  4. Test Adapter e3oncan - Viessmann E3 Serie einbinden
    1.0k
177 Beiträge 14 Kommentatoren 23.0k Aufrufe 16 Beobachtet
  • R RaspiCan
    Habs direkt kopiert
    HomoranH Offline
    HomoranH Offline
    #139
    @RaspiCan sagte:
    Habs direkt kopiert
    Aber die Startmarken abgeschnitten
    • R RaspiCan
      Habs direkt kopiert
      #140
      @RaspiCan
      Es fehlen die öffnenden CodeTags.
      Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
      Bring das auf die aktuelle Version.
      Und bring auch nodejs auf die aktuell für den ioBroker vorgesehene Version 22.
      SWAP würde ich auch einrichten.
      • R RaspiCan
        Script v.2026-06-01
        *** BASE SYSTEM ***
         Static hostname: raspberrypi
               Icon name: computer
                  Kernel: Linux 6.12.62+rpt-rpi-v8
            Architecture: arm64
        OS is similar to:
        Model           : Raspberry Pi 4 Model B Rev 1.5
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : 64bit
        System was installed 451 days ago (on 2025-03-10).
        Systemuptime and Load:
         14:15:45 up  2:28,  7 users,  load average: 0.13, 0.05, 0.01
        CPU threads     : 4
        *** LIFE CYCLE STATUS ***
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** TIME AND TIMEZONES ***
                       Local time: Fri 2026-06-05 14:15:45 CEST
                   Universal time: Fri 2026-06-05 12:15:45 UTC
                         RTC time: n/a
        System clock synchronized: no
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        raspi
        HOME=/home/raspi
        GROUPS=raspi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
        iobroker
        HOME=/home/iobroker
        *** DISPLAY-SERVER SETUP ***
        Display-Server:         Unknown
        Display-Manager:        * lightdm.service - Light Display Manager
        Desktop:
        Session:                tty
        System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'.
        Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
        *** MEMORY ***
        Mem:            4.0G        1.2G        874M         23M        2.0G        2.8G
        Swap:             0B          0B          0B
        Total:          4.0G        1.2G        874M
        Active iob-Instances:   8
                 3795 M total memory
                 1153 M used memory
                 1604 M active memory
                 1043 M inactive memory
                  834 M free memory
                  106 M buffer memory
                 1791 M swap cache
                    0 M total swap
                    0 M used swap
                    0 M free swap
        top - 14:15:46 up  2:28,  7 users,  load average: 0.13, 0.05, 0.01
        Tasks: 243 total,   1 running, 242 sleeping,   0 stopped,   0 zombie
        %Cpu(s): 14.3 us, 14.3 sy,  0.0 ni, 71.4 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   3795.8 total,    834.2 free,   1153.5 used,   1898.5 buff/cache
        MiB Swap:      0.0 total,      0.0 free,      0.0 used.   2642.3 avail Mem
        *** FAILED SERVICES ***
          UNIT                                 LOAD   ACTIVE SUB    DESCRIPTION
        * systemd-networkd-wait-online.service loaded failed failed Wait for Network to be Configured
        1 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        No critical errors detected
        *** FILESYSTEM ***
        udev           devtmpfs  1.6G     0  1.6G   0% /dev
        tmpfs          tmpfs     380M  1.4M  379M   1% /run
        /dev/sda2      ext4      916G   19G  851G   3% /
        tmpfs          tmpfs     1.9G  224K  1.9G   1% /dev/shm
        tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
        /dev/sda1      vfat      511M   70M  442M  14% /boot/firmware
        tmpfs          tmpfs     380M   48K  380M   1% /run/user/1000
        /dev/mmcblk0p2 ext4       58G  8.0G   48G  15% /media/raspi/rootfs
        /dev/mmcblk0p1 vfat      510M   68M  443M  14% /media/raspi/bootfs
        Messages concerning filesystems in dmesg:
        [Fri Jun  5 11:47:43 2026] EXT4-fs (sda2): mounted filesystem a36be96c-66be-4487-a7a6-0481bca99d89 ro with ordered data mode. Quota mode: none.
        [Fri Jun  5 11:47:44 2026] EXT4-fs (sda2): re-mounted a36be96c-66be-4487-a7a6-0481bca99d89 r/w.
