  4. io Broker startet nicht mehr
    6.6k
59 Beiträge 7 Kommentatoren 8.6k Aufrufe 6 Beobachtet
  • M MrNight
    @codierknecht sagte in io Broker startet nicht mehr:
    iobroker diag
    MAX11905:~ MAX$ ./iobroker diag
    iobroker [command]
    Commands:
    iobroker setup Setup ioBroker
    iobroker start [all|<adapter>.<instance>|<adapter>] Starts the js-controller or a specified adapter instance or all instances of an adapter
    iobroker stop [<adapter>.<instance>|<adapter>] stops the js-controller or a specified adapter instance or all instances of an adapter
    iobroker restart [<adapter>.<instance>|<adapter>] Restarts js-controller or a specified adapter instance or all instances of an adapter [aliases: r]
    iobroker debug <adapter>[.<instance>] Starts a Node.js debugging session for the adapter instance
    iobroker info Shows the host info
    iobroker logs [<adapter>] Monitor log
    iobroker add <adapter> [desiredNumber] Add instance of adapter [aliases: a]
    iobroker install <adapter> Installs a specified adapter [aliases: i]
    iobroker rebuild [<module>] Rebuild all native modules or path
    iobroker url <url> [<name>] Install adapter from specified url, e.g. GitHub, if a package name is provided instead of an url, it will be installed from npm
    iobroker del <adapter> Remove adapter and all instances from this host [aliases: delete]
    iobroker del <adapter>.<instance> Remove adapter instance [aliases: delete]
    iobroker update [<repositoryUrl>] Update repository and list adapters
    iobroker upgrade Upgrade management
    iobroker upload [all|<adapter>] Upload management [aliases: u]
    iobroker object Object management [aliases: o]
    iobroker state State management [aliases: s]
    iobroker message <adapter>[.instance] <command> [<message>] Send message to adapter instance/s
    iobroker list <type> [<filter>] List all entries, like objects
    iobroker chmod <mode> <file> Change file rights
    iobroker chown <user> <group> <file> Change file ownership
    iobroker touch <file> Touch file
    iobroker rm <file> Remove file
    iobroker file File management
    iobroker user User commands
    iobroker group group management
    iobroker host <hostname> Set host to given hostname
    iobroker set <adapter>.<instance> Change settings of adapter config
    iobroker license <license.file or license.text> Update license by given file
    iobroker cert Certificate management
    iobroker clean <yes> Clears all objects and states
    iobroker backup Create backup
    iobroker restore <backup name or path> Restore a specified backup
    iobroker validate <backup name or path> Validate a specified backup
    iobroker status [all|<adapter>.<instance>] Status of ioBroker or adapter instance [aliases: isrun]
    iobroker repo Show repo information
    iobroker uuid Show uuid of the installation [aliases: id]
    iobroker unsetup Reset license, installation secret and language
    iobroker fix Execute the installation fixer script, this updates your ioBroker installation
    iobroker nodejs-update [<major-version>] Upgrade the Node.JS installation to the current LTS
    iobroker multihost Multihost management
    iobroker compact compact group management
    iobroker plugin Plugin management
    iobroker vendor <passphrase> [<vendor.json>] Update the vendor information using given passphrase
    iobroker version [<adapter>] Show version of js-controller or specified adapter [aliases: v]
    Options:
    --help Show help [boolean]
    MAX11905:~ MAX$
    MAX11905:~ MAX$
    die installation ist schon ne zeit her...mehre Jahre
    Und danke allgemein für eure Hilfe.
    @mrnight
    Unter Linux richtet sich das alles ein, wenn man den
    iob fix
    ausführt. Ob und wie das unter MacOS funktioniert kann ich aber nicht sagen.
      @mrnight
      iob fix
      MrNight
      schrieb am zuletzt editiert von MrNight
      @thomas-braun @Codierknecht
      node:internal/modules/cjs/loader:1228
      throw err;
      Error: Cannot find module '/Users/MAX/node_modules/iobroker.js-controller/lib/setup'
      Require stack:
      • /Users/MAX/iob
        at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15)
        at Module._load (node:internal/modules/cjs/loader:1051:27)
        at Module.require (node:internal/modules/cjs/loader:1311:19)
        at require (node:internal/modules/helpers:179:18)
        at Object.<anonymous> (/Users/MAX/iob:2:1)
        at Module._compile (node:internal/modules/cjs/loader:1469:14)
        at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
        at Module.load (node:internal/modules/cjs/loader:1288:32)
        at Module._load (node:internal/modules/cjs/loader:1104:12)
        at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:173:12) {
        code: 'MODULE_NOT_FOUND',
        requireStack: [ '/Users/MAX/iob' ]
      Node.js v20.18.2
      das kommt dann...
