  4. [neuer Adapter] smartgarden adapter for Gardena smart system
gardena smart systemsmartgarden
1.1k Beiträge 109 Kommentatoren 518.2k Aufrufe 102 Beobachtet
  • jpgorganizerJ jpgorganizer
    @muckel
    ich habs gefunden ... stelle neue Version ein ... brauch nix mehr. Danke.
    M
    M
    muckel
    schrieb am zuletzt editiert von muckel
    #118
    @jpgorganizer
    Super Job! Danke schön! :-)
    Alle Daten werden jetzt auch vom Sensor über den Adapter angezeigt.
    • jpgorganizerJ
      jpgorganizerJ
      jpgorganizer
      #119
      @muckel Danke für deinen Support. Ich war einfach zu doof zu sehen, dass in einer Auswahl der Sensor komplett fehlt.
      @dslraser
      Sollte nun gehen. Bitte testet und bitte auch Feedback.
      Neue Version 0.4.2 ist auf github.
      jpgorganizer
      0.4.2
      • (jpgorganizer)
        • error missing SENSOR data fixed
      0.4.1
      • (jpgorganizer)
        • Dependency get's resolved now
      0.4.0
      • (jpgorganizer)
        • NOTE: with this version an additional dependency is necessary at runtime. If it does not get installed together with the installation of this adapter, please install seperately with npm install https://github.com/jpgorganizer/ioBroker.utils or npm i @jpgorganizer/utils
        • NOTE: you must delete all states of the adapter instance to install this release and please check your application carefully for necessary adjustments regarding type/role changes (see below)
        • data types of (nearly) all datapoints adjusted for compliance with ioBroker guidance:
          • states now have special ioBroker type and role instead of former string/text where applicable, e.g. number/value.battery for batteryLevel_value (Issue https://github.com/jpgorganizer/ioBroker.smartgarden/issues/3)
        • datapoint activity_value_i replaced by activity_mowing_i with type/role boolean/indicator.working: true means mowing, false means not mowing
        • possibility to pre-define states integrated, see new switch PreDefine States in adapter/instance configuration (Issue https://github.com/jpgorganizer/ioBroker.smartgarden/issues/2)
        • states are readonly now; except states for commands (Issue https://github.com/jpgorganizer/ioBroker.smartgarden/issues/4)
        • input field for useTestVariable in adapter/instance configuration switched to a checkbox (former: text); please check your settings
        • error in command stop_all_valves_i in VALVE_SET fixed
      smartgarden Adapter für GARDENA smart system
      M dslraserD 2 Antworten Letzte Antwort
        @dslraser
        jpgorganizer
        0.4.2
        • (jpgorganizer)
        0.4.1
        • (jpgorganizer)
        0.4.0
        • (jpgorganizer)
        M
        M
        muckel
        #120
        @jpgorganizer
        Siehe oben! 👏
          @dslraser
          jpgorganizer
          0.4.2
          • (jpgorganizer)
          0.4.1
          • (jpgorganizer)
          0.4.0
          • (jpgorganizer)
          dslraserD
          dslraserD
          dslraser
          #121
          @jpgorganizer
          alles da 👍
          • dslraserD dslraser
            @jpgorganizer
            alles da 👍
            M
            M
            muckel
            #122
            @dslraser
            @jpgorganizer
            Jetzt kann ich endlich den alten Gardena Adapter löschen.
            Bin schon neugierig was du noch in den Adapter einbringen wirst.
            Danke für dein Engagment!!! :-)
            jpgorganizerJ 1 Antwort Letzte Antwort
            • M muckel
              @dslraser
              @jpgorganizer
              jpgorganizerJ
              jpgorganizerJ
              jpgorganizer
              #123
              @muckel
              @dslraser
              Ideen viele - Zeit wird fehlen, wenn die Sonne scheint, bin ich auf dem MTB Zuhause.
              Ideen gerne einbringen und auch hier diskutieren. Auch unter https://github.com/jpgorganizer/ioBroker.smartgarden/issues sammle ich eifrig Ideen und Bugs (hoffentlich davon weniger)
              jpgorganizer
                @muckel
                @dslraser
                jpgorganizer
                dslraserD
                dslraserD
                dslraser
                #124
                @jpgorganizer Danke Dir für den Adapter👍
                so, ich lösche jetzt auch den alten Adapter.
                Hier (iQontrol) habe ich es nun auch drinn.
