  4. iob diag - Skript
    1.0k
iob diag - Skript
863 Beiträge 52 Kommentatoren 309.3k Aufrufe 40 Beobachtet
  • T TT-Tom
    @Thomas-Braun
    von wo muss es gestartet werden? aus dem iobroker Verzeichnis oder aus meinem user Verzeichnis??
    beim User habe ich ein paar Fehlermeldungen, arbeite da mit einem LXC Container.
    Script v.2026-03-08
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)
     Static hostname: iobtest
           Icon name: computer-container
             Chassis: container ☐
      Virtualization: lxc
              Kernel: Linux 6.17.13-1-pve
        Architecture: x86-64
    OS is similar to:
    model name	: Intel(R) N100
    CPU threads     : 4
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64bit
    Systemuptime and Load:
     09:21:36 up 5 days, 17:02,  1 user,  load average: 0.69, 0.68, 0.52
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'trixie'!
    *** TIME AND TIMEZONES ***
                   Local time: Mon 2026-03-09 09:21:36 CET
               Universal time: Mon 2026-03-09 08:21:36 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    tom
    HOME=/home/tom
    GROUPS=tom sudo users iobroker
    iobroker
    [sudo] password for tom:
    HOME=/home/iobroker
    SUDO_HOME=/home/tom
    GROUPS=iobroker tty dialout audio video plugdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server:		Unknown
    Display-Manager: 	Not found
    Desktop:
    Session:		tty
    *** MEMORY ***
    Mem:            8.4G        2.7G        5.5G        3.0M        145M        5.6G
    Swap:           536M        234M        302M
    Total:          8.9G        3.0G        5.8G
    Active iob-Instances: 	16
             8000 M total memory
             2612 M used memory
             1649 M active memory
             1011 M inactive memory
             5250 M free memory
                0 M buffer memory
              139 M swap cache
              512 M total swap
              223 M used swap
              288 M free swap
    top - 09:21:47 up 5 days, 17:02,  1 user,  load average: 0.90, 0.73, 0.54
    Tasks:  41 total,   1 running,  40 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  3.6 us,  1.8 sy,  0.0 ni, 78.6 id, 16.1 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   8000.0 total,   5250.4 free,   2613.2 used,    139.2 buff/cache
    MiB Swap:    512.0 total,    288.4 free,    223.6 used.   5386.8 avail Mem
    *** FAILED SERVICES ***
      UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
    * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
    Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
            ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
            SUB    -> The low-level unit activation state, values depend on unit type.
    2 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    dmesg: read kernel buffer failed: Operation not permitted
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem               Type      Size  Used Avail Use% Mounted on
    DATEN1/subvol-101-disk-1 zfs        64G   14G   51G  22% /
    none                     tmpfs     492K  4.0K  488K   1% /dev
    udev                     devtmpfs   16G     0   16G   0% /dev/tty
    tmpfs                    tmpfs      16G     0   16G   0% /dev/shm
    tmpfs                    tmpfs     6.3G  132K  6.3G   1% /run
    tmpfs                    tmpfs      16G  2.8M   16G   1% /tmp
    tmpfs                    tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs                    tmpfs     3.2G  8.0K  3.2G   1% /run/user/1000
    Messages concerning filesystems in dmesg:
    Show mounted filesystems:
    TARGET SOURCE                   FSTYPE OPTIONS
    /      DATEN1/subvol-101-disk-1 zfs    rw,relatime,xattr,posixacl,casesensitive
    /var:
    319M	/var/
    181M	/var/cache
    178M	/var/cache/apt
    125M	/var/cache/apt/archives
    70M	/var/lib
    Archived and active journals take up 4.2M in the file system.
    /opt/iobroker/backups:
    139M	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    245M	/opt/iobroker/iobroker-data/
    121M	/opt/iobroker/iobroker-data/backup-objects
    113M	/opt/iobroker/iobroker-data/files
    24M	/opt/iobroker/iobroker-data/files/mytime.admin
    23M	/opt/iobroker/iobroker-data/files/mytime.admin/custom/assets
    15M	/opt/iobroker/iobroker-data/files/mytime.admin/custom/assets/index-B_3WOu59.js.map
    7.8M	/opt/iobroker/iobroker-data/objects.jsonl
    4.4M	/opt/iobroker/iobroker-data/backup-objects/2026-03-09_08-19_objects.jsonl.gz
    4.4M	/opt/iobroker/iobroker-data/backup-objects/2026-03-09_06-19_objects.jsonl.gz
    4.4M	/opt/iobroker/iobroker-data/backup-objects/2026-03-09_04-19_objects.jsonl.gz
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    No Devices found 'by-id'
    *** ZigBee Settings ***
    Zigbee Network Settings on your coordinator / in nvbackup are:
    zigbee.X
    \nExtended Pan ID:
    \n*** MASKED ***
    \nPan ID:
    \n*** MASKED ***
    \nChannel:
    \n*** MASKED ***
    \nNetwork Key:
    \n*** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs		v22.22.0
    /usr/bin/node		v22.22.0
    /usr/bin/npm		10.9.4
    /usr/bin/npx		10.9.4
    ✓ Node.js installation is correct
    nodejs:
      Installed: 22.22.0-1nodesource1
      Candidate: 22.22.0-1nodesource1
      Version table:
     *** 22.22.0-1nodesource1 1001
         22.21.0-1nodesource1 1001
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         20.19.2+dfsg-1 500
            500 http://deb.debian.org/debian trixie/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    node:fs:2437
        return binding.writeFileUtf8(
    Error: EACCES: permission denied, open '/home/iobroker/node_modules/is-my-node-vulnerable/schedule.etag'
        at Object.writeFileSync (node:fs:2437:20)
        at ClientRequest.<anonymous> (/home/iobroker/node_modules/is-my-node-vulnerable/is-vulnerable.js:82:12)
        at Object.onceWrapper (node:events:634:26)
        at ClientRequest.emit (node:events:519:28)
        at HTTPParser.parserOnIncomingClient [as onIncoming] (node:_http_client:772:27)
        at HTTPParser.parserOnHeadersComplete (node:_http_common:122:17)
        at TLSSocket.socketOnData (node:_http_client:614:22)
        at TLSSocket.emit (node:events:519:28)
        at addChunk (node:internal/streams/readable:561:12)
        at readableAddChunkPushByteMode (node:internal/streams/readable:512:3) {
      errno: -13,
      code: 'EACCES',
      syscall: 'open',
      path: '/home/iobroker/node_modules/is-my-node-vulnerable/schedule.etag'
    Node.js v22.22.0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobtest             iobtest (version: 7.1.0, hostname: iobtest       , alive, uptime: 493355)
    Core adapters versions
    js-controller: 	7.1.0
    admin: 		7.8.2
    javascript: 	9.0.18
    nodejs modules from github: 	3
    +-- iobroker.fahrplan@1.4.1 (git+ssh://git@github.com/tt-tom17/ioBroker.fahrplan.git#a25514b1774a271768b58081fe4031bf3eb9ebca)
    +-- iobroker.nspanel-lovelace-ui@0.13.4 (git+ssh://git@github.com/ticaki/ioBroker.nspanel-lovelace-ui.git#b8e5efbbe1973a36a4dfdb0f0e3e63c435630803)
    +-- iobroker.public-transport@0.0.5 (git+ssh://git@github.com/tt-tom17/ioBroker.public-transport.git#335d0dd3595a1dd8da7aa69116f84923b001ff5b)
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobtest                                  -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alias-manager.0          : alias-manager         : iobtest                                  - disabled
    + system.adapter.backitup.0               : backitup              : iobtest                                  -  enabled
      system.adapter.cloudless-homeconnect.0  : cloudless-homeconnect : iobtest                                  - disabled
      system.adapter.devices.0                : devices               : iobtest                                  - disabled
    + system.adapter.fahrplan.0               : fahrplan              : iobtest                                  -  enabled
      system.adapter.hmip.0                   : hmip                  : iobtest                                  - disabled
      system.adapter.ical.0                   : ical                  : iobtest                                  -  enabled
    + system.adapter.influxdb.0               : influxdb              : iobtest                                  -  enabled, port: 8086
    + system.adapter.javascript.0             : javascript            : iobtest                                  -  enabled
    + system.adapter.javascript.1             : javascript            : iobtest                                  -  enabled
    + system.adapter.mqtt-client.0            : mqtt-client           : iobtest                                  -  enabled, port: 1883
    + system.adapter.mqtt.0                   : mqtt                  : iobtest                                  -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.mqtt.1                   : mqtt                  : iobtest                                  - disabled, port: 1883, bind: 0.0.0.0
      system.adapter.mytime.0                 : mytime                : iobtest                                  - disabled
      system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobtest                                  -  enabled
    + system.adapter.nspanel-lovelace-ui.0    : nspanel-lovelace-ui   : iobtest                                  -  enabled
      system.adapter.opendtu.0                : opendtu               : iobtest                                  - disabled
      system.adapter.openweathermap.0         : openweathermap        : iobtest                                  -  enabled
    + system.adapter.pirate-weather.0         : pirate-weather        : iobtest                                  -  enabled
      system.adapter.proxmox.0                : proxmox               : iobtest                                  - disabled
    + system.adapter.public-transport.0       : public-transport      : iobtest                                  -  enabled
    + system.adapter.simple-api.0             : simple-api            : iobtest                                  -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      system.adapter.socketio.0               : socketio              : iobtest                                  - disabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.sql.0                    : sql                   : iobtest                                  -  enabled
      system.adapter.trashschedule.0          : trashschedule         : iobtest                                  - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobtest                                  -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobtest                                  -  enabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobtest                                  -  enabled
      system.adapter.vis.0                    : vis                   : iobtest                                  -  enabled
    + system.adapter.web.0                    : web                   : iobtest                                  -  enabled, port: 8082, bind: 192.168.178.53, run as: admin
      system.adapter.ws.0                     : ws                    : iobtest                                  - disabled, port: 8084, bind: 0.0.0.0, run as: admin
      system.adapter.yahka.0                  : yahka                 : iobtest                                  - disabled
      system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobtest                                  - disabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): beta
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: beta
    Adapter    "admin"        : 7.8.3    , installed 7.8.2  [Updatable]
    Adapter    "alias-manager": 2.1.0    , installed 2.1.0
    Adapter    "backitup"     : 3.3.14   , installed 3.3.14
    Adapter    "cloudless-homeconnect": 1.6.3, installed 1.6.3
    Adapter    "devices"      : 1.2.14   , installed 1.2.14
    Adapter    "fahrplan"     : 1.4.1    , installed 1.4.1
    Adapter    "hmip"         : 1.27.0   , installed 1.27.0
    Adapter    "ical"         : 1.19.7   , installed 1.19.7
    Adapter    "javascript"   : 9.0.18   , installed 9.0.18
    Controller "js-controller": 7.1.0    , installed 7.1.0
    Adapter    "mqtt-client"  : 3.0.0    , installed 3.0.0
    Adapter    "mytime"       : 2.3.2    , installed 2.3.2
    Adapter    "netatmo-crawler": 1.1.0  , installed 1.1.0
    Adapter    "nspanel-lovelace-ui": 0.13.4, installed 0.13.4
    Adapter    "opendtu"      : 3.1.0    , installed 3.1.0
    Adapter    "openweathermap": 1.4.0   , installed 1.4.0
    Adapter    "pirate-weather": 0.8.0   , installed 0.8.0
    Adapter    "proxmox"      : 2.4.10   , installed 2.4.10
    Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
    Adapter    "socketio"     : 7.0.8    , installed 7.0.8
    Adapter    "sql"          : 3.0.1    , installed 3.0.1
    Adapter    "trashschedule": 5.2.1    , installed 5.2.1
    Adapter    "vis-hqwidgets": 1.6.0    , installed 1.6.0
    Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
    Adapter    "web"          : 8.0.0    , installed 8.0.0
    Adapter    "ws"           : 4.0.0    , installed 4.0.0
    Adapter    "yahka"        : 1.1.6    , installed 1.1.6
    Adapter    "zigbee2mqtt"  : 3.0.21   , installed 3.0.21
    Objects and States
    Objects: 	10075
    States: 	8039
    Hit:1 http://security.debian.org trixie-security InRelease
    Hit:2 http://deb.debian.org/debian trixie InRelease
    Hit:3 http://deb.debian.org/debian trixie-updates InRelease
    Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
    Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian trixie InRelease
    Reading package lists... Done
    Pending systemupdates: 1
    *** Listening Ports ***
    Netid State  Recv-Q Send-Q  Local Address:Port     Peer Address:Port Process
    udp   UNCONN 0      0             0.0.0.0:sunrpc        0.0.0.0:*     users:(("rpcbind",pid=140,fd=5),("systemd",pid=1,fd=35))
    udp   UNCONN 0      0                [::]:sunrpc           [::]:*     users:(("rpcbind",pid=140,fd=7),("systemd",pid=1,fd=37))
    tcp   LISTEN 0      511    192.168.178.53:8082          0.0.0.0:*     users:(("io.web.0",pid=637,fd=35))
    tcp   LISTEN 0      100         127.0.0.1:smtp          0.0.0.0:*     users:(("master",pid=294,fd=13))
    tcp   LISTEN 0      4096          0.0.0.0:sunrpc        0.0.0.0:*     users:(("rpcbind",pid=140,fd=4),("systemd",pid=1,fd=34))
    tcp   LISTEN 0      511         127.0.0.1:9001          0.0.0.0:*     users:(("iobroker.js-con",pid=143,fd=23))
    tcp   LISTEN 0      511         127.0.0.1:9000          0.0.0.0:*     users:(("iobroker.js-con",pid=143,fd=29))
    tcp   LISTEN 0      511                 *:tproxy              *:*     users:(("io.admin.0",pid=882,fd=39))
    tcp   LISTEN 0      511                 *:8087                *:*     users:(("io.simple-api.0",pid=684,fd=35))
    tcp   LISTEN 0      100             [::1]:smtp             [::]:*     users:(("master",pid=294,fd=14))
    tcp   LISTEN 0      4096                *:ssh                 *:*     users:(("sshd",pid=165,fd=3),("systemd",pid=1,fd=61))
    tcp   LISTEN 0      4096             [::]:sunrpc           [::]:*     users:(("rpcbind",pid=140,fd=6),("systemd",pid=1,fd=36))
    2026-03-09 09:01:43.488  - info: host.iobtest instance system.adapter.nspanel-lovelace-ui.0 in version "0.13.4" (non-npm: ticaki/ioBroker.nspanel-lovelace-ui#b8e5efbbe1973a36a4dfdb0f0e3e63c435630803) started with pid 25570
    2026-03-09 09:01:44.377  - info: nspanel-lovelace-ui.0 (25570) starting. Version 0.13.4 (non-npm: ticaki/ioBroker.nspanel-lovelace-ui#b8e5efbbe1973a36a4dfdb0f0e3e63c435630803) in /opt/iobroker/node_modules/iobroker.nspanel-lovelace-ui, node: v22.22.0, js-controller: 7.1.0
    2026-03-09 09:01:44.429  - info: nspanel-lovelace-ui.0 (25570) Configured panels: name#topic -> [Buero#SmartHome/NSPanel_1], [DEV-Panel#NSPanel_DEV]
    2026-03-09 09:01:44.430  - info: nspanel-lovelace-ui.0 (25570) Found 2 script configs for topics: SmartHome/NSPanel_1, NSPanel_DEV
    2026-03-09 09:01:44.430  - info: nspanel-lovelace-ui.0 (25570) Detailed configuration checks are suppressed here. Full validation output is only shown when the configuration script is sent to the adapter.
    2026-03-09 09:01:46.351  - info: nspanel-lovelace-ui.0 (25570) [Buero] Setting panel to offline until first message!
    2026-03-09 09:01:46.392  - info: nspanel-lovelace-ui.0 (25570) [DEV-Panel] Setting panel to offline until first message!
    2026-03-09 09:01:53.211  - info: nspanel-lovelace-ui.0 (25570) [controller] 2 Panels initialized
    2026-03-09 09:01:54.380  - info: nspanel-lovelace-ui.0 (25570) [Buero] is online!
    2026-03-09 09:01:54.803  - info: nspanel-lovelace-ui.0 (25570) [Buero] Panel startup finished!
    2026-03-09 09:05:01.421  - info: nspanel-lovelace-ui.0 (25570) [Buero] Panel startup finished!