      • Samson71S Offline
        Samson71S Offline
        Samson71
        @mrnight
        Bitte setze Protokolle und Logs in Code-Tags </>.
        Lang genug bist Du dabei und solltest das kennen.
        Markus
        Bitte beachten:
          MrNight
          @Codierknecht @Thomas-Braun
          code_text
          iobroker fix
          Options:
          Das kommt bei iobroker update:
          code_text
          Used repository: beta
          Adapter    "admin"        : 7.4.19   , installed 5.4.9  [Updatable]
          Adapter    "alexa2"       : 3.26.7   , installed 3.19.7 [Updatable]
          Adapter    "backitup"     : 3.0.31   , installed 2.4.12 [Updatable]
          Adapter    "cloud"        : 5.0.1    , installed 4.2.2  [Updatable]
          Adapter    "email"        : 1.3.1    , installed 1.1.3  [Updatable]
          Adapter    "harmony"      : 1.5.0    , installed 1.2.2  [Updatable]
          Adapter    "hm-rpc"       : 2.0.2    , installed 1.15.15 [Updatable]
          Adapter    "hmip"         : 1.26.5   , installed 1.20.0 [Updatable]
          Adapter    "hue"          : 3.14.1   , installed 3.14.1
          Adapter    "iot"          : 3.4.5    , installed 3.4.5
          Adapter    "javascript"   : 8.9.1    , installed 6.0.1  [Updatable]
          Controller "js-controller": 7.0.6    , installed 7.0.6
          Adapter    "musiccast"    : 1.1.4    , installed 1.1.4
          Adapter    "owntracks"    : 1.1.0    , installed 1.0.3  [Updatable]
          Adapter    "pushover"     : 4.1.0    , installed 2.1.0  [Updatable]
          Adapter    "sayit"        : 5.0.0    , installed 1.12.6 [Updatable]
          Adapter    "scenes"       : 4.0.1    , installed 4.0.1
          Adapter    "simple-api"   : 2.8.0    , installed 2.7.1  [Updatable]
          Adapter    "telegram"     : 4.0.0    , installed 1.14.1 [Updatable]
          Adapter    "text2command" : 3.0.3    , installed 3.0.3
          Adapter    "vis"          : 1.5.6    , installed 1.4.15 [Updatable]
          Adapter    "web"          : 6.3.1    , installed 3.4.16 [Updatable]
          Adapter    "yahka"        : 1.0.9    , installed 0.11.0 [Updatable]
          • M MrNight
            code_text
            iobroker fix
            Options:
            code_text
            @mrnight sagte in io Broker startet nicht mehr:
            ernsthaft?
            soooo alte Versionen?
            und dann node so neu?
            das passt nicht.
            bring mal alles auf Stand
            ich weiß nicht ob der fixer aus meiner Signatur besser läuft.
            probiers mal
            CodierknechtC M 2 Antworten Letzte Antwort
              ernsthaft?
              das passt nicht.
              probiers mal
              CodierknechtC Offline
              Codierknecht
              @homoran sagte in io Broker startet nicht mehr:
              Das ist so alt und verstrubbelt, da würde wohl eher 'ne Neuinstallation Sinn machen ;-)
              HmIP|ZigBee|Tasmota|Unifi
              Zabbix Certified Specialist
                ernsthaft?
                das passt nicht.
                probiers mal
                MrNight
                das system ist die ganze zeit vernünftig gelaufen.
                1. wie kann ich das nun auf Stand bringen?
                  2.wie funktioniert das mit deinem Installationsfixer?
                HomoranH ? W 4 Antworten Letzte Antwort
                • M MrNight
                  Dieser Beitrag wurde gelöscht!
