  4. [neuer Adapter] smartgarden adapter for Gardena smart system
gardena smart systemsmartgarden
1.1k Beiträge 109 Kommentatoren 518.1k Aufrufe 102 Beobachtet
  • jpgorganizerJ
    jpgorganizerJ
    jpgorganizer
    #119
    @muckel Danke für deinen Support. Ich war einfach zu doof zu sehen, dass in einer Auswahl der Sensor komplett fehlt.
    @dslraser
    Sollte nun gehen. Bitte testet und bitte auch Feedback.
    Neue Version 0.4.2 ist auf github.
    jpgorganizer
    0.4.2
    • (jpgorganizer)
      • error missing SENSOR data fixed
    0.4.1
    • (jpgorganizer)
      • Dependency get's resolved now
    0.4.0
    • (jpgorganizer)
      • NOTE: with this version an additional dependency is necessary at runtime. If it does not get installed together with the installation of this adapter, please install seperately with npm install https://github.com/jpgorganizer/ioBroker.utils or npm i @jpgorganizer/utils
      • NOTE: you must delete all states of the adapter instance to install this release and please check your application carefully for necessary adjustments regarding type/role changes (see below)
      • data types of (nearly) all datapoints adjusted for compliance with ioBroker guidance:
        • states now have special ioBroker type and role instead of former string/text where applicable, e.g. number/value.battery for batteryLevel_value (Issue https://github.com/jpgorganizer/ioBroker.smartgarden/issues/3)
      • datapoint activity_value_i replaced by activity_mowing_i with type/role boolean/indicator.working: true means mowing, false means not mowing
      • possibility to pre-define states integrated, see new switch PreDefine States in adapter/instance configuration (Issue https://github.com/jpgorganizer/ioBroker.smartgarden/issues/2)
      • states are readonly now; except states for commands (Issue https://github.com/jpgorganizer/ioBroker.smartgarden/issues/4)
      • input field for useTestVariable in adapter/instance configuration switched to a checkbox (former: text); please check your settings
      • error in command stop_all_valves_i in VALVE_SET fixed
    smartgarden Adapter für GARDENA smart system
    M dslraserD 2 Antworten Letzte Antwort
    • jpgorganizerJ jpgorganizer
      @dslraser
      jpgorganizer
      0.4.2
      • (jpgorganizer)
      0.4.1
      • (jpgorganizer)
      0.4.0
      • (jpgorganizer)
      M
      M
      muckel
      #120
      @jpgorganizer
      Siehe oben! 👏
        @dslraser
        jpgorganizer
        0.4.2
        • (jpgorganizer)
        0.4.1
        • (jpgorganizer)
        0.4.0
        • (jpgorganizer)
        dslraserD
        dslraserD
        dslraser
        #121
        @jpgorganizer
        alles da 👍
        • dslraserD dslraser
          @jpgorganizer
          alles da 👍
          M
          M
          muckel
          #122
          @dslraser
          @jpgorganizer
          Jetzt kann ich endlich den alten Gardena Adapter löschen.
          Bin schon neugierig was du noch in den Adapter einbringen wirst.
          Danke für dein Engagment!!! :-)
          jpgorganizerJ 1 Antwort Letzte Antwort
          • M muckel
            @dslraser
            @jpgorganizer
            jpgorganizerJ
            jpgorganizerJ
            jpgorganizer
            #123
            @muckel
            @dslraser
            Ideen viele - Zeit wird fehlen, wenn die Sonne scheint, bin ich auf dem MTB Zuhause.
            Ideen gerne einbringen und auch hier diskutieren. Auch unter https://github.com/jpgorganizer/ioBroker.smartgarden/issues sammle ich eifrig Ideen und Bugs (hoffentlich davon weniger)
            jpgorganizer
              @muckel
              @dslraser
              jpgorganizer
              dslraserD
              dslraserD
              dslraser
              #124
              @jpgorganizer Danke Dir für den Adapter👍
              so, ich lösche jetzt auch den alten Adapter.
              Hier (iQontrol) habe ich es nun auch drinn.
              • H
                H
                Hosifox
                #125
                Hallo
                ich habe den Adapter ohne Fehler installiert und danach eingerichtet. ich bekomme im LOG den Fehler
                (6116) Error: getlocations: no data
                Muss ich noch was einstellen?
                Gruß Thorsten
                • H Hosifox
                  Hallo
                  Gruß Thorsten
                  jpgorganizerJ
                  jpgorganizerJ
                  jpgorganizer
                  #126
                  @Hosifox
                  Hi, prüfe nochmals Username, Passwort und API Key. Vorallem den API Key!
