  4. [Tester gesucht] WireGuard UI Installer
68 Beiträge 11 Kommentatoren 11.3k Aufrufe 14 Beobachtet
  • CrunkFXC CrunkFX
    @dslraser Mach mal:
    cd /opt/wireguard-ui
    docker-compose up
    dslraserD Offline
    dslraserD Offline
    dslraser
    @crunkfx sagte in [Tester gesucht] WireGuard UI Installer:
    docker-compose up
    Finished!
    The client configuration is available in: /root/test.conf
    New clients can be added by running this script again.
    root@tinkerboard:~# cd /opt/wireguard-ui
    root@tinkerboard:/opt/wireguard-ui# docker-compose up
    Removing wgui
    Starting e99836ca4efb_wgui ... error
    ERROR: for e99836ca4efb_wgui  Cannot start service wg: OCI runtime create failed: container_linux.go:367: starting container process caused: process_linux.go:495: container init caused: process_linux.go:458: setting cgroup config for procHooks process caused: can't load program: function not implemented: unknown
    ERROR: for wg  Cannot start service wg: OCI runtime create failed: container_linux.go:367: starting container process caused: process_linux.go:495: container init caused: process_linux.go:458: setting cgroup config for procHooks process caused: can't load program: function not implemented: unknown
    ERROR: Encountered errors while bringing up the project.
    • CrunkFXC Offline
      CrunkFXC Offline
      CrunkFX
      Forum Testing
      @dslraser sagte in [Tester gesucht] WireGuard UI Installer:
      Ich habe leider kein funktionierendes Armbian am laufen aber teste das mal bitte:
      nano /boot/cmdline.txt
      ans Ende anfügen:
      systemd.unified_cgroup_hierarchy=0
      Neustarten
      docker-compose up
      • CrunkFXC CrunkFX
        ans Ende anfügen:
        Neustarten
        docker-compose up
        dslraserD Offline
        dslraserD Offline
        dslraser
        docker-compose up
        leider kein Erfolg
        CrunkFXC 1 Antwort Letzte Antwort
        • dslraserD dslraser
          docker-compose up
          leider kein Erfolg
          CrunkFXC Offline
          CrunkFXC Offline
          CrunkFX
          Forum Testing
          @dslraser zeig mal bitte den output von:
          ls /boot
          • CrunkFXC CrunkFX
            ls /boot
            dslraserD Offline
            dslraserD Offline
            dslraser
            ls /boot
            root@tinkerboard:/opt/wireguard-ui# cd
            root@tinkerboard:~# ls /boot
            armbianEnv.txt                  boot.scr                  dtb                           System.map-5.10.0-9-rt-armmp  uInitrd-5.10.60-rockchip
            armbian_first_run.txt.template  cmdline.txt               dtb-5.10.60-rockchip          System.map-5.10.60-rockchip   vmlinuz-5.10.0-9-rt-armmp
            boot.bmp                        config-5.10.0-9-rt-armmp  initrd.img-5.10.0-9-rt-armmp  uInitrd                       vmlinuz-5.10.60-rockchip
            boot.cmd                        config-5.10.60-rockchip   initrd.img-5.10.60-rockchip   uInitrd-5.10.0-9-rt-armmp     zImage
            root@tinkerboard:~#
              ls /boot
              root@tinkerboard:~#
              CrunkFXC Offline
              CrunkFXC Offline
              CrunkFX
              Forum Testing
              @dslraser Kannst du einmal das docker Installationsscript Ausführen:
              curl -fsSL https://get.docker.com | sh
              • CrunkFXC CrunkFX
                dslraserD Offline
                dslraserD Offline
                dslraser
                root@tinkerboard:~# curl -fsSL https://get.docker.com | sh
                # Executing docker install script, commit: 93d2499759296ac1f9c510605fef85052a2c32be
                Warning: the "docker" command appears to already exist on this system.
                If you already have Docker installed, this script can cause trouble, which is
                why we're displaying this warning and provide the opportunity to cancel the
                installation.
                If you installed the current Docker package using this script and are using it
                again to update Docker, you can safely ignore this message.
                You may press Ctrl+C now to abort this script.
