  4. [neuer Adapter] smartgarden adapter for Gardena smart system
    5.2k
gardena smart systemsmartgarden
1.1k Beiträge 108 Kommentatoren 420.9k Aufrufe 101 Beobachtet
  • jpgorganizerJ jpgorganizer
    @muckel Danke für deinen Support. Ich war einfach zu doof zu sehen, dass in einer Auswahl der Sensor komplett fehlt.
    @dslraser
    Sollte nun gehen. Bitte testet und bitte auch Feedback.
    Neue Version 0.4.2 ist auf github.
    Grüße
    jpgorganizer
    0.4.2
    • (jpgorganizer)
      • error missing SENSOR data fixed
    0.4.1
    • (jpgorganizer)
      • Dependency get's resolved now
    0.4.0
    • (jpgorganizer)
      • NOTE: with this version an additional dependency is necessary at runtime. If it does not get installed together with the installation of this adapter, please install seperately with npm install https://github.com/jpgorganizer/ioBroker.utils or npm i @jpgorganizer/utils
      • NOTE: you must delete all states of the adapter instance to install this release and please check your application carefully for necessary adjustments regarding type/role changes (see below)
      • data types of (nearly) all datapoints adjusted for compliance with ioBroker guidance:
        • states now have special ioBroker type and role instead of former string/text where applicable, e.g. number/value.battery for batteryLevel_value (Issue https://github.com/jpgorganizer/ioBroker.smartgarden/issues/3)
      • datapoint activity_value_i replaced by activity_mowing_i with type/role boolean/indicator.working: true means mowing, false means not mowing
      • possibility to pre-define states integrated, see new switch PreDefine States in adapter/instance configuration (Issue https://github.com/jpgorganizer/ioBroker.smartgarden/issues/2)
      • states are readonly now; except states for commands (Issue https://github.com/jpgorganizer/ioBroker.smartgarden/issues/4)
      • input field for useTestVariable in adapter/instance configuration switched to a checkbox (former: text); please check your settings
      • error in command stop_all_valves_i in VALVE_SET fixed
    dslraserD Offline
    dslraserD Offline
    dslraser
    #121
    @jpgorganizer
    alles da 👍
    • dslraserD dslraser
      @jpgorganizer
      alles da 👍
      muckel
      #122
      @dslraser
      @jpgorganizer
      Jetzt kann ich endlich den alten Gardena Adapter löschen.
      Bin schon neugierig was du noch in den Adapter einbringen wirst.
      Danke für dein Engagment!!! :-)
      jpgorganizerJ 1 Antwort Letzte Antwort
      • M muckel
        @dslraser
        @jpgorganizer
        jpgorganizerJ Offline
        jpgorganizer
        #123
        @muckel
        @dslraser
        Ideen viele - Zeit wird fehlen, wenn die Sonne scheint, bin ich auf dem MTB Zuhause.
        Ideen gerne einbringen und auch hier diskutieren. Auch unter https://github.com/jpgorganizer/ioBroker.smartgarden/issues sammle ich eifrig Ideen und Bugs (hoffentlich davon weniger)
        VG
        jpgorganizer
        smartgarden Adapter für GARDENA smart system
        Plattform: Raspberry Pi OS Linux 12 (bookworm), Node.js: v18.18.2, NPM: 9.8.1
          @muckel
          @dslraser
          VG
          jpgorganizer
          dslraserD Offline
          dslraserD Offline
          dslraser
          #124
          @jpgorganizer Danke Dir für den Adapter👍
          so, ich lösche jetzt auch den alten Adapter.
          Hier (iQontrol) habe ich es nun auch drinn.
          • H Offline
            Hosifox
            #125
            Hallo
            ich habe den Adapter ohne Fehler installiert und danach eingerichtet. ich bekomme im LOG den Fehler
            (6116) Error: getlocations: no data
            Muss ich noch was einstellen?
            Gruß Thorsten
            • H Hosifox
              Hallo
              Gruß Thorsten
              jpgorganizer
              #126
              @Hosifox
              Hi, prüfe nochmals Username, Passwort und API Key. Vorallem den API Key!
              Die Gardena Geräte sind eingerichtet? Welche sollte es geben?
              Grüße
              jpgorganizer
                @dslraser sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                @jpgorganizer
                Ich habe jetzt den API-Key gelöscht und neu erstellt. Damit wird der Adapter nun wieder grün.
                das muss man nicht verstehen ??? würde ich aber gerne
                Das müssen wir beobachten, ob sowas öfter vorkommt. Danke für die Rückmeldung.
                Grüße
                jpgorganizer
                jpgorganizer
                #127
                @Hosifox
                @jpgorganizer sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                @jpgorganizer
                Grüße
                jpgorganizer
                das gab es wohl schon mal ..... falls es daran liegt, dann trotzdem mal melden, dass es das war
                Grüße
                jpgorganizer
                • H Offline
                  Hosifox
                  #128
                  PW und Username sind richtig. Es gibt ja 2 Keys, ich nehme nicht den secrete Key sondern den Application key, denke das ist soweit richtig. Was heisst Geräte eingerichtet?? Der Mäher ist über die Gardena APP voll funktionsfähig. Muss ich noch woanders was einrichten?
                  https://api.authentication.husqvarnagroup.dev und https://api.smart.gardena.dev muss ich ja nichts ändern oder?
