  4. JavaScript
  5. Script: Alexa Listen pflegen und Anzeigen
javascripttemplate
409 Beiträge 29 Kommentatoren 151.1k Aufrufe 42 Beobachtet
  • H helfi9999
    @liv-in-sky bekomme immer folgenden Fehler:
    31.12.2019, 12:41:48.027 [info ]: javascript.0 (25077) script.js.Test.Skript_1: false
    31.12.2019, 12:42:00.312 [info ]: javascript.0 (25077) script.js.Test.Skript_1:
    31.12.2019, 12:42:04.736 [info ]: javascript.0 (25077) Stop script script.js.Test.Skript_1
    31.12.2019, 12:45:55.304 [info ]: javascript.0 (25077) Start javascript script.js.Test.Skript_1
    31.12.2019, 12:45:55.355 [warn ]: javascript.0 (25077) at writeHTML (script.js.Test.Skript_1:108:2)
    31.12.2019, 12:45:55.355 [warn ]: javascript.0 (25077) at script.js.Test.Skript_1:228:1
    31.12.2019, 12:45:55.362 [info ]: javascript.0 (25077) script.js.Test.Skript_1: registered 2 subscriptions and 1 schedule
    31.12.2019, 12:45:55.385 [info ]: javascript.0 (25077) script.js.Test.Skript_1: NaN
    31.12.2019, 12:45:55.391 [info ]: javascript.0 (25077) script.js.Test.Skript_1:
    31.12.2019, 12:45:55.760 [info ]: javascript.0 (25077) script.js.Test.Skript_1: 0:choose ...;1:test;2:seife;3:seife für lena;4:test;5:neuer Start;
    31.12.2019, 12:46:00.008 [warn ]: javascript.0 (25077) at writeHTML (script.js.Test.Skript_1:108:2)
    31.12.2019, 12:46:00.009 [warn ]: javascript.0 (25077) at Object.<anonymous> (script.js.Test.Skript_1:225:2)
    31.12.2019, 12:47:00.232 [warn ]: javascript.0 (25077) at writeHTML (script.js.Test.Skript_1:108:2)
    31.12.2019, 12:47:00.232 [warn ]: javascript.0 (25077) at Object.<anonymous> (script.js.Test.Skript_1:225:2)
    31.12.2019, 12:47:56.112 [info ]: javascript.0 (25077) script.js.Test.Skript_1: test111
    31.12.2019, 12:47:58.124 [warn ]: javascript.0 (25077) at writeHTML (script.js.Test.Skript_1:144:12)
    31.12.2019, 12:47:58.124 [warn ]: javascript.0 (25077) at Object.<anonymous> (script.js.Test.Skript_1:248:4)
    31.12.2019, 12:47:58.147 [info ]: javascript.0 (25077) script.js.Test.Skript_1:
    31.12.2019, 12:47:58.528 [info ]: javascript.0 (25077) script.js.Test.Skript_1: 0:choose ...;1:test;2:seife;3:test111;4:seife für lena;5:test;6:neuer Start;
    31.12.2019, 12:48:38.989 [info ]: javascript.0 (25077) script.js.Test.Skript_1: werew
    31.12.2019, 12:48:41.003 [warn ]: javascript.0 (25077) at writeHTML (script.js.Test.Skript_1:144:12)
    31.12.2019, 12:48:41.003 [warn ]: javascript.0 (25077) at Object.<anonymous> (script.js.Test.Skript_1:248:4)
    31.12.2019, 12:48:41.025 [info ]: javascript.0 (25077) script.js.Test.Skript_1:
    31.12.2019, 12:48:41.408 [info ]: javascript.0 (25077) script.js.Test.Skript_1: 0:choose ...;1:test;2:seife;3:test111;4:werew;5:seife für lena;6:test;7:neuer Start;
    31.12.2019, 12:49:00.416 [info ]: javascript.0 (25077) script.js.Test.Skript_1: werewwwww
    31.12.2019, 12:49:02.433 [warn ]: javascript.0 (25077) at writeHTML (script.js.Test.Skript_1:144:12)
