  4. Test Adapter e3oncan - Viessmann E3 Serie einbinden
    5.4k
177 Beiträge 14 Kommentatoren 20.2k Aufrufe 16 Beobachtet
  • R RaspiCan
    Script v.2026-06-01
    *** BASE SYSTEM ***
     Static hostname: raspberrypi
           Icon name: computer
              Kernel: Linux 6.12.62+rpt-rpi-v8
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64bit
    System was installed 451 days ago (on 2025-03-10).
    Systemuptime and Load:
     14:15:45 up  2:28,  7 users,  load average: 0.13, 0.05, 0.01
    CPU threads     : 4
    *** LIFE CYCLE STATUS ***
    Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Fri 2026-06-05 14:15:45 CEST
               Universal time: Fri 2026-06-05 12:15:45 UTC
                     RTC time: n/a
    System clock synchronized: no
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    raspi
    HOME=/home/raspi
    GROUPS=raspi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         Unknown
    Display-Manager:        * lightdm.service - Light Display Manager
    Desktop:
    Session:                tty
    System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'.
    Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
    *** MEMORY ***
    Mem:            4.0G        1.2G        874M         23M        2.0G        2.8G
    Swap:             0B          0B          0B
    Total:          4.0G        1.2G        874M
    Active iob-Instances:   8
             3795 M total memory
             1153 M used memory
             1604 M active memory
             1043 M inactive memory
              834 M free memory
              106 M buffer memory
             1791 M swap cache
                0 M total swap
                0 M used swap
                0 M free swap
    top - 14:15:46 up  2:28,  7 users,  load average: 0.13, 0.05, 0.01
    Tasks: 243 total,   1 running, 242 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 14.3 us, 14.3 sy,  0.0 ni, 71.4 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3795.8 total,    834.2 free,   1153.5 used,   1898.5 buff/cache
    MiB Swap:      0.0 total,      0.0 free,      0.0 used.   2642.3 avail Mem
    *** FAILED SERVICES ***
      UNIT                                 LOAD   ACTIVE SUB    DESCRIPTION
    * systemd-networkd-wait-online.service loaded failed failed Wait for Network to be Configured
    1 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     380M  1.4M  379M   1% /run
    /dev/sda2      ext4      916G   19G  851G   3% /
    tmpfs          tmpfs     1.9G  224K  1.9G   1% /dev/shm
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/sda1      vfat      511M   70M  442M  14% /boot/firmware
    tmpfs          tmpfs     380M   48K  380M   1% /run/user/1000
    /dev/mmcblk0p2 ext4       58G  8.0G   48G  15% /media/raspi/rootfs
    /dev/mmcblk0p1 vfat      510M   68M  443M  14% /media/raspi/bootfs
    Messages concerning filesystems in dmesg:
    [Fri Jun  5 11:47:43 2026] EXT4-fs (sda2): mounted filesystem a36be96c-66be-4487-a7a6-0481bca99d89 ro with ordered data mode. Quota mode: none.
    [Fri Jun  5 11:47:44 2026] EXT4-fs (sda2): re-mounted a36be96c-66be-4487-a7a6-0481bca99d89 r/w.
    [Fri Jun  5 11:47:52 2026] EXT4-fs (mmcblk0p2): recovery complete
    [Fri Jun  5 11:47:52 2026] EXT4-fs (mmcblk0p2): mounted filesystem a36be96c-66be-4487-a7a6-0481bca99d89 r/w with ordered data mode. Quota mode: none.
    Show mounted filesystems:
    TARGET                        SOURCE         FSTYPE      OPTIONS
    /                             /dev/sda2      ext4        rw,noatime
    |-/run/user/1000/doc          portal         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
    |-/boot/firmware              /dev/sda1      vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    |-/media/raspi/rootfs /dev/mmcblk0p2 ext4        rw,nosuid,nodev,relatime,errors=remount-ro
    `-/media/raspi/bootfs /dev/mmcblk0p1 vfat        rw,nosuid,nodev,relatime,uid=1000,gid=1000,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,showexec,utf8,flush,errors=remount-ro
    /var:
    2.5G    /var/
    1.1G    /var/cache/apt
    1.1G    /var/cache
    962M    /var/cache/apt/archives
    666M    /var/log
    Archived and active journals take up 664.5M in the file system.