        [Fri Jun  5 11:47:52 2026] EXT4-fs (mmcblk0p2): recovery complete
        [Fri Jun  5 11:47:52 2026] EXT4-fs (mmcblk0p2): mounted filesystem a36be96c-66be-4487-a7a6-0481bca99d89 r/w with ordered data mode. Quota mode: none.
        Show mounted filesystems:
        TARGET                        SOURCE         FSTYPE      OPTIONS
        /                             /dev/sda2      ext4        rw,noatime
        |-/run/user/1000/doc          portal         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
        |-/boot/firmware              /dev/sda1      vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        |-/media/raspi/rootfs /dev/mmcblk0p2 ext4        rw,nosuid,nodev,relatime,errors=remount-ro
        `-/media/raspi/bootfs /dev/mmcblk0p1 vfat        rw,nosuid,nodev,relatime,uid=1000,gid=1000,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,showexec,utf8,flush,errors=remount-ro
        /var:
        2.5G    /var/
        1.1G    /var/cache/apt
        1.1G    /var/cache
        962M    /var/cache/apt/archives
        666M    /var/log
        Archived and active journals take up 664.5M in the file system.
        /opt/iobroker/backups:
        3.2G    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        5.6G    /opt/iobroker/iobroker-data/
        5.4G    /opt/iobroker/iobroker-data/history
        87M     /opt/iobroker/iobroker-data/files
        55M     /opt/iobroker/iobroker-data/backup-objects
        47M     /opt/iobroker/iobroker-data/files/admin.admin
        19M     /opt/iobroker/iobroker-data/objects.jsonl
        8.2M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BDfRPp5J.js
        4.3M    /opt/iobroker/iobroker-data/history/20260221/history.Drehzahl Verdichter Wärmepumpe.json
        4.2M    /opt/iobroker/iobroker-data/history/20260318/history.Drehzahl Verdichter Wärmepumpe.json
        4.2M    /opt/iobroker/iobroker-data/history/20260315/history.Drehzahl Verdichter Wärmepumpe.json
        USB-Devices by-id:
        USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
        please always prefer the links 'by-id':
        No Devices found 'by-id'
        No nvbackup.json found.
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v20.20.2
        /usr/bin/node           v20.20.2
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        ✓ Node.js installation is correct
        nodejs:
          Installed: 20.20.2-1nodesource1
          Candidate: 20.20.2-1nodesource1
          Version table:
         *** 20.20.2-1nodesource1 1001
                500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
             20.20.1-1nodesource1 1001
             20.20.0-1nodesource1 1001
             20.19.6-1nodesource1 1001
             20.19.5-1nodesource1 1001
             20.19.4-1nodesource1 1001
             20.19.3-1nodesource1 1001
             20.19.2-1nodesource1 1001
             20.19.1-1nodesource1 1001
             20.19.0-1nodesource1 1001
             20.18.3-1nodesource1 1001
             20.18.2-1nodesource1 1001
             20.18.1-1nodesource1 1001
             20.18.0-1nodesource1 1001
             20.17.0-1nodesource1 1001
             20.16.0-1nodesource1 1001
             20.15.1-1nodesource1 1001
             20.15.0-1nodesource1 1001
             20.14.0-1nodesource1 1001
             20.13.1-1nodesource1 1001
             20.13.0-1nodesource1 1001
             20.12.2-1nodesource1 1001
             20.12.1-1nodesource1 1001
             20.12.0-1nodesource1 1001
             20.11.1-1nodesource1 1001
             20.11.0-1nodesource1 1001
             20.10.0-1nodesource1 1001
             20.9.0-1nodesource1 1001
             20.8.1-1nodesource1 1001
             20.8.0-1nodesource1 1001
             20.7.0-1nodesource1 1001
             20.6.1-1nodesource1 1001
             20.6.0-1nodesource1 1001
             20.5.1-1nodesource1 1001
             20.5.0-1nodesource1 1001
             20.4.0-1nodesource1 1001
             20.3.1-1nodesource1 1001
             20.3.0-1nodesource1 1001
             20.2.0-1nodesource1 1001
             20.1.0-1nodesource1 1001
             20.0.0-1nodesource1 1001
             18.20.4+dfsg-1~deb12u2 500
                500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
             18.20.4+dfsg-1~deb12u1 500
                500 http://deb.debian.org/debian bookworm/main arm64 Packages
        No problems detected
        Errors in npm tree: 0
        Vulnerabilities detected in the Node.js version!
