  4. [ESPHome] Beta release
591 Beiträge 48 Kommentatoren 238.9k Aufrufe 39 Beobachtet
  • O OPatrick
    @thomas-braun ich habe gerade auch das update auf node 14 gemacht:
    Leider klappt das nicht..
    pi@mospi:~ $  iobroker add esphome
    NPM version: 6.14.15
    npm install iobroker.esphome@0.2.4 --loglevel error --prefix "/opt/iobroker" (System call)
    /usr/local/lib/python3.8/site-packages/_distutils_hack/__init__.py:24: UserWarning: Distutils was imported before Setuptools, but importing Setuptools also replaces the `distutils` module in `sys.modules`. This may lead to undesirable behaviors or errors. To avoid these issues, avoid using distutils directly, ensure that setuptools is installed in the traditional way (e.g. not an editable install), and/or make sure that setuptools is always imported before distutils.
      warnings.warn(
    /usr/local/lib/python3.8/site-packages/_distutils_hack/__init__.py:36: UserWarning: Setuptools is replacing distutils.
      warnings.warn("Setuptools is replacing distutils.")
    Traceback (most recent call last):
      File "/opt/iobroker/node_modules/nopy/src/get-pip.py", line 20061, in <module>
        main()
      File "/opt/iobroker/node_modules/nopy/src/get-pip.py", line 194, in main
        bootstrap(tmpdir=tmpdir)
      File "/opt/iobroker/node_modules/nopy/src/get-pip.py", line 119, in bootstrap
        import setuptools  # noqa
      File "/usr/local/lib/python3.8/site-packages/setuptools/__init__.py", line 8, in <module>
        import _distutils_hack.override  # noqa: F401
      File "/usr/local/lib/python3.8/site-packages/_distutils_hack/override.py", line 1, in <module>
        __import__('_distutils_hack').do_override()
      File "/usr/local/lib/python3.8/site-packages/_distutils_hack/__init__.py", line 73, in do_override
        ensure_local_distutils()
      File "/usr/local/lib/python3.8/site-packages/_distutils_hack/__init__.py", line 61, in ensure_local_distutils
        assert '_distutils' in core.__file__, core.__file__
    AssertionError: /usr/local/lib/python3.8/distutils/core.py
    Error: Exited with code 1.
        at ChildProcess.<anonymous> (/opt/iobroker/node_modules/nopy/src/api.js:277:20)
        at ChildProcess.emit (events.js:400:28)
        at maybeClose (internal/child_process.js:1058:16)
        at Process.ChildProcess._handle.onexit (internal/child_process.js:293:5)
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! iobroker.esphome@0.2.4 install: `npip install`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the iobroker.esphome@0.2.4 install script.
    npm ERR!     /home/iobroker/.npm/_logs/2022-01-02T20_29_14_127Z-debug.log
    host.mospi Cannot install iobroker.esphome@0.2.4: 1
    pi@mospi:~ $ node -v
    v14.18.2
    pi@mospi:~ $ npm -v
    6.14.15
    pi@mospi:~ $
    was mich stuzig mach ist folgendes:
      warnings.warn(
    das taucht bei dir nicht auf...
    #457
    @opatrick
    apt policy python3
    und
    which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
    liefern jeweils?
    • O Offline
      O Offline
      OPatrick
      #458
      pi@mospi:~ $ python3:
        Installiert:           3.9.2-3
        Installationskandidat: 3.9.2-3
        Versionstabelle:
       *** 3.9.2-3 500
              500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Package                          s
              100 /var/lib/dpkg/statuspython3
      beim which Befehl passiert rein gar nichts keine anzeige kein Fehler..
      • O OPatrick
          Versionstabelle:
         *** 3.9.2-3 500
        #459
        @opatrick
        Dann hast du dir python3 irgendwoher irgendwie ins System gekloppt.
        Dein erschwindeltes python3.8 wieder deinstallieren und die vorgesehene Version 3.9.2-3 installieren. Dann funktioniert auch die Installation des Adapters wie bei mir.