    /opt/iobroker/backups:
    3.2G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    5.6G    /opt/iobroker/iobroker-data/
    5.4G    /opt/iobroker/iobroker-data/history
    87M     /opt/iobroker/iobroker-data/files
    55M     /opt/iobroker/iobroker-data/backup-objects
    47M     /opt/iobroker/iobroker-data/files/admin.admin
    19M     /opt/iobroker/iobroker-data/objects.jsonl
    8.2M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BDfRPp5J.js
    4.3M    /opt/iobroker/iobroker-data/history/20260221/history.Drehzahl Verdichter Wärmepumpe.json
    4.2M    /opt/iobroker/iobroker-data/history/20260318/history.Drehzahl Verdichter Wärmepumpe.json
    4.2M    /opt/iobroker/iobroker-data/history/20260315/history.Drehzahl Verdichter Wärmepumpe.json
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    No Devices found 'by-id'
    No nvbackup.json found.
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.20.2
    /usr/bin/node           v20.20.2
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    ✓ Node.js installation is correct
    nodejs:
      Installed: 20.20.2-1nodesource1
      Candidate: 20.20.2-1nodesource1
      Version table:
     *** 20.20.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
            100 /var/lib/dpkg/status
         20.20.1-1nodesource1 1001
         20.20.0-1nodesource1 1001
         20.19.6-1nodesource1 1001
         20.19.5-1nodesource1 1001
         20.19.4-1nodesource1 1001
         20.19.3-1nodesource1 1001
         20.19.2-1nodesource1 1001
         20.19.1-1nodesource1 1001
         20.19.0-1nodesource1 1001
         20.18.3-1nodesource1 1001
         20.18.2-1nodesource1 1001
         20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.20.4+dfsg-1~deb12u2 500
         18.20.4+dfsg-1~deb12u1 500
    No problems detected
    Errors in npm tree: 0
    Vulnerabilities detected in the Node.js version!
    node:fs:2380
        return binding.writeFileUtf8(
    Error: EACCES: permission denied, open '/home/iobroker/node_modules/is-my-node-vulnerable/schedule.etag'
        at Object.writeFileSync (node:fs:2380:20)
        at ClientRequest.<anonymous> (/home/iobroker/node_modules/is-my-node-vulnerable/is-vulnerable.js:82:12)
        at Object.onceWrapper (node:events:639:26)
        at ClientRequest.emit (node:events:524:28)
        at HTTPParser.parserOnIncomingClient [as onIncoming] (node:_http_client:702:27)
        at HTTPParser.parserOnHeadersComplete (node:_http_common:118:17)
        at TLSSocket.socketOnData (node:_http_client:544:22)
        at TLSSocket.emit (node:events:524:28)
        at addChunk (node:internal/streams/readable:561:12)
        at readableAddChunkPushByteMode (node:internal/streams/readable:512:3) {
      errno: -13,
      code: 'EACCES',
      syscall: 'open',
      path: '/home/iobroker/node_modules/is-my-node-vulnerable/schedule.etag'
    Node.js v20.20.2
    npm notice
    npm notice New major version of npm available! 10.8.2 -> 11.16.0
    npm notice Changelog: https://github.com/npm/cli/releases/tag/v11.16.0
    npm notice To update run: npm install -g npm@11.16.0
    npm notice
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    raspberrypi         raspberrypi (version: 7.0.7, hostname: raspberrypi   , alive, uptime: 7713)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.22
    javascript:     "javascript" not found
    nodejs modules from github:     0
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
    + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
    + system.adapter.e3oncan.0                : e3oncan               : raspberrypi                              -  enabled
      system.adapter.e3oncan.1                : e3oncan               : raspberrypi                              - disabled
    + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
    + system.adapter.history.0                : history               : raspberrypi                              -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    │ (index) │ id                         │ name        │ version   │ upgrade policy │
    │ 0       │ 'system.adapter.admin'     │ 'admin'     │ '7.7.22'  │ 'none'         │
    │ 1       │ 'system.adapter.backitup'  │ 'backitup'  │ '3.3.14'  │ 'none'         │
    │ 2       │ 'system.adapter.discovery' │ 'discovery' │ '5.0.0'   │ 'none'         │
    │ 3       │ 'system.adapter.e3oncan'   │ 'e3oncan'   │ '0.10.14' │ 'none'         │
    │ 4       │ 'system.adapter.echarts'   │ 'echarts'   │ '3.1.0'   │ 'none'         │
    │ 5       │ 'system.adapter.history'   │ 'history'   │ '3.0.1'   │ 'none'         │
    │ 6       │ 'system.adapter.socketio'  │ 'socketio'  │ '6.7.1'   │ 'none'         │
    │ 7       │ 'system.adapter.web'       │ 'web'       │ '7.0.8'   │ 'none'         │
