  4. [Tester gesucht] WireGuard UI Installer
68 Beiträge 11 Kommentatoren 11.3k Aufrufe 14 Beobachtet
  • dslraserD dslraser
    @crunkfx sagte in [Tester gesucht] WireGuard UI Installer:
    ls /boot
    root@tinkerboard:/opt/wireguard-ui# cd
    root@tinkerboard:~# ls /boot
    armbianEnv.txt                  boot.scr                  dtb                           System.map-5.10.0-9-rt-armmp  uInitrd-5.10.60-rockchip
    armbian_first_run.txt.template  cmdline.txt               dtb-5.10.60-rockchip          System.map-5.10.60-rockchip   vmlinuz-5.10.0-9-rt-armmp
    boot.bmp                        config-5.10.0-9-rt-armmp  initrd.img-5.10.0-9-rt-armmp  uInitrd                       vmlinuz-5.10.60-rockchip
    boot.cmd                        config-5.10.60-rockchip   initrd.img-5.10.60-rockchip   uInitrd-5.10.0-9-rt-armmp     zImage
    root@tinkerboard:~#
    CrunkFXC Offline
    CrunkFXC Offline
    CrunkFX
    Forum Testing
    @dslraser Kannst du einmal das docker Installationsscript Ausführen:
    curl -fsSL https://get.docker.com | sh
    • CrunkFXC CrunkFX
      dslraserD Offline
      dslraserD Offline
      dslraser
      root@tinkerboard:~# curl -fsSL https://get.docker.com | sh
      # Executing docker install script, commit: 93d2499759296ac1f9c510605fef85052a2c32be
      Warning: the "docker" command appears to already exist on this system.
      If you already have Docker installed, this script can cause trouble, which is
      why we're displaying this warning and provide the opportunity to cancel the
      installation.
      If you installed the current Docker package using this script and are using it
      again to update Docker, you can safely ignore this message.
      You may press Ctrl+C now to abort this script.
      + sleep 20
      + sh -c apt-get update -qq >/dev/null
      + sh -c DEBIAN_FRONTEND=noninteractive apt-get install -y -qq apt-transport-https ca-certificates curl >/dev/null
      + sh -c curl -fsSL "https://download.docker.com/linux/debian/gpg" | gpg --dearmor --yes -o /usr/share/keyrings/docker-archive-keyring.gpg
      + sh -c echo "deb [arch=armhf signed-by=/usr/share/keyrings/docker-archive-keyring.gpg] https://download.docker.com/linux/debian bullseye stable" > /etc/apt/sources.list.d/docker.list
      + sh -c DEBIAN_FRONTEND=noninteractive apt-get install -y -qq --no-install-recommends  docker-ce-cli docker-ce >/dev/null
      + version_gte 20.10
      + [ -z  ]
      + return 0
      + sh -c DEBIAN_FRONTEND=noninteractive apt-get install -y -qq docker-ce-rootless-extras >/dev/null
      + sh -c docker version
      Client: Docker Engine - Community
      Version:           20.10.11
      API version:       1.41
      Go version:        go1.16.9
      Git commit:        dea9396
      Built:             Thu Nov 18 00:37:17 2021
      OS/Arch:           linux/arm
      Context:           default
      Experimental:      true
      Server: Docker Engine - Community
      Engine:
       Version:          20.10.11
       API version:      1.41 (minimum version 1.12)
       Git commit:       847da18
       Built:            Thu Nov 18 00:35:33 2021
       OS/Arch:          linux/arm
       Experimental:     false
      containerd:
       Version:          1.4.12
       GitCommit:        7b11cfaabd73bb80907dd23182b9347b4245eb5d
      runc:
       Version:          1.0.2
       GitCommit:        v1.0.2-0-g52b36a2
      docker-init:
       Version:          0.19.0
       GitCommit:        de40ad0
      To run Docker as a non-privileged user, consider setting up the
      Docker daemon in rootless mode for your user:
         dockerd-rootless-setuptool.sh install
      Visit https://docs.docker.com/go/rootless/ to learn about rootless mode.
      To run the Docker daemon as a fully privileged service, but granting non-root
      users access, refer to https://docs.docker.com/go/daemon-access/
      WARNING: Access to the remote API on a privileged Docker daemon is equivalent
              to root access on the host. Refer to the 'Docker daemon attack surface'
              documentation for details: https://docs.docker.com/go/attack-surface/
      Ich installiere WG mit Deinem Script jetzt dann nochmal ? (hatte ich gerade deinstalliert)
      CrunkFXC 1 Antwort Letzte Antwort
        installation.
