  3. Einsteigerfragen
  4. Installation
  5. Troubleshooting NodeJS update
    apollon77A
nodejs 18nodejs update
504 Beiträge 60 Kommentatoren 265.7k Aufrufe 52 Beobachtet
    @habedere sagte in Troubleshooting NodeJS update:
    VIS möchte ich zukünftig evtl. schon nutzen...
    Mit Display an der gleichen Kiste?
    Ich würde das nochmal installieren, diesmal gleich in der Lite-Version, ohne X-Server und ohne CUPS.
    H
    H
    Habedere
    #104
    Neuer Versuch...
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 3 Model B Rev 1.2
    Architecture    : aarch64
    Docker          : false
    Virtualization  : none
    Distributor ID: Debian
    Description:    Debian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     20:04:34 up 50 min,  2 users,  load average: 0.30, 0.24, 0.30
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=51.5'C
    volt=1.2938V
    *** Time and Time Zones ***
                   Local time: Sun 2023-04-23 20:04:35 BST
               Universal time: Sun 2023-04-23 19:04:35 UTC
                     RTC time: n/a
                    Time zone: Europe/London (BST, +0100)
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    nulu
    /home/nulu
    nulu adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            909M        232M        452M        0.0K        224M        613M
    Swap:            99M         18M         81M
    Total:          1.0G        250M        533M
              909 M total memory
              232 M used memory
              122 M active memory
              233 M inactive memory
              452 M free memory
               24 M buffer memory
              200 M swap cache
               99 M total swap
               18 M used swap
               81 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4      110G  2.3G  104G   3% /
    devtmpfs       devtmpfs  325M     0  325M   0% /dev
    tmpfs          tmpfs     455M     0  455M   0% /dev/shm
    tmpfs          tmpfs     182M  1.1M  181M   1% /run
    /dev/sda1      vfat      255M   31M  225M  12% /boot
    tmpfs          tmpfs      91M     0   91M   0% /run/user/1000
    [Sun Apr 23 19:13:56 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=e2d113b0-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Sun Apr 23 19:14:02 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
    [Sun Apr 23 19:14:02 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Sun Apr 23 19:14:06 2023] EXT4-fs (sda2): re-mounted. Opts: (null). Quota mode: none.
    TARGET  SOURCE    FSTYPE OPTIONS
    /       /dev/sda2 ext4   rw,noatime
    `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    458M    /var/
    179M    /var/cache
    173M    /var/cache/apt
    147M    /var/lib
    122M    /var/lib/apt/lists
    Archived and active journals take up 32.0M in the file system.
    /opt/iobroker/backups:
    4.0K    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    15M     /opt/iobroker/iobroker-data/files
    13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
    1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
    652K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
    384K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.16.0
    /usr/bin/node           v18.16.0
    /usr/bin/npm            9.5.1
    /usr/bin/npx            9.5.1
    nodejs:
      Installed: 18.16.0-deb-1nodesource1
      Candidate: 18.16.0-deb-1nodesource1
      Version table:
     *** 18.16.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
         12.22.5~dfsg-2~11u1 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     "javascript" not found
    Adapters from github:   0
    Adapter State
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "backitup"     : 2.6.16   , installed 2.6.16
    Objects and States
    Objects:        142
    States:         104
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
    Reading package lists...