    31.12.2019, 12:49:02.433 [warn ]: javascript.0 (25077) at Object.<anonymous> (script.js.Test.Skript_1:248:4)
    31.12.2019, 12:49:02.449 [info ]: javascript.0 (25077) script.js.Test.Skript_1:
    31.12.2019, 12:49:02.835 [info ]: javascript.0 (25077) script.js.Test.Skript_1: 0:choose ...;1:test;2:seife;3:test111;4:werew;5:seife für lena;6:test;7:neuer Start;8:werewwwww;
    31.12.2019, 12:51:00.224 [warn ]: javascript.0 (25077) at writeHTML (script.js.Test.Skript_1:144:12)
    31.12.2019, 12:51:00.224 [warn ]: javascript.0 (25077) at Object.<anonymous> (script.js.Test.Skript_1:225:2)
    31.12.2019, 12:51:00.627 [info ]: javascript.0 (25077) script.js.Test.Skript_1: 0:choose ...;1:seife für lena;2:test;3:neuer Start;4:werewwwww;
    31.12.2019, 12:52:00.018 [warn ]: javascript.0 (25077) at writeHTML (script.js.Test.Skript_1:144:12)
    31.12.2019, 12:52:00.018 [warn ]: javascript.0 (25077) at Object.<anonymous> (script.js.Test.Skript_1:225:2)
    31.12.2019, 12:52:00.421 [info ]: javascript.0 (25077) script.js.Test.Skript_1: 0:choose ...;
    31.12.2019, 13:01:32.493 [info ]: javascript.0 (25077) Stop script script.js.Test.Skript_1
    Was habe ich verkehrt eingestellt.
    Hier noch das Script:
    //HIER WIRD PFAD UND FILENAME DEFINIERT
    const path = "/htmlexample.html"; //FIlenamen definieren
    const home ='vis.0' //wo soll das file im iobroker-file-system liegen ? (oder z.b auch iqontrol.meta)
    let braucheEinFile=false; // bei true wird ein file geschrieben - für iqontrol
    let braucheEinVISWidget=true; // bei true wird ein html-tabelle in einen dp geschrieben - siehe nächste zeile
    let dpVIS="javascript.0.TabletVis.Einkauf.Vis" //WICHTIG wenn "braucheEinVISWidget" auf true gesetzt !! dp zusätzlich für VIS-HTML-Basic-Widget
    let dPDELETE="javascript.0.TabletVis.Einkauf.Delete";
    let dPDELETEWert="javascript.0.TabletVis.Einkauf.Delete_Wert";
    let dPDELETEAuswahl="javascript.0.TabletVis.Einkauf.Delete_Auswahl";
    let dpANLEGEN="javascript.0.TabletVis.Einkauf.Anlegen";
    let mySchedule=" * * * * * "; //jede minute
    //HIER DIE SPALTEN ANZAHL DEFINIEREN - jede Spalte einen Wert - in diesem Beispiel sind es 4
    var htmlFeld1='Einkaufen'; // überschrift Tabellen Spalte1
    var htmlFeld2='Finished'; // überschrift Tabellen Spalte2
    var htmlFeld3='Created'; // überschrift Tabellen Spalte3
    var htmlFeld4='Since...'; // überschrift Tabellen Spalte4
    //hier werden die styles für die tabelle definiert
    //ÜBERSCHRIFT ÜBER TABELLE
    let htmlUberschrift=true; // mit Überschrift über der tabelle
    const htmlFeldUeber="ALEXA Einkauf"; // Überschrift
    const htmlFarbUber="white"; // Farbe der Überschrift
    //MEHRERE TABELLEN NEBENEINANDER
    let mehrfachTabelle=1; // bis zu 4 Tabellen werden nebeneinander geschrieben- verkürzt das Ganze, dafür etwas breiter - MÖGLICH 1,2,3,oder 4 !!!