    2026-03-09 09:05:20.941  - info: fahrplan.0 (607) Updated 3 routes, 3 enabled and 0 disabled
    2026-03-09 09:05:21.194  - info: fahrplan.0 (607) Updated 1 departure timetables, 1 enabled and 0 disabled
    2026-03-09 09:10:26.298  - info: fahrplan.0 (607) Updated 3 routes, 3 enabled and 0 disabled
    2026-03-09 09:10:26.578  - info: fahrplan.0 (607) Updated 1 departure timetables, 1 enabled and 0 disabled
    2026-03-09 09:11:37.614  - warn: admin.0 (882) nspanel-lovelace-ui has an invalid jsonConfig: [{"instancePath":"/items/pagePower/items/pagePowerdata/items/6","schemaPath":"#/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"attr"},"message":"must NOT have additional properties"},{"instancePath":"/items/pagePower/items/pagePowerdata/items/6","schemaPath":"#/items/allOf/18/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"},{"instancePath":"/items/pagePower/items/pagePowerdata","schemaPath":"#/patternProperties/%5E.%2B/allOf/57/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"},{"instancePath":"/items/pagePower","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/11/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"},{"instancePath":"","schemaPath":"#/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"}]
    2026-03-09 09:15:05.013  - info: host.iobtest instance system.adapter.netatmo-crawler.0 in version "1.1.0" started with pid 25592
    2026-03-09 09:15:05.673  - info: netatmo-crawler.0 (25592) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v22.22.0, js-controller: 7.1.0
    2026-03-09 09:15:05.690  - info: netatmo-crawler.0 (25592) Getting data for stationid:70:ee:50:35:dc:b6
    2026-03-09 09:15:06.537  - info: netatmo-crawler.0 (25592) Terminated (NO_ERROR): Everything done. Going to terminate till next schedule
    2026-03-09 09:15:07.047  - info: host.iobtest instance system.adapter.netatmo-crawler.0 having pid 25592 terminated with code 0 (NO_ERROR)
    2026-03-09 09:15:30.461  - info: fahrplan.0 (607) Updated 3 routes, 3 enabled and 0 disabled
    2026-03-09 09:15:30.698  - info: fahrplan.0 (607) Updated 1 departure timetables, 1 enabled and 0 disabled
    2026-03-09 09:20:34.384  - info: fahrplan.0 (607) Updated 3 routes, 3 enabled and 0 disabled
    2026-03-09 09:20:34.716  - info: fahrplan.0 (607) Updated 1 departure timetables, 1 enabled and 0 disabled
    zum Vergleich die normal iob diag Ausgabe
    Script v.2026-01-31
    *** BASE SYSTEM ***
      Virtualization: lxc
    OS is similar to:
    Docker          : false
    Kernel          : x86_64
    Userland        : 64 bit
     09:51:54 up 5 days, 17:32,  1 user,  load average: 0.27, 0.63, 0.57
    CPU threads: 4
                   Local time: Mon 2026-03-09 09:51:54 CET
               Universal time: Mon 2026-03-09 08:51:54 UTC
                     RTC time: n/a
              RTC in local TZ: no
    tom
    HOME=/home/tom
    iobroker
    HOME=/home/iobroker
    SUDO_HOME=/home/tom
    Display-Server: 	false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session: 		tty
    *** MEMORY ***
    Mem:            8.4G        2.0G        6.2G        3.1M        194M        6.4G
    Swap:           536M        339K        536M
    Total:          8.9G        2.0G        6.8G
             8000 M total memory
             1865 M used memory
             1904 M active memory
               43 M inactive memory
             5952 M free memory
                0 M buffer memory
              185 M swap cache
              512 M total swap
                0 M used swap
              511 M free swap
    top - 09:51:54 up 5 days, 17:32,  1 user,  load average: 0.27, 0.63, 0.57
    Tasks:  45 total,   1 running,  44 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   8000.0 total,   5951.3 free,   1866.2 used,    185.3 buff/cache
    MiB Swap:    512.0 total,    511.7 free,      0.3 used.   6133.8 avail Mem
    *** FILESYSTEM ***
    /var:
    319M	/var/
    181M	/var/cache
    178M	/var/cache/apt
    70M	/var/lib
    Archived and active journals take up 4.3M in the file system.
    242M	/opt/iobroker/iobroker-data/
    7.6M	/opt/iobroker/iobroker-data/objects.jsonl
    USB-Devices by-id:
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    /usr/bin/npm 		10.9.4
    /usr/bin/npx 		10.9.4
    nodejs:
      Candidate: 22.22.1-1nodesource1
      Version table:
         22.22.1-1nodesource1 1001
         20.19.2+dfsg-1 500
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobtest             iobtest (version: 7.1.0, hostname: iobtest       , alive, uptime: 316)
    admin: 		7.8.2
    javascript: 	9.0.18
    Adapter State
    + instance is alive
    Objects and States
    Objects: 	10019
    States: 	7993
    tcp        0      0 192.168.178.53:8082     0.0.0.0:*               LISTEN      1001       31394874   27969/io.web.0
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          30032      294/master
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          17403      1/init
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       31384629   27130/iobroker.js-c
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       31384634   27130/iobroker.js-c
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       31384845   27149/io.admin.0
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       31395098   28008/io.simple-api
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          30033      294/master
    tcp6       0      0 :::22                   :::*                    LISTEN      0          21994      1/init
    tcp6       0      0 :::111                  :::*                    LISTEN      0          17405      1/init
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          17404      1/init
    udp6       0      0 :::111                  :::*                                0          17406      1/init
    2026-03-09 09:47:37.959  - error: javascript.0 (27223) script.js.common.Speedtest: Speedtest konnte nicht ausgeführt werden! Error: Command failed: /usr/bin/speedtest -f json --accept-license --accept-gdpr
    2026-03-09 09:47:39.217  - info: vis.0 (28024) Terminated (NO_ERROR): Without reason
    2026-03-09 09:47:39.744  - info: host.iobtest instance system.adapter.vis.0 terminated while should be started once
    2026-03-09 09:47:41.039  - info: host.iobtest instance system.adapter.nspanel-lovelace-ui.0 in version "0.13.4" (non-npm: ticaki/ioBroker.nspanel-lovelace-ui#b8e5efbbe1973a36a4dfdb0f0e3e63c435630803) started with pid 28082
    2026-03-09 09:47:41.820  - info: nspanel-lovelace-ui.0 (28082) starting. Version 0.13.4 (non-npm: ticaki/ioBroker.nspanel-lovelace-ui#b8e5efbbe1973a36a4dfdb0f0e3e63c435630803) in /opt/iobroker/node_modules/iobroker.nspanel-lovelace-ui, node: v22.22.0, js-controller: 7.1.0
    2026-03-09 09:47:41.872  - info: nspanel-lovelace-ui.0 (28082) Configured panels: name#topic -> [Buero#SmartHome/NSPanel_1], [DEV-Panel#NSPanel_DEV]
    2026-03-09 09:47:41.872  - info: nspanel-lovelace-ui.0 (28082) Found 2 script configs for topics: SmartHome/NSPanel_1, NSPanel_DEV
    2026-03-09 09:47:41.872  - info: nspanel-lovelace-ui.0 (28082) Detailed configuration checks are suppressed here. Full validation output is only shown when the configuration script is sent to the adapter.
    2026-03-09 09:47:43.781  - info: nspanel-lovelace-ui.0 (28082) [Buero] Setting panel to offline until first message!
    2026-03-09 09:47:43.823  - info: nspanel-lovelace-ui.0 (28082) [DEV-Panel] Setting panel to offline until first message!
    2026-03-09 09:47:44.836  - info: host.iobtest instance system.adapter.public-transport.0 in version "0.0.5" (non-npm: tt-tom17/ioBroker.public-transport#335d0dd3595a1dd8da7aa69116f84923b001ff5b) started with pid 28097
    2026-03-09 09:47:45.575  - info: public-transport.0 (28097) starting. Version 0.0.5 (non-npm: tt-tom17/ioBroker.public-transport#335d0dd3595a1dd8da7aa69116f84923b001ff5b) in /opt/iobroker/node_modules/iobroker.public-transport, node: v22.22.0, js-controller: 7.1.0
    2026-03-09 09:47:45.634  - info: public-transport.0 (28097) HAFAS-Client initialisiert mit Profil: vbb
    2026-03-09 09:47:45.635  - info: public-transport.0 (28097) 1 aktive Station(en) gefunden:
    2026-03-09 09:47:45.635  - info: public-transport.0 (28097)   - S Zepernick (ID: 900350163)
    2026-03-09 09:47:45.635  - info: public-transport.0 (28097) Rufe Abfahrten ab für: S Zepernick (900350163)
    2026-03-09 09:47:46.241  - info: public-transport.0 (28097) Abfahrten aktualisiert für: S Zepernick (900350163)
    2026-03-09 09:47:46.241  - info: public-transport.0 (28097) Erste Abfrage abgeschlossen: 1 erfolgreich, 0 fehlgeschlagen
    2026-03-09 09:47:46.241  - info: public-transport.0 (28097) Warte auf die nächste Abfrage in 60 Minuten...
    2026-03-09 09:47:46.242  - info: public-transport.0 (28097) 1 aktive Station(en) gefunden:
    2026-03-09 09:47:46.242  - info: public-transport.0 (28097) Infos für: S Zepernick (900350163) abfragen...
    2026-03-09 09:47:50.280  - info: nspanel-lovelace-ui.0 (28082) [Buero] is online!
    2026-03-09 09:47:50.972  - info: nspanel-lovelace-ui.0 (28082) [controller] 2 Panels initialized
    2026-03-09 09:47:51.086  - info: nspanel-lovelace-ui.0 (28082) [Buero] Panel startup finished!
    #782
    @TT-Tom sagte in iob diag - Skript:
    Aus dem Verzeichnis, wo das heruntergeladene Skript liegt. Sollte i.d.R. das home-Verzeichnis des users sein.
    Die Meldung
    sollte eigentlich nicht kommen. Aber da es beim 'ordentlichen' Aufruf via 'iob diag' funktioniert ist es auch nicht weiter wichtig.
    Den ZibBee-Adapter hast du gar nicht am Start, dafür aber zigbee2mqtt. Passt also in der Ausgabe dann.
    Am Rande:
    Spiel das nodejs-Update ein. ;-)
    T 2 Antworten Letzte Antwort
    • S Abwesend
      S Abwesend
      Shadowhunter23
      schrieb am zuletzt editiert von Shadowhunter23
      #783
      Ob das was ausmacht kann @thomas-braun beantworten, dein User hat nicht alle Gruppen. Laut Anleitung müsstest du folgendes tun:
      Falls ein User nachträglich angelegt werden soll muss dieser noch per
      usermod -aG adm,dialout,sudo,audio,video,plugdev,users,iobroker tom
      den relevanten Gruppen hinzugefügt werden.
      Ich rufe das Script auch aus dem user Verzeichnis auf und es läuft ohne Probleme ( auch ein LXC ).
      Proxmox 9 HA-Cluster mit 3x HP prodesk 400 G6 i5
      ioBroker Backup Analyzer
        Die Meldung
        Am Rande:
        TT-Tom
        #784
        @Thomas-Braun
        okay dann ist die obere Ausgabe, wie geschrieben aus dem User-Verzeichnis und unten die normale iob diag vom ioBroker.
        mach ich :)
        Gruß Tom
        Public Transport
        NSPanel Adapter Wiki
        • S Shadowhunter23
          TT-Tom
          #785
          @Shadowhunter23
          bleiben die selben Meldungen
          Gruß Tom
          Public Transport
            Die Meldung
            Am Rande:
            TT-Tom
            #786
            @Thomas-Braun
            habe es mal mit unmask aufgerufen
            hier ein Fehler in der PanID, wobei ich ja kein Zigbee.0 habe und auch ein ZigbeeOnLan im System
            Pan ID:
            ./iob_diag.sh: line 693: printf: 0x906": invalid hex number
            2310
            die andern Zigbee Ausgaben passen.
            Gruß Tom
            Public Transport
            • T TT-Tom
              @Thomas-Braun
              Pan ID:
              2310
              #787
              Danke! Das muss ich abfangen, der Wert wird aus einem USB-Stick bzw. dem nvbackup ausgelesen. Wenn das nicht vorhanden ist kommt diese Meldung.
              Kannst du mir die Zigbee-Passage bei dir mal vollständig mit der --unmask Option zeigen?
              (Wobei, so ganz eigentlich sollte der Code gar nicht durchlaufen werden, wenn es keine zigbee.X Instanz gibt)
              • S Abwesend
                S Abwesend
                Shadowhunter23
                #788
                Schade das hier nicht viele mit Zigbee den Code von @thomas-braun testen.
                • S Shadowhunter23
                  #789
                  @Shadowhunter23 sagte in iob diag - Skript:
                  es geht doch jetzt um die absolut seltene Kombination von (mehreren) LAN mit einem oder mehreren USB Konvertern
                    TT-Tom
                    #790
                    @Thomas-Braun brauchst du jetzt nochmal Daten oder kommt eine neue Version zum Testen?
                    Gruß Tom
                    Public Transport
                    • T TT-Tom
                      #791
                      @TT-Tom
                      Die aktuellste Version ist immer laufend im ersten Thread verlinkt.
                      Frische Ausgaben sind immer gerne gesehen.
                      Am interessantesten wären aber momentan komplexere Setups was ZigBee angeht, da ist am meisten gefeilt worden.
                        S Abwesend
                        S Abwesend
                        Shadowhunter23
                        #792
                        @Homoran sagte in iob diag - Skript:
                        Und wie man gesehen hat, hatte @tt-tom auch Fehler und das hilft @thomas-braun
                        • NashraN Offline
                          NashraN Offline
                          Nashra
                          Most Active Forum Testing
                          #793
                          Moin, hier mal meine Ausgabe vom aktuellsten Skript.
                          ========== Langfassung ab hier markieren und kopieren ===========
                          ```bash
                          Script v.2026-03-10
                          *** GRUNDSYSTEM ***
                           Static hostname: ioBroker
                            Virtualization: lxc
                                    Kernel: Linux 6.17.9-1-pve
                          OS is similar to:
                          model name      : Intel(R) Core(TM) i3-8100 CPU @ 3.60GHz
                          CPU threads     : 4
                          Docker          : false
                          Kernel          : x86_64
                          Userland        : 64bit
                           08:24:36 up 34 days, 16:56,  0 users,  load average: 1.01, 0.70, 0.59
                          *** LEBENSZYKLUS STATUS ***
                          Das Betriebssystem ist das aktuelle, stabile Debian 'trixie'!
                          *** ZEIT UND ZEITZONEN ***               Local time: Thu 2026-03-12 08:24:37 CET
                                     Universal time: Thu 2026-03-12 07:24:37 UTC
                                           RTC time: n/a
                                    RTC in local TZ: no
                          *** User und Gruppen ***
                          User der 'iob diag' aufgerufen hat:
                          jack
                          HOME=/home/jack
                          GROUPS=jack sudo users iobroker
                          User der den 'js-controller' ausführt:
                          iobroker[sudo] password for jack:
                          HOME=/home/iobroker
                          SUDO_HOME=/home/jack
                          Desktop:
                          Session:
                          *** MEMORY ***
                          Mem:             12G        6.4G        5.7G        6.7M        884M        6.5G
                          Swap:             0B          0B          0B
                          Total:           12G        6.4G        5.7G
                          Active iob-Instances:   50
                                  12288 M total memory
                                   6057 M used memory
                                   4592 M active memory
                                   1999 M inactive memory
                                   5393 M free memory
                                      0 M buffer memory
                                    843 M swap cache
                                      0 M total swap
                                      0 M used swap
                                      0 M free swap
                          top - 08:24:42 up 34 days, 16:57,  0 users,  load average: 0.93, 0.69, 0.59
                          Tasks:  75 total,   1 running,  74 sleeping,   0 stopped,   0 zombie
                          %Cpu(s):  6.8 us,  0.0 sy,  0.0 ni, 90.9 id,  2.3 wa,  0.0 hi,  0.0 si,  0.0 st
                          MiB Mem :  12288.0 total,   5391.2 free,   6058.9 used,    844.1 buff/cache
                          MiB Swap:      0.0 total,      0.0 free,      0.0 used.   6229.1 avail Mem
                          0 loaded units listed.
                          Es wurden keine kritischen Fehler gefunden
                          *** FILESYSTEM ***
                          /dev/mapper/pve-vm--100--disk--0 ext4       25G   12G   13G  48% /
                          none                             tmpfs     8.0K  4.0K  4.0K  50% /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_a8533ff07196ed1182936c4ce259fb3e-if00-port0
                          udev                             devtmpfs  7.8G     0  7.8G   0% /dev/tty
                          tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
                          tmpfs                            tmpfs     3.2G  372K  3.2G   1% /run
                          tmpfs                            tmpfs     7.8G  6.0M  7.8G   1% /tmp
                          /      /dev/mapper/pve-vm--100--disk--0 ext4   rw,relatime,stripe=16
                          /var:
                          1.8G    /var/
                          1.3G    /var/log/journal/d283c01113b6426689c9fe48dd9c672b
                          1.3G    /var/log
                          277M    /var/cache
                          Archived and active journals take up 299.3M in the file system.