        node:fs:2380
            return binding.writeFileUtf8(
        Error: EACCES: permission denied, open '/home/iobroker/node_modules/is-my-node-vulnerable/schedule.etag'
            at Object.writeFileSync (node:fs:2380:20)
            at ClientRequest.<anonymous> (/home/iobroker/node_modules/is-my-node-vulnerable/is-vulnerable.js:82:12)
            at Object.onceWrapper (node:events:639:26)
            at ClientRequest.emit (node:events:524:28)
            at HTTPParser.parserOnIncomingClient [as onIncoming] (node:_http_client:702:27)
            at HTTPParser.parserOnHeadersComplete (node:_http_common:118:17)
            at TLSSocket.socketOnData (node:_http_client:544:22)
            at TLSSocket.emit (node:events:524:28)
            at addChunk (node:internal/streams/readable:561:12)
            at readableAddChunkPushByteMode (node:internal/streams/readable:512:3) {
          errno: -13,
          code: 'EACCES',
          syscall: 'open',
          path: '/home/iobroker/node_modules/is-my-node-vulnerable/schedule.etag'
        Node.js v20.20.2
        npm notice
        npm notice New major version of npm available! 10.8.2 -> 11.16.0
        npm notice Changelog: https://github.com/npm/cli/releases/tag/v11.16.0
        npm notice To update run: npm install -g npm@11.16.0
        npm notice
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        raspberrypi         raspberrypi (version: 7.0.7, hostname: raspberrypi   , alive, uptime: 7713)
        Core adapters versions
        js-controller:  7.0.7
        admin:          7.7.22
        javascript:     "javascript" not found
        nodejs modules from github:     0
        Adapter State
        + system.adapter.e3oncan.0                : e3oncan               : raspberrypi                              -  enabled
          system.adapter.e3oncan.1                : e3oncan               : raspberrypi                              - disabled
        + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
        + system.adapter.history.0                : history               : raspberrypi                              -  enabled
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Adapters
        │ (index) │ id                         │ name        │ version   │ upgrade policy │
        │ 0       │ 'system.adapter.admin'     │ 'admin'     │ '7.7.22'  │ 'none'         │
        │ 1       │ 'system.adapter.backitup'  │ 'backitup'  │ '3.3.14'  │ 'none'         │
        │ 2       │ 'system.adapter.discovery' │ 'discovery' │ '5.0.0'   │ 'none'         │
        │ 3       │ 'system.adapter.e3oncan'   │ 'e3oncan'   │ '0.10.14' │ 'none'         │
        │ 4       │ 'system.adapter.echarts'   │ 'echarts'   │ '3.1.0'   │ 'none'         │
        │ 5       │ 'system.adapter.history'   │ 'history'   │ '3.0.1'   │ 'none'         │
        │ 6       │ 'system.adapter.socketio'  │ 'socketio'  │ '6.7.1'   │ 'none'         │
        │ 7       │ 'system.adapter.web'       │ 'web'       │ '7.0.8'   │ 'none'         │
        │ 8       │ 'system.adapter.ws'        │ 'ws'        │ '2.6.2'   │ 'none'         │
        ioBroker-Adapter Versions and update status
        Used repository: stable
        Adapter    "admin"        : 7.8.23   , installed 7.7.22 [Updatable]
        Adapter    "backitup"     : 3.3.14   , installed 3.3.14
        Adapter    "e3oncan"      : 0.11.3   , installed 0.10.14 [Updatable]
        Adapter    "echarts"      : 3.1.0    , installed 3.1.0
        Adapter    "history"      : 4.0.0    , installed 3.0.1  [Updatable]
        Controller "js-controller": 7.0.7    , installed 7.0.7
        Adapter    "socketio"     : 7.1.3    , installed 7.1.3
        Adapter    "web"          : 8.0.0    , installed 7.0.8  [Updatable]
        Adapter    "ws"           : 4.0.0    , installed 3.0.19 [Updatable]
        Objects and States
        Objects:        5587
        States:         5466
        Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
        Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
        Hit:5 https://mschneider82.github.io/vieventlog stable InRelease
        Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
        Reading package lists...
