  4. Test Adapter Material Design Widgets v0.1.x
adaptervismaterial ui
189 Beiträge 22 Kommentatoren 62.8k Aufrufe 30 Beobachtet
  • ScroungerS Scrounger
    @sigi234 sagte in Test Adapter Material Design Widgets v0.1.x:
    Und wie? Kannst du mir bitte ein Beispiel machen irgendwo habe ich immer einen Fehler:
    DP:
    daswetter.0.NextHours.Location_1.Day_1.current.clouds_value
    Poste mal die Value des Datenpunktes.
    sigi234S
    sigi234S
    #123
    @Scrounger sagte in Test Adapter Material Design Widgets v0.1.x:
    DP:
    53 %
      "from": "system.adapter.daswetter.0",
      "ts": 1544353203713,
      "user": "system.user.admin",
      "common": {
        "name": "clouds",
        "type": "string",
        "role": "weather.clouds.forecast.0",
        "unit": "%",
        "read": true,
        "write": false,
        "custom": {
          "history.0": {
            "enabled": true,
            "changesOnly": true,
            "debounce": "1000",
            "maxLength": "10",
            "retention": "31536000",
            "changesRelogInterval": 5,
            "changesMinDelta": 0,
            "aliasId": ""
          "iqontrol.0": {
            "enabled": true,
            "readonly": true,
            "invert": false,
            "unit": "%",
            "type": "number",
            "role": "state",
            "targetValueId": "",
            "confirm": false,
            "pincode": "",
            "unit_zero": "",
            "unit_one": "",
            "min": "",
            "max": "",
            "step": ""
      "native": {},
      "acl": {
        "object": 1636,
        "owner": "system.user.admin",
        "state": 1636
      "_id": "daswetter.0.NextHours.Location_1.Day_1.current.clouds_value",
      "type": "state"
    ScroungerS 1 Antwort Letzte Antwort
    • sigi234S sigi234
      DP:
      53 %
        "common": {
          "name": "clouds",
          "type": "string",
          "unit": "%",
          "read": true,
          "write": false,
          "custom": {
            "history.0": {
              "enabled": true,
              "debounce": "1000",
              "maxLength": "10",
              "aliasId": ""
            "iqontrol.0": {
              "enabled": true,
              "readonly": true,
              "invert": false,
              "unit": "%",
              "type": "number",
              "role": "state",
              "confirm": false,
              "pincode": "",
              "unit_zero": "",
              "unit_one": "",
              "min": "",
              "max": "",
              "step": ""
        "native": {},
        "acl": {
          "object": 1636,
          "state": 1636
        "type": "state"
      ScroungerS
      ScroungerS
      Scrounger
      #124
      @sigi234
      Brauch den Wert des Datenpunktes.
      Was genau funktioniert denn nicht?
        @sigi234
        sigi234S
        sigi234S
        #125
        • sigi234S sigi234
          ScroungerS
          ScroungerS
          Scrounger
          #126
          Das kann ja auch nicht gehen. Der datenpunkt muss z.B. folgendes Format haben:
          {"img":"/vis.0/myImages/erlebnis_50.png","name":"Empire","betriebszeit":"4h 06m","funk":"5G","ip":"10.0.0.1"},
          {"img":"/vis.0/myImages/erlebnis_100.png","name":"Handy","betriebszeit":"13m","funk":"5G","ip":"10.0.0.2"},
          {"img":"/vis.0/myImages/erlebnis_100.png","name":"Harmony Hub - Wohnzimmer","betriebszeit":"18T 07h 21m","funk":"2G","ip":"10.0.0.3"},
          {"img":"/vis.0/myImages/erlebnis_25.png","name":"MusicCast - Esszimmer (WX-030)","betriebszeit":"1h 57m","funk":"2G","ip":"10.0.0.4"},
          {"img":"/vis.0/myImages/erlebnis_75.png","name":"MusicCast - Küche (ISX-18D)","betriebszeit":"4h 10m","funk":"2G","ip":"10.0.0.5"}
          Am besten schreibst du dir ein kleines skript mit dem du alle Werte, die du in der Tabelle haben möchtest, in das oben dargestellte format bringst.
