  4. [neuer Adapter] smartgarden adapter for Gardena smart system
gardena smart systemsmartgarden
1.1k Beiträge 109 Kommentatoren 449.6k Aufrufe 102 Beobachtet
  • jpgorganizerJ jpgorganizer
    @dslraser
    @StrathCole
    so, wieder Feuer frei - Abhängigkeit der Lib kann nun aufgelöst werden.
    die aktuelle Version ist nun die 0.4.1
    weiterhin die Notes von der 0.4.0 beachten
    0.4.1
    • (jpgorganizer)
      • Dependency get's resolved now
    0.4.0
    • (jpgorganizer)
      • NOTE: with this version an additional dependency is necessary at runtime. If it does not get installed together with the installation of this adapter, please install seperately with npm install https://github.com/jpgorganizer/ioBroker.utils or npm i @jpgorganizer/utils
      • NOTE: you must delete all states of the adapter instance to install this release and please check your application carefully for necessary adjustments regarding type/role changes (see below)
      • data types of (nearly) all datapoints adjusted for compliance with ioBroker guidance:
        • states now have special ioBroker type and role instead of former string/text where applicable, e.g. number/value.battery for batteryLevel_value (Issue https://github.com/jpgorganizer/ioBroker.smartgarden/issues/3)
      • datapoint activity_value_i replaced by activity_mowing_i with type/role boolean/indicator.working: true means mowing, false means not mowing
      • possibility to pre-define states integrated, see new switch PreDefine States in adapter/instance configuration (Issue https://github.com/jpgorganizer/ioBroker.smartgarden/issues/2)
      • states are readonly now; except states for commands (Issue https://github.com/jpgorganizer/ioBroker.smartgarden/issues/4)
      • input field for useTestVariable in adapter/instance configuration switched to a checkbox (former: text); please check your settings
      • error in command stop_all_valves_i in VALVE_SET fixed
    Grüße
    jpgorganizer
    dslraserD Offline
    dslraserD Offline
    dslraser
    #81
    @jpgorganizer sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
    ich mache jetzt schon eine ganze Weile rum, aber ich bekomme den Adapter nicht mehr grün.
    undefined2020-03-31 17:14:50.156 - info: host.iobroker "system.adapter.smartgarden.0" disabled
    2020-03-31 17:14:50.156 - info: host.iobroker stopInstance system.adapter.smartgarden.0 (force=false, process=true)
    2020-03-31 17:14:50.160 - info: smartgarden.0 (906) Got terminate signal TERMINATE_YOURSELF
    2020-03-31 17:14:50.162 - info: smartgarden.0 (906) terminating
    2020-03-31 17:14:50.162 - info: smartgarden.0 (906) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2020-03-31 17:14:50.157 - info: host.iobroker stopInstance system.adapter.smartgarden.0 send kill signal
    2020-03-31 17:14:50.687 - info: host.iobroker instance system.adapter.smartgarden.0 terminated with code 156 (156)
    2020-03-31 17:14:52.239 - info: host.iobroker "system.adapter.smartgarden.0" enabled
    2020-03-31 17:14:52.259 - info: host.iobroker instance system.adapter.smartgarden.0 started with pid 921
    2020-03-31 17:14:53.979 - info: smartgarden.0 (921) starting. Version 0.4.1 in /opt/iobroker/node_modules/iobroker.smartgarden, node: v10.19.0
    2020-03-31 17:14:54.016 - info: smartgarden.0 (921) sgSetState: info.revision Main: 2010 / API: 2010
    2020-03-31 17:14:54.018 - info: smartgarden.0 (921) Gardena Smart System Service hosts at: smart_host: https://api.smart.gardena.dev authentication_host: https://api.authentication.husqvarnagroup.dev
    2020-03-31 17:14:54.336 - info: smartgarden.0 (921) Connection: successful: response.statusCode / statusMessage=200 / OK
    2020-03-31 17:14:54.337 - info: smartgarden.0 (921) sgSetState: info.connection true
    2020-03-31 17:14:54.339 - info: smartgarden.0 (921) get_locations ...
    2020-03-31 17:14:54.486 - error: smartgarden.0 (921) Error: getlocations: no data
    jpgorganizerJ 1 Antwort Letzte Antwort
    • dslraserD dslraser
      jpgorganizerJ Offline
      jpgorganizer
      #82
      @dslraser sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
      Der Fehler kommt, nach dem Einloggen und wenn er dann keine Geräte von der Schnittstelle gemeldet bekommt.
      Prüfe nochmals die Gardena Account Daten und auch den API-Key. Hast du vielleicht zwei Gardena Accounts? 1x mit und 1x ohne Geräte?
