  4. [Tester gesucht] WireGuard UI Installer
68 Beiträge 11 Kommentatoren 11.3k Aufrufe 14 Beobachtet
  • CrunkFXC Offline
    CrunkFXC Offline
    CrunkFX
    Forum Testing
    @dslraser sagte in [Tester gesucht] WireGuard UI Installer:
    setting cgroup config for procHooks process caused: can't load program: function not implemented
    Ich habe leider kein funktionierendes Armbian am laufen aber teste das mal bitte:
    nano /boot/cmdline.txt
    ans Ende anfügen:
    systemd.unified_cgroup_hierarchy=0
    Neustarten
    cd /opt/wireguard-ui
    docker-compose up
    • CrunkFXC CrunkFX
      ans Ende anfügen:
      Neustarten
      docker-compose up
      dslraserD Offline
      dslraserD Offline
      dslraser
      @crunkfx sagte in [Tester gesucht] WireGuard UI Installer:
      docker-compose up
      leider kein Erfolg
      root@tinkerboard:~# cd /opt/wireguard-ui
      root@tinkerboard:/opt/wireguard-ui# docker-compose up
      Starting e99836ca4efb_wgui ... error
      ERROR: for e99836ca4efb_wgui  Cannot start service wg: OCI runtime create failed: container_linux.go:367: starting container process caused: process_linux.go:495: container init caused: process_linux.go:458: setting cgroup config for procHooks process caused: can't load program: function not implemented: unknown
      ERROR: for wg  Cannot start service wg: OCI runtime create failed: container_linux.go:367: starting container process caused: process_linux.go:495: container init caused: process_linux.go:458: setting cgroup config for procHooks process caused: can't load program: function not implemented: unknown
      ERROR: Encountered errors while bringing up the project.
      CrunkFXC 1 Antwort Letzte Antwort
      • dslraserD dslraser
        docker-compose up
        leider kein Erfolg
        CrunkFXC Offline
        CrunkFXC Offline
        CrunkFX
        Forum Testing
        @dslraser zeig mal bitte den output von:
        ls /boot
        • CrunkFXC CrunkFX
          ls /boot
          dslraserD Offline
          dslraserD Offline
          dslraser
          ls /boot
          root@tinkerboard:/opt/wireguard-ui# cd
          root@tinkerboard:~# ls /boot
          armbianEnv.txt                  boot.scr                  dtb                           System.map-5.10.0-9-rt-armmp  uInitrd-5.10.60-rockchip
          armbian_first_run.txt.template  cmdline.txt               dtb-5.10.60-rockchip          System.map-5.10.60-rockchip   vmlinuz-5.10.0-9-rt-armmp
          boot.bmp                        config-5.10.0-9-rt-armmp  initrd.img-5.10.0-9-rt-armmp  uInitrd                       vmlinuz-5.10.60-rockchip
          boot.cmd                        config-5.10.60-rockchip   initrd.img-5.10.60-rockchip   uInitrd-5.10.0-9-rt-armmp     zImage
          root@tinkerboard:~#
            ls /boot
            root@tinkerboard:~#
            CrunkFXC Offline
            CrunkFXC Offline
            CrunkFX
            Forum Testing
            @dslraser Kannst du einmal das docker Installationsscript Ausführen:
            curl -fsSL https://get.docker.com | sh
            • CrunkFXC CrunkFX
              dslraserD Offline
              dslraserD Offline
              dslraser
              root@tinkerboard:~# curl -fsSL https://get.docker.com | sh
              # Executing docker install script, commit: 93d2499759296ac1f9c510605fef85052a2c32be
              Warning: the "docker" command appears to already exist on this system.
              If you already have Docker installed, this script can cause trouble, which is
              why we're displaying this warning and provide the opportunity to cancel the
              installation.
              If you installed the current Docker package using this script and are using it
              again to update Docker, you can safely ignore this message.
              You may press Ctrl+C now to abort this script.
              + sleep 20
              + sh -c apt-get update -qq >/dev/null
              + sh -c DEBIAN_FRONTEND=noninteractive apt-get install -y -qq apt-transport-https ca-certificates curl >/dev/null
              + sh -c curl -fsSL "https://download.docker.com/linux/debian/gpg" | gpg --dearmor --yes -o /usr/share/keyrings/docker-archive-keyring.gpg
              + sh -c echo "deb [arch=armhf signed-by=/usr/share/keyrings/docker-archive-keyring.gpg] https://download.docker.com/linux/debian bullseye stable" > /etc/apt/sources.list.d/docker.list
              + sh -c DEBIAN_FRONTEND=noninteractive apt-get install -y -qq --no-install-recommends  docker-ce-cli docker-ce >/dev/null
              + version_gte 20.10
              + [ -z  ]
              + return 0
              + sh -c DEBIAN_FRONTEND=noninteractive apt-get install -y -qq docker-ce-rootless-extras >/dev/null
              + sh -c docker version
              Client: Docker Engine - Community
              Version:           20.10.11
              API version:       1.41
              Go version:        go1.16.9
              Git commit:        dea9396
              Built:             Thu Nov 18 00:37:17 2021
              OS/Arch:           linux/arm
              Context:           default
              Experimental:      true
              Server: Docker Engine - Community
              Engine:
               Version:          20.10.11
               API version:      1.41 (minimum version 1.12)
               Git commit:       847da18
               Built:            Thu Nov 18 00:35:33 2021
               OS/Arch:          linux/arm
               Experimental:     false
              containerd:
               Version:          1.4.12
               GitCommit:        7b11cfaabd73bb80907dd23182b9347b4245eb5d
              runc:
               Version:          1.0.2
               GitCommit:        v1.0.2-0-g52b36a2
              docker-init:
               Version:          0.19.0
               GitCommit:        de40ad0
              To run Docker as a non-privileged user, consider setting up the
              Docker daemon in rootless mode for your user:
                 dockerd-rootless-setuptool.sh install
              Visit https://docs.docker.com/go/rootless/ to learn about rootless mode.
