  4. [ESPHome] Beta release
591 Beiträge 48 Kommentatoren 238.9k Aufrufe 39 Beobachtet
  • O OPatrick
    naja ich habe über apt-get reinstall python3 etc.. versucht die Verzeichniss links richtig zu setzten..
    pi@mospi:/usr/local/lib $ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    v14.18.2
    v14.18.2
    6.14.15
    OK:1 http://phoscon.de/apt/deconz bullseye-beta InRelease
    OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    OK:3 http://archive.raspberrypi.org/debian bullseye InRelease
    OK:4 https://deb.nodesource.com/node_14.x bullseye InRelease
    Alle Pakete sind aktuell.
    OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
    OK:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    nodejs:
      Installiert:           14.18.2-deb-1nodesource1
      Installationskandidat: 14.18.2-deb-1nodesource1
      Versionstabelle:
     *** 14.18.2-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_14.x bullseye/main armhf Packages
         12.22.5~dfsg-2~11u1 500
    das sieht gut aus :-) aber beim
    das nicht :-(
    pi@mospi:/usr/local/lib $ iobroker add esphome
    NPM version: 6.14.15
    npm install iobroker.esphome@0.2.4 --loglevel error --prefix "/opt/iobroker" (System call)
    Error: Python site module exited with code 1.
    Could not find platform independent libraries <prefix>
    Could not find platform dependent libraries <exec_prefix>
    Consider setting $PYTHONHOME to <prefix>[:<exec_prefix>]
    Python path configuration:
      PYTHONHOME = (not set)
      PYTHONPATH = '/opt/iobroker/node_modules/iobroker.esphome'
      program name = 'python3.8'
      isolated = 0
      environment = 1
      user site = 1
      import site = 1
      sys._base_executable = '/usr/local/bin/python3.8'
      sys.base_prefix = '/usr/local'
      sys.base_exec_prefix = '/usr/local'
      sys.executable = '/usr/local/bin/python3.8'
      sys.prefix = '/usr/local'
      sys.exec_prefix = '/usr/local'
      sys.path = [
        '/opt/iobroker/node_modules/iobroker.esphome',
        '/usr/local/lib/python38.zip',
        '/usr/local/lib/python3.8',
        '/usr/local/lib/lib-dynload',
    Fatal Python error: init_fs_encoding: failed to get the Python codec of the filesystem encoding
    Python runtime state: core initialized
    ModuleNotFoundError: No module named 'encodings'
    Current thread 0x76f87040 (most recent call first):
    <no Python frame>
        at ChildProcess.<anonymous> (/opt/iobroker/node_modules/nopy/src/api.js:106:16)
        at ChildProcess.emit (events.js:400:28)
        at maybeClose (internal/child_process.js:1058:16)
        at Process.ChildProcess._handle.onexit (internal/child_process.js:293:5)
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! iobroker.esphome@0.2.4 install: `npip install`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the iobroker.esphome@0.2.4 install script.
    npm ERR!     /home/iobroker/.npm/_logs/2022-01-02T21_11_14_284Z-debug.log
    host.mospi Cannot install iobroker.esphome@0.2.4: 1
    #467
    @opatrick sagte in [ESPHome] Beta release:
    Konkret?
    Das bitte in einem eigenen Thread. Hat wie gesagt mit dem Adapter nix zu tun.
    • E e-s
      @draexler
      Werden denn im esphome Adapter Daten vom esp über api angezeigt, ich würde tippen das das passwort im esphome Adapter nicht drin steht.
      draexlerD Offline
      draexlerD Offline
      draexler
      #468
      @e-s said in [ESPHome] Beta release:
      Habe des ESP mal aus dem Adapter gelöscht und wieder mit hinzugefügt und zwar mit dem API Passwort was in der YAML hinterlegt. Die Meldung das das PW falsch ist, kommt aber immer noch...
      Noch irgendeine Idee?
      E 1 Antwort Letzte Antwort
      • draexlerD draexler
        e-s
        #469
        @draexler
        Hast du mal ein extrem einfaches pw getestet und auf nicht gewünschte Leerzeichen geachtet?
