  4. Sonoff NSPanel
    2.6k
    4.7k
    4.0k
Sonoff NSPanel
1.5k Beiträge 78 Kommentatoren 813.5k Aufrufe 80 Beobachtet
  • T TT-Tom
    ich habe eine Frage zu den Hardware Button. Ich habe in der Konsole den String aus dem Script eingegeben. Leider ohne Erfolg. Das sind die Zeilen aus dem Log Tasmota.
    17:40:43.249 CMD: Rule2 on Button1#state do Publish %topic%/%prefix%/RESULT {"CustomRecv":"event,button1"} endon on Button2#state do Publish %topic%/%prefix%/RESULT {"CustomRecv":"event,button2"} endon
    17:40:43.267 RUL: Stored uncompressed, would compress from 177 to 81 (-54%)
    17:40:43.279 MQT: SmartHome/NSPanel_1/stat/RESULT = {"Rule2":{"State":"ON","Once":"OFF","StopOnError":"OFF","Length":177,"Free":334,"Rules":"on Button1#state do Publish %topic%/%prefix%/RESULT {\"CustomRecv\":\"event,button1\"} endon on Button2#state do Publish %topic%/%prefix%/RESULT {\"CustomRecv\":\"event,button2\"} endon"}}
    17:40:56.653 CMD: Rule2 1
    17:40:56.668 MQT: SmartHome/NSPanel_1/stat/RESULT = {"Rule2":{"State":"ON","Once":"OFF","StopOnError":"OFF","Length":177,"Free":334,"Rules":"on Button1#state do Publish %topic%/%prefix%/RESULT {\"CustomRecv\":\"event,button1\"} endon on Button2#state do Publish %topic%/%prefix%/RESULT {\"CustomRecv\":\"event,button2\"} endon"}}
    17:41:00.880 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
    17:41:10.848 RUL: BUTTON1#STATE performs "Publish NSPanel_1/%prefix%/RESULT {"CustomRecv":"event,button1"}"
    17:41:10.862 MQT: NSPanel_1/%prefix%/RESULT = {"CustomRecv":"event,button1"}
    Was mich wundert ist das der %prefix% nicht auf gelöst wird.
    Gruß Tom
    ArmilarA Offline
    ArmilarA Offline
    Armilar
    Most Active Forum Testing
    #881
    @tt-tom sagte in Sonoff NSPanel:
    Gruß Tom
    Mich nicht ;-) . Versuche mal:
    Rule2 on Button1#state do Publish SmartHome/NSPanel_1/tele/RESULT {"CustomRecv":"event,button1"} endon on Button2#state do Publish SmartHome/NSPanel_1/tele/RESULT {"CustomRecv":"event,button2"} endon
    Danach
    Rule2 1
    NSPanel_1 = /%topic%/
    tele = /%prefix%/
    Du kannst das aber auch direkt in "Klarschrift" verwenden. Man wechselt ja nicht täglich die Adapter- oder die MQTT-Einstellungen, sondern in der Regel nur einmal.
    • WalW Wal
       TFT EU STABLE Version   : FlashNextion http://nspanel.pky.eu/lovelace-ui/github/nspanel-v3.1.0.tft
      Gibt es auch eine US nspanel.tft ?
      joBr99
      schrieb am zuletzt editiert von joBr99
      #882
      @wal said in Sonoff NSPanel:
      EU Version: FlashNextion http://nspanel.pky.eu/lovelace-ui/github/nspanel-v3.1.0.tft
      US Landscape Version: FlashNextion http://nspanel.pky.eu/lovelace-ui/github/nspanel-us-l-v3.1.0.tft
      US Portrait Version: FlashNextion http://nspanel.pky.eu/lovelace-ui/github/nspanel-us-p-v3.1.0.tft
      Sollte funktionieren, nur das AutoUpdate ist vermutlich mit dem ioBroker Skript kaputt, da die US Version da nicht implementiert ist.
      • J joBr99
        ArmilarA Offline
        ArmilarA Offline
        Armilar
        #883
        @jobr99 sagte in Sonoff NSPanel:
        Die Zeile lässt sich ja schnell tauschen. Denke auch, dass das funktioniert. 👍
        WalW 1 Antwort Letzte Antwort
        • ArmilarA Armilar
          WalW Offline
          WalW Offline
          Wal
          schrieb am zuletzt editiert von Wal
          #884
          @armilar ,
          hat gefunzt danke.
          edit: sorry, jobr99 natürlich.