                + sleep 20
                + sh -c apt-get update -qq >/dev/null
                + sh -c DEBIAN_FRONTEND=noninteractive apt-get install -y -qq apt-transport-https ca-certificates curl >/dev/null
                + sh -c curl -fsSL "https://download.docker.com/linux/debian/gpg" | gpg --dearmor --yes -o /usr/share/keyrings/docker-archive-keyring.gpg
                + sh -c echo "deb [arch=armhf signed-by=/usr/share/keyrings/docker-archive-keyring.gpg] https://download.docker.com/linux/debian bullseye stable" > /etc/apt/sources.list.d/docker.list
                + sh -c DEBIAN_FRONTEND=noninteractive apt-get install -y -qq --no-install-recommends  docker-ce-cli docker-ce >/dev/null
                + version_gte 20.10
                + [ -z  ]
                + return 0
                + sh -c DEBIAN_FRONTEND=noninteractive apt-get install -y -qq docker-ce-rootless-extras >/dev/null
                + sh -c docker version
                Client: Docker Engine - Community
                Version:           20.10.11
                API version:       1.41
                Go version:        go1.16.9
                Git commit:        dea9396
                Built:             Thu Nov 18 00:37:17 2021
                OS/Arch:           linux/arm
                Context:           default
                Experimental:      true
                Server: Docker Engine - Community
                Engine:
                 Version:          20.10.11
                 API version:      1.41 (minimum version 1.12)
                 Git commit:       847da18
                 Built:            Thu Nov 18 00:35:33 2021
                 OS/Arch:          linux/arm
                 Experimental:     false
                containerd:
                 Version:          1.4.12
                 GitCommit:        7b11cfaabd73bb80907dd23182b9347b4245eb5d
                runc:
                 Version:          1.0.2
                 GitCommit:        v1.0.2-0-g52b36a2
                docker-init:
                 Version:          0.19.0
                 GitCommit:        de40ad0
                To run Docker as a non-privileged user, consider setting up the
                Docker daemon in rootless mode for your user:
                   dockerd-rootless-setuptool.sh install
                Visit https://docs.docker.com/go/rootless/ to learn about rootless mode.
                To run the Docker daemon as a fully privileged service, but granting non-root
                users access, refer to https://docs.docker.com/go/daemon-access/
                WARNING: Access to the remote API on a privileged Docker daemon is equivalent
                        to root access on the host. Refer to the 'Docker daemon attack surface'
                        documentation for details: https://docs.docker.com/go/attack-surface/
                Ich installiere WG mit Deinem Script jetzt dann nochmal ? (hatte ich gerade deinstalliert)
                  installation.
                  + sleep 20
                  + version_gte 20.10
                  + [ -z  ]
                  + return 0
                  Version:           20.10.11
                  API version:       1.41
                  Git commit:        dea9396
                  OS/Arch:           linux/arm
                  Context:           default
                  Experimental:      true
                  Engine:
                   Version:          20.10.11
                   Git commit:       847da18
                   OS/Arch:          linux/arm
                   Experimental:     false
                  containerd:
                   Version:          1.4.12
                  runc:
                   Version:          1.0.2
                  docker-init:
                   Version:          0.19.0
                   GitCommit:        de40ad0
                  CrunkFXC Offline
                  CrunkFXC Offline
                  CrunkFX
                  Forum Testing
                  @dslraser Versuch nochmal
                  Reboot
                  docker-compose up
                  • CrunkFXC CrunkFX
                    Reboot
                    docker-compose up
                    dslraserD Offline
                    dslraserD Offline
                    dslraser
                    docker-compose up
                    ERROR: Couldn't connect to Docker daemon at http+docker://localhost - is it running?
                    If it's at a non-standard location, specify the URL with the DOCKER_HOST environment variable.
                      docker-compose up
                      CrunkFXC Offline
                      CrunkFXC Offline
                      CrunkFX
                      Forum Testing
                      @dslraser Das ist leider ein armbian Problem, ich werde bei mir ein Test Setup aufbauen und den installer erweitern. Wenn ich es schaffe noch bis Tagesende
                      ScroungerS dslraserD 2 Antworten Letzte Antwort
                      • CrunkFXC CrunkFX
                        ScroungerS Offline
                        ScroungerS Offline
                        Scrounger
                        @crunkfx
                        Hab es heute auch mal getestet - funktioniert wunderbar, vielen Dank dafür!
                        • CrunkFXC CrunkFX
                          dslraserD Offline
                          dslraserD Offline
                          dslraser
                          Konntest Du schon was testen?