        • DutchmanD Dutchman
          Aktuelle Test Version 0.1.0
          Veröffentlichungsdatum 28-02-2021
          Github Link https://github.com/Drozmotix/ioBroker.esphome
          Dokumentation https://Drozmotix.github.io/languages/de/ESPHome/
          Der Adapter stellt über seine native API eine Verbindung zum von ESPHome verwalteten Gerät her und stellt sicher, dass alle Daten bei jeder Änderung synchronisiert werden
          Unterstützte Typen
          Der adapter unterstützt momentan folgende sensor typen
          Type Funktionalität mehr Informationen
          BinarySensor Sie können verschiedene Arten von Binärsensoren verwenden. Diese werden automatisch in ioBroker angezeigt und verfügen über mehrere Konfigurationsoptionen. Binary Sensor Component
          Climate ESPHome unterstützt Klimageräte. Klimageräte können verschiedene Arten von Hardware darstellen, aber der entscheidende Faktor ist, dass Klimageräte eine einstellbare Zieltemperatur haben und in verschiedene Modi wie HEAT, COOL, AUTO oder OFF geschaltet werden können. Climate Component
          Sensor ESPHome unterstützt viele verschiedene Sensoren. Jeder von ihnen ist eine Plattform der Sensordomäne und jeder Sensor verfügt über mehrere Basiskonfigurationsoptionen. Sensor Component
          TextSensor Textsensoren sind normalen Sensoren sehr ähnlich. Wenn die „normalen“ Sensoren jedoch nur Sensoren darstellen, die Zahlen ausgeben, kann diese Komponente einen beliebigen Text darstellen. Text Sensor Component
          Switch Mit der GPIO-Switch-Plattform können Sie einen beliebigen Pin auf Ihrem Knoten als Switch verwenden. Sie können beispielsweise ein Relais an einen GPIO-Pin anschließen und über diese Plattform verwenden. GPIO Switch
          Viel spass !
          PS: Habe diesmal sogar Doku geschrieben 🤓
          liv-in-skyL Offline
          liv-in-skyL Offline
          #470
          @dutchman
          sorry aber konnte mein thema nicht finden - wird aber sicher irgendwo stehen
          habe 3 esphome devices. wollte heute nach einem jahr mal wieder etwas in einem device ändern (ich habe den adapter nicht installiert), und bekam auf meinem win10 bei "esphome run ...yaml" immer einen fehler
          also wollte ich mal über den adapter probieren. der wird installiert und ich kann von hand die devices einbinden und bekomme datenpunkte
          was ich nicht verstehe: wie bekomme ich nun die geräte in iobroker über das dashboard - das ist im moment leer - ich konnte auf dem pc das esphome wieder zum laufen bringen. mit "esphome dashboard config/" kann ich auf dem pc das dashboard aktivieren und erst dann sehe ich in iobroker auch ein dashboard - ist aber leer und zeigt keine devices an
          was muss ich jetzt machen ? ich möchte das dashboard nicht auf dem pc starten, sondern immer haben - muss das auf dem iobroker server installiert werden ?
          und .. wie bekomme ich dann die schon geflashten devices in dieses dashboard
          sorry für die fragen - aber irgendwie check ich es nicht
          • liv-in-skyL liv-in-sky
            @dutchman
            FredFF Online
            FredFF Online
            FredF
            Most Active Forum Testing
            #471
            @liv-in-sky sagte in [ESPHome] Beta release:
            Das liegt imho daran, dass das Dashboard im ESPHome Adapter älter ist, als das mit du deine ESP programmiert hast
            • FredFF FredF
              liv-in-skyL Offline
              liv-in-skyL Offline
              #472
              @fredf
              und das bedeutet ??
              sehe ich das richtig, dass ich auf dem iobroker server nichts außer phyton instaliert haben muss - und das sollte rein theoretisch funktionieren ?
              FredFF SBorgS 2 Antworten Letzte Antwort
                @fredf
                und das bedeutet ??