        + sleep 20
        + version_gte 20.10
        + [ -z  ]
        + return 0
        Version:           20.10.11
        API version:       1.41
        Git commit:        dea9396
        OS/Arch:           linux/arm
        Context:           default
        Experimental:      true
        Engine:
         Version:          20.10.11
         Git commit:       847da18
         OS/Arch:          linux/arm
         Experimental:     false
        containerd:
         Version:          1.4.12
        runc:
         Version:          1.0.2
        docker-init:
         Version:          0.19.0
         GitCommit:        de40ad0
        CrunkFXC Offline
        CrunkFXC Offline
        CrunkFX
        Forum Testing
        @dslraser Versuch nochmal
        Reboot
        cd /opt/wireguard-ui
        docker-compose up
        • CrunkFXC CrunkFX
          Reboot
          docker-compose up
          dslraserD Offline
          dslraserD Offline
          dslraser
          docker-compose up
          root@tinkerboard:~# cd /opt/wireguard-ui
          root@tinkerboard:/opt/wireguard-ui# docker-compose up
          ERROR: Couldn't connect to Docker daemon at http+docker://localhost - is it running?
          If it's at a non-standard location, specify the URL with the DOCKER_HOST environment variable.
            docker-compose up
            CrunkFXC Offline
            CrunkFXC Offline
            CrunkFX
            Forum Testing
            @dslraser Das ist leider ein armbian Problem, ich werde bei mir ein Test Setup aufbauen und den installer erweitern. Wenn ich es schaffe noch bis Tagesende
            ScroungerS dslraserD 2 Antworten Letzte Antwort
            • CrunkFXC CrunkFX
              ScroungerS Offline
              ScroungerS Offline
              Scrounger
              @crunkfx
              Hab es heute auch mal getestet - funktioniert wunderbar, vielen Dank dafür!
              • CrunkFXC CrunkFX
                dslraserD Offline
                dslraserD Offline
                dslraser
                Konntest Du schon was testen?
                CrunkFXC 2 Antworten Letzte Antwort
                  CrunkFXC Offline
                  CrunkFXC Offline
                  CrunkFX
                  Forum Testing
                  @dslraser Ja ich bin aktuell dabei das ganze ohne Docker auszulegen, da das auf den ARM und Proxmox Plattformen nur Probleme macht. Allerdings ist das etwas aufwendiger als gehofft. Ich bin gerade in der Testphase
                  • CrunkFXC CrunkFX
                    CrunkFXC Offline
                    CrunkFXC Offline
                    CrunkFX
                    Forum Testing
                    @crunkfx Mal kurz OffTopic: könnt ihr aktuell auf Github Zugreifen?
                    IdleBitI 1 Antwort Letzte Antwort
                    • CrunkFXC CrunkFX
                      IdleBitI Offline
                      IdleBitI Offline
                      IdleBit
                      @crunkfx Nein ich auch nicht :(
                        CrunkFXC Offline
                        CrunkFXC Offline
                        CrunkFX
                        Forum Testing
                        @dslraser @BBTown
                        Ich habe nun den Installer komplett Entdockert😳(Steht so bestimmt im Duden!).
                        Wer testen möchte und bereits die Docker Variante am laufen hat macht folgendes:
                        docker stop wgui
                        docker rm wgui
                        Anschließend für alle:
                        wget https://raw.githubusercontent.com/KleSecGmbH/ioBroker/dev/wireguard/installer-wgui.sh -O installer-wgui.sh && bash installer-wgui.sh
                        Die Konfigdaten liegen im Ordner:
                        /opt/wireguard-ui/db
                        wer damit spielen möchte.
                        NegaleinN dslraserD BBTownB 4 Antworten Letzte Antwort
                        • CrunkFXC CrunkFX
                          @dslraser @BBTown
                          docker stop wgui
                          docker rm wgui
                          NegaleinN Offline
                          NegaleinN Offline
                          Negalein
                          läuft und alles alte (User, etc.) sind noch da! :)
                          ° Fixer ---> iob fix
                          • CrunkFXC CrunkFX
                            @dslraser @BBTown
                            docker stop wgui
                            docker rm wgui
                            dslraserD Offline
                            dslraserD Offline
                            dslraser
                            @dslraser @BBTown
                            docker stop wgui
                            docker rm wgui
                            Ich bin noch unterwegs. Wenn ich heute Abend zu Hause bin werde ich es probieren.
