  4. [ESPHome] Beta release
    6.3k
591 Beiträge 48 Kommentatoren 230.8k Aufrufe 39 Beobachtet
  • O OPatrick
    which geht jetzt aber immer noch Fehler...
    pi@mospi:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
    /usr/bin/node
    /usr/bin/npm
    pi@mospi:~ $ iobroker add esphome
    NPM version: 6.14.15
    npm install iobroker.esphome@0.2.4 --loglevel error --prefix "/opt/iobroker" (System call)
    /usr/local/lib/python3.8/site-packages/_distutils_hack/__init__.py:24: UserWarning: Distutils was imported before Setuptools, but importing Setuptools also replaces the `distutils` module in `sys.modules`. This may lead to undesirable behaviors or errors. To avoid these issues, avoid using distutils directly, ensure that setuptools is installed in the traditional way (e.g. not an editable install), and/or make sure that setuptools is always imported before distutils.
      warnings.warn(
    /usr/local/lib/python3.8/site-packages/_distutils_hack/__init__.py:36: UserWarning: Setuptools is replacing distutils.
      warnings.warn("Setuptools is replacing distutils.")
    Traceback (most recent call last):
      File "/opt/iobroker/node_modules/nopy/src/get-pip.py", line 20061, in <module>
        main()
      File "/opt/iobroker/node_modules/nopy/src/get-pip.py", line 194, in main
        bootstrap(tmpdir=tmpdir)
      File "/opt/iobroker/node_modules/nopy/src/get-pip.py", line 119, in bootstrap
        import setuptools  # noqa
      File "/usr/local/lib/python3.8/site-packages/setuptools/__init__.py", line 8, in <module>
        import _distutils_hack.override  # noqa: F401
      File "/usr/local/lib/python3.8/site-packages/_distutils_hack/override.py", line 1, in <module>
        __import__('_distutils_hack').do_override()
      File "/usr/local/lib/python3.8/site-packages/_distutils_hack/__init__.py", line 73, in do_override
        ensure_local_distutils()
      File "/usr/local/lib/python3.8/site-packages/_distutils_hack/__init__.py", line 61, in ensure_local_distutils
        assert '_distutils' in core.__file__, core.__file__
    AssertionError: /usr/local/lib/python3.8/distutils/core.py
    Error: Exited with code 1.
        at ChildProcess.<anonymous> (/opt/iobroker/node_modules/nopy/src/api.js:277:20)
        at ChildProcess.emit (events.js:400:28)
        at maybeClose (internal/child_process.js:1058:16)
        at Process.ChildProcess._handle.onexit (internal/child_process.js:293:5)
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! iobroker.esphome@0.2.4 install: `npip install`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the iobroker.esphome@0.2.4 install script.
    npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR!     /home/iobroker/.npm/_logs/2022-01-02T20_55_04_809Z-debug.log
    host.mospi Cannot install iobroker.esphome@0.2.4: 1
    pi@mospi:~ $
    da scheint python immer noch verbogen zu sein.. :-) ok wie bekomme ich das weg?
    #461
    @opatrick
    Und wie hast du python3.8 nun ins System gekloppt? Muss ja von 'irgendwoher' manuell kommen, in den Repos liegt die Version ja nicht vor.
    Thomas BraunT O 2 Antworten Letzte Antwort
      @opatrick
      #462
      @OPatrick
      Deine schiefe Installation ist übrigens was für einen eigenen, neuen Thread wert, das hat mit dem Beta-Testen des Adapters ja nix zu tun.
        @opatrick
        O Offline
        O Offline
        OPatrick
        #463
        ja das kam leider etwas unglücklich. Weil beim aller ersten Versuch der Adapter Installation kamen zig Fehler Meldungen weil das Modul cryptography von python gefehlt usw..
        Da habe ich dann wahrscheinlich python manuell installiert :-(
        jetzt habe ich es zwar manuel gelöscht.. Aber die ganzen Pfade stimmen nimmer :-(
        ein sudo und er which befehl brachten nix..
        pi@mospi:/usr/local/lib $ iobroker add esphome                                                            NPM version: 6.14.15
        Error: Python site module exited with code 1.
        Could not find platform independent libraries <prefix>
        Could not find platform dependent libraries <exec_prefix>
        Consider setting $PYTHONHOME to <prefix>[:<exec_prefix>]
        Python path configuration:
          PYTHONHOME = (not set)
          PYTHONPATH = '/opt/iobroker/node_modules/iobroker.esphome'
          program name = 'python3.8'
        Thomas BraunT A 3 Antworten Letzte Antwort
        • O OPatrick
          #464
          @opatrick sagte in [ESPHome] Beta release:
          Konkret? Du verfrickelst dein System immer mehr...
          O 1 Antwort Letzte Antwort
          • O OPatrick
            #465
            Noch konkreter? Ich sehe nicht was du da jetzt wie warum wo gemacht hast.