          Habe es zwar schon mal gelesen, aber doppelt gemoppelt hält länger.
          Mit "SetOption73 on" kann man die Relais von den Hardwareschaltern entkoppeln und mit zwei neuen Objekten im MQTT Adapter
          cmnd/POWER1
          cmnd/POWER2
          kann man die Relais über MQTT schalten.
          Edit:
          Die Buttons kann man mit einer Regel als Objekt einbinden.
          Rule2
          on Button1#state do Backlog Publish Wohnzimmer/%topic%/stat/BUTTON1 true;RuleTimer1 1 endon
          on Button2#state do Backlog Publish Wohnzimmer/%topic%/stat/BUTTON2 true;RuleTimer2 1 endon
          on Rules#Timer=1 do Publish Wohnzimmer/%topic%/stat/BUTTON1 false endon
          on Rules#Timer=2 do Publish Wohnzimmer/%topic%/stat/BUTTON2 false endon
          Rule2 1
          den Objektpfad eurem NSPanel anpassen.
          Walter
          DoorIO-Adapter
          • MichaelFM Offline
            MichaelFM Offline
            MichaelF
            schrieb am zuletzt editiert von MichaelF
            #885
            ich bin auch grade Fleißig am nachbauen. Hab jetzt soweit alle Fehlermeldungen vom Script weg.
            Datenpunkte sind da und Funktionieren auch allerdings bekomme ich das Display nicht dazu bewegt mir was anderes außer "Waiting for content" anzuzeigen.
            Der Datenpunkt CustomSend habe ich via Mqtt Explorer angelegt und er Funktioniert meine ich auch :
            Gegangen bin ich nach der Anleitung hier im Thread, bis eigentlich der Screensaver angezeigt werden soll das tut er aber nicht.
            Vielleicht einer ein Tipp wo ich anfangen kann zu suchen ?
            Grüße
            • MichaelFM MichaelF
              Grüße
              ArmilarA Offline
              ArmilarA Offline
              Armilar
              #886
              @michaelf
              wie ist deine Config-Einstellung?
                  panelRecvTopic: "mqtt.3.tele.tasmota_C82F70.RESULT",       //anpassen
                  panelSendTopic: "mqtt.3.cmnd.tasmota_C82F70.CustomSend",   //anpassen
              so?
              MichaelFM 1 Antwort Letzte Antwort
              • ArmilarA Armilar
                @michaelf
                so?
                MichaelFM Offline
                MichaelFM Offline
                MichaelF
                #887
                @armilar said in Sonoff NSPanel:
                @michaelf
                so?
                Ja sollte passen
                  @michaelf
                  so?
                  Ja sollte passen
                  ArmilarA Offline
                  ArmilarA Offline
                  Armilar
                  #888
                  @michaelf sagte in Sonoff NSPanel:
                  @michaelf
                  so?
                  Ja sollte passen
                  Sieht eigentlich gut aus. Wenn nichts verdreht wurde, dann sollte das Script jetzt zumindest mal jede Minute in den CustomSend - Datenpunkt deiner mqtt.3 - Adapterinstanz schreiben. Und das ist auch schon passiert gem. deines ersten Screenshots
                  Mach mal das Panel stromlos und Stecker wieder rein. Irgendwie hängt es zwischen mqtt.3. und Panel
                  • ArmilarA Armilar
                    @michaelf
                    so?
                    Ja sollte passen
                    MichaelFM Offline
                    MichaelFM Offline
                    MichaelF
                    #889
                    @michaelf
                    so?
                    Ja sollte passen
                    Also alle Minute kommt :
                    time~19:38
                    Sonst :
                    entityUpd~Büro 2~0|1~delete~~~~~~delete~~~~~~delete~~~~~~delete~~~~~~delete~~~~~~delete~~~~~
                    Muss ich beim Mqtt ein Benutzername und Passwort vergeben?, weil das hab ich nicht.
                      @michaelf
                      so?