                  • M MrNight
                    @mrnight stell erst mal das Repo auf stable
                    dann machst du nochmsl iob update
                    • M MrNight
                      trotzdem alle 4 Wochen updates machen. Normalerweise haette da der grosse schwarze Boxhandschuh aus'm Monitor kommen muessen.. :)
                      Dein Betriebssystem muss doch auch updates bekommen...
                        MrNight
                        wie kann ich das auf Repo auf stable setzen? wenn ich doch nicht mehr auf die Oberfläche komme?
                        Bitte nicht schlagen.😞
                          MrNight
                          @ilovegym
                          ja da der Mac mini nur für IObroker im Einsatz ist ..... und ich nicht Updates machen wollte vom Mac und dann was nicht mehr Kompatibel ist.... habe ich es gelassen. 🙄
                          Nun ist der Rechner auch auf den neusten Stand. Nochmals passiert das mir nicht.
                          • M MrNight
                            @mrnight :man-shrugging:
                            irgendwas wie iob repo set stable
                            mach mal erst ein iob repo show
                            • M MrNight
                              @mrnight Nach etwas wühlen im Forum
                              iob repo list
                              iob repo unset UNGEWÜNSCHTES_REPO
                              iob repo set GEWÜNSCHTES_REPO
                              Der erste Befehl zeigt dir von dir vergebenen Namen der Repos an
                              der nächste deaktiviert das aktuelle, müsste bei dir beta heissen.
                              der letzte aktiviert dann das, was stable sein müsste
                              • M MrNight
                                @ilovegym
                                @mrnight ok, alles gut.. das naechste Mal weisste bescheid.. ist immer hinterher mehr arbeit, was altes up to daten als alle eck mal rum zu schauen.. :)
                                Beim Mac sowieso wieder n Thema.. ganz speziell..
                                  iob repo list
                                  MrNight
                                  @Homoran
                                  So sieht es nun aus.
                                  MAX11905:~ MAX$ ./iobroker repo set 0
                                  Repository "stable" set as active.
                                  Nun habe ich versucht zb. den Admin adapter mit
                                  ./iobroker upgrade admin
                                  die Adapter einzeln zu Updaten
                                  max11905:~ max$ ./iobroker upgrade admin
                                  This upgrade of "admin" will at least introduce the following changes:
                                  -> 7.4.10:
                                  Corrected JSON-Config tables
                                  Corrected translation on the update adapter dialog
                                  -> 7.4.8:
                                  Show latest/stable labels by updating/downgrading of adapters
                                  Corrected selection of chinese language
                                  -> 7.4.7:
                                  Corrected the rendering of custom JSON config components
                                  Corrected the news dialog for multi-line messages
                                  -> 7.4.4:
                                  Showed value in object edit dialog
                                  -> 7.4.3:
                                  Changed information box on the hosts tab
                                  Corrected some errors in JsonConfig library
                                  Added flag expertMode to hide JSON config controls for non-experts
                                  Corrected cloud icon for admin
                                  Added old dialog names to adapter-react-v5 again
                                  -> 7.4.2:
                                  Made improvement for JSONConfig components
                                  Added clear button to text area JSON config component
                                  -> 7.4.1:
                                  BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                                  Would you like to upgrade admin from @5.4.9 to @7.4.10 now? [(y)es, (n)o]:
                                  wenn ich dann auf "Y" startet er auch den Installationsprozess .
                                  Nur wenn ich dann "iobroker Update" mache. Kommt wieder das die Version 5.4.9 Installiert ist .😞
                                  • M MrNight
                                    W Offline
                                    W Offline
                                    warp735
                                    Und dann fällt dir auf einmal ein: "Heute qualm ich mal n Update rein, oder was?!"
                                    • W warp735
                                      Samson71S Offline
                                      Samson71S Offline
                                      Samson71
                                      @warp735
                                      Echt hilfreich so ein sinnloses Nachtreten an 34er Stelle.
                                      Markus
                                      Bitte beachten:
                                      • M MrNight
                                        @Homoran
                                        -> 7.4.10:
                                        -> 7.4.8:
                                        -> 7.4.7:
                                        -> 7.4.4:
                                        -> 7.4.3:
                                        -> 7.4.2:
                                        -> 7.4.1:
                                        zeigen!