                          2.5G    /opt/iobroker/backups/
                          2.5G    /opt/iobroker/iobroker-data/
                          1.2G    /opt/iobroker/iobroker-data/files
                          651M    /opt/iobroker/iobroker-data/history
                          501M    /opt/iobroker/iobroker-data/backup-objects
                          269M    /opt/iobroker/iobroker-data/files/vis.0
                          81M     /opt/iobroker/iobroker-data/objects.jsonl
                          51M     /opt/iobroker/iobroker-data/states.jsonl
                          27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
                          26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
                          26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
                          USB-Devices by-id:
                          USB-Sticks - Vermeide direkte Links zu /dev/tty* in deinen Adapter-Einstellungen,
                          bevorzuge immer die Links 'by-id':
                          ✓ zigbee.0 COM-Port stimmt mit 'by-id' überein. Sehr gut!
                          zigbee.X
                          \nExtended Pan ID:
                          \n*** MASKED ***
                          \nPan ID:
                          \n*** MASKED ***
                          \nChannel:
                          \n*** MASKED ***
                          \nNetwork Key:
                          \n*** MASKED ***
                          === ZigBee-Port-Übersicht ===
                          Instanz         Konfigurierter Port                 Verfügbarer by-id-Port             Status
                          zigbee.0        ...936c4ce259fb3e-if00-port0        ...936c4ce259fb3e-if00-port0        ✓ Übereinstimmend
                          /usr/bin/nodejs         v22.22.1
                          /usr/bin/node           v22.22.1
                          /usr/bin/npm            10.9.4
                          /usr/bin/npx            10.9.4
                          ✓ Node.js ist korrekt installiert
                          nodejs:
                            Installed: 22.22.1-1nodesource1
                            Version table:
                           *** 22.22.1-1nodesource1 1001
                               20.19.2+dfsg-1 500
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          Hosts:
                          ioBroker            ioBroker (version: 7.0.7, hostname: ioBroker      , alive, uptime: 323440)
                          js-controller:  7.0.7
                          admin:          7.7.22
                          javascript:     9.0.18
                          nodejs modules from github:     7
                          +-- iobroker.email@2.0.5-alpha.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.email.git#929e50908b8836bdc66e1297323324ef763bd575)
                          +-- iobroker.icons-icons8@0.0.1 (git+ssh://git@github.com/ioBroker/ioBroker.icons-icons8.git#c0fcc9a6aa79b281951215cf86726f45622c8409)
                          +-- iobroker.labcom@0.1.4 (git+ssh://git@github.com/100prznt/ioBroker.labcom.git#0fae7c5e0f5c705838ff71922846fea7769b67fd)
                          +-- iobroker.logparser@2.4.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.logparser.git#266cccca93fd6f272ebce95e8f9e936363c30263)
                          | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
                          +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
                          +-- iobroker.vis-owl@0.2.13 (git+ssh://git@github.com/gerbuchner/ioBroker.vis-owl.git#26f227f5d70d75b265c03bb40c3e400d90013b84)
                          Adapter State
                          + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                          + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
                            system.adapter.alias-manager.0          : alias-manager         : ioBroker                                 - disabled
                          + system.adapter.ankersolix2.0            : ankersolix2           : ioBroker                                 -  enabled
                          + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
                            system.adapter.birthdays.0              : birthdays             : ioBroker                                 -  enabled
                            system.adapter.birthdays.1              : birthdays             : ioBroker                                 -  enabled
                          + system.adapter.brightsky.0              : brightsky             : ioBroker                                 -  enabled
                            system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
                            system.adapter.daswetter.1              : daswetter             : ioBroker                                 -  enabled
                          + system.adapter.deyeidc.0                : deyeidc               : ioBroker                                 -  enabled, port: 8899
                            system.adapter.dwd.0                    : dwd                   : ioBroker                                 -  enabled
                          + system.adapter.echarts.0                : echarts               : ioBroker                                 -  enabled
                          + system.adapter.email.0                  : email                 : ioBroker                                 -  enabled
                          + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: ioBroker                                 -  enabled
                          + system.adapter.energiefluss-erweitert.1 : energiefluss-erweitert: ioBroker                                 -  enabled
                            system.adapter.feiertage.0              : feiertage             : ioBroker                                 -  enabled
                            system.adapter.flot.0                   : flot                  : ioBroker                                 - disabled
                          + system.adapter.history.0                : history               : ioBroker                                 -  enabled
                            system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
                            system.adapter.ical.1                   : ical                  : ioBroker                                 -  enabled
                            system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: ioBroker                                 - disabled
                            system.adapter.icons-icons8.0           : icons-icons8          : ioBroker                                 - disabled
                            system.adapter.icons-material-png.0     : icons-material-png    : ioBroker                                 - disabled
                            system.adapter.icons-material-svg.0     : icons-material-svg    : ioBroker                                 - disabled
                            system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
                            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 - disabled
                            system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBroker                                 - disabled
                            system.adapter.influxdb.0               : influxdb              : ioBroker                                 - disabled, port: 8086
                          + system.adapter.influxdb.1               : influxdb              : ioBroker                                 -  enabled, port: 8086
                          + system.adapter.influxdb.2               : influxdb              : ioBroker                                 -  enabled, port: 8086
                          + system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
                          + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
                            system.adapter.labcom.0                 : labcom                : ioBroker                                 -  enabled
                          + system.adapter.lgtv.0                   : lgtv                  : ioBroker                                 -  enabled
                          + system.adapter.lgtv.1                   : lgtv                  : ioBroker                                 -  enabled
                          + system.adapter.linux-control.0          : linux-control         : ioBroker                                 -  enabled
                          + system.adapter.logparser.0              : logparser             : ioBroker                                 -  enabled
                          + system.adapter.nut.0                    : nut                   : ioBroker                                 -  enabled
                          + system.adapter.nut.1                    : nut                   : ioBroker                                 -  enabled
                            system.adapter.nut.2                    : nut                   : ioBroker                                 - disabled
                          + system.adapter.nut.3                    : nut                   : ioBroker                                 -  enabled
                          + system.adapter.open-meteo-weather.0     : open-meteo-weather    : ioBroker                                 -  enabled
                          + system.adapter.open-meteo-weather.1     : open-meteo-weather    : ioBroker                                 -  enabled
                            system.adapter.openweathermap.0         : openweathermap        : ioBroker                                 -  enabled
                          + system.adapter.parcel.0                 : parcel                : ioBroker                                 -  enabled
                          + system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
                          + system.adapter.pirate-weather.0         : pirate-weather        : ioBroker                                 -  enabled
                          + system.adapter.pollenflug.0             : pollenflug            : ioBroker                                 -  enabled
                          + system.adapter.pollenflug.1             : pollenflug            : ioBroker                                 -  enabled
                          + system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
                          + system.adapter.rest-api.0               : rest-api              : ioBroker                                 -  enabled, port: 8093, bind: 0.0.0.0, run as: rest
                            system.adapter.rssfeed.0                : rssfeed               : ioBroker                                 - disabled
                          + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                          + system.adapter.shelly.1                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                          + system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                          + system.adapter.snmp.0                   : snmp                  : ioBroker                                 -  enabled
                            system.adapter.socketio.0               : socketio              : ioBroker                                 - disabled, port: 8084, bind: 0.0.0.0, run as: admin
                          + system.adapter.synology.0               : synology              : ioBroker                                 -  enabled, port: 5000
                          + system.adapter.synology.1               : synology              : ioBroker                                 -  enabled, port: 5000
                            system.adapter.synology.2               : synology              : ioBroker                                 - disabled, port: 5000
                          + system.adapter.tagesschau.0             : tagesschau            : ioBroker                                 -  enabled
                          + system.adapter.tankerkoenig.0           : tankerkoenig          : ioBroker                                 -  enabled
                          + system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
                          + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
                          + system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
                          + system.adapter.unifi-network.0          : unifi-network         : ioBroker                                 -  enabled, port: 443
                            system.adapter.unifi.0                  : unifi                 : ioBroker                                 - disabled
                          + system.adapter.upnp.0                   : upnp                  : ioBroker                                 -  enabled
                            system.adapter.vis-2-widgets-icontwo.0  : vis-2-widgets-icontwo : ioBroker                                 - disabled
                            system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: ioBroker                                 - disabled
                            system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: ioBroker                                 - disabled
                            system.adapter.vis-2.0                  : vis-2                 : ioBroker                                 - disabled
                            system.adapter.vis-bars.0               : vis-bars              : ioBroker                                 - disabled
                            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker                                 - disabled
                            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker                                 - disabled
                            system.adapter.vis-google-fonts.0       : vis-google-fonts      : ioBroker                                 -  enabled
                            system.adapter.vis-history.0            : vis-history           : ioBroker                                 - disabled
                            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
                            system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 - disabled
                          + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
                            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
                            system.adapter.vis-justgage.0           : vis-justgage          : ioBroker                                 - disabled
                            system.adapter.vis-map.0                : vis-map               : ioBroker                                 - disabled
                            system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker                                 - disabled
                            system.adapter.vis-owl.0                : vis-owl               : ioBroker                                 - disabled
                            system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker                                 - disabled
                            system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
                            system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
                          + system.adapter.weather-warnings.0       : weather-warnings      : ioBroker                                 -  enabled
                            system.adapter.weatherunderground.0     : weatherunderground    : ioBroker                                 -  enabled
                            system.adapter.weatherunderground.1     : weatherunderground    : ioBroker                                 -  enabled
                          + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 192.168.1.14, run as: admin
                            system.adapter.wettercom.0              : wettercom             : ioBroker                                 - disabled
                          + system.adapter.ws.0                     : ws                    : ioBroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                          + system.adapter.zigbee.0                 : zigbee                : ioBroker                                 -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_a8533ff07196ed1182936c4ce259fb3e-if00-port0
                          + instance is alive
                          │ (index) │ name               │ url                                                     │ auto upgrade │
                          │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
                          │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
                          │ 2       │ 'stable-live'      │ 'http://iobroker.live/repo/sources-dist.json'           │ false        │
                          │ 3       │ 'latest-live'      │ 'http://iobroker.live/repo/sources-dist-latest.json'    │ false        │
                          Adapter    "admin"        : 7.7.22   , installed 7.7.22
                          Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
                          Adapter    "ankersolix2"  : 2.4.1    , installed 2.4.1
                          Adapter    "backitup"     : 3.3.13   , installed 3.3.13
                          Adapter    "birthdays"    : 5.0.0    , installed 5.0.0
                          Adapter    "brightsky"    : 0.6.6    , installed 0.6.6
                          Adapter    "daswetter"    : 3.2.8    , installed 3.2.8
                          Adapter    "deyeidc"      : 0.3.1    , installed 0.3.1
                          Adapter    "echarts"      : 1.9.2    , installed 1.9.2
                          Adapter    "email"        : 2.0.4    , installed 2.0.5-alpha.0
                          Adapter    "energiefluss-erweitert": 0.8.1, installed 0.8.1
                          Adapter    "feiertage"    : 1.3.0    , installed 1.3.0
                          Adapter    "ical"         : 1.18.1   , installed 1.18.1
                          Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
                          Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
                          Adapter    "iot"          : 5.0.7    , installed 5.0.7
                          Controller "js-controller": 7.0.7    , installed 7.0.7
                          Adapter    "lgtv"         : 2.5.0    , installed 2.5.0
                          Adapter    "linux-control": 1.1.5    , installed 1.1.5
                          Adapter    "logparser"    : 2.4.0    , installed 2.4.0
                          Adapter    "nut"          : 1.6.0    , installed 1.6.0
                          Adapter    "openweathermap": 1.1.2   , installed 1.1.2
                          Adapter    "ping"         : 1.7.9    , installed 2.0.0
                          Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
                          Adapter    "rest-api"     : 4.0.1    , installed 4.0.1
                          Adapter    "rssfeed"      : 3.6.1    , installed 3.6.1
                          Adapter    "shelly"       : 10.5.2   , installed 10.5.2
                          Adapter    "snmp"         : 3.4.0    , installed 3.4.0
                          Adapter    "synology"     : 3.1.0    , installed 3.1.0
                          Adapter    "tagesschau"   : 0.6.0    , installed 0.6.0
                          Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                          Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                          Adapter    "tuya"         : 3.16.0   , installed 3.16.0
                          Adapter    "unifi"        : 0.7.0    , installed 0.7.0
                          Adapter    "unifi-network": 1.3.1    , installed 1.3.1
                          Adapter    "upnp"         : 1.1.0    , installed 1.1.0
                          Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
                          Adapter    "vis-2-widgets-icontwo": 1.25.0, installed 1.25.0
                          Adapter    "vis-2-widgets-inventwo": 0.5.5, installed 0.5.5
                          Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
                          Adapter    "vis-icontwo"  : 2.11.1   , installed 2.11.1
                          Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
                          Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
                          Adapter    "weather-warnings": 0.10.0, installed 0.10.0
                          Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                          Adapter    "web"          : 7.0.8    , installed 7.0.8
                          Adapter    "ws"           : 2.6.2    , installed 3.0.19
                          Adapter    "zigbee"       : 3.3.5    , installed 3.3.5
                          Objects and States
                          Objects:        66803
                          States:         59093
                          Hit:1 http://deb.debian.org/debian trixie InRelease
                          Hit:2 http://security.debian.org trixie-security InRelease
                          Offene Systemupdates: 0
                          udp       UNCONN     0          0                    0.0.0.0:sunrpc              0.0.0.0:*         users:(("rpcbind",pid=139,fd=5),("systemd",pid=1,fd=35))
