  4. Anfrage Tahoma/Somfy IO Adapter
611 Beiträge 103 Kommentatoren 306.3k Aufrufe 86 Beobachtet
  • G Gre4t0ne
    Bei mir funktioniert der Adapter ABER das Protokoll wird mit folgenden Warnings überschwemmt:
    025-01-02 21:31:58.979	warn	Body: {"errorCode":"UNSPECIFIED_ERROR","error":"\"No registered event listener.\""}
    tahoma.0
    2025-01-02 21:31:58.978	warn	Response: {"statusCode":400,"body":{"errorCode":"UNSPECIFIED_ERROR","error":"\"No registered event listener.\""},"headers":{"content-type":"application/json","access-control-allow-origin":"*","access-control-allow-headers":"Authorization","content-length":"77","connection":"close","date":"Thu, 02 Jan 2025 20:31:58 GMT","server":"KizOs"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"gateway-2080-0101-7321.local:8443","port":"8443","hostname":"gateway-2080-0101-7321.local","hash":null,"search":null,"query":null,"pathname":"/enduser-mobile-web/1/enduserAPI/events/9aac0498-8cbd-4cc9-884b-33532b7fce55/fetch","path":"/enduser-mobile-web/1/enduserAPI/events/9aac0498-8cbd-4cc9-884b-33532b7fce55/fetch","href":"https://gateway-2080-0101-7321.local:8443/enduser-mobile-web/1/enduserAPI/events/9aac0498-8cbd-4cc9-884b-33532b7fce55/fetch"},"method":"POST","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:79.0) Gecko/20100101 Firefox/79.0","Authorization":"Bearer 66f2f74093e4a56b44ac","Content-type":"application/json","accept":"application/json","content-length":2}}}
    tahoma.0
    2025-01-02 21:31:58.978	warn	error during request: null, request path: events/9aac0498-8cbd-4cc9-884b-33532b7fce55/fetch with payload:{}
    tahoma.0
    2025-01-02 21:31:39.043	warn	Body: {"errorCode":"UNSPECIFIED_ERROR","error":"\"No registered event listener.\""}
    tahoma.0
    2025-01-02 21:31:39.042	warn	Response: {"statusCode":400,"body":{"errorCode":"UNSPECIFIED_ERROR","error":"\"No registered event listener.\""},"headers":{"content-type":"application/json","access-control-allow-origin":"*","access-control-allow-headers":"Authorization","content-length":"77","connection":"close","date":"Thu, 02 Jan 2025 20:31:39 GMT","server":"KizOs"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"gateway-2080-0101-7321.local:8443","port":"8443","hostname":"gateway-2080-0101-7321.local","hash":null,"search":null,"query":null,"pathname":"/enduser-mobile-web/1/enduserAPI/events/9aac0498-8cbd-4cc9-884b-33532b7fce55/fetch","path":"/enduser-mobile-web/1/enduserAPI/events/9aac0498-8cbd-4cc9-884b-33532b7fce55/fetch","href":"https://gateway-2080-0101-7321.local:8443/enduser-mobile-web/1/enduserAPI/events/9aac0498-8cbd-4cc9-884b-33532b7fce55/fetch"},"method":"POST","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:79.0) Gecko/20100101 Firefox/79.0","Authorization":"Bearer 66f2f74093e4a56b44ac","Content-type":"application/json","accept":"application/json","content-length":2}}}
    tahoma.0
    2025-01-02 21:31:39.042	warn	error during request: null, request path: events/9aac0498-8cbd-4cc9-884b-33532b7fce55/fetch with payload:{}
    gammler2003
    #588
    @gre4t0ne Ich habe exakt die selbe Situation - der Adapter funktioniert, aber spuckt in ständig diese Fehlermeldung aus. Ich nutze den Zugang über die lokale API auf eine Tahoma Classic.
    Gibt es hier in der Runde Ideen, woran das liegen könnte? Vielen Dank euch vorab.
    • G gammler2003
      Kanumouse
      #589
      Ich habe den gleichen Fehler.
      Es kommt immer folgende Warnmeldung:
      Response: {"statusCode":400,"body":"{\"errorCode\":\"UNSPECIFIED_ERROR\",\"error\":\"Unknown object.\"}","headers":{"content-type":"application/json","access-control-allow-origin":"*","access-control-allow-headers":"Authorization, Content-Type","content-length":"59","connection":"close","date":"Sat, 01 Feb 2025 15:15:17 GMT","server":"KizOs"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"gateway-2052-7119-6399:8443","port":"8443","hostname":"gateway-2052-7119-6399","hash":null,"search":null,"query":null,"pathname":"/enduser-mobile-web/1/enduserAPI/setup","path":"/enduser-mobile-web/1/enduserAPI/setup","href":"https://gateway-2052-7119-6399:8443/enduser-mobile-web/1/enduserAPI/setup"},"method":"GET","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:79.0) Gecko/20100101 Firefox/79.0","Authorization":"Bearer 65823c3daa66f8769349","Content-type":"application/json"}}}
      G 1 Antwort Letzte Antwort
      • K Kanumouse
        Gukerl
        #590
        Es scheint, als hätte Tahoma die API abgedreht.
        https://github.com/Somfy-Developer/Somfy-TaHoma-Developer-Mode/issues/161
        LG, Andi
        • G Gukerl
          LG, Andi
          gammler2003
          #591
          @gukerl Mit dem aktuellen Update der Tahoma scheint das Problem wieder behoben zu sein. So wird es zumindest auf Github diskutiert und ich bekomme nach dem Update auf meiner Classic auch keine Fehlermeldungen mehr.
