  4. Nodejs v18.12.1
Nodejs v18.12.1
382 Beiträge 10 Kommentatoren 87.0k Aufrufe 8 Beobachtet
  • KrisiunK
    KrisiunK
    Krisiun
    #240
    @thomas-braun sagte in Nodejs v18.12.1:
    ls -la /etc/systemd/system/multi-user.target.wants/iobroker.service
    pi@raspberrypi4-iob:~ $ ls -la /etc/systemd/system/multi-user.target.wants/iobroker.service
    lrwxrwxrwx 1 root root 36 Okt 29  2021 /etc/systemd/system/multi-user.target.wants/iobroker.service -> /lib/systemd/system/iobroker.service
    • KrisiunK Krisiun
      Thomas BraunT
      Thomas BraunT
      Most Active Developer
      #241
      @krisiun
      iob stop
      iob fix
      iob start
      • KrisiunK
        KrisiunK
        Krisiun
        #242
        iob fix
        pi@raspberrypi4-iob:~ $ iob stop
        pi@raspberrypi4-iob:~ $ iob fix
        da bei fix passiert nichts weiter
        • KrisiunK Krisiun
          iob fix
          Thomas BraunT
          Thomas BraunT
          #243
          @krisiun
          curl -fsL https://iobroker.net/fix.sh | bash -
          • KrisiunK
            KrisiunK
            Krisiun
            #244
            pi@raspberrypi4-iob:~ $ curl -fsL https://iobroker.net/fix.sh | bash -
            library: loaded
            Library version=2022-06-15
                Welcome to the ioBroker installation fixer!
                Script version: 2022-06-03
                You might need to enter your password a couple of times.
                Installing prerequisites (1/3)
            Holen:1 http://archive.raspberrypi.org/debian buster InRelease [32,6 kB]
            Holen:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
            OK:3 https://deb.nodesource.com/node_16.x buster InRelease
            Holen:4 http://archive.raspberrypi.org/debian buster/main armhf Packages [392 kB]
            Es wurden 439 kB in 1 s geholt (425 kB/s).
            Installed gcc-c++
                Checking ioBroker user and directory permissions (2/3)
                Checking autostart (3/3)
            • KrisiunK
              KrisiunK
              Krisiun
              #245
              Aber iob startet immer noch nicht :(
              • KrisiunK Krisiun
                library: loaded
                Installed gcc-c++
                Thomas BraunT
                Thomas BraunT
                #246
                @krisiun
                Das ist nicht vollständig.
                • KrisiunK
                  KrisiunK
                  Krisiun
                  #247
                  Enabling autostart...
                  Autostart enabled!
                      Your installation was fixed successfully
                      Run iobroker start to start ioBroker again!
                  • KrisiunK
                    KrisiunK
                    Krisiun
                    #248
                    juppiii !!! jetzt läuft der wieder BRAVO THOMAS
                    Aber was machen wir mit dem Speicherplatz da war doch viel zu wenig da?
                    • KrisiunK Krisiun
                      Thomas BraunT
                      Thomas BraunT
                      #249
                      @krisiun
                      Das dürfte ich in den nächsten Tagen von alleine klären. Wenn da jetzt die log-Files nicht mehr so rasant größer werden wird das über die Log Rotation irgendwann von alleine entsorgt.
                      KrisiunK 1 Antwort Letzte Antwort
                        @krisiun
                        KrisiunK
                        KrisiunK
                        Krisiun
                        #250
                        Schau mal noch kurz hier bitte
                         7,2 GiB [          ] /opt
                            3,1 GiB [          ] /usr
                            1,2 GiB [          ] /home
                           48,2 MiB [          ] /boot
                            8,5 MiB [          ] /run
                            7,3 MiB [          ] /root
                            5,9 MiB [          ] /etc
                           36,0 KiB [          ] /tmp
                        e  16,0 KiB [          ] /lost+found
                        e   4,0 KiB [          ] /srv
                        e   4,0 KiB [          ] /mnt
                        e   4,0 KiB [          ] /media
                            0,0   B [          ] /sys
                        .   0,0   B [          ] /proc
                            0,0   B [          ] /dev
                        @   0,0   B [          ]  sbin
                        @   0,0   B [          ]  lib
                        @   0,0   B [          ]  bin
                        • KrisiunK Krisiun
                           7,2 GiB [          ] /opt
                              3,1 GiB [          ] /usr
                              1,2 GiB [          ] /home
                             48,2 MiB [          ] /boot
                              8,5 MiB [          ] /run
                              7,3 MiB [          ] /root
                              5,9 MiB [          ] /etc
                             36,0 KiB [          ] /tmp
                          e   4,0 KiB [          ] /srv
                          e   4,0 KiB [          ] /mnt
                              0,0   B [          ] /sys
                          .   0,0   B [          ] /proc
                              0,0   B [          ] /dev
                          @   0,0   B [          ]  sbin
                          @   0,0   B [          ]  lib
                          @   0,0   B [          ]  bin
                          Thomas BraunT
                          Thomas BraunT
                          #251
                          @krisiun
                          Auch das ist mal wieder nicht vollständig.
