  4. Test Adapter e3oncan - Viessmann E3 Serie einbinden
    1.0k
177 Beiträge 14 Kommentatoren 23.0k Aufrufe 16 Beobachtet
  • R Offline
    RaspiCan
    schrieb am zuletzt editiert von RaspiCan
    #134
    2026-06-05 14:08:23.658 - error: e3oncan.0 (27942) UDS timeout on 0x68c.2852
    habe kein Update gemacht
    • R RaspiCan
      #135
      @RaspiCan sagte:
      Dann poste das Log, besser noch die Ausgabe von
      iob diag
      Damit man sieht wo du da wie unterwegs bist.
      • R Offline
        RaspiCan
        #136
        Script v.2026-06-01
        *** BASE SYSTEM ***
         Static hostname: raspberrypi
               Icon name: computer
                  Kernel: Linux 6.12.62+rpt-rpi-v8
            Architecture: arm64
        OS is similar to:
        Model           : Raspberry Pi 4 Model B Rev 1.5
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : 64bit
        System was installed 451 days ago (on 2025-03-10).
        Systemuptime and Load:
         14:15:45 up  2:28,  7 users,  load average: 0.13, 0.05, 0.01
        CPU threads     : 4
        *** LIFE CYCLE STATUS ***
        Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** TIME AND TIMEZONES ***
                       Local time: Fri 2026-06-05 14:15:45 CEST
                   Universal time: Fri 2026-06-05 12:15:45 UTC
                         RTC time: n/a
        System clock synchronized: no
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        raspi
        HOME=/home/raspi
        GROUPS=raspi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
        iobroker
        HOME=/home/iobroker
        *** DISPLAY-SERVER SETUP ***
        Display-Server:         Unknown
        Display-Manager:        * lightdm.service - Light Display Manager
        Desktop:
        Session:                tty
        System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'.
        Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
        *** MEMORY ***
        Mem:            4.0G        1.2G        874M         23M        2.0G        2.8G
        Swap:             0B          0B          0B
        Total:          4.0G        1.2G        874M
        Active iob-Instances:   8
                 3795 M total memory
                 1153 M used memory
                 1604 M active memory
                 1043 M inactive memory
                  834 M free memory
                  106 M buffer memory
                 1791 M swap cache
                    0 M total swap
                    0 M used swap
                    0 M free swap
        top - 14:15:46 up  2:28,  7 users,  load average: 0.13, 0.05, 0.01
        Tasks: 243 total,   1 running, 242 sleeping,   0 stopped,   0 zombie
        %Cpu(s): 14.3 us, 14.3 sy,  0.0 ni, 71.4 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   3795.8 total,    834.2 free,   1153.5 used,   1898.5 buff/cache
        MiB Swap:      0.0 total,      0.0 free,      0.0 used.   2642.3 avail Mem
        *** FAILED SERVICES ***
          UNIT                                 LOAD   ACTIVE SUB    DESCRIPTION
        * systemd-networkd-wait-online.service loaded failed failed Wait for Network to be Configured
        1 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        No critical errors detected
        *** FILESYSTEM ***
        udev           devtmpfs  1.6G     0  1.6G   0% /dev
        tmpfs          tmpfs     380M  1.4M  379M   1% /run
        /dev/sda2      ext4      916G   19G  851G   3% /
        tmpfs          tmpfs     1.9G  224K  1.9G   1% /dev/shm
        tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
        /dev/sda1      vfat      511M   70M  442M  14% /boot/firmware
        tmpfs          tmpfs     380M   48K  380M   1% /run/user/1000
        /dev/mmcblk0p2 ext4       58G  8.0G   48G  15% /media/raspi/rootfs
        /dev/mmcblk0p1 vfat      510M   68M  443M  14% /media/raspi/bootfs
        Messages concerning filesystems in dmesg:
        [Fri Jun  5 11:47:43 2026] EXT4-fs (sda2): mounted filesystem a36be96c-66be-4487-a7a6-0481bca99d89 ro with ordered data mode. Quota mode: none.
        [Fri Jun  5 11:47:44 2026] EXT4-fs (sda2): re-mounted a36be96c-66be-4487-a7a6-0481bca99d89 r/w.
        [Fri Jun  5 11:47:52 2026] EXT4-fs (mmcblk0p2): recovery complete
        [Fri Jun  5 11:47:52 2026] EXT4-fs (mmcblk0p2): mounted filesystem a36be96c-66be-4487-a7a6-0481bca99d89 r/w with ordered data mode. Quota mode: none.
