compressing /opt/iobroker/iobroker-data/objects.jsonl
    Cannot compress objects.jsonl: Error: Failed to lock DB file "/opt/iobroker/iobr        oker-data/objects.jsonl"!
        at JsonlDB.open (/home/iobroker/.npm/_npx/36bee06d4228a674/node_modules/@alc        alzone/jsonl-db/build/lib/db.js:185:19)
        at async compressDB (/home/iobroker/.npm/_npx/36bee06d4228a674/node_modules/        @iobroker/jsonltool/index.js:37:9)
        at async main (/home/iobroker/.npm/_npx/36bee06d4228a674/node_modules/@iobro        ker/jsonltool/index.js:93:17)
    Compressed 1 JSONL files. Done
        Checking autostart (5/5)
    Enabling autostart...
    Autostart enabled!
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    iob diag Ausgabe "Summary":
                         v.2023-04-16
    Operatingsystem:        Raspbian GNU/Linux 11 (bullseye)
    Kernel:                 6.1.21-v7+
    Installation:           Native
    User-ID:                1000
    X-Server:               false
    Boot Target:            multi-user.target
    Pending OS-Updates:     0
    Pending iob updates:    0
    Nodejs-Installation:    /usr/bin/nodejs         v16.20.0
                            /usr/bin/node           v16.20.0
                            /usr/bin/npm            8.19.4
                            /usr/bin/npx            8.19.4
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:            921M        213M        101M        0.0K        606M        684M
    Swap:            99M         32M         67M
    Total:          1.0G        245M        169M
    Active iob-Instances:   0
    Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
    ioBroker Core:          js-controller           4.0.23
                            admin                   6.2.22
    ioBroker Status:        Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
    Objects:                1
    States:                 1
    Size of iob-Database:
    628M    /opt/iobroker/iobroker-data/objects.jsonl
    88K     /opt/iobroker/iobroker-data/states.jsonl
    bot1000
    #407
    Jemand noch ne Idee?
    • B bot1000
      DJMarc75D Offline
      DJMarc75D Offline
      DJMarc75
      #408
      @bot1000 sagte in Server Cannot start inMem-objects on port 9001:
      ja, wie wäre es wenn Du tatsächlich Deine Installation auf den aktuellen Stand bringen würdest ?
      Also Node auf die empfohlene Version bringen.
      https://forum.iobroker.net/topic/64032/update-nodejs-best-practise-supported-16-und-18
      Lehrling seit 1975 !!!
      • B bot1000
        @crunchip
        Timeout beide auf 30000 gesetzt. Immer noch der gleiche Fehler
        crunchipC Abwesend
        crunchipC Abwesend
        #409
        @bot1000 dann probier spasseshalber mal mit 60000
        Ausserdem musst du deine keys für grafana und influx anpassen
          bot1000
          #410
          @crunchip
          Kurzen Tipp wo ich weitere Infos bekomme wie das funktioniert?
          • B bot1000
            @crunchip
            #411
            @bot1000
            https://forum.iobroker.net/topic/62040/linux-debian-grafana-repo-muss-aktualisiert-werden
            Für influx steht auch was im weiteren Verlauf des Threads dabei.
            W 1 Antwort Letzte Antwort
              @bot1000
              W Offline
              W Offline
              Worn
              #412
              Moin, ich hatte den Fehler heute auch wieder. Es hat also 3 Monate gedauert, bis das wieder aufgetreten ist. Der iob Fixer hat geholfen. Mein System ist stark veraltet, der neue PI etc. ist in Arbeit, aber es läuft wieder alles.
              Compressed 2 JSONL files. Done
              Meine Frage: Die JSON Files sollen doch automatisch komprimiert werden, richtig? JS Controller ist die 4.0.23 aktuell. Wie könnte ich denn mal prüfen, wieso das automatische Komprimieren nicht funktioniert. Vielleicht "muss" man das irgendwo mal enablen?