          • T
            T
            tazdevil20
            #127
            Habe eine Frage zu der Value Select List:
            • In dem Objekt "Schalter" wird doch sicherlich hinterlegt welche Auswahl getroffen wurde. Wie muss ich hier die Einstellung vornehmen, oder ist das noch soweit Beta, dass noch keine Funktionalität hinterlegt ist? Habe alles schon ausprobiert, jedoch wurde nie ein Wert eingetragen.
            Jetzt der Feature requests:
            • Besteht die Möglichkeit die Werte variable mittels JSON bereitzustellen?
            • Ich würde den Button auch gerne etwas von der Höhe her verkleinern.
            • Die Auswahlliste breiter darstellen als der Button.
            ScroungerS 2 Antworten Letzte Antwort
            • T tazdevil20
              ScroungerS
              ScroungerS
              Scrounger
              #128
              @tazdevil20 sagte in Test Adapter Material Design Widgets v0.1.x:
              Funktioniert. Mustt hier die Werte Eintragen die der Datenpunkt (Schalter) annehmen soll:
              Nein.
              Geht mit css überschreiben
              • A
                A
                acramatic
                #129
                besteht die Möglichkeit, sich die Werte eines Kreisdiagramms addiert anzeigen zu lassen?
                  @dos1973
                  Was möchtest du denn machen?
                  Du kannst css bei allen Widgets einsetzen, musst dann halt entsprechend dir die element zur runtime anschauen und mit CSS dann das überschrieben was du willst.
                  Edit:
                  Hallo, kann ich beim Table Widget nur bestimmte COL anzeigen lassen so wie es im Table Widget im Original geht?
                  Ist implementiert, bitte testen
                  D
                  D
                  dos1973
                  #130
                  @dos1973
                  als Anfang zb. Schrift/ Schriftgröße etc...
                  ich habe eine switch hinzugefügt und habe es hiermit versucht, (Testweise)
                  funktioniert aber nicht/ oder nicht richtig.
                  .mdc-switch .mdc-switch--checked{
                      font-size:36px !important;
                  ich glaube ich habe das richtige Element gefunden, aber entweder es verschiebt sich alles total, oder die --checked option, also die Farbe funktioniert nicht. könnte ich eine Beispiel anhand des switch bekommen.
                  • A acramatic
                    ScroungerS
                    ScroungerS
                    Scrounger
                    schrieb am zuletzt editiert von Scrounger
                    #131
                    @acramatic sagte in Test Adapter Material Design Widgets v0.1.x:
                    Mach dir nen Skript das die einzelnen Werte des Kreisdiagramms in einem Datenpunkte addiert und dann mit z.B. nem String Widget den Datenpunkt anzeigen.
                    @dos1973 sagte in Test Adapter Material Design Widgets v0.1.x:
                    Das kannst doch im Editor einstellen über die Kategorie Font.
                      D
                      D
                      dos1973
                      schrieb am zuletzt editiert von dos1973
                      #132
                      @Scrounger
                      Das ist klar,
                      mein vis geht über mehrer Seiten, wenn ich dann etwas ändere wollen würde, dann muss ich das überall manuell machen...
                      Font und schrift, war nur als Beispiel gedacht.
                      • D dos1973
                        @Scrounger
                        Das ist klar,
                        ScroungerS
                        ScroungerS
                        Scrounger
                        #133
                        @dos1973
                        Eigene CSS Klasse wo du nur die Attribute überschreibst und dann unter allgemein zuweist hast auch probiert?
                        Beispiel kann ich Grad keine liefern da ich net am Rechner bin, evtl heute Abend
                          @dos1973
                          D
                          D
                          dos1973
                          #134
                          @Scrounger
                          ja, eigene funktionieren nicht.
                          wie machen das alle anderen hier, alle Werte manuell im Editor?