        Show mounted filesystems:
        TARGET                        SOURCE         FSTYPE      OPTIONS
        /                             /dev/sda2      ext4        rw,noatime
        |-/run/user/1000/doc          portal         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
        |-/boot/firmware              /dev/sda1      vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        |-/media/raspi/rootfs /dev/mmcblk0p2 ext4        rw,nosuid,nodev,relatime,errors=remount-ro
        `-/media/raspi/bootfs /dev/mmcblk0p1 vfat        rw,nosuid,nodev,relatime,uid=1000,gid=1000,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,showexec,utf8,flush,errors=remount-ro
        /var:
        2.5G    /var/
        1.1G    /var/cache/apt
        1.1G    /var/cache
        962M    /var/cache/apt/archives
        666M    /var/log
        Archived and active journals take up 664.5M in the file system.
        /opt/iobroker/backups:
        3.2G    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        5.6G    /opt/iobroker/iobroker-data/
        5.4G    /opt/iobroker/iobroker-data/history
        87M     /opt/iobroker/iobroker-data/files
        55M     /opt/iobroker/iobroker-data/backup-objects
        47M     /opt/iobroker/iobroker-data/files/admin.admin
        19M     /opt/iobroker/iobroker-data/objects.jsonl
        8.2M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BDfRPp5J.js
        4.3M    /opt/iobroker/iobroker-data/history/20260221/history.Drehzahl Verdichter Wärmepumpe.json
        4.2M    /opt/iobroker/iobroker-data/history/20260318/history.Drehzahl Verdichter Wärmepumpe.json
        4.2M    /opt/iobroker/iobroker-data/history/20260315/history.Drehzahl Verdichter Wärmepumpe.json
        USB-Devices by-id:
        USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
        please always prefer the links 'by-id':
        No Devices found 'by-id'
        No nvbackup.json found.
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v20.20.2
        /usr/bin/node           v20.20.2
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        ✓ Node.js installation is correct
        nodejs:
          Installed: 20.20.2-1nodesource1
          Candidate: 20.20.2-1nodesource1
          Version table:
         *** 20.20.2-1nodesource1 1001
                500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
             20.20.1-1nodesource1 1001
             20.20.0-1nodesource1 1001
             20.19.6-1nodesource1 1001
             20.19.5-1nodesource1 1001
             20.19.4-1nodesource1 1001
             20.19.3-1nodesource1 1001
             20.19.2-1nodesource1 1001
             20.19.1-1nodesource1 1001
             20.19.0-1nodesource1 1001
             20.18.3-1nodesource1 1001
             20.18.2-1nodesource1 1001
             20.18.1-1nodesource1 1001
             20.18.0-1nodesource1 1001
             20.17.0-1nodesource1 1001
             20.16.0-1nodesource1 1001
             20.15.1-1nodesource1 1001
             20.15.0-1nodesource1 1001
             20.14.0-1nodesource1 1001
             20.13.1-1nodesource1 1001
             20.13.0-1nodesource1 1001
             20.12.2-1nodesource1 1001
             20.12.1-1nodesource1 1001
             20.12.0-1nodesource1 1001
             20.11.1-1nodesource1 1001
             20.11.0-1nodesource1 1001
             20.10.0-1nodesource1 1001
             20.9.0-1nodesource1 1001
             20.8.1-1nodesource1 1001
             20.8.0-1nodesource1 1001
             20.7.0-1nodesource1 1001
             20.6.1-1nodesource1 1001
             20.6.0-1nodesource1 1001
             20.5.1-1nodesource1 1001
             20.5.0-1nodesource1 1001
             20.4.0-1nodesource1 1001
             20.3.1-1nodesource1 1001
             20.3.0-1nodesource1 1001
             20.2.0-1nodesource1 1001
             20.1.0-1nodesource1 1001
             20.0.0-1nodesource1 1001
             18.20.4+dfsg-1~deb12u2 500
                500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
             18.20.4+dfsg-1~deb12u1 500
                500 http://deb.debian.org/debian bookworm/main arm64 Packages
        No problems detected
        Errors in npm tree: 0
        Vulnerabilities detected in the Node.js version!
