  4. Test: Adapter Log Parser v0.x.x GitHub
logloggingadapterparserlogparservis
213 Beiträge 21 Kommentatoren 55.1k Aufrufe 41 Beobachtet
  • ScroungerS Scrounger
    @Mic
    Hab heut schon den ganzen Tag mitgelesen und mich drauf gefreut heute noch den Adapter auszuprobieren. Installiert, läuft, perfekt - vielen Dank super Adapter!
    Vorallem die Struktur finde ich sehr durchdacht. Speziell die Datenpunkte für Visualisierung und den selection Datenpunkt, bin begeistert :-)
    Hab gleich mal nen MDW Select Wigdet gebastelt für den selection Datenpunkt:
    [{"tpl":"tplVis-materialdesign-Select","data":{"oid":"logparser.0.visualization.table0.selection","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","inputType":"text","inputLayout":"regular","showInputMessageAlways":"true","showInputCounter":"true","clearIconShow":"true","listDataMethod":"jsonStringObject","countSelectItems":"1","listPosition":"auto","showSelectedIcon":"prepend-inner","showValue":false,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"jsonStringObject":"[\n\t{\n\t\t\"text\": \"Info\",\n\t\t\"value\": \"Info\"\n\t},\n\t{\n\t\t\"text\": \"Warn\",\n\t\t\"value\": \"Warn\"\n\t},\n\t{\n\t\t\"text\": \"Error\",\n\t\t\"value\": \"Error\"\n\t},\n\t{\n\t\t\"text\": \"WarnAndError\",\n\t\t\"value\": \"WarnAndError\"\n\t},\n\t{\n\t\t\"text\": \"Homematic\",\n\t\t\"value\": \"Homematic\"\n\t}\n]"},"style":{"left":"34px","top":"230px","width":"353px","height":"38px"},"widgetSet":"materialdesign"}]
    Jetzt hab ich endlich nen grund gefunden dem Select Widget noch beizubringen mit multistates umgehen zu können.
    ScroungerS
    ScroungerS
    Scrounger
    @Scrounger sagte in Test: Adapter Log Parser v0.x.x GitHub:
    Zur Info mt der neuen Material Design Widgets Version 0.3.0 geht das jetzt (demnächst im latest).
    D.h. beim Select Widget einfach den Datenpunkt selection eintragen
    und bei Eingabemethode Objekt hat Werteliste auswählen:
    So funktioniert die Auswahl dann out of the box.
    KnallochseK MicM 2 Antworten Letzte Antwort
      KnallochseK
      KnallochseK
      Knallochse
      @Scrounger Ich habe heute mal eine Testview mit dem Select Widget erstellt. Hat super funktioniert.
      Wegen Platzmangel habe ich dann in meiner normalen View in einem Popup Fenster zu arbeiten (Widget - jqui -container - icon - view in Dialog).
      Da wird das Auswahlmenü nicht angezeit. Als ich dann das Popup Fenster geschlossen hatte war das Auswahlfenster da (lag dahinter). Das spielen mit dem Z-Index brachte leider auch keinen Erfolg.
      • MicM Mic
        Aktuelle Test Version 0.4.6
        Veröffentlichungsdatum 13. April 2020
        Github Link https://github.com/Mic-M/ioBroker.logparser
        Über diesen Adapter
        Mit diesem Adapter können die ioBroker-Logs aller Adapter entsprechend geparsed, also gefiltert werden. Dieser Adapter ersetzt auch vollständig mein Log-Script (siehe Github | ioBroker-Forum-Thread).
        Siehe hier die Vorankündigung: Adapter Log-Parser – brauche bitte Eure Meinung
        Ein paar Kommentare:
        • Es sind soweit alle Features des Log-Scripts vorhanden.
        • Die Performance wurde massiv verbessert. Ich habe die meisten Script-Teile entsprechend umgeschrieben.
        • Bestehende Log-Scripts von mir im JavaScript-Adapter bitte deaktivieren zum testen.
        • Installation für die Tester über "5.) Adapter aus eigener URL installieren". Dann werden die entsprechenden Datenpunkte unter logparser.0 angelegt.
        • Für die Umsteiger vom Log-Script: Hier eine Vergleichstabelle der Datenpunkte
        Euer Feedback ist sehr willkommen :-) Ich werde auch noch Lasttests durchführen, also viele Logs gleichzeitig reinballern, um zu sehen wie sich der Adapter verhält.
        Anleitungen:
        Deutsch | Englisch
        Fragen zu Filterregeln:
        Bitte hier stellen: Log Parser: Fragen und Antworten zu Regex und Filterregeln
        Changelog:
        Siehe hier
        Beispiel für VIS:
        (Hier die Beschreibung)
        KnallochseK
        KnallochseK
        Knallochse
        @Mic Echt geile Sache dein Adapter. Funktioniert so weit ich das bis jetzt überblicken kann - Hervorragend .