      Grüße
      jpgorganizer
      smartgarden Adapter für GARDENA smart system
        Grüße
        jpgorganizer
        dslraserD Offline
        dslraserD Offline
        dslraser
        #83
        Grüße
        alles schon mehrfach geprüft. Und nein, ich habe nur einen Account. Im Browser kann ich mich genau mit diesen Daten anmelden. ApI-Key passt auch.
          Grüße
          jpgorganizer
          dslraserD Offline
          dslraserD Offline
          dslraser
          #84
          @jpgorganizer
          Ich habe jetzt den API-Key gelöscht und neu erstellt. Damit wird der Adapter nun wieder grün.
            @jpgorganizer
            jpgorganizer
            #85
            @jpgorganizer
            das muss man nicht verstehen ??? würde ich aber gerne
            Das müssen wir beobachten, ob sowas öfter vorkommt. Danke für die Rückmeldung.
            Grüße
            jpgorganizer
            dslraserD jpgorganizerJ 2 Antworten Letzte Antwort
              @jpgorganizer
              Grüße
              jpgorganizer
              dslraserD Offline
              dslraserD Offline
              dslraser
              #86
              @jpgorganizer
              So, mein Blockly brauchte ich kaum ändern, läuft mit der 0.4.1 immer noch (nur den Stop aller Ventile habe ich im Blockly geändert. Der DP .stop_all_valves_i mit STOP_UNTIL_NEXT_TASK funktioniert nun 👍 )
              Bis auf die Sensordaten ist alles okay. Da warte ich mal noch etwas ab, da diese Daten nicht ständig übertragen werden. Im Moment ist es leer.
                @muckel sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                Feedback: Sensor gibt keine der Messdaten an den Adapter. Bodenfeuchte, Temperatur, Helligkeit
                sowas ähnliches hat @dslraser auch schon gesagt. Ich habe keinen sensor, deshalb bin ich auf eurer Mitarbeit angewiesen.
                Bitte macht mal in der Instance Konfig den Loglevel auf 3 und startet dann den Adaper und lasst mir mal den gesamten Log zukommen.
                jpgorganizer
                muckel
                #87
                @jpgorganizer
                Hier der gewünschte log
                smartgarden.0	2020-03-31 18:08:15.797	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_COMMON_7332.rfLinkState_value ONLINE
                smartgarden.0	2020-03-31 18:08:15.796	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_COMMON_7332.modelType_value GARDENA smart Irrigation Control
                smartgarden.0	2020-03-31 18:08:15.796	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_COMMON_7332.serial_value 00001393
                smartgarden.0	2020-03-31 18:08:15.796	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_COMMON_7332.rfLinkLevel_timestamp 2020-03-31T15:30:10.995+0000
                smartgarden.0	2020-03-31 18:08:15.795	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_COMMON_7332.rfLinkLevel_value 60
                smartgarden.0	2020-03-31 18:08:15.795	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_COMMON_7332.batteryState_value NO_BATTERY
                smartgarden.0	2020-03-31 18:08:15.794	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_COMMON_7332.name_value Bewässerungsteuerung Garten
                smartgarden.0	2020-03-31 18:08:15.794	info	(11408) setServiceStates: smartgarden.0.LOCATION_5a66f03f-74db-4fa0-9e61-38bbded6504a.DEVICE_d2bf229d-d6a9-46d1-98ea-10f3379c7332.SERVICE_COMMON_d2bf229d-d6a9-46d1-98ea-10f3379c7332
                smartgarden.0	2020-03-31 18:08:15.791	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:6.lastErrorCode_timestamp 2019-08-31T05:50:16.873+0000
                smartgarden.0	2020-03-31 18:08:15.791	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:6.lastErrorCode_value NO_MESSAGE
                smartgarden.0	2020-03-31 18:08:15.790	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:6.state_timestamp 2019-08-31T05:50:21.319+0000
                smartgarden.0	2020-03-31 18:08:15.790	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:6.state_value UNAVAILABLE
                smartgarden.0	2020-03-31 18:08:15.790	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:6.activity_timestamp 2019-08-31T05:50:16.781+0000
                smartgarden.0	2020-03-31 18:08:15.789	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:6.duration_value null
