  4. [HowTo] InfluxDB 2.1 auf Debian 11 (proxmox CT) installieren
131 Beiträge 23 Kommentatoren 61.6k Aufrufe 29 Beobachtet
  • lobomauL lobomau
    @lobomau leider habe ich doch Probleme mit InfluxDB2.x
    Wenn ich bestimmte Graphen aufrufe (flot oder echart) bekomme ich Warnungen, Fehler und der influxdb-container geht an seine CPU Grenze. Kann jemand damit etwas anfangen?
    influxdb.0
    2022-01-11 13:10:06.456	warn	Error in query "from(bucket: "Speicher") |> range(start: 2021-01-11T00:09:54.319Z, stop: 2022-01-11T00:09:54.319Z) |> filter(fn: (r) => r["_measurement"] == "proxmox.0.node_proxmox.cpu") |> pivot(rowKey:["_time"], columnKey: ["_field"], valueColumn: "_value") |> sort(columns: ["_time"], desc: true) |> group() |> limit(n: 1)": RequestTimedOutError: Request timed out
    influxdb.0
    2022-01-11 13:09:57.449	warn	Error in query "from(bucket: "Speicher") |> range(start: 2021-01-11T00:09:43.437Z, stop: 2022-01-11T00:09:43.437Z) |> filter(fn: (r) => r["_measurement"] == "linkeddevices.0.Leistung_PV-4000W.power") |> pivot(rowKey:["_time"], columnKey: ["_field"], valueColumn: "_value") |> sort(columns: ["_time"], desc: true) |> group() |> limit(n: 1)": RequestTimedOutError: Request timed out
    influxdb.0
    2022-01-11 13:21:53.792	error	Error: read ECONNRESET
    influxdb.0
    2022-01-11 13:21:52.952	error	RequestTimedOutError: Request timed out
    influxdb.0
    2022-01-11 13:21:39.892	error	RequestTimedOutError: Request timed out
    influxdb.0
    2022-01-11 13:21:26.878	error	getHistory: Error: 3 Error happened while processing 3 queries
    influxdb.0
    2022-01-11 13:21:26.462	error	getHistory: Error: 3 Error happened while processing 3 queries
    influxdb.0
    2022-01-11 13:21:25.166	error	getHistory: Error: 3 Error happened while processing 3 queries
    influxdb.0
    2022-01-11 13:21:19.879	error	Error during ping: RequestTimedOutError: Request timed out. Attempting reconnect.
    influxdb.0
    2022-01-11 13:21:17.204	error	getHistory: Error: 3 Error happened while processing 3 queries
    influxdb.0
    2022-01-11 13:21:15.474	error	getHistory: Error: 3 Error happened while processing 3 queries
    influxdb.0
    2022-01-11 13:21:13.517	error	getHistory: Error: 3 Error happened while processing 3 queries
    influxdb.0
    2022-01-11 13:21:10.540	error	getHistory: Error: 3 Error happened while processing 3 queries
    influxdb.0
    2022-01-11 13:21:10.051	error	getHistory: Error: 3 Error happened while processing 3 queries
    F
    F
    ftd
    @lobomau Kannst du die gleiche Abfrage mal in der Influx GUI starten? Wie lange dauert die?
    • F ftd
      lobomauL
      lobomauL
      lobomau
      @ftd werde ich gleich mal testen. Im Augenblick geht gar nix mehr. Influx nimmt was es kriegen kann an CPU. Ist seit paar Stunden so, komme grad nach Hause...