    const htmlFarbZweiteTabelle="black"; // Farbe der Überschrift bei jeder 2.ten Tabelle
    const htmlFarbTableColorUber="black"; // Überschrift in der tabelle - der einzelnen Spalten
    //GANZE TABELLE
    const backgroundAll="#000000";
    const htmlSchriftart="Helvetica";
    const htmlSchriftgroesse="13px";
    //FELDER UND RAHMEN
    const htmlFarbFelderschrift="white"; // SchriftFarbe der Felder
    const htmlFarbFelderschrift2="white"; // SchriftFarbe der Felder für jede 2te Tabelle
    const htmlFarbTableColorGradient1="#66b8ea"; // Gradient - Hintergrund der Tabelle - Verlauffarbe
    const htmlFarbTableColorGradient2="#5f85cf"; // Gradient - Hintergrund der Tabelle - ist dieser Wert gleich Gradient1 gibt es keinen verlauf
    const htmlFarbTableBorderColor="#2C7FB6"; // Farbe des Rahmen - is tdieser gleich den gradienten, sind die rahmen unsichtbar
    const htmlRahmenLinien=1; // Format für Rahmen(Gitter)linien 1=alle - 2=nur vertikal - 3= nur horizontal - 4=keine
    // HIER NICHTS ÄNDERN
    const htmlEnd= '</table></body>';
    const htmlStart= "<!DOCTYPE html><html lang="de"><head><title>Vorlage</title><meta http-equiv="content-type" content="text/html; charset=utf-8"></head><body bgcolor=""+backgroundAll+"">";
    //const htmlUeber= "<p style="color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-weight: bold">"+htmlFeldUeber+"</p>";
    const htmlTabStyleCol= "<table bordercolor=""+htmlFarbTableBorderColor+"" border="3" cellspacing="3" cellpadding="3" rules="cols" style="color:"+htmlFarbFelderschrift+"; font-size:"+htmlSchriftgroesse+
    "; font-family:"+htmlSchriftart+";background-image: linear-gradient(42deg,"+htmlFarbTableColorGradient2+","+htmlFarbTableColorGradient1+");">";
    const htmlTabStyleRow= "<table bordercolor=""+htmlFarbTableBorderColor+"" border="3" cellspacing="3" cellpadding="3" rules="rows" style="color:"+htmlFarbFelderschrift+"; font-size:"+htmlSchriftgroesse+
    const htmlTabStyleAll= "<table bordercolor=""+htmlFarbTableBorderColor+"" border="3" cellspacing="3" cellpadding="3" rules="all" style="color:"+htmlFarbFelderschrift+"; font-size:"+htmlSchriftgroesse+
    const htmlTabStyleNone= "<table bordercolor=""+htmlFarbTableBorderColor+"" border="3" cellspacing="3" cellpadding="3" rules="none" style="color:"+htmlFarbFelderschrift+"; font-size:"+htmlSchriftgroesse+
    const htmlTabUeber1="<tr style="color:"+htmlFarbTableColorUber+"; font-weight: bold">";
    const htmlTabUeber3="</tr>";
    //NICHTS ÄNDERN - abhängig von den oben definierten _Spalten - in diesem Beispiel sind es 4
    var htmlTabUeber2="<td align=center> "+htmlFeld1+" </td><td align=center> "+htmlFeld2+" </td><td align=center> "+htmlFeld3+" </td><td align=center> "+htmlFeld4+" </td>";
    var htmlTabUeber2_1="<td align=center style="color:"+htmlFarbZweiteTabelle+""> "+htmlFeld1+" </td><td align=center style="color:"+htmlFarbZweiteTabelle+""> "+htmlFeld2+
    " </td><td align=center style="color:"+htmlFarbZweiteTabelle+""> "+htmlFeld3+" </td><td align=center style="color:"+htmlFarbZweiteTabelle+""> "+htmlFeld4+
    " </td>";
    var htmlOut="";
    var mix;
    var counter;
    var myIDArr=[];
    var warte;
    var myRememberList="";
    function writeHTML(){
     var htmlTabStyle;
    switch (+htmlRahmenLinien) {
    case 1: htmlTabStyle=htmlTabStyleAll; break;
    case 2: htmlTabStyle=htmlTabStyleCol; break;
    case 3: htmlTabStyle=htmlTabStyleRow; break;
    case 4: htmlTabStyle=htmlTabStyleNone; break;
    htmlOut="";
    counter=-1;
    var htmlTabUeber="";
    switch (mehrfachTabelle) {
    case 1: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber3; break;
    case 2: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
    case 3: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2+htmlTabUeber2+htmlTabUeber3; break;