        Pending systemupdates: 0
        *** Listening Ports ***
        Netid State  Recv-Q Send-Q Local Address:Port   Peer Address:PortProcess
        udp   UNCONN 0      0            0.0.0.0:mdns        0.0.0.0:*    users:(("avahi-daemon",pid=495,fd=12))
        udp   UNCONN 0      0            0.0.0.0:54621       0.0.0.0:*    users:(("avahi-daemon",pid=495,fd=14))
        udp   UNCONN 0      0                  *:37406             *:*    users:(("avahi-daemon",pid=495,fd=15))
        udp   UNCONN 0      0                  *:mdns              *:*    users:(("avahi-daemon",pid=495,fd=13))
        tcp   LISTEN 0      128          0.0.0.0:ssh         0.0.0.0:*    users:(("sshd",pid=14888,fd=3))
        tcp   LISTEN 0      128        127.0.0.1:ipp         0.0.0.0:*    users:(("cupsd",pid=629,fd=7))
        tcp   LISTEN 0      511        127.0.0.1:9000        0.0.0.0:*    users:(("iobroker.js-con",pid=24529,fd=25))
        tcp   LISTEN 0      511        127.0.0.1:9001        0.0.0.0:*    users:(("iobroker.js-con",pid=24529,fd=19))
        tcp   LISTEN 0      4096               *:5000              *:*    users:(("vieventlog",pid=25918,fd=5))
        tcp   LISTEN 0      128             [::]:ssh            [::]:*    users:(("sshd",pid=14888,fd=4))
        tcp   LISTEN 0      511                *:tproxy            *:*    users:(("io.admin.0",pid=24561,fd=32))
        tcp   LISTEN 0      511                *:8082              *:*    users:(("io.web.0",pid=25014,fd=27))
        tcp   LISTEN 0      16                 *:5900              *:*    users:(("wayvnc",pid=680,fd=9))
        tcp   LISTEN 0      128            [::1]:ipp            [::]:*    users:(("cupsd",pid=629,fd=6))
        2026-06-05 14:15:39.649  - error: e3oncan.0 (27942) UDS timeout on 0x68c.388
        2026-06-05 14:15:40.255  - error: e3oncan.0 (27942) UDS timeout on 0x680.1393
        2026-06-05 14:15:43.778  - error: e3oncan.0 (27942) UDS timeout on 0x6cf.2442
        2026-06-05 14:15:47.152  - error: e3oncan.0 (27942) UDS timeout on 0x68c.390
        2026-06-05 14:15:47.757  - error: e3oncan.0 (27942) UDS timeout on 0x680.1769
        2026-06-05 14:15:53.765  - error: e3oncan.0 (27942) UDS timeout on 0x6cf.2442
        2026-06-05 14:15:54.691  - error: e3oncan.0 (27942) UDS timeout on 0x68c.2852
        2026-06-05 14:15:55.262  - error: e3oncan.0 (27942) UDS timeout on 0x680.1770
        2026-06-05 14:16:02.212  - error: e3oncan.0 (27942) UDS timeout on 0x68c.388
        2026-06-05 14:16:02.773  - error: e3oncan.0 (27942) UDS timeout on 0x680.1771
        2026-06-05 14:16:03.772  - error: e3oncan.0 (27942) UDS timeout on 0x6cf.2442
        2026-06-05 14:16:09.724  - error: e3oncan.0 (27942) UDS timeout on 0x68c.390
        2026-06-05 14:16:10.287  - error: e3oncan.0 (27942) UDS timeout on 0x680.1772
        2026-06-05 14:16:13.791  - error: e3oncan.0 (27942) UDS timeout on 0x6cf.2442
        2026-06-05 14:16:17.238  - error: e3oncan.0 (27942) UDS timeout on 0x68c.2852
        2026-06-05 14:16:17.800  - error: e3oncan.0 (27942) UDS timeout on 0x680.1773
        2026-06-05 14:16:23.784  - error: e3oncan.0 (27942) UDS timeout on 0x6cf.2442
        2026-06-05 14:16:24.750  - error: e3oncan.0 (27942) UDS timeout on 0x68c.388
        2026-06-05 14:16:25.316  - error: e3oncan.0 (27942) UDS timeout on 0x680.1774
        2026-06-05 14:16:32.273  - error: e3oncan.0 (27942) UDS timeout on 0x68c.390
        2026-06-05 14:16:32.832  - error: e3oncan.0 (27942) UDS timeout on 0x680.1775
        2026-06-05 14:16:33.794  - error: e3oncan.0 (27942) UDS timeout on 0x6cf.2442
        2026-06-05 14:16:39.804  - error: e3oncan.0 (27942) UDS timeout on 0x68c.2852
        2026-06-05 14:16:40.371  - error: e3oncan.0 (27942) UDS timeout on 0x680.1776
        2026-06-05 14:16:43.784  - error: e3oncan.0 (27942) UDS timeout on 0x6cf.2442
        ============= Mark until here for C&P =============
        iob diag has finished.
