  4. DMP8624 -> iobroker
    6.0k
DMP8624 -> iobroker
235 Beiträge 7 Kommentatoren 50.5k Aufrufe 5 Beobachtet
  • Ralla66R Ralla66
    @wal
    keine Änderung,
    ESP TX geht ja mit RS485 -> Hterm/DPM bei mir.
    Geantwortet wird auch.
    Schauen was an RX ankommt per print ?
    Was bedeutet das DC hinter der Baud ? for web ui cmd Mqtt Json .
    Was bewirkt das.
    WalW Offline
    WalW Offline
    Wal
    #81
    @ralla66 ,
    das kommt bei mir raus:
    17:52:29.708 : 01 03 02 00 1d 78 4d
    17:52:29.861 > 01 03 00 00 00 01 00 02 62 c6
    17:52:29.922 : 01 03 02 03 e8 b8 fa
    17:52:30.032 > 01 03 00 01 00 01 00 02 5f 06
    17:52:30.093 : 01 03 02 01 f4 b8 53
    17:52:30.243 > 01 03 00 02 00 01 00 02 1b 06
    17:52:30.304 : 01 03 02 00 01 79 84
    17:52:30.454 > 01 03 10 01 00 01 00 02 5d 96
    17:52:30.515 : 01 03 02 03 e8 b8 fa
    17:52:30.666 > 01 03 10 02 00 01 00 02 19 96
    17:52:30.727 : 01 03 02 00 00 b8 44
    17:52:30.830 > 01 03 10 03 00 01 00 02 24 56
    17:52:30.892 : 01 03 02 00 1d 78 4d
    17:52:30.948 BRY: GC from 4683 to 4223 bytes, objects freed 2/46 (in 1 ms) - slots from 51/122 to 51/122
    17:52:30.959 MQT: tele/Haus.DPM8624/STATE = {"Time":"2023-09-18T17:52:30","Uptime":"0T00:16:38","UptimeSec":998,"Heap":142,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":101,"MqttCount":1,"Berry":{"HeapUsed":4,"Objects":46},"Wifi":{"AP":1,"SSId":"1GBit","BSSId":"B0:F2:08:54:F3:97","Channel":11,"Mode":"11n","RSSI":90,"Signal":-55,"LinkCount":1,"Downtime":"0T00:00:03"}}
    17:52:30.978 MQT: tele/Haus.DPM8624/SENSOR = {"Time":"2023-09-18T17:52:30","DC":{"sVolt":10.00,"sCur":0.50,"sSwitch":1,"dVolt":10.00,"vCur":0.00,"tCur":29.0}}
    17:52:31.038 > 01 03 00 00 00 01 00 02 62 c6
    17:52:31.098 : 01 03 02 03 e8 b8 fa
    17:52:31.249 > 01 03 00 01 00 01 00 02 5f 06
    17:52:31.310 : 01 03 02 01 f4 b8 53
    17:52:31.511 > 01 03 00 02 00 01 00 02 1b 06
    17:52:31.572 : 01 03 02 00 01 79 84
    17:52:31.675 > 01 03 10 01 00 01 00 02 5d 96
    17:52:31.736 : 01 03 02 03 e8 b8 fa
    17:52:31.839 > 01 03 10 02 00 01 00 02 19 96
    17:52:31.900 : 01 03 02 00 00 b8 44
    17:52:32.055 > 01 03 10 03 00 01 00 02 24 56
    17:52:32.116 : 01 03 02 00 1d 78 4d
    17:52:32.267 > 01 03 00 00 00 01 00 02 62 c6
    17:52:32.328 : 01 03 02 03 e8 b8 fa
    17:52:32.431 > 01 03 00 01 00 01 00 02 5f 06
    17:52:32.492 : 01 03 02 01 f4 b8 53
    17:52:32.642 > 01 03 00 02 00 01 00 02 1b 06
    17:52:32.703 : 01 03 02 00 01 79 84
    17:52:32.857 > 01 03 10 01 00 01 00 02 5d 96
    17:52:32.918 : 01 03 02 03 e8 b8 fa
    17:52:33.076 > 01 03 10 02 00 01 00 02 19 96
    17:52:33.137 : 01 03 02 00 00 b8 44
    17:52:33.240 > 01 03 10 03 00 01 00 02 24 56
    Walter
    DoorIO-Adapter
    • WalW Wal
      @ralla66 ,
      das ist der Name den man als Platzhalter vergibt, damit man die Empfangenen Daten im Skript nutzen kann.
      temp=DC#sVolt
      print %temp%
      da wird bei dir aber auch 0 rauskommen wie in der Anzeige.
      edit: schau doch mal in die Konsole mit sensor53 d1
      Ralla66R Offline
      Ralla66R Offline
      Ralla66
      #82
      @wal sagte in DMP8624 -> iobroker:
      sensor53 d1
      16:53:11.175 > 01 03 10 02 00 01 00 02 19 96
      16:53:11.236 : 7f 7e bf ff 8f d7
      16:53:11.380 > 01 03 10 03 00 01 00 02 24 56
      16:53:11.441 : 7f 7e bf c5 0f 65 ff
      16:53:11.586 > 01 03 00 00 00 01 00 02 62 c6
      16:53:11.647 : 7f 7e bf 17 24 f5
      16:53:11.790 > 01 03 00 01 00 01 00 02 5f 06
      16:53:11.852 : 7f 7e bf 2f 64 e0
      16:53:12.002 > 01 03 00 02 00 01 00 02 1b 06
      dann ist RX falsch
      WalW 1 Antwort Letzte Antwort
      • Ralla66R Ralla66
        sensor53 d1
        dann ist RX falsch
        WalW Offline
        WalW Offline
        Wal
        #83
        @ralla66 ,
        da haben wir doch das Problem.
        Du kannst die Daten senden aber empfängst nur sch****.
        Walter
        DoorIO-Adapter
        • WalW Wal
          @ralla66 ,
          Ralla66R Offline
          Ralla66R Offline
          Ralla66
          #84
          @wal
          ok, invertiert ? weil der RS485 / TTL Wandler fehlt ?
          Nachtrag, die kommen aber sauber in Hterm am PC an.
          Das ist ja ein FTDI Chip drinne, meine der Invertiert.
          WalW 2 Antworten Letzte Antwort
          • Ralla66R Ralla66
            @wal
            WalW Offline
            WalW Offline
            Wal
            #85
            @ralla66 ,
            RS485 arbeitet glaube ich mit positiver und negativer Spannung.
            -5V GND +5V
            TTL nur mit positiver
            GND +5V
            Walter
            DoorIO-Adapter
            • Ralla66R Ralla66
              @wal
              WalW Offline
              WalW Offline
              Wal
              #86
              @ralla66 sagte in DMP8624 -> iobroker:
              @wal
              Kannst bei mir einen Wandler abholen, habe welche da. ;-)
              Walter
              DoorIO-Adapter
              • WalW Wal
                @ralla66 ,
                -5V GND +5V
                GND +5V
                Ralla66R Offline
                Ralla66R Offline
                Ralla66
                #87
                @wal
                ok hilft ja nicht, Kramkiste oder Amazon Bestellbutton click. :-)
                Da war was, teste aber noch Serial Delimiter 128 vom ESP
                • HomoranH Offline
                  HomoranH Offline
                  #88
                  ich lese hier die ganze Zeit hochinteressiert mit.
                  Kannte das "Netzteil" bisher nicht, hab es mir bei ELV angesehen und die Anleitung dort, sowie bei joy-it durchgelesen.
                  Nach meinem Verständnis müsste die Verbindung mit dem USB-Kabel an A/B und Umstellung des Protokolls im Menü auf Modbus doch mit dem Modbus Adapter möglich se7n.
                  ...wenn man die Register kennte.
                  ich hab keine gefunden.
                  oder sind die 30001...., die ich in dem Output bei euch sehe, die Register?
                  Ralla66R WalW 2 Antworten Letzte Antwort
                    Ralla66R Offline
                    Ralla66R Offline
                    Ralla66
                    #89
                    Register sind bekannt.
                    01 Geräte ID
                    03 Read Register oder 06 Write Register oder 10 Write multiple registers
                    Nachtrag
                    PDF click
                      WalW Offline
                      WalW Offline
                      Wal
                      schrieb am zuletzt editiert von Wal
                      #90
                      @homoran ,
                      habe ja schon Verbindung mit dem Modbusadapter hinbekommen.
                      40001 ist die Spannung habe ich schon rausgefunden.
                      Leider meldet sich der TE nicht mehr, deshalb habe ich nicht weiter getestet.
                      Das Teil muss ja dann auch direkt mit dem ioBroker verbunden werden oder man Braucht ein Seriell/TCP Adapter.
                      Da ist mir aber erst mal ein ESP lieber weil vorhanden. ;-)
                      Mit dem Netzteil kann man das machen falls du das noch nicht kennst.