                                        ggf. stimmen irgendwelche Abhängigkeiten nicht.
                                        Ich fürchte auch, dass du den controller von einer ebenso antiken Verdion direkt auf due v7 gehoben hast, was nicht vorgesehen ist, und zu Kollateralschäden führt
                                          MrNight
                                          MAX11905:~ MAX$ ./iobroker update
                                          Used repositories: beta, stable
                                          Adapter    "admin"        : 7.4.10   , installed 5.4.9  [Updatable]
                                          Adapter    "alexa2"       : 3.26.5   , installed 3.19.7 [Updatable]
                                          Adapter    "hmip"         : 1.25.0   , installed 1.20.0 [Updatable]
                                          Adapter    "hue"          : 3.13.1   , installed 3.14.1
                                          Adapter    "iot"          : 3.3.0    , installed 3.4.5
                                          Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                                          Adapter    "scenes"       : 3.2.3    , installed 4.0.1
                                          Adapter    "web"          : 6.2.5    , installed 3.4.16 [Updatable]
                                          Adapter    "yahka"        : 1.0.3    , installed 0.11.0 [Updatable]
                                          MAX11905:~ MAX$
                                          so sieht das dann immer noch aus.
                                          Wenn ich dann nur den Admin Adapter Updaten will.
                                          MAX11905:~ MAX$ ./iobroker upgrade admin
                                          -> 7.4.10:
                                          -> 7.4.8:
                                          -> 7.4.7:
                                          -> 7.4.4:
                                          -> 7.4.3:
                                          -> 7.4.2:
                                          -> 7.4.1:
                                          das bestätige ich dann mit "y"
                                          dann erscheint das:
                                          host.E11905.fritz.box Adapter "system.adapter.admin.0" is stopped.
                                          NPM version: 10.8.2
                                          Installing iobroker.admin@7.4.10... (System call)
                                          added 81 packages, removed 6 packages, changed 11 packages, and audited 1056 packages in 21s
                                          98 packages are looking for funding
                                            run `npm fund` for details
                                          88 vulnerabilities (12 low, 47 moderate, 24 high, 5 critical)
                                          To address issues that do not require attention, run:
                                            npm audit fix
                                          To address all issues possible (including breaking changes), run:
                                            npm audit fix --force
                                          Some issues need review, and may require choosing
                                          a different dependency.
                                          Run `npm audit` for details.
                                          Updating objects from io-package.json for adapter "admin" with version "7.4.10"
                                          Update "system.adapter.admin.0"
                                          upload [312] admin.admin /Users/e/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                                          upload [300] admin.admin /Users/enricoklimczak/node_modules/iobroker.admin/admin/custom/i18n/ru.json custom/i18n/ru.json application/json
                                          upload [250] admin.admin /Users/e/node_modules/iobroker.admin/admin/custom/static/js/node_modules_mui_system_esm_useTheme_useTheme_js-_95041.7238f945.chunk.js custom/static/js/node_modules_mui_system_esm_useTheme_useTheme_js-_95041.7238f945.chunk.js application/javascript
                                          upload [200] admin.admin /Users/e/node_modules/iobroker.admin/admin/custom/static/js/src_bootstrap_jsx.b1e4762d.chunk.js custom/static/js/src_bootstrap_jsx.b1e4762d.chunk.js application/javascript
                                          upload [150] admin.admin /Users/e/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_iobroker_json-config_build_index_js.fcf5d44e.chunk.js custom/static/js/vendors-node_modules_iobroker_json-config_build_index_js.fcf5d44e.chunk.js application/javascript
                                          upload [100] admin.admin /Users/e/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_FilledInput_FilledInput_js.08770d2e.chunk.js custom/static/js/vendors-node_modules_mui_material_FilledInput_FilledInput_js.08770d2e.chunk.js application/javascript
                                          upload [90] admin.admin /Users/e/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_colors_index_js-node_modules_mui_material_styles_index_js.f075e886.chunk.js custom/static/js/vendors-node_modules_mui_material_colors_index_js-node_modules_mui_material_styles_index_js.f075e886.chunk.js application/javascript
                                          upload [80] admin.admin /Users/e/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_styles_defaultTheme_js-node_modules_mui_material_styles_ide-00a7ec.54dc30ec.chunk.js custom/static/js/vendors-node_modules_mui_material_styles_defaultTheme_js-node_modules_mui_material_styles_ide-00a7ec.54dc30ec.chunk.js application/javascript
