[neuer Adapter] smartgarden adapter for Gardena smart system
bei mir liegt Schnee im Garten - Test muss verschoben werden
@jpgorganizer
bei mir nicht.
kannst Du schon mal das Update zur Verfügung stellen ? Ich habe Zeit ind könnte testen. -
@jpgorganizer
bei mir nicht.
kannst Du schon mal das Update zur Verfügung stellen ? Ich habe Zeit ind könnte testen.@dslraser ich habe ihn online auf github ... kannst ja testen und Info geben.
Bitte beachte die Relesase Notes:
0.4.0
- (jpgorganizer)
- NOTE: with this version an additional dependency is necessary at runtime. If it does not get installed together with the installation of this adapter, please install seperately with
npm install https://github.com/jpgorganizer/ioBroker.utils - NOTE: you must delete all states of the adapter instance to install this release and please check your application carefully for necessary adjustments regarding type/role changes (see below)
- data types of (nearly) all datapoints adjusted for compliance with ioBroker guidance:
- states now have special ioBroker type and role instead of former
string/textwhere applicable, e.g.number/value.batteryforbatteryLevel_value(Issue https://github.com/jpgorganizer/ioBroker.smartgarden/issues/3)
- datapoint
activity_value_ireplaced byactivity_mowing_iwith type/roleboolean/indicator.working:truemeans mowing,falsemeans not mowing - possibility to pre-define states integrated, see new switch
PreDefine Statesin adapter/instance configuration (Issue https://github.com/jpgorganizer/ioBroker.smartgarden/issues/2) - states are readonly now; except states for commands (Issue https://github.com/jpgorganizer/ioBroker.smartgarden/issues/4)
- input field for
useTestVariablein adapter/instance configuration switched to a checkbox (former: text); please check your settings - error in command
stop_all_valves_iin VALVE_SET fixed
jpgorganizer - (jpgorganizer)
hab gerade geprüft : ich kann den Adapter nicht installieren - liegt an der Auflösung einer Abhängigkeit - ich bin dran und melde mich
@jpgorganizer Ja, für die Abhängigkeiten muss die Lib erst
npm publishdurchlaufen haben. -
npm publishdurchlaufen haben.@StrathCole ja, schon gesehen, aber ich wollte npm eigentlich erst mal vermeiden :-( werde es für die Lib aber wohl trotzdem schon machen müssen.
@jpgorganizer Ja, hatte ich auch gemerkt, als ich etwas in ein Lib ausgelagert habe. Etwas umständlich. Beim publish musst du auch beachten, dass du
npm publish --access publicmachst, weil du sonst für private Projekte was Kostenpflichtiges brauchst. Habe ich ne Weile gebraucht, das zu finden. Bei den Adaptern ging es ohne. -
so, wieder Feuer frei - Abhängigkeit der Lib kann nun aufgelöst werden.
die aktuelle Version ist nun die 0.4.1
weiterhin die Notes von der 0.4.0 beachten0.4.1
- (jpgorganizer)
- Dependency get's resolved now
0.4.0
- (jpgorganizer)
npm install https://github.com/jpgorganizer/ioBroker.utilsornpm i @jpgorganizer/utils - NOTE: you must delete all states of the adapter instance to install this release and please check your application carefully for necessary adjustments regarding type/role changes (see below)
- datapoint
- input field for
@jpgorganizer Möchtest du grundsätzlich auch Pull Requests bekommen oder lieber erst mal alles allein bauen, wenn wir Ideen haben?
@StrathCole sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
eigentlich wäre es mir lieber, wenn ich Dinge selbst einbaue. Ggfs. komme ich gerne drauf zurück. Danke für's Angebot.
Ideen am besten hier diskutieren oder gleich als Issue in github anlegen. Je nachdem, wie genau die Idee schon vorliegt.
jpgorganizer -
Super Adapter! Danke.
Feedback: Sensor gibt keine der Messdaten an den Adapter. Bodenfeuchte, Temperatur, Helligkeit
@muckel sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
sowas ähnliches hat @dslraser auch schon gesagt. Ich habe keinen sensor, deshalb bin ich auf eurer Mitarbeit angewiesen.