                          udp       UNCONN     0          0                    0.0.0.0:33004               0.0.0.0:*         users:(("io.snmp.0",pid=3117533,fd=30))
                          udp       UNCONN     0          0                    0.0.0.0:41470               0.0.0.0:*         users:(("io.snmp.0",pid=3117533,fd=31))
                          udp       UNCONN     0          0                    0.0.0.0:1900                0.0.0.0:*         users:(("io.upnp.0",pid=3118428,fd=31))
                          udp       UNCONN     0          0                    0.0.0.0:51694               0.0.0.0:*         users:(("io.upnp.0",pid=3118428,fd=30))
                          udp       UNCONN     0          0               192.168.1.14:mdns                0.0.0.0:*         users:(("io.tr-064.0",pid=3117618,fd=62))
                          udp       UNCONN     0          0                    0.0.0.0:coap                0.0.0.0:*         users:(("io.shelly.0",pid=3117502,fd=39))
                          udp       UNCONN     0          0                    0.0.0.0:6666                0.0.0.0:*         users:(("io.tuya.0",pid=3117634,fd=44))
                          udp       UNCONN     0          0                    0.0.0.0:6667                0.0.0.0:*         users:(("io.tuya.0",pid=3117634,fd=45))
                          udp       UNCONN     0          0                       [::]:sunrpc                 [::]:*         users:(("rpcbind",pid=139,fd=7),("systemd",pid=1,fd=37))
                          tcp       LISTEN     0          4096                 0.0.0.0:sunrpc              0.0.0.0:*         users:(("rpcbind",pid=139,fd=4),("systemd",pid=1,fd=34))
                          tcp       LISTEN     0          511                  0.0.0.0:9000                0.0.0.0:*         users:(("iobroker.js-con",pid=3116170,fd=29))
                          tcp       LISTEN     0          511                  0.0.0.0:9001                0.0.0.0:*         users:(("iobroker.js-con",pid=3116170,fd=23))
                          tcp       LISTEN     0          511                  0.0.0.0:1882                0.0.0.0:*         users:(("io.shelly.1",pid=3117518,fd=31))
                          tcp       LISTEN     0          1                    0.0.0.0:9999                0.0.0.0:*         users:(("nc",pid=1156031,fd=3))
                          tcp       LISTEN     0          511             192.168.1.14:8082                0.0.0.0:*         users:(("io.web.0",pid=3118942,fd=30))
                          tcp       LISTEN     0          100                127.0.0.1:smtp                0.0.0.0:*         users:(("master",pid=306,fd=13))
                          tcp       LISTEN     0          4096                    [::]:sunrpc                 [::]:*         users:(("rpcbind",pid=139,fd=6),("systemd",pid=1,fd=36))
                          tcp       LISTEN     0          4096                       *:ssh                       *:*         users:(("sshd",pid=180,fd=3),("systemd",pid=1,fd=52))
                          tcp       LISTEN     0          100                    [::1]:smtp                   [::]:*         users:(("master",pid=306,fd=14))
                          tcp       LISTEN     0          511                        *:tproxy                    *:*         users:(("io.admin.0",pid=3116193,fd=32))
                          tcp       LISTEN     0          511                        *:8084                      *:*         users:(("io.ws.0",pid=3118962,fd=29))
                          tcp       LISTEN     0          511                        *:8087                      *:*         users:(("io.simple-api.0",pid=3118340,fd=29))
                          tcp       LISTEN     0          511                        *:8093                      *:*         users:(("io.rest-api.0",pid=3589791,fd=29))
                          2026-03-12 08:20:00.004  - info: javascript.0 (3116315) script.js.Heizungen.Raumklima: Absolute Luftfeuchte in Waeschezimmer gespeichert in 0_userdata.0.Raumklima.Lueftungsempfehlung.AbsoluteLuftfeuchtigkeit.Waeschezimmer: 11.24 g/m³
                          2026-03-12 08:20:00.004  - info: javascript.0 (3116315) script.js.Heizungen.Raumklima: Taupunkt in Waeschezimmer gespeichert in 0_userdata.0.Raumklima.Taupunkt.Waeschezimmer: 16.08 °C
                          2026-03-12 08:20:00.005  - info: javascript.0 (3116315) script.js.Heizungen.Raumklima: [Waeschezimmer] Fixed Calculation: RH_in=65.5%, Threshold=60 -> Empfehlung Lüften: true
                          2026-03-12 08:20:00.005  - info: javascript.0 (3116315) script.js.Heizungen.Raumklima: [Waeschezimmer] Absolute Humidity Calculation: AH_in=11.24 g/m³, AH_out=6.67 g/m³, Offset=0 -> Lüften senkt Luftfeuchte: true
                          2026-03-12 08:20:00.005  - info: javascript.0 (3116315) script.js.Heizungen.Raumklima: Absolute Luftfeuchte in Flur gespeichert in 0_userdata.0.Raumklima.Lueftungsempfehlung.AbsoluteLuftfeuchtigkeit.Flur: 12.18 g/m³
                          2026-03-12 08:20:00.005  - info: javascript.0 (3116315) script.js.Heizungen.Raumklima: Taupunkt in Flur gespeichert in 0_userdata.0.Raumklima.Taupunkt.Flur: 17.38 °C
                          2026-03-12 08:20:00.005  - info: javascript.0 (3116315) script.js.Heizungen.Raumklima: [Flur] Fixed Calculation: RH_in=66.5%, Threshold=60 -> Empfehlung Lüften: true
                          2026-03-12 08:20:00.005  - info: javascript.0 (3116315) script.js.Heizungen.Raumklima: [Flur] Absolute Humidity Calculation: AH_in=12.18 g/m³, AH_out=6.67 g/m³, Offset=0 -> Lüften senkt Luftfeuchte: true
                          2026-03-12 08:20:00.005  - info: javascript.0 (3116315) script.js.Heizungen.Raumklima: Absolute Luftfeuchte in Schlafzimmer gespeichert in 0_userdata.0.Raumklima.Lueftungsempfehlung.AbsoluteLuftfeuchtigkeit.Schlafzimmer: 10.16 g/m³
                          2026-03-12 08:20:00.005  - info: javascript.0 (3116315) script.js.Heizungen.Raumklima: Taupunkt in Schlafzimmer gespeichert in 0_userdata.0.Raumklima.Taupunkt.Schlafzimmer: 14.58 °C
                          2026-03-12 08:20:00.005  - info: javascript.0 (3116315) script.js.Heizungen.Raumklima: [Schlafzimmer] Fixed Calculation: RH_in=52%, Threshold=60 -> Empfehlung Lüften: false
                          2026-03-12 08:20:00.005  - info: javascript.0 (3116315) script.js.Heizungen.Raumklima: [Schlafzimmer] Absolute Humidity Calculation: AH_in=10.16 g/m³, AH_out=6.67 g/m³, Offset=0 -> Lüften senkt Luftfeuchte: true
                          2026-03-12 08:20:00.005  - info: javascript.0 (3116315) script.js.Heizungen.Raumklima: Absolute Luftfeuchte in Werkstatt gespeichert in 0_userdata.0.Raumklima.Lueftungsempfehlung.AbsoluteLuftfeuchtigkeit.Werkstatt: 8.55 g/m³
                          2026-03-12 08:20:00.005  - info: javascript.0 (3116315) script.js.Heizungen.Raumklima: Taupunkt in Werkstatt gespeichert in 0_userdata.0.Raumklima.Taupunkt.Werkstatt: 11.77 °C
                          2026-03-12 08:20:00.005  - info: javascript.0 (3116315) script.js.Heizungen.Raumklima: [Werkstatt] Fixed Calculation: RH_in=60%, Threshold=60 -> Empfehlung Lüften: true
                          2026-03-12 08:20:00.005  - info: javascript.0 (3116315) script.js.Heizungen.Raumklima: [Werkstatt] Absolute Humidity Calculation: AH_in=8.55 g/m³, AH_out=6.67 g/m³, Offset=0 -> Lüften senkt Luftfeuchte: true
                          2026-03-12 08:20:00.005  - info: javascript.0 (3116315) script.js.Heizungen.Raumklima: runCalculation ausgelöst (10-Minuten-Intervall)
                          2026-03-12 08:20:47.703  - info: javascript.0 (3116315) script.js.Wetter.Statistik-md: Material Design Widgets: Wetter Skript triggered by '0_userdata.0.Wetterstation.Aussentemperatur'
                          2026-03-12 08:21:49.490  - info: javascript.0 (3116315) script.js.Wetter.Statistik-md: Material Design Widgets: Wetter Skript triggered by '0_userdata.0.Wetterstation.Aussentemperatur'
                          2026-03-12 08:22:33.787  - info: javascript.0 (3116315) script.js.Ereignisse.Büroheizung: Warm Heizung-Büro ist aus
                          2026-03-12 08:22:33.881  - info: javascript.0 (3116315) script.js.Ereignisse.Büroheizung: Warm Heizung-Büro ist an
                          2026-03-12 08:22:55.351  - info: javascript.0 (3116315) script.js.Wetter.Statistik-md: Material Design Widgets: Wetter Skript triggered by '0_userdata.0.Wetterstation.Aussentemperatur'
                          2026-03-12 08:23:00.043  - info: javascript.0 (3116315) script.js.Ereignisse.Büroheizung: Warm Heizung-Büro ist aus
                          2026-03-12 08:23:59.365  - info: javascript.0 (3116315) script.js.Wetter.Statistik-md: Material Design Widgets: Wetter Skript triggered by '0_userdata.0.Wetterstation.Aussentemperatur'
                          2026-03-12 08:25:03.670  - info: javascript.0 (3116315) script.js.Wetter.Statistik-md: Material Design Widgets: Wetter Skript triggered by '0_userdata.0.Wetterstation.Aussentemperatur'
                          ============ Langfassung bis hier markieren =============
                          Gruß Ralf
                          • NashraN Nashra
                            ```bash
                            Script v.2026-03-10
                            *** GRUNDSYSTEM ***
                              Virtualization: lxc
                            OS is similar to:
                            CPU threads     : 4
                            Docker          : false
                            Kernel          : x86_64
                            Userland        : 64bit
                                             RTC time: n/a
                                      RTC in local TZ: no
                            jack
                            HOME=/home/jack
                            HOME=/home/iobroker
                            Desktop:
                            Session:
                            *** MEMORY ***
                            Swap:             0B          0B          0B
                                     6057 M used memory
                                     5393 M free memory
                                        0 M buffer memory
                                      843 M swap cache
                                        0 M total swap
                                        0 M used swap
                                        0 M free swap
                            *** FILESYSTEM ***
                            /var:
                            1.8G    /var/
                            1.3G    /var/log
                            277M    /var/cache
                            USB-Devices by-id:
                            zigbee.X
                            \nExtended Pan ID:
                            \n*** MASKED ***
                            \nPan ID:
                            \n*** MASKED ***
                            \nChannel:
                            \n*** MASKED ***
                            \nNetwork Key:
                            \n*** MASKED ***
                            /usr/bin/npm            10.9.4
                            /usr/bin/npx            10.9.4
                            nodejs:
                              Version table:
                                 20.19.2+dfsg-1 500
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Hosts:
                            admin:          7.7.22
                            javascript:     9.0.18
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects:        66803
                            States:         59093
                            #794
                            @Nashra
                            Ah, mal die --de Version. Sehr schön.
                            Bei
                                             RTC time: n/a
                            fehlt offenbar ein Zeilensprung.
                            Und bei den Netzwerkports fehlen die gebunden Ports, glaube ich. Muss ich mir später mal genauer anschauen.
                            • Thomas BraunT Online
                              #795
                              Mal nur so zum Test, ob die neuste Version auch noch komplett in ein Forenposting passt. Es sind noch ein paar Kleinigkeiten dazu gekommen.
                              Script v.2026-05-18
                              *** BASE SYSTEM ***
                               Static hostname: chet
                                     Icon name: computer
                                        Kernel: Linux 6.18.29+rpt-rpi-v8
                                  Architecture: arm64
                              OS is similar to:
                              Model           : Raspberry Pi 4 Model B Rev 1.4
                              Docker          : false
                              Virtualization  : none
                              Kernel          : aarch64
                              Userland        : 64bit
                               23:43:24 up 2 days,  1:51,  1 user,  load average: 0.65, 0.41, 0.38
                              CPU threads     : 4
                              *** RASPBERRY THROTTLING ***
                              Current issues:
                              Previously detected issues:
                                             Local time: Mon 2026-05-18 23:43:24 CEST
                                         Universal time: Mon 2026-05-18 21:43:24 UTC
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              echad
                              HOME=/home/echad
                              GROUPS=echad adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                              iobroker
                              HOME=/home/iobroker
                              GROUPS=iobroker tty dialout audio video plugdev bluetooth redis gpio i2c
                              Desktop:
                              Session:                tty
                              Boot Target:            multi-user.target
                              *** MEMORY ***
                              Mem:            8.2G        5.6G        834M         26M        1.9G        2.6G
                              Swap:           2.1G         28M        2.1G
                              Total:           10G        5.6G        3.0G
                              Active iob-Instances:   38
                                       7818 M total memory
                                       5358 M used memory
                                       3593 M active memory
                                       2760 M inactive memory
                                        795 M free memory
                                        436 M buffer memory
                                       1353 M swap cache
                                       2047 M total swap
                                         27 M used swap
                                       2020 M free swap
                              top - 23:43:25 up 2 days,  1:51,  1 user,  load average: 0.76, 0.44, 0.39
                              Tasks: 214 total,   1 running, 213 sleeping,   0 stopped,   0 zombie
                              %Cpu(s):  0.0 us,  4.5 sy,  0.0 ni, 95.5 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                              MiB Mem :   7818.8 total,    795.3 free,   5358.7 used,   1789.5 buff/cache
                              MiB Swap:   2048.0 total,   2020.7 free,     27.3 used.   2460.1 avail Mem
                              *** FILESYSTEM ***
                              udev           devtmpfs  3.6G     0  3.6G   0% /dev
                              tmpfs          tmpfs     1.6G   23M  1.6G   2% /run
                              /dev/sda2      ext4      110G   18G   87G  17% /
                              tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                              tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
                              tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
                              tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-resolved.service
                              tmpfs          tmpfs     3.9G  2.6M  3.9G   1% /tmp
                              /dev/sda1      vfat      510M   75M  436M  15% /boot/firmware
                              tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
                              tmpfs          tmpfs     782M  8.0K  782M   1% /run/user/1000
                              [Sat May 16 21:51:29 2026] EXT4-fs (sda2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
                              [Sat May 16 21:51:30 2026] EXT4-fs (sda2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w.
                              /                /dev/sda2 ext4   rw,noatime
                              `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                              /var:
                              5.1G    /var/
                              2.8G    /var/cache/apt
                              2.8G    /var/cache
                              2.6G    /var/cache/apt/archives
                              302M    /var/lib
                              Archived and active journals take up 45.6M in the file system.
                              4.0K    /opt/iobroker/backups/
                              1.1G    /opt/iobroker/iobroker-data/
                              645M    /opt/iobroker/iobroker-data/history
                              186M    /opt/iobroker/iobroker-data/files
                              186M    /opt/iobroker/iobroker-data/backup-objects
                              65M     /opt/iobroker/iobroker-data/history/20250702
                              32M     /opt/iobroker/iobroker-data/objects.jsonl
                              30M     /opt/iobroker/iobroker-data/files/notification-manager.admin/build/index.js.map
                              12M     /opt/iobroker/iobroker-data/history/20260518/history.0_userdata.0.stromzaehler.SML.aktuelle_wirkleistung.json
                              12M     /opt/iobroker/iobroker-data/history/20260517/history.0_userdata.0.stromzaehler.SML.aktuelle_wirkleistung.json
                              12M     /opt/iobroker/iobroker-data/history/20260516/history.0_userdata.0.stromzaehler.SML.aktuelle_wirkleistung.json
                              USB-Devices by-id:
                              /dev/serial/by-id/usb-Silicon_Labs_slae.sh_cc2652rb_stick_-_slaesh_s_iot_stuff_00_12_4B_00_23_93_2C_A8-if00-port0
                              ✓ Your zigbee.0 COM-Port is matching 'by-id'. Very good!
                              zigbee.X
                              Extended Pan ID:
                              *** MASKED ***
                              Pan ID:
                              *** MASKED ***
                              Channel:
                              *** MASKED ***
                              Network Key:
                              *** MASKED ***
                              === ZigBee Port Overview ===
                              Instance        Configured Port                     Available by-id Port                Status
                              zigbee.0        ...00_23_93_2C_A8-if00-port0        ...00_23_93_2C_A8-if00-port0        ✓ Matching
                              /usr/bin/nodejs         v24.15.0
                              /usr/bin/node           v24.15.0
                              /usr/bin/npm            11.12.1
                              /usr/bin/npx            11.12.1
                              nodejs:
                                Installed: 24.15.0-1nodesource1
                                Candidate: 24.15.0-1nodesource1
                                Version table:
                               *** 24.15.0-1nodesource1 1001
                                      500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages
                                   24.14.1-1nodesource1 1001
                                   24.14.0-1nodesource1 1001
                                   24.13.1-1nodesource1 1001
                                   24.13.0-1nodesource1 1001
                                   24.12.0-1nodesource1 1001
                                   24.11.1-1nodesource1 1001
                                   24.11.0-1nodesource1 1001
                                   24.10.0-1nodesource1 1001
                                   24.9.0-1nodesource1 1001
                                   24.8.0-1nodesource1 1001
                                   24.7.0-1nodesource1 1001
                                   24.6.0-1nodesource1 1001
                                   24.5.0-1nodesource1 1001
                                   24.4.1-1nodesource1 1001
                                   24.4.0-1nodesource1 1001
                                   24.3.0-1nodesource1 1001
                                   24.1.0-1nodesource1 1001
                                   24.0.2-1nodesource1 1001
                                   24.0.1-1nodesource1 1001
                                   24.0.0-1nodesource1 1001
                                   20.19.2+dfsg-1+deb13u2 500
                                      500 http://deb.debian.org/debian trixie/main arm64 Packages
                                      500 http://deb.debian.org/debian-security trixie-security/main arm64 Packages
                              No known Vulnerabilities detected!