        Wie @Dutchman schon schrieb, wären mehr Adapter zur Auswahl (Parser-Regeln) bestimmt nicht schlecht.
        Was man nicht braucht kann man ja deaktivieren / oder löschen.
        Bei löschen vielleicht noch einen Button für "Werkszustand 😀 "
        Die Bedienung ist für mich sehr schlüssig und finde ich toll.
        MicM 1 Antwort Letzte Antwort
        • K Kuddel
          ich habe das gleiche problem wie @Glasfaser
          Ich will alle Logeinträge die +++ enthalten in einer Ansicht zusammenfassen.
          Im Log selber sollen die +++ aber nicht auftauchen:
          Whitelist: +++
          Entferne: /script.js.[^:]*: /, "+++"
          Ergebnis:
          MicM
          MicM
          Mic
          @Kuddel sagte in Test: Adapter Log Parser v0.x.x GitHub:
          Whitelist: +++
          Ergebnis:
          Danke, damit konnte ich es reproduzieren. War ein Fehler im Adapter. Aber bitte die Strings ohne Anführungszeichen, also /script\.js\.[^:]*: /, "+++" ändern in /script\.js\.[^:]*: /, +++.
          --> Sollte behoben sein in aktueller Github-Version 0.4.1
          Bitte um dein Test-Feedback :-)
          Über folgendes Issue werde ich es später ermöglichen, dass man auch Anführungszeichen (") benutzen kann wenn man will: https://github.com/Mic-M/ioBroker.logparser/issues/11
          • K Kuddel
            Mir ist noch etwas aufgefallen:
            Gestern ist eingestellt und im Log steht yesterday
            MicM
            MicM
            Mic
            War ein Bug. --> Sollte behoben sein in aktueller Github-Version 0.4.1
            • DutchmanD Dutchman
              Sehr nice mic ! ich hänge mich mal mit dran den als Entwickler ist der adapter sehr praktisch !
              In der basis klappt es ziemlich ok, muss natürlich noch ausgiebig testen.
              Par kleine Sachen
              • Der interface überschlaget mich mit langen texten, da verliert man sehr schnell de faden
              • Die Tabellen sind leider sehr unuebersichtlich, auf nem 4k schirm hat man platz aber normaler PC/tabblet fast nicht mit zu arbeiten :
              • Es gibt keine uebersetzungen (wen du damit Hilfe brauchst sag bescheid hab das in mehreren Adaptern drin)
              • Hab dir n PR geschickt fuer issue/enhancement templates auf git :)
              • es waehre praktisch das alle adapter bereits in der Tabelle stehen wuerde, jetzt muss man alles eintragen das ist bij 40 adapter bissl mies
              MicM
              MicM
              Mic
              @Dutchman sagte in Test: Adapter Log Parser v0.x.x GitHub:
              Habe jetzt in Version in aktueller Github-Version 0.4.1 zumindest die Spaltenbreiten optimiert (zumindest für Chrome Browser).
                @Mic
                MicM
                MicM
                Mic
                @Mic
                Vielen Dank für dein Feedback, schätze ich sehr 👍 Ebenso, dass du das direkt aufgegriffen hast für deinen Adapter 😎
                Ich bin noch an meinem Adapter beschäftigt (Debugging etc.), daher dauert es noch etwas, bis ich deine Implementierungen testen und Feedback geben kann.
                • sigi234S sigi234
                  @Mic
                  Hallo, Super Adapter ! 👍
                  Habe mal eine View gebastelt, irgendwo habe ich einen Fehler, die Logs springen wieder zurück.
                  Kannst du die View mal testen?
                  VIEW_Log_Mic3_sigi234.txt
                  MicM
                  MicM
                  Mic
                  @sigi234 sagte in Test: Adapter Log Parser v0.x.x GitHub:
                  @Mic
                  Danke für dein Feedback Sigi, schöne View hast du da :-)
                  Was meinst du mit "springen wieder zurück"? Ich komme nicht gleich dazu, mir das anzusehen, evtl. erst in ein paar Tagen, also nicht wundern ;)
                  Stephan SchleichS 1 Antwort Letzte Antwort
                  • KnallochseK Knallochse
                    MicM
                    MicM
                    Mic
                    @Knallochse sagte in Test: Adapter Log Parser v0.x.x GitHub:
                    Danke auch für deine Rückmeldung 😎
                    Das mit Adapter-Auswahl ist schon per Issue adressiert, werde das aber wohl erst angehen, sobald ansonsten alles passt, will ihn erstmal zügig "latest" und dann "stable" hin bekommen :-) Da hab ich noch ein paar Sachen zu tun (u.a. gute Dokumentation, Übersetzungen, etc.).
                    Meine Idee ist aktuell diese: Now regarding issue #2 - probably it would be better to let the user choose which adapters to add to the filter (so multiple selection by using the ctrl key)....