                          • D dos1973
                            @Scrounger
                            ScroungerS
                            ScroungerS
                            Scrounger
                            #135
                            @dos1973
                            Geht per css:
                            .materialdesign-checkbox > label {
                                font-size: 50px;
                            und auch mit eigener css klasse:
                            .myCheckBox > label {
                                font-size: 80px;
                            • T tazdevil20
                              ScroungerS
                              ScroungerS
                              Scrounger
                              #136
                              Grad eingefallen - kann doch im Editor eingestellt werden über 'menuWidth'
                              • B
                                B
                                BobBruni
                                #137
                                Gibt es eine einfache Möglichkeit bei den List-Cards Zeilenumbrüche zu ermöglichen?
                                • O Oli
                                  @crunchip
                                  benötigst du noch Hilfe?
                                  ub.privatU
                                  ub.privatU
                                  ub.privat
                                  #138
                                  @Oli
                                  stehe vor der selbenAnfängerfrage wie @crunchip.
                                  Möchte über das Widget "Menü" meine Views aufrufen.
                                  Soweit so gut, funktioniert auch, ABER der View-Inhalt wird nicht angezeigt???
                                  Was bedeutet eigentlich "Checkbox "persistent" must be activated!" ... wo finde ich diese Checkbox?
                                  Halt Fragen, über Fragen...
                                  sigi234S O 2 Antworten Letzte Antwort
                                    Die installation hatte ich ja schon vor langer Zeit gemacht, mich aber noch nicht wirklich damit beschäftigt.
                                    Habe zwar hin und wieder immer mal mitgelesen, jedoch ist das hier ganz schön gewachsen👍
                                    Nun habe ich mir mal die aktuelle Version geladen und stehe irgendwie auf der Leitung.
                                    Scheitere schon bei der Einstellung des Top App Bar widget
                                    • Das Top App Bar zieh ich mir rüber und vergrößere auf meine View, richtig?
                                    • view Tab 0 ist dann logischerweise meine Startseite?
                                    • für was ist die Objekt Id in diesem Widget, was muss ich da anlegen?
                                    • wie bekomme ich da ein Untermenü hin? das mit dem view| view| view raff ich net, muss ich da was von Hand eingeben oder die einzelnen Views auswählen, getrennt mit einem |
                                    das wären nun erstmal ein paar Fragen,
                                    wenn die mir jemand in Kurzfassung beantworten könnte, damit ich da mal ein wenig weitermachen kann, wäre klasse
                                    ub.privatU
                                    ub.privatU
                                    ub.privat
                                    #139
                                    @crunchip
                                    hast Du für dein Problem eine "Lösung" gefunden???
                                    Komme auch nicht wirklich weiter...
                                    • ub.privatU ub.privat
                                      @Oli
                                      sigi234S
                                      sigi234S
                                      #140
                                      @ub-privat sagte in Test Adapter Material Design Widgets v0.1.x:
                                      ub.privatU 1 Antwort Letzte Antwort
                                        @Oli
                                        O
                                        O
                                        Oli
                                        #141
                                        @ub-privat
                                        du gibst im im gelb markierten Bereich deine Seiten ein die du angezeigt haben willst
                                        Wenn du ein Untermenü erstellen willst, gibst du "|" als Trennzeichen.
                                        Bei Bezeichnung gibst du die Namen ein, welche angezeigt werden sollen und bei Bilder, deine Bilder die angezeigt werden sollen.
                                        Bei einem Untermenü gibst folgendes bei den Bildern ein:
                                        {"itemImage": "/vis.0/main/img/Meine Icons/Sonstiges/Internet.png", "subItems": ["/icons-mfd-png/weather_cloudy.png", "/icons-mfd-png/scene_gas_station.png", "/vis.0/main/img/Meine Icons/Sonstiges/Heizöl.png"]}
                                        Oliver
                                        • sigi234S sigi234
                                          ub.privatU
                                          ub.privatU
                                          ub.privat
                                          #142
                                          @sigi234
                                          DANKE! Inuitiv habe ich dies bereits erledigt...
                                          83.8k