                smartgarden.0	2020-03-31 18:08:15.789	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:6.duration_timestamp
                smartgarden.0	2020-03-31 18:08:15.788	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:6.duration_leftover_i null
                smartgarden.0	2020-03-31 18:08:15.788	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:6.activity_value CLOSED
                smartgarden.0	2020-03-31 18:08:15.788	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:6.name_value Valve 6
                smartgarden.0	2020-03-31 18:08:15.787	info	(11408) setServiceStates: smartgarden.0.LOCATION_5a66f03f-74db-4fa0-9e61-38bbded6504a.DEVICE_d2bf229d-d6a9-46d1-98ea-10f3379c7332.SERVICE_VALVE_d2bf229d-d6a9-46d1-98ea-10f3379c7332%3A6
                smartgarden.0	2020-03-31 18:08:15.786	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:5.lastErrorCode_timestamp 2019-08-31T05:50:16.863+0000
                smartgarden.0	2020-03-31 18:08:15.785	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:5.lastErrorCode_value NO_MESSAGE
                smartgarden.0	2020-03-31 18:08:15.785	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:5.state_timestamp 2019-08-31T05:50:21.319+0000
                smartgarden.0	2020-03-31 18:08:15.784	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:5.state_value UNAVAILABLE
                smartgarden.0	2020-03-31 18:08:15.784	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:5.activity_timestamp 2019-08-31T05:50:16.765+0000
                smartgarden.0	2020-03-31 18:08:15.783	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:5.duration_value null
                smartgarden.0	2020-03-31 18:08:15.783	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:5.duration_timestamp
                smartgarden.0	2020-03-31 18:08:15.783	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:5.duration_leftover_i null
                smartgarden.0	2020-03-31 18:08:15.782	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:5.activity_value CLOSED
                smartgarden.0	2020-03-31 18:08:15.782	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:5.name_value Valve 5
                smartgarden.0	2020-03-31 18:08:15.781	info	(11408) setServiceStates: smartgarden.0.LOCATION_5a66f03f-74db-4fa0-9e61-38bbded6504a.DEVICE_d2bf229d-d6a9-46d1-98ea-10f3379c7332.SERVICE_VALVE_d2bf229d-d6a9-46d1-98ea-10f3379c7332%3A5
                smartgarden.0	2020-03-31 18:08:15.778	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:4.lastErrorCode_timestamp 2019-08-31T05:50:16.855+0000
                smartgarden.0	2020-03-31 18:08:15.776	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:4.lastErrorCode_value NO_MESSAGE
                smartgarden.0	2020-03-31 18:08:15.775	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:4.state_timestamp 2019-08-31T05:50:21.319+0000
                smartgarden.0	2020-03-31 18:08:15.775	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:4.state_value OK
                smartgarden.0	2020-03-31 18:08:15.774	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:4.activity_timestamp 2019-10-20T03:59:57.087+0000
                smartgarden.0	2020-03-31 18:08:15.774	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:4.duration_value null
                smartgarden.0	2020-03-31 18:08:15.773	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:4.duration_timestamp
                smartgarden.0	2020-03-31 18:08:15.773	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:4.duration_leftover_i null
                smartgarden.0	2020-03-31 18:08:15.772	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:4.activity_value CLOSED
                smartgarden.0	2020-03-31 18:08:15.772	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:4.name_value Rasensprenger
                smartgarden.0	2020-03-31 18:08:15.771	info	(11408) setServiceStates: smartgarden.0.LOCATION_5a66f03f-74db-4fa0-9e61-38bbded6504a.DEVICE_d2bf229d-d6a9-46d1-98ea-10f3379c7332.SERVICE_VALVE_d2bf229d-d6a9-46d1-98ea-10f3379c7332%3A4
                smartgarden.0	2020-03-31 18:08:15.770	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:3.lastErrorCode_timestamp 2019-08-31T05:50:16.847+0000
                smartgarden.0	2020-03-31 18:08:15.769	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:3.lastErrorCode_value NO_MESSAGE