    case 4: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
    //HIER SIND DIE § WERTE, DIE IN DER SCHLEIFE GEFILTERET WER%DEN - Jede spalte einen wert
    var val1; var val2; var val0; var val3; var valSort; var valID; var myListWerte=""; var myListAuswahl="";
    setState(dPDELETE,0);
    var myArr=[]; var myList=""; var myListArr=[]; myIDArr=[];
    myListArr.push('0'+":"+'choose ...'+";");
    myListWerte=myListWerte+"choose ..."+";";
    myListAuswahl=myListAuswahl+(0+";");
    myIDArr.push("dummy");
    $('alexa2.0.Lists.SHOPPING_LIST.items.*.value').each(function(id, i) { // hier eigene schleife definierenalexa2.0.Lists.SHOPPING_LIST.items.0f43141e-029c-4860-bcd0-828702b0dc86.value
           val0=getState(id).val;
           val1=getState(id.replace("value","completed")).val;
           val2=valSort=getState(id.replace("value","updatedDateTime")).val;
           valID=getState(id.replace("value","id")).val;
           myIDArr.push(valID);
           var yy= (Math.round((new Date()).getTime() / 1000))-Math.round(val2/1000);
           val2=formatDate(getDateObject(val2), "TT.MM - SS:mm:ss")
           val3=(Math.floor( ((yy)/60/60/24) )+"d "+ Math.floor(((yy)/60/60) % 24) +"h "+ Math.floor( ((yy)/60) % 60 )+" m")
           if (val1==false) {val1="❌"} else{val1="✅"}
           myArr.push([val0,val1,val2,val3,valSort]);
           val0=val0.replace(/,/g,'-');
           myListArr.push((i+1)+":"+val0+";");
           myListWerte=myListWerte+val0+";";
           myListAuswahl=myListAuswahl+(i+1)+";";
        //log (myListArr.toString());
       for (var x=0;x<myListArr.length;x++){
         myList=myList.concat(myListArr[x]);
        // log(myListArr[x]);
         //log(myList);
       //log("-----------myList : "+myList)
       if(myList!=myRememberList){
           setState(dPDELETEWert,myListWerte);
           setState(dPDELETEAuswahl,myListAuswahl);
         var timeout = setTimeout(function () {
            var obj = getObject(dPDELETE);
            obj.common.states=myList;
            myRememberList=myList;
            log(myList);
            setObject(dPDELETE, obj);
         }, 400);
    //SORT
    myArr.sort(function (alpha, beta) {
    if (alpha[4] > beta[4])
    return -11;
    if (beta[4] > alpha[4])
    return 1;
    return 0;
    for (var x=0 ; x<myArr.length ; x++) {
    counter++;
    //HIER WERDEN DIE DATEN DER SCHLEIFE ZUSAMMENGESETZT - hat man oben 2 Felder definiert, braucht man hier 2 Werte
    val0=myArr[x][0];
    val1=myArr[x][1];
    val2=myArr[x][2];
    val3=myArr[x][3];
     //HIER WERDEN DIE DATEN DER SCHLEIFE ZUSAMMENGESETZT - hat man oben 4 Felder definiert, braucht man hier 4 Werte
         case 1:                    htmlOut=htmlOut+"<tr><td>&ensp;"+val0+"&ensp;</td><td align=center>&ensp;"+val1+"&ensp;</td><td align=center>&ensp;"+val2+"&ensp;</td><td align=center>&ensp;"+val3+"&ensp;</td></tr>"; break;
        case 2:  if(counter%2==0)  {htmlOut = htmlOut+"<tr><td>&ensp;"+val0+"&ensp;</td><td align=center>&ensp;"+val1+"&ensp;</td><td align=center>&ensp;"+val2+"&ensp;</td><td align=center>&ensp;"+val3+"&ensp;</td>"; }
                              else {htmlOut = htmlOut+"<td style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align=center style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align=center style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td><td  align=center style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val3+"&ensp;</td></tr>";} break;
        case 3: if(counter%3==0 )  {htmlOut = htmlOut+"<tr><td>&ensp;"+val0+"&ensp;</td><td align=center>&ensp;"+val1+"&ensp;</td><td align=center>&ensp;"+val2+"&ensp;</td><td align=center>&ensp;"+val3+"&ensp;</td>"; }