              O Offline
              O Offline
              OPatrick
              #466
              naja ich habe über apt-get reinstall python3 etc.. versucht die Verzeichniss links richtig zu setzten..
              pi@mospi:/usr/local/lib $ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
              /usr/bin/nodejs
              /usr/bin/node
              /usr/bin/npm
              v14.18.2
              v14.18.2
              6.14.15
              OK:1 http://phoscon.de/apt/deconz bullseye-beta InRelease
              OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
              OK:3 http://archive.raspberrypi.org/debian bullseye InRelease
              OK:4 https://deb.nodesource.com/node_14.x bullseye InRelease
              Alle Pakete sind aktuell.
              OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
              OK:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
              nodejs:
                Installiert:           14.18.2-deb-1nodesource1
                Installationskandidat: 14.18.2-deb-1nodesource1
                Versionstabelle:
               *** 14.18.2-deb-1nodesource1 500
                      500 https://deb.nodesource.com/node_14.x bullseye/main armhf Packages
                      100 /var/lib/dpkg/status
                   12.22.5~dfsg-2~11u1 500
                      500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
              das sieht gut aus :-) aber beim
              das nicht :-(
                isolated = 0
                environment = 1
                user site = 1
                import site = 1
                sys._base_executable = '/usr/local/bin/python3.8'
                sys.base_prefix = '/usr/local'
                sys.base_exec_prefix = '/usr/local'
                sys.executable = '/usr/local/bin/python3.8'
                sys.prefix = '/usr/local'
                sys.exec_prefix = '/usr/local'
                sys.path = [
                  '/opt/iobroker/node_modules/iobroker.esphome',
                  '/usr/local/lib/python38.zip',
                  '/usr/local/lib/python3.8',
                  '/usr/local/lib/lib-dynload',
              Fatal Python error: init_fs_encoding: failed to get the Python codec of the filesystem encoding
              Python runtime state: core initialized
              ModuleNotFoundError: No module named 'encodings'
              Current thread 0x76f87040 (most recent call first):
              <no Python frame>
                  at ChildProcess.<anonymous> (/opt/iobroker/node_modules/nopy/src/api.js:106:16)
              npm ERR! errno 1
              npm ERR!
              npm ERR!     /home/iobroker/.npm/_logs/2022-01-02T21_11_14_284Z-debug.log
              • O OPatrick
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                v14.18.2
                v14.18.2
                6.14.15
                nodejs:
                  Versionstabelle:
                das nicht :-(
                  isolated = 0
                  environment = 1
                  user site = 1
                  import site = 1
                  sys.path = [
                <no Python frame>
                npm ERR! errno 1
                npm ERR!
                #467
                Konkret?
                Das bitte in einem eigenen Thread. Hat wie gesagt mit dem Adapter nix zu tun.
                • E e-s
                  @draexler
                  Werden denn im esphome Adapter Daten vom esp über api angezeigt, ich würde tippen das das passwort im esphome Adapter nicht drin steht.
                  draexlerD Offline
                  draexlerD Offline
                  draexler
                  #468
                  @e-s said in [ESPHome] Beta release:
                  Habe des ESP mal aus dem Adapter gelöscht und wieder mit hinzugefügt und zwar mit dem API Passwort was in der YAML hinterlegt. Die Meldung das das PW falsch ist, kommt aber immer noch...
                  Noch irgendeine Idee?
                  E 1 Antwort Letzte Antwort
                  • draexlerD draexler
                    e-s
                    #469
                    @draexler
                    Hast du mal ein extrem einfaches pw getestet und auf nicht gewünschte Leerzeichen geachtet?
                    • DutchmanD Dutchman
                      Aktuelle Test Version 0.1.0
                      Veröffentlichungsdatum 28-02-2021
                      Github Link https://github.com/Drozmotix/ioBroker.esphome
                      Dokumentation https://Drozmotix.github.io/languages/de/ESPHome/
                      Der Adapter stellt über seine native API eine Verbindung zum von ESPHome verwalteten Gerät her und stellt sicher, dass alle Daten bei jeder Änderung synchronisiert werden
                      Unterstützte Typen
                      Der adapter unterstützt momentan folgende sensor typen
                      Type Funktionalität mehr Informationen
                      BinarySensor Sie können verschiedene Arten von Binärsensoren verwenden. Diese werden automatisch in ioBroker angezeigt und verfügen über mehrere Konfigurationsoptionen. Binary Sensor Component
                      Climate ESPHome unterstützt Klimageräte. Klimageräte können verschiedene Arten von Hardware darstellen, aber der entscheidende Faktor ist, dass Klimageräte eine einstellbare Zieltemperatur haben und in verschiedene Modi wie HEAT, COOL, AUTO oder OFF geschaltet werden können. Climate Component
                      Sensor ESPHome unterstützt viele verschiedene Sensoren. Jeder von ihnen ist eine Plattform der Sensordomäne und jeder Sensor verfügt über mehrere Basiskonfigurationsoptionen. Sensor Component
                      TextSensor Textsensoren sind normalen Sensoren sehr ähnlich. Wenn die „normalen“ Sensoren jedoch nur Sensoren darstellen, die Zahlen ausgeben, kann diese Komponente einen beliebigen Text darstellen. Text Sensor Component
                      Switch Mit der GPIO-Switch-Plattform können Sie einen beliebigen Pin auf Ihrem Knoten als Switch verwenden. Sie können beispielsweise ein Relais an einen GPIO-Pin anschließen und über diese Plattform verwenden. GPIO Switch
                      Viel spass !