        node:fs:2380
            return binding.writeFileUtf8(
        Error: EACCES: permission denied, open '/home/iobroker/node_modules/is-my-node-vulnerable/schedule.etag'
            at Object.writeFileSync (node:fs:2380:20)
            at ClientRequest.<anonymous> (/home/iobroker/node_modules/is-my-node-vulnerable/is-vulnerable.js:82:12)
            at Object.onceWrapper (node:events:639:26)
            at ClientRequest.emit (node:events:524:28)
            at HTTPParser.parserOnIncomingClient [as onIncoming] (node:_http_client:702:27)
            at HTTPParser.parserOnHeadersComplete (node:_http_common:118:17)
            at TLSSocket.socketOnData (node:_http_client:544:22)
            at TLSSocket.emit (node:events:524:28)
            at addChunk (node:internal/streams/readable:561:12)
            at readableAddChunkPushByteMode (node:internal/streams/readable:512:3) {
          errno: -13,
          code: 'EACCES',
          syscall: 'open',
          path: '/home/iobroker/node_modules/is-my-node-vulnerable/schedule.etag'
        Node.js v20.20.2
        npm notice
        npm notice New major version of npm available! 10.8.2 -> 11.16.0
        npm notice Changelog: https://github.com/npm/cli/releases/tag/v11.16.0
        npm notice To update run: npm install -g npm@11.16.0
        npm notice
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        raspberrypi         raspberrypi (version: 7.0.7, hostname: raspberrypi   , alive, uptime: 7713)
        Core adapters versions
        js-controller:  7.0.7
        admin:          7.7.22
        javascript:     "javascript" not found
        nodejs modules from github:     0
        Adapter State
        + system.adapter.e3oncan.0                : e3oncan               : raspberrypi                              -  enabled
          system.adapter.e3oncan.1                : e3oncan               : raspberrypi                              - disabled
        + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
        + system.adapter.history.0                : history               : raspberrypi                              -  enabled
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Adapters
        │ (index) │ id                         │ name        │ version   │ upgrade policy │
        │ 0       │ 'system.adapter.admin'     │ 'admin'     │ '7.7.22'  │ 'none'         │
        │ 1       │ 'system.adapter.backitup'  │ 'backitup'  │ '3.3.14'  │ 'none'         │
        │ 2       │ 'system.adapter.discovery' │ 'discovery' │ '5.0.0'   │ 'none'         │
        │ 3       │ 'system.adapter.e3oncan'   │ 'e3oncan'   │ '0.10.14' │ 'none'         │
        │ 4       │ 'system.adapter.echarts'   │ 'echarts'   │ '3.1.0'   │ 'none'         │
        │ 5       │ 'system.adapter.history'   │ 'history'   │ '3.0.1'   │ 'none'         │
        │ 6       │ 'system.adapter.socketio'  │ 'socketio'  │ '6.7.1'   │ 'none'         │
        │ 7       │ 'system.adapter.web'       │ 'web'       │ '7.0.8'   │ 'none'         │
        │ 8       │ 'system.adapter.ws'        │ 'ws'        │ '2.6.2'   │ 'none'         │
        ioBroker-Adapter Versions and update status
        Used repository: stable
        Adapter    "admin"        : 7.8.23   , installed 7.7.22 [Updatable]
        Adapter    "backitup"     : 3.3.14   , installed 3.3.14
        Adapter    "e3oncan"      : 0.11.3   , installed 0.10.14 [Updatable]
        Adapter    "echarts"      : 3.1.0    , installed 3.1.0
        Adapter    "history"      : 4.0.0    , installed 3.0.1  [Updatable]
        Controller "js-controller": 7.0.7    , installed 7.0.7
        Adapter    "socketio"     : 7.1.3    , installed 7.1.3
        Adapter    "web"          : 8.0.0    , installed 7.0.8  [Updatable]
        Adapter    "ws"           : 4.0.0    , installed 3.0.19 [Updatable]
        Objects and States
        Objects:        5587
        States:         5466
        Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
        Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
        Hit:5 https://mschneider82.github.io/vieventlog stable InRelease
        Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
        Reading package lists...