        HomoranH Offline
        HomoranH Offline
        #141
        @RaspiCan sagte:
        Da hat dein Dateisystem wohl einen Schaden (gehabt).
        @RaspiCan sagte:
        Veraltet!
        Bitte auf v22 updaten
        Von OS rede ich gar nicht
        • R RaspiCan
          Script v.2026-06-01
          *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
          OS is similar to:
          Docker          : false
          Kernel          : aarch64
          Userland        : 64bit
          CPU threads     : 4
          Current issues:
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          raspi
          HOME=/home/raspi
          iobroker
          HOME=/home/iobroker
          Desktop:
          Session:                tty
          *** MEMORY ***
          Swap:             0B          0B          0B
                   3795 M total memory
                   1153 M used memory
                    834 M free memory
                    106 M buffer memory
                   1791 M swap cache
                      0 M total swap
                      0 M used swap
                      0 M free swap
          *** FILESYSTEM ***
          /var:
          2.5G    /var/
          1.1G    /var/cache/apt
          1.1G    /var/cache
          666M    /var/log
          USB-Devices by-id:
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          nodejs:
            Version table:
          node:fs:2380
            errno: -13,
            code: 'EACCES',
            syscall: 'open',
          Node.js v20.20.2
          npm notice
          npm notice
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          admin:          7.7.22
          Adapter State
          + instance is alive
          Objects and States
          Objects:        5587
          States:         5466
          #142
          @RaspiCan
          Und lass mal den
          iob fix
          laufen, da stimmt was mit den Rechten nicht.
          jrbwhJ 1 Antwort Letzte Antwort
            @RaspiCan
            Und lass mal den
            iob fix
            jrbwhJ Offline
            jrbwhJ Offline
            jrbwh
            #143
            @raspican Ich würde immer noch gerne die Log-Einträge beim Start des e3oncan-Adapters sehen.
            Thomas BraunT R 2 Antworten Letzte Antwort
            • jrbwhJ jrbwh
              #144
              @jrbwh
              Ja, würde allerdings auf einem System mit aktuellem Stand sinnvoller sein. Die ioBroker-Adapter sind ja auch alle pflegebedürftig, inkl.
                @jrbwh
                jrbwhJ Offline
                jrbwhJ Offline
                jrbwh
                #145
                @Thomas-Braun Stimmt.
                @raspican Wenn Du den Adpater updatest, empfehle ich, direkt auf v1.0.3 (Beta-Repo) zu gehen. Sonst gibt's beim node.js-Upgrade gleich wieder neue Probleme. Die Änderungen sind im Readme und in diesem Thread ganz oben ausführlich beschrieben.
                R 1 Antwort Letzte Antwort
                • jrbwhJ jrbwh
                  RaspiCan
                  #146
                  @jrbwh
                  v1.0.3=0.11.3?
                  Thomas BraunT jrbwhJ 2 Antworten Letzte Antwort
                  • R RaspiCan
                    @jrbwh
                    v1.0.3=0.11.3?
                    #147
                    @RaspiCan
                    Nein, die 1.0.3 liegt nur als Beta-Version im entsprechenden Repository bereit.
                    Hast du denn deine Kiste jetzt auf einen aktuellen Stand gehievt?
                    • R Offline
                      RaspiCan
                      #148
                      Nein, habe ich nicht, muss mir das erst anlesen wie das geht.