      top - 17:57:26 up 39 days,  3:27,  3 users,  load average: 156.61, 149.68, 142.3
      Tasks: 400 total,   1 running, 399 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.4 us, 25.4 sy,  0.0 ni,  0.0 id, 74.1 wa,  0.0 hi,  0.1 si,  0.0 st
      MiB Mem :   7813.9 total,    298.7 free,   6960.1 used,    555.1 buff/cache
      MiB Swap:   7168.0 total,   4583.1 free,   2584.9 used.    510.3 avail Mem
          PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
      3778649 100998    20   0 5575048   1.9g  23268 S 100.3  24.5 130:41.03 influxd
      3783114 root      20   0   10700   4432   3480 R   0.7   0.1   0:00.38 top
      3842149 101000    20   0  758568  56352  10836 S   0.7   0.7  28:54.91 io.syno+
      1233138 100108    20   0 3392572 377880   9380 S   0.3   4.7  57:21.34 java
      3181972 101000    20   0  951068  34604   8768 S   0.3   0.4   7:17.51 io.back+
            1 root      20   0  164588   8896   6480 S   0.0   0.1   0:42.85 systemd
            2 root      20   0       0      0      0 S   0.0   0.0   0:03.13 kthreadd
            3 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 rcu_gp
            4 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 rcu_par+
            6 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker+
            9 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 mm_perc+
           10 root      20   0       0      0      0 S   0.0   0.0   0:00.00 rcu_tas+
           11 root      20   0       0      0      0 S   0.0   0.0   0:00.00 rcu_tas+
           12 root      20   0       0      0      0 S   0.0   0.0  12:03.82 ksoftir+
      Host: NUC8i3 mit Proxmox:
      • Slave: Pi4
      • lobomauL lobomau
        Thomas BraunT
        Thomas BraunT
        Most Active Developer
        @lobomau sagte in [HowTo] InfluxDB 2.1 auf Debian 11 (proxmox CT) installieren:
        Das kannst du dir fast rahmen lassen. Selten so eine hohe Load gesehen.
        • SegwayS Segway
          @ftd sagte in [HowTo] InfluxDB 2.1 auf Debian 11 (proxmox CT) installieren:
          @docgame Ahh, moment...
          Du hast einen neuen Container erstellt. Du hast InfluxDB 2.x installiert. Du möchtest InfluxQL Syntax nutzen --> das funktioniert nicht
          Die neue native Syntax für eine neue Datenbank/Bucket in Influx 2.1 ist Flux. InfluxQL wird in 2.1 nicht mehr unterstützt.
          Im Prinzip hast du Recht aber würde die Hoffnung noch nicht aufgeben.
          Angeblich soll der Zugriff auch per InfluxQL klappen nur leider ist die Doku von Influx echt grauselig !
          Ich tüftle grad wie man das evtl hinbekommt :-)
          R
          R
          Rushmed
          @segway sagte in [HowTo] InfluxDB 2.1 auf Debian 11 (proxmox CT) installieren:
          Für mich ist das Umstellen aller Dashboards und auch das neu Anlegen echt mühselig. Gibts hier schon etwas Neues
          • Uli977U
            Uli977U
            Uli977
            ich möchte InfluxDB in einem ProxmoxCT installieren, bekomme aber folgende Meldung bei der Influxdb installation.
            apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8))
            Kann mir da jemand helfen, was zu tun ist?
            Viele Grüße!
            wendy2702W FredFF 2 Antworten Letzte Antwort
            • Uli977U Uli977
              Viele Grüße!
              wendy2702W
              wendy2702W
              @uli977 sagte in [HowTo] InfluxDB 2.1 auf Debian 11 (proxmox CT) installieren:
              Welches OS und nach welchem Befehl genau bzw. an welcher Stelle der Anleitung?
              Uli977U 1 Antwort Letzte Antwort
              • wendy2702W wendy2702
                Uli977U
                Uli977U
                Uli977
                @wendy2702
                Ubuntu 21.04
                Nach Eingabe dieses Befehls
                wget -qO- https://repos.influxdata.com/influxdb.key | sudo apt-key add -
                • Uli977U Uli977
                  @wendy2702
                  Ubuntu 21.04
                  wendy2702W
                  wendy2702W
                  Keine Ahnung woher du den hast.
                  Der steht weder auf Seite 1 dieser Anleitung noch in der offiziellen Influx Anleitung.