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              Hosts:
                              chet                chet (version: 7.1.2, hostname: chet          , alive, uptime: 179522)
                              js-controller:  7.1.2
                              admin:          7.8.25
                              javascript:     9.2.2
                              +-- iobroker.govee-app@0.0.10 (git+ssh://git@github.com/TA2k/ioBroker.govee-app.git#d5e7f1703b520238db36cd1552c54cdfa89c6715)
                              | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
                              +-- iobroker.switchbot-hub@0.1.2 (git+ssh://git@github.com/DrozmotiX/ioBroker.switchbot-hub.git#7a05fa59dfc5e3ce8d73018badc4e420996452f8)
                              Adapter State
                              + system.adapter.admin.0                  : admin                 : chet                                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                              + system.adapter.alexa2.0                 : alexa2                : chet                                     -  enabled
                              + system.adapter.ankersolix2.0            : ankersolix2           : chet                                     -  enabled
                              + system.adapter.awtrix-light.0           : awtrix-light          : chet                                     -  enabled
                              + system.adapter.backitup.0               : backitup              : chet                                     -  enabled
                              + system.adapter.ble.0                    : ble                   : chet                                     -  enabled
                              + system.adapter.cloud.0                  : cloud                 : chet                                     -  enabled
                              + system.adapter.echarts.0                : echarts               : chet                                     -  enabled
                              + system.adapter.firetv.0                 : firetv                : chet                                     -  enabled
                              + system.adapter.followthesun.0           : followthesun          : chet                                     -  enabled
                              + system.adapter.govee-app.0              : govee-app             : chet                                     -  enabled
                                system.adapter.govee-local.0            : govee-local           : chet                                     - disabled
                              + system.adapter.history.0                : history               : chet                                     -  enabled
                                system.adapter.ical.0                   : ical                  : chet                                     -  enabled
                                system.adapter.iceroad.0                : iceroad               : chet                                     -  enabled
                              + system.adapter.iot.0                    : iot                   : chet                                     -  enabled
                              + system.adapter.javascript.0             : javascript            : chet                                     -  enabled
                              + system.adapter.mihome-cloud.0           : mihome-cloud          : chet                                     -  enabled, port: 9898, bind: 0.0.0.0
                              + system.adapter.mihome-vacuum.0          : mihome-vacuum         : chet                                     -  enabled, port: 54321, bind: 0.0.0.0
                              + system.adapter.mihome.0                 : mihome                : chet                                     -  enabled, port: 9898, bind: 0.0.0.0
                              + system.adapter.mqtt.0                   : mqtt                  : chet                                     -  enabled, port: 1883, bind: 0.0.0.0
                              + system.adapter.nina.0                   : nina                  : chet                                     -  enabled
                              + system.adapter.notification-manager.0   : notification-manager  : chet                                     -  enabled
                              + system.adapter.nuki-extended.0          : nuki-extended         : chet                                     -  enabled
                              + system.adapter.nut.0                    : nut                   : chet                                     -  enabled
                              + system.adapter.opendtu.0                : opendtu               : chet                                     -  enabled
                                system.adapter.openweathermap.0         : openweathermap        : chet                                     -  enabled
                              + system.adapter.parcel.0                 : parcel                : chet                                     -  enabled
                                system.adapter.playstation.0            : playstation           : chet                                     - disabled
                              + system.adapter.rpi2.0                   : rpi2                  : chet                                     -  enabled
                              + system.adapter.sainlogic.0              : sainlogic             : chet                                     -  enabled, port: 45000, bind: 0.0.0.0
                                system.adapter.samsung.0                : samsung               : chet                                     - disabled
                                system.adapter.samsung_tizen.0          : samsung_tizen         : chet                                     - disabled, port: 8002
                              + system.adapter.switchbot-hub.0          : switchbot-hub         : chet                                     -  enabled
                              + system.adapter.tado.0                   : tado                  : chet                                     -  enabled
                              + system.adapter.tr-064.0                 : tr-064                : chet                                     -  enabled
                              + system.adapter.tradfri.0                : tradfri               : chet                                     -  enabled
                              + system.adapter.trashschedule.0          : trashschedule         : chet                                     -  enabled
                              + system.adapter.tuya.0                   : tuya                  : chet                                     -  enabled
                              + system.adapter.weather-warnings.0       : weather-warnings      : chet                                     -  enabled
                              + system.adapter.web.0                    : web                   : chet                                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                              + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : chet                                     -  enabled
                              + system.adapter.ws.0                     : ws                    : chet                                     -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                              + system.adapter.zigbee.0                 : zigbee                : chet                                     -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_slae.sh_cc2652rb_stick_-_slaesh_s_iot_stuff_00_12_4B_00_23_93_2C_A8-if00-port0
                              + instance is alive
                              │ 0       │ 'beta'        │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
                              │ 1       │ 'live-stable' │ 'http://iobroker.live/repo/sources-dist.json'           │ false        │
                              │ 2       │ 'live-beta'   │ 'http://iobroker.live/repo/sources-dist-latest.json'    │ false        │
                              │ 3       │ 'stable'      │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
                              │ (index) │ id                                    │ name                   │ version  │ upgrade policy │
                              │ 0       │ 'system.adapter.admin'                │ 'admin'                │ '7.8.25' │ 'none'         │
                              │ 1       │ 'system.adapter.alexa2'               │ 'alexa2'               │ '3.27.4' │ 'none'         │
                              │ 2       │ 'system.adapter.ankersolix2'          │ 'ankersolix2'          │ '2.4.1'  │ 'none'         │
                              │ 3       │ 'system.adapter.awtrix-light'         │ 'awtrix-light'         │ '3.0.0'  │ 'none'         │
                              │ 4       │ 'system.adapter.backitup'             │ 'backitup'             │ '3.3.17' │ 'none'         │
                              │ 5       │ 'system.adapter.ble'                  │ 'ble'                  │ '0.14.1' │ 'none'         │
                              │ 6       │ 'system.adapter.cloud'                │ 'cloud'                │ '6.0.4'  │ 'none'         │
                              │ 7       │ 'system.adapter.echarts'              │ 'echarts'              │ '3.1.0'  │ 'none'         │
                              │ 8       │ 'system.adapter.firetv'               │ 'firetv'               │ '2.2.0'  │ 'none'         │
                              │ 9       │ 'system.adapter.followthesun'         │ 'followthesun'         │ '0.5.2'  │ 'none'         │
                              │ 10      │ 'system.adapter.govee-app'            │ 'govee-app'            │ '0.0.10' │ 'none'         │
                              │ 11      │ 'system.adapter.govee-local'          │ 'govee-local'          │ '0.4.6'  │ 'none'         │
                              │ 12      │ 'system.adapter.history'              │ 'history'              │ '4.0.0'  │ 'none'         │
                              │ 13      │ 'system.adapter.ical'                 │ 'ical'                 │ '1.20.1' │ 'none'         │
                              │ 14      │ 'system.adapter.iceroad'              │ 'iceroad'              │ '1.2.1'  │ 'none'         │
                              │ 15      │ 'system.adapter.iot'                  │ 'iot'                  │ '6.0.3'  │ 'none'         │
                              │ 16      │ 'system.adapter.javascript'           │ 'javascript'           │ '9.2.2'  │ 'none'         │
                              │ 17      │ 'system.adapter.mihome'               │ 'mihome'               │ '1.4.0'  │ 'none'         │
                              │ 18      │ 'system.adapter.mihome-cloud'         │ 'mihome-cloud'         │ '1.0.6'  │ 'none'         │
                              │ 19      │ 'system.adapter.mihome-vacuum'        │ 'mihome-vacuum'        │ '5.3.0'  │ 'none'         │
                              │ 20      │ 'system.adapter.mqtt'                 │ 'mqtt'                 │ '6.1.4'  │ 'none'         │
                              │ 21      │ 'system.adapter.nina'                 │ 'nina'                 │ '0.0.26' │ 'none'         │
                              │ 22      │ 'system.adapter.notification-manager' │ 'notification-manager' │ '1.3.0'  │ 'none'         │
                              │ 23      │ 'system.adapter.nuki-extended'        │ 'nuki-extended'        │ '2.8.2'  │ 'none'         │
                              │ 24      │ 'system.adapter.nut'                  │ 'nut'                  │ '1.7.0'  │ 'none'         │
                              │ 25      │ 'system.adapter.opendtu'              │ 'opendtu'              │ '3.1.0'  │ 'none'         │
                              │ 26      │ 'system.adapter.openweathermap'       │ 'openweathermap'       │ '1.4.0'  │ 'none'         │
                              │ 27      │ 'system.adapter.parcel'               │ 'parcel'               │ '0.3.1'  │ 'none'         │
                              │ 28      │ 'system.adapter.playstation'          │ 'playstation'          │ '0.0.3'  │ 'none'         │
                              │ 29      │ 'system.adapter.rpi2'                 │ 'rpi2'                 │ '3.0.2'  │ 'none'         │
                              │ 30      │ 'system.adapter.sainlogic'            │ 'sainlogic'            │ '1.2.1'  │ 'none'         │
                              │ 31      │ 'system.adapter.samsung'              │ 'samsung'              │ '0.7.0'  │ 'none'         │
                              │ 32      │ 'system.adapter.samsung_tizen'        │ 'samsung_tizen'        │ '1.1.0'  │ 'none'         │
                              │ 33      │ 'system.adapter.switchbot-hub'        │ 'switchbot-hub'        │ '0.1.2'  │ 'none'         │
                              │ 34      │ 'system.adapter.tado'                 │ 'tado'                 │ '0.8.4'  │ 'none'         │
                              │ 35      │ 'system.adapter.tr-064'               │ 'tr-064'               │ '4.3.0'  │ 'none'         │
                              │ 36      │ 'system.adapter.tradfri'              │ 'tradfri'              │ '3.1.3'  │ 'none'         │
                              │ 37      │ 'system.adapter.trashschedule'        │ 'trashschedule'        │ '5.3.0'  │ 'none'         │
                              │ 38      │ 'system.adapter.tuya'                 │ 'tuya'                 │ '3.17.0' │ 'none'         │
                              │ 39      │ 'system.adapter.weather-warnings'     │ 'weather-warnings'     │ '0.10.1' │ 'none'         │
                              │ 40      │ 'system.adapter.web'                  │ 'web'                  │ '8.1.0'  │ 'none'         │
                              │ 41      │ 'system.adapter.whatsapp-cmb'         │ 'whatsapp-cmb'         │ '0.3.0'  │ 'none'         │
                              │ 42      │ 'system.adapter.ws'                   │ 'ws'                   │ '4.1.0'  │ 'none'         │
                              │ 43      │ 'system.adapter.zigbee'               │ 'zigbee'               │ '3.4.5'  │ 'none'         │
                              ioBroker-Adapter Versions and update status
                              Adapter    "admin"        : 7.8.25   , installed 7.8.25
                              Adapter    "awtrix-light" : 3.0.0    , installed 3.0.0
                              Adapter    "backitup"     : 3.3.17   , installed 3.3.17
                              Adapter    "ble"          : 0.14.1   , installed 0.14.1
                              Adapter    "cloud"        : 6.0.4    , installed 6.0.4
                              Adapter    "echarts"      : 3.1.0    , installed 3.1.0
                              Adapter    "firetv"       : 2.2.0    , installed 2.2.0
                              Adapter    "followthesun" : 0.5.2    , installed 0.5.2
                              Adapter    "govee-local"  : 0.4.6    , installed 0.4.6
                              Adapter    "history"      : 4.0.0    , installed 4.0.0
                              Adapter    "ical"         : 1.20.1   , installed 1.20.1
                              Adapter    "iceroad"      : 1.2.1    , installed 1.2.1
                              Adapter    "iot"          : 6.0.3    , installed 6.0.3
                              Adapter    "javascript"   : 9.2.2    , installed 9.2.2
                              Controller "js-controller": 7.1.2    , installed 7.1.2
                              Adapter    "mihome"       : 1.4.0    , installed 1.4.0
                              Adapter    "mihome-cloud" : 1.0.6    , installed 1.0.6
                              Adapter    "mihome-vacuum": 5.3.0    , installed 5.3.0
                              Adapter    "nina"         : 0.0.26   , installed 0.0.26
                              Adapter    "notification-manager": 1.3.0, installed 1.3.0
                              Adapter    "nuki-extended": 2.8.2    , installed 2.8.2
                              Adapter    "nut"          : 1.7.0    , installed 1.7.0
                              Adapter    "parcel"       : 0.3.1    , installed 0.3.1
                              Adapter    "playstation"  : 0.0.3    , installed 0.0.3
                              Adapter    "rpi2"         : 3.0.2    , installed 3.0.2
                              Adapter    "sainlogic"    : 1.2.1    , installed 1.2.1
                              Adapter    "samsung"      : 0.7.0    , installed 0.7.0
                              Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
                              Adapter    "socketio"     : 7.1.3    , installed 7.1.3
                              Adapter    "tado"         : 0.8.4    , installed 0.8.4
                              Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
                              Adapter    "trashschedule": 5.3.0    , installed 5.3.0
                              Adapter    "tuya"         : 3.17.0   , installed 3.17.0
                              Adapter    "weather-warnings": 0.10.1, installed 0.10.1
                              Adapter    "web"          : 8.1.0    , installed 8.1.0
                              Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
                              Adapter    "ws"           : 4.1.0    , installed 4.1.0
                              Adapter    "zigbee"       : 3.4.5    , installed 3.4.5
                              Objects and States
                              Objects:        10503
                              States:         8582
                              Hit:1 http://archive.raspberrypi.com/debian trixie InRelease
                              Hit:3 http://deb.debian.org/debian-security trixie-security InRelease
                              Hit:4 http://deb.debian.org/debian trixie-updates InRelease
                              Get:5 https://cli.github.com/packages stable InRelease [3917 B]
                              Hit:6 https://deb.nodesource.com/node_24.x nodistro InRelease
                              Hit:7 https://repo.mosquitto.org/debian trixie InRelease
                              Get:8 https://pkgs.tailscale.com/stable/debian trixie InRelease
                              Hit:9 https://packagecloud.io/ookla/speedtest-cli/debian trixie InRelease
                              Fetched 10.5 kB in 1s (7481 B/s)
                              Pending systemupdates: 0
                              udp              UNCONN             0                  0                                                  0.0.0.0:6667                                       0.0.0.0:*                users:(("io.tuya.0",pid=1728,fd=41))
                              udp              UNCONN             0                  0                                               127.0.0.54:domain                                     0.0.0.0:*                users:(("systemd-resolve",pid=331,fd=19))
                              udp              UNCONN             0                  0                                               127.0.0.53:domain                                     0.0.0.0:*                users:(("systemd-resolve",pid=331,fd=17))
                              udp              UNCONN             0                  0                                                  0.0.0.0:53421                                      0.0.0.0:*                users:(("io.mihome-vacuu",pid=1568,fd=34))
                              udp              UNCONN             0                  0                                                  0.0.0.0:33089                                      0.0.0.0:*                users:(("io.tradfri.0",pid=2063,fd=30))
                              udp              UNCONN             0                  0                                                  0.0.0.0:41641                                      0.0.0.0:*                users:(("tailscaled",pid=935,fd=18))
                              udp              UNCONN             0                  0                                            100.77.247.74:mdns                                       0.0.0.0:*                users:(("io.tr-064.0",pid=1715,fd=67))
                              udp              UNCONN             0                  0                                           192.168.178.48:mdns                                       0.0.0.0:*                users:(("io.tr-064.0",pid=1715,fd=66))
                              udp              UNCONN             0                  0                                                  0.0.0.0:5355                                       0.0.0.0:*                users:(("systemd-resolve",pid=331,fd=11))
                              udp              UNCONN             0                  0                                                  0.0.0.0:9898                                       0.0.0.0:*                users:(("io.mihome.0",pid=1586,fd=35))
                              udp              UNCONN             0                  0                                                  0.0.0.0:6666                                       0.0.0.0:*                users:(("io.tuya.0",pid=1728,fd=40))
                              udp              UNCONN             0                  0                               [fe80::121:85fe:2566:b9f0]:dhcpv6-client                                    *:*                users:(("NetworkManager",pid=666,fd=28))
                              udp              UNCONN             0                  0                                                        *:41641                                            *:*                users:(("tailscaled",pid=935,fd=17))
                              udp              UNCONN             0                  0                                                        *:5355                                             *:*                users:(("systemd-resolve",pid=331,fd=13))
                              tcp              LISTEN             0                  100                                                0.0.0.0:1883                                       0.0.0.0:*                users:(("mosquitto",pid=1070,fd=6))
                              tcp              LISTEN             0                  20                                               127.0.0.1:smtp                                       0.0.0.0:*                users:(("exim4",pid=1317,fd=5))
                              tcp              LISTEN             0                  4096                                             127.0.0.1:5037                                       0.0.0.0:*                users:(("adb",pid=1517,fd=12))
                              tcp              LISTEN             0                  511                                              127.0.0.1:9001                                       0.0.0.0:*                users:(("iobroker.js-con",pid=929,fd=23))
                              tcp              LISTEN             0                  511                                              127.0.0.1:9000                                       0.0.0.0:*                users:(("iobroker.js-con",pid=929,fd=29))
                              tcp              LISTEN             0                  4096                                               0.0.0.0:5355                                       0.0.0.0:*                users:(("systemd-resolve",pid=331,fd=12))
                              tcp              LISTEN             0                  4096                                            127.0.0.54:domain                                     0.0.0.0:*                users:(("systemd-resolve",pid=331,fd=20))
                              tcp              LISTEN             0                  128                                                0.0.0.0:ssh                                        0.0.0.0:*                users:(("sshd",pid=955,fd=6))
                              tcp              LISTEN             0                  16                                                 0.0.0.0:nut                                        0.0.0.0:*                users:(("upsd",pid=941,fd=4))
                              tcp              LISTEN             0                  4096                                         127.0.0.53%lo:domain                                     0.0.0.0:*                users:(("systemd-resolve",pid=331,fd=18))
                              tcp              LISTEN             0                  4096                                         100.77.247.74:39029                                      0.0.0.0:*                users:(("tailscaled",pid=935,fd=23))
                              tcp              LISTEN             0                  100                                                   [::]:1883                                          [::]:*                users:(("mosquitto",pid=1070,fd=7))
                              tcp              LISTEN             0                  4096                                                  [::]:5355                                          [::]:*                users:(("systemd-resolve",pid=331,fd=14))
                              tcp              LISTEN             0                  4096                           [fd7a:115c:a1e0::6b01:f74a]:60625                                         [::]:*                users:(("tailscaled",pid=935,fd=24))
                              tcp              LISTEN             0                  128                                                   [::]:ssh                                           [::]:*                users:(("sshd",pid=955,fd=7))
                              tcp              LISTEN             0                  20                                                   [::1]:smtp                                          [::]:*                users:(("exim4",pid=1317,fd=6))
                              tcp              LISTEN             0                  511                                                      *:8084                                             *:*                users:(("io.ws.0",pid=2159,fd=34))
                              tcp              LISTEN             0                  511                                                      *:8082                                             *:*                users:(("io.web.0",pid=1745,fd=35))
                              tcp              LISTEN             0                  511                                                      *:tproxy                                           *:*                users:(("io.admin.0",pid=41326,fd=38))
                              tcp              LISTEN             0                  511                                                      *:45000                                            *:*                users:(("io.sainlogic.0",pid=2014,fd=32))
                              tcp              LISTEN             0                  511                                                      *:51989                                            *:*                users:(("io.nuki-extende",pid=1644,fd=37))
                              2026-05-18 12:10:17.587  - info: zigbee.0 (80561) cleanup successful
                              2026-05-18 12:10:17.588  - info: zigbee.0 (80561) terminating
                              2026-05-18 12:10:17.595  - info: zigbee.0 (80561) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              2026-05-18 12:10:32.973  - info: zigbee.0 (116693) starting. Version 3.4.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v24.15.0, js-controller: 7.1.2
                              2026-05-18 12:10:33.004  - info: zigbee.0 (116693) init localConfig
                              2026-05-18 12:10:33.028  - info: zigbee.0 (116693) Adapter ready - starting subsystems. Adapter is running in info mode.