    Pending Updates: 19
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12940      821/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       32536      7399/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       32529      7399/iobroker.js-co
    tcp6       0      0 :::22                   :::*                    LISTEN      0          12942      821/sshd: /usr/sbin
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       31304      7481/io.admin.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14288      920/dhcpcd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11804      428/avahi-daemon: r
    udp        0      0 0.0.0.0:47649           0.0.0.0:*                           108        11806      428/avahi-daemon: r
    udp6       0      0 :::54407                :::*                                108        11807      428/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        11805      428/avahi-daemon: r
    2023-04-23 19:25:03.203  - info: host.raspberrypi hostname: raspberrypi, node: v18.16.0
    2023-04-23 19:25:03.206  - info: host.raspberrypi ip addresses: 192.168.178.3 fdc8:6d06:a691:4a6d:84c6:b886:6e48:f44e fe80::d47e:3b7d:8adc:4dd3
    2023-04-23 19:25:04.032  - info: host.raspberrypi connected to Objects and States
    2023-04-23 19:25:04.118  - info: host.raspberrypi Node.js version has changed from unknown to 18.16.0
    2023-04-23 19:25:04.231  - info: host.raspberrypi Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
    2023-04-23 19:25:04.292  - info: host.raspberrypi added notifications configuration of host
    2023-04-23 19:25:05.103  - info: host.raspberrypi 3 instances found
    2023-04-23 19:25:05.124  - info: host.raspberrypi starting 3 instances
    2023-04-23 19:25:05.241  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 7481
    2023-04-23 19:25:09.197  - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 7488
    2023-04-23 19:25:10.651  - info: admin.0 (7481) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v18.16.0, js-controller: 4.0.24
    2023-04-23 19:25:10.780  - info: admin.0 (7481) requesting all states
    2023-04-23 19:25:10.782  - info: admin.0 (7481) requesting all objects
    2023-04-23 19:25:11.389  - info: admin.0 (7481) received all objects
    2023-04-23 19:25:12.036  - info: admin.0 (7481) http server listening on port 8081
    2023-04-23 19:25:12.039  - info: admin.0 (7481) Use link "http://localhost:8081" to configure.
    2023-04-23 19:25:12.101  - info: admin.0 (7481) socket.io server listening on port 8081
    2023-04-23 19:25:12.257  - warn: admin.0 (7481) Repository cannot be read: Active repo - stable
    2023-04-23 19:25:12.262  - warn: admin.0 (7481) Active repository "stable" cannot be read
    2023-04-23 19:25:13.215  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 7516
    2023-04-23 19:25:14.316  - info: discovery.0 (7488) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.16.0, js-controller: 4.0.24
    2023-04-23 19:25:18.369  - info: backitup.0 (7516) starting. Version 2.6.16 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.16.0, js-controller: 4.0.24
    2023-04-23 19:25:18.629  - info: backitup.0 (7516) [iobroker] backup was activated at 02:40 every 1 day(s)
    2023-04-23 19:25:24.768  - info: admin.0 (7481) ==> Connected system.user.admin from ::ffff:192.168.178.10
    2023-04-23 19:25:44.524  - info: admin.0 (7481) ==> Connected system.user.admin from ::ffff:192.168.178.10
    • H Habedere
      Neuer Versuch...
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Docker          : false
      Release:        11
      Codename:       bullseye
      VERSION_ID="11"
      ID=debian
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      temp=51.5'C
      volt=1.2938V
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      nulu
      /home/nulu
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            99M         18M         81M
                909 M total memory
                232 M used memory
                122 M active memory
                452 M free memory
                 24 M buffer memory
                200 M swap cache
                 99 M total swap
                 18 M used swap
                 81 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      458M    /var/
      179M    /var/cache
      173M    /var/cache/apt
      147M    /var/lib
      /usr/bin/npm            9.5.1
      /usr/bin/npx            9.5.1
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.3.5
      Adapter State
      + instance is alive
      Objects and States
      Objects:        142
      States:         104
      Pending Updates: 19
      Thomas BraunT
      Thomas BraunT
      #105
      Zeitzone setzen.
      Pending Updates: 19
      System auf Stand halten.
      H 1 Antwort Letzte Antwort
        Zeitzone setzen.
        Pending Updates: 19
        H
        H
        Habedere
        schrieb am zuletzt editiert von Habedere
        #106
        Beides erledgit - also Zeit fürs Backup?
        Operatingsystem:        Debian GNU/Linux 11 (bullseye)
        Kernel:                 6.1.21-v8+
        Installation:           Native
        Timezone:               Europe/London (BST, +0100)
        User-ID:                1000
        X-Server:               false
        Pending OS-Updates:     0
        Pending iob updates:    0
        nulu@raspberrypi:~ $ date
        Sun 23 Apr 21:27:45 CEST 2023
        • H Habedere
          Kernel:                 6.1.21-v8+
          User-ID:                1000
          X-Server:               false
          Thomas BraunT
          Thomas BraunT
          #107
          @habedere
          Zeig nochmal einen Durchlauf von iob diag
          Summary reicht.
          • H Habedere
            Kernel:                 6.1.21-v8+
            User-ID:                1000
            X-Server:               false
            Thomas BraunT
            Thomas BraunT
            #108
            Wohnst du auf der Insel?