    │ 8       │ 'system.adapter.ws'        │ 'ws'        │ '2.6.2'   │ 'none'         │
    ioBroker-Adapter Versions and update status
    Used repository: stable
    Adapter    "admin"        : 7.8.23   , installed 7.7.22 [Updatable]
    Adapter    "backitup"     : 3.3.14   , installed 3.3.14
    Adapter    "e3oncan"      : 0.11.3   , installed 0.10.14 [Updatable]
    Adapter    "echarts"      : 3.1.0    , installed 3.1.0
    Adapter    "history"      : 4.0.0    , installed 3.0.1  [Updatable]
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "socketio"     : 7.1.3    , installed 7.1.3
    Adapter    "web"          : 8.0.0    , installed 7.0.8  [Updatable]
    Adapter    "ws"           : 4.0.0    , installed 3.0.19 [Updatable]
    Objects and States
    Objects:        5587
    States:         5466
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:5 https://mschneider82.github.io/vieventlog stable InRelease
    Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending systemupdates: 0
    *** Listening Ports ***
    Netid State  Recv-Q Send-Q Local Address:Port   Peer Address:PortProcess
    udp   UNCONN 0      0            0.0.0.0:mdns        0.0.0.0:*    users:(("avahi-daemon",pid=495,fd=12))
    udp   UNCONN 0      0            0.0.0.0:54621       0.0.0.0:*    users:(("avahi-daemon",pid=495,fd=14))
    udp   UNCONN 0      0                  *:37406             *:*    users:(("avahi-daemon",pid=495,fd=15))
    udp   UNCONN 0      0                  *:mdns              *:*    users:(("avahi-daemon",pid=495,fd=13))
    tcp   LISTEN 0      128          0.0.0.0:ssh         0.0.0.0:*    users:(("sshd",pid=14888,fd=3))
    tcp   LISTEN 0      128        127.0.0.1:ipp         0.0.0.0:*    users:(("cupsd",pid=629,fd=7))
    tcp   LISTEN 0      511        127.0.0.1:9000        0.0.0.0:*    users:(("iobroker.js-con",pid=24529,fd=25))
    tcp   LISTEN 0      511        127.0.0.1:9001        0.0.0.0:*    users:(("iobroker.js-con",pid=24529,fd=19))
    tcp   LISTEN 0      4096               *:5000              *:*    users:(("vieventlog",pid=25918,fd=5))
    tcp   LISTEN 0      128             [::]:ssh            [::]:*    users:(("sshd",pid=14888,fd=4))
    tcp   LISTEN 0      511                *:tproxy            *:*    users:(("io.admin.0",pid=24561,fd=32))
    tcp   LISTEN 0      511                *:8082              *:*    users:(("io.web.0",pid=25014,fd=27))
    tcp   LISTEN 0      16                 *:5900              *:*    users:(("wayvnc",pid=680,fd=9))
    tcp   LISTEN 0      128            [::1]:ipp            [::]:*    users:(("cupsd",pid=629,fd=6))
    2026-06-05 14:15:39.649  - error: e3oncan.0 (27942) UDS timeout on 0x68c.388
    2026-06-05 14:15:40.255  - error: e3oncan.0 (27942) UDS timeout on 0x680.1393
    2026-06-05 14:15:43.778  - error: e3oncan.0 (27942) UDS timeout on 0x6cf.2442
    2026-06-05 14:15:47.152  - error: e3oncan.0 (27942) UDS timeout on 0x68c.390
    2026-06-05 14:15:47.757  - error: e3oncan.0 (27942) UDS timeout on 0x680.1769
    2026-06-05 14:15:53.765  - error: e3oncan.0 (27942) UDS timeout on 0x6cf.2442
    2026-06-05 14:15:54.691  - error: e3oncan.0 (27942) UDS timeout on 0x68c.2852
    2026-06-05 14:15:55.262  - error: e3oncan.0 (27942) UDS timeout on 0x680.1770
    2026-06-05 14:16:02.212  - error: e3oncan.0 (27942) UDS timeout on 0x68c.388
    2026-06-05 14:16:02.773  - error: e3oncan.0 (27942) UDS timeout on 0x680.1771
    2026-06-05 14:16:03.772  - error: e3oncan.0 (27942) UDS timeout on 0x6cf.2442
    2026-06-05 14:16:09.724  - error: e3oncan.0 (27942) UDS timeout on 0x68c.390
    2026-06-05 14:16:10.287  - error: e3oncan.0 (27942) UDS timeout on 0x680.1772
    2026-06-05 14:16:13.791  - error: e3oncan.0 (27942) UDS timeout on 0x6cf.2442
    2026-06-05 14:16:17.238  - error: e3oncan.0 (27942) UDS timeout on 0x68c.2852
    2026-06-05 14:16:17.800  - error: e3oncan.0 (27942) UDS timeout on 0x680.1773
    2026-06-05 14:16:23.784  - error: e3oncan.0 (27942) UDS timeout on 0x6cf.2442
    2026-06-05 14:16:24.750  - error: e3oncan.0 (27942) UDS timeout on 0x68c.388
    2026-06-05 14:16:25.316  - error: e3oncan.0 (27942) UDS timeout on 0x680.1774
    2026-06-05 14:16:32.273  - error: e3oncan.0 (27942) UDS timeout on 0x68c.390
    2026-06-05 14:16:32.832  - error: e3oncan.0 (27942) UDS timeout on 0x680.1775
    2026-06-05 14:16:33.794  - error: e3oncan.0 (27942) UDS timeout on 0x6cf.2442
    2026-06-05 14:16:39.804  - error: e3oncan.0 (27942) UDS timeout on 0x68c.2852
    2026-06-05 14:16:40.371  - error: e3oncan.0 (27942) UDS timeout on 0x680.1776
    2026-06-05 14:16:43.784  - error: e3oncan.0 (27942) UDS timeout on 0x6cf.2442
    ============= Mark until here for C&P =============
    iob diag has finished.