                              2026-05-18 12:10:33.101  - info: zigbee.0 (116693) delete old Backup files. keep only last 10
                              2026-05-18 12:10:33.104  - info: zigbee.0 (116693) Autostart Zigbee subsystem
                              2026-05-18 12:10:33.105  - info: zigbee.0 (116693) Starting Adapter npm ...
                              2026-05-18 12:10:33.127  - info: zigbee.0 (116693) Installed Version: iobroker.zigbee@3.4.5 (Converters 26.51.1 Herdsman 10.1.0)
                              2026-05-18 12:10:33.129  - info: zigbee.0 (116693) configured transmit power :
                              2026-05-18 12:10:33.130  - info: zigbee.0 (116693) Starting Zigbee-Herdsman
                              2026-05-18 12:10:45.261  - info: zigbee.0 (116693) Zigbee-Herdsman started successfully with Coordinator firmware version: ZStack3x0 : 20250321 (2-1.2.7.1)
                              2026-05-18 12:10:45.265  - info: zigbee.0 (116693) No devices
                              2026-05-18 12:10:45.269  - info: zigbee.0 (116693) Zigbee started
                              2026-05-18 12:23:20.138  - warn: nuki-extended.0 (1644) getWebApi(): Error retrieving logs: 500 - {"code":500,"description":"The server encountered an unexpected condition which prevented it from fulfilling the request","homeRef":"/","reasonPhrase":"Internal Server Error","uri":"http://www.w3.org/Protocols/rfc2616/rfc2616-sec10.html#sec10.5.1"}
                              2026-05-18 13:16:53.120  - error: mihome-cloud.0 (1491) Error polling custom properties for Wassersensor Bad: timeout of 15000ms exceeded
                              2026-05-18 13:47:02.437  - error: mihome-cloud.0 (1491) Error polling custom properties for Wohnungstür: timeout of 15000ms exceeded
                              2026-05-18 15:00:14.415  - error: parcel.0 (2167) Error: read ECONNRESET
                              2026-05-18 18:18:53.413  - warn: awtrix-light.0 (1875) Unable to perform action for apps.batchar.visible - API is not connected (device not reachable?)
                              2026-05-18 18:37:34.018  - error: mihome-cloud.0 (1491) Error polling custom properties for Gateway: timeout of 15000ms exceeded
                              2026-05-18 20:30:19.410  - warn: javascript.0 (1359) script.js.common.sonnenuntergang: Golden hour wurde getriggert
                              2026-05-18 20:36:20.329  - warn: iceroad.0 (141788) get state error: Connection is closed.
                              2026-05-18 20:47:03.312  - error: mihome-cloud.0 (1491) Error polling custom properties for Wassersensor: timeout of 15000ms exceeded
                              2026-05-18 23:37:02.627  - error: mihome-cloud.0 (1491) Error polling custom properties for Wassersensor: timeout of 15000ms exceeded
                              ============= Mark until here for C&P =============
                              iob diag has finished.
                              echad@chet:~ $
                                Script v.2026-05-18
                                *** BASE SYSTEM ***
                                Operating System: Debian GNU/Linux 13 (trixie)
                                       Icon name: computer
                                    Architecture: arm64
                                OS is similar to:
                                Docker          : false
                                Kernel          : aarch64
                                Userland        : 64bit
                                Systemuptime and Load:
                                CPU threads     : 4
                                *** LIFE CYCLE STATUS ***
                                Operating System is the current Debian stable version codenamed 'trixie'!
                                Current issues:
                                *** TIME AND TIMEZONES ***
                                                 RTC time: n/a
                                              NTP service: active
                                          RTC in local TZ: no
                                *** Users and Groups ***
                                User that called 'iob diag':
                                echad
                                HOME=/home/echad
                                iobroker
                                HOME=/home/iobroker
                                *** DISPLAY-SERVER SETUP ***
                                Display-Server:         Unknown
                                Display-Manager:        Not found
                                Desktop:
                                Session:                tty
                                *** MEMORY ***
                                Swap:           2.1G         28M        2.1G
                                         7818 M total memory
                                         5358 M used memory
                                          795 M free memory
                                          436 M buffer memory
                                         1353 M swap cache
                                         2047 M total swap
                                           27 M used swap
                                         2020 M free swap
                                *** FAILED SERVICES ***
                                *** DMESG CRITICAL ERRORS ***
                                No critical errors detected
                                *** FILESYSTEM ***
                                Messages concerning filesystems in dmesg:
                                Show mounted filesystems:
                                TARGET           SOURCE    FSTYPE OPTIONS
                                /var:
                                5.1G    /var/
                                2.8G    /var/cache/apt
                                2.8G    /var/cache
                                302M    /var/lib
                                /opt/iobroker/backups:
                                /opt/iobroker/iobroker-data:
                                USB-Devices by-id:
                                USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
                                please always prefer the links 'by-id':
                                *** ZigBee Settings ***
                                Zigbee Network Settings on your coordinator / in nvbackup are:
                                zigbee.X
                                Extended Pan ID:
                                *** MASKED ***
                                Pan ID:
                                *** MASKED ***
                                Channel:
                                *** MASKED ***
                                Network Key:
                                *** MASKED ***
                                *** NodeJS-Installation ***
                                ✓ Node.js installation is correct
                                nodejs:
                                  Version table:
                                No problems detected
                                Errors in npm tree: 0
                                *** ioBroker-Installation ***
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                Hosts:
                                Core adapters versions
                                admin:          7.8.25
                                javascript:     9.2.2
                                nodejs modules from github:     3
                                Adapter State
                                + instance is alive
                                Objects and States
                                Objects:        10503
                                States:         8582
                                echad@chet:~ $
                                MCU
                                #796
                                @Thomas-Braun Gibt es die diag auch für Windows?
                                Thomas BraunT S 2 Antworten Letzte Antwort
                                • M MCU
                                  #797
                                  @MCU
                                  Das Skript läuft nur unter Linux. Von Windows hab ich ja keine Ahnung.
                                  Ich weiß nicht mal, was passiert wenn man
                                  iob diag
                                  auf einem Windows aufruft.
                                  Aber ich meine @gaspode hatte mal mit einer Portierung (oder zumindest etwas ähnlichem) angefangen.
                                  • S Abwesend
                                    S Abwesend
                                    Shadowhunter23
                                    #798
                                    Du solltest den Link im ersten Beitrag noch anpassen zur neusten Version.
                                    • S Shadowhunter23
                                      #799
                                      @Shadowhunter23
                                      Stimmt.
                                      Versuch es jetzt mal.
                                      • skvarelS Offline
                                        skvarelS Offline
                                        skvarel
                                        #800
                                        Jetzt musste ich das auch endlich mal testen:
                                        ```bash
                                        Script v.2026-05-18
                                        *** GRUNDSYSTEM ***
                                        Operating System: Ubuntu 24.04.4 LTS
                                               Icon name: computer-desktop
                                                 Chassis: desktop 🖥️
                                                  Kernel: Linux 6.8.0-117-generic
                                            Architecture: x86-64
                                         Hardware Vendor: Dell Inc.
                                          Hardware Model: OptiPlex 3050
                                        Firmware Version: 1.6.5
                                           Firmware Date: Sat 2017-09-09
                                            Firmware Age: 8y 8month 1w 1d
                                        OS is similar to: debian
                                        model name      : Intel(R) Core(TM) i3-6100T CPU @ 3.20GHz
                                        Docker          : false
                                        Kernel          : x86_64
                                        Userland        : 64bit
                                         08:00:11 up 1 day, 58 min,  1 user,  load average: 1.79, 1.15, 1.02
                                        CPU threads     : 4
                                        Das Betriebssystem mit dem Codenamen 'noble' ist unbekannt. Bitte den Status der Unterstützung eigenständig prüfen.
                                                       Local time: Tue 2026-05-19 08:00:11 CEST
                                                   Universal time: Tue 2026-05-19 06:00:11 UTC
                                                         RTC time: Tue 2026-05-19 06:00:11
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        pi
                                        HOME=/home/pi
                                        GROUPS=pi adm cdrom sudo dip plugdev lxd iobroker
                                        iobroker
                                        HOME=/home/iobroker
                                        GROUPS=iobroker tty dialout audio video plugdev redis
                                        Desktop:
                                        Session:                tty
                                        *** MEMORY ***
                                        Mem:             16G        8.3G        5.5G        5.0M        3.2G        8.4G
                                        Swap:           4.3G          0B        4.3G
                                        Total:           20G        8.3G        9.8G
                                        Active iob-Instances:   54
                                                15877 M total memory
                                                 7909 M used memory
                                                 7918 M active memory
                                                 1805 M inactive memory
                                                 5213 M free memory
                                                  583 M buffer memory
                                                 2512 M swap cache
                                                 4095 M total swap
                                                    0 M used swap
                                                 4095 M free swap
                                        top - 08:00:11 up 1 day, 58 min,  1 user,  load average: 1.79, 1.15, 1.02
                                        Tasks: 239 total,   2 running, 237 sleeping,   0 stopped,   0 zombie
                                        %Cpu(s):  4.1 us,  4.1 sy,  0.0 ni, 91.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                        MiB Mem :  15877.7 total,   5213.0 free,   7910.1 used,   3095.6 buff/cache
                                        MiB Swap:   4096.0 total,   4096.0 free,      0.0 used.   7967.6 avail Mem
                                        *** FILESYSTEM ***
                                        Filesystem                        Type   Size  Used Avail Use% Mounted on
                                        tmpfs                             tmpfs  1.6G  4.6M  1.6G   1% /run
                                        /dev/mapper/ubuntu--vg-ubuntu--lv ext4   467G   20G  428G   5% /
                                        tmpfs                             tmpfs  5.0M     0  5.0M   0% /run/lock
                                        /dev/nvme0n1p2                    ext4   2.0G  200M  1.6G  11% /boot
                                        tmpfs                             tmpfs  1.6G   12K  1.6G   1% /run/user/1000
                                        [Mon May 18 07:01:29 2026] Btrfs loaded, zoned=yes, fsverity=yes
                                        [Mon May 18 07:01:29 2026] EXT4-fs (dm-0): mounted filesystem a547182b-43b5-440e-b6fe-09323774b05c ro with ordered data mode. Quota mode: none.
                                        [Mon May 18 07:01:29 2026] EXT4-fs (dm-0): re-mounted a547182b-43b5-440e-b6fe-09323774b05c r/w.
                                        [Mon May 18 07:01:30 2026] EXT4-fs (nvme0n1p2): mounted filesystem 7a71a3d0-fb5e-4ed0-8d6d-dc24002c0eef r/w with ordered data mode. Quota mode: none.
                                        /       /dev/mapper/ubuntu--vg-ubuntu--lv ext4   rw,relatime
                                        `-/boot /dev/nvme0n1p2                    ext4   rw,relatime
                                        /var:
                                        5.1G    /var/
                                        4.2G    /var/log
                                        4.1G    /var/log/journal/b521ee0ca8cb46db87113e33c1d11d82
                                        756M    /var/lib
                                        Archived and active journals take up 4.0G in the file system.
                                        252M    /opt/iobroker/backups/
                                        514M    /opt/iobroker/iobroker-data/
                                        327M    /opt/iobroker/iobroker-data/files
                                        132M    /opt/iobroker/iobroker-data/backup-objects
                                        56M     /opt/iobroker/iobroker-data/files/vis-2
                                        47M     /opt/iobroker/iobroker-data/files/admin.admin
                                        52M     /opt/iobroker/iobroker-data/objects.jsonl
                                        19M     /opt/iobroker/iobroker-data/files/matter.admin/assets/index-DMt8RVCF.js
                                        9.8M    /opt/iobroker/iobroker-data/files/vis-2/material-icons/knx-uf.json
                                        9.2M    /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js
                                        USB-Devices by-id:
                                        Keine Geräte gefunden 'by-id'
                                        No nvbackup.json found.
                                        /usr/bin/nodejs         v22.22.2
                                        /usr/bin/node           v22.22.2
                                        /usr/bin/npm            10.9.7
                                        /usr/bin/npx            10.9.7
                                        nodejs:
                                          Installed: 22.22.2-1nodesource1
                                          Candidate: 22.22.2-1nodesource1
                                          Version table:
                                         *** 22.22.2-1nodesource1 1001
                                             22.22.0-1nodesource1 1001
                                             22.21.0-1nodesource1 1001
                                             22.20.0-1nodesource1 1001
                                             22.19.0-1nodesource1 1001
                                             22.18.0-1nodesource1 1001
                                             22.17.1-1nodesource1 1001
                                             22.17.0-1nodesource1 1001
                                             22.16.0-1nodesource1 1001
                                             22.15.1-1nodesource1 1001
                                             22.15.0-1nodesource1 1001
                                             22.14.0-1nodesource1 1001
                                             22.13.1-1nodesource1 1001
                                             22.13.0-1nodesource1 1001
                                             22.12.0-1nodesource1 1001
                                             22.11.0-1nodesource1 1001
                                             22.10.0-1nodesource1 1001
                                             22.9.0-1nodesource1 1001
                                             22.8.0-1nodesource1 1001
                                             22.7.0-1nodesource1 1001
                                             22.6.0-1nodesource1 1001
                                             22.5.1-1nodesource1 1001
                                             22.5.0-1nodesource1 1001
                                             22.4.1-1nodesource1 1001
                                             22.4.0-1nodesource1 1001
                                             22.3.0-1nodesource1 1001
                                             22.2.0-1nodesource1 1001
                                             22.1.0-1nodesource1 1001
                                             22.0.0-1nodesource1 1001
                                             18.19.1+dfsg-6ubuntu5 500
                                                500 http://archive.ubuntu.com/ubuntu noble/universe amd64 Packages
                                        Keine bekannten Sicherheitslücken in der Node.js-Version erkannt!