        Und bitte auch die Ausgabe auf die zweite Befehlskette noch liefern. Nicht das du dir das ähnlich schief ins System gedübelt hast.
        O 1 Antwort Letzte Antwort
          @opatrick
          O Offline
          O Offline
          OPatrick
          schrieb am zuletzt editiert von OPatrick
          #460
          which geht jetzt aber immer noch Fehler...
          pi@mospi:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
          /usr/bin/node
          /usr/bin/npm
            warnings.warn(
              main()
          npm ERR! errno 1
          npm ERR!
          npm ERR!     /home/iobroker/.npm/_logs/2022-01-02T20_55_04_809Z-debug.log
          pi@mospi:~ $
          da scheint python immer noch verbogen zu sein.. :-) ok wie bekomme ich das weg?
          • O OPatrick
            /usr/bin/node
            /usr/bin/npm
              warnings.warn(
                main()
            npm ERR! errno 1
            npm ERR!
            pi@mospi:~ $
            #461
            @opatrick
            Und wie hast du python3.8 nun ins System gekloppt? Muss ja von 'irgendwoher' manuell kommen, in den Repos liegt die Version ja nicht vor.
            Thomas BraunT O 2 Antworten Letzte Antwort
              @opatrick
              #462
              @OPatrick
              Deine schiefe Installation ist übrigens was für einen eigenen, neuen Thread wert, das hat mit dem Beta-Testen des Adapters ja nix zu tun.
                @opatrick
                O Offline
                O Offline
                OPatrick
                #463
                ja das kam leider etwas unglücklich. Weil beim aller ersten Versuch der Adapter Installation kamen zig Fehler Meldungen weil das Modul cryptography von python gefehlt usw..
                Da habe ich dann wahrscheinlich python manuell installiert :-(
                jetzt habe ich es zwar manuel gelöscht.. Aber die ganzen Pfade stimmen nimmer :-(
                ein sudo und er which befehl brachten nix..
                pi@mospi:/usr/local/lib $ iobroker add esphome                                                            NPM version: 6.14.15
                Error: Python site module exited with code 1.
                Could not find platform independent libraries <prefix>
                Could not find platform dependent libraries <exec_prefix>
                Consider setting $PYTHONHOME to <prefix>[:<exec_prefix>]
                Python path configuration:
                  PYTHONHOME = (not set)
                  PYTHONPATH = '/opt/iobroker/node_modules/iobroker.esphome'
                  program name = 'python3.8'
                Thomas BraunT A 3 Antworten Letzte Antwort
                • O OPatrick
                  #464
                  @opatrick sagte in [ESPHome] Beta release:
                  Konkret? Du verfrickelst dein System immer mehr...
                  • O OPatrick
                    #465
                    Noch konkreter? Ich sehe nicht was du da jetzt wie warum wo gemacht hast.
                      O Offline
                      O Offline
                      OPatrick
                      #466
                      naja ich habe über apt-get reinstall python3 etc.. versucht die Verzeichniss links richtig zu setzten..
                      pi@mospi:/usr/local/lib $ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
                      /usr/bin/nodejs
                      /usr/bin/node
                      /usr/bin/npm
                      v14.18.2
                      v14.18.2
                      6.14.15
                      OK:1 http://phoscon.de/apt/deconz bullseye-beta InRelease
                      OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                      OK:3 http://archive.raspberrypi.org/debian bullseye InRelease
                      OK:4 https://deb.nodesource.com/node_14.x bullseye InRelease
                      Alle Pakete sind aktuell.