              To run the Docker daemon as a fully privileged service, but granting non-root
              users access, refer to https://docs.docker.com/go/daemon-access/
              WARNING: Access to the remote API on a privileged Docker daemon is equivalent
                      to root access on the host. Refer to the 'Docker daemon attack surface'
                      documentation for details: https://docs.docker.com/go/attack-surface/
              Ich installiere WG mit Deinem Script jetzt dann nochmal ? (hatte ich gerade deinstalliert)
                installation.
                + sleep 20
                + version_gte 20.10
                + [ -z  ]
                + return 0
                Version:           20.10.11
                API version:       1.41
                Git commit:        dea9396
                OS/Arch:           linux/arm
                Context:           default
                Experimental:      true
                Engine:
                 Version:          20.10.11
                 Git commit:       847da18
                 OS/Arch:          linux/arm
                 Experimental:     false
                containerd:
                 Version:          1.4.12
                runc:
                 Version:          1.0.2
                docker-init:
                 Version:          0.19.0
                 GitCommit:        de40ad0
                CrunkFXC Offline
                CrunkFXC Offline
                CrunkFX
                Forum Testing
                @dslraser Versuch nochmal
                Reboot
                docker-compose up
                • CrunkFXC CrunkFX
                  Reboot
                  docker-compose up
                  dslraserD Offline
                  dslraserD Offline
                  dslraser
                  docker-compose up
                  ERROR: Couldn't connect to Docker daemon at http+docker://localhost - is it running?
                  If it's at a non-standard location, specify the URL with the DOCKER_HOST environment variable.
                    docker-compose up
                    CrunkFXC Offline
                    CrunkFXC Offline
                    CrunkFX
                    Forum Testing
                    @dslraser Das ist leider ein armbian Problem, ich werde bei mir ein Test Setup aufbauen und den installer erweitern. Wenn ich es schaffe noch bis Tagesende
                    ScroungerS dslraserD 2 Antworten Letzte Antwort
                    • CrunkFXC CrunkFX
                      ScroungerS Offline
                      ScroungerS Offline
                      Scrounger
                      @crunkfx
                      Hab es heute auch mal getestet - funktioniert wunderbar, vielen Dank dafür!
                      • CrunkFXC CrunkFX
                        dslraserD Offline
                        dslraserD Offline
                        dslraser
                        Konntest Du schon was testen?
                        CrunkFXC 2 Antworten Letzte Antwort
                          CrunkFXC Offline
                          CrunkFXC Offline
                          CrunkFX
                          Forum Testing
                          @dslraser Ja ich bin aktuell dabei das ganze ohne Docker auszulegen, da das auf den ARM und Proxmox Plattformen nur Probleme macht. Allerdings ist das etwas aufwendiger als gehofft. Ich bin gerade in der Testphase
                          • CrunkFXC CrunkFX
                            CrunkFXC Offline
                            CrunkFXC Offline
                            CrunkFX
                            Forum Testing
                            @crunkfx Mal kurz OffTopic: könnt ihr aktuell auf Github Zugreifen?
                            IdleBitI 1 Antwort Letzte Antwort
                            • CrunkFXC CrunkFX
                              IdleBitI Offline
                              IdleBitI Offline
                              IdleBit
                              @crunkfx Nein ich auch nicht :(
                                CrunkFXC Offline
                                CrunkFXC Offline
                                CrunkFX
                                Forum Testing
                                @dslraser @BBTown
                                Ich habe nun den Installer komplett Entdockert😳(Steht so bestimmt im Duden!).
                                Wer testen möchte und bereits die Docker Variante am laufen hat macht folgendes:
                                docker stop wgui
                                docker rm wgui
                                Anschließend für alle:
                                wget https://raw.githubusercontent.com/KleSecGmbH/ioBroker/dev/wireguard/installer-wgui.sh -O installer-wgui.sh && bash installer-wgui.sh
                                Die Konfigdaten liegen im Ordner:
                                /opt/wireguard-ui/db
                                wer damit spielen möchte.
