  4. io Broker startet nicht mehr
    6.6k
59 Beiträge 7 Kommentatoren 8.6k Aufrufe 6 Beobachtet
  • M MrNight
    wenn ich nur "iob diag" eingebe im Terminal kommt
    (-bash: iob: command not found)
    CodierknechtC Offline
    Codierknecht
    @mrnight
    iobroker diag tut's?
    Wie alt ist denn Deine Installation?
    HmIP|ZigBee|Tasmota|Unifi
    Zabbix Certified Specialist
    • CodierknechtC Codierknecht
      @mrnight
      MrNight
      @codierknecht sagte in io Broker startet nicht mehr:
      iobroker diag
      MAX11905:~ MAX$ ./iobroker diag
      iobroker [command]
      Commands:
      iobroker setup Setup ioBroker
      iobroker start [all|<adapter>.<instance>|<adapter>] Starts the js-controller or a specified adapter instance or all instances of an adapter
      iobroker stop [<adapter>.<instance>|<adapter>] stops the js-controller or a specified adapter instance or all instances of an adapter
      iobroker restart [<adapter>.<instance>|<adapter>] Restarts js-controller or a specified adapter instance or all instances of an adapter [aliases: r]
      iobroker debug <adapter>[.<instance>] Starts a Node.js debugging session for the adapter instance
      iobroker info Shows the host info
      iobroker logs [<adapter>] Monitor log
      iobroker add <adapter> [desiredNumber] Add instance of adapter [aliases: a]
      iobroker install <adapter> Installs a specified adapter [aliases: i]
      iobroker rebuild [<module>] Rebuild all native modules or path
      iobroker url <url> [<name>] Install adapter from specified url, e.g. GitHub, if a package name is provided instead of an url, it will be installed from npm
      iobroker del <adapter> Remove adapter and all instances from this host [aliases: delete]
      iobroker del <adapter>.<instance> Remove adapter instance [aliases: delete]
      iobroker update [<repositoryUrl>] Update repository and list adapters
      iobroker upgrade Upgrade management
      iobroker upload [all|<adapter>] Upload management [aliases: u]
      iobroker object Object management [aliases: o]
      iobroker state State management [aliases: s]
      iobroker message <adapter>[.instance] <command> [<message>] Send message to adapter instance/s
      iobroker list <type> [<filter>] List all entries, like objects
      iobroker chmod <mode> <file> Change file rights
      iobroker chown <user> <group> <file> Change file ownership
      iobroker touch <file> Touch file
      iobroker rm <file> Remove file
      iobroker file File management
      iobroker user User commands
      iobroker group group management
      iobroker host <hostname> Set host to given hostname
      iobroker set <adapter>.<instance> Change settings of adapter config
      iobroker license <license.file or license.text> Update license by given file
      iobroker cert Certificate management
      iobroker clean <yes> Clears all objects and states
      iobroker backup Create backup
      iobroker restore <backup name or path> Restore a specified backup
      iobroker validate <backup name or path> Validate a specified backup
      iobroker status [all|<adapter>.<instance>] Status of ioBroker or adapter instance [aliases: isrun]
      iobroker repo Show repo information
      iobroker uuid Show uuid of the installation [aliases: id]
      iobroker unsetup Reset license, installation secret and language
      iobroker fix Execute the installation fixer script, this updates your ioBroker installation
      iobroker nodejs-update [<major-version>] Upgrade the Node.JS installation to the current LTS
      iobroker multihost Multihost management
      iobroker compact compact group management
      iobroker plugin Plugin management
      iobroker vendor <passphrase> [<vendor.json>] Update the vendor information using given passphrase
      iobroker version [<adapter>] Show version of js-controller or specified adapter [aliases: v]
      Options:
      --help Show help [boolean]
      MAX11905:~ MAX$
      MAX11905:~ MAX$
      die installation ist schon ne zeit her...mehre Jahre
      Und danke allgemein für eure Hilfe.
      • M MrNight
        iobroker diag
        iobroker [command]
        Commands:
        Options:
        MAX11905:~ MAX$
        MAX11905:~ MAX$
        @mrnight
        Unter Linux richtet sich das alles ein, wenn man den
        iob fix
        ausführt. Ob und wie das unter MacOS funktioniert kann ich aber nicht sagen.
