  4. Sonoff NSPanel
    6.8k
Sonoff NSPanel
1.5k Beiträge 78 Kommentatoren 881.3k Aufrufe 80 Beobachtet
    TT-Tom
    #880
    ich habe eine Frage zu den Hardware Button. Ich habe in der Konsole den String aus dem Script eingegeben. Leider ohne Erfolg. Das sind die Zeilen aus dem Log Tasmota.
    17:40:43.249 CMD: Rule2 on Button1#state do Publish %topic%/%prefix%/RESULT {"CustomRecv":"event,button1"} endon on Button2#state do Publish %topic%/%prefix%/RESULT {"CustomRecv":"event,button2"} endon
    17:40:43.267 RUL: Stored uncompressed, would compress from 177 to 81 (-54%)
    17:40:43.279 MQT: SmartHome/NSPanel_1/stat/RESULT = {"Rule2":{"State":"ON","Once":"OFF","StopOnError":"OFF","Length":177,"Free":334,"Rules":"on Button1#state do Publish %topic%/%prefix%/RESULT {\"CustomRecv\":\"event,button1\"} endon on Button2#state do Publish %topic%/%prefix%/RESULT {\"CustomRecv\":\"event,button2\"} endon"}}
    17:40:56.653 CMD: Rule2 1
    17:40:56.668 MQT: SmartHome/NSPanel_1/stat/RESULT = {"Rule2":{"State":"ON","Once":"OFF","StopOnError":"OFF","Length":177,"Free":334,"Rules":"on Button1#state do Publish %topic%/%prefix%/RESULT {\"CustomRecv\":\"event,button1\"} endon on Button2#state do Publish %topic%/%prefix%/RESULT {\"CustomRecv\":\"event,button2\"} endon"}}
    17:41:00.880 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
    17:41:10.848 RUL: BUTTON1#STATE performs "Publish NSPanel_1/%prefix%/RESULT {"CustomRecv":"event,button1"}"
    17:41:10.862 MQT: NSPanel_1/%prefix%/RESULT = {"CustomRecv":"event,button1"}
    Was mich wundert ist das der %prefix% nicht auf gelöst wird.
    Gruß Tom
    Gruß Tom
    Public Transport
    NSPanel Adapter Wiki
    • T TT-Tom
      Gruß Tom
      ArmilarA Offline
      ArmilarA Offline
      Armilar
      Most Active Forum Testing
      #881
      @tt-tom sagte in Sonoff NSPanel:
      Gruß Tom
      Mich nicht ;-) . Versuche mal:
      Rule2 on Button1#state do Publish SmartHome/NSPanel_1/tele/RESULT {"CustomRecv":"event,button1"} endon on Button2#state do Publish SmartHome/NSPanel_1/tele/RESULT {"CustomRecv":"event,button2"} endon
      Danach
      Rule2 1
      NSPanel_1 = /%topic%/
      tele = /%prefix%/
      Du kannst das aber auch direkt in "Klarschrift" verwenden. Man wechselt ja nicht täglich die Adapter- oder die MQTT-Einstellungen, sondern in der Regel nur einmal.
      • WalW Wal
         TFT EU STABLE Version   : FlashNextion http://nspanel.pky.eu/lovelace-ui/github/nspanel-v3.1.0.tft
        Gibt es auch eine US nspanel.tft ?
        joBr99
        schrieb am zuletzt editiert von joBr99
        #882
        @wal said in Sonoff NSPanel:
        EU Version: FlashNextion http://nspanel.pky.eu/lovelace-ui/github/nspanel-v3.1.0.tft
        US Landscape Version: FlashNextion http://nspanel.pky.eu/lovelace-ui/github/nspanel-us-l-v3.1.0.tft
        US Portrait Version: FlashNextion http://nspanel.pky.eu/lovelace-ui/github/nspanel-us-p-v3.1.0.tft
        Sollte funktionieren, nur das AutoUpdate ist vermutlich mit dem ioBroker Skript kaputt, da die US Version da nicht implementiert ist.