                              else { if(counter%3==1 )  { htmlOut = htmlOut+"<td style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align=center style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align=center style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td><td  align=center style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val3+"&ensp;</td>";}
                                               else    {htmlOut = htmlOut+"<td>&ensp;"+val0+"&ensp;</td><td align=center>&ensp;&ensp;"+val1+"&ensp;</td><td align=center>&ensp;"+val2+"&ensp;</td><td align=center>&ensp;"+val3+"&ensp;</td></tr>";}
                                         } break;
        case 4: if(counter%4==0)  {htmlOut = htmlOut+"<tr><td>&ensp;"+val0+"&ensp;</td><td align=center>&ensp;"+val1+"&ensp;</td><td align=center>&ensp;"+val2+"&ensp;</td><td align=center>&ensp;"+val3+"&ensp;</td>"; }
                                  else {if(counter%2==1 )  { htmlOut = htmlOut+"<td style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align=center style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align=center style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td><td  align=center style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val3+"&ensp;</td>";}
                                               else    {if(counter%2==1 && counter%4==3)  { htmlOut= htmlOut+"<td style=\"color:"+htmlFarbFelderschrift2+"\"&ensp;>"+val0+"&ensp;</td><td  align=center style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td align=center style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td><td  align=center style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val3+"&ensp;</td></tr>";}
        else    {htmlOut = htmlOut = htmlOut+"<td>&ensp;"+val0+"&ensp;</td><td>&ensp;"+val1+"&ensp;</td><td align=center>&ensp;"+val2+"&ensp;</td><td align=center>&ensp;"+val3+"&ensp;</td>";}}
                                         } break;
     } //switch ende
    }; //Schleifen ende
    // tabelle fertigstellen
    case 1: break;
    case 2: mix=Math.abs(((counter+1)%2)-mehrfachTabelle);
    if(mix==1) htmlOut = htmlOut.replace(/</td>$/, '</td><td> </td><td> </td><td> </td><td> </td></tr>');
    break;
    case 3: mix =Math.abs(((counter+1)%3)-mehrfachTabelle);
    if(mix==2) htmlOut = htmlOut.replace(/</td>$/, '</td><td> </td><td> </td><td> </td><td> </td><td> </td><td> </td><td> </td><td> </td></tr>');
    break;
    case 4: mix=Math.abs(((counter+1)%4)-mehrfachTabelle);
    if(mix==3) htmlOut = htmlOut.replace(/</td>$/, '</td><td> </td><td> </td><td> </td><td> </td><td> </td><td> </td><td> </td><td> </td><td> </td><td> <td> </td><td> </td></td></tr>');
    break; }
          //Ausgabe über VIS html widget - tabelle in datenpunkt schreiben - html tabelle ohne html header und body
           var htmlOutVIS="";
           const htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-weight: bold\">"+htmlFeldUeber+"&ensp;&ensp;&ensp;"+(counter+1)+"</p>";
           htmlUberschrift ? htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>" : htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</table>"
           //log(htmlOutVIS);
           if (braucheEinVISWidget) setState(dpVIS, htmlOutVIS );
    //mit oder ohne überschrift
    htmlUberschrift ? htmlOut=htmlStart+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd : htmlOut=htmlStart+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd;
    //log(htmlOut);
    setState(dpANLEGEN,"");
    } // function ende
    //hier wird schleife gestartet und das file geschrieben
    schedule(mySchedule, function () {
    writeHTML();
    if (braucheEinFile) {writeFile(home, path ,htmlOut, function (error) { /* log('file written');*/ });}
    writeHTML();
    on({id: dPDELETE, ack: false, change: "ne"}, function (obj) {
    let a=getState(dPDELETE).val;
    if (a!=0){
    let toDelete=myIDArr[getState(dPDELETE).val];