                  Die Gardena Geräte sind eingerichtet? Welche sollte es geben?
                  jpgorganizer
                    @dslraser sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                    @jpgorganizer
                    Ich habe jetzt den API-Key gelöscht und neu erstellt. Damit wird der Adapter nun wieder grün.
                    das muss man nicht verstehen ??? würde ich aber gerne
                    Das müssen wir beobachten, ob sowas öfter vorkommt. Danke für die Rückmeldung.
                    jpgorganizer
                    jpgorganizerJ
                    jpgorganizerJ
                    jpgorganizer
                    #127
                    @Hosifox
                    @jpgorganizer sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                    @jpgorganizer
                    jpgorganizer
                    das gab es wohl schon mal ..... falls es daran liegt, dann trotzdem mal melden, dass es das war
                    jpgorganizer
                    • H
                      H
                      Hosifox
                      #128
                      PW und Username sind richtig. Es gibt ja 2 Keys, ich nehme nicht den secrete Key sondern den Application key, denke das ist soweit richtig. Was heisst Geräte eingerichtet?? Der Mäher ist über die Gardena APP voll funktionsfähig. Muss ich noch woanders was einrichten?
                      https://api.authentication.husqvarnagroup.dev und https://api.smart.gardena.dev muss ich ja nichts ändern oder?
                      StrathColeS 1 Antwort Letzte Antwort
                      • H Hosifox
                        StrathColeS
                        StrathColeS
                        StrathCole
                        #129
                        @Hosifox Hast du für den Api-Key die API freigeschaltet? Muss man nach dem Anlegen des Keys ja machen (unten drunter).
                        SolarWatt-Anlage mit 9,6 kWp – KOSTAL Plenticore Plus 10 – BYD B-Box HV 8,96 – Viessmann Vitocal 333g – Zehnder ComfoD 350 (Comfoair 350) mit RS232-Ethernet-Konverter
                        • H
                          H
                          Hosifox
                          #130
                          Ja habe ich gemacht, alle 3 API stehen auf connect.
                          • H
                            H
                            Hosifox
                            #131
                            Der Adapter wird auch kurz grün, dann aber sofort wieder gelb.
                            • H
                              H
                              Hosifox
                              #132
                              1. get_locations ...
                                smartgarden.0 2020-04-03 18:40:40.109 info (2172) sgSetState: info.connection true
                                smartgarden.0 2020-04-03 18:40:40.108 info (2172) Connection: successful: response.statusCode /
                              dann wird er gelb
                              • J
                                J
                                jack99n
                                #133
                                Ich habe mir auch den Adapter mal Installiert. Kann man mir jemand sagen unter welchem Datenpunkt ich mein Sileno Mäher steuern kann?
                                • J jack99n
                                  J
                                  J
                                  jack99n
                                  #134
                                  @jack99n sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                                  Okay einfach mal die Anleitung auf Git lesen. 😬
                                  • H Hosifox
                                    dann wird er gelb
                                    jpgorganizerJ
                                    jpgorganizerJ
                                    jpgorganizer
                                    schrieb am zuletzt editiert von jpgorganizer
                                    #135
                                    @Hosifox sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                                    da steht doch bestimmt noch was hinten dran ....
                                    Aber ist eigentlich egal, denn das ist vom connect am Service ... der scheint zu klappen, deshalb geht der Adapter erst mal auf grün,
                                    dann kommt die Abfrage auf die Locations (also die Sammlung der Geräte) und die geht nicht. Da kommt nichts zurück. Warum?
                                    Deshalb wird Adapter wieder gelb.
                                    Ich behaupte, dass @dslraser ein ähnliches Problem hatte und dieses mit einem neuen APIkey gelöst hat.
                                    jpgorganizer
                                      jpgorganizer
                                      dslraserD
                                      dslraserD
                                      dslraser
                                      #136
                                      Das wollte ich auch gerade schreiben.
                                      • H
                                        H
                                        Hosifox
                                        #137
                                        Leider nicht, Problem besteht weiterhin.
                                        • H Hosifox
                                          jpgorganizerJ
                                          jpgorganizerJ
                                          jpgorganizer
                                          #138
                                          @Hosifox
                                          kannst du mal das Script versuchen, siehe weiter oben ....
                                          @muckel
                                          Script steht auf github
                                          https://github.com/jpgorganizer/ioBroker.smartgarden/blob/master/apitestscript/apitest.py
                                          Darin muss man gleich in den oberen Zeilen die eigenen Daten eintragen.
                                          # account specific values
                                          USERNAME = 'myUserEmail'
                                          PASSWORD = 'myUserPassword'
                                          API_KEY =  'myApplicationApiKey'
                                          Aufruf des scriptes mit
                                          python3 apitest.py
                                          Bitte posted nirgends die vollständigen Ausgaben des Scriptes, es stehen EURE token in der Ausgabe.
                                          Einfach in der Ausgabe mal schauen, ob sich dort die gesuchten Daten finden.
                                          Zur Info bei evlt. fehlenden Modulen. Ich musste bei mir folgendes installieren:
                                          pi@ioBroker:~ $ sudo apt-get install python3
                                          pi@ioBroker:~ $ sudo apt-get install python3-pip
                                          pi@ioBroker:~ $ pip3 install requests
                                          pi@ioBroker:~ $ pip3 install websocket-client
                                          pi@ioBroker:~ $  python3 --version
                                          Python 3.7.3
                                          pi@ioBroker:~ $ pip3 --version
                                          pip 18.1 from /usr/lib/python3/dist-packages/pip (python 3.7)
                                          jpgorganizer
                                          33.2k
                                          84.3k