                            Vielen Dank für Deine Mühe.
                            • David G.D Online
                              David G.D Online
                              David G.
                              Hey,
                              wollte es auch mal testen.
                              Bei mir kommt:
                              pi@iobroker: wget https://raw.githubusercontent.com/KleSecGmbH/ioBroker/dev/wireguard/installer-wgui.sh -O installer-wgui.sh && bash installer-wgui.sh
                              --2021-11-28 10:40:47--  https://raw.githubusercontent.com/KleSecGmbH/ioBroker/dev/wireguard/installer-wgui.sh
                              Auflösen des Hostnamens raw.githubusercontent.com (raw.githubusercontent.com)… 185.199.111.133, 185.199.110.133, 185.199.109.133, ...
                              Verbindungsaufbau zu raw.githubusercontent.com (raw.githubusercontent.com)|185.199.111.133|:443 … verbunden.
                              HTTP-Anforderung gesendet, auf Antwort wird gewartet … 200 OK
                              Länge: 7758 (7,6K) [text/plain]
                              Wird in »installer-wgui.sh« gespeichert.
                              installer-wgui.sh     0%[                    ]       0  --.-KB/s
                              installer-wgui.sh   100%[===================>]   7,58K  --.-KB/s    in 0,001s
                              2021-11-28 10:40:47 (11,3 MB/s) - »installer-wgui.sh« gespeichert [7758/7758]
                              E: Sperrdatei /var/lib/dpkg/lock-frontend konnte nicht geöffnet werden. - open (13: Keine Berechtigung)
                              E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), are you root?
                              pi@iobroker:~ $
                              EDIT:
                              Diese Meldung bekommeich über meinen SSH-Client an Smartphone. Mit Putty passiert garnichts. Man drückt Enter und die Zeile mit wget verschwindet einfach.
                              • David G.D David G.
                                Hey,
                                Bei mir kommt:
                                pi@iobroker:~ $
                                EDIT:
                                CrunkFXC Offline
                                CrunkFXC Offline
                                CrunkFX
                                Forum Testing
                                @david-g Versuch mal vor bash sudo zu schreiben.
                                • CrunkFXC CrunkFX
                                  David G.D Online
                                  David G.D Online
                                  David G.
                                  @crunkfx
                                  Jetzt kommt was.
                                  Aber auch mit Fehler:
                                  wireguard-ui-install V1.0.3 Stand 27.11.2021     @2021 forum.
                                  ┌─────────────────Wollen Sie fortfahren?───────────────────┐
                                  │ Dieser Installer wird Wireguard-UI, sowie alle           │   │ notwendigen Pakete und Paketquellen laden und            │
                                  │ installieren.                                            │
                                  │               <  Ja  >        < Nein >                   │
                                  #### 1.   Updates werden geholt und Installiert
                                  #apt update wird ausgführt
                                  WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
                                  #Erfolgreich
                                  #apt upgrade wird ausgführt
                                  #Erfolgreich
                                  #### 3.   WireGuard-UI wird installiert
                                  mkdir: das Verzeichnis „/opt/wireguard-ui“ kann nicht angelegt werden: Die Datei existiert bereits
                                  --2021-11-28 14:03:52--  https://raw.githubusercontent.com/KleSecGmbH/ioBroker/main/wireguard/wgui.path
                                  Auflösen des Hostnamens raw.githubusercontent.com (raw.githubusercontent.com)… 185.199.111.133, 185.199.109.133, 185.199.110.133, ...
                                  Länge: 143 [text/plain]
                                  Wird in »/etc/systemd/system/wgui.path« gespeichert.
                                  /etc/systemd/sy 100%[======>]     143  --.-KB/s    in 0s
                                  2021-11-28 14:03:52 (2,99 MB/s) - »/etc/systemd/system/wgui.path« gespeichert [143/143]
                                  --2021-11-28 14:03:52--  https://raw.githubusercontent.com/KleSecGmbH/ioBroker/main/wireguard/wgui.service
                                  Länge: 172 [text/plain]
                                  Wird in »/etc/systemd/system/wgui.service« gespeichert.
                                  ┌─────────────────────────ERROR────────────────────────────┐   │ Ups. Irgendwas ist da schiefgeleufen ;(                  │   │                                                          │
                                  │                         <  OK  >                         │
                                    @crunkfx
                                    Jetzt kommt was.