Bitte macht mal in der Instance Konfig den Loglevel auf 3 und startet dann den Adaper und lasst mir mal den gesamten Log zukommen.
jpgorganizer -
- (jpgorganizer)
0.4.0
- (jpgorganizer)
- datapoint
- input field for
jpgorganizer@jpgorganizer sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
ich mache jetzt schon eine ganze Weile rum, aber ich bekomme den Adapter nicht mehr grün.
undefined2020-03-31 17:14:50.156 - info: host.iobroker "system.adapter.smartgarden.0" disabled 2020-03-31 17:14:50.156 - info: host.iobroker stopInstance system.adapter.smartgarden.0 (force=false, process=true) 2020-03-31 17:14:50.160 - info: smartgarden.0 (906) Got terminate signal TERMINATE_YOURSELF 2020-03-31 17:14:50.162 - info: smartgarden.0 (906) terminating 2020-03-31 17:14:50.162 - info: smartgarden.0 (906) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason 2020-03-31 17:14:50.157 - info: host.iobroker stopInstance system.adapter.smartgarden.0 send kill signal 2020-03-31 17:14:50.687 - info: host.iobroker instance system.adapter.smartgarden.0 terminated with code 156 (156) 2020-03-31 17:14:52.239 - info: host.iobroker "system.adapter.smartgarden.0" enabled 2020-03-31 17:14:52.259 - info: host.iobroker instance system.adapter.smartgarden.0 started with pid 921 2020-03-31 17:14:53.979 - info: smartgarden.0 (921) starting. Version 0.4.1 in /opt/iobroker/node_modules/iobroker.smartgarden, node: v10.19.0 2020-03-31 17:14:54.016 - info: smartgarden.0 (921) sgSetState: info.revision Main: 2010 / API: 2010 2020-03-31 17:14:54.018 - info: smartgarden.0 (921) Gardena Smart System Service hosts at: smart_host: https://api.smart.gardena.dev authentication_host: https://api.authentication.husqvarnagroup.dev 2020-03-31 17:14:54.336 - info: smartgarden.0 (921) Connection: successful: response.statusCode / statusMessage=200 / OK 2020-03-31 17:14:54.337 - info: smartgarden.0 (921) sgSetState: info.connection true 2020-03-31 17:14:54.339 - info: smartgarden.0 (921) get_locations ... 2020-03-31 17:14:54.486 - error: smartgarden.0 (921) Error: getlocations: no data - (jpgorganizer)
undefined2020-03-31 17:14:50.156 - info: host.iobroker "system.adapter.smartgarden.0" disabled 2020-03-31 17:14:50.156 - info: host.iobroker stopInstance system.adapter.smartgarden.0 (force=false, process=true) 2020-03-31 17:14:50.160 - info: smartgarden.0 (906) Got terminate signal TERMINATE_YOURSELF 2020-03-31 17:14:50.162 - info: smartgarden.0 (906) terminating 2020-03-31 17:14:50.162 - info: smartgarden.0 (906) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason 2020-03-31 17:14:50.157 - info: host.iobroker stopInstance system.adapter.smartgarden.0 send kill signal 2020-03-31 17:14:50.687 - info: host.iobroker instance system.adapter.smartgarden.0 terminated with code 156 (156) 2020-03-31 17:14:52.239 - info: host.iobroker "system.adapter.smartgarden.0" enabled 2020-03-31 17:14:52.259 - info: host.iobroker instance system.adapter.smartgarden.0 started with pid 921 2020-03-31 17:14:53.979 - info: smartgarden.0 (921) starting. Version 0.4.1 in /opt/iobroker/node_modules/iobroker.smartgarden, node: v10.19.0 2020-03-31 17:14:54.016 - info: smartgarden.0 (921) sgSetState: info.revision Main: 2010 / API: 2010 2020-03-31 17:14:54.018 - info: smartgarden.0 (921) Gardena Smart System Service hosts at: smart_host: https://api.smart.gardena.dev authentication_host: https://api.authentication.husqvarnagroup.dev 2020-03-31 17:14:54.336 - info: smartgarden.0 (921) Connection: successful: response.statusCode / statusMessage=200 / OK 2020-03-31 17:14:54.337 - info: smartgarden.0 (921) sgSetState: info.connection true 2020-03-31 17:14:54.339 - info: smartgarden.0 (921) get_locations ... 2020-03-31 17:14:54.486 - error: smartgarden.0 (921) Error: getlocations: no data@dslraser sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
Der Fehler kommt, nach dem Einloggen und wenn er dann keine Geräte von der Schnittstelle gemeldet bekommt.