                      PS: Habe diesmal sogar Doku geschrieben 🤓
                      liv-in-skyL Offline
                      liv-in-skyL Offline
                      liv-in-sky
                      #470
                      @dutchman
                      sorry aber konnte mein thema nicht finden - wird aber sicher irgendwo stehen
                      habe 3 esphome devices. wollte heute nach einem jahr mal wieder etwas in einem device ändern (ich habe den adapter nicht installiert), und bekam auf meinem win10 bei "esphome run ...yaml" immer einen fehler
                      also wollte ich mal über den adapter probieren. der wird installiert und ich kann von hand die devices einbinden und bekomme datenpunkte
                      was ich nicht verstehe: wie bekomme ich nun die geräte in iobroker über das dashboard - das ist im moment leer - ich konnte auf dem pc das esphome wieder zum laufen bringen. mit "esphome dashboard config/" kann ich auf dem pc das dashboard aktivieren und erst dann sehe ich in iobroker auch ein dashboard - ist aber leer und zeigt keine devices an
                      was muss ich jetzt machen ? ich möchte das dashboard nicht auf dem pc starten, sondern immer haben - muss das auf dem iobroker server installiert werden ?
                      und .. wie bekomme ich dann die schon geflashten devices in dieses dashboard
                      sorry für die fragen - aber irgendwie check ich es nicht
                      FredFF 1 Antwort Letzte Antwort
                      • liv-in-skyL liv-in-sky
                        @dutchman
                        FredFF Online
                        FredFF Online
                        FredF
                        Most Active Forum Testing
                        #471
                        @liv-in-sky sagte in [ESPHome] Beta release:
                        Das liegt imho daran, dass das Dashboard im ESPHome Adapter älter ist, als das mit du deine ESP programmiert hast
                        • FredFF FredF
                          liv-in-skyL Offline
                          liv-in-skyL Offline
                          liv-in-sky
                          #472
                          @fredf
                          und das bedeutet ??
                          sehe ich das richtig, dass ich auf dem iobroker server nichts außer phyton instaliert haben muss - und das sollte rein theoretisch funktionieren ?
                          FredFF SBorgS 2 Antworten Letzte Antwort
                            @fredf
                            und das bedeutet ??
                            FredFF Online
                            FredFF Online
                            FredF
                            #473
                            @liv-in-sky Ganz verstehe ich das Problem nicht... und das was ich vorher schrieb ist blödsinn...
                            Darüber öffnest du das Dashboard?
                            Bei den Adapter Einstellungen ist die IP des ioBroker eingetragen?
                            • FredFF FredF
                              liv-in-skyL Offline
                              liv-in-skyL Offline
                              liv-in-sky
                              #474
                              @fredf
                              ok - die iobroker adresse ist jetzt drin und ann geht es auch auf - ein problem weniger
                              und warum ist das leer ?
                                @fredf
                                und das bedeutet ??
                                SBorgS Offline
                                SBorgS Offline
                                SBorg
                                #475
                                @liv-in-sky Du hast wahrscheinlich nicht deine yaml-Dateien in den ioB kopiert? Dann weiß er auch im Dashboard IMO nichts von deinen Geräten.
                                /opt/iobroker/iobroker-data/esphome.0/xyz.yaml
                                LG SBorg ( SBorg auf GitHub)
                                liv-in-skyL 4 Antworten Letzte Antwort
                                • SBorgS SBorg
                                  liv-in-skyL Offline
                                  liv-in-skyL Offline
                                  liv-in-sky
                                  #476
                                  @sborg das mach ich gleich mal :)
                                  • SBorgS SBorg
                                    liv-in-skyL Offline
                                    liv-in-skyL Offline
                                    liv-in-sky
                                    #477
                                    @sborg
                                    @FredF
                                    danke euch beiden
                                      @sborg
                                      @FredF
                                      danke euch beiden
                                      FredFF Online
                                      FredFF Online
                                      FredF
                                      #478
                                      @liv-in-sky Du musstest also die yaml Dateien einfügen wie @SBorg geschrieben hat?
                                      • FredFF FredF
                                        liv-in-skyL Offline
                                        liv-in-skyL Offline
                                        liv-in-sky
                                        #479
                                        @fredf
                                        ja - das war's
                                          @fredf
                                          ja - das war's
                                          FredFF Online
                                          FredFF Online
                                          FredF
                                          #480
                                          @liv-in-sky wieder was gelernt 👍