                  StrathColeS 1 Antwort Letzte Antwort
                  • H Hosifox
                    StrathColeS Offline
                    StrathColeS Offline
                    StrathCole
                    #129
                    @Hosifox Hast du für den Api-Key die API freigeschaltet? Muss man nach dem Anlegen des Keys ja machen (unten drunter).
                    SolarWatt-Anlage mit 9,6 kWp – KOSTAL Plenticore Plus 10 – BYD B-Box HV 8,96 – Viessmann Vitocal 333g – Zehnder ComfoD 350 (Comfoair 350) mit RS232-Ethernet-Konverter
                    • H Offline
                      Hosifox
                      #130
                      Ja habe ich gemacht, alle 3 API stehen auf connect.
                      • H Offline
                        Hosifox
                        #131
                        Der Adapter wird auch kurz grün, dann aber sofort wieder gelb.
                        • H Offline
                          Hosifox
                          #132
                          1. get_locations ...
                            smartgarden.0 2020-04-03 18:40:40.109 info (2172) sgSetState: info.connection true
                            smartgarden.0 2020-04-03 18:40:40.108 info (2172) Connection: successful: response.statusCode /
                          dann wird er gelb
                          • J Offline
                            jack99n
                            #133
                            Ich habe mir auch den Adapter mal Installiert. Kann man mir jemand sagen unter welchem Datenpunkt ich mein Sileno Mäher steuern kann?
                            • J jack99n
                              jack99n
                              #134
                              @jack99n sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                              Okay einfach mal die Anleitung auf Git lesen. 😬
                              • H Hosifox
                                dann wird er gelb
                                jpgorganizer
                                schrieb am zuletzt editiert von jpgorganizer
                                #135
                                @Hosifox sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                                da steht doch bestimmt noch was hinten dran ....
                                Aber ist eigentlich egal, denn das ist vom connect am Service ... der scheint zu klappen, deshalb geht der Adapter erst mal auf grün,
                                dann kommt die Abfrage auf die Locations (also die Sammlung der Geräte) und die geht nicht. Da kommt nichts zurück. Warum?
                                Deshalb wird Adapter wieder gelb.
                                Ich behaupte, dass @dslraser ein ähnliches Problem hatte und dieses mit einem neuen APIkey gelöst hat.
                                VG
                                jpgorganizer
                                  VG
                                  jpgorganizer
                                  dslraserD Offline
                                  dslraserD Offline
                                  dslraser
                                  #136
                                  Das wollte ich auch gerade schreiben.
                                  • H Offline
                                    Hosifox
                                    #137
                                    Leider nicht, Problem besteht weiterhin.
                                    • H Hosifox
                                      jpgorganizer
                                      #138
                                      @Hosifox
                                      kannst du mal das Script versuchen, siehe weiter oben ....
                                      @muckel
                                      Script steht auf github
                                      https://github.com/jpgorganizer/ioBroker.smartgarden/blob/master/apitestscript/apitest.py
                                      Darin muss man gleich in den oberen Zeilen die eigenen Daten eintragen.
                                      # account specific values
                                      USERNAME = 'myUserEmail'
                                      PASSWORD = 'myUserPassword'
                                      API_KEY =  'myApplicationApiKey'
                                      Aufruf des scriptes mit
                                      python3 apitest.py
                                      Bitte posted nirgends die vollständigen Ausgaben des Scriptes, es stehen EURE token in der Ausgabe.
                                      Einfach in der Ausgabe mal schauen, ob sich dort die gesuchten Daten finden.
                                      Zur Info bei evlt. fehlenden Modulen. Ich musste bei mir folgendes installieren:
                                      pi@ioBroker:~ $ sudo apt-get install python3
                                      pi@ioBroker:~ $ sudo apt-get install python3-pip
                                      pi@ioBroker:~ $ pip3 install requests
                                      pi@ioBroker:~ $ pip3 install websocket-client
                                      pi@ioBroker:~ $  python3 --version
                                      Python 3.7.3
                                      pi@ioBroker:~ $ pip3 --version
                                      pip 18.1 from /usr/lib/python3/dist-packages/pip (python 3.7)
                                      VG
                                      jpgorganizer
                                      • dslraserD Offline
                                        dslraserD Offline
                                        dslraser
                                        #139
                                        Mein Blockly für das Irrigation Control habe ich heute auf die 6 möglichen Ventile angepasst (Pumpe habe ich keine, da kann ich nicht mit dienen)
                                        Vielleicht braucht es Jemand, dann
                                        KLICK HIER
                                        • H Offline
                                          Hosifox
                                          #140
                                          Heute morgen aufgestanden und der Adapter war grün, warum auch immer:)