Prüfe nochmals die Gardena Account Daten und auch den API-Key. Hast du vielleicht zwei Gardena Accounts? 1x mit und 1x ohne Geräte?
jpgorganizer -
Grüßealles schon mehrfach geprüft. Und nein, ich habe nur einen Account. Im Browser kann ich mich genau mit diesen Daten anmelden. ApI-Key passt auch.
jpgorganizerIch habe jetzt den API-Key gelöscht und neu erstellt. Damit wird der Adapter nun wieder grün.
das muss man nicht verstehen ??? würde ich aber gerne
Das müssen wir beobachten, ob sowas öfter vorkommt. Danke für die Rückmeldung.
jpgorganizer -
jpgorganizerSo, mein Blockly brauchte ich kaum ändern, läuft mit der 0.4.1 immer noch (nur den Stop aller Ventile habe ich im Blockly geändert. Der DP .stop_all_valves_i mit STOP_UNTIL_NEXT_TASK funktioniert nun
Bis auf die Sensordaten ist alles okay. Da warte ich mal noch etwas ab, da diese Daten nicht ständig übertragen werden. Im Moment ist es leer.
jpgorganizerHier der gewünschte log
smartgarden.0 2020-03-31 18:08:15.797 info (11408) sgSetState: sg.0.L_504a.D_7332.S_COMMON_7332.rfLinkState_value ONLINE smartgarden.0 2020-03-31 18:08:15.796 info (11408) sgSetState: sg.0.L_504a.D_7332.S_COMMON_7332.modelType_value GARDENA smart Irrigation Control smartgarden.0 2020-03-31 18:08:15.796 info (11408) sgSetState: sg.0.L_504a.D_7332.S_COMMON_7332.serial_value 00001393 smartgarden.0 2020-03-31 18:08:15.796 info (11408) sgSetState: sg.0.L_504a.D_7332.S_COMMON_7332.rfLinkLevel_timestamp 2020-03-31T15:30:10.995+0000 smartgarden.0 2020-03-31 18:08:15.795 info (11408) sgSetState: sg.0.L_504a.D_7332.S_COMMON_7332.rfLinkLevel_value 60 smartgarden.0 2020-03-31 18:08:15.795 info (11408) sgSetState: sg.0.L_504a.D_7332.S_COMMON_7332.batteryState_value NO_BATTERY smartgarden.0 2020-03-31 18:08:15.794 info (11408) sgSetState: sg.0.L_504a.D_7332.S_COMMON_7332.name_value Bewässerungsteuerung Garten smartgarden.0 2020-03-31 18:08:15.794 info (11408) setServiceStates: smartgarden.0.LOCATION_5a66f03f-74db-4fa0-9e61-38bbded6504a.DEVICE_d2bf229d-d6a9-46d1-98ea-10f3379c7332.SERVICE_COMMON_d2bf229d-d6a9-46d1-98ea-10f3379c7332 smartgarden.0 2020-03-31 18:08:15.791 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:6.lastErrorCode_timestamp 2019-08-31T05:50:16.873+0000 smartgarden.0 2020-03-31 18:08:15.791 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:6.lastErrorCode_value NO_MESSAGE smartgarden.0 2020-03-31 18:08:15.790 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:6.state_timestamp 2019-08-31T05:50:21.319+0000 smartgarden.0 2020-03-31 18:08:15.790 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:6.state_value UNAVAILABLE smartgarden.0 2020-03-31 18:08:15.790 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:6.activity_timestamp 2019-08-31T05:50:16.781+0000 smartgarden.0 2020-03-31 18:08:15.789 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:6.duration_value null smartgarden.0 2020-03-31 18:08:15.789 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:6.duration_timestamp smartgarden.0 2020-03-31 18:08:15.788 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:6.duration_leftover_i null smartgarden.0 2020-03-31 18:08:15.788 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:6.activity_value CLOSED smartgarden.0 2020-03-31 18:08:15.788 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:6.name_value Valve 6 smartgarden.0 2020-03-31 18:08:15.787 info (11408) setServiceStates: smartgarden.0.LOCATION_5a66f03f-74db-4fa0-9e61-38bbded6504a.DEVICE_d2bf229d-d6a9-46d1-98ea-10f3379c7332.SERVICE_VALVE_d2bf229d-d6a9-46d1-98ea-10f3379c7332%3A6 smartgarden.0 2020-03-31 18:08:15.786 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:5.lastErrorCode_timestamp 2019-08-31T05:50:16.863+0000 smartgarden.0 2020-03-31 