          • G gammler2003
            Gukerl
            #592
            @gammler2003 Vielen DANK für den Hinweis.
            Was aber immer noch beim Starten des Adapters passiert:
            tahoma has an invalid jsonConfig: [{"instancePath":"/items/basicSettingsTab/items/note","schemaPath":"#/patternProperties/%5E.%2B/allOf/37/then/oneOf","keyword":"oneOf","params":{"passingSchemas":[0,1]},"message":"must match exactly one schema in oneOf"},{"instancePath":"/items/basicSettingsTab","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/9/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"},{"instancePath":"","schemaPath":"#/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"}]
            Auffällig auch, steuere ich die Somfy Außenrollo mit der Fernbedienung, mache etwas finster, wird der core:ClosureState erst nach einem Neustart des Adapters übernommen. Umgekehrt, die Jalousie mit dem Adapter geht zumindest mit Somfy gar nicht. Bei meinen Velux Dachflächenfenstern klappt es wieder wunderbar.
            Zusammengefasst scheint die API nicht ganz durchgängig zu sein.
            LG, Andi
            ioT4dbI 1 Antwort Letzte Antwort
            • G Gukerl
              LG, Andi
              ioT4dbI Online
              ioT4dbI Online
              ioT4db
              #593
              moin. das meiste scheint wieder zu laufen mit der API. Außer die "actionGroups", die funktionieren jedenfalls bei mir nur über die cloud, nicht aber per API.
              Ist das bei jemand anderes auch so?
              • ioT4dbI ioT4db
                gammler2003
                #594
                @iot4db Ist bei mir auch so. Ich meine aber, dass das über die lokale API noch nie möglich war.
                • W Offline
                  W Offline
                  WJ49
                  schrieb am zuletzt editiert von WJ49
                  #595
                  ich habe 15 Velux Rolläden auf dem Dach und mir jetzt die Tahoma Switch zugelegt, mit dem Tahoma Adapter im iobroker verbunden. Über die lokale API.
                  Unter Jarvis habe ich es so realisiert:
                  a1a81a89-8b1c-423d-8e52-6ba324ac2c68-1739696097252-d5e44f05-1ca8-413a-a386-3eadff77f037-grafik.png
                  6123197b-6148-46f5-9cc0-1b27491571ec-1739696159812-af9fdec9-c74a-4a32-9aeb-9ac64c50dedb-grafik.png
                  Das funktioniert wunderbar. Hier meine Frage:
                  Wenn ich die Rolläden im Script Blockly über command steuere-open oder steuere-close fahren möchte, stürzt die Tahoma Instanz ab.
                  Nutze ich aber den state closureState mit 0% oder 100% läuft es.
                  Wieso kann ich im script die commands nicht nutzen aber einen state zum steuern?
                  Freue mich auf Eure Antworten.
                  Gruß Wilfried
                  • JailobeamJ Offline
                    JailobeamJ Offline
                    Jailobeam
                    #596
                    Hey Zusammen,
                    Ich habe seit gestern das problem das meine Box nicht mehr auf gateway-xxxx-xxxx-xxxx als hostnamen reagiert sondern nur auf xxxx-xxxx-xxxx somit ist die lokale api tot und lässt sich nicht verbinden.
                    hat jemand eine idee wie man es lösen könnte ?
                    XXXX ist natürlich meine Pin von der BOX die ich auch pingen kann und die Api per Browser erreiche aber nur ohne gateway- vor der Pin
                    tahoma.0
                    	2025-04-10 16:34:33.539	warn	error during request: Error: getaddrinfo ENOTFOUND gateway-XXXX-XXXX-XXXX, request path: setup/gateways with payload:{}
                    tahoma.0
                    	2025-04-10 16:34:33.537	debug	GET request on https://gateway-XXXX-XXXX-XXXX:8443/enduser-mobile-web/1/enduserAPI/setup/gateways with payload:{}
                    tahoma.0
                    	2025-04-10 16:34:33.537	debug	Update gateway status for id undefined
                    ExcodiburE 1 Antwort Letzte Antwort
                    • JailobeamJ Jailobeam
                      Hey Zusammen,
                      tahoma.0
                      tahoma.0
                      tahoma.0
                      ExcodiburE Offline
                      ExcodiburE Offline
                      Excodibur
                      #597
                      @jailobeam Antwort siehe auch dein Ticket hier: https://github.com/Excodibur/ioBroker.tahoma/issues/424#issuecomment-2797009346
                      Es scheint Somfy-seitig ausgelöst zu werden und lässt sich aktuell anscheinend durch einen Hard-Reset der Box ohne Datenverlust beheben.