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: redis
                                        Hosts:
                                        ioBroker            ioBroker (version: 7.1.2, hostname: ioBroker      , alive, uptime: 89915)
                                        admin:          7.8.25
                                        javascript:     9.2.2
                                        nodejs modules from github:     2
                                        +-- iobroker.energiefluss-erweitert@0.8.2 (git+ssh://git@github.com/SKB-CGN/ioBroker.energiefluss-erweitert.git#89dbb71bf0fc70044249fd6453c25194130d9971)
                                        +-- iobroker.linux-control@1.1.6 (git+ssh://git@github.com/Scrounger/ioBroker.linux-control.git#59f578f3402850684ba8767a24a9ff288b05a3f0)
                                        Adapter State
                                        + system.adapter.autodarts.0              : autodarts             : ioBroker                                 -  enabled, port: 3180
                                        + system.adapter.bambulab.0               : bambulab              : ioBroker                                 -  enabled, port: 8883
                                        + system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 -  enabled
                                        + system.adapter.device-watcher.0         : device-watcher        : ioBroker                                 -  enabled
                                        + system.adapter.devices.0                : devices               : ioBroker                                 -  enabled
                                        + system.adapter.discovergy.0             : discovergy            : ioBroker                                 -  enabled
                                        + system.adapter.enpal.0                  : enpal                 : ioBroker                                 -  enabled
                                          system.adapter.fb-checkpresence.0       : fb-checkpresence      : ioBroker                                 - disabled
                                          system.adapter.foxesscloud.0            : foxesscloud           : ioBroker                                 - disabled
                                        + system.adapter.foxesscloud.1            : foxesscloud           : ioBroker                                 -  enabled
                                        + system.adapter.harmony.0                : harmony               : ioBroker                                 -  enabled
                                        + system.adapter.hmip.0                   : hmip                  : ioBroker                                 -  enabled
                                        + system.adapter.ical.3                   : ical                  : ioBroker                                 -  enabled
                                          system.adapter.ical.4                   : ical                  : ioBroker                                 -  enabled
                                        + system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
                                        + system.adapter.javascript.1             : javascript            : ioBroker                                 -  enabled
                                        + system.adapter.javascript.2             : javascript            : ioBroker                                 -  enabled
                                        + system.adapter.javascript.3             : javascript            : ioBroker                                 -  enabled
                                        + system.adapter.javascript.5             : javascript            : ioBroker                                 -  enabled
                                        + system.adapter.life360ng.0              : life360ng             : ioBroker                                 -  enabled
                                        + system.adapter.matter.0                 : matter                : ioBroker                                 -  enabled
                                        + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1885, bind: 0.0.0.0
                                        + system.adapter.mqtt.1                   : mqtt                  : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                                          system.adapter.nanoleaf-lightpanels.0   : nanoleaf-lightpanels  : ioBroker                                 - disabled, port: 16021
                                        + system.adapter.operating-hours.0        : operating-hours       : ioBroker                                 -  enabled
                                        + system.adapter.reolink.5                : reolink               : ioBroker                                 -  enabled
                                        + system.adapter.reolink.6                : reolink               : ioBroker                                 -  enabled
                                        + system.adapter.reolink.7                : reolink               : ioBroker                                 -  enabled
                                        + system.adapter.reolink.8                : reolink               : ioBroker                                 -  enabled
                                        + system.adapter.reolink.9                : reolink               : ioBroker                                 -  enabled
                                          system.adapter.seq.0                    : seq                   : ioBroker                                 - disabled, port: 443
                                          system.adapter.snmp.0                   : snmp                  : ioBroker                                 - disabled
                                        + system.adapter.sonoff.0                 : sonoff                : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                                        + system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 -  enabled
                                          system.adapter.spotify-premium.0        : spotify-premium       : ioBroker                                 - disabled
                                        + system.adapter.sureflap.0               : sureflap              : ioBroker                                 -  enabled
                                        + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                                        + system.adapter.tidy.0                   : tidy                  : ioBroker                                 -  enabled
                                          system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 - disabled
                                        + system.adapter.trashschedule.1          : trashschedule         : ioBroker                                 -  enabled
                                        + system.adapter.vis-2.0                  : vis-2                 : ioBroker                                 -  enabled
                                          system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 -  enabled
                                        + system.adapter.wallpanel.0              : wallpanel             : ioBroker                                 -  enabled
                                        + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                        + system.adapter.wiobrowser.0             : wiobrowser            : ioBroker                                 -  enabled, port: 5000
                                        + system.adapter.wled.0                   : wled                  : ioBroker                                 -  enabled
                                        + system.adapter.worx.0                   : worx                  : ioBroker                                 -  enabled
                                        + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : ioBroker                                 -  enabled
                                        + instance is alive
                                        ioBroker-Repositories
                                        │ 0       │ 'Beta'   │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
                                        │ 1       │ 'Stable' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
                                        Active repo(s): Beta
                                        Upgrade policy: none
                                        Installed ioBroker-Adapters
                                        │ 2       │ 'system.adapter.autodarts'              │ 'autodarts'              │ '1.0.8'   │ 'none'         │
                                        │ 3       │ 'system.adapter.backitup'               │ 'backitup'               │ '3.3.17'  │ 'none'         │
                                        │ 4       │ 'system.adapter.bambulab'               │ 'bambulab'               │ '0.4.3'   │ 'none'         │
                                        │ 5       │ 'system.adapter.birthdays'              │ 'birthdays'              │ '6.0.0'   │ 'none'         │
                                        │ 6       │ 'system.adapter.brightsky'              │ 'brightsky'              │ '1.1.0'   │ 'none'         │
                                        │ 7       │ 'system.adapter.device-reminder'        │ 'device-reminder'        │ '3.1.2'   │ 'none'         │
                                        │ 8       │ 'system.adapter.device-watcher'         │ 'device-watcher'         │ '2.15.15' │ 'none'         │
                                        │ 9       │ 'system.adapter.devices'                │ 'devices'                │ '2.0.18'  │ 'none'         │
                                        │ 10      │ 'system.adapter.discovergy'             │ 'discovergy'             │ '0.7.0'   │ 'none'         │
                                        │ 11      │ 'system.adapter.dwd'                    │ 'dwd'                    │ '2.8.5'   │ 'none'         │
                                        │ 12      │ 'system.adapter.echarts'                │ 'echarts'                │ '1.9.2'   │ 'none'         │
                                        │ 13      │ 'system.adapter.egigeozone'             │ 'egigeozone'             │ '0.1.2'   │ 'none'         │
                                        │ 14      │ 'system.adapter.energiefluss-erweitert' │ 'energiefluss-erweitert' │ '0.8.2'   │ 'none'         │
                                        │ 15      │ 'system.adapter.enpal'                  │ 'enpal'                  │ '0.2.0'   │ 'none'         │
                                        │ 16      │ 'system.adapter.fb-checkpresence'       │ 'fb-checkpresence'       │ '1.4.2'   │ 'none'         │
                                        │ 17      │ 'system.adapter.feiertage'              │ 'feiertage'              │ '1.4.0'   │ 'none'         │
                                        │ 18      │ 'system.adapter.foxesscloud'            │ 'foxesscloud'            │ '0.2.3'   │ 'none'         │
                                        │ 19      │ 'system.adapter.harmony'                │ 'harmony'                │ '2.1.0'   │ 'none'         │
                                        │ 20      │ 'system.adapter.hiob'                   │ 'hiob'                   │ '0.1.7'   │ 'none'         │
                                        │ 21      │ 'system.adapter.hmip'                   │ 'hmip'                   │ '1.27.0'  │ 'none'         │
                                        │ 22      │ 'system.adapter.ical'                   │ 'ical'                   │ '1.20.1'  │ 'none'         │
                                        │ 23      │ 'system.adapter.influxdb'               │ 'influxdb'               │ '4.0.2'   │ 'none'         │
                                        │ 24      │ 'system.adapter.javascript'             │ 'javascript'             │ '9.2.2'   │ 'none'         │
                                        │ 25      │ 'system.adapter.life360ng'              │ 'life360ng'              │ '1.9.0'   │ 'none'         │
                                        │ 26      │ 'system.adapter.linux-control'          │ 'linux-control'          │ '1.1.6'   │ 'none'         │
                                        │ 27      │ 'system.adapter.matter'                 │ 'matter'                 │ '1.0.0'   │ 'none'         │
                                        │ 28      │ 'system.adapter.motion'                 │ 'motion'                 │ '0.0.1'   │ 'none'         │
                                        │ 29      │ 'system.adapter.mqtt'                   │ 'mqtt'                   │ '6.1.4'   │ 'none'         │
                                        │ 30      │ 'system.adapter.nanoleaf-lightpanels'   │ 'nanoleaf-lightpanels'   │ '1.6.0'   │ 'none'         │
                                        │ 31      │ 'system.adapter.operating-hours'        │ 'operating-hours'        │ '1.5.1'   │ 'none'         │
                                        │ 32      │ 'system.adapter.owntracks'              │ 'owntracks'              │ '1.1.0'   │ 'none'         │
                                        │ 33      │ 'system.adapter.ping'                   │ 'ping'                   │ '2.2.4'   │ 'none'         │
                                        │ 34      │ 'system.adapter.reolink'                │ 'reolink'                │ '1.4.2'   │ 'none'         │
                                        │ 35      │ 'system.adapter.rtspstream'             │ 'rtspstream'             │ '0.0.4'   │ 'none'         │
                                        │ 36      │ 'system.adapter.seq'                    │ 'seq'                    │ '1.0.2'   │ 'none'         │
                                        │ 37      │ 'system.adapter.shelly'                 │ 'shelly'                 │ '10.6.1'  │ 'none'         │
                                        │ 38      │ 'system.adapter.simple-api'             │ 'simple-api'             │ '3.0.7'   │ 'none'         │
                                        │ 39      │ 'system.adapter.snmp'                   │ 'snmp'                   │ '3.4.0'   │ 'none'         │
                                        │ 40      │ 'system.adapter.socketio'               │ 'socketio'               │ '7.1.3'   │ 'none'         │
                                        │ 41      │ 'system.adapter.sonoff'                 │ 'sonoff'                 │ '3.3.0'   │ 'none'         │
                                        │ 42      │ 'system.adapter.sourceanalytix'         │ 'sourceanalytix'         │ '0.4.14'  │ 'none'         │
                                        │ 43      │ 'system.adapter.spotify-premium'        │ 'spotify-premium'        │ '2.0.3'   │ 'none'         │
                                        │ 44      │ 'system.adapter.statistics'             │ 'statistics'             │ '2.4.0'   │ 'none'         │
                                        │ 45      │ 'system.adapter.sureflap'               │ 'sureflap'               │ '3.4.2'   │ 'none'         │
                                        │ 46      │ 'system.adapter.tankerkoenig'           │ 'tankerkoenig'           │ '3.4.0'   │ 'none'         │
                                        │ 47      │ 'system.adapter.telegram'               │ 'telegram'               │ '4.1.0'   │ 'none'         │
                                        │ 48      │ 'system.adapter.tidy'                   │ 'tidy'                   │ '0.1.1'   │ 'none'         │
                                        │ 49      │ 'system.adapter.tr-064'                 │ 'tr-064'                 │ '4.3.0'   │ 'none'         │
                                        │ 50      │ 'system.adapter.trashschedule'          │ 'trashschedule'          │ '5.3.0'   │ 'none'         │
                                        │ 51      │ 'system.adapter.tuya'                   │ 'tuya'                   │ '3.17.0'  │ 'none'         │
                                        │ 52      │ 'system.adapter.vis-2'                  │ 'vis-2'                  │ '2.13.19' │ 'none'         │
                                        │ 53      │ 'system.adapter.vis-2-widgets-icontwo'  │ 'vis-2-widgets-icontwo'  │ '1.40.0'  │ 'none'         │
                                        │ 54      │ 'system.adapter.vis-2-widgets-inventwo' │ 'vis-2-widgets-inventwo' │ '1.0.0'   │ 'none'         │
                                        │ 55      │ 'system.adapter.vis-2-widgets-material' │ 'vis-2-widgets-material' │ '1.4.10'  │ 'none'         │
                                        │ 56      │ 'system.adapter.vis-icontwo'            │ 'vis-icontwo'            │ '2.11.3'  │ 'none'         │
                                        │ 57      │ 'system.adapter.vw-connect'             │ 'vw-connect'             │ '0.8.4'   │ 'none'         │
                                        │ 58      │ 'system.adapter.wallpanel'              │ 'wallpanel'              │ '0.3.11'  │ 'none'         │
                                        │ 59      │ 'system.adapter.web'                    │ 'web'                    │ '8.1.0'   │ 'none'         │
                                        │ 60      │ 'system.adapter.wiobrowser'             │ 'wiobrowser'             │ '2.0.2'   │ 'none'         │
                                        │ 61      │ 'system.adapter.wireless-settings'      │ 'wireless-settings'      │ '1.0.2'   │ 'none'         │
                                        │ 62      │ 'system.adapter.wled'                   │ 'wled'                   │ '0.9.2'   │ 'none'         │
                                        │ 63      │ 'system.adapter.worx'                   │ 'worx'                   │ '3.3.0'   │ 'none'         │
                                        │ 64      │ 'system.adapter.ws'                     │ 'ws'                     │ '4.1.0'   │ 'none'         │
                                        │ 65      │ 'system.adapter.xterm'                  │ 'xterm'                  │ '3.0.2'   │ 'none'         │
                                        │ 66      │ 'system.adapter.zigbee'                 │ 'zigbee'                 │ '3.0.1'   │ 'none'         │
                                        │ 67      │ 'system.adapter.zigbee2mqtt'            │ 'zigbee2mqtt'            │ '3.2.1'   │ 'none'         │
                                        Used repository: Beta
                                        Adapter    "autodarts"    : 1.0.8    , installed 1.0.8
                                        Adapter    "bambulab"     : 0.4.3    , installed 0.4.3
                                        Adapter    "birthdays"    : 6.0.0    , installed 6.0.0
                                        Adapter    "brightsky"    : 1.1.0    , installed 1.1.0
                                        Adapter    "device-reminder": 3.1.2  , installed 3.1.2
                                        Adapter    "device-watcher": 2.15.15 , installed 2.15.15
                                        Adapter    "devices"      : 2.0.18   , installed 2.0.18
                                        Adapter    "discovergy"   : 0.7.0    , installed 0.7.0
                                        Adapter    "energiefluss-erweitert": 0.8.2, installed 0.8.2
                                        Adapter    "enpal"        : 0.2.0    , installed 0.2.0
                                        Adapter    "fb-checkpresence": 1.4.2 , installed 1.4.2
                                        Adapter    "feiertage"    : 1.4.0    , installed 1.4.0
                                        Adapter    "foxesscloud"  : 0.2.3    , installed 0.2.3
                                        Adapter    "harmony"      : 2.1.0    , installed 2.1.0
                                        Adapter    "hmip"         : 1.27.0   , installed 1.27.0
                                        Adapter    "life360ng"    : 1.9.0    , installed 1.9.0
                                        Adapter    "linux-control": 1.1.5    , installed 1.1.6
                                        Adapter    "matter"       : 1.0.0    , installed 1.0.0
                                        Adapter    "nanoleaf-lightpanels": 1.6.0, installed 1.6.0
                                        Adapter    "operating-hours": 1.5.1  , installed 1.5.1
                                        Adapter    "ping"         : 2.2.4    , installed 2.2.4
                                        Adapter    "reolink"      : 1.4.2    , installed 1.4.2
                                        Adapter    "seq"          : 1.0.2    , installed 1.0.2
                                        Adapter    "shelly"       : 10.6.1   , installed 10.6.1
                                        Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
                                        Adapter    "sonoff"       : 3.3.0    , installed 3.3.0
                                        Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
                                        Adapter    "spotify-premium": 2.0.3  , installed 2.0.3
                                        Adapter    "sureflap"     : 3.4.2    , installed 3.4.2
                                        Adapter    "vis-2"        : 2.13.19  , installed 2.13.19
                                        Adapter    "vis-2-widgets-icontwo": 1.40.0, installed 1.40.0
                                        Adapter    "vis-2-widgets-inventwo": 1.0.0, installed 1.0.0
                                        Adapter    "vis-icontwo"  : 2.11.3   , installed 2.11.3
                                        Adapter    "vw-connect"   : 0.8.4    , installed 0.8.4
                                        Adapter    "wallpanel"    : 0.3.11   , installed 0.3.11
                                        Adapter    "wiobrowser"   : 2.0.2    , installed 2.0.2
                                        Adapter    "wled"         : 0.9.2    , installed 0.9.2
                                        Adapter    "worx"         : 3.3.0    , installed 3.3.0
                                        Adapter    "xterm"        : 3.0.2    , installed 3.0.2
                                        Adapter    "zigbee2mqtt"  : 3.2.1    , installed 3.2.1
                                        Objects and States
                                        Objects:        22344
                                        States:         23015
                                        Hit:1 http://security.ubuntu.com/ubuntu noble-security InRelease
                                        Hit:2 https://apt.grafana.com stable InRelease
                                        Hit:3 http://archive.ubuntu.com/ubuntu noble InRelease
                                        Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
                                        Get:5 https://repos.influxdata.com/debian stable InRelease [6922 B]
                                        Hit:6 http://archive.ubuntu.com/ubuntu noble-updates InRelease
                                        Hit:7 http://archive.ubuntu.com/ubuntu noble-backports InRelease
                                        Hit:8 https://packages.redis.io/deb noble InRelease
                                        Fetched 6922 B in 1s (7773 B/s)
                                        Reading package lists... Done
                                        *** Listening Ports ***
                                        Netid     State      Recv-Q     Send-Q                              Local Address:Port                  Peer Address:Port     Process
                                        udp       UNCONN     0          0                                         0.0.0.0:61991                      0.0.0.0:*         users:(("io.harmony.0",pid=1865,fd=30))
