  4. Test Adapter e3oncan - Viessmann E3 Serie einbinden
    1.0k
177 Beiträge 14 Kommentatoren 23.0k Aufrufe 16 Beobachtet
  • R RaspiCan
    Habs direkt kopiert
    #140
    @RaspiCan
    Es fehlen die öffnenden CodeTags.
    Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
    Bring das auf die aktuelle Version.
    Und bring auch nodejs auf die aktuell für den ioBroker vorgesehene Version 22.
    SWAP würde ich auch einrichten.
    • R RaspiCan
      Script v.2026-06-01
      *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
                Kernel: Linux 6.12.62+rpt-rpi-v8
          Architecture: arm64
      OS is similar to:
      Model           : Raspberry Pi 4 Model B Rev 1.5
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 64bit
      System was installed 451 days ago (on 2025-03-10).
      Systemuptime and Load:
       14:15:45 up  2:28,  7 users,  load average: 0.13, 0.05, 0.01
      CPU threads     : 4
      *** LIFE CYCLE STATUS ***
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** TIME AND TIMEZONES ***
                     Local time: Fri 2026-06-05 14:15:45 CEST
                 Universal time: Fri 2026-06-05 12:15:45 UTC
                       RTC time: n/a
      System clock synchronized: no
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      raspi
      HOME=/home/raspi
      GROUPS=raspi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      *** DISPLAY-SERVER SETUP ***
      Display-Server:         Unknown
      Display-Manager:        * lightdm.service - Light Display Manager
      Desktop:
      Session:                tty
      System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'.
      Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
      *** MEMORY ***
      Mem:            4.0G        1.2G        874M         23M        2.0G        2.8G
      Swap:             0B          0B          0B
      Total:          4.0G        1.2G        874M
      Active iob-Instances:   8
               3795 M total memory
               1153 M used memory
               1604 M active memory
               1043 M inactive memory
                834 M free memory
                106 M buffer memory
               1791 M swap cache
                  0 M total swap
                  0 M used swap
                  0 M free swap
      top - 14:15:46 up  2:28,  7 users,  load average: 0.13, 0.05, 0.01
      Tasks: 243 total,   1 running, 242 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 14.3 us, 14.3 sy,  0.0 ni, 71.4 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   3795.8 total,    834.2 free,   1153.5 used,   1898.5 buff/cache
      MiB Swap:      0.0 total,      0.0 free,      0.0 used.   2642.3 avail Mem
      *** FAILED SERVICES ***
        UNIT                                 LOAD   ACTIVE SUB    DESCRIPTION
      * systemd-networkd-wait-online.service loaded failed failed Wait for Network to be Configured
      1 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      udev           devtmpfs  1.6G     0  1.6G   0% /dev
      tmpfs          tmpfs     380M  1.4M  379M   1% /run
      /dev/sda2      ext4      916G   19G  851G   3% /
      tmpfs          tmpfs     1.9G  224K  1.9G   1% /dev/shm
      tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
      /dev/sda1      vfat      511M   70M  442M  14% /boot/firmware
      tmpfs          tmpfs     380M   48K  380M   1% /run/user/1000
      /dev/mmcblk0p2 ext4       58G  8.0G   48G  15% /media/raspi/rootfs
      /dev/mmcblk0p1 vfat      510M   68M  443M  14% /media/raspi/bootfs
      Messages concerning filesystems in dmesg:
      [Fri Jun  5 11:47:43 2026] EXT4-fs (sda2): mounted filesystem a36be96c-66be-4487-a7a6-0481bca99d89 ro with ordered data mode. Quota mode: none.
      [Fri Jun  5 11:47:44 2026] EXT4-fs (sda2): re-mounted a36be96c-66be-4487-a7a6-0481bca99d89 r/w.
      [Fri Jun  5 11:47:52 2026] EXT4-fs (mmcblk0p2): recovery complete
      [Fri Jun  5 11:47:52 2026] EXT4-fs (mmcblk0p2): mounted filesystem a36be96c-66be-4487-a7a6-0481bca99d89 r/w with ordered data mode. Quota mode: none.