    #141
    @RaspiCan sagte:
    Da hat dein Dateisystem wohl einen Schaden (gehabt).
    @RaspiCan sagte:
    Veraltet!
    Bitte auf v22 updaten
    Von OS rede ich gar nicht
    • R RaspiCan
      Script v.2026-06-01
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      OS is similar to:
      Docker          : false
      Kernel          : aarch64
      Userland        : 64bit
      CPU threads     : 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      raspi
      HOME=/home/raspi
      iobroker
      HOME=/home/iobroker
      Desktop:
      Session:                tty
      *** MEMORY ***
      Swap:             0B          0B          0B
               3795 M total memory
               1153 M used memory
                834 M free memory
                106 M buffer memory
               1791 M swap cache
                  0 M total swap
                  0 M used swap
                  0 M free swap
      *** FILESYSTEM ***
      /var:
      2.5G    /var/
      1.1G    /var/cache/apt
      1.1G    /var/cache
      666M    /var/log
      USB-Devices by-id:
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      nodejs:
        Version table:
      node:fs:2380
        errno: -13,
        code: 'EACCES',
        syscall: 'open',
      Node.js v20.20.2
      npm notice
      npm notice
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.7.22
      Adapter State
      + instance is alive
      Objects and States
      Objects:        5587
      States:         5466
      #142
      @RaspiCan
      Und lass mal den
      iob fix
      laufen, da stimmt was mit den Rechten nicht.
      jrbwhJ 1 Antwort Letzte Antwort
        @RaspiCan
        Und lass mal den
        iob fix
        jrbwhJ Online
        jrbwhJ Online
        jrbwh
        #143
        @raspican Ich würde immer noch gerne die Log-Einträge beim Start des e3oncan-Adapters sehen.
        Thomas BraunT R 2 Antworten Letzte Antwort
        • jrbwhJ jrbwh
          #144
          @jrbwh
          Ja, würde allerdings auf einem System mit aktuellem Stand sinnvoller sein. Die ioBroker-Adapter sind ja auch alle pflegebedürftig, inkl.
            @jrbwh
            jrbwhJ Online
            jrbwhJ Online
            jrbwh
            #145
            @Thomas-Braun Stimmt.
            @raspican Wenn Du den Adpater updatest, empfehle ich, direkt auf v1.0.3 (Beta-Repo) zu gehen. Sonst gibt's beim node.js-Upgrade gleich wieder neue Probleme. Die Änderungen sind im Readme und in diesem Thread ganz oben ausführlich beschrieben.
            R 1 Antwort Letzte Antwort
            • jrbwhJ jrbwh
              RaspiCan
              #146
              @jrbwh
              v1.0.3=0.11.3?
              Thomas BraunT jrbwhJ 2 Antworten Letzte Antwort
              • R RaspiCan
                @jrbwh
                v1.0.3=0.11.3?
                #147
                @RaspiCan
                Nein, die 1.0.3 liegt nur als Beta-Version im entsprechenden Repository bereit.
                Hast du denn deine Kiste jetzt auf einen aktuellen Stand gehievt?
                  RaspiCan
                  #148
                  Nein, habe ich nicht, muss mir das erst anlesen wie das geht.