                smartgarden.0	2020-03-31 18:08:15.769	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:3.state_timestamp 2019-08-31T05:50:21.319+0000
                smartgarden.0	2020-03-31 18:08:15.768	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:3.state_value OK
                smartgarden.0	2020-03-31 18:08:15.768	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:3.activity_timestamp 2019-10-20T04:59:57.085+0000
                smartgarden.0	2020-03-31 18:08:15.767	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:3.duration_value null
                smartgarden.0	2020-03-31 18:08:15.767	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:3.duration_timestamp
                smartgarden.0	2020-03-31 18:08:15.767	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:3.duration_leftover_i null
                smartgarden.0	2020-03-31 18:08:15.766	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:3.activity_value CLOSED
                smartgarden.0	2020-03-31 18:08:15.766	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:3.name_value Böschung und Hochbeet
                smartgarden.0	2020-03-31 18:08:15.765	info	(11408) setServiceStates: smartgarden.0.LOCATION_5a66f03f-74db-4fa0-9e61-38bbded6504a.DEVICE_d2bf229d-d6a9-46d1-98ea-10f3379c7332.SERVICE_VALVE_d2bf229d-d6a9-46d1-98ea-10f3379c7332%3A3
                smartgarden.0	2020-03-31 18:08:15.762	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:2.lastErrorCode_timestamp 2019-08-31T05:50:16.840+0000
                smartgarden.0	2020-03-31 18:08:15.761	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:2.lastErrorCode_value NO_MESSAGE
                smartgarden.0	2020-03-31 18:08:15.761	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:2.state_timestamp 2019-08-31T05:50:21.319+0000
                smartgarden.0	2020-03-31 18:08:15.760	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:2.state_value OK
                smartgarden.0	2020-03-31 18:08:15.760	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:2.activity_timestamp 2019-10-20T04:29:57.132+0000
                smartgarden.0	2020-03-31 18:08:15.759	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:2.duration_value null
                smartgarden.0	2020-03-31 18:08:15.759	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:2.duration_timestamp
                smartgarden.0	2020-03-31 18:08:15.758	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:2.duration_leftover_i null
                smartgarden.0	2020-03-31 18:08:15.758	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:2.activity_value CLOSED
                smartgarden.0	2020-03-31 18:08:15.757	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:2.name_value Zaun- und Kiwibeet
                smartgarden.0	2020-03-31 18:08:15.756	info	(11408) setServiceStates: smartgarden.0.LOCATION_5a66f03f-74db-4fa0-9e61-38bbded6504a.DEVICE_d2bf229d-d6a9-46d1-98ea-10f3379c7332.SERVICE_VALVE_d2bf229d-d6a9-46d1-98ea-10f3379c7332%3A2
                smartgarden.0	2020-03-31 18:08:15.715	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:1.lastErrorCode_timestamp 2019-08-31T05:50:16.833+0000
                smartgarden.0	2020-03-31 18:08:15.714	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:1.lastErrorCode_value NO_MESSAGE
                smartgarden.0	2020-03-31 18:08:15.714	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:1.state_timestamp 2019-08-31T05:50:21.319+0000
                smartgarden.0	2020-03-31 18:08:15.713	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:1.state_value OK
                smartgarden.0	2020-03-31 18:08:15.713	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:1.activity_timestamp 2019-10-20T02:59:57.008+0000
                smartgarden.0	2020-03-31 18:08:15.712	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:1.duration_value null
                smartgarden.0	2020-03-31 18:08:15.712	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:1.duration_timestamp
                smartgarden.0	2020-03-31 18:08:15.711	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:1.duration_leftover_i null
                smartgarden.0	2020-03-31 18:08:15.710	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:1.activity_value CLOSED
                smartgarden.0	2020-03-31 18:08:15.710	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:1.name_value Himbeerbeet
