  4. Nodejs v18.12.1
    apollon77A
Nodejs v18.12.1
382 Beiträge 10 Kommentatoren 85.4k Aufrufe 8 Beobachtet
  • KrisiunK
    KrisiunK
    Krisiun
    #238
    @thomas-braun sagte in Nodejs v18.12.1:
    ls -la /usr/lib/systemd/system/iobroker.service
    pi@raspberrypi4-iob:~ $ ls -la /usr/lib/systemd/system/iobroker.service
    -rw-r--r-- 1 root root 1 Nov 24 08:03 /usr/lib/systemd/system/iobroker.service
    • KrisiunK Krisiun
      Thomas BraunT
      Thomas BraunT
      #239
      @krisiun
      ls -la /etc/systemd/system/multi-user.target.wants/iobroker.service
      • KrisiunK
        KrisiunK
        Krisiun
        #240
        pi@raspberrypi4-iob:~ $ ls -la /etc/systemd/system/multi-user.target.wants/iobroker.service
        lrwxrwxrwx 1 root root 36 Okt 29  2021 /etc/systemd/system/multi-user.target.wants/iobroker.service -> /lib/systemd/system/iobroker.service
        • KrisiunK Krisiun
          Thomas BraunT
          Thomas BraunT
          #241
          @krisiun
          iob stop
          iob fix
          iob start
          • KrisiunK
            KrisiunK
            Krisiun
            #242
            iob fix
            pi@raspberrypi4-iob:~ $ iob stop
            pi@raspberrypi4-iob:~ $ iob fix
            da bei fix passiert nichts weiter
            • KrisiunK Krisiun
              iob fix
              Thomas BraunT
              Thomas BraunT
              #243
              @krisiun
              curl -fsL https://iobroker.net/fix.sh | bash -
              • KrisiunK
                KrisiunK
                Krisiun
                #244
                pi@raspberrypi4-iob:~ $ curl -fsL https://iobroker.net/fix.sh | bash -
                library: loaded
                Library version=2022-06-15
                    Welcome to the ioBroker installation fixer!
                    Script version: 2022-06-03
                    You might need to enter your password a couple of times.
                    Installing prerequisites (1/3)
                Holen:1 http://archive.raspberrypi.org/debian buster InRelease [32,6 kB]
                Holen:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
                OK:3 https://deb.nodesource.com/node_16.x buster InRelease
                Holen:4 http://archive.raspberrypi.org/debian buster/main armhf Packages [392 kB]
                Es wurden 439 kB in 1 s geholt (425 kB/s).
                Installed gcc-c++
                    Checking ioBroker user and directory permissions (2/3)
                    Checking autostart (3/3)
                • KrisiunK
                  KrisiunK
                  Krisiun
                  #245
                  Aber iob startet immer noch nicht :(
                  • KrisiunK Krisiun
                    library: loaded
                    Installed gcc-c++
                    Thomas BraunT
                    Thomas BraunT
                    #246
                    @krisiun
                    Das ist nicht vollständig.
                    • KrisiunK
                      KrisiunK
                      Krisiun
                      #247
                      Enabling autostart...
                      Autostart enabled!
                          Your installation was fixed successfully
                          Run iobroker start to start ioBroker again!
                      • KrisiunK
                        KrisiunK
                        Krisiun
                        #248
                        juppiii !!! jetzt läuft der wieder BRAVO THOMAS
                        Aber was machen wir mit dem Speicherplatz da war doch viel zu wenig da?
                        • KrisiunK Krisiun
                          Thomas BraunT
                          Thomas BraunT
                          #249
                          @krisiun
                          Das dürfte ich in den nächsten Tagen von alleine klären. Wenn da jetzt die log-Files nicht mehr so rasant größer werden wird das über die Log Rotation irgendwann von alleine entsorgt.