        • J joBr99
          ArmilarA Offline
          ArmilarA Offline
          Armilar
          #883
          @jobr99 sagte in Sonoff NSPanel:
          Die Zeile lässt sich ja schnell tauschen. Denke auch, dass das funktioniert. 👍
          WalW 1 Antwort Letzte Antwort
          • ArmilarA Armilar
            WalW Offline
            WalW Offline
            Wal
            schrieb am zuletzt editiert von Wal
            #884
            @armilar ,
            hat gefunzt danke.
            edit: sorry, jobr99 natürlich.
            Habe es zwar schon mal gelesen, aber doppelt gemoppelt hält länger.
            Mit "SetOption73 on" kann man die Relais von den Hardwareschaltern entkoppeln und mit zwei neuen Objekten im MQTT Adapter
            cmnd/POWER1
            cmnd/POWER2
            kann man die Relais über MQTT schalten.
            Edit:
            Die Buttons kann man mit einer Regel als Objekt einbinden.
            Rule2
            on Button1#state do Backlog Publish Wohnzimmer/%topic%/stat/BUTTON1 true;RuleTimer1 1 endon
            on Button2#state do Backlog Publish Wohnzimmer/%topic%/stat/BUTTON2 true;RuleTimer2 1 endon
            on Rules#Timer=1 do Publish Wohnzimmer/%topic%/stat/BUTTON1 false endon
            on Rules#Timer=2 do Publish Wohnzimmer/%topic%/stat/BUTTON2 false endon
            Rule2 1
            den Objektpfad eurem NSPanel anpassen.
            Walter
            DoorIO-Adapter
            • MichaelFM Online
              MichaelFM Online
              MichaelF
              schrieb am zuletzt editiert von MichaelF
              #885
              ich bin auch grade Fleißig am nachbauen. Hab jetzt soweit alle Fehlermeldungen vom Script weg.
              Datenpunkte sind da und Funktionieren auch allerdings bekomme ich das Display nicht dazu bewegt mir was anderes außer "Waiting for content" anzuzeigen.
              Der Datenpunkt CustomSend habe ich via Mqtt Explorer angelegt und er Funktioniert meine ich auch :
              Gegangen bin ich nach der Anleitung hier im Thread, bis eigentlich der Screensaver angezeigt werden soll das tut er aber nicht.
              Vielleicht einer ein Tipp wo ich anfangen kann zu suchen ?
              • MichaelFM MichaelF
                ArmilarA Offline
                ArmilarA Offline
                Armilar
                #886
                @michaelf
                wie ist deine Config-Einstellung?
                    panelRecvTopic: "mqtt.3.tele.tasmota_C82F70.RESULT",       //anpassen
                    panelSendTopic: "mqtt.3.cmnd.tasmota_C82F70.CustomSend",   //anpassen
                so?
                MichaelFM 1 Antwort Letzte Antwort
                • ArmilarA Armilar
                  @michaelf
                  so?
                  MichaelFM Online
                  MichaelFM Online
                  MichaelF
                  #887
                  @armilar said in Sonoff NSPanel:
                  @michaelf
                  so?
                  Ja sollte passen
                    @michaelf
                    so?
                    Ja sollte passen
                    ArmilarA Offline
                    ArmilarA Offline
                    Armilar
                    #888
                    @michaelf sagte in Sonoff NSPanel:
                    @michaelf
                    so?
                    Ja sollte passen
                    Sieht eigentlich gut aus. Wenn nichts verdreht wurde, dann sollte das Script jetzt zumindest mal jede Minute in den CustomSend - Datenpunkt deiner mqtt.3 - Adapterinstanz schreiben. Und das ist auch schon passiert gem. deines ersten Screenshots
                    Mach mal das Panel stromlos und Stecker wieder rein. Irgendwie hängt es zwischen mqtt.3. und Panel
                    • ArmilarA Armilar
                      @michaelf
                      so?