    var stateHelp="alexa2.0.Lists.SHOPPING_LIST.items."+toDelete+".#delete"
    setState(stateHelp,true);
    writeHTML(); }, 2000);
    log(a+stateHelp)
    on({id: dpANLEGEN, ack: false, change: "ne"}, function (obj) {
    log(getState(dpANLEGEN).val);
    if(getState(dpANLEGEN).val!="") {
    setState("alexa2.0.Lists.SHOPPING_LIST.#New",getState(dpANLEGEN).val)
    Hoffe du kannst mir helfen
    liv-in-skyL
    liv-in-skyL
    @helfi9999
    bitte stelle die scripts mit dem code tag ins forum - also zuerst spoiler - dann im spoiler den code tag
    https://forum.iobroker.net/post/348376
    • liv-in-skyL liv-in-sky
      es gibt ein update der scripte
      • wer updaten will sollte sich eine kopie behalten, es muss alles ersetzt werden, da neue settings dazugekommen sind - aus der kopie kann man dann die farben und settings wieder rauskopieren
      • dazu gekommen ist:
        -ein etwa bessere html-definition für den browser (falls man sich ein file generieren läßt)
        -tabellen weite
        -größe der zellen
        -das schedule ist jetzt oben einstellbar
      sigi234S
      sigi234S
      @liv-in-sky sagte in Script: Alexa Listen pflegen und Anzeigen:
        -tabellen weite
        -größe der zellen
      Puh, gerade mit der Vis fertig geworden. Umbauen.
      • sigi234S sigi234
          -tabellen weite
          -größe der zellen
        liv-in-skyL
        liv-in-skyL
        @sigi234 die vis bleibt ja - nur die scripts nochmal einstellen - aber warte noch - das mit dem hintergrund für die files muss ich nochmal checken - da ist wohl ein würmchen drin - vielleicht gibt es nochmal ein update
          sigi234S
          sigi234S
          Ok, kann man dann auch die Überschriften unabhängig von den Zellen ausrichten?
          • Agria4800A Agria4800
            @Agria4800
            vielleicht probiere ich das mal aus - manchmal will man einfach papier in der hand haben
            ich habe oft nur ein paar wenige sachen - wenn ich dann vor meine standard geschäfte fahre (penny und so) , öffnet sich die webseite auf dem handy automatisch, wenn ich vor dem laden stehe und der motor ausgeht - dann zeigt es mir die 2-3 sachen zur erinnerung an und ich lass das handy einfach im auto - wollte mal etwas mit tasker auf android spielen !
            muss mal schauen, ob ich das html file auch zu tasker rüber bekomme - dann ein link auf den desktop und die alexa app bleibt zu
            ps: in den neuen scripts ist die größe der zellen und natürlich die schriftgröße einstellbar - dann kannst du am layout deiner pdf's arbeiten
            Das ist natürlich auch ne prima Sache, aber nix für meine Frau...da geht nur das gute alte Papier ;-)
            Ich bin grad unter Zeitdruck, wollte nur mal schnell testen,... die Größe der Tabelle und die Schrift ändern geht... aber der Hintergrund außerhalb der Tabelle bleibt schwarz bei mir... (Vielleicht mache ich auf die schnelle was falsch)
            geändert habe ich :
            35 I const backgroundAll="white"; #ffffff will auch nicht....
            Geh heute Abend nochmal in Ruhe dran
            liv-in-skyL
            liv-in-skyL
            @Agria4800 ne - hab ich verbockt !! - der background-schlingel hat sich versteckt
            im ersten post sind neue scripts
            oder einfacher unter der const htmlStart:
            ersetze zeile (ungefähr) 66 mit :
            "<style> * {  margin: 0;} body {background-color: "+backgroundAll+"; margin: 0 auto;  }"+
            hat vorher so ausgesehen
            "<style> * {  margin: 0;} body {background-color: black; margin: 0 auto;  }"+
            Agria4800A 1 Antwort Letzte Antwort
            • sigi234S sigi234
              liv-in-skyL
              liv-in-skyL
              @sigi234 nein - aber einfach abschalten und extra in der vis etwas einfügen - ginge das ?