          @mrnight
          iob fix
          MrNight
          schrieb am zuletzt editiert von MrNight
          @thomas-braun @Codierknecht
          node:internal/modules/cjs/loader:1228
          throw err;
          Error: Cannot find module '/Users/MAX/node_modules/iobroker.js-controller/lib/setup'
          Require stack:
          • /Users/MAX/iob
            at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15)
            at Module._load (node:internal/modules/cjs/loader:1051:27)
            at Module.require (node:internal/modules/cjs/loader:1311:19)
            at require (node:internal/modules/helpers:179:18)
            at Object.<anonymous> (/Users/MAX/iob:2:1)
            at Module._compile (node:internal/modules/cjs/loader:1469:14)
            at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
            at Module.load (node:internal/modules/cjs/loader:1288:32)
            at Module._load (node:internal/modules/cjs/loader:1104:12)
            at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:173:12) {
            code: 'MODULE_NOT_FOUND',
            requireStack: [ '/Users/MAX/iob' ]
          Node.js v20.18.2
          das kommt dann...
          • Samson71S Offline
            Samson71S Offline
            Samson71
            @mrnight
            Bitte setze Protokolle und Logs in Code-Tags </>.
            Lang genug bist Du dabei und solltest das kennen.
            Markus
            Bitte beachten:
              MrNight
              @Codierknecht @Thomas-Braun
              code_text
              iobroker fix
              Options:
              Das kommt bei iobroker update:
              code_text
              Used repository: beta
              Adapter    "admin"        : 7.4.19   , installed 5.4.9  [Updatable]
              Adapter    "alexa2"       : 3.26.7   , installed 3.19.7 [Updatable]
              Adapter    "backitup"     : 3.0.31   , installed 2.4.12 [Updatable]
              Adapter    "cloud"        : 5.0.1    , installed 4.2.2  [Updatable]
              Adapter    "email"        : 1.3.1    , installed 1.1.3  [Updatable]
              Adapter    "harmony"      : 1.5.0    , installed 1.2.2  [Updatable]
              Adapter    "hm-rpc"       : 2.0.2    , installed 1.15.15 [Updatable]
              Adapter    "hmip"         : 1.26.5   , installed 1.20.0 [Updatable]
              Adapter    "hue"          : 3.14.1   , installed 3.14.1
              Adapter    "iot"          : 3.4.5    , installed 3.4.5
              Adapter    "javascript"   : 8.9.1    , installed 6.0.1  [Updatable]
              Controller "js-controller": 7.0.6    , installed 7.0.6
              Adapter    "musiccast"    : 1.1.4    , installed 1.1.4
              Adapter    "owntracks"    : 1.1.0    , installed 1.0.3  [Updatable]
              Adapter    "pushover"     : 4.1.0    , installed 2.1.0  [Updatable]
              Adapter    "sayit"        : 5.0.0    , installed 1.12.6 [Updatable]
              Adapter    "scenes"       : 4.0.1    , installed 4.0.1
              Adapter    "simple-api"   : 2.8.0    , installed 2.7.1  [Updatable]
              Adapter    "telegram"     : 4.0.0    , installed 1.14.1 [Updatable]
              Adapter    "text2command" : 3.0.3    , installed 3.0.3
              Adapter    "vis"          : 1.5.6    , installed 1.4.15 [Updatable]
              Adapter    "web"          : 6.3.1    , installed 3.4.16 [Updatable]
              Adapter    "yahka"        : 1.0.9    , installed 0.11.0 [Updatable]
              • M MrNight
                code_text
                iobroker fix
                Options:
                code_text
                @mrnight sagte in io Broker startet nicht mehr:
                ernsthaft?
                soooo alte Versionen?
                und dann node so neu?
                das passt nicht.
                bring mal alles auf Stand
                ich weiß nicht ob der fixer aus meiner Signatur besser läuft.
                probiers mal
                CodierknechtC M 2 Antworten Letzte Antwort
                  ernsthaft?
                  das passt nicht.
                  probiers mal
                  Codierknecht
                  @homoran sagte in io Broker startet nicht mehr:
                  Das ist so alt und verstrubbelt, da würde wohl eher 'ne Neuinstallation Sinn machen ;-)
                    ernsthaft?
                    das passt nicht.
                    probiers mal
                    MrNight
                    das system ist die ganze zeit vernünftig gelaufen.