                      Ja sollte passen
                      MichaelFM Online
                      MichaelFM Online
                      MichaelF
                      #889
                      @michaelf
                      so?
                      Ja sollte passen
                      Also alle Minute kommt :
                      time~19:38
                      Sonst :
                      entityUpd~Büro 2~0|1~delete~~~~~~delete~~~~~~delete~~~~~~delete~~~~~~delete~~~~~~delete~~~~~
                      Muss ich beim Mqtt ein Benutzername und Passwort vergeben?, weil das hab ich nicht.
                        @michaelf
                        so?
                        Ja sollte passen
                        time~19:38
                        Sonst :
                        ArmilarA Offline
                        ArmilarA Offline
                        Armilar
                        #890
                        @michaelf
                        so?
                        Ja sollte passen
                        time~19:38
                        Sonst :
                        Eben. Das ist auch okay so. Genau das macht das Skript. Die Zeit wird in den CustomSend geschrieben und mqtt transportiert es zum Panel. entityUpd ist auch okay so, solange die Aliase fehlen müsste das Panel zumindest die Überschrift der Seite bringen. Ich sag es mal so - am TS-Skript liegt es nicht...
                        Eher zwischen deinem mqtt.3. Adapter und dem Panel
                        Zeigt das Panel etwas an, wenn du die Nachrichten mit dem MQTT-Explorrer sendest? Obwohl es ist ja faktisch das gleiche wie die Daten vom Skript
                        • ArmilarA Armilar
                          @michaelf
                          so?
                          Ja sollte passen
                          time~19:38
                          Sonst :
                          MichaelFM Online
                          MichaelFM Online
                          MichaelF
                          #891
                          @michaelf
                          so?
                          Ja sollte passen
                          time~19:38
                          Sonst :
                          Eventuell hier was zu sehen ?
                            @michaelf
                            so?
                            Ja sollte passen
                            time~19:38
                            Sonst :
                            TT-Tom
                            #892
                            @michaelf
                            Du hast in tasmota Benutzer und Passwort vergeben, diese müssen auch in mqtt3 eingetragen werden
                            Gruß Tom
                            Public Transport
                            • MichaelFM Online
                              MichaelFM Online
                              MichaelF
                              #893
                              nein das wird da immer angezeigt.
                              Habe aber grade mal ein Benutzer und Passwort vergeben, verbindet aber trotzdem nur Waiting for content......
                                TT-Tom
                                #894
                                @michaelf
                                Mqtt3 hat aber jetzt eine Verbindung. Starte das Script nochmal neu
                                Gruß Tom
                                Public Transport
                                • MichaelFM Online
                                  MichaelFM Online
                                  MichaelF
                                  #895
                                  Hab ich, ändert sich leider nichts.
                                    TT-Tom
                                    #896
                                    @michaelf
                                    Fehler gefunden deine Einstellung vom mqtt Server da steht MQTT.0 da muss mqtt.3 rein
                                    Maske zum bekanntgegeben eigener State
                                    Gruß Tom
                                    Public Transport
                                    • T TT-Tom
                                      @michaelf
                                      MichaelFM Online
                                      MichaelFM Online
                                      MichaelF
                                      #897
                                      @tt-tom said in Sonoff NSPanel:
                                      mqtt.3
                                      Super !!!!!, das war es DANKE :-)
                                        mqtt.3
                                        TT-Tom
                                        #898
                                        @michaelf
                                        Viel Spaß noch mit dem Panel.
                                        Gruß Tom
                                        Public Transport
                                        • T TT-Tom
                                          @michaelf
                                          MichaelFM Online
                                          MichaelFM Online
                                          MichaelF
                                          #899
                                          @michaelf
                                          Danke, aber schon wieder die nächste Frage..............
                                          Versuche grade die Aliase anzulegen aber das + ist aus gegraut muss ich noch irgendwo was aktivieren?
                                          Hab es rausgefunden :-)
                                          Grüsse