              ungefähr zeile 24
              let htmlUberschrift=true; auf false setzen
              • sigi234S sigi234
                liv-in-skyL
                liv-in-skyL
                @sigi234 falls du die anzahl noch brauchst - ist ja in der überschrift integriert , gibt es da ein blockly um die anzahl extra heraus zu filtern und in einen dp zu schreiben
                https://forum.iobroker.net/post/348476
                  ungefähr zeile 24
                  sigi234S
                  sigi234S
                  ungefähr zeile 24
                  Ja das habe ich sowieso auf false, ich meine das:
                  • sigi234S sigi234
                    ungefähr zeile 24
                    liv-in-skyL
                    liv-in-skyL
                    @sigi234 nein geht auch nicht - was hättest du den gerne für eine ausrichtung
                    geht es um den ersten wert ?
                      sigi234S
                      sigi234S
                      Um Alle, die richten sich ja mittig aus. Left wäre noch gut. Außer Wert 2.
                      var htmlFeld1='Zu erledigen'; // überschrift Tabellen Spalte1 / Option Ausrichtung
                      var htmlFeld2='Status'; // überschrift Tabellen Spalte2 / Option Ausrichtung
                      var htmlFeld3='Erstellt'; // überschrift Tabellen Spalte3 / Option Ausrichtung
                      var htmlFeld4='Seit...'; // überschrift Tabellen Spalte4 / Option Ausrichtung
                      • sigi234S sigi234
                        liv-in-skyL
                        liv-in-skyL
                        @sigi234 aber alle die sind zentriert (bis auf die linke/erste spalte) - da sieht es doof aus, wenn die überschriften dann links sind - außer beim ersten wert - da macht links sinn, weil ja die werte auch alle links sind - glaub ich werd das noch ändern
                        die option für jede spalte eine eigene ausrichtung zu integrieren wäre sehr aufwendig und würde erst wichtig werden, wenn man mehrere zeilen pro zelle hätte , dann würde es etwas chaotisch aussehen - anfangs hatte ich alles links - dass sieht aber sehr schlecht aus, wenn nur ein kästchen oder etwas kleines in der zelle ist
                          sigi234S
                          sigi234S
                          @liv-in-sky
                          Theoretisch kann ich sie ja ausblenden. 🙂
                          • sigi234S sigi234
                            @liv-in-sky
                            liv-in-skyL
                            liv-in-skyL
                            @sigi234 da könnt ich evtl aber eine einstellung machen - keine tabellenwerte-überschrift
                              Habe das mit der Anzahl der Einträge in seperater Anzeige mal anders gelöst.
                              Wollte da keinen neuen Schedule für haben.
                              Die Werte sind ja schon da also schneide ich sie ab.
                              sigi234S
                              sigi234S
                              @Yetiberg sagte in Script: Alexa Listen pflegen und Anzeigen:
                              Wie kommst du auf die Anzahl?
                              • sigi234S sigi234
                                liv-in-skyL
                                liv-in-skyL
                                @sigi234 er liest sie aus dem auswahlDeleteAuswahl-datenpunkt aus - da steht die anzahl drin und wird auch upgedatet - es ist der letzte wert
                                • sigi234S sigi234
                                  liv-in-skyL
                                  liv-in-skyL
                                  #66
                                  @sigi234
                                  spaltenüberschriften können nun abgeschalten werden
                                    sigi234S
                                    sigi234S
                                    #67
                                    Bekomme immer ein ; angezeigt?
                                    • sigi234S sigi234
                                      liv-in-skyL
                                      liv-in-skyL
                                      #68
                                      @sigi234 habe es nie ausprobiert - gib mir bitte export - dann test ich mal
                                        #69
                                        Ich bin da noch bei, das wegzufiltern.
                                        Ich hatte das getestet wo ich mehr als 9 in der Liste hatte.
                                        Wartet mal ein wenig. Ich schaue mal.
                                        liv-in-skyL sigi234S 2 Antworten Letzte Antwort
                                          liv-in-skyL
                                          liv-in-skyL
                                          #70
                                          @Yetiberg übernimmst du ?
                                          33.2k
                                          84.3k