                          KrisiunK 1 Antwort Letzte Antwort
                            @krisiun
                            KrisiunK
                            KrisiunK
                            Krisiun
                            #250
                            Schau mal noch kurz hier bitte
                             7,2 GiB [          ] /opt
                                3,1 GiB [          ] /usr
                                1,2 GiB [          ] /home
                               48,2 MiB [          ] /boot
                                8,5 MiB [          ] /run
                                7,3 MiB [          ] /root
                                5,9 MiB [          ] /etc
                               36,0 KiB [          ] /tmp
                            e  16,0 KiB [          ] /lost+found
                            e   4,0 KiB [          ] /srv
                            e   4,0 KiB [          ] /mnt
                            e   4,0 KiB [          ] /media
                                0,0   B [          ] /sys
                            .   0,0   B [          ] /proc
                                0,0   B [          ] /dev
                            @   0,0   B [          ]  sbin
                            @   0,0   B [          ]  lib
                            @   0,0   B [          ]  bin
                            • KrisiunK Krisiun
                               7,2 GiB [          ] /opt
                                  3,1 GiB [          ] /usr
                                  1,2 GiB [          ] /home
                                 48,2 MiB [          ] /boot
                                  8,5 MiB [          ] /run
                                  7,3 MiB [          ] /root
                                  5,9 MiB [          ] /etc
                                 36,0 KiB [          ] /tmp
                              e   4,0 KiB [          ] /srv
                              e   4,0 KiB [          ] /mnt
                                  0,0   B [          ] /sys
                              .   0,0   B [          ] /proc
                                  0,0   B [          ] /dev
                              @   0,0   B [          ]  sbin
                              @   0,0   B [          ]  lib
                              @   0,0   B [          ]  bin
                              Thomas BraunT
                              Thomas BraunT
                              #251
                              @krisiun
                              Auch das ist mal wieder nicht vollständig.
                                @krisiun
                                KrisiunK
                                KrisiunK
                                Krisiun
                                #252
                                ja habe ich auch gerade gemerkt
                                • KrisiunK
                                  KrisiunK
                                  Krisiun
                                  #253
                                      7,2 GiB [          ] /opt
                                      3,1 GiB [          ] /usr
                                      1,2 GiB [          ] /home
                                     48,2 MiB [          ] /boot
                                      8,5 MiB [          ] /run
                                      7,3 MiB [          ] /root
                                      5,9 MiB [          ] /etc
                                     36,0 KiB [          ] /tmp
                                  e   4,0 KiB [          ] /srv
                                  e   4,0 KiB [          ] /mnt
                                      0,0   B [          ] /sys
                                  .   0,0   B [          ] /proc
                                      0,0   B [          ] /dev
                                  @   0,0   B [          ]  sbin
                                  @   0,0   B [          ]  lib
                                  @   0,0   B [          ]  bin
                                  • KrisiunK
                                    KrisiunK
                                    Krisiun
                                    #254
                                    Das lässt sich einfach nicht anderes kopieren
                                    • KrisiunK Krisiun
                                          7,2 GiB [          ] /opt
                                          3,1 GiB [          ] /usr
                                          1,2 GiB [          ] /home
                                         48,2 MiB [          ] /boot
                                          8,5 MiB [          ] /run
                                          7,3 MiB [          ] /root
                                          5,9 MiB [          ] /etc
                                         36,0 KiB [          ] /tmp
                                      e   4,0 KiB [          ] /srv
                                      e   4,0 KiB [          ] /mnt
                                          0,0   B [          ] /sys
                                      .   0,0   B [          ] /proc
                                          0,0   B [          ] /dev
                                      @   0,0   B [          ]  sbin
                                      @   0,0   B [          ]  lib
                                      @   0,0   B [          ]  bin
                                      Thomas BraunT
                                      Thomas BraunT
                                      #255
                                      @krisiun
                                      Auch das ist nicht vollständig.
                                      Kopier doch einfach ab dem LogIn Prompt alles bis einschließlich des nächsten leeren LogIn Prompts.
                                      • KrisiunK
                                        KrisiunK
                                        Krisiun
                                        #256
                                            0,0   B [          ]    400 /dev
                                            5,9 MiB [          ]  1.697 /etc
                                            1,2 GiB [          ] 35.930 /home
                                        e   4,0 KiB [          ]        /mnt
                                            7,2 GiB [          ] > 100k /opt
                                        .   0,0   B [          ] > 100k /proc
                                            7,3 MiB [          ]    987 /root
                                            8,5 MiB [          ]    559 /run
                                        e   4,0 KiB [          ]        /srv
                                            0,0   B [          ] 31.303 /sys
                                           36,0 KiB [          ]      8 /tmp
                                            3,1 GiB [          ] > 100k /usr
                                           94,4 GiB [##########]  7.007 /var
                                        @   0,0   B [          ]         bin
                                        @   0,0   B [          ]         lib
                                        @   0,0   B [          ]         sbin
                                        • KrisiunK
                                          KrisiunK
                                          Krisiun
                                          #257
                                          OK dann lassen wir das. Ich will Dich nicht weiter nerven. Wenigstens nicht mehr heute :)
                                          Villen Dank
                                          83.9k
