  4. Nodejs v18.12.1
    apollon77A
Nodejs v18.12.1
382 Beiträge 10 Kommentatoren 85.5k Aufrufe 8 Beobachtet
  • KrisiunK Krisiun
    @thomas-braun sagte in Nodejs v18.12.1:
    ls -la /usr/lib/systemd/system/iobroker.service
    pi@raspberrypi4-iob:~ $ ls -la /usr/lib/systemd/system/iobroker.service
    -rw-r--r-- 1 root root 1 Nov 24 08:03 /usr/lib/systemd/system/iobroker.service
    Thomas BraunT
    Thomas BraunT
    #239
    @krisiun
    ls -la /etc/systemd/system/multi-user.target.wants/iobroker.service
    • KrisiunK
      KrisiunK
      Krisiun
      #240
      pi@raspberrypi4-iob:~ $ ls -la /etc/systemd/system/multi-user.target.wants/iobroker.service
      lrwxrwxrwx 1 root root 36 Okt 29  2021 /etc/systemd/system/multi-user.target.wants/iobroker.service -> /lib/systemd/system/iobroker.service
      • KrisiunK Krisiun
        Thomas BraunT
        Thomas BraunT
        #241
        @krisiun
        iob stop
        iob fix
        iob start
        • KrisiunK
          KrisiunK
          Krisiun
          #242
          iob fix
          pi@raspberrypi4-iob:~ $ iob stop
          pi@raspberrypi4-iob:~ $ iob fix
          da bei fix passiert nichts weiter
          • KrisiunK Krisiun
            iob fix
            Thomas BraunT
            Thomas BraunT
            #243
            @krisiun
            curl -fsL https://iobroker.net/fix.sh | bash -
            • KrisiunK
              KrisiunK
              Krisiun
              #244
              pi@raspberrypi4-iob:~ $ curl -fsL https://iobroker.net/fix.sh | bash -
              library: loaded
              Library version=2022-06-15
                  Welcome to the ioBroker installation fixer!
                  Script version: 2022-06-03
                  You might need to enter your password a couple of times.
                  Installing prerequisites (1/3)
              Holen:1 http://archive.raspberrypi.org/debian buster InRelease [32,6 kB]
              Holen:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
              OK:3 https://deb.nodesource.com/node_16.x buster InRelease
              Holen:4 http://archive.raspberrypi.org/debian buster/main armhf Packages [392 kB]
              Es wurden 439 kB in 1 s geholt (425 kB/s).
              Installed gcc-c++
                  Checking ioBroker user and directory permissions (2/3)
                  Checking autostart (3/3)
              • KrisiunK
                KrisiunK
                Krisiun
                #245
                Aber iob startet immer noch nicht :(
                • KrisiunK Krisiun
                  library: loaded
                  Installed gcc-c++
                  Thomas BraunT
                  Thomas BraunT
                  #246
                  @krisiun
                  Das ist nicht vollständig.
                  • KrisiunK
                    KrisiunK
                    Krisiun
                    #247
                    Enabling autostart...
                    Autostart enabled!
                        Your installation was fixed successfully
                        Run iobroker start to start ioBroker again!
                    • KrisiunK
                      KrisiunK
                      Krisiun
                      #248
                      juppiii !!! jetzt läuft der wieder BRAVO THOMAS
                      Aber was machen wir mit dem Speicherplatz da war doch viel zu wenig da?
                      • KrisiunK Krisiun
                        Thomas BraunT
                        Thomas BraunT
                        #249
                        @krisiun
                        Das dürfte ich in den nächsten Tagen von alleine klären. Wenn da jetzt die log-Files nicht mehr so rasant größer werden wird das über die Log Rotation irgendwann von alleine entsorgt.