        Pending systemupdates: 0
        *** Listening Ports ***
        Netid State  Recv-Q Send-Q Local Address:Port   Peer Address:PortProcess
        udp   UNCONN 0      0            0.0.0.0:mdns        0.0.0.0:*    users:(("avahi-daemon",pid=495,fd=12))
        udp   UNCONN 0      0            0.0.0.0:54621       0.0.0.0:*    users:(("avahi-daemon",pid=495,fd=14))
        udp   UNCONN 0      0                  *:37406             *:*    users:(("avahi-daemon",pid=495,fd=15))
        udp   UNCONN 0      0                  *:mdns              *:*    users:(("avahi-daemon",pid=495,fd=13))
        tcp   LISTEN 0      128          0.0.0.0:ssh         0.0.0.0:*    users:(("sshd",pid=14888,fd=3))
        tcp   LISTEN 0      128        127.0.0.1:ipp         0.0.0.0:*    users:(("cupsd",pid=629,fd=7))
        tcp   LISTEN 0      511        127.0.0.1:9000        0.0.0.0:*    users:(("iobroker.js-con",pid=24529,fd=25))
        tcp   LISTEN 0      511        127.0.0.1:9001        0.0.0.0:*    users:(("iobroker.js-con",pid=24529,fd=19))
        tcp   LISTEN 0      4096               *:5000              *:*    users:(("vieventlog",pid=25918,fd=5))
        tcp   LISTEN 0      128             [::]:ssh            [::]:*    users:(("sshd",pid=14888,fd=4))
        tcp   LISTEN 0      511                *:tproxy            *:*    users:(("io.admin.0",pid=24561,fd=32))
        tcp   LISTEN 0      511                *:8082              *:*    users:(("io.web.0",pid=25014,fd=27))
        tcp   LISTEN 0      16                 *:5900              *:*    users:(("wayvnc",pid=680,fd=9))
        tcp   LISTEN 0      128            [::1]:ipp            [::]:*    users:(("cupsd",pid=629,fd=6))
        2026-06-05 14:15:39.649  - error: e3oncan.0 (27942) UDS timeout on 0x68c.388
        2026-06-05 14:15:40.255  - error: e3oncan.0 (27942) UDS timeout on 0x680.1393
        2026-06-05 14:15:43.778  - error: e3oncan.0 (27942) UDS timeout on 0x6cf.2442
        2026-06-05 14:15:47.152  - error: e3oncan.0 (27942) UDS timeout on 0x68c.390
        2026-06-05 14:15:47.757  - error: e3oncan.0 (27942) UDS timeout on 0x680.1769
        2026-06-05 14:15:53.765  - error: e3oncan.0 (27942) UDS timeout on 0x6cf.2442
        2026-06-05 14:15:54.691  - error: e3oncan.0 (27942) UDS timeout on 0x68c.2852
        2026-06-05 14:15:55.262  - error: e3oncan.0 (27942) UDS timeout on 0x680.1770
        2026-06-05 14:16:02.212  - error: e3oncan.0 (27942) UDS timeout on 0x68c.388
        2026-06-05 14:16:02.773  - error: e3oncan.0 (27942) UDS timeout on 0x680.1771
        2026-06-05 14:16:03.772  - error: e3oncan.0 (27942) UDS timeout on 0x6cf.2442
        2026-06-05 14:16:09.724  - error: e3oncan.0 (27942) UDS timeout on 0x68c.390
        2026-06-05 14:16:10.287  - error: e3oncan.0 (27942) UDS timeout on 0x680.1772
        2026-06-05 14:16:13.791  - error: e3oncan.0 (27942) UDS timeout on 0x6cf.2442
        2026-06-05 14:16:17.238  - error: e3oncan.0 (27942) UDS timeout on 0x68c.2852
        2026-06-05 14:16:17.800  - error: e3oncan.0 (27942) UDS timeout on 0x680.1773
        2026-06-05 14:16:23.784  - error: e3oncan.0 (27942) UDS timeout on 0x6cf.2442
        2026-06-05 14:16:24.750  - error: e3oncan.0 (27942) UDS timeout on 0x68c.388
        2026-06-05 14:16:25.316  - error: e3oncan.0 (27942) UDS timeout on 0x680.1774
        2026-06-05 14:16:32.273  - error: e3oncan.0 (27942) UDS timeout on 0x68c.390
        2026-06-05 14:16:32.832  - error: e3oncan.0 (27942) UDS timeout on 0x680.1775
        2026-06-05 14:16:33.794  - error: e3oncan.0 (27942) UDS timeout on 0x6cf.2442
        2026-06-05 14:16:39.804  - error: e3oncan.0 (27942) UDS timeout on 0x68c.2852
        2026-06-05 14:16:40.371  - error: e3oncan.0 (27942) UDS timeout on 0x680.1776
        2026-06-05 14:16:43.784  - error: e3oncan.0 (27942) UDS timeout on 0x6cf.2442
        ============= Mark until here for C&P =============
        iob diag has finished.