                                NegaleinN dslraserD BBTownB 4 Antworten Letzte Antwort
                                • CrunkFXC CrunkFX
                                  @dslraser @BBTown
                                  docker stop wgui
                                  docker rm wgui
                                  NegaleinN Offline
                                  NegaleinN Offline
                                  Negalein
                                  läuft und alles alte (User, etc.) sind noch da! :)
                                  ° Fixer ---> iob fix
                                  • CrunkFXC CrunkFX
                                    @dslraser @BBTown
                                    docker stop wgui
                                    docker rm wgui
                                    dslraserD Offline
                                    dslraserD Offline
                                    dslraser
                                    @dslraser @BBTown
                                    docker stop wgui
                                    docker rm wgui
                                    Ich bin noch unterwegs. Wenn ich heute Abend zu Hause bin werde ich es probieren.
                                    Vielen Dank für Deine Mühe.
                                    • David G.D Online
                                      David G.D Online
                                      David G.
                                      Hey,
                                      wollte es auch mal testen.
                                      Bei mir kommt:
                                      pi@iobroker: wget https://raw.githubusercontent.com/KleSecGmbH/ioBroker/dev/wireguard/installer-wgui.sh -O installer-wgui.sh && bash installer-wgui.sh
                                      --2021-11-28 10:40:47--  https://raw.githubusercontent.com/KleSecGmbH/ioBroker/dev/wireguard/installer-wgui.sh
                                      Auflösen des Hostnamens raw.githubusercontent.com (raw.githubusercontent.com)… 185.199.111.133, 185.199.110.133, 185.199.109.133, ...
                                      Verbindungsaufbau zu raw.githubusercontent.com (raw.githubusercontent.com)|185.199.111.133|:443 … verbunden.
                                      HTTP-Anforderung gesendet, auf Antwort wird gewartet … 200 OK
                                      Länge: 7758 (7,6K) [text/plain]
                                      Wird in »installer-wgui.sh« gespeichert.
                                      installer-wgui.sh     0%[                    ]       0  --.-KB/s
                                      installer-wgui.sh   100%[===================>]   7,58K  --.-KB/s    in 0,001s
                                      2021-11-28 10:40:47 (11,3 MB/s) - »installer-wgui.sh« gespeichert [7758/7758]
                                      E: Sperrdatei /var/lib/dpkg/lock-frontend konnte nicht geöffnet werden. - open (13: Keine Berechtigung)
                                      E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), are you root?
                                      pi@iobroker:~ $
                                      EDIT:
                                      Diese Meldung bekommeich über meinen SSH-Client an Smartphone. Mit Putty passiert garnichts. Man drückt Enter und die Zeile mit wget verschwindet einfach.
                                      • David G.D David G.
                                        Hey,
                                        Bei mir kommt:
                                        pi@iobroker:~ $
                                        EDIT:
                                        CrunkFXC Offline
                                        CrunkFXC Offline
                                        CrunkFX
                                        Forum Testing
                                        @david-g Versuch mal vor bash sudo zu schreiben.
                                        • CrunkFXC CrunkFX
                                          David G.D Online
                                          David G.D Online
                                          David G.
                                          @crunkfx
                                          Jetzt kommt was.
                                          Aber auch mit Fehler:
                                          wireguard-ui-install V1.0.3 Stand 27.11.2021     @2021 forum.
                                          ┌─────────────────Wollen Sie fortfahren?───────────────────┐
                                          │ Dieser Installer wird Wireguard-UI, sowie alle           │   │ notwendigen Pakete und Paketquellen laden und            │
                                          │ installieren.                                            │
                                          │               <  Ja  >        < Nein >                   │
                                          #### 1.   Updates werden geholt und Installiert
                                          #apt update wird ausgführt
                                          WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
                                          #Erfolgreich
                                          #apt upgrade wird ausgführt
                                          #Erfolgreich
                                          #### 3.   WireGuard-UI wird installiert
                                          mkdir: das Verzeichnis „/opt/wireguard-ui“ kann nicht angelegt werden: Die Datei existiert bereits
                                          --2021-11-28 14:03:52--  https://raw.githubusercontent.com/KleSecGmbH/ioBroker/main/wireguard/wgui.path
                                          Auflösen des Hostnamens raw.githubusercontent.com (raw.githubusercontent.com)… 185.199.111.133, 185.199.109.133, 185.199.110.133, ...
                                          Länge: 143 [text/plain]
                                          Wird in »/etc/systemd/system/wgui.path« gespeichert.
                                          /etc/systemd/sy 100%[======>]     143  --.-KB/s    in 0s
                                          2021-11-28 14:03:52 (2,99 MB/s) - »/etc/systemd/system/wgui.path« gespeichert [143/143]
                                          --2021-11-28 14:03:52--  https://raw.githubusercontent.com/KleSecGmbH/ioBroker/main/wireguard/wgui.service
                                          Länge: 172 [text/plain]
                                          Wird in »/etc/systemd/system/wgui.service« gespeichert.
                                          ┌─────────────────────────ERROR────────────────────────────┐   │ Ups. Irgendwas ist da schiefgeleufen ;(                  │   │                                                          │
                                          │                         <  OK  >                         │