                        KrisiunK 1 Antwort Letzte Antwort
                          @krisiun
                          KrisiunK
                          KrisiunK
                          Krisiun
                          #250
                          Schau mal noch kurz hier bitte
                           7,2 GiB [          ] /opt
                              3,1 GiB [          ] /usr
                              1,2 GiB [          ] /home
                             48,2 MiB [          ] /boot
                              8,5 MiB [          ] /run
                              7,3 MiB [          ] /root
                              5,9 MiB [          ] /etc
                             36,0 KiB [          ] /tmp
                          e  16,0 KiB [          ] /lost+found
                          e   4,0 KiB [          ] /srv
                          e   4,0 KiB [          ] /mnt
                          e   4,0 KiB [          ] /media
                              0,0   B [          ] /sys
                          .   0,0   B [          ] /proc
                              0,0   B [          ] /dev
                          @   0,0   B [          ]  sbin
                          @   0,0   B [          ]  lib
                          @   0,0   B [          ]  bin
                          • KrisiunK Krisiun
                             7,2 GiB [          ] /opt
                                3,1 GiB [          ] /usr
                                1,2 GiB [          ] /home
                               48,2 MiB [          ] /boot
                                8,5 MiB [          ] /run
                                7,3 MiB [          ] /root
                                5,9 MiB [          ] /etc
                               36,0 KiB [          ] /tmp
                            e   4,0 KiB [          ] /srv
                            e   4,0 KiB [          ] /mnt
                                0,0   B [          ] /sys
                            .   0,0   B [          ] /proc
                                0,0   B [          ] /dev
                            @   0,0   B [          ]  sbin
                            @   0,0   B [          ]  lib
                            @   0,0   B [          ]  bin
                            Thomas BraunT
                            Thomas BraunT
                            #251
                            @krisiun
                            Auch das ist mal wieder nicht vollständig.
                              @krisiun
                              KrisiunK
                              KrisiunK
                              Krisiun
                              #252
                              ja habe ich auch gerade gemerkt
                              • KrisiunK
                                KrisiunK
                                Krisiun
                                #253
                                    7,2 GiB [          ] /opt
                                    3,1 GiB [          ] /usr
                                    1,2 GiB [          ] /home
                                   48,2 MiB [          ] /boot
                                    8,5 MiB [          ] /run
                                    7,3 MiB [          ] /root
                                    5,9 MiB [          ] /etc
                                   36,0 KiB [          ] /tmp
                                e   4,0 KiB [          ] /srv
                                e   4,0 KiB [          ] /mnt
                                    0,0   B [          ] /sys
                                .   0,0   B [          ] /proc
                                    0,0   B [          ] /dev
                                @   0,0   B [          ]  sbin
                                @   0,0   B [          ]  lib
                                @   0,0   B [          ]  bin
                                • KrisiunK
                                  KrisiunK
                                  Krisiun
                                  #254
                                  Das lässt sich einfach nicht anderes kopieren
                                  • KrisiunK Krisiun
                                        7,2 GiB [          ] /opt
                                        3,1 GiB [          ] /usr
                                        1,2 GiB [          ] /home
                                       48,2 MiB [          ] /boot
                                        8,5 MiB [          ] /run
                                        7,3 MiB [          ] /root
                                        5,9 MiB [          ] /etc
                                       36,0 KiB [          ] /tmp
                                    e   4,0 KiB [          ] /srv
                                    e   4,0 KiB [          ] /mnt
                                        0,0   B [          ] /sys
                                    .   0,0   B [          ] /proc
                                        0,0   B [          ] /dev
                                    @   0,0   B [          ]  sbin
                                    @   0,0   B [          ]  lib
                                    @   0,0   B [          ]  bin
                                    Thomas BraunT
                                    Thomas BraunT
                                    #255
                                    @krisiun
                                    Auch das ist nicht vollständig.
                                    Kopier doch einfach ab dem LogIn Prompt alles bis einschließlich des nächsten leeren LogIn Prompts.
                                    • KrisiunK
                                      KrisiunK
                                      Krisiun
                                      #256
                                          0,0   B [          ]    400 /dev
                                          5,9 MiB [          ]  1.697 /etc
                                          1,2 GiB [          ] 35.930 /home
                                      e   4,0 KiB [          ]        /mnt
                                          7,2 GiB [          ] > 100k /opt
                                      .   0,0   B [          ] > 100k /proc
                                          7,3 MiB [          ]    987 /root
                                          8,5 MiB [          ]    559 /run
                                      e   4,0 KiB [          ]        /srv
                                          0,0   B [          ] 31.303 /sys
                                         36,0 KiB [          ]      8 /tmp
                                          3,1 GiB [          ] > 100k /usr
                                         94,4 GiB [##########]  7.007 /var
                                      @   0,0   B [          ]         bin
                                      @   0,0   B [          ]         lib
                                      @   0,0   B [          ]         sbin
                                      • KrisiunK
                                        KrisiunK
                                        Krisiun
                                        #257
                                        OK dann lassen wir das. Ich will Dich nicht weiter nerven. Wenigstens nicht mehr heute :)
                                        Villen Dank
                                        • KrisiunK Krisiun
                                          Villen Dank
                                          Thomas BraunT
                                          Thomas BraunT
                                          #258
                                          @krisiun
                                          df -h
                                          84.0k
