  4. io Broker startet nicht mehr
    6.6k
59 Beiträge 7 Kommentatoren 8.6k Aufrufe 6 Beobachtet
    MrNight
    @thomas-braun sagte in io Broker startet nicht mehr:
    iob diag
    Error: Cannot find module '/Users/MAX/node_modules/iobroker.js-controller/lib/setup'
    Require stack:
    • /Users/MAX/iob
      at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15)
      at Module._load (node:internal/modules/cjs/loader:1051:27)
      at Module.require (node:internal/modules/cjs/loader:1311:19)
      at require (node:internal/modules/helpers:179:18)
      at Object.<anonymous> (/Users/MAX/iob:2:1)
      at Module._compile (node:internal/modules/cjs/loader:1469:14)
      at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
      at Module.load (node:internal/modules/cjs/loader:1288:32)
      at Module._load (node:internal/modules/cjs/loader:1104:12)
      at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:173:12) {
      code: 'MODULE_NOT_FOUND',
      requireStack: [ '/Users/MAX/iob' ]
    Node.js v20.18.2
    das spuckt er nun aktuell raus bei ./iob diag
    • M MrNight
      iob diag
      Require stack:
      • /Users/MAX/iob
      Node.js v20.18.2
      @mrnight sagte in io Broker startet nicht mehr:
      Das muss aber auch auf einem Mac dann anders aussehen.
        MrNight
        wenn ich nur "iob diag" eingebe im Terminal kommt
        (-bash: iob: command not found)
        • M MrNight
          CodierknechtC Offline
          Codierknecht
          @mrnight
          iobroker diag tut's?
          Wie alt ist denn Deine Installation?
          HmIP|ZigBee|Tasmota|Unifi
          Zabbix Certified Specialist
          • CodierknechtC Codierknecht
            @mrnight
            MrNight
            @codierknecht sagte in io Broker startet nicht mehr:
            iobroker diag
            MAX11905:~ MAX$ ./iobroker diag
            iobroker [command]
            Commands:
            iobroker setup Setup ioBroker
            iobroker start [all|<adapter>.<instance>|<adapter>] Starts the js-controller or a specified adapter instance or all instances of an adapter
            iobroker stop [<adapter>.<instance>|<adapter>] stops the js-controller or a specified adapter instance or all instances of an adapter
            iobroker restart [<adapter>.<instance>|<adapter>] Restarts js-controller or a specified adapter instance or all instances of an adapter [aliases: r]
            iobroker debug <adapter>[.<instance>] Starts a Node.js debugging session for the adapter instance
            iobroker info Shows the host info
            iobroker logs [<adapter>] Monitor log
            iobroker add <adapter> [desiredNumber] Add instance of adapter [aliases: a]
            iobroker install <adapter> Installs a specified adapter [aliases: i]
            iobroker rebuild [<module>] Rebuild all native modules or path
            iobroker url <url> [<name>] Install adapter from specified url, e.g. GitHub, if a package name is provided instead of an url, it will be installed from npm
            iobroker del <adapter> Remove adapter and all instances from this host [aliases: delete]
            iobroker del <adapter>.<instance> Remove adapter instance [aliases: delete]
            iobroker update [<repositoryUrl>] Update repository and list adapters
            iobroker upgrade Upgrade management
            iobroker upload [all|<adapter>] Upload management [aliases: u]
            iobroker object Object management [aliases: o]
            iobroker state State management [aliases: s]
            iobroker message <adapter>[.instance] <command> [<message>] Send message to adapter instance/s
            iobroker list <type> [<filter>] List all entries, like objects
            iobroker chmod <mode> <file> Change file rights
            iobroker chown <user> <group> <file> Change file ownership
            iobroker touch <file> Touch file
            iobroker rm <file> Remove file
            iobroker file File management
            iobroker user User commands
            iobroker group group management
            iobroker host <hostname> Set host to given hostname
            iobroker set <adapter>.<instance> Change settings of adapter config
            iobroker license <license.file or license.text> Update license by given file
            iobroker cert Certificate management
            iobroker clean <yes> Clears all objects and states
            iobroker backup Create backup
            iobroker restore <backup name or path> Restore a specified backup
            iobroker validate <backup name or path> Validate a specified backup
            iobroker status [all|<adapter>.<instance>] Status of ioBroker or adapter instance [aliases: isrun]
            iobroker repo Show repo information
            iobroker uuid Show uuid of the installation [aliases: id]
            iobroker unsetup Reset license, installation secret and language
            iobroker fix Execute the installation fixer script, this updates your ioBroker installation
            iobroker nodejs-update [<major-version>] Upgrade the Node.JS installation to the current LTS
            iobroker multihost Multihost management
            iobroker compact compact group management
            iobroker plugin Plugin management
            iobroker vendor <passphrase> [<vendor.json>] Update the vendor information using given passphrase
            iobroker version [<adapter>] Show version of js-controller or specified adapter [aliases: v]
            Options:
            --help Show help [boolean]
            MAX11905:~ MAX$
            MAX11905:~ MAX$
            die installation ist schon ne zeit her...mehre Jahre
            Und danke allgemein für eure Hilfe.