                          CrunkFXC 2 Antworten Letzte Antwort
                            CrunkFXC Offline
                            CrunkFXC Offline
                            CrunkFX
                            Forum Testing
                            @dslraser Ja ich bin aktuell dabei das ganze ohne Docker auszulegen, da das auf den ARM und Proxmox Plattformen nur Probleme macht. Allerdings ist das etwas aufwendiger als gehofft. Ich bin gerade in der Testphase
                            • CrunkFXC CrunkFX
                              CrunkFXC Offline
                              CrunkFXC Offline
                              CrunkFX
                              Forum Testing
                              @crunkfx Mal kurz OffTopic: könnt ihr aktuell auf Github Zugreifen?
                              IdleBitI 1 Antwort Letzte Antwort
                              • CrunkFXC CrunkFX
                                IdleBitI Offline
                                IdleBitI Offline
                                IdleBit
                                @crunkfx Nein ich auch nicht :(
                                  CrunkFXC Offline
                                  CrunkFXC Offline
                                  CrunkFX
                                  Forum Testing
                                  @dslraser @BBTown
                                  Ich habe nun den Installer komplett Entdockert😳(Steht so bestimmt im Duden!).
                                  Wer testen möchte und bereits die Docker Variante am laufen hat macht folgendes:
                                  docker stop wgui
                                  docker rm wgui
                                  Anschließend für alle:
                                  wget https://raw.githubusercontent.com/KleSecGmbH/ioBroker/dev/wireguard/installer-wgui.sh -O installer-wgui.sh && bash installer-wgui.sh
                                  Die Konfigdaten liegen im Ordner:
                                  /opt/wireguard-ui/db
                                  wer damit spielen möchte.
                                  NegaleinN dslraserD BBTownB 4 Antworten Letzte Antwort
                                  • CrunkFXC CrunkFX
                                    @dslraser @BBTown
                                    docker stop wgui
                                    docker rm wgui
                                    NegaleinN Offline
                                    NegaleinN Offline
                                    Negalein
                                    läuft und alles alte (User, etc.) sind noch da! :)
                                    ° Fixer ---> iob fix
                                    • CrunkFXC CrunkFX
                                      @dslraser @BBTown
                                      docker stop wgui
                                      docker rm wgui
                                      dslraserD Offline
                                      dslraserD Offline
                                      dslraser
                                      @dslraser @BBTown
                                      docker stop wgui
                                      docker rm wgui
                                      Ich bin noch unterwegs. Wenn ich heute Abend zu Hause bin werde ich es probieren.
                                      Vielen Dank für Deine Mühe.
                                      • David G.D Online
                                        David G.D Online
                                        David G.
                                        Hey,
                                        wollte es auch mal testen.
                                        Bei mir kommt:
                                        pi@iobroker: wget https://raw.githubusercontent.com/KleSecGmbH/ioBroker/dev/wireguard/installer-wgui.sh -O installer-wgui.sh && bash installer-wgui.sh
                                        --2021-11-28 10:40:47--  https://raw.githubusercontent.com/KleSecGmbH/ioBroker/dev/wireguard/installer-wgui.sh
                                        Auflösen des Hostnamens raw.githubusercontent.com (raw.githubusercontent.com)… 185.199.111.133, 185.199.110.133, 185.199.109.133, ...
                                        Verbindungsaufbau zu raw.githubusercontent.com (raw.githubusercontent.com)|185.199.111.133|:443 … verbunden.
                                        HTTP-Anforderung gesendet, auf Antwort wird gewartet … 200 OK
                                        Länge: 7758 (7,6K) [text/plain]
                                        Wird in »installer-wgui.sh« gespeichert.
                                        installer-wgui.sh     0%[                    ]       0  --.-KB/s
                                        installer-wgui.sh   100%[===================>]   7,58K  --.-KB/s    in 0,001s
                                        2021-11-28 10:40:47 (11,3 MB/s) - »installer-wgui.sh« gespeichert [7758/7758]
                                        E: Sperrdatei /var/lib/dpkg/lock-frontend konnte nicht geöffnet werden. - open (13: Keine Berechtigung)
                                        E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), are you root?
                                        pi@iobroker:~ $
                                        EDIT:
                                        Diese Meldung bekommeich über meinen SSH-Client an Smartphone. Mit Putty passiert garnichts. Man drückt Enter und die Zeile mit wget verschwindet einfach.
                                        • David G.D David G.
                                          Hey,
                                          Bei mir kommt:
                                          pi@iobroker:~ $
                                          EDIT:
                                          CrunkFXC Offline
                                          CrunkFXC Offline
                                          CrunkFX
                                          Forum Testing
                                          @david-g Versuch mal vor bash sudo zu schreiben.