        Thomas BraunT HomoranH 3 Antworten Letzte Antwort
        • R RaspiCan
          Script v.2026-06-01
          *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
          OS is similar to:
          Docker          : false
          Kernel          : aarch64
          Userland        : 64bit
          CPU threads     : 4
          Current issues:
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          raspi
          HOME=/home/raspi
          iobroker
          HOME=/home/iobroker
          Desktop:
          Session:                tty
          *** MEMORY ***
          Swap:             0B          0B          0B
                   3795 M total memory
                   1153 M used memory
                    834 M free memory
                    106 M buffer memory
                   1791 M swap cache
                      0 M total swap
                      0 M used swap
                      0 M free swap
          *** FILESYSTEM ***
          /var:
          2.5G    /var/
          1.1G    /var/cache/apt
          1.1G    /var/cache
          666M    /var/log
          USB-Devices by-id:
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          nodejs:
            Version table:
          node:fs:2380
            errno: -13,
            code: 'EACCES',
            syscall: 'open',
          Node.js v20.20.2
          npm notice
          npm notice
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          admin:          7.7.22
          Adapter State
          + instance is alive
          Objects and States
          Objects:        5587
          States:         5466
          #137
          @RaspiCan
          Setz das in CodeTags.
          Oder kopier das komplett, inkl. der dafür vorgesehenen Kopiermarken.
          • R Offline
            RaspiCan
            #138
            Habs direkt kopiert
            • R RaspiCan
              Habs direkt kopiert
              HomoranH Offline
              HomoranH Offline
              #139
              @RaspiCan sagte:
              Habs direkt kopiert
              Aber die Startmarken abgeschnitten
              • R RaspiCan
                Habs direkt kopiert
                #140
                @RaspiCan
                Es fehlen die öffnenden CodeTags.
                Bring das auf die aktuelle Version.
                Und bring auch nodejs auf die aktuell für den ioBroker vorgesehene Version 22.
                SWAP würde ich auch einrichten.
                • R RaspiCan
                  Script v.2026-06-01
                  *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm64
                  OS is similar to:
                  Docker          : false
                  Kernel          : aarch64
                  Userland        : 64bit
                  CPU threads     : 4
                  Current issues:
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  raspi
                  HOME=/home/raspi
                  iobroker
                  HOME=/home/iobroker
                  Desktop:
                  Session:                tty
                  *** MEMORY ***
                  Swap:             0B          0B          0B
                           3795 M total memory
                           1153 M used memory
                            834 M free memory
                            106 M buffer memory
                           1791 M swap cache
                              0 M total swap
                              0 M used swap
                              0 M free swap
                  *** FILESYSTEM ***
                  /var:
                  2.5G    /var/
                  1.1G    /var/cache/apt
                  1.1G    /var/cache
                  666M    /var/log
                  USB-Devices by-id:
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  nodejs:
                    Version table:
                  node:fs:2380
                    errno: -13,
                    code: 'EACCES',
                    syscall: 'open',
                  Node.js v20.20.2
                  npm notice
                  npm notice
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Hosts:
                  admin:          7.7.22
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        5587
                  States:         5466
                  HomoranH Offline
                  HomoranH Offline
                  #141
                  @RaspiCan sagte:
                  Da hat dein Dateisystem wohl einen Schaden (gehabt).
                  @RaspiCan sagte:
                  Veraltet!