                smartgarden.0	2020-03-31 18:08:15.709	info	(11408) setServiceStates: smartgarden.0.LOCATION_5a66f03f-74db-4fa0-9e61-38bbded6504a.DEVICE_d2bf229d-d6a9-46d1-98ea-10f3379c7332.SERVICE_VALVE_d2bf229d-d6a9-46d1-98ea-10f3379c7332%3A1
                smartgarden.0	2020-03-31 18:08:15.647	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_SET_7332.lastErrorCode_timestamp 2020-02-11T19:57:25.833+0000
                smartgarden.0	2020-03-31 18:08:15.647	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_SET_7332.lastErrorCode_value NO_MESSAGE
                smartgarden.0	2020-03-31 18:08:15.646	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_SET_7332.state_timestamp 2020-02-11T19:57:25.833+0000
                smartgarden.0	2020-03-31 18:08:15.646	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_SET_7332.stop_all_valves_i null
                smartgarden.0	2020-03-31 18:08:15.645	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_SET_7332.state_value OK
                smartgarden.0	2020-03-31 18:08:15.645	info	(11408) setServiceStates: smartgarden.0.LOCATION_5a66f03f-74db-4fa0-9e61-38bbded6504a.DEVICE_d2bf229d-d6a9-46d1-98ea-10f3379c7332.SERVICE_VALVE_SET_d2bf229d-d6a9-46d1-98ea-10f3379c7332
                smartgarden.0	2020-03-31 18:08:15.642	info	(11408) sgSetState: sg.0.L_504a.D_c63b.S_COMMON_c63b.rfLinkState_value ONLINE
                smartgarden.0	2020-03-31 18:08:15.642	info	(11408) sgSetState: sg.0.L_504a.D_c63b.S_COMMON_c63b.modelType_value GARDENA smart Sensor
                smartgarden.0	2020-03-31 18:08:15.641	info	(11408) sgSetState: sg.0.L_504a.D_c63b.S_COMMON_c63b.serial_value 00003256
                smartgarden.0	2020-03-31 18:08:15.641	info	(11408) sgSetState: sg.0.L_504a.D_c63b.S_COMMON_c63b.rfLinkLevel_timestamp 2020-03-31T15:43:17.925+0000
                smartgarden.0	2020-03-31 18:08:15.640	info	(11408) sgSetState: sg.0.L_504a.D_c63b.S_COMMON_c63b.rfLinkLevel_value 30
                smartgarden.0	2020-03-31 18:08:15.640	info	(11408) sgSetState: sg.0.L_504a.D_c63b.S_COMMON_c63b.batteryState_timestamp 2020-03-30T21:10:41.910+0000
                smartgarden.0	2020-03-31 18:08:15.639	info	(11408) sgSetState: sg.0.L_504a.D_c63b.S_COMMON_c63b.batteryState_value OK
                smartgarden.0	2020-03-31 18:08:15.639	info	(11408) sgSetState: sg.0.L_504a.D_c63b.S_COMMON_c63b.batteryLevel_timestamp 2020-03-30T21:10:41.910+0000
                smartgarden.0	2020-03-31 18:08:15.638	info	(11408) sgSetState: sg.0.L_504a.D_c63b.S_COMMON_c63b.batteryLevel_value 95
                smartgarden.0	2020-03-31 18:08:15.638	info	(11408) sgSetState: sg.0.L_504a.D_c63b.S_COMMON_c63b.name_value Sensor
                smartgarden.0	2020-03-31 18:08:15.637	info	(11408) setServiceStates: smartgarden.0.LOCATION_5a66f03f-74db-4fa0-9e61-38bbded6504a.DEVICE_c5a76528-97d2-4816-9c90-9589f0fac63b.SERVICE_COMMON_c5a76528-97d2-4816-9c90-9589f0fac63b
                smartgarden.0	2020-03-31 18:08:15.636	info	(11408) sgSetState: sg.0.L_504a.D_b6a2.S_COMMON_b6a2.rfLinkState_value ONLINE
                smartgarden.0	2020-03-31 18:08:15.636	info	(11408) sgSetState: sg.0.L_504a.D_b6a2.S_COMMON_b6a2.modelType_value GARDENA smart Mower
                smartgarden.0	2020-03-31 18:08:15.635	info	(11408) sgSetState: sg.0.L_504a.D_b6a2.S_COMMON_b6a2.serial_value 00008016
                smartgarden.0	2020-03-31 18:08:15.635	info	(11408) sgSetState: sg.0.L_504a.D_b6a2.S_COMMON_b6a2.rfLinkLevel_timestamp 2020-03-30T21:12:42.678+0000
                smartgarden.0	2020-03-31 18:08:15.634	info	(11408) sgSetState: sg.0.L_504a.D_b6a2.S_COMMON_b6a2.rfLinkLevel_value 70
                smartgarden.0	2020-03-31 18:08:15.634	info	(11408) sgSetState: sg.0.L_504a.D_b6a2.S_COMMON_b6a2.batteryState_timestamp 2020-03-30T22:00:42.625+0000
                smartgarden.0	2020-03-31 18:08:15.633	info	(11408) sgSetState: sg.0.L_504a.D_b6a2.S_COMMON_b6a2.batteryState_value OK
                smartgarden.0	2020-03-31 18:08:15.633	info	(11408) sgSetState: sg.0.L_504a.D_b6a2.S_COMMON_b6a2.batteryLevel_timestamp 2020-03-30T22:00:42.625+0000
                smartgarden.0	2020-03-31 18:08:15.632	info	(11408) sgSetState: sg.0.L_504a.D_b6a2.S_COMMON_b6a2.batteryLevel_value 100
                smartgarden.0	2020-03-31 18:08:15.632	info	(11408) sgSetState: sg.0.L_504a.D_b6a2.S_COMMON_b6a2.name_value Tussi