                • H
                  H
                  Hosifox
                  #125
                  Hallo
                  ich habe den Adapter ohne Fehler installiert und danach eingerichtet. ich bekomme im LOG den Fehler
                  (6116) Error: getlocations: no data
                  Muss ich noch was einstellen?
                  Gruß Thorsten
                  • H Hosifox
                    Hallo
                    Gruß Thorsten
                    jpgorganizerJ
                    jpgorganizerJ
                    jpgorganizer
                    #126
                    @Hosifox
                    Hi, prüfe nochmals Username, Passwort und API Key. Vorallem den API Key!
                    Die Gardena Geräte sind eingerichtet? Welche sollte es geben?
                    jpgorganizer
                      @dslraser sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                      @jpgorganizer
                      Ich habe jetzt den API-Key gelöscht und neu erstellt. Damit wird der Adapter nun wieder grün.
                      das muss man nicht verstehen ??? würde ich aber gerne
                      Das müssen wir beobachten, ob sowas öfter vorkommt. Danke für die Rückmeldung.
                      jpgorganizer
                      jpgorganizerJ
                      jpgorganizerJ
                      jpgorganizer
                      #127
                      @Hosifox
                      @jpgorganizer sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                      @jpgorganizer
                      jpgorganizer
                      das gab es wohl schon mal ..... falls es daran liegt, dann trotzdem mal melden, dass es das war
                      jpgorganizer
                      • H
                        H
                        Hosifox
                        #128
                        PW und Username sind richtig. Es gibt ja 2 Keys, ich nehme nicht den secrete Key sondern den Application key, denke das ist soweit richtig. Was heisst Geräte eingerichtet?? Der Mäher ist über die Gardena APP voll funktionsfähig. Muss ich noch woanders was einrichten?
                        https://api.authentication.husqvarnagroup.dev und https://api.smart.gardena.dev muss ich ja nichts ändern oder?
                        StrathColeS 1 Antwort Letzte Antwort
                        • H Hosifox
                          StrathColeS
                          StrathColeS
                          StrathCole
                          #129
                          @Hosifox Hast du für den Api-Key die API freigeschaltet? Muss man nach dem Anlegen des Keys ja machen (unten drunter).
                          SolarWatt-Anlage mit 9,6 kWp – KOSTAL Plenticore Plus 10 – BYD B-Box HV 8,96 – Viessmann Vitocal 333g – Zehnder ComfoD 350 (Comfoair 350) mit RS232-Ethernet-Konverter
                          • H
                            H
                            Hosifox
                            #130
                            Ja habe ich gemacht, alle 3 API stehen auf connect.
                            • H
                              H
                              Hosifox
                              #131
                              Der Adapter wird auch kurz grün, dann aber sofort wieder gelb.
                              • H
                                H
                                Hosifox
                                #132
                                1. get_locations ...
                                  smartgarden.0 2020-04-03 18:40:40.109 info (2172) sgSetState: info.connection true
                                  smartgarden.0 2020-04-03 18:40:40.108 info (2172) Connection: successful: response.statusCode /
                                dann wird er gelb
                                • J
                                  J
                                  jack99n
                                  #133
                                  Ich habe mir auch den Adapter mal Installiert. Kann man mir jemand sagen unter welchem Datenpunkt ich mein Sileno Mäher steuern kann?
                                  • J jack99n
                                    J
                                    J
                                    jack99n
                                    #134
                                    @jack99n sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                                    Okay einfach mal die Anleitung auf Git lesen. 😬
                                    • H Hosifox
                                      dann wird er gelb
                                      jpgorganizerJ
                                      jpgorganizerJ
                                      jpgorganizer
                                      schrieb am zuletzt editiert von jpgorganizer
                                      #135
                                      @Hosifox sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                                      da steht doch bestimmt noch was hinten dran ....
                                      Aber ist eigentlich egal, denn das ist vom connect am Service ... der scheint zu klappen, deshalb geht der Adapter erst mal auf grün,
                                      dann kommt die Abfrage auf die Locations (also die Sammlung der Geräte) und die geht nicht. Da kommt nichts zurück. Warum?
                                      Deshalb wird Adapter wieder gelb.
                                      Ich behaupte, dass @dslraser ein ähnliches Problem hatte und dieses mit einem neuen APIkey gelöst hat.
                                      jpgorganizer
                                        jpgorganizer
                                        dslraserD
                                        dslraserD
                                        dslraser
                                        #136
                                        Das wollte ich auch gerade schreiben.
                                        • H
                                          H
                                          Hosifox
                                          #137
                                          Leider nicht, Problem besteht weiterhin.
                                          33.2k
                                          84.3k