                    1. wie kann ich das nun auf Stand bringen?
                      2.wie funktioniert das mit deinem Installationsfixer?
                    HomoranH ? W 4 Antworten Letzte Antwort
                    • M MrNight
                      Dieser Beitrag wurde gelöscht!
                      • M MrNight
                        @mrnight stell erst mal das Repo auf stable
                        dann machst du nochmsl iob update
                        • M MrNight
                          trotzdem alle 4 Wochen updates machen. Normalerweise haette da der grosse schwarze Boxhandschuh aus'm Monitor kommen muessen.. :)
                          Dein Betriebssystem muss doch auch updates bekommen...
                            MrNight
                            wie kann ich das auf Repo auf stable setzen? wenn ich doch nicht mehr auf die Oberfläche komme?
                            Bitte nicht schlagen.😞
                              MrNight
                              @ilovegym
                              ja da der Mac mini nur für IObroker im Einsatz ist ..... und ich nicht Updates machen wollte vom Mac und dann was nicht mehr Kompatibel ist.... habe ich es gelassen. 🙄
                              Nun ist der Rechner auch auf den neusten Stand. Nochmals passiert das mir nicht.
                              • M MrNight
                                @mrnight :man-shrugging:
                                irgendwas wie iob repo set stable
                                mach mal erst ein iob repo show
                                • M MrNight
                                  @mrnight Nach etwas wühlen im Forum
                                  iob repo list
                                  iob repo unset UNGEWÜNSCHTES_REPO
                                  iob repo set GEWÜNSCHTES_REPO
                                  Der erste Befehl zeigt dir von dir vergebenen Namen der Repos an
                                  der nächste deaktiviert das aktuelle, müsste bei dir beta heissen.
                                  der letzte aktiviert dann das, was stable sein müsste
                                  • M MrNight
                                    @ilovegym
                                    @mrnight ok, alles gut.. das naechste Mal weisste bescheid.. ist immer hinterher mehr arbeit, was altes up to daten als alle eck mal rum zu schauen.. :)
                                    Beim Mac sowieso wieder n Thema.. ganz speziell..
                                      iob repo list
                                      MrNight
                                      @Homoran
                                      So sieht es nun aus.
                                      MAX11905:~ MAX$ ./iobroker repo set 0
                                      Repository "stable" set as active.
                                      Nun habe ich versucht zb. den Admin adapter mit
                                      ./iobroker upgrade admin
                                      die Adapter einzeln zu Updaten
                                      max11905:~ max$ ./iobroker upgrade admin
                                      This upgrade of "admin" will at least introduce the following changes:
                                      -> 7.4.10:
                                      Corrected JSON-Config tables
                                      Corrected translation on the update adapter dialog
                                      -> 7.4.8:
                                      Show latest/stable labels by updating/downgrading of adapters
                                      Corrected selection of chinese language
                                      -> 7.4.7:
                                      Corrected the rendering of custom JSON config components
                                      Corrected the news dialog for multi-line messages
                                      -> 7.4.4:
                                      Showed value in object edit dialog
                                      -> 7.4.3:
                                      Changed information box on the hosts tab
                                      Corrected some errors in JsonConfig library
                                      Added flag expertMode to hide JSON config controls for non-experts
                                      Corrected cloud icon for admin
                                      Added old dialog names to adapter-react-v5 again
                                      -> 7.4.2:
                                      Made improvement for JSONConfig components
                                      Added clear button to text area JSON config component
                                      -> 7.4.1:
                                      BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                                      Would you like to upgrade admin from @5.4.9 to @7.4.10 now? [(y)es, (n)o]:
                                      wenn ich dann auf "Y" startet er auch den Installationsprozess .
                                      Nur wenn ich dann "iobroker Update" mache. Kommt wieder das die Version 5.4.9 Installiert ist .😞
                                      • M MrNight
                                        W Offline
                                        W Offline
                                        warp735
                                        Und dann fällt dir auf einmal ein: "Heute qualm ich mal n Update rein, oder was?!"
                                        • W warp735
                                          Samson71S Offline
                                          Samson71S Offline
                                          Samson71
                                          @warp735
                                          Echt hilfreich so ein sinnloses Nachtreten an 34er Stelle.
                                          Markus
                                          Bitte beachten:
