Nodejs v18.12.1
@thomas-braun sagte in Nodejs v18.12.1:
ls -la /etc/systemd/system/multi-user.target.wants/iobroker.service
pi@raspberrypi4-iob:~ $ ls -la /etc/systemd/system/multi-user.target.wants/iobroker.service lrwxrwxrwx 1 root root 36 Okt 29 2021 /etc/systemd/system/multi-user.target.wants/iobroker.service -> /lib/systemd/system/iobroker.serviceiob stop iob fix iob start -
iob fix
pi@raspberrypi4-iob:~ $ iob stop pi@raspberrypi4-iob:~ $ iob fix pi@raspberrypi4-iob:~ $da bei fix passiert nichts weiter
iob fix
curl -fsL https://iobroker.net/fix.sh | bash - -
pi@raspberrypi4-iob:~ $ curl -fsL https://iobroker.net/fix.sh | bash - library: loaded Library version=2022-06-15 ========================================================================== Welcome to the ioBroker installation fixer! Script version: 2022-06-03 You might need to enter your password a couple of times. ========================================================================== ========================================================================== Installing prerequisites (1/3) ========================================================================== Holen:1 http://archive.raspberrypi.org/debian buster InRelease [32,6 kB] Holen:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB] OK:3 https://deb.nodesource.com/node_16.x buster InRelease Holen:4 http://archive.raspberrypi.org/debian buster/main armhf Packages [392 kB] Es wurden 439 kB in 1 s geholt (425 kB/s). Paketlisten werden gelesen... Fertig Installed gcc-c++ ========================================================================== Checking ioBroker user and directory permissions (2/3) ========================================================================== Created /etc/sudoers.d/iobroker Fixing directory permissions... ========================================================================== Checking autostart (3/3) ========================================================================== -
pi@raspberrypi4-iob:~ $ curl -fsL https://iobroker.net/fix.sh | bash - library: loaded Library version=2022-06-15 ========================================================================== Welcome to the ioBroker installation fixer! Script version: 2022-06-03 You might need to enter your password a couple of times. ========================================================================== ========================================================================== Installing prerequisites (1/3) ========================================================================== Holen:1 http://archive.raspberrypi.org/debian buster InRelease [32,6 kB] Holen:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB] OK:3 https://deb.nodesource.com/node_16.x buster InRelease Holen:4 http://archive.raspberrypi.org/debian buster/main armhf Packages [392 kB] Es wurden 439 kB in 1 s geholt (425 kB/s). Paketlisten werden gelesen... Fertig Installed gcc-c++ ========================================================================== Checking ioBroker user and directory permissions (2/3) ========================================================================== Created /etc/sudoers.d/iobroker Fixing directory permissions... ========================================================================== Checking autostart (3/3) ==========================================================================Das ist nicht vollständig.
juppiii !!! jetzt läuft der wieder BRAVO THOMAS
Aber was machen wir mit dem Speicherplatz da war doch viel zu wenig da?Das dürfte ich in den nächsten Tagen von alleine klären. Wenn da jetzt die log-Files nicht mehr so rasant größer werden wird das über die Log Rotation irgendwann von alleine entsorgt.
Schau mal noch kurz hier bitte
7,2 GiB [ ] /opt 3,1 GiB [ ] /usr 1,2 GiB [ ] /home 48,2 MiB [ ] /boot 8,5 MiB [ ] /run 7,3 MiB [ ] /root 5,9 MiB [ ] /etc 36,0 KiB [ ] /tmp e 16,0 KiB [ ] /lost+found e 4,0 KiB [ ] /srv e 4,0 KiB [ ] /mnt e 4,0 KiB [ ] /media 0,0 B [ ] /sys . 0,0 B [ ] /proc 0,0 B [ ] /dev @ 0,0 B [ ] sbin @ 0,0 B [ ] lib @ 0,0 B [ ] bin -
7,2 GiB [ ] /opt 3,1 GiB [ ] /usr 1,2 GiB [ ] /home 48,2 MiB [ ] /boot 8,5 MiB [ ] /run 7,3 MiB [ ] /root 5,9 MiB [ ] /etc 36,0 KiB [ ] /tmp e 16,0 KiB [ ] /lost+found e 4,0 KiB [ ] /srv e 4,0 KiB [ ] /mnt e 4,0 KiB [ ] /media 0,0 B [ ] /sys . 0,0 B [ ] /proc 0,0 B [ ] /dev @ 0,0 B [ ] sbin @ 0,0 B [ ] lib @ 0,0 B [ ] binAuch das ist mal wieder nicht vollständig.
ja habe ich auch gerade gemerkt -
7,2 GiB [ ] /opt 3,1 GiB [ ] /usr 1,2 GiB [ ] /home 48,2 MiB [ ] /boot 8,5 MiB [ ] /run 7,3 MiB [ ] /root 5,9 MiB [ ] /etc 36,0 KiB [ ] /tmp e 16,0 KiB [ ] /lost+found e 4,0 KiB [ ] /srv e 4,0 KiB [ ] /mnt e 4,0 KiB [ ] /media 0,0 B [ ] /sys . 0,0 B [ ] /proc 0,0 B [ ] /dev @ 0,0 B [ ] sbin @ 0,0 B [ ] lib @ 0,0 B [ ] binAuch das ist nicht vollständig.
Kopier doch einfach ab dem LogIn Prompt alles bis einschließlich des nächsten leeren LogIn Prompts. -
0,0 B [ ] 400 /dev 5,9 MiB [ ] 1.697 /etc 1,2 GiB [ ] 35.930 /home e 16,0 KiB [ ] /lost+found e 4,0 KiB [ ] /media e 4,0 KiB [ ] /mnt 7,2 GiB [ ] > 100k /opt . 0,0 B [ ] > 100k /proc 7,3 MiB [ ] 987 /root 8,5 MiB [ ] 559 /run e 4,0 KiB [ ] /srv 0,0 B [ ] 31.303 /sys 36,0 KiB [ ] 8 /tmp 3,1 GiB [ ] > 100k /usr 94,4 GiB [##########] 7.007 /var @ 0,0 B [ ] bin @ 0,0 B [ ] lib @ 0,0 B [ ] sbin -
OK dann lassen wir das. Ich will Dich nicht weiter nerven. Wenigstens nicht mehr heute :)
Villen Dank
df -h -
df -h
pi@raspberrypi4-iob:~ $ df -h Dateisystem Größe Benutzt Verf. Verw% Eingehängt auf /dev/root 117G 106G 6,4G 95% / devtmpfs 1,8G 0 1,8G 0% /dev tmpfs 1,9G 0 1,9G 0% /dev/shm tmpfs 1,9G 8,5M 1,9G 1% /run tmpfs 5,0M 4,0K 5,0M 1% /run/lock tmpfs 1,9G 0 1,9G 0% /sys/fs/cgroup /dev/mmcblk0p1 253M 49M 204M 20% /boot tmpfs 384M 0 384M 0% /run/user/1000 //192.168.178.2/homes/ioBroker-Backup 5,5T 3,1T 2,4T 57% /opt/iobroker/backups -