            H 2 Antworten Letzte Antwort
              H
              H
              Habedere
              #109
              ne sorry - war der Zeitversatz der ausgeführten Änderungen :)
              mach gerade nochmal iob diag neu...
              Dann sieht es sauber aus :)
                H
                H
                Habedere
                #110
                                     v.2023-04-16
                Kernel:                 6.1.21-v8+
                User-ID:                1000
                X-Server:               false
                Nodejs-Installation:    /usr/bin/nodejs         v18.16.0
                                        /usr/bin/npm            9.5.1
                                        /usr/bin/npx            9.5.1
                Recommended versions are nodejs 18.x.y and npm 9.x.y
                MEMORY:
                Mem:            909M        329M        142M        1.0M        437M        517M
                Swap:            99M          0B         99M
                Total:          1.0G        329M        242M
                Active iob-Instances:   4
                ioBroker Core:          js-controller           4.0.24
                                        admin                   6.3.5
                Objects type: jsonl
                States  type: jsonl
                Objects:                142
                States:                 104
                Size of iob-Database:
                6.5M    /opt/iobroker/iobroker-data/objects.jsonl
                576K    /opt/iobroker/iobroker-data/states.jsonl
                • H Habedere
                                       v.2023-04-16
                  Kernel:                 6.1.21-v8+
                  User-ID:                1000
                  X-Server:               false
                                          /usr/bin/npm            9.5.1
                                          /usr/bin/npx            9.5.1
                  MEMORY:
                  Swap:            99M          0B         99M
                                          admin                   6.3.5
                  Objects type: jsonl
                  States  type: jsonl
                  Objects:                142
                  States:                 104
                  Thomas BraunT
                  Thomas BraunT
                  #111
                  @habedere
                  Ja, jetzt ist die Basis solide.
                    @habedere
                    H
                    H
                    Habedere
                    #112
                    Sehr schön - Danke!
                    Kurze Frage noch - wenn auch etwas OT.
                    Die MariaDB für den SQL Adapter muss ich nochmal extra installieren oder? Damit ioBroker das SQL Backup einspielen kann...
                    Oder macht der das gleich mit?!
                    • H Habedere
                      Sehr schön - Danke!
                      Thomas BraunT
                      Thomas BraunT
                      #113
                      Der iobroker kann keine Software-Pakete in das Basis-System einspielen. Jedenfalls nicht via Adapter-Installation. Also muss die Datenbank zuvor installiert werden.
                      • H
                        H
                        Habedere
                        #114
                        Danke - habe die MariaDB neu installiert.
                        Kurze Frage - kann es sein dass die neueste ioBroker Version + Adapter etc. mehr RAM benötigen?!
                        Ich laufe komplett auf Anschlag mit meinen 1GB - wüsste nicht dass es vorher auch so krass war...
                        *** MEMORY ***
                        Mem:            909M        745M         56M        0.0K        107M        107M
                        Swap:            99M         99M        0.0K
                        Total:          1.0G        844M         57M
                                  909 M total memory
                                  745 M used memory
                                  525 M active memory
                                  241 M inactive memory
                                   56 M free memory
                                    7 M buffer memory
                                   99 M swap cache
                                   99 M total swap
                                   99 M used swap
                                    0 M free swap
                        Raspberry only:
                        oom events: 0
                        Oder kann es sein nachdem ich das Backup eingespielt habe, dass da was doppelt läuft?
                        Hatte da heute noch diverse Probleme mit redis etc etc... Evtl. hab ich wieder gemurxt :(
                        • H Habedere
                          *** MEMORY ***
                          Swap:            99M         99M        0.0K
                                    909 M total memory
                                    745 M used memory
                                    525 M active memory
                                     56 M free memory
                                      7 M buffer memory
                                     99 M swap cache
                                     99 M total swap
                                     99 M used swap
                                      0 M free swap
                          Raspberry only:
                          oom events: 0
                          crunchipC
                          crunchipC
                          Developer Global Moderator Most Active Forum Testing
                          #115
                          @habedere natürlich können neuere Versionen auch mehr verbrauchen, alles in allem wird ja auch stehts verbessert und Leistungsstärker
                          1GB ist halt nun mal begrenzt geeignet
                            H
                            H
                            Habedere
                            #116
                            @crunchip sagte in Troubleshooting NodeJS update:
                            schlecht - hab nur 10 Adapter laufen und einige sonstige noch aus :)
                            Kann ich die SSD 1:1 an nen größeren Raspi hängen ohne den ganzen Mist von vorn installieren zu müssen?