                  Das hier aus der Offiziellen Anleitung:
                  wget -qO- https://repos.influxdata.com/influxdb.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdb.gpg > /dev/null
                  export DISTRIB_ID=$(lsb_release -si); export DISTRIB_CODENAME=$(lsb_release -sc)
                  echo "deb [signed-by=/etc/apt/trusted.gpg.d/influxdb.gpg] https://repos.influxdata.com/${DISTRIB_ID,,} ${DISTRIB_CODENAME} stable" | sudo tee /etc/apt/sources.list.d/influxdb.list > /dev/null
                  sudo apt-get update && sudo apt-get install influxdb2
                  Ist das was auf Seite 1 beschrieben steht
                  Uli977U 3 Antworten Letzte Antwort
                    Uli977U
                    Uli977U
                    Uli977
                    @wendy2702
                    Hatte dies von der Seite verdrahtet.info
                    Danke, so wie von dir beschrieben geht es!
                    Danke! Danke!
                    • Uli977U Uli977
                      Viele Grüße!
                      FredFF
                      FredFF
                      FredF
                      Most Active Forum Testing
                      @uli977 Dieses Problem hatte ich gestern auch... Anscheinend kommt diese Fehlermeldung durch Debian 11. Mit Debian 10 hat es dann geklappt...
                      • FredFF FredF
                        wendy2702W
                        wendy2702W
                        #66
                        @fredf Sag bitte nicht du hast wegen der "Meldung" ein totes/sterbendes Pferd installiert?
                          FredFF
                          FredFF
                          FredF
                          schrieb am zuletzt editiert von FredF
                          #67
                          @wendy2702 Um zu sehen ob es daran liegt schon, habe aber noch keine Lösung nach mehreren erfolglosen gefunden...
                          Edit: Könnte es daran liegen, das ich noch auf proxmox 6 bin?
                            Uli977U
                            Uli977U
                            Uli977
                            schrieb am zuletzt editiert von Uli977
                            #68
                            @wendy2702
                            Gibt es noch ne Anleitung wie man die DB dann einrichtet und wie ich mit dem ioBroker dran komme?
                            Influxdb läuft in einem eigenen Container im proxmox und hat auch eine eigene IP..
                            • Uli977U Uli977
                              @wendy2702
                              wendy2702W
                              wendy2702W
                              #69
                              @uli977 https://github.com/ioBroker/ioBroker.influxdb
                              • FredFF FredF
                                wendy2702W
                                wendy2702W
                                #70
                                @fredf Liegt am verwendeten OS im Container.
                                  Uli977U
                                  Uli977U
                                  Uli977
                                  #71
                                  @wendy2702
                                  irgendwie komme ich nicht mittels eingabe "influx" in das UI....
                                  • Uli977U Uli977
                                    @wendy2702
                                    wendy2702W
                                    wendy2702W
                                    #72
                                    @uli977 Hat sich glaube ich zu Influx 2.x geändert:
                                    https://docs.influxdata.com/influxdb/v2.1/reference/cli/influx/
                                    • Uli977U Uli977
                                      @wendy2702
                                      FredFF
                                      FredFF
                                      FredF
                                      #73
                                      @wendy2702
                                      influx setup
                                      • Uli977U
                                        Uli977U
                                        Uli977
                                        #74
                                        Danke Euch InfluxDB läuft und hat Verbindung mit dem ioBroker.....
                                        Ich mach mal weiter und schaue wie es dann so klappt im Grafana.
                                          Uli977U
                                          Uli977U
                                          Uli977
                                          #75
                                          @wendy2702
                                          ich habe die Daten in InfluxDB, das ist schonmal gut.
                                          Der ioBroker, spielt also seine Daten schonmal in die Datenbank.
                                          Aber ich bekomme sie nicht in Grafana
                                          InfluxDB und Grafana laufen auf dem gleichen Server, deshalb localhost
                                          Woran kann es liegen?
                                          Zugangsdaten, am User oder irgendwelche Rechte oder dergleichen?
                                          33.2k
                                          84.3k