                  • R RaspiCan
                    #149
                    @RaspiCan
                    nodejs-Update:
                    iob nodejs-update
                    dann danach:
                    https://forum.iobroker.net/topic/81187/upgrade-von-debian-12-bookworm-auf-debian-13-trixie
                    • R RaspiCan
                      @jrbwh
                      v1.0.3=0.11.3?
                      jrbwhJ Online
                      jrbwhJ Online
                      jrbwh
                      #150
                      @RaspiCan Version 1.0.3 ist im Beta-Repo verfügbar. Du wechselt zum Beta-Repo indem Du in der Adapter-Ansicht ober auf das Werkzeug-Symbol klickst, dann den Haken bei Beta machst und bestätigst:
                      Nach dem Schließen mit OK evtl. nochmal auf Aktualisieren klicken. Dann sollte die Version 1.0.3 zur Installation angeboten werden.
                      • jrbwhJ jrbwh
                        #151
                        @jrbwh @raspican
                        Alternativ, ohne das Beta-Repo zu aktivieren:
                        Aber die Basis musst du zuvor auf Stand bringen.
                          RaspiCan
                          schrieb am zuletzt editiert von RaspiCan
                          #152
                          Vielen Dank für die Hilfe, ich bin bei linux absoluter Anfänger
                          e3oncan 1.03 ist installiert
                          nodejs 22 ist installiert
                          Error und timeout ist nun weg
                          vor dem update von bookworm auf trixie hab ich respekt
                          • R RaspiCan
                            #153
                            @RaspiCan sagte:
                            Nutzt dir aber nix, je länger du da 'Respekt' hast, desto komplizierter bis unmöglich wird das ganze.
                              RaspiCan
                              #154
                              Mit welchem Befehl mach ich das umfassende Update von allem, bestensfalls noch zusätzlich auf die vorhandene ssd?
                              • R RaspiCan
                                #155
                                @RaspiCan sagte:
                                Hab ich dir oben schon verlinkt.
                                • jrbwhJ jrbwh
                                  RaspiCan
                                  #156
                                  @jrbwh
                                  e3oncan.0
                                  2026-06-05 17:33:16.633	info	Startup of instance e3oncan.0: Done.
                                  e3oncan.0
                                  2026-06-05 17:33:16.581	info	UDS worker started on EHCU_0x6cf (0x6cf) with 1 active schedule(s).
                                  e3oncan.0
                                  2026-06-05 17:33:16.527	info	UDS worker started on BACKENDGATEWAY_0x6c5 (0x6c5) with 0 active schedule(s).
                                  e3oncan.0
                                  2026-06-05 17:33:16.475	info	UDS worker started on BACKENDGATEWAY_0x6c3 (0x6c3) with 0 active schedule(s).
                                  e3oncan.0
                                  2026-06-05 17:33:16.424	info	UDS worker started on VCMU_0x68c (0x68c) with 1 active schedule(s).
                                  e3oncan.0
                                  2026-06-05 17:33:16.372	info	UDS worker started on HMI_0x684 (0x684) with 0 active schedule(s).
                                  e3oncan.0
                                  2026-06-05 17:33:16.320	info	UDS worker started on HPMUMASTER_0x680 (0x680) with 2 active schedule(s).
                                  e3oncan.0
                                  2026-06-05 17:33:15.893	info	Collect worker started on HPMUMASTER_0x680
                                  e3oncan.0
                                  2026-06-05 17:33:15.842	info	CAN-Adapter connected: can0
                                  e3oncan.0
                                  2026-06-05 17:33:14.976	info	Startup of instance e3oncan.0: Starting.
                                  e3oncan.0
                                  2026-06-05 17:33:14.951	info	starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.e3oncan, node: v22.22.3, js-controller: 7.0.7
                                  host.raspberrypi
                                  2026-06-05 17:33:12.857	info	instance system.adapter.e3oncan.0 in version "1.0.3" started with pid 40520
                                  host.raspberrypi
                                  2026-06-05 17:33:09.377	info	instance system.adapter.e3oncan.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    @RaspiCan sagte:
                                    RaspiCan
                                    #157
                                    @Thomas-Braun
                                    Sorry, ich meine das Backup, nicht update, sorry
                                    • R RaspiCan
                                      @Thomas-Braun
                                      #158
                                      @RaspiCan
                                      Mit dem Backitup-Adapter am besten.
                                        RaspiCan
                                        #159
                                        Dachte, da gibts noch was anderes
                                        Die Backups mach ich sowieso jede Nacht
                                        • R RaspiCan
                                          #160
                                          @RaspiCan
                                          Was soll es denn noch anderes geben? Deine config in /etc kannst du auch wegsichern. Bei Konflikten wirst du aber während des Upgrades danach gefragt.