18:08:15.785 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:5.lastErrorCode_value NO_MESSAGE smartgarden.0 2020-03-31 18:08:15.785 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:5.state_timestamp 2019-08-31T05:50:21.319+0000 smartgarden.0 2020-03-31 18:08:15.784 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:5.state_value UNAVAILABLE smartgarden.0 2020-03-31 18:08:15.784 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:5.activity_timestamp 2019-08-31T05:50:16.765+0000 smartgarden.0 2020-03-31 18:08:15.783 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:5.duration_value null smartgarden.0 2020-03-31 18:08:15.783 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:5.duration_timestamp smartgarden.0 2020-03-31 18:08:15.783 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:5.duration_leftover_i null smartgarden.0 2020-03-31 18:08:15.782 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:5.activity_value CLOSED smartgarden.0 2020-03-31 18:08:15.782 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:5.name_value Valve 5 smartgarden.0 2020-03-31 18:08:15.781 info (11408) setServiceStates: smartgarden.0.LOCATION_5a66f03f-74db-4fa0-9e61-38bbded6504a.DEVICE_d2bf229d-d6a9-46d1-98ea-10f3379c7332.SERVICE_VALVE_d2bf229d-d6a9-46d1-98ea-10f3379c7332%3A5 smartgarden.0 2020-03-31 18:08:15.778 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:4.lastErrorCode_timestamp 2019-08-31T05:50:16.855+0000 smartgarden.0 2020-03-31 18:08:15.776 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:4.lastErrorCode_value NO_MESSAGE smartgarden.0 2020-03-31 18:08:15.775 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:4.state_timestamp 2019-08-31T05:50:21.319+0000 smartgarden.0 2020-03-31 18:08:15.775 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:4.state_value OK smartgarden.0 2020-03-31 18:08:15.774 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:4.activity_timestamp 2019-10-20T03:59:57.087+0000 smartgarden.0 2020-03-31 18:08:15.774 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:4.duration_value null smartgarden.0 2020-03-31 18:08:15.773 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:4.duration_timestamp smartgarden.0 2020-03-31 18:08:15.773 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:4.duration_leftover_i null smartgarden.0 2020-03-31 18:08:15.772 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:4.activity_value CLOSED smartgarden.0 2020-03-31 18:08:15.772 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:4.name_value Rasensprenger smartgarden.0 2020-03-31 18:08:15.771 info (11408) setServiceStates: smartgarden.0.LOCATION_5a66f03f-74db-4fa0-9e61-38bbded6504a.DEVICE_d2bf229d-d6a9-46d1-98ea-10f3379c7332.SERVICE_VALVE_d2bf229d-d6a9-46d1-98ea-10f3379c7332%3A4 smartgarden.0 2020-03-31 18:08:15.770 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:3.lastErrorCode_timestamp 2019-08-31T05:50:16.847+0000 smartgarden.0 2020-03-31 18:08:15.769 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:3.lastErrorCode_value NO_MESSAGE smartgarden.0 2020-03-31 18:08:15.769 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:3.state_timestamp 2019-08-31T05:50:21.319+0000 smartgarden.0 2020-03-31 18:08:15.768 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:3.state_value OK smartgarden.0 2020-03-31 18:08:15.768 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:3.activity_timestamp 2019-10-20T04:59:57.085+0000 smartgarden.0 2020-03-31 18:08:15.767 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:3.duration_value null smartgarden.0 2020-03-31 18:08:15.767 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:3.duration_timestamp smartgarden.0 2020-03-31 18:08:15.767 