                      OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
                      OK:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                      nodejs:
                        Installiert:           14.18.2-deb-1nodesource1
                        Installationskandidat: 14.18.2-deb-1nodesource1
                        Versionstabelle:
                       *** 14.18.2-deb-1nodesource1 500
                              500 https://deb.nodesource.com/node_14.x bullseye/main armhf Packages
                           12.22.5~dfsg-2~11u1 500
                      das sieht gut aus :-) aber beim
                      das nicht :-(
                        isolated = 0
                        environment = 1
                        user site = 1
                        import site = 1
                        sys._base_executable = '/usr/local/bin/python3.8'
                        sys.base_prefix = '/usr/local'
                        sys.base_exec_prefix = '/usr/local'
                        sys.executable = '/usr/local/bin/python3.8'
                        sys.prefix = '/usr/local'
                        sys.exec_prefix = '/usr/local'
                        sys.path = [
                          '/opt/iobroker/node_modules/iobroker.esphome',
                          '/usr/local/lib/python38.zip',
                          '/usr/local/lib/python3.8',
                          '/usr/local/lib/lib-dynload',
                      Fatal Python error: init_fs_encoding: failed to get the Python codec of the filesystem encoding
                      Python runtime state: core initialized
                      ModuleNotFoundError: No module named 'encodings'
                      Current thread 0x76f87040 (most recent call first):
                      <no Python frame>
                          at ChildProcess.<anonymous> (/opt/iobroker/node_modules/nopy/src/api.js:106:16)
                      npm ERR! errno 1
                      npm ERR!
                      npm ERR!     /home/iobroker/.npm/_logs/2022-01-02T21_11_14_284Z-debug.log
                      • O OPatrick
                        /usr/bin/nodejs
                        /usr/bin/node
                        /usr/bin/npm
                        v14.18.2
                        v14.18.2
                        6.14.15
                        nodejs:
                          Versionstabelle:
                        das nicht :-(
                          isolated = 0
                          environment = 1
                          user site = 1
                          import site = 1
                          sys.path = [
                        <no Python frame>
                        npm ERR! errno 1
                        npm ERR!
                        #467
                        Konkret?
                        Das bitte in einem eigenen Thread. Hat wie gesagt mit dem Adapter nix zu tun.
                        • E e-s
                          @draexler
                          Werden denn im esphome Adapter Daten vom esp über api angezeigt, ich würde tippen das das passwort im esphome Adapter nicht drin steht.
                          draexlerD Offline
                          draexlerD Offline
                          draexler
                          #468
                          @e-s said in [ESPHome] Beta release:
                          Habe des ESP mal aus dem Adapter gelöscht und wieder mit hinzugefügt und zwar mit dem API Passwort was in der YAML hinterlegt. Die Meldung das das PW falsch ist, kommt aber immer noch...
                          Noch irgendeine Idee?
                          E 1 Antwort Letzte Antwort
                          • draexlerD draexler
                            e-s
                            #469
                            @draexler
                            Hast du mal ein extrem einfaches pw getestet und auf nicht gewünschte Leerzeichen geachtet?
                            • DutchmanD Dutchman
                              Aktuelle Test Version 0.1.0
                              Veröffentlichungsdatum 28-02-2021
                              Github Link https://github.com/Drozmotix/ioBroker.esphome
                              Dokumentation https://Drozmotix.github.io/languages/de/ESPHome/
                              Der Adapter stellt über seine native API eine Verbindung zum von ESPHome verwalteten Gerät her und stellt sicher, dass alle Daten bei jeder Änderung synchronisiert werden
                              Unterstützte Typen
                              Der adapter unterstützt momentan folgende sensor typen
                              Type Funktionalität mehr Informationen
                              BinarySensor Sie können verschiedene Arten von Binärsensoren verwenden. Diese werden automatisch in ioBroker angezeigt und verfügen über mehrere Konfigurationsoptionen. Binary Sensor Component
                              Climate ESPHome unterstützt Klimageräte. Klimageräte können verschiedene Arten von Hardware darstellen, aber der entscheidende Faktor ist, dass Klimageräte eine einstellbare Zieltemperatur haben und in verschiedene Modi wie HEAT, COOL, AUTO oder OFF geschaltet werden können. Climate Component
                              Sensor ESPHome unterstützt viele verschiedene Sensoren. Jeder von ihnen ist eine Plattform der Sensordomäne und jeder Sensor verfügt über mehrere Basiskonfigurationsoptionen. Sensor Component
                              TextSensor Textsensoren sind normalen Sensoren sehr ähnlich. Wenn die „normalen“ Sensoren jedoch nur Sensoren darstellen, die Zahlen ausgeben, kann diese Komponente einen beliebigen Text darstellen. Text Sensor Component
                              Switch Mit der GPIO-Switch-Plattform können Sie einen beliebigen Pin auf Ihrem Knoten als Switch verwenden. Sie können beispielsweise ein Relais an einen GPIO-Pin anschließen und über diese Plattform verwenden. GPIO Switch
                              Viel spass !