                                        udp       UNCONN     0          0                                         0.0.0.0:mdns                       0.0.0.0:*         users:(("io.wled.0",pid=3056,fd=22))
                                        udp       UNCONN     0          0                                         0.0.0.0:mdns                       0.0.0.0:*         users:(("io.matter.0",pid=2558,fd=41))
                                        udp       UNCONN     0          0                                         0.0.0.0:mdns                       0.0.0.0:*         users:(("io.matter.0",pid=2558,fd=35))
                                        udp       UNCONN     0          0                                         0.0.0.0:mdns                       0.0.0.0:*         users:(("io.matter.0",pid=2558,fd=38))
                                        udp       UNCONN     0          0                                         0.0.0.0:5540                       0.0.0.0:*         users:(("io.matter.0",pid=2558,fd=45))
                                        udp       UNCONN     0          0                                         0.0.0.0:5541                       0.0.0.0:*         users:(("io.matter.0",pid=2558,fd=37))
                                        udp       UNCONN     0          0                                         0.0.0.0:5542                       0.0.0.0:*         users:(("io.matter.0",pid=2558,fd=47))
                                        udp       UNCONN     0          0                                         0.0.0.0:6666                       0.0.0.0:*         users:(("io.tuya.0",pid=2110,fd=53))
                                        udp       UNCONN     0          0                                         0.0.0.0:6667                       0.0.0.0:*         users:(("io.tuya.0",pid=2110,fd=54))
                                        udp       UNCONN     0          0                                      127.0.0.54:domain                     0.0.0.0:*         users:(("systemd-resolve",pid=696,fd=16))
                                        udp       UNCONN     0          0                                   127.0.0.53%lo:domain                     0.0.0.0:*         users:(("systemd-resolve",pid=696,fd=14))
                                        udp       UNCONN     0          0                          192.168.130.130%enp2s0:bootpc                     0.0.0.0:*         users:(("systemd-network",pid=512,fd=24))
                                        udp       UNCONN     0          0                                         0.0.0.0:sunrpc                     0.0.0.0:*         users:(("rpcbind",pid=647,fd=5),("systemd",pid=1,fd=40))
                                        udp       UNCONN     0          0                                  172.18.255.255:netbios-ns                 0.0.0.0:*         users:(("nmbd",pid=991,fd=25))
                                        udp       UNCONN     0          0                                      172.18.0.1:netbios-ns                 0.0.0.0:*         users:(("nmbd",pid=991,fd=24))
                                        udp       UNCONN     0          0                                  172.17.255.255:netbios-ns                 0.0.0.0:*         users:(("nmbd",pid=991,fd=21))
                                        udp       UNCONN     0          0                                      172.17.0.1:netbios-ns                 0.0.0.0:*         users:(("nmbd",pid=991,fd=20))
                                        udp       UNCONN     0          0                                 192.168.255.255:netbios-ns                 0.0.0.0:*         users:(("nmbd",pid=991,fd=16))
                                        udp       UNCONN     0          0                                 192.168.130.130:netbios-ns                 0.0.0.0:*         users:(("nmbd",pid=991,fd=15))
                                        udp       UNCONN     0          0                                         0.0.0.0:netbios-ns                 0.0.0.0:*         users:(("nmbd",pid=991,fd=13))
                                        udp       UNCONN     0          0                                  172.18.255.255:netbios-dgm                0.0.0.0:*         users:(("nmbd",pid=991,fd=27))
                                        udp       UNCONN     0          0                                      172.18.0.1:netbios-dgm                0.0.0.0:*         users:(("nmbd",pid=991,fd=26))
                                        udp       UNCONN     0          0                                  172.17.255.255:netbios-dgm                0.0.0.0:*         users:(("nmbd",pid=991,fd=23))
                                        udp       UNCONN     0          0                                      172.17.0.1:netbios-dgm                0.0.0.0:*         users:(("nmbd",pid=991,fd=22))
                                        udp       UNCONN     0          0                                 192.168.255.255:netbios-dgm                0.0.0.0:*         users:(("nmbd",pid=991,fd=18))
                                        udp       UNCONN     0          0                                 192.168.130.130:netbios-dgm                0.0.0.0:*         users:(("nmbd",pid=991,fd=17))
                                        udp       UNCONN     0          0                                         0.0.0.0:netbios-dgm                0.0.0.0:*         users:(("nmbd",pid=991,fd=14))
                                        udp       UNCONN     0          0                                            [::]:mdns                          [::]:*         users:(("io.matter.0",pid=2558,fd=43))
                                        udp       UNCONN     0          0                                            [::]:mdns                          [::]:*         users:(("io.matter.0",pid=2558,fd=42))
                                        udp       UNCONN     0          0                                            [::]:mdns                          [::]:*         users:(("io.matter.0",pid=2558,fd=40))
                                        udp       UNCONN     0          0                                            [::]:mdns                          [::]:*         users:(("io.matter.0",pid=2558,fd=39))
                                        udp       UNCONN     0          0                                            [::]:5540                          [::]:*         users:(("io.matter.0",pid=2558,fd=44))
                                        udp       UNCONN     0          0                                            [::]:5541                          [::]:*         users:(("io.matter.0",pid=2558,fd=36))
                                        udp       UNCONN     0          0                                            [::]:5542                          [::]:*         users:(("io.matter.0",pid=2558,fd=46))
                                        udp       UNCONN     0          0                                            [::]:sunrpc                        [::]:*         users:(("rpcbind",pid=647,fd=7),("systemd",pid=1,fd=42))
                                        udp       UNCONN     0          0              [fe80::da9e:f3ff:fe78:3132]%enp2s0:dhcpv6-client                 [::]:*         users:(("systemd-network",pid=512,fd=22))
                                        tcp       LISTEN     0          50                                        0.0.0.0:netbios-ssn                0.0.0.0:*         users:(("smbd",pid=1007,fd=31))
                                        tcp       LISTEN     0          4096                                      0.0.0.0:ssh                        0.0.0.0:*         users:(("sshd",pid=2422,fd=3),("systemd",pid=1,fd=104))
                                        tcp       LISTEN     0          4096                                      0.0.0.0:sunrpc                     0.0.0.0:*         users:(("rpcbind",pid=647,fd=4),("systemd",pid=1,fd=39))
                                        tcp       LISTEN     0          4096                                   127.0.0.54:domain                     0.0.0.0:*         users:(("systemd-resolve",pid=696,fd=17))
                                        tcp       LISTEN     0          4096                                      0.0.0.0:http                       0.0.0.0:*         users:(("docker-proxy",pid=1323,fd=7))
                                        tcp       LISTEN     0          50                                        0.0.0.0:microsoft-ds               0.0.0.0:*         users:(("smbd",pid=1007,fd=30))
                                        tcp       LISTEN     0          511                                       0.0.0.0:1885                       0.0.0.0:*         users:(("io.mqtt.0",pid=1949,fd=34))
                                        tcp       LISTEN     0          511                                       0.0.0.0:1883                       0.0.0.0:*         users:(("io.sonoff.0",pid=2039,fd=40))
                                        tcp       LISTEN     0          511                                       0.0.0.0:1882                       0.0.0.0:*         users:(("io.shelly.0",pid=2271,fd=36))
                                        tcp       LISTEN     0          511                                     127.0.0.1:9001                       0.0.0.0:*         users:(("iobroker.js-con",pid=1464,fd=23))
                                        tcp       LISTEN     0          4096                                    127.0.0.1:34169                      0.0.0.0:*         users:(("containerd",pid=764,fd=15))
                                        tcp       LISTEN     0          511                                     127.0.0.1:redis                      0.0.0.0:*         users:(("redis-server",pid=720,fd=20))
                                        tcp       LISTEN     0          4096                                127.0.0.53%lo:domain                     0.0.0.0:*         users:(("systemd-resolve",pid=696,fd=15))
                                        tcp       LISTEN     0          50                                           [::]:netbios-ssn                   [::]:*         users:(("smbd",pid=1007,fd=29))
                                        tcp       LISTEN     0          4096                                         [::]:ssh                           [::]:*         users:(("sshd",pid=2422,fd=4),("systemd",pid=1,fd=105))
                                        tcp       LISTEN     0          4096                                         [::]:sunrpc                        [::]:*         users:(("rpcbind",pid=647,fd=6),("systemd",pid=1,fd=41))
                                        tcp       LISTEN     0          4096                                         [::]:http                          [::]:*         users:(("docker-proxy",pid=1330,fd=7))
                                        tcp       LISTEN     0          50                                           [::]:microsoft-ds                  [::]:*         users:(("smbd",pid=1007,fd=28))
                                        tcp       LISTEN     0          4096                                            *:3000                             *:*         users:(("grafana",pid=1463,fd=26))
                                        tcp       LISTEN     0          511                                             *:61991                            *:*         users:(("io.harmony.0",pid=1865,fd=29))
                                        tcp       LISTEN     0          511                                         [::1]:redis                         [::]:*         users:(("redis-server",pid=720,fd=21))
                                        tcp       LISTEN     0          511                                             *:8087                             *:*         users:(("io.simple-api.0",pid=2722,fd=35))
                                        tcp       LISTEN     0          4096                                            *:8086                             *:*         users:(("influxd",pid=946,fd=358))
                                        tcp       LISTEN     0          511                                             *:8084                             *:*         users:(("io.ws.0",pid=2881,fd=34))
                                        tcp       LISTEN     0          511                                             *:8082                             *:*         users:(("io.web.0",pid=201844,fd=35))
                                        tcp       LISTEN     0          511                                             *:tproxy                           *:*         users:(("io.admin.0",pid=1516,fd=39))
                                        2026-05-19 07:46:20.939  - info: foxesscloud.1 (431341) terminating
                                        2026-05-19 07:46:21.459  - info: host.ioBroker instance system.adapter.foxesscloud.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                        2026-05-19 07:46:24.912  - info: host.ioBroker instance system.adapter.foxesscloud.1 in version "0.2.3" started with pid 432358
                                        2026-05-19 07:46:25.815  - info: foxesscloud.1 (432358) starting. Version 0.2.3 in /opt/iobroker/node_modules/iobroker.foxesscloud, node: v22.22.2, js-controller: 7.1.2
                                        2026-05-19 07:46:25.875  - info: foxesscloud.1 (432358) Update interval set to 60 seconds
                                        2026-05-19 07:46:46.437  - info: admin.0 (1516) ==> Connected system.user.admin from ::ffff:192.168.150.50
                                        2026-05-19 07:57:40.390  - info: shelly.0 (2271) [MQTT] Client Close: 192.168.160.180 (shellypmminig3 / shellypmminig3-d0cf13d26c0c / shellypmminig3#d0cf13d26c0c#1) (false)
                                        2026-05-19 07:57:42.471  - info: shelly.0 (2271) [MQTT] Device with client id "shellypmminig3-d0cf13d26c0c" connected from 192.168.160.180!
                                        2026-05-19 07:57:43.576  - info: shelly.0 (2271) [MQTT] Device with client id "shellypmminig3-d0cf13d26c0c" initialized.
                                        2026-05-19 08:00:00.144  - info: host.ioBroker instance system.adapter.ical.0 in version "1.20.1" started with pid 437844
                                        2026-05-19 08:00:02.305  - info: ical.0 (437844) starting. Version 1.20.1 in /opt/iobroker/node_modules/iobroker.ical, node: v22.22.2, js-controller: 7.1.2
                                        2026-05-19 08:00:03.149  - info: ical.0 (437844) processing URL: Sven https://calendar.google.com/calendar/ical/...entfernt...
                                        2026-05-19 08:00:04.180  - info: host.ioBroker instance system.adapter.ical.1 in version "1.20.1" started with pid 437879
                                        2026-05-19 08:00:06.004  - info: ical.1 (437879) starting. Version 1.20.1 in /opt/iobroker/node_modules/iobroker.ical, node: v22.22.2, js-controller: 7.1.2
                                        2026-05-19 08:00:06.750  - info: ical.1 (437879) processing URL: Nicole https://calendar.google.com/calendar/ical/....entfernt....
                                        2026-05-19 08:00:08.216  - info: host.ioBroker instance system.adapter.ical.3 in version "1.20.1" started with pid 437912
                                        2026-05-19 08:00:08.495  - info: ical.0 (437844) Terminated (NO_ERROR): Without reason
                                        2026-05-19 08:00:09.038  - info: host.ioBroker instance system.adapter.ical.0 having pid 437844 terminated with code 0 (NO_ERROR)
                                        2026-05-19 08:00:10.002  - info: ical.3 (437912) starting. Version 1.20.1 in /opt/iobroker/node_modules/iobroker.ical, node: v22.22.2, js-controller: 7.1.2
                                        2026-05-19 08:00:10.590  - info: ical.3 (437912) processing URL: Jannis /basic.ics...entfernt... info: ical.1 (437879) Terminated (NO_ERROR): Without reason
                                        2026-05-19 08:00:12.644  - info: host.ioBroker instance system.adapter.ical.1 having pid 437879 terminated with code 0 (NO_ERROR)
                                        2026-05-19 08:00:15.713  - info: ical.3 (437912) Terminated (NO_ERROR): Without reason
                                        2026-05-19 08:00:16.255  - info: host.ioBroker instance system.adapter.ical.3 having pid 437912 terminated with code 0 (NO_ERROR)
                                        MOD-EDIT: private Daten entfernt!
                                        EDIT:
                                        Falls da jemand etwas komisches entdeckt, Hilfe nehme ich sehr gerne an
                                        #TeamInventwo
                                        Unsere Adapter:
                                        • skvarelS skvarel
                                          ========== Langfassung ab hier markieren und kopieren ===========
                                          ```bash
                                          Script v.2026-05-18
                                          *** GRUNDSYSTEM ***
                                           Static hostname: ioBroker
                                                   Chassis: desktop 🖥️
                                          Docker          : false
                                          Kernel          : x86_64
                                          Userland        : 64bit
                                          CPU threads     : 4
                                          *** LEBENSZYKLUS STATUS ***
                                          *** ZEIT UND ZEITZONEN ***
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          *** User und Gruppen ***
                                          User der 'iob diag' aufgerufen hat:
                                          pi
                                          HOME=/home/pi
                                          User der den 'js-controller' ausführt:
                                          iobroker
                                          HOME=/home/iobroker
                                          Desktop:
                                          Session:                tty
                                          *** MEMORY ***
                                          Swap:           4.3G          0B        4.3G
                                                   7909 M used memory
                                                   5213 M free memory
                                                    583 M buffer memory
                                                   2512 M swap cache
                                                   4095 M total swap
                                                      0 M used swap
                                                   4095 M free swap
                                          0 loaded units listed.
                                          Es wurden keine kritischen Fehler gefunden
                                          *** FILESYSTEM ***
                                          tmpfs                             tmpfs  7.8G     0  7.8G   0% /dev/shm
                                          /var:
                                          5.1G    /var/
                                          4.2G    /var/log
                                          756M    /var/lib
                                          27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
                                          USB-Devices by-id:
                                          USB-Sticks - Vermeide direkte Links zu /dev/tty* in deinen Adapter-Einstellungen,
                                          bevorzuge immer die Links 'by-id':
                                          /usr/bin/npm            10.9.7
                                          /usr/bin/npx            10.9.7
                                          ✓ Node.js ist korrekt installiert
                                          nodejs:
                                            Version table:
                                               22.22.1-1nodesource1 1001
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: redis
                                          Hosts:
                                          admin:          7.8.25
                                          javascript:     9.2.2
                                          Adapter State
                                          + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                          + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
                                          + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
                                            system.adapter.birthdays.0              : birthdays             : ioBroker                                 -  enabled
                                          + system.adapter.brightsky.0              : brightsky             : ioBroker                                 -  enabled
                                          + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: ioBroker                                 -  enabled
                                          + system.adapter.energiefluss-erweitert.1 : energiefluss-erweitert: ioBroker                                 -  enabled
                                            system.adapter.feiertage.0              : feiertage             : ioBroker                                 -  enabled
                                            system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
                                            system.adapter.ical.1                   : ical                  : ioBroker                                 -  enabled
                                          + system.adapter.influxdb.1               : influxdb              : ioBroker                                 -  enabled, port: 8086
                                          + system.adapter.linux-control.0          : linux-control         : ioBroker                                 -  enabled
                                          + system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
                                          + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                                          + system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                          + system.adapter.tankerkoenig.0           : tankerkoenig          : ioBroker                                 -  enabled
                                          + system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
                                          + system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
                                            system.adapter.vis-2-widgets-icontwo.0  : vis-2-widgets-icontwo : ioBroker                                 - disabled
                                            system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: ioBroker                                 - disabled
                                          + instance is alive
                                          Objects and States
                                          Objects:        22344
                                          States:         23015
                                          EDIT:
                                          #801
                                          @skvarel sagte:
                                          Da fehlt dir das Paket, das die Daten für die Unterstützungszeiträume bereitstellt. Müsste per
                                          iob fix
                                          zu beheben sein. Ansonsten von Hand installieren:
                                          sudo apt install distro-info distro-info-data
                                          skvarelS 1 Antwort Letzte Antwort