                smartgarden.0	2020-03-31 18:08:15.631	info	(11408) setServiceStates: smartgarden.0.LOCATION_5a66f03f-74db-4fa0-9e61-38bbded6504a.DEVICE_7044cd9e-41d2-4466-886e-d8786903b6a2.SERVICE_COMMON_7044cd9e-41d2-4466-886e-d8786903b6a2
                smartgarden.0	2020-03-31 18:08:15.628	info	(11408) sgSetState: sg.0.L_504a.D_b6a2.S_MOWER_b6a2.operatingHours_value 1159
                smartgarden.0	2020-03-31 18:08:15.627	info	(11408) sgSetState: sg.0.L_504a.D_b6a2.S_MOWER_b6a2.activity_timestamp 2020-03-31T15:16:56.719+0000
                smartgarden.0	2020-03-31 18:08:15.627	info	(11408) sgSetState: sg.0.L_504a.D_b6a2.S_MOWER_b6a2.activity_control_i null
                smartgarden.0	2020-03-31 18:08:15.626	info	(11408) sgSetState: sg.0.L_504a.D_b6a2.S_MOWER_b6a2.activity_mowing_i false
                smartgarden.0	2020-03-31 18:08:15.626	info	(11408) sgSetState: sg.0.L_504a.D_b6a2.S_MOWER_b6a2.activity_value PARKED_PARK_SELECTED
                smartgarden.0	2020-03-31 18:08:15.625	info	(11408) sgSetState: sg.0.L_504a.D_b6a2.S_MOWER_b6a2.state_timestamp 2020-03-31T15:16:56.719+0000
                smartgarden.0	2020-03-31 18:08:15.624	info	(11408) sgSetState: sg.0.L_504a.D_b6a2.S_MOWER_b6a2.state_value OK
                smartgarden.0	2020-03-31 18:08:15.624	info	(11408) setServiceStates: smartgarden.0.LOCATION_5a66f03f-74db-4fa0-9e61-38bbded6504a.DEVICE_7044cd9e-41d2-4466-886e-d8786903b6a2.SERVICE_MOWER_7044cd9e-41d2-4466-886e-d8786903b6a2
                smartgarden.0	2020-03-31 18:08:15.607	info	(11408) sgSetState: sg.0.L_504a.D_9a5d.S_COMMON_9a5d.rfLinkState_value ONLINE
                smartgarden.0	2020-03-31 18:08:15.606	info	(11408) sgSetState: sg.0.L_504a.D_9a5d.S_COMMON_9a5d.modelType_value GARDENA smart Water Control
                smartgarden.0	2020-03-31 18:08:15.606	info	(11408) sgSetState: sg.0.L_504a.D_9a5d.S_COMMON_9a5d.serial_value 00031728
                smartgarden.0	2020-03-31 18:08:15.605	info	(11408) sgSetState: sg.0.L_504a.D_9a5d.S_COMMON_9a5d.rfLinkLevel_timestamp 2020-03-31T15:59:51.659+0000
                smartgarden.0	2020-03-31 18:08:15.605	info	(11408) sgSetState: sg.0.L_504a.D_9a5d.S_COMMON_9a5d.rfLinkLevel_value 70
                smartgarden.0	2020-03-31 18:08:15.604	info	(11408) sgSetState: sg.0.L_504a.D_9a5d.S_COMMON_9a5d.batteryState_timestamp 2020-03-31T15:59:51.602+0000
                smartgarden.0	2020-03-31 18:08:15.604	info	(11408) sgSetState: sg.0.L_504a.D_9a5d.S_COMMON_9a5d.batteryState_value OUT_OF_OPERATION
                smartgarden.0	2020-03-31 18:08:15.603	info	(11408) sgSetState: sg.0.L_504a.D_9a5d.S_COMMON_9a5d.batteryLevel_timestamp 2020-03-31T15:59:51.636+0000
                smartgarden.0	2020-03-31 18:08:15.603	info	(11408) sgSetState: sg.0.L_504a.D_9a5d.S_COMMON_9a5d.batteryLevel_value 0
                smartgarden.0	2020-03-31 18:08:15.602	info	(11408) sgSetState: sg.0.L_504a.D_9a5d.S_COMMON_9a5d.name_value Blumenbeet Straße
                smartgarden.0	2020-03-31 18:08:15.601	info	(11408) setServiceStates: smartgarden.0.LOCATION_5a66f03f-74db-4fa0-9e61-38bbded6504a.DEVICE_2512c1ce-5226-414b-8ea3-b61fe40c9a5d.SERVICE_COMMON_2512c1ce-5226-414b-8ea3-b61fe40c9a5d
                smartgarden.0	2020-03-31 18:08:15.555	info	(11408) sgSetState: sg.0.L_504a.D_9a5d.S_VALVE_9a5d.state_value OK
                smartgarden.0	2020-03-31 18:08:15.555	info	(11408) sgSetState: sg.0.L_504a.D_9a5d.S_VALVE_9a5d.activity_timestamp 2020-03-30T22:59:59.184+0000
                smartgarden.0	2020-03-31 18:08:15.554	info	(11408) sgSetState: sg.0.L_504a.D_9a5d.S_VALVE_9a5d.duration_value null
                smartgarden.0	2020-03-31 18:08:15.554	info	(11408) sgSetState: sg.0.L_504a.D_9a5d.S_VALVE_9a5d.duration_timestamp
                smartgarden.0	2020-03-31 18:08:15.553	info	(11408) sgSetState: sg.0.L_504a.D_9a5d.S_VALVE_9a5d.duration_leftover_i null
                smartgarden.0	2020-03-31 18:08:15.553	info	(11408) sgSetState: sg.0.L_504a.D_9a5d.S_VALVE_9a5d.activity_value CLOSED
                smartgarden.0	2020-03-31 18:08:15.552	info	(11408) sgSetState: sg.0.L_504a.D_9a5d.S_VALVE_9a5d.name_value Blumenbeet Straße
                smartgarden.0	2020-03-31 18:08:15.551	info	(11408) setServiceStates: smartgarden.0.LOCATION_5a66f03f-74db-4fa0-9e61-38bbded6504a.DEVICE_2512c1ce-5226-414b-8ea3-b61fe40c9a5d.SERVICE_VALVE_2512c1ce-5226-414b-8ea3-b61fe40c9a5d