                  Bitte auf v22 updaten
                  Von OS rede ich gar nicht
                  • R RaspiCan
                    Script v.2026-06-01
                    *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm64
                    OS is similar to:
                    Docker          : false
                    Kernel          : aarch64
                    Userland        : 64bit
                    CPU threads     : 4
                    Current issues:
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    raspi
                    HOME=/home/raspi
                    iobroker
                    HOME=/home/iobroker
                    Desktop:
                    Session:                tty
                    *** MEMORY ***
                    Swap:             0B          0B          0B
                             3795 M total memory
                             1153 M used memory
                              834 M free memory
                              106 M buffer memory
                             1791 M swap cache
                                0 M total swap
                                0 M used swap
                                0 M free swap
                    *** FILESYSTEM ***
                    /var:
                    2.5G    /var/
                    1.1G    /var/cache/apt
                    1.1G    /var/cache
                    666M    /var/log
                    USB-Devices by-id:
                    /usr/bin/npm            10.8.2
                    /usr/bin/npx            10.8.2
                    nodejs:
                      Version table:
                    node:fs:2380
                      errno: -13,
                      code: 'EACCES',
                      syscall: 'open',
                    Node.js v20.20.2
                    npm notice
                    npm notice
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Hosts:
                    admin:          7.7.22
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        5587
                    States:         5466
                    #142
                    @RaspiCan
                    Und lass mal den
                    iob fix
                    laufen, da stimmt was mit den Rechten nicht.
                    jrbwhJ 1 Antwort Letzte Antwort
                      @RaspiCan
                      Und lass mal den
                      iob fix
                      jrbwhJ Offline
                      jrbwhJ Offline
                      jrbwh
                      #143
                      @raspican Ich würde immer noch gerne die Log-Einträge beim Start des e3oncan-Adapters sehen.
                      Thomas BraunT R 2 Antworten Letzte Antwort
                      • jrbwhJ jrbwh
                        #144
                        @jrbwh
                        Ja, würde allerdings auf einem System mit aktuellem Stand sinnvoller sein. Die ioBroker-Adapter sind ja auch alle pflegebedürftig, inkl.
                          @jrbwh
                          jrbwhJ Offline
                          jrbwhJ Offline
                          jrbwh
                          #145
                          @Thomas-Braun Stimmt.
                          @raspican Wenn Du den Adpater updatest, empfehle ich, direkt auf v1.0.3 (Beta-Repo) zu gehen. Sonst gibt's beim node.js-Upgrade gleich wieder neue Probleme. Die Änderungen sind im Readme und in diesem Thread ganz oben ausführlich beschrieben.
                          R 1 Antwort Letzte Antwort
                          • jrbwhJ jrbwh
                            RaspiCan
                            #146
                            @jrbwh
                            v1.0.3=0.11.3?
                            Thomas BraunT jrbwhJ 2 Antworten Letzte Antwort
                            • R RaspiCan
                              @jrbwh
                              v1.0.3=0.11.3?
                              #147
                              @RaspiCan
                              Nein, die 1.0.3 liegt nur als Beta-Version im entsprechenden Repository bereit.
                              Hast du denn deine Kiste jetzt auf einen aktuellen Stand gehievt?
                              • R Offline
                                RaspiCan
                                #148
                                Nein, habe ich nicht, muss mir das erst anlesen wie das geht.
                                • R RaspiCan
                                  #149
                                  @RaspiCan
                                  nodejs-Update:
                                  iob nodejs-update
                                  dann danach:
                                  https://forum.iobroker.net/topic/81187/upgrade-von-debian-12-bookworm-auf-debian-13-trixie
                                  • R RaspiCan
                                    @jrbwh
                                    v1.0.3=0.11.3?
                                    jrbwhJ Offline
                                    jrbwhJ Offline
                                    jrbwh
                                    #150
                                    @RaspiCan Version 1.0.3 ist im Beta-Repo verfügbar. Du wechselt zum Beta-Repo indem Du in der Adapter-Ansicht ober auf das Werkzeug-Symbol klickst, dann den Haken bei Beta machst und bestätigst:
                                    Nach dem Schließen mit OK evtl. nochmal auf Aktualisieren klicken. Dann sollte die Version 1.0.3 zur Installation angeboten werden.
                                    • jrbwhJ jrbwh
                                      #151
                                      @jrbwh @raspican
                                      Alternativ, ohne das Beta-Repo zu aktivieren:
                                      Aber die Basis musst du zuvor auf Stand bringen.
                                      • R Offline
                                        RaspiCan
                                        #152
                                        Vielen Dank für die Hilfe, ich bin bei linux absoluter Anfänger
                                        e3oncan 1.03 ist installiert
                                        nodejs 22 ist installiert
                                        Error und timeout ist nun weg
                                        vor dem update von bookworm auf trixie hab ich respekt
                                        • R RaspiCan
                                          #153
                                          @RaspiCan sagte:
                                          Nutzt dir aber nix, je länger du da 'Respekt' hast, desto komplizierter bis unmöglich wird das ganze.