      Show mounted filesystems:
      TARGET                        SOURCE         FSTYPE      OPTIONS
      /                             /dev/sda2      ext4        rw,noatime
      |-/run/user/1000/doc          portal         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
      |-/boot/firmware              /dev/sda1      vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      |-/media/raspi/rootfs /dev/mmcblk0p2 ext4        rw,nosuid,nodev,relatime,errors=remount-ro
      `-/media/raspi/bootfs /dev/mmcblk0p1 vfat        rw,nosuid,nodev,relatime,uid=1000,gid=1000,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,showexec,utf8,flush,errors=remount-ro
      /var:
      2.5G    /var/
      1.1G    /var/cache/apt
      1.1G    /var/cache
      962M    /var/cache/apt/archives
      666M    /var/log
      Archived and active journals take up 664.5M in the file system.
      /opt/iobroker/backups:
      3.2G    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      5.6G    /opt/iobroker/iobroker-data/
      5.4G    /opt/iobroker/iobroker-data/history
      87M     /opt/iobroker/iobroker-data/files
      55M     /opt/iobroker/iobroker-data/backup-objects
      47M     /opt/iobroker/iobroker-data/files/admin.admin
      19M     /opt/iobroker/iobroker-data/objects.jsonl
      8.2M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BDfRPp5J.js
      4.3M    /opt/iobroker/iobroker-data/history/20260221/history.Drehzahl Verdichter Wärmepumpe.json
      4.2M    /opt/iobroker/iobroker-data/history/20260318/history.Drehzahl Verdichter Wärmepumpe.json
      4.2M    /opt/iobroker/iobroker-data/history/20260315/history.Drehzahl Verdichter Wärmepumpe.json
      USB-Devices by-id:
      USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
      please always prefer the links 'by-id':
      No Devices found 'by-id'
      No nvbackup.json found.
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.20.2
      /usr/bin/node           v20.20.2
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      ✓ Node.js installation is correct
      nodejs:
        Installed: 20.20.2-1nodesource1
        Candidate: 20.20.2-1nodesource1
        Version table:
       *** 20.20.2-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
           20.20.1-1nodesource1 1001
           20.20.0-1nodesource1 1001
           20.19.6-1nodesource1 1001
           20.19.5-1nodesource1 1001
           20.19.4-1nodesource1 1001
           20.19.3-1nodesource1 1001
           20.19.2-1nodesource1 1001
           20.19.1-1nodesource1 1001
           20.19.0-1nodesource1 1001
           20.18.3-1nodesource1 1001
           20.18.2-1nodesource1 1001
           20.18.1-1nodesource1 1001
           20.18.0-1nodesource1 1001
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.20.4+dfsg-1~deb12u2 500
              500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
           18.20.4+dfsg-1~deb12u1 500
              500 http://deb.debian.org/debian bookworm/main arm64 Packages
      No problems detected
      Errors in npm tree: 0
      Vulnerabilities detected in the Node.js version!