                            • H Habedere
                              crunchipC
                              crunchipC
                              #117
                              @habedere Anzahl Adapter ist zweitrangig, kommt ja drauf an welche und wie viel dann der jeweilige Adapter verbrät.
                              Theoretisch sollte es klappen mit der SSD, bin mir da aber nicht 100% sicher.
                              • BananaJoeB
                                BananaJoeB
                                BananaJoe
                                #118
                                Ich habe gerade unter Ubuntu 22.04 von NodeJS Version 16 auf 18 geupgraded ...
                                Öhm, das war ja mal ganz schrecklich unspektakulär ... beim Wechsel von 14 auf 16 hat er jede Menge Adapter rebuilded - das fällt diesmal weg?
                                Gerade beim ZigBee-Adapter waren es letztes mal 2 Anläufe, jetzt startet der einfach wieder ...
                                • BananaJoeB BananaJoe
                                  Thomas BraunT
                                  Thomas BraunT
                                  #119
                                  @bananajoe sagte in Troubleshooting NodeJS update:
                                  Ist es das nicht in den überwiegenden Fällen eigentlich immer?
                                  • BananaJoeB
                                    BananaJoeB
                                    BananaJoe
                                    #120
                                    Ha, doch was gefunden:
                                    2023-05-03 20:54:58.621  - error: echarts.0 (12715) Cannot find required modules: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                                    was compiled against a different Node.js version using
                                    NODE_MODULE_VERSION 93. This version of Node.js requires
                                    NODE_MODULE_VERSION 108. Please try re-compiling or re-installing
                                    the module (for instance, using `npm rebuild` or `npm install`).
                                    2023-05-03 20:55:40.504  - error: echarts.0 (12715) Cannot find required modules: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                                    2023-05-03 20:55:42.236  - error: echarts.0 (12715) Cannot find required modules: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                                    2023-05-03 20:55:52.262  - info: javascript.0 (10419) script.js.001_Routinen.Solaranlage.Ertragsrechnung: exec: wget --output-document /tmp/Cam225Solaranlage.jpg 'http://192.168.1.225/cgi-bin/api.cgi?cmd=Snap&channel=0&rs=IchbineingeilerTypp&user=admin&password=znil2001'
                                    2023-05-03 20:55:52.274  - error: echarts.0 (12715) Cannot find required modules: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                                      Thomas BraunT
                                      Thomas BraunT
                                      #121
                                      @bananajoe
                                      Canvas sollte sich aber auch selber richten. Geduld...
                                        @bananajoe
                                        BananaJoeB
                                        BananaJoeB
                                        BananaJoe
                                        #122
                                        @thomas-braun ah, danke, war schon am suchen.
                                        Hatte schon beim Einrichten damals etwas suchen müssen bis canvas lief.
                                        Installiert sieht es richtig aus (meiner Bescheidenen Meinung nach)
                                        iobroker@iobroker:/opt/iobroker$ npm list canvas
                                        iobroker.inst@2.0.3 /opt/iobroker
                                        ├── canvas@2.11.2
                                        ├─┬ iobroker.echarts@1.4.14
                                        │ ├── canvas@2.11.2 deduped
                                        │ └─┬ jsdom@21.1.1
                                        │   └── canvas@2.11.2 deduped
                                        ├─┬ iobroker.energiefluss@3.6.0 (git+ssh://git@github.com/SKB-CGN/ioBroker.energiefluss.git#1b2f62380b39ac21b8a94853d76b4acf6c395111)
                                        └─┬ iobroker.iot@1.14.5
                                        • BananaJoeB
                                          BananaJoeB
                                          BananaJoe
                                          #123
                                          Man bin ich ungeduldig. Aber wie @Thomas-Braun geschrieben hat - Geduld.
                                          Der eCharts-Adapter ist einmal "abgestürzt" als ich versucht habe ein Diagramm zu senden, danach ging wieder,
                                          Ich hatte auf eine Log-Meldung zum Rebuild gehofft.
                                          84.0k