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:3.duration_leftover_i null smartgarden.0 2020-03-31 18:08:15.766 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:3.activity_value CLOSED smartgarden.0 2020-03-31 18:08:15.766 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:3.name_value Böschung und Hochbeet smartgarden.0 2020-03-31 18:08:15.765 info (11408) setServiceStates: smartgarden.0.LOCATION_5a66f03f-74db-4fa0-9e61-38bbded6504a.DEVICE_d2bf229d-d6a9-46d1-98ea-10f3379c7332.SERVICE_VALVE_d2bf229d-d6a9-46d1-98ea-10f3379c7332%3A3 smartgarden.0 2020-03-31 18:08:15.762 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:2.lastErrorCode_timestamp 2019-08-31T05:50:16.840+0000 smartgarden.0 2020-03-31 18:08:15.761 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:2.lastErrorCode_value NO_MESSAGE smartgarden.0 2020-03-31 18:08:15.761 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:2.state_timestamp 2019-08-31T05:50:21.319+0000 smartgarden.0 2020-03-31 18:08:15.760 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:2.state_value OK smartgarden.0 2020-03-31 18:08:15.760 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:2.activity_timestamp 2019-10-20T04:29:57.132+0000 smartgarden.0 2020-03-31 18:08:15.759 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:2.duration_value null smartgarden.0 2020-03-31 18:08:15.759 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:2.duration_timestamp smartgarden.0 2020-03-31 18:08:15.758 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:2.duration_leftover_i null smartgarden.0 2020-03-31 18:08:15.758 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:2.activity_value CLOSED smartgarden.0 2020-03-31 18:08:15.757 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:2.name_value Zaun- und Kiwibeet smartgarden.0 2020-03-31 18:08:15.756 info (11408) setServiceStates: smartgarden.0.LOCATION_5a66f03f-74db-4fa0-9e61-38bbded6504a.DEVICE_d2bf229d-d6a9-46d1-98ea-10f3379c7332.SERVICE_VALVE_d2bf229d-d6a9-46d1-98ea-10f3379c7332%3A2 smartgarden.0 2020-03-31 18:08:15.715 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:1.lastErrorCode_timestamp 2019-08-31T05:50:16.833+0000 smartgarden.0 2020-03-31 18:08:15.714 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:1.lastErrorCode_value NO_MESSAGE smartgarden.0 2020-03-31 18:08:15.714 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:1.state_timestamp 2019-08-31T05:50:21.319+0000 smartgarden.0 2020-03-31 18:08:15.713 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:1.state_value OK smartgarden.0 2020-03-31 18:08:15.713 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:1.activity_timestamp 2019-10-20T02:59:57.008+0000 smartgarden.0 2020-03-31 18:08:15.712 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:1.duration_value null smartgarden.0 2020-03-31 18:08:15.712 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:1.duration_timestamp smartgarden.0 2020-03-31 18:08:15.711 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:1.duration_leftover_i null smartgarden.0 2020-03-31 18:08:15.710 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:1.activity_value CLOSED smartgarden.0 2020-03-31 18:08:15.710 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:1.name_value Himbeerbeet smartgarden.0 2020-03-31 18:08:15.709 info (11408) setServiceStates: smartgarden.0.LOCATION_5a66f03f-74db-4fa0-9e61-38bbded6504a.DEVICE_d2bf229d-d6a9-46d1-98ea-10f3379c7332.SERVICE_VALVE_d2bf229d-d6a9-46d1-98ea-10f3379c7332%3A1 smartgarden.0 2020-03-31 18:08:15.647 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_SET_7332.lastErrorCode_timestamp 2020-02-11T19:57:25.833+0000 smartgarden.0 2020-03-31 18:08:15.647 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_SET_7332.lastErrorCode_value