            • M MrNight
              iobroker diag
              iobroker [command]
              Commands:
              Options:
              MAX11905:~ MAX$
              MAX11905:~ MAX$
              @mrnight
              Unter Linux richtet sich das alles ein, wenn man den
              iob fix
              ausführt. Ob und wie das unter MacOS funktioniert kann ich aber nicht sagen.
                @mrnight
                iob fix
                MrNight
                schrieb am zuletzt editiert von MrNight
                @thomas-braun @Codierknecht
                node:internal/modules/cjs/loader:1228
                throw err;
                Require stack:
                • /Users/MAX/iob
                Node.js v20.18.2
                das kommt dann...
                • Samson71S Offline
                  Samson71S Offline
                  Samson71
                  @mrnight
                  Bitte setze Protokolle und Logs in Code-Tags </>.
                  Lang genug bist Du dabei und solltest das kennen.
                  Markus
                  Bitte beachten:
                    MrNight
                    @Codierknecht @Thomas-Braun
                    code_text
                    iobroker fix
                    Options:
                    Das kommt bei iobroker update:
                    code_text
                    Used repository: beta
                    Adapter    "admin"        : 7.4.19   , installed 5.4.9  [Updatable]
                    Adapter    "alexa2"       : 3.26.7   , installed 3.19.7 [Updatable]
                    Adapter    "backitup"     : 3.0.31   , installed 2.4.12 [Updatable]
                    Adapter    "cloud"        : 5.0.1    , installed 4.2.2  [Updatable]
                    Adapter    "email"        : 1.3.1    , installed 1.1.3  [Updatable]
                    Adapter    "harmony"      : 1.5.0    , installed 1.2.2  [Updatable]
                    Adapter    "hm-rpc"       : 2.0.2    , installed 1.15.15 [Updatable]
                    Adapter    "hmip"         : 1.26.5   , installed 1.20.0 [Updatable]
                    Adapter    "hue"          : 3.14.1   , installed 3.14.1
                    Adapter    "iot"          : 3.4.5    , installed 3.4.5
                    Adapter    "javascript"   : 8.9.1    , installed 6.0.1  [Updatable]
                    Controller "js-controller": 7.0.6    , installed 7.0.6
                    Adapter    "musiccast"    : 1.1.4    , installed 1.1.4
                    Adapter    "owntracks"    : 1.1.0    , installed 1.0.3  [Updatable]
                    Adapter    "pushover"     : 4.1.0    , installed 2.1.0  [Updatable]
                    Adapter    "sayit"        : 5.0.0    , installed 1.12.6 [Updatable]
                    Adapter    "scenes"       : 4.0.1    , installed 4.0.1
                    Adapter    "simple-api"   : 2.8.0    , installed 2.7.1  [Updatable]
                    Adapter    "telegram"     : 4.0.0    , installed 1.14.1 [Updatable]
                    Adapter    "text2command" : 3.0.3    , installed 3.0.3
                    Adapter    "vis"          : 1.5.6    , installed 1.4.15 [Updatable]
                    Adapter    "web"          : 6.3.1    , installed 3.4.16 [Updatable]
                    Adapter    "yahka"        : 1.0.9    , installed 0.11.0 [Updatable]
                    • M MrNight
                      code_text
                      iobroker fix
                      Options:
                      code_text
                      ernsthaft?
                      soooo alte Versionen?
                      und dann node so neu?
                      das passt nicht.
                      bring mal alles auf Stand
                      ich weiß nicht ob der fixer aus meiner Signatur besser läuft.
                      probiers mal
                      CodierknechtC M 2 Antworten Letzte Antwort
                        ernsthaft?
                        das passt nicht.
                        probiers mal
                        Codierknecht
                        @homoran sagte in io Broker startet nicht mehr:
                        Das ist so alt und verstrubbelt, da würde wohl eher 'ne Neuinstallation Sinn machen ;-)
                          ernsthaft?
                          das passt nicht.
                          probiers mal
                          MrNight
                          das system ist die ganze zeit vernünftig gelaufen.
                          1. wie kann ich das nun auf Stand bringen?
                            2.wie funktioniert das mit deinem Installationsfixer?
                          HomoranH ? W 4 Antworten Letzte Antwort
                          • M MrNight
                            Dieser Beitrag wurde gelöscht!
                            • M MrNight
                              @mrnight stell erst mal das Repo auf stable
                              dann machst du nochmsl iob update
                              • M MrNight
                                trotzdem alle 4 Wochen updates machen. Normalerweise haette da der grosse schwarze Boxhandschuh aus'm Monitor kommen muessen.. :)
                                Dein Betriebssystem muss doch auch updates bekommen...
                                  MrNight
                                  wie kann ich das auf Repo auf stable setzen? wenn ich doch nicht mehr auf die Oberfläche komme?
                                  Bitte nicht schlagen.😞
                                    MrNight
                                    @ilovegym
                                    ja da der Mac mini nur für IObroker im Einsatz ist ..... und ich nicht Updates machen wollte vom Mac und dann was nicht mehr Kompatibel ist.... habe ich es gelassen. 🙄
                                    Nun ist der Rechner auch auf den neusten Stand. Nochmals passiert das mir nicht.
                                    • M MrNight
                                      @mrnight :man-shrugging:
                                      irgendwas wie iob repo set stable
                                      mach mal