              • W Worn
                #413
                @worn sagte in Server Cannot start inMem-objects on port 9001:
                Vielleicht muss man sein System auch nur aktuell halten?
                js-controller
                latest:	4.0.24 for 5 months
                stable:	4.0.24 for 5 months
                  js-controller
                  W Offline
                  W Offline
                  Worn
                  #414
                  Da hast du absolut Recht. Mich wunderte nur, dass irgendwo stand, die Komprimierung sollte bei JS 4.0.23 schon drin sein (meine ich hier gelesen zu haben), daher interessiert mich, ob da woanders ein Fehler steckt. Aktualisieren mache ich natürlich jetzt. Mal sehen, was dann in ~3 Monaten passiert (bzw. dann ist sicher der neue Raspi mit allem neu im Einsatz).
                  • W Worn
                    #415
                    Wo stehst du denn im Moment?
                    iob diag
                    hilft dir da evtl. weiter.
                      iob diag
                      W Offline
                      W Offline
                      Worn
                      #416
                      Wie gesagt ist veraltet :). Dennoch läuft alles noch einwandfrei.
                      • W Worn
                        #417
                        @worn
                        Keine Screenshots von Text.
                        • W Worn
                          crunchipC Abwesend
                          crunchipC Abwesend
                          #418
                          @worn also mit stretch und nodejs12 haste aber Glück bzw die passenden Adapter am laufen, denn einige bzw viele Adapter unterstützen dies in der aktuellen Version gar nicht mehr
                            W Offline
                            W Offline
                            Worn
                            #419
                            @crunchip : Raspi befindet sich eh in Ablöse :).
                            @Thomas-Braun : Danke für die Info.
                            • DJMarc75D DJMarc75
                              bot1000
                              #420
                              @djmarc75 Nach dem Update funktioniert alles wieder!
                              • B bot1000
                                bot1000
                                #421
                                @bot1000 Was wird eigentlich in iobroker-data/objects.jsonl gespeichert? Wenn die Datei weiter so wächst, habe ich da früher oder später Probleme. Würde das gerne verhinden
                                Thomas BraunT apollon77A 2 Antworten Letzte Antwort
                                • B bot1000
                                  #422
                                  Ein aktueller js-controller, der auf jsonl/jsonl läuft macht das von alleine.
                                  Alternativ regelmäßig den iob fix laufen lassen, der macht das u. a. auch.
                                  • B bot1000
                                    #423
                                    @bot1000 wie Thomas sagt. Js-Controller 4.0.24 is your friend.
                                    • apollon77A apollon77
                                      #424
                                      @apollon77 @bot1000
                                      Soviel dann zu
                                      Ich sag's ja wieder und wieder: Haltet einfach die Kisten immer auf Stand...
                                        @dieter_p sagte in Server Cannot start inMem-objects on port 9001:
                                        Sorry da stimmte was nicht:
                                        Da stimmt immer noch was nicht...
                                        Egal.
                                        cd /opt/iobroker
                                        sudo -H -u iobroker npm install iobroker.js-controller
                                        AphofisA Offline
                                        AphofisA Offline
                                        Aphofis
                                        schrieb am zuletzt editiert von Aphofis
                                        #425
                                        Mega!
                                        War gerade dabei iobroker up zu daten und hatte fehler beim starten mit dem selben Fehler wie hier beschrieben diese kombi hat geholfen.
                                        /usr/bin/nodejs
                                        /usr/bin/node
                                        /usr/bin/npm
                                        v16.20.2
                                        v16.20.2
                                        8.19.4
                                        pi
                                        /opt/iobroker
                                        nach dem ich
                                        cd /opt/iobroker
                                        ausgeführt hatte und dann iobroker gestartet hatte war der Fehler weg!
                                        Der Fehler war nach dem normalen update upgrade self:
                                        pi@AquaPi:~ $ iob status
                                        /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
                                                throw e;
                                        Error: Connection is closed.