                              PS: Habe diesmal sogar Doku geschrieben 🤓
                              liv-in-skyL Offline
                              liv-in-skyL Offline
                              #470
                              @dutchman
                              sorry aber konnte mein thema nicht finden - wird aber sicher irgendwo stehen
                              habe 3 esphome devices. wollte heute nach einem jahr mal wieder etwas in einem device ändern (ich habe den adapter nicht installiert), und bekam auf meinem win10 bei "esphome run ...yaml" immer einen fehler
                              also wollte ich mal über den adapter probieren. der wird installiert und ich kann von hand die devices einbinden und bekomme datenpunkte
                              was ich nicht verstehe: wie bekomme ich nun die geräte in iobroker über das dashboard - das ist im moment leer - ich konnte auf dem pc das esphome wieder zum laufen bringen. mit "esphome dashboard config/" kann ich auf dem pc das dashboard aktivieren und erst dann sehe ich in iobroker auch ein dashboard - ist aber leer und zeigt keine devices an
                              was muss ich jetzt machen ? ich möchte das dashboard nicht auf dem pc starten, sondern immer haben - muss das auf dem iobroker server installiert werden ?
                              und .. wie bekomme ich dann die schon geflashten devices in dieses dashboard
                              sorry für die fragen - aber irgendwie check ich es nicht
                              • liv-in-skyL liv-in-sky
                                @dutchman
                                FredFF Offline
                                FredFF Offline
                                FredF
                                Most Active Forum Testing
                                #471
                                @liv-in-sky sagte in [ESPHome] Beta release:
                                Das liegt imho daran, dass das Dashboard im ESPHome Adapter älter ist, als das mit du deine ESP programmiert hast
                                • FredFF FredF
                                  liv-in-skyL Offline
                                  liv-in-skyL Offline
                                  #472
                                  @fredf
                                  und das bedeutet ??
                                  sehe ich das richtig, dass ich auf dem iobroker server nichts außer phyton instaliert haben muss - und das sollte rein theoretisch funktionieren ?
                                  FredFF SBorgS 2 Antworten Letzte Antwort
                                    @fredf
                                    und das bedeutet ??
                                    FredFF Offline
                                    FredFF Offline
                                    FredF
                                    #473
                                    @liv-in-sky Ganz verstehe ich das Problem nicht... und das was ich vorher schrieb ist blödsinn...
                                    Darüber öffnest du das Dashboard?
                                    Bei den Adapter Einstellungen ist die IP des ioBroker eingetragen?
                                    • FredFF FredF
                                      liv-in-skyL Offline
                                      liv-in-skyL Offline
                                      #474
                                      @fredf
                                      ok - die iobroker adresse ist jetzt drin und ann geht es auch auf - ein problem weniger
                                      und warum ist das leer ?
                                        @fredf
                                        und das bedeutet ??
                                        SBorgS Offline
                                        SBorgS Offline
                                        SBorg
                                        #475
                                        @liv-in-sky Du hast wahrscheinlich nicht deine yaml-Dateien in den ioB kopiert? Dann weiß er auch im Dashboard IMO nichts von deinen Geräten.
                                        /opt/iobroker/iobroker-data/esphome.0/xyz.yaml
                                        LG SBorg ( SBorg auf GitHub)
                                        liv-in-skyL 4 Antworten Letzte Antwort
                                        • SBorgS SBorg
                                          liv-in-skyL Offline
                                          liv-in-skyL Offline
                                          #476
                                          @sborg das mach ich gleich mal :)