                                    │ installieren.                                            │
                                    │               <  Ja  >        < Nein >                   │
                                    #Erfolgreich
                                    #Erfolgreich
                                    │                         <  OK  >                         │
                                    CrunkFXC Offline
                                    CrunkFXC Offline
                                    CrunkFX
                                    Forum Testing
                                    @david-g Zeig mal den Output von:
                                    systemctl start wireguard-ui
                                    • CrunkFXC CrunkFX
                                      David G.D Online
                                      David G.D Online
                                      David G.
                                      @crunkfx
                                      Last login: Sun Nov 28 14:03:37 2021 from 192.168.99.77
                                      pi@iobroker:~ $ systemctl start wireguard-ui
                                      ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ===
                                      Legitimierung ist zum Starten von »wireguard-ui.service« notwendig.
                                      Authenticating as: ,,, (pi)
                                      Password:
                                      Mit pw:
                                      Last login: Sun Nov 28 14:08:42 2021 from 192.168.99.77
                                      Password:
                                      ==== AUTHENTICATION COMPLETE ===
                                      pi@iobroker:~ $
                                      EDIT:
                                      Tippfehler im PW
                                        @crunkfx
                                        Password:
                                        Mit pw:
                                        Password:
                                        pi@iobroker:~ $
                                        EDIT:
                                        Tippfehler im PW
                                        CrunkFXC Offline
                                        CrunkFXC Offline
                                        CrunkFX
                                        Forum Testing
                                        schrieb am zuletzt editiert von CrunkFX
                                        @david-g nochmal bitte aber mit sudo
                                        • CrunkFXC CrunkFX
                                          David G.D Online
                                          David G.D Online
                                          David G.
                                          @crunkfx
                                          Wird ohne Bestätigung angenommen.
                                          Hab mal einen Status nachgeschoben.
                                          Last login: Sun Nov 28 14:09:34 2021 from 192.168.99.77
                                          pi@iobroker:~ $ sudo systemctl start wireguard-ui
                                          pi@iobroker:~ $ sudo systemctl status wireguard-ui
                                          ● wireguard-ui.service
                                             Loaded: loaded (/etc/systemd/system/wireguard-ui.service; en   Active: failed (Result: exit-code) since Sun 2021-11-28 14:4  Process: 31190 ExecStart=/opt/wireguard-ui/wireguard-ui (code Main PID: 31190 (code=exited, status=203/EXEC)
                                          Nov 28 14:40:08 iobroker systemd[1]: Started wireguard-ui.serviNov 28 14:40:08 iobroker systemd[31190]: wireguard-ui.service: Nov 28 14:40:08 iobroker systemd[31190]: wireguard-ui.service: Nov 28 14:40:08 iobroker systemd[1]: wireguard-ui.service: MainNov 28 14:40:08 iobroker systemd[1]: wireguard-ui.service: Faillines 1-11/11 (END)...skipping...
                                          Nov 28 14:40:08 iobroker systemd[1]: Started wireguard-ui.serviNov 28 14:40:08 iobroker systemd[31190]: wireguard-ui.service: Nov 28 14:40:08 iobroker systemd[31190]: wireguard-ui.service: Nov 28 14:40:08 iobroker systemd[1]: wireguard-ui.service: MainNov 28 14:40:08 iobroker systemd[1]: wireguard-ui.service: Fail~
                                             Loaded: loaded (/etc/systemd/system/wireguard-ui.service; en   Active: failed (Result: exit-code) since Sun 2021-11-28 14:4  Process: 31190 ExecStart=/opt/wireguard-ui/wireguard-ui (code● wireguard-ui.service
                                             Loaded: loaded (/etc/systemd/system/wireguard-ui.service; en   Active: failed (Result: exit-code) since Sun 2021-11-28 14:4  Process: 31190 ExecStart=/opt/wireguard-ui/wireguard-ui (code Main PID: 31190 (code=exited, status=203/EXEC)                Nov 28 14:40:08 iobroker systemd[1]: Started wireguard-ui.serviNov 28 14:40:08 iobroker systemd[31190]: wireguard-ui.service: Nov 28 14:40:08 iobroker systemd[31190]: wireguard-ui.service: Nov 28 14:40:08 iobroker systemd[1]: wireguard-ui.service: MainNov 28 14:40:08 iobroker systemd[1]: wireguard-ui.service: Fail~
                                          lines 1-11/11 (END)