                                          upload [70] admin.admin /Users/e/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_styles_useTheme_js-node_modules_cronstrue_locales_de_js-nod-b40f79.ee63d226.chunk.js custom/static/js/vendors-node_modules_mui_material_styles_useTheme_js-node_modules_cronstrue_locales_de_js-nod-b40f79.ee63d226.chunk.js application/javascript
                                          upload [60] admin.admin /Users/e/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_system_esm_colorManipulator_colorManipulator_js-node_modules_mui_sys-525238.332f7d66.chunk.js custom/static/js/vendors-node_modules_mui_system_esm_colorManipulator_colorManipulator_js-node_modules_mui_sys-525238.332f7d66.chunk.js application/javascript
                                          upload [50] admin.admin /Users/e/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_x-date-pickers_index_js.eed2bb86.chunk.js custom/static/js/vendors-node_modules_mui_x-date-pickers_index_js.eed2bb86.chunk.js application/javascript
                                          upload [40] admin.admin /Users/enrico/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-color_es_index_js.1328581e.chunk.js custom/static/js/vendors-node_modules_react-color_es_index_js.1328581e.chunk.js application/javascript
                                          upload [30] admin.admin /Users/enriconode_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.98467b71.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.98467b71.chunk.js application/javascript
                                          upload [20] admin.admin /Users/enrico/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.bfe7ef04.chunk.js custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.bfe7ef04.chunk.js application/javascript
                                          upload [19] admin.admin /Users/e/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.bfe7ef04.chunk.js.map custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.bfe7ef04.chunk.js.map application/json
                                          upload [18] admin.admin /Users/e/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-icons_fa_index_mjs.9fe68fd5.chunk.js custom/static/js/vendors-node_modules_react-icons_fa_index_mjs.9fe68fd5.chunk.js application/javascript
                                          upload [17] admin.admin /Users/e/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-icons_fa_index_mjs.9fe68fd5.chunk.js.map custom/static/js/vendors-node_modules_react-icons_fa_index_mjs.9fe68fd5.chunk.js.map application/json
                                          upload [16] admin.admin /Users/e/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-qr-code_lib_index_js.0471d4fd.chunk.js custom/static/js/vendors-node_modules_react-qr-code_lib_index_js.0471d4fd.chunk.js application/javascript
                                          upload [15] admin.admin /Users/e/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-qr-code_lib_index_js.0471d4fd.chunk.js.map custom/static/js/vendors-node_modules_react-qr-code_lib_index_js.0471d4fd.chunk.js.map application/json
                                          upload [14] admin.admin /Users/e/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-qr-code_lib_index_js.38e93c56.chunk.js custom/static/js/vendors-node_modules_react-qr-code_lib_index_js.38e93c56.chunk.js application/javascript
                                          upload [13] admin.admin /Users/e/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-qr-code_lib_index_js.38e93c56.chunk.js.map custom/static/js/vendors-node_modules_react-qr-code_lib_index_js.38e93c56.chunk.js.map application/json
                                          upload [12] admin.admin /Users/e/node_modules/iobroker.admin/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
                                          upload [11] admin.admin /Users/e/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                          upload [10] admin.admin /Users/e/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                          upload [9] admin.admin /Users/e/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                          upload [8] admin.admin /Users/e/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                          upload [7] admin.admin /Users/e/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                          upload [6] admin.admin /Users/e/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                          upload [5] admin.admin /Users/e/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                          upload [4] admin.admin /Users/e/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                          upload [3] admin.admin /Users/e/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                          upload [2] admin.admin /Users/e/node_modules/iobroker.admin/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                                          upload [1] admin.admin /Users/e/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                          upload [0] admin.admin /Users/e/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
                                          host.Eini11905.fritz.box Adapter "system.adapter.admin.0" is started
                                          E11905:~ e$
                                          wenn man dann wieder "iobroker update macht zeigt er an das es wieder nur die 5 Version ist. Hoffe habe das einigermaßen Verständlich rüber gebracht.
                                          Danke Dir.....