      node:fs:2380
          return binding.writeFileUtf8(
      Error: EACCES: permission denied, open '/home/iobroker/node_modules/is-my-node-vulnerable/schedule.etag'
          at Object.writeFileSync (node:fs:2380:20)
          at ClientRequest.<anonymous> (/home/iobroker/node_modules/is-my-node-vulnerable/is-vulnerable.js:82:12)
          at Object.onceWrapper (node:events:639:26)
          at ClientRequest.emit (node:events:524:28)
          at HTTPParser.parserOnIncomingClient [as onIncoming] (node:_http_client:702:27)
          at HTTPParser.parserOnHeadersComplete (node:_http_common:118:17)
          at TLSSocket.socketOnData (node:_http_client:544:22)
          at TLSSocket.emit (node:events:524:28)
          at addChunk (node:internal/streams/readable:561:12)
          at readableAddChunkPushByteMode (node:internal/streams/readable:512:3) {
        errno: -13,
        code: 'EACCES',
        syscall: 'open',
        path: '/home/iobroker/node_modules/is-my-node-vulnerable/schedule.etag'
      Node.js v20.20.2
      npm notice
      npm notice New major version of npm available! 10.8.2 -> 11.16.0
      npm notice Changelog: https://github.com/npm/cli/releases/tag/v11.16.0
      npm notice To update run: npm install -g npm@11.16.0
      npm notice
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      raspberrypi         raspberrypi (version: 7.0.7, hostname: raspberrypi   , alive, uptime: 7713)
      Core adapters versions
      js-controller:  7.0.7
      admin:          7.7.22
      javascript:     "javascript" not found
      nodejs modules from github:     0
      Adapter State
      + system.adapter.e3oncan.0                : e3oncan               : raspberrypi                              -  enabled
        system.adapter.e3oncan.1                : e3oncan               : raspberrypi                              - disabled
      + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
      + system.adapter.history.0                : history               : raspberrypi                              -  enabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Adapters
      │ (index) │ id                         │ name        │ version   │ upgrade policy │
      │ 0       │ 'system.adapter.admin'     │ 'admin'     │ '7.7.22'  │ 'none'         │
      │ 1       │ 'system.adapter.backitup'  │ 'backitup'  │ '3.3.14'  │ 'none'         │
      │ 2       │ 'system.adapter.discovery' │ 'discovery' │ '5.0.0'   │ 'none'         │
      │ 3       │ 'system.adapter.e3oncan'   │ 'e3oncan'   │ '0.10.14' │ 'none'         │
      │ 4       │ 'system.adapter.echarts'   │ 'echarts'   │ '3.1.0'   │ 'none'         │
      │ 5       │ 'system.adapter.history'   │ 'history'   │ '3.0.1'   │ 'none'         │
      │ 6       │ 'system.adapter.socketio'  │ 'socketio'  │ '6.7.1'   │ 'none'         │
      │ 7       │ 'system.adapter.web'       │ 'web'       │ '7.0.8'   │ 'none'         │
      │ 8       │ 'system.adapter.ws'        │ 'ws'        │ '2.6.2'   │ 'none'         │
      ioBroker-Adapter Versions and update status
      Used repository: stable
      Adapter    "admin"        : 7.8.23   , installed 7.7.22 [Updatable]
      Adapter    "backitup"     : 3.3.14   , installed 3.3.14
      Adapter    "e3oncan"      : 0.11.3   , installed 0.10.14 [Updatable]
      Adapter    "echarts"      : 3.1.0    , installed 3.1.0
      Adapter    "history"      : 4.0.0    , installed 3.0.1  [Updatable]
      Controller "js-controller": 7.0.7    , installed 7.0.7
      Adapter    "socketio"     : 7.1.3    , installed 7.1.3
      Adapter    "web"          : 8.0.0    , installed 7.0.8  [Updatable]
      Adapter    "ws"           : 4.0.0    , installed 3.0.19 [Updatable]
      Objects and States
      Objects:        5587
      States:         5466
      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:5 https://mschneider82.github.io/vieventlog stable InRelease
      Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending systemupdates: 0
      *** Listening Ports ***
      Netid State  Recv-Q Send-Q Local Address:Port   Peer Address:PortProcess
      udp   UNCONN 0      0            0.0.0.0:mdns        0.0.0.0:*    users:(("avahi-daemon",pid=495,fd=12))
      udp   UNCONN 0      0            0.0.0.0:54621       0.0.0.0:*    users:(("avahi-daemon",pid=495,fd=14))
      udp   UNCONN 0      0                  *:37406             *:*    users:(("avahi-daemon",pid=495,fd=15))
      udp   UNCONN 0      0                  *:mdns              *:*    users:(("avahi-daemon",pid=495,fd=13))
      tcp   LISTEN 0      128          0.0.0.0:ssh         0.0.0.0:*    users:(("sshd",pid=14888,fd=3))
      tcp   LISTEN 0      128        127.0.0.1:ipp         0.0.0.0:*    users:(("cupsd",pid=629,fd=7))
      tcp   LISTEN 0      511        127.0.0.1:9000        0.0.0.0:*    users:(("iobroker.js-con",pid=24529,fd=25))
      tcp   LISTEN 0      511        127.0.0.1:9001        0.0.0.0:*    users:(("iobroker.js-con",pid=24529,fd=19))
      tcp   LISTEN 0      4096               *:5000              *:*    users:(("vieventlog",pid=25918,fd=5))
      tcp   LISTEN 0      128             [::]:ssh            [::]:*    users:(("sshd",pid=14888,fd=4))
      tcp   LISTEN 0      511                *:tproxy            *:*    users:(("io.admin.0",pid=24561,fd=32))
      tcp   LISTEN 0      511                *:8082              *:*    users:(("io.web.0",pid=25014,fd=27))
      tcp   LISTEN 0      16                 *:5900              *:*    users:(("wayvnc",pid=680,fd=9))
      tcp   LISTEN 0      128            [::1]:ipp            [::]:*    users:(("cupsd",pid=629,fd=6))
      2026-06-05 14:15:39.649  - error: e3oncan.0 (27942) UDS timeout on 0x68c.388
      2026-06-05 14:15:40.255  - error: e3oncan.0 (27942) UDS timeout on 0x680.1393
      2026-06-05 14:15:43.778  - error: e3oncan.0 (27942) UDS timeout on 0x6cf.2442
      2026-06-05 14:15:47.152  - error: e3oncan.0 (27942) UDS timeout on 0x68c.390
      2026-06-05 14:15:47.757  - error: e3oncan.0 (27942) UDS timeout on 0x680.1769
      2026-06-05 14:15:53.765  - error: e3oncan.0 (27942) UDS timeout on 0x6cf.2442
      2026-06-05 14:15:54.691  - error: e3oncan.0 (27942) UDS timeout on 0x68c.2852
      2026-06-05 14:15:55.262  - error: e3oncan.0 (27942) UDS timeout on 0x680.1770
      2026-06-05 14:16:02.212  - error: e3oncan.0 (27942) UDS timeout on 0x68c.388
      2026-06-05 14:16:02.773  - error: e3oncan.0 (27942) UDS timeout on 0x680.1771
      2026-06-05 14:16:03.772  - error: e3oncan.0 (27942) UDS timeout on 0x6cf.2442
      2026-06-05 14:16:09.724  - error: e3oncan.0 (27942) UDS timeout on 0x68c.390
      2026-06-05 14:16:10.287  - error: e3oncan.0 (27942) UDS timeout on 0x680.1772
      2026-06-05 14:16:13.791  - error: e3oncan.0 (27942) UDS timeout on 0x6cf.2442
      2026-06-05 14:16:17.238  - error: e3oncan.0 (27942) UDS timeout on 0x68c.2852
      2026-06-05 14:16:17.800  - error: e3oncan.0 (27942) UDS timeout on 0x680.1773
      2026-06-05 14:16:23.784  - error: e3oncan.0 (27942) UDS timeout on 0x6cf.2442
      2026-06-05 14:16:24.750  - error: e3oncan.0 (27942) UDS timeout on 0x68c.388
      2026-06-05 14:16:25.316  - error: e3oncan.0 (27942) UDS timeout on 0x680.1774
      2026-06-05 14:16:32.273  - error: e3oncan.0 (27942) UDS timeout on 0x68c.390
      2026-06-05 14:16:32.832  - error: e3oncan.0 (27942) UDS timeout on 0x680.1775
      2026-06-05 14:16:33.794  - error: e3oncan.0 (27942) UDS timeout on 0x6cf.2442
      2026-06-05 14:16:39.804  - error: e3oncan.0 (27942) UDS timeout on 0x68c.2852
      2026-06-05 14:16:40.371  - error: e3oncan.0 (27942) UDS timeout on 0x680.1776
      2026-06-05 14:16:43.784  - error: e3oncan.0 (27942) UDS timeout on 0x6cf.2442
      ============= Mark until here for C&P =============
      iob diag has finished.