                      Walter
                      DoorIO-Adapter
                      • WalW Wal
                        @homoran ,
                        HomoranH Offline
                        HomoranH Offline
                        #91
                        ja! das ist klar.
                        Hab für modbus und smartmeter einen Slave im Keller.
                        Jetzt brauch ich nur noch einen Grund das Teil zu kaufen
                          ja! das ist klar.
                          WalW Offline
                          WalW Offline
                          Wal
                          #92
                          @homoran ,
                          du bist sehr schnell siehe oben. ;-)
                          Walter
                          DoorIO-Adapter
                          • WalW Wal
                            @homoran ,
                            HomoranH Offline
                            HomoranH Offline
                            #93
                            @homoran ,
                            iiiihhhhhh
                            ich hab dir und deinem Link vertraut
                            Jod!
                            heißes Wasser!
                            Weihwasser!
                            ist das so etwas
                              @homoran ,
                              iiiihhhhhh
                              Jod!
                              heißes Wasser!
                              Weihwasser!
                              ist das so etwas
                              WalW Offline
                              WalW Offline
                              Wal
                              #94
                              @homoran ,
                              Angeber. ;-)
                              Ja fast, mit dem Teil kann man eine Nulleinspeisung mit einem Balkonkraftwerk hinbekommen.
                              Walter
                              DoorIO-Adapter
                              • WalW Wal
                                @homoran ,
                                Angeber. ;-)
                                HomoranH Offline
                                HomoranH Offline
                                #95
                                @homoran ,
                                damit ^^ auch.
                                da hab ich 55.9V, mit denen ich was machen könnte.
                                Angeber.
                                nur ein ganz klein wenig 😂
                                  @homoran ,
                                  damit ^^ auch.
                                  Angeber.
                                  WalW Offline
                                  WalW Offline
                                  Wal
                                  #96
                                  @homoran ,
                                  schau dir das Video an ist sehr interessant, geht ja auch mit dem Handy.
                                  Walter
                                  DoorIO-Adapter
                                  • WalW Wal
                                    @homoran ,
                                    Ralla66R Offline
                                    Ralla66R Offline
                                    Ralla66
                                    #97
                                    @wal
                                    und immer schön langsam die Spannung / Strom erhöhen bei Balkonwechselrichtern.
                                    Sonst werden die Eingangs C im WR gegrillt. Hab da praktische Erfahrung mit :-)
                                    • Ralla66R Ralla66
                                      @wal
                                      WalW Offline
                                      WalW Offline
                                      Wal
                                      #98
                                      @ralla66 ,
                                      ich würde ja gerne auch Nachts auf Null regeln.
                                      Bei ca. 270W und 14 Stunden brauche ich bei 80% Lade/Entladung einen 5KWh Akku und um den zu laden ca. 3 Paneel im Sommer.
                                      Nur fürs spielen kann ich mich noch nicht dazu durchringen, aber den DC-Regler habe ich schon mal. :-)
                                      Walter
                                      DoorIO-Adapter
                                      Ralla66R 2 Antworten Letzte Antwort
                                      • WalW Wal
                                        @ralla66 ,
                                        Ralla66R Offline
                                        Ralla66R Offline
                                        Ralla66
                                        #99
                                        @wal
                                        habe ich so ähnlich, 2 Plyontech mit 2,4 KWh , abends per Nulleinspeisung raus.
                                        Hatte das erst per Hoymiles 600 mit ESP DTU geregelt. Riesiger Aufwand halt.
                                        Versicherungstechnisch auch fragwürdig. Hatte dann den DPM gekauft aber das
                                        Projekt wieder verworfen.
                                        Bin nun auf Lumentree WR umgestiegen. Die bieten per Wlan eine Nulleinspeisung an.
                                        Mqtt für IO ist auch an Board. Die Zählerwerte können per Json vom Tasmota ESP
                                        angefordert werden. Sehr cool geproggtes Projekt.
                                        Versicherungstechnisch halt sauber.
                                        Github Projekt
                                        Video von Christian der Kanal
                                        • WalW Wal
                                          @ralla66 ,
                                          Ralla66R Offline
                                          Ralla66R Offline
                                          Ralla66
                                          #100
                                          @wal
                                          Nur mal so als Idee.
                                          Im DPM Script könnte man ja das Json des Zähler ESP abholen und den Bezugswert Watt rausfiltern. Drauf hin dann V und A des DPM steuern.
                                          Möglichkeit 2 wäre eine Rule im Zähler ESP setzen die alle x sec einen http Wert zum DPM ESP sendet.
                                          Test Json im IO abholen
                                          Json mit ESP Lumentree Software