                      JailobeamJ Q 2 Antworten Letzte Antwort
                      • ExcodiburE Excodibur
                        JailobeamJ Offline
                        JailobeamJ Offline
                        Jailobeam
                        schrieb am zuletzt editiert von Jailobeam
                        #598
                        @excodibur
                        Ich habe das problem bei mir lösen können in dem ich einen neuen DNS eintrag in die Firewall eingetragen habe mit gateway-xxxx-xxxx-xxxx zu der IP der Connexoon Box
                        @Excodibur kannst du vielleicht der Adapter anpassen ?
                        man kann doch im Adapter auch anpassen dass man statt der PIN ( Host Adresse zu der das "gateway-" hinzugefügt wird ) auch einen feld für IP einträgt wo nichts hinzugefügt werden soll.
                        oder bei PIN das hinzufügen von dem prefix gateway- rausnehmen falls wir den später doch brauchen einfach per zB Checkbox Prefix aktivieren oder deaktivieren
                        Vielen Dank !
                        Schöne Grüße Jailo
                          Q Offline
                          Q Offline
                          quipso
                          #599
                          @excodibur
                          Hallo zusammen. Erst einmal großes Lob an alle, die sich mit der Programmierung und Pflege der Adapter beschäftigen. Danke.
                          Zur Problemlösung kann ich leider auch nichts beitragen. Der Vorschlag mit dem Reset hat bei mir leider nicht funktioniert.
                          Auch habe ich mal versuchsweise eine weitere Instanz sowie eine weitere Box Angeschlossen. Die zweite Box allerdings hat sofort und automatisch ein Update ausgeführt. Das Ergebnis ist aber dasselbe.
                          Danke und Grüße
                          quipso
                          ExcodiburE JailobeamJ 2 Antworten Letzte Antwort
                          • Q quipso
                            @excodibur
                            Danke und Grüße
                            quipso
                            ExcodiburE Offline
                            ExcodiburE Offline
                            Excodibur
                            #600
                            @quipso https://github.com/Excodibur/ioBroker.tahoma/releases/tag/v0.11.0 Mit dem neuen Release sollte es für die Härtefälle jetzt auch eine Möglichkeit geben die IP-Addresse der Box direkt einzutragen.
                            P Q 2 Antworten Letzte Antwort
                            • Q quipso
                              @excodibur
                              Danke und Grüße
                              quipso
                              JailobeamJ Offline
                              JailobeamJ Offline
                              Jailobeam
                              #601
                              @quipso
                              wenn ich in meinem Controller es richtig gesehen habe hat die Box wieder den richtigen Hostnamen mit gateway-xxxx-xxxx-xxxx somit wär der fehler wieder behoben glaube die Connnexoon hat heute nachts auch nen neustart gegen 3 gemacht seit dem hat sie nun den wieder richtigen Hostnamen
                              Q 1 Antwort Letzte Antwort
                                pfahlenbauer
                                #602
                                @excodibur
                                Danke! Das hat bei mir geholfen (Tahoma Premium)
                                  Q Offline
                                  Q Offline
                                  quipso
                                  #603
                                  @excodibur
                                  Danke auch von mir! Es funktioniert nun wieder. :-)
                                  quipso
                                    @quipso
                                    Q Offline
                                    Q Offline
                                    quipso
                                    #604
                                    @jailobeam
                                    Danke für den Hinweis. Das habe ich wohl verpasst und habe es jetzt nicht mehr überprüft. Die Möglichkeit nun die IP der Box einzutragen finde ich dann doch sehr elegant.
                                    quipso
                                    • J Offline
                                      Jogi73
                                      #605
                                      ich habe 13 Oximo io Motoren und einen Markisenmotor io am laufen. Der Adapter ist verbunden mittels API. Trotzdem kann ich die Motoren nicht steuern. Müsste zumindest nicht die manuelle Steuerung über die Buttons in den Commands möglich sein? Aber da tut sich nichts. Ich vermute dies auch als Grund, wieso meine Steuerung über Blockly nicht funktioniert, wenn ich hier einen der Buttons einbinde.
                                      Hat jemand schon ähnliche Erfahrungen gemacht?
                                      Jogi
                                      • M Online
                                        M Online
                                        michihorn
                                        #606
                                        Hallo ich weiß der Artikel hier ist schon etwas älter.
                                        Ich habe die Tahoma Box seit einigen Jahren, plötzlich verliert der Adapter die Passworte. Keine Ahnung woran das aktuell liegt. Hat jemand mehr Informationen? Adapter Version 0.11.0
                                        Michael
                                        • M michihorn
                                          Michael
                                          #607
                                          @michihorn sagte in Anfrage Tahoma/Somfy IO Adapter:
                                          Dein Logfile?