                FredFF Online
                FredFF Online
                FredF
                #473
                @liv-in-sky Ganz verstehe ich das Problem nicht... und das was ich vorher schrieb ist blödsinn...
                Darüber öffnest du das Dashboard?
                Bei den Adapter Einstellungen ist die IP des ioBroker eingetragen?
                • FredFF FredF
                  liv-in-skyL Offline
                  liv-in-skyL Offline
                  #474
                  @fredf
                  ok - die iobroker adresse ist jetzt drin und ann geht es auch auf - ein problem weniger
                  und warum ist das leer ?
                    @fredf
                    und das bedeutet ??
                    SBorgS Offline
                    SBorgS Offline
                    SBorg
                    #475
                    @liv-in-sky Du hast wahrscheinlich nicht deine yaml-Dateien in den ioB kopiert? Dann weiß er auch im Dashboard IMO nichts von deinen Geräten.
                    /opt/iobroker/iobroker-data/esphome.0/xyz.yaml
                    LG SBorg ( SBorg auf GitHub)
                    liv-in-skyL 4 Antworten Letzte Antwort
                    • SBorgS SBorg
                      liv-in-skyL Offline
                      liv-in-skyL Offline
                      #476
                      @sborg das mach ich gleich mal :)
                      • SBorgS SBorg
                        liv-in-skyL Offline
                        liv-in-skyL Offline
                        #477
                        @sborg
                        @FredF
                        danke euch beiden
                          @sborg
                          @FredF
                          danke euch beiden
                          FredFF Online
                          FredFF Online
                          FredF
                          #478
                          @liv-in-sky Du musstest also die yaml Dateien einfügen wie @SBorg geschrieben hat?
                          • FredFF FredF
                            liv-in-skyL Offline
                            liv-in-skyL Offline
                            #479
                            @fredf
                            ja - das war's
                              @fredf
                              ja - das war's
                              FredFF Online
                              FredFF Online
                              FredF
                              #480
                              @liv-in-sky wieder was gelernt 👍
                              • SBorgS Offline
                                SBorgS Offline
                                SBorg
                                #481
                                Die werden ja normalerweise vom Adapter erzeugt, nur hat @liv-in-sky sie ja extern erzeugt, da fehlen sie dem Adapter halt ;)
                                • SBorgS SBorg
                                  liv-in-skyL Offline
                                  liv-in-skyL Offline
                                  #482
                                  @sborg
                                  ist es eigentlich pflicht, ein api kennwort zu haben ?
                                    @sborg
                                    SBorgS Offline
                                    SBorgS Offline
                                    SBorg
                                    #483
                                    @liv-in-sky Ich weiß nicht ob der Adapter ohne funktioniert. Seitens ESPHome nein:
                                    password (Optional, string): The password to protect the API Server with. Defaults to no password.
                                    • SBorgS SBorg
                                      liv-in-skyL Offline
                                      liv-in-skyL Offline
                                      #484
                                      @sborg
                                      hoffentlich letztes thema
                                      es kommt immer wieder vor, dass der name mit .local irgendwo abgefragt wird. zb. http://temperaturxiaomi.local/ wenn man visit drückt
                                      aber ich habe keine local sondern fritz.box
                                      weißt du, wo ich das richtig einstellen kann
                                        @sborg
                                        SBorgS Offline
                                        SBorgS Offline
                                        SBorg
                                        #485
                                        @liv-in-sky Versuche es mal unter wifi in der yaml:
                                        wifi:
                                          use_address: temperaturxiaomi.fritz.box
                                        • SBorgS SBorg
                                          wifi:
                                          liv-in-skyL Offline
                                          liv-in-skyL Offline
                                          #486
                                          @sborg
                                          schwere geburt - namen mismatch, dns mismatch und evtl sogar falscher esp32 type (da laden über wifi dauernd unterbrochen hat
                                          aber jetzt sind alle drin und online
                                          funktioniert auch
                                          draexlerD 1 Antwort Letzte Antwort