                smartgarden.0	2020-03-31 18:08:15.549	info	(11408) setServiceStates: smartgarden.0.LOCATION_5a66f03f-74db-4fa0-9e61-38bbded6504a.DEVICE_2512c1ce-5226-414b-8ea3-b61fe40c9a5d.SERVICE_VALVE_SET_2512c1ce-5226-414b-8ea3-b61fe40c9a5d%3Awc
                smartgarden.0	2020-03-31 18:08:15.465	info	(11408) parseMessage: COMMON found
                smartgarden.0	2020-03-31 18:08:15.464	info	(11408) parseMessage: VALVE found
                smartgarden.0	2020-03-31 18:08:15.463	info	(11408) parseMessage: VALVE found
                smartgarden.0	2020-03-31 18:08:15.462	info	(11408) parseMessage: VALVE found
                smartgarden.0	2020-03-31 18:08:15.461	info	(11408) parseMessage: VALVE found
                smartgarden.0	2020-03-31 18:08:15.460	info	(11408) parseMessage: VALVE found
                smartgarden.0	2020-03-31 18:08:15.420	info	(11408) parseMessage: VALVE_SET found
                smartgarden.0	2020-03-31 18:08:15.419	info	(11408) parseMessage: COMMON found
                smartgarden.0	2020-03-31 18:08:15.419	info	(11408) parseMessage: Unknown message found
                smartgarden.0	2020-03-31 18:08:15.418	info	(11408) parseMessage: COMMON found
                smartgarden.0	2020-03-31 18:08:15.417	info	(11408) parseMessage: MOWER found
                smartgarden.0	2020-03-31 18:08:15.416	info	(11408) parseMessage: COMMON found
                smartgarden.0	2020-03-31 18:08:15.413	info	(11408) parseMessage: VALVE found
                smartgarden.0	2020-03-31 18:08:15.411	info	(11408) parseMessage: VALVE_SET found
                smartgarden.0	2020-03-31 18:08:15.409	info	(11408) parseMessage: DEVICE found
                smartgarden.0	2020-03-31 18:08:15.408	info	(11408) parseMessage: DEVICE found
                smartgarden.0	2020-03-31 18:08:15.406	info	(11408) parseMessage: DEVICE found
                smartgarden.0	2020-03-31 18:08:15.404	info	(11408) parseMessage: DEVICE found
                smartgarden.0	2020-03-31 18:08:15.400	info	(11408) sgSetState: L_504a.name My Garden
                smartgarden.0	2020-03-31 18:08:15.400	info	(11408) parseMessage: LOCATION found
                smartgarden.0	2020-03-31 18:08:13.220	info	(11408) on_open: ### connected ###
                smartgarden.0	2020-03-31 18:08:12.332	info	(11408) get_websocket ...
                smartgarden.0	2020-03-31 18:08:12.330	info	(11408) get_locations: successful / response.statusMessage: OK
                smartgarden.0	2020-03-31 18:08:11.768	info	(11408) get_locations ...
                smartgarden.0	2020-03-31 18:08:11.766	info	(11408) sgSetState: info.connection true
                smartgarden.0	2020-03-31 18:08:11.765	info	(11408) Connection: successful: response.statusCode / statusMessage=200 / OK
                smartgarden.0	2020-03-31 18:08:11.230	info	(11408) Gardena Smart System Service hosts at: smart_host: https://api.smart.gardena.dev authentication_host: https://api.authentication.husqvarnagroup.dev
                smartgarden.0	2020-03-31 18:08:11.229	info	(11408) sgSetState: info.revision Main: 2010 / API: 2010
                smartgarden.0	2020-03-31 18:08:11.209	info	(11408) starting. Version 0.4.1 in /opt/iobroker/node_modules/iobroker.smartgarden, node: v10.16.0
                host.SmartHome	2020-03-31 18:08:09.927	info	instance system.adapter.smartgarden.0 started with pid 11408
                host.SmartHome	2020-03-31 18:08:09.905	info	"system.adapter.smartgarden.0" enabled
                host.SmartHome	2020-03-31 18:08:05.075	info	instance system.adapter.smartgarden.0 terminated with code 156 (156)
                smartgarden.0	2020-03-31 18:08:04.553	info	(1661) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                smartgarden.0	2020-03-31 18:08:04.553	info	(1661) terminating
                smartgarden.0	2020-03-31 18:08:04.552	info	(1661) Got terminate signal TERMINATE_YOURSELF
                  @jpgorganizer
                  muckel
                  #88
                  @jpgorganizer
                  Bei mir werden auch die Datenpunkte nicht angelegt, bei @dslraser schon.
                  • M muckel
                    @jpgorganizer
                    jpgorganizer
                    #89
                    @muckel
                    schau mal bei den Datenpunkten unter
                    kannst du da mal einen Screenshot machen, was da so dabei ist. Und ist unter dem Device noch ein anderer Service (SERVICE_xxxxx)?