                      Ja sollte passen
                      time~19:38
                      Sonst :
                      ArmilarA Offline
                      ArmilarA Offline
                      Armilar
                      #890
                      @michaelf
                      so?
                      Ja sollte passen
                      time~19:38
                      Sonst :
                      Eben. Das ist auch okay so. Genau das macht das Skript. Die Zeit wird in den CustomSend geschrieben und mqtt transportiert es zum Panel. entityUpd ist auch okay so, solange die Aliase fehlen müsste das Panel zumindest die Überschrift der Seite bringen. Ich sag es mal so - am TS-Skript liegt es nicht...
                      Eher zwischen deinem mqtt.3. Adapter und dem Panel
                      Zeigt das Panel etwas an, wenn du die Nachrichten mit dem MQTT-Explorrer sendest? Obwohl es ist ja faktisch das gleiche wie die Daten vom Skript
                      • ArmilarA Armilar
                        @michaelf
                        so?
                        Ja sollte passen
                        time~19:38
                        Sonst :
                        MichaelFM Offline
                        MichaelFM Offline
                        MichaelF
                        #891
                        @michaelf
                        so?
                        Ja sollte passen
                        time~19:38
                        Sonst :
                        Eventuell hier was zu sehen ?
                          @michaelf
                          so?
                          Ja sollte passen
                          time~19:38
                          Sonst :
                          TT-Tom
                          #892
                          @michaelf
                          Du hast in tasmota Benutzer und Passwort vergeben, diese müssen auch in mqtt3 eingetragen werden
                          Gruß Tom
                          Public Transport
                          NSPanel Adapter Wiki
                          • MichaelFM Offline
                            MichaelFM Offline
                            MichaelF
                            #893
                            nein das wird da immer angezeigt.
                            Habe aber grade mal ein Benutzer und Passwort vergeben, verbindet aber trotzdem nur Waiting for content......
                              TT-Tom
                              #894
                              @michaelf
                              Mqtt3 hat aber jetzt eine Verbindung. Starte das Script nochmal neu
                              Gruß Tom
                              Public Transport
                              • MichaelFM Offline
                                MichaelFM Offline
                                MichaelF
                                #895
                                Hab ich, ändert sich leider nichts.
                                  TT-Tom
                                  #896
                                  @michaelf
                                  Fehler gefunden deine Einstellung vom mqtt Server da steht MQTT.0 da muss mqtt.3 rein
                                  Maske zum bekanntgegeben eigener State
                                  Gruß Tom
                                  Public Transport
                                  • T TT-Tom
                                    @michaelf
                                    MichaelFM Offline
                                    MichaelFM Offline
                                    MichaelF
                                    #897
                                    @tt-tom said in Sonoff NSPanel:
                                    mqtt.3
                                    Super !!!!!, das war es DANKE :-)
                                      mqtt.3
                                      TT-Tom
                                      #898
                                      @michaelf
                                      Viel Spaß noch mit dem Panel.
                                      Gruß Tom
                                      Public Transport
                                      • T TT-Tom
                                        @michaelf
                                        MichaelFM Offline
                                        MichaelFM Offline
                                        MichaelF
                                        #899
                                        @michaelf
                                        Danke, aber schon wieder die nächste Frage..............
                                        Versuche grade die Aliase anzulegen aber das + ist aus gegraut muss ich noch irgendwo was aktivieren?
                                        Hab es rausgefunden :-)
                                        Grüsse
                                        • MichaelFM Offline
                                          MichaelFM Offline
                                          MichaelF
                                          #900
                                          Ich glaube ich brauche doch nochmal ein wenig support.......
                                          Hatte einige Aliase angelegt zwei Seiten und eigentlich alles gut. Dann bekam ich diese Fehlermeldung :
                                          Dachte ok, Script beim hin und her kopieren zerschossen, den Scrip neu angelegt aber der gleiche Fehler Ständiger Reboot der ganzen Instanz.
                                          Seit zwei Minuten läuft es wieder, kann mir jemand sagen was das war oder ist ?
                                          Nochmal ein Besseres Bild:
                                          Das der
                                          IconsSelector
                                          Fehlt kann ja irgendwie nicht sein.
                                          WalW T 2 Antworten Letzte Antwort