                            @krisiun
                            KrisiunK
                            KrisiunK
                            Krisiun
                            #252
                            ja habe ich auch gerade gemerkt
                            • KrisiunK
                              KrisiunK
                              Krisiun
                              #253
                                  7,2 GiB [          ] /opt
                                  3,1 GiB [          ] /usr
                                  1,2 GiB [          ] /home
                                 48,2 MiB [          ] /boot
                                  8,5 MiB [          ] /run
                                  7,3 MiB [          ] /root
                                  5,9 MiB [          ] /etc
                                 36,0 KiB [          ] /tmp
                              e   4,0 KiB [          ] /srv
                              e   4,0 KiB [          ] /mnt
                                  0,0   B [          ] /sys
                              .   0,0   B [          ] /proc
                                  0,0   B [          ] /dev
                              @   0,0   B [          ]  sbin
                              @   0,0   B [          ]  lib
                              @   0,0   B [          ]  bin
                              • KrisiunK
                                KrisiunK
                                Krisiun
                                #254
                                Das lässt sich einfach nicht anderes kopieren
                                • KrisiunK Krisiun
                                      7,2 GiB [          ] /opt
                                      3,1 GiB [          ] /usr
                                      1,2 GiB [          ] /home
                                     48,2 MiB [          ] /boot
                                      8,5 MiB [          ] /run
                                      7,3 MiB [          ] /root
                                      5,9 MiB [          ] /etc
                                     36,0 KiB [          ] /tmp
                                  e   4,0 KiB [          ] /srv
                                  e   4,0 KiB [          ] /mnt
                                      0,0   B [          ] /sys
                                  .   0,0   B [          ] /proc
                                      0,0   B [          ] /dev
                                  @   0,0   B [          ]  sbin
                                  @   0,0   B [          ]  lib
                                  @   0,0   B [          ]  bin
                                  Thomas BraunT
                                  Thomas BraunT
                                  #255
                                  @krisiun
                                  Auch das ist nicht vollständig.
                                  Kopier doch einfach ab dem LogIn Prompt alles bis einschließlich des nächsten leeren LogIn Prompts.
                                  • KrisiunK
                                    KrisiunK
                                    Krisiun
                                    #256
                                        0,0   B [          ]    400 /dev
                                        5,9 MiB [          ]  1.697 /etc
                                        1,2 GiB [          ] 35.930 /home
                                    e   4,0 KiB [          ]        /mnt
                                        7,2 GiB [          ] > 100k /opt
                                    .   0,0   B [          ] > 100k /proc
                                        7,3 MiB [          ]    987 /root
                                        8,5 MiB [          ]    559 /run
                                    e   4,0 KiB [          ]        /srv
                                        0,0   B [          ] 31.303 /sys
                                       36,0 KiB [          ]      8 /tmp
                                        3,1 GiB [          ] > 100k /usr
                                       94,4 GiB [##########]  7.007 /var
                                    @   0,0   B [          ]         bin
                                    @   0,0   B [          ]         lib
                                    @   0,0   B [          ]         sbin
                                    • KrisiunK
                                      KrisiunK
                                      Krisiun
                                      #257
                                      OK dann lassen wir das. Ich will Dich nicht weiter nerven. Wenigstens nicht mehr heute :)
                                      Villen Dank
                                      • KrisiunK Krisiun
                                        Villen Dank
                                        Thomas BraunT
                                        Thomas BraunT
                                        #258
                                        @krisiun
                                        df -h
                                        • KrisiunK
                                          KrisiunK
                                          Krisiun
                                          #259
                                          df -h
                                          pi@raspberrypi4-iob:~ $ df -h
                                          Dateisystem                           Größe Benutzt Verf. Verw% Eingehängt auf
                                          /dev/root                              117G    106G  6,4G   95% /
                                          devtmpfs                               1,8G       0  1,8G    0% /dev
                                          tmpfs                                  1,9G       0  1,9G    0% /dev/shm
                                          tmpfs                                  1,9G    8,5M  1,9G    1% /run
                                          tmpfs                                  5,0M    4,0K  5,0M    1% /run/lock
                                          tmpfs                                  1,9G       0  1,9G    0% /sys/fs/cgroup
                                          /dev/mmcblk0p1                         253M     49M  204M   20% /boot
                                          tmpfs                                  384M       0  384M    0% /run/user/1000
                                          //192.168.178.2/homes/ioBroker-Backup  5,5T    3,1T  2,4T   57% /opt/iobroker/backups
                                          84.1k