                    • MicM Mic
                      GlasfaserG
                      GlasfaserG
                      @Mic
                      Für was ist diese Einstellung .... ?
                      MicM GlasfaserG 2 Antworten Letzte Antwort
                      • MicM Mic
                        Whitelist: +++
                        Ergebnis:
                        K
                        K
                        Kuddel
                        schrieb am zuletzt editiert von Kuddel
                        @Mic sagte in Test: Adapter Log Parser v0.x.x GitHub:
                        Whitelist: +++
                        Ergebnis:
                        jetzt werden die Einträge nicht mehr aufgelistet :-(
                        javascript.0	2020-04-09 08:44:39.257	info	(63817) script.js.smarthome.z_test.test_2: +++ test +++
                        Letzter Eintrag:
                        Konfig:
                        EDIT:
                        Die Einträge werden jetzt doch aufgelistet:
                        Wie entferne ich jetzt noch die +++ am Ende?
                        EDIT 2:
                        Habe jetzt folgenden Workaround:
                        Bereinige Log Message*: /script.js.[^:]*: /,+++ , +++
                        • MicM Mic
                          @Mic
                          Stephan SchleichS
                          Stephan SchleichS
                          Stephan Schleich
                          schrieb am zuletzt editiert von Stephan Schleich
                          @Mic
                          Er meint damit, dass wen du Warn,Error etc. anklickst und ein Info Log kommt er sofort wieder auf Info springt
                          • Stephan SchleichS Stephan Schleich
                            @Mic
                            MicM
                            MicM
                            Mic
                            @sigi234
                            @Stephan-Schleich sagte in Test: Adapter Log Parser v0.x.x GitHub:
                            Ok, danke euch. Sollte nun behoben sein mit Version 0.4.2.
                            • MicM Mic
                              @sigi234
                              sigi234S
                              sigi234S
                              Ja behoben, Danke.👍
                              • K Kuddel
                                Whitelist: +++
                                Ergebnis:
                                Letzter Eintrag:
                                Konfig:
                                EDIT:
                                EDIT 2:
                                MicM
                                MicM
                                Mic
                                EDIT 2:
                                Dein Feedback zeigt, wie wichtig eure Tests sind 👍
                                Es gab noch einen Fehler bezüglich "multiple regex/string config values separated by comma". Habe ich nun mit 0.4.3 behoben.
                                Dadurch solltest du auch deinen Workaround nicht mehr benötigen.
                                • GlasfaserG Glasfaser
                                  @Mic
                                  MicM
                                  MicM
                                  Mic
                                  @Glasfaser sagte in Test: Adapter Log Parser v0.x.x GitHub:
                                  @Mic
                                  Keine Ahnung 🤔 Scheint bei mehreren Adaptern so zu sein, dass die angezeigt werden, u.a. auch RSS Parser. Was stellt man denn da normalerweise ein? Wird evtl. durch den "Adapter Creator" so hinzugefügt...
                                  • MicM
                                    MicM
                                    Mic
                                    Kurzes Update:
                                    Keine neuen Funktionen, aber ich habe eine Adapter-Dokumentation erstellt (Deutsch, Englisch), Übersetzungen hinzugefügt und automatisiert dank @Dutchman , sowie Adapter-Konfiguration noch mal verbessert.
                                    Jetzt mit Version 0.4.4 auf Github.
                                      MicM
                                      MicM
                                      Mic
                                      Sehr cool, vielen dank hierfür! Gerade erfolgreich getestet :-)
                                      • MicM Mic
                                        GlasfaserG
                                        GlasfaserG
                                        @Mic
                                        Der Eintrag für Zusammenfügen ist nicht gesetzt !
                                        Im Log zeigt er die einzelne Einträge ... das ist ja richtig ,
                                        aber er Zählt die Einträge hoch und zeigt Sie jeweils an .
                                        Heute um 21:00 Uhr habe ich dein Update auf 0.4.4 aufgespielt und wegen einem Adapter Neustart beginnt das Zählen neu .( Gleicher Tag )
                                        21:05 Uhr Meldung ausgelöst .
                                        20:06 Uhr Meldung ausgelöst und es wird im dann zusätzlich der Eintrag [2 Einträge] davorgesetzt .
                                        • MicM
                                          MicM
                                          Mic
                                          schrieb am zuletzt editiert von Mic
                                          Hi @Glasfaser
                                          kannst du bitte Folgendes durchführen:
                                          1. Die Adapter-Einstellungen exportieren, gegebenenfalls entsprechende Daten anonymisieren / entfernen und hier in deiner Antwort in Code-Tags posten:
                                          2. Im Admin-Interface links "Log" auswählen, "Log Herunterladen" anklicken und aktuellen Log herunterladen. Den Download in Texteditor öffnen (z.B. Notepad++) und alles löschen bis auf die relevanten Logzeilen, um die es geht. Ggf. anonymisieren. Das Ergebnis hier in Code-Tags posten.
                                          Danke.
                                          83.8k