NO_MESSAGE smartgarden.0 2020-03-31 18:08:15.646 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_SET_7332.state_timestamp 2020-02-11T19:57:25.833+0000 smartgarden.0 2020-03-31 18:08:15.646 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_SET_7332.stop_all_valves_i null smartgarden.0 2020-03-31 18:08:15.645 info (11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_SET_7332.state_value OK smartgarden.0 2020-03-31 18:08:15.645 info (11408) setServiceStates: smartgarden.0.LOCATION_5a66f03f-74db-4fa0-9e61-38bbded6504a.DEVICE_d2bf229d-d6a9-46d1-98ea-10f3379c7332.SERVICE_VALVE_SET_d2bf229d-d6a9-46d1-98ea-10f3379c7332 smartgarden.0 2020-03-31 18:08:15.642 info (11408) sgSetState: sg.0.L_504a.D_c63b.S_COMMON_c63b.rfLinkState_value ONLINE smartgarden.0 2020-03-31 18:08:15.642 info (11408) sgSetState: sg.0.L_504a.D_c63b.S_COMMON_c63b.modelType_value GARDENA smart Sensor smartgarden.0 2020-03-31 18:08:15.641 info (11408) sgSetState: sg.0.L_504a.D_c63b.S_COMMON_c63b.serial_value 00003256 smartgarden.0 2020-03-31 18:08:15.641 info (11408) sgSetState: sg.0.L_504a.D_c63b.S_COMMON_c63b.rfLinkLevel_timestamp 2020-03-31T15:43:17.925+0000 smartgarden.0 2020-03-31 18:08:15.640 info (11408) sgSetState: sg.0.L_504a.D_c63b.S_COMMON_c63b.rfLinkLevel_value 30 smartgarden.0 2020-03-31 18:08:15.640 info (11408) sgSetState: sg.0.L_504a.D_c63b.S_COMMON_c63b.batteryState_timestamp 2020-03-30T21:10:41.910+0000 smartgarden.0 2020-03-31 18:08:15.639 info (11408) sgSetState: sg.0.L_504a.D_c63b.S_COMMON_c63b.batteryState_value OK smartgarden.0 2020-03-31 18:08:15.639 info (11408) sgSetState: sg.0.L_504a.D_c63b.S_COMMON_c63b.batteryLevel_timestamp 2020-03-30T21:10:41.910+0000 smartgarden.0 2020-03-31 18:08:15.638 info (11408) sgSetState: sg.0.L_504a.D_c63b.S_COMMON_c63b.batteryLevel_value 95 smartgarden.0 2020-03-31 18:08:15.638 info (11408) sgSetState: sg.0.L_504a.D_c63b.S_COMMON_c63b.name_value Sensor smartgarden.0 2020-03-31 18:08:15.637 info (11408) setServiceStates: smartgarden.0.LOCATION_5a66f03f-74db-4fa0-9e61-38bbded6504a.DEVICE_c5a76528-97d2-4816-9c90-9589f0fac63b.SERVICE_COMMON_c5a76528-97d2-4816-9c90-9589f0fac63b smartgarden.0 2020-03-31 18:08:15.636 info (11408) sgSetState: sg.0.L_504a.D_b6a2.S_COMMON_b6a2.rfLinkState_value ONLINE smartgarden.0 2020-03-31 18:08:15.636 info (11408) sgSetState: sg.0.L_504a.D_b6a2.S_COMMON_b6a2.modelType_value GARDENA smart Mower smartgarden.0 2020-03-31 18:08:15.635 info (11408) sgSetState: sg.0.L_504a.D_b6a2.S_COMMON_b6a2.serial_value 00008016 smartgarden.0 2020-03-31 18:08:15.635 info (11408) sgSetState: sg.0.L_504a.D_b6a2.S_COMMON_b6a2.rfLinkLevel_timestamp 2020-03-30T21:12:42.678+0000 smartgarden.0 2020-03-31 18:08:15.634 info (11408) sgSetState: sg.0.L_504a.D_b6a2.S_COMMON_b6a2.rfLinkLevel_value 70 smartgarden.0 2020-03-31 18:08:15.634 info (11408) sgSetState: sg.0.L_504a.D_b6a2.S_COMMON_b6a2.batteryState_timestamp 2020-03-30T22:00:42.625+0000 smartgarden.0 2020-03-31 18:08:15.633 info (11408) sgSetState: sg.0.L_504a.D_b6a2.S_COMMON_b6a2.batteryState_value OK smartgarden.0 2020-03-31 18:08:15.633 info (11408) sgSetState: sg.0.L_504a.D_b6a2.S_COMMON_b6a2.batteryLevel_timestamp 2020-03-30T22:00:42.625+0000 smartgarden.0 2020-03-31 18:08:15.632 info (11408) sgSetState: sg.0.L_504a.D_b6a2.S_COMMON_b6a2.batteryLevel_value 100 smartgarden.0 2020-03-31 18:08:15.632 info (11408) sgSetState: sg.0.L_504a.D_b6a2.S_COMMON_b6a2.name_value Tussi smartgarden.0 2020-03-31 18:08:15.631 info (11408) setServiceStates: smartgarden.0.LOCATION_5a66f03f-74db-4fa0-9e61-38bbded6504a.DEVICE_7044cd9e-41d2-4466-886e-d8786903b6a2.SERVICE_COMMON_7044cd9e-41d2-4466-886e-d8786903b6a2 smartgarden.0 2020-03-31 18:08:15.628 info (11408) sgSetState: sg.0.L_504a.D_b6a2.S_MOWER_b6a2.operatingHours_value 1159 smartgarden.0 2020-03-31 18:08:15.627 info (11408) sgSetState: sg.0.L_504a.D_b6a2.S_MOWER_b6a2.activity_timestamp 2020-03-31T15:16:56.719+0000 smartgarden.0 2020-03-31 18:08:15.627 info (11408) sgSetState: sg.0.L_504a.D_b6a2.S_MOWER_b6a2.activity_control_i null smartgarden.0 2020-03-31 18:08:15.626 info (11408) sgSetState: sg.0.L_504a.D_b6a2.S_MOWER_b6a2.activity_mowing_i false smartgarden.0 2020-03-31 18:08:15.626 info (11408) sgSetState: sg.0.L_504a.D_b6a2.S_MOWER_b6a2.activity_value PARKED_PARK_SELECTED smartgarden.0 2020-03-31 18:08:15.625 info (11408) sgSetState: sg.0.L_504a.D_b6a2.S_MOWER_b6a2.state_timestamp 2020-03-31T15:16:56.719+0000 smartgarden.0 2020-03-31 18:08:15.624 info (11408) sgSetState: sg.0.L_504a.D_b6a2.S_MOWER_b6a2.state_value OK smartgarden.0 2020-03-31 18:08:15.624 info (11408) setServiceStates: smartgarden.0.LOCATION_5a66f03f-74db-4fa0-9e61-38bbded6504a.DEVICE_7044cd9e-41d2-4466-886e-d8786903b6a2.SERVICE_MOWER_7044cd9e-41d2-4466-886e-d8786903b6a2 smartgarden.0 2020-03-31 18:08:15.607 info (11408) sgSetState: sg.0.L_504a.D_9a5d.S_COMMON_9a5d.rfLinkState_value ONLINE smartgarden.0 2020-03-31 18:08:15.606 info (11408) sgSetState: sg.0.L_504a.D_9a5d.S_COMMON_9a5d.modelType_value GARDENA smart Water Control smartgarden.0 2020-03-31 18:08:15.606 info (11408) sgSetState: sg.0.L_504a.D_9a5d.S_COMMON_9a5d.serial_value 00031728 smartgarden.0 2020-03-31 18:08:15.605 info (11408) sgSetState: sg.0.L_504a.D_9a5d.S_COMMON_9a5d.rfLinkLevel_timestamp 2020-03-31T15:59:51.659+0000 smartgarden.0 2020-03-31 18:08:15.605 info (11408) sgSetState: sg.0.L_504a.D_9a5d.S_COMMON_9a5d.rfLinkLevel_value 70 smartgarden.0 2020-03-31 18:08:15.604 info (11408) sgSetState: sg.0.L_504a.D_9a5d.S_COMMON_9a5d.batteryState_timestamp 2020-03-31T15:59:51.602+0000 smartgarden.0 2020-03-31 18:08:15.604 info (11408) sgSetState: sg.0.L_504a.D_9a5d.S_COMMON_9a5d.batteryState_value OUT_OF_OPERATION smartgarden.0 2020-03-31 18:08:15.603 info (11408) sgSetState: sg.0.L_504a.D_9a5d.S_COMMON_9a5d.batteryLevel_timestamp 2020-03-31T15:59:51.636+0000 smartgarden.0 2020-03-31 18:08:15.603 info (11408) sgSetState: sg.0.L_504a.D_9a5d.S_COMMON_9a5d.batteryLevel_value 0 smartgarden.0 2020-03-31 18:08:15.602 info (11408) sgSetState: sg.0.L_504a.D_9a5d.S_COMMON_9a5d.name_value Blumenbeet Straße smartgarden.0 2020-03-31 18:08:15.601 info (11408) setServiceStates: smartgarden.0.LOCATION_5a66f03f-74db-4fa0-9e61-38bbded6504a.DEVICE_2512c1ce-5226-414b-8ea3-b61fe40c9a5d.SERVICE_COMMON_2512c1ce-5226-414b-8ea3-b61fe40c9a5d smartgarden.0 2020-03-31 18:08:15.555 info (11408) sgSetState: sg.0.L_504a.D_9a5d.S_VALVE_9a5d.state_value OK smartgarden.0 2020-03-31 18:08:15.555 info (11408) sgSetState: sg.0.L_504a.D_9a5d.S_VALVE_9a5d.activity_timestamp 2020-03-30T22:59:59.184+0000 smartgarden.0 2020-03-31 18:08:15.554 info (11408) sgSetState: sg.0.L_504a.D_9a5d.S_VALVE_9a5d.duration_value null smartgarden.0 2020-03-31 18:08:15.554 info (11408) sgSetState: sg.0.L_504a.D_9a5d.S_VALVE_9a5d.duration_timestamp smartgarden.0 2020-03-31 18:08:15.553 info (11408) sgSetState: sg.0.L_504a.D_9a5d.S_VALVE_9a5d.duration_leftover_i null smartgarden.0 2020-03-31 18:08:15.553 info (11408) sgSetState: sg.0.L_504a.D_9a5d.S_VALVE_9a5d.activity_value CLOSED smartgarden.0 2020-03-31 18:08:15.552 info (11408) sgSetState: sg.0.L_504a.D_9a5d.S_VALVE_9a5d.name_value Blumenbeet Straße smartgarden.0 2020-03-31 18:08:15.551 info (11408) setServiceStates: smartgarden.0.LOCATION_5a66f03f-74db-4fa0-9e61-38bbded6504a.DEVICE_2512c1ce-5226-414b-8ea3-b61fe40c9a5d.SERVICE_VALVE_2512c1ce-5226-414b-8ea3-b61fe40c9a5d smartgarden.0 2020-03-31 18:08:15.549 info (11408) setServiceStates: smartgarden.0.LOCATION_5a66f03f-74db-4fa0-9e61-38bbded6504a.DEVICE_2512c1ce-5226-414b-8ea3-b61fe40c9a5d.SERVICE_VALVE_SET_2512c1ce-5226-414b-8ea3-b61fe40c9a5d%3Awc smartgarden.0 2020-03-31 18:08:15.465 info (11408) parseMessage: COMMON found smartgarden.0 2020-03-31 18:08:15.464 info (11408) parseMessage: VALVE found smartgarden.0 2020-03-31 18:08:15.464 info (11408) parseMessage: VALVE found smartgarden.0 2020-03-31 18:08:15.463 info (11408) parseMessage: VALVE found smartgarden.0 2020-03-31 18:08:15.462 info (11408) parseMessage: VALVE found smartgarden.0 2020-03-31 18:08:15.461 info (11408) parseMessage: VALVE found smartgarden.0 2020-03-31 18:08:15.460 info (11408) parseMessage: VALVE found smartgarden.0 2020-03-31 18:08:15.420 info (11408) parseMessage: VALVE_SET found smartgarden.0 2020-03-31 18:08:15.419 info (11408) parseMessage: COMMON found smartgarden.0 2020-03-31 18:08:15.419 info (11408) parseMessage: Unknown message found smartgarden.0 2020-03-31 18:08:15.418 info (11408) parseMessage: COMMON found smartgarden.0 2020-03-31 18:08:15.417 info (11408) parseMessage: MOWER found smartgarden.0 2020-03-31 18:08:15.416 info (11408) parseMessage: COMMON found smartgarden.0 2020-03-31 18:08:15.413 info (11408) parseMessage: VALVE found smartgarden.0 2020-03-31 18:08:15.411 info (11408) parseMessage: VALVE_SET found smartgarden.0 2020-03-31 18:08:15.409 info (11408) parseMessage: DEVICE found smartgarden.0 2020-03-31 18:08:15.408 info (11408) parseMessage: DEVICE found smartgarden.0 2020-03-31 18:08:15.406 info (11408) parseMessage: DEVICE found smartgarden.0 2020-03-31 18:08:15.404 info (11408) parseMessage: DEVICE found smartgarden.0 2020-03-31 18:08:15.400 info (11408) sgSetState: L_504a.name My Garden smartgarden.0 2020-03-31 18:08:15.400 info (11408) parseMessage: LOCATION found smartgarden.0 2020-03-31 18:08:13.220 info (11408) on_open: ### connected ### smartgarden.0 2020-03-31 18:08:12.332 info (11408) get_websocket ... smartgarden.0 2020-03-31 18:08:12.330 info (11408) get_locations: successful / response.statusMessage: OK smartgarden.0 2020-03-31 18:08:11.768 info (11408) get_locations ... smartgarden.0 2020-03-31 18:08:11.766 info (11408) sgSetState: info.connection true smartgarden.0 2020-03-31 18:08:11.765 info (11408) Connection: successful: response.statusCode / statusMessage=200 / OK smartgarden.0 2020-03-31 18:08:11.230 info (11408) Gardena Smart System Service hosts at: smart_host: https://api.smart.gardena.dev authentication_host: https://api.authentication.husqvarnagroup.dev smartgarden.0 2020-03-31 18:08:11.229 info (11408) sgSetState: info.revision Main: 2010 / API: 2010 smartgarden.0 2020-03-31 18:08:11.209 info (11408) starting. Version 0.4.1 in /opt/iobroker/node_modules/iobroker.smartgarden, node: v10.16.0 host.SmartHome 2020-03-31 18:08:09.927 info instance system.adapter.smartgarden.0 started with pid 11408 host.SmartHome 2020-03-31 18:08:09.905 info "system.adapter.smartgarden.0" enabled host.SmartHome 2020-03-31 18:08:05.075 info instance system.adapter.smartgarden.0 terminated with code 156 (156) smartgarden.0 2020-03-31 18:08:04.553 info (1661) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason smartgarden.0 2020-03-31 18:08:04.553 info (1661) terminating smartgarden.0 2020-03-31 18:08:04.552 info (1661) Got terminate signal TERMINATE_YOURSELF -
@jpgorganizer
Bei mir werden auch die Datenpunkte nicht angelegt, bei @dslraser schon.
schau mal bei den Datenpunkten unter
DEVICE_c5a76528-97d2-4816-9c90-9589f0fac63b.SERVICE_COMMON_c5a76528-97d2-4816-9c90-9589f0fac63bkannst du da mal einen Screenshot machen, was da so dabei ist. Und ist unter dem Device noch ein anderer Service (SERVICE_xxxxx)?
jpgorganizer