      HomoranH Offline
      HomoranH Offline
      #141
      @RaspiCan sagte:
      Da hat dein Dateisystem wohl einen Schaden (gehabt).
      @RaspiCan sagte:
      Veraltet!
      Bitte auf v22 updaten
      Von OS rede ich gar nicht
      • R RaspiCan
        Script v.2026-06-01
        *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
        OS is similar to:
        Docker          : false
        Kernel          : aarch64
        Userland        : 64bit
        CPU threads     : 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        raspi
        HOME=/home/raspi
        iobroker
        HOME=/home/iobroker
        Desktop:
        Session:                tty
        *** MEMORY ***
        Swap:             0B          0B          0B
                 3795 M total memory
                 1153 M used memory
                  834 M free memory
                  106 M buffer memory
                 1791 M swap cache
                    0 M total swap
                    0 M used swap
                    0 M free swap
        *** FILESYSTEM ***
        /var:
        2.5G    /var/
        1.1G    /var/cache/apt
        1.1G    /var/cache
        666M    /var/log
        USB-Devices by-id:
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        nodejs:
          Version table:
        node:fs:2380
          errno: -13,
          code: 'EACCES',
          syscall: 'open',
        Node.js v20.20.2
        npm notice
        npm notice
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        admin:          7.7.22
        Adapter State
        + instance is alive
        Objects and States
        Objects:        5587
        States:         5466
        #142
        @RaspiCan
        Und lass mal den
        iob fix
        laufen, da stimmt was mit den Rechten nicht.
        jrbwhJ 1 Antwort Letzte Antwort
          @RaspiCan
          Und lass mal den
          iob fix
          jrbwhJ Offline
          jrbwhJ Offline
          jrbwh
          #143
          @raspican Ich würde immer noch gerne die Log-Einträge beim Start des e3oncan-Adapters sehen.
          Thomas BraunT R 2 Antworten Letzte Antwort
          • jrbwhJ jrbwh
            #144
            @jrbwh
            Ja, würde allerdings auf einem System mit aktuellem Stand sinnvoller sein. Die ioBroker-Adapter sind ja auch alle pflegebedürftig, inkl.
              @jrbwh
              jrbwhJ Offline
              jrbwhJ Offline
              jrbwh
              #145
              @Thomas-Braun Stimmt.
              @raspican Wenn Du den Adpater updatest, empfehle ich, direkt auf v1.0.3 (Beta-Repo) zu gehen. Sonst gibt's beim node.js-Upgrade gleich wieder neue Probleme. Die Änderungen sind im Readme und in diesem Thread ganz oben ausführlich beschrieben.
              R 1 Antwort Letzte Antwort
              • jrbwhJ jrbwh
                RaspiCan
                #146
                @jrbwh
                v1.0.3=0.11.3?
                Thomas BraunT jrbwhJ 2 Antworten Letzte Antwort
                • R RaspiCan
                  @jrbwh
                  v1.0.3=0.11.3?
                  #147
                  @RaspiCan
                  Nein, die 1.0.3 liegt nur als Beta-Version im entsprechenden Repository bereit.
                  Hast du denn deine Kiste jetzt auf einen aktuellen Stand gehievt?
                  • R Offline
                    RaspiCan
                    #148
                    Nein, habe ich nicht, muss mir das erst anlesen wie das geht.
                    • R RaspiCan
                      #149
                      @RaspiCan
                      nodejs-Update:
                      iob nodejs-update
                      dann danach:
                      https://forum.iobroker.net/topic/81187/upgrade-von-debian-12-bookworm-auf-debian-13-trixie
                      • R RaspiCan
                        @jrbwh
                        v1.0.3=0.11.3?