                    VG
                    jpgorganizer
                      @muckel
                      VG
                      jpgorganizer
                      muckel
                      schrieb am zuletzt editiert von muckel
                      #90
                      @jpgorganizer
                      nein, der screenshot ist alles was da ist vom Sensor.
                      mehr gibt es nicht.
                      • M muckel
                        @jpgorganizer
                        mehr gibt es nicht.
                        dslraserD Offline
                        dslraserD Offline
                        dslraser
                        #91
                        @muckel
                        @jpgorganizer
                        Die Sensor DP waren bisher auch nicht da bei mir. Daten kommen übrigens keine.
                        Erscheinen die DP jetzt vielleicht deshalb ?
                        @muckel
                        hast Du da auch einen Haken drinn ?
                        • jpgorganizerJ Offline
                          jpgorganizer
                          #92
                          @muckel @dslraser
                          Es sieht für mich so aus, als ob der Sensor keine Daten oder nur sehr selten Daten liefert. Der ist doch batteriebetrieben, richtig? Dann wird der auf Energie Sparen getrimmt sein und nur selten Daten übertragen. Also einfach mal warten.
                          Wenn sich die Temp ändert, dann sollte er was übrtragen, ausser er hat eine Schwelle, wieviel sich ändern muss.
                          Ich hoffe nicht, dass die API noch einen Fehler hat und sie nie Daten liefert. Ansich funktioniert die ganz gut.
                          das kann gut sein - wenn keine Werte drin stehen, dann ist es so.
                          VG
                          jpgorganizer
                            @muckel
                            @jpgorganizer
                            @muckel
                            muckel
                            #93
                            @dslraser
                            Haken gesetzt und die DP sind da nach einem Neustart des Adapters.
                            Daten natürlich noch keine, das dauert immer wie du richtig sagst.
                            @jpgorganizer
                            Daten kommen in der APP von Gardena an und ändern sich auch.
                            .rfLinkLevel_timestamp wird auch richtig geschrieben.
                            Adapter empfängt vom Sensor Daten.
                            Nur die Sensordaten nicht.
                            • M muckel
                              @dslraser
                              @jpgorganizer
                              jpgorganizer
                              #94
                              tja, Gardena nutzt selbst eine andere Schnittstelle, die aber leider weder dokumentiert noch freigegeben ist.
                              VG
                              jpgorganizer
                                VG
                                jpgorganizer
                                muckel
                                #95
                                @jpgorganizer
                                gibt es eine einfache Möglichkeit die Daten des Sensors in der API abzurufen?
                                • M muckel
                                  @jpgorganizer
                                  jpgorganizer
                                  #96
                                  @muckel
                                  Nein, es gibt keine Möglichkeit irgendwelche Daten abzufragen. Man frägt 1x an und bekommt, was man bekommt.
                                  Hast du oder @dslraser eine Möglichkeit ein python3 Script laufen zu lassen? Es gibt ein Python3 Script von Gardena ohne jeglichen Schnickschnack mit dem man mal testen könnte, ob wirklich nichts kommt, oder ob der Adapter dies nur irgendwie ignoriert. Ich kann mir sowas natürlich nicht vorstellen :-), aber testen kann ich das nicht, da ich keinen Sensor habe.
                                  VG
                                  jpgorganizer
                                  dslraserD M 2 Antworten Letzte Antwort
                                    @muckel
                                    VG
                                    jpgorganizer
                                    dslraserD Offline
                                    dslraserD Offline
                                    dslraser
                                    #97
                                    python3 Script
                                    wenn Du mir sagst was ich machen muß ? Davon habe ich keine Ahnung.
                                      python3 Script
                                      jpgorganizer
                                      #98
                                      @dslraser
                                      du (bzw. dein ioBroker) arbeitest unter Linux?
                                        @dslraser
                                        dslraserD Offline
                                        dslraserD Offline
                                        dslraser
                                        #99
                                        @jpgorganizer
                                        Synology Docker Container, also ja (mit Portainer)
                                          @jpgorganizer
                                          jpgorganizer
                                          #100
                                          @dslraser
                                          ok, du musst folgendes tun können:
                                          • python3 und noch ein paar andere Module installieren, wenn es noch nicht drauf ist
                                            • log dich mal auf der Kommandozeile ein
                                            • rufe folgendes auf python3 --version : Achte auf das doppelte Minuszeichen! Wenn da nun eine VersionsNr erscheint, dann ist es drauf. Sollte dann so aussehen
                                              pi@ioBroker:~ $  python3 --version
                                              Python 3.7.3
                                            • falls das nicht kommt (die Versionsnr wird egal sein), dann musst du python3 installieren. Ich habe jetzt keine Ahnung wie das in einem Docker Container geht. Vmtl. aber wie meist unter Linux mit apt-get. Kennst du das?
                                              • teste dann mal ob du apt-get nutzen kannst? Wie oben mit python3, hier nur apt-get --version aufrufen.