                                            at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:18        4:25)
                                            at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_        handler.js:151:20)
                                            at Object.onceWrapper (node:events:628:26)
                                            at Socket.emit (node:events:513:28)
                                            at TCP.<anonymous> (node:net:301:12)
                                        Emitted 'error' event on ScanStream instance at:
                                            at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
                                            at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.j        s:12:23)
                                            at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
                                            at processTicksAndRejections (node:internal/process/task_queues:96:5)
                                        also besten Dank!!!
                                        • AphofisA Aphofis
                                          Mega!
                                          /usr/bin/nodejs
                                          /usr/bin/node
                                          /usr/bin/npm
                                          v16.20.2
                                          v16.20.2
                                          8.19.4
                                          pi
                                          /opt/iobroker
                                          nach dem ich
                                          cd /opt/iobroker
                                                  throw e;
                                          also besten Dank!!!
                                          Alex-Smarthome
                                          schrieb am zuletzt editiert von Alex-Smarthome
                                          #426
                                          Hallo Leute, ich muss euch mal wieder zu Rate ziehen. Sonntag war bei uns Stromausfall, und wie sollte es als IT-Elektroniker auch anders sein, habe ich den NUC auf dem Debian 12 mit IoBroker läuft in die falsche Steckdose stecken gehabt und so hat meine USV nicht gegriffen. Seid dem bekomme ich den Fehler
                                          „Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!“
                                          Ich habe mich seit dem durch sämtliche Posts hier und auch in anderen Foren gekämpft, immer dasselbe. Der IoB Fix gibt aus das alles wieder ok ist, aber ich komme nicht mehr auf mein Admin.
                                          ~$ iob status
                                          <--- Last few GCs --->
                                          [4348:0x6e90870]    17147 ms: Mark-sweep (reduce) 2047.6 (2069.5) -> 2047.2 (2066.4) MB, 26.2 / 0.0 ms  (+ 2.2 ms in 32 steps since start of marking, biggest step 1.9 ms, walltime since start of marking 32 ms) (average mu = 0.238, current mu = 0.149) allo
                                          <--- JS stacktrace --->
                                          FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
                                           1: 0xb95b60 node::Abort() [node]
                                           2: 0xa9a7f8  [node]
                                           3: 0xd6f2f0 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [node]
                                           4: 0xd6f697 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [node]
                                           5: 0xf4cba5  [node]
                                           6: 0xf5f08d v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [node]
                                           7: 0xf3978e v8::internal::HeapAllocator::AllocateRawWithLightRetrySlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [node]
                                           8: 0xf3ab57 v8::internal::HeapAllocator::AllocateRawWithRetryOrFailSlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [node]
                                           9: 0xf1b0a0 v8::internal::Factory::AllocateRaw(int, v8::internal::AllocationType, v8::internal::AllocationAlignment) [node]
                                          10: 0xf12b14 v8::internal::FactoryBase<v8::internal::Factory>::AllocateRawWithImmortalMap(int, v8::internal::AllocationType, v8::internal::Map, v8::internal::AllocationAlignment) [node]
                                          11: 0xf14ea8 v8::internal::FactoryBase<v8::internal::Factory>::NewRawTwoByteString(int, v8::internal::AllocationType) [node]
                                          12: 0xf1e35c v8::internal::Factory::NewStringFromUtf8(v8::base::Vector<char const> const&, v8::internal::AllocationType) [node]
                                          13: 0xd7e3a3 v8::String::NewFromUtf8(v8::Isolate*, char const*, v8::NewStringType, int) [node]
                                          14: 0xc84d71  [node]
                                          15: 0xc84e8d node::StringDecoder::DecodeData(v8::Isolate*, char const*, unsigned long*) [node]
                                          16: 0xc8545e  [node]
                                          17: 0x169372f  [node]
                                          /usr/bin/iob: Zeile 12:  4346 Abgebrochen             sudo -H -u iobroker node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js "$@"
                                          Über Hilfe wäre ich sehr dankbar, da jetzt alles was so schön lief jetzt wieder Manuel gesteuert werden muss.