                        jrbwhJ Offline
                        jrbwhJ Offline
                        jrbwh
                        #150
                        @RaspiCan Version 1.0.3 ist im Beta-Repo verfügbar. Du wechselt zum Beta-Repo indem Du in der Adapter-Ansicht ober auf das Werkzeug-Symbol klickst, dann den Haken bei Beta machst und bestätigst:
                        Nach dem Schließen mit OK evtl. nochmal auf Aktualisieren klicken. Dann sollte die Version 1.0.3 zur Installation angeboten werden.
                        • jrbwhJ jrbwh
                          #151
                          @jrbwh @raspican
                          Alternativ, ohne das Beta-Repo zu aktivieren:
                          Aber die Basis musst du zuvor auf Stand bringen.
                          • R Offline
                            RaspiCan
                            schrieb am zuletzt editiert von RaspiCan
                            #152
                            Vielen Dank für die Hilfe, ich bin bei linux absoluter Anfänger
                            e3oncan 1.03 ist installiert
                            nodejs 22 ist installiert
                            Error und timeout ist nun weg
                            vor dem update von bookworm auf trixie hab ich respekt
                            • R RaspiCan
                              #153
                              @RaspiCan sagte:
                              Nutzt dir aber nix, je länger du da 'Respekt' hast, desto komplizierter bis unmöglich wird das ganze.
                              • R Offline
                                RaspiCan
                                #154
                                Mit welchem Befehl mach ich das umfassende Update von allem, bestensfalls noch zusätzlich auf die vorhandene ssd?
                                • R RaspiCan
                                  #155
                                  @RaspiCan sagte:
                                  Hab ich dir oben schon verlinkt.
                                  • jrbwhJ jrbwh
                                    RaspiCan
                                    #156
                                    @jrbwh
                                    e3oncan.0
                                    2026-06-05 17:33:16.633	info	Startup of instance e3oncan.0: Done.
                                    e3oncan.0
                                    2026-06-05 17:33:16.581	info	UDS worker started on EHCU_0x6cf (0x6cf) with 1 active schedule(s).
                                    e3oncan.0
                                    2026-06-05 17:33:16.527	info	UDS worker started on BACKENDGATEWAY_0x6c5 (0x6c5) with 0 active schedule(s).
                                    e3oncan.0
                                    2026-06-05 17:33:16.475	info	UDS worker started on BACKENDGATEWAY_0x6c3 (0x6c3) with 0 active schedule(s).
                                    e3oncan.0
                                    2026-06-05 17:33:16.424	info	UDS worker started on VCMU_0x68c (0x68c) with 1 active schedule(s).
                                    e3oncan.0
                                    2026-06-05 17:33:16.372	info	UDS worker started on HMI_0x684 (0x684) with 0 active schedule(s).
                                    e3oncan.0
                                    2026-06-05 17:33:16.320	info	UDS worker started on HPMUMASTER_0x680 (0x680) with 2 active schedule(s).
                                    e3oncan.0
                                    2026-06-05 17:33:15.893	info	Collect worker started on HPMUMASTER_0x680
                                    e3oncan.0
                                    2026-06-05 17:33:15.842	info	CAN-Adapter connected: can0
                                    e3oncan.0
                                    2026-06-05 17:33:14.976	info	Startup of instance e3oncan.0: Starting.
                                    e3oncan.0
                                    2026-06-05 17:33:14.951	info	starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.e3oncan, node: v22.22.3, js-controller: 7.0.7
                                    host.raspberrypi
                                    2026-06-05 17:33:12.857	info	instance system.adapter.e3oncan.0 in version "1.0.3" started with pid 40520
                                    host.raspberrypi
                                    2026-06-05 17:33:09.377	info	instance system.adapter.e3oncan.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      @RaspiCan sagte:
                                      RaspiCan
                                      #157
                                      @Thomas-Braun
                                      Sorry, ich meine das Backup, nicht update, sorry
                                      • R RaspiCan
                                        @Thomas-Braun
                                        #158
                                        @RaspiCan
                                        Mit dem Backitup-Adapter am besten.
                                        • R Offline
                                          RaspiCan
                                          #159
                                          Dachte, da gibts noch was anderes
                                          Die Backups mach ich sowieso jede Nacht