                      • R RaspiCan
                        #149
                        @RaspiCan
                        nodejs-Update:
                        iob nodejs-update
                        dann danach:
                        https://forum.iobroker.net/topic/81187/upgrade-von-debian-12-bookworm-auf-debian-13-trixie
                        • R RaspiCan
                          @jrbwh
                          v1.0.3=0.11.3?
                          jrbwhJ Offline
                          jrbwhJ Offline
                          jrbwh
                          #150
                          @RaspiCan Version 1.0.3 ist im Beta-Repo verfügbar. Du wechselt zum Beta-Repo indem Du in der Adapter-Ansicht ober auf das Werkzeug-Symbol klickst, dann den Haken bei Beta machst und bestätigst:
                          Nach dem Schließen mit OK evtl. nochmal auf Aktualisieren klicken. Dann sollte die Version 1.0.3 zur Installation angeboten werden.
                          • jrbwhJ jrbwh
                            #151
                            @jrbwh @raspican
                            Alternativ, ohne das Beta-Repo zu aktivieren:
                            Aber die Basis musst du zuvor auf Stand bringen.
                            • R Offline
                              RaspiCan
                              schrieb am zuletzt editiert von RaspiCan
                              #152
                              Vielen Dank für die Hilfe, ich bin bei linux absoluter Anfänger
                              e3oncan 1.03 ist installiert
                              nodejs 22 ist installiert
                              Error und timeout ist nun weg
                              vor dem update von bookworm auf trixie hab ich respekt
                              • R RaspiCan
                                #153
                                @RaspiCan sagte:
                                Nutzt dir aber nix, je länger du da 'Respekt' hast, desto komplizierter bis unmöglich wird das ganze.
                                • R Offline
                                  RaspiCan
                                  #154
                                  Mit welchem Befehl mach ich das umfassende Update von allem, bestensfalls noch zusätzlich auf die vorhandene ssd?
                                  • R RaspiCan
                                    #155
                                    @RaspiCan sagte:
                                    Hab ich dir oben schon verlinkt.
                                    • jrbwhJ jrbwh
                                      RaspiCan
                                      #156
                                      @jrbwh
                                      e3oncan.0
                                      2026-06-05 17:33:16.633	info	Startup of instance e3oncan.0: Done.
                                      e3oncan.0
                                      2026-06-05 17:33:16.581	info	UDS worker started on EHCU_0x6cf (0x6cf) with 1 active schedule(s).
                                      e3oncan.0
                                      2026-06-05 17:33:16.527	info	UDS worker started on BACKENDGATEWAY_0x6c5 (0x6c5) with 0 active schedule(s).
                                      e3oncan.0
                                      2026-06-05 17:33:16.475	info	UDS worker started on BACKENDGATEWAY_0x6c3 (0x6c3) with 0 active schedule(s).
                                      e3oncan.0
                                      2026-06-05 17:33:16.424	info	UDS worker started on VCMU_0x68c (0x68c) with 1 active schedule(s).
                                      e3oncan.0
                                      2026-06-05 17:33:16.372	info	UDS worker started on HMI_0x684 (0x684) with 0 active schedule(s).
                                      e3oncan.0
                                      2026-06-05 17:33:16.320	info	UDS worker started on HPMUMASTER_0x680 (0x680) with 2 active schedule(s).
                                      e3oncan.0
                                      2026-06-05 17:33:15.893	info	Collect worker started on HPMUMASTER_0x680
                                      e3oncan.0
                                      2026-06-05 17:33:15.842	info	CAN-Adapter connected: can0
                                      e3oncan.0
                                      2026-06-05 17:33:14.976	info	Startup of instance e3oncan.0: Starting.
                                      e3oncan.0
                                      2026-06-05 17:33:14.951	info	starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.e3oncan, node: v22.22.3, js-controller: 7.0.7
                                      host.raspberrypi
                                      2026-06-05 17:33:12.857	info	instance system.adapter.e3oncan.0 in version "1.0.3" started with pid 40520
                                      host.raspberrypi
                                      2026-06-05 17:33:09.377	info	instance system.adapter.e3oncan.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                        @RaspiCan sagte:
                                        RaspiCan
                                        #157
                                        @Thomas-Braun
                                        Sorry, ich meine das Backup, nicht update, sorry
                                        • R RaspiCan
                                          @Thomas-Braun
                                          #158
                                          @RaspiCan
                                          Mit dem Backitup-Adapter am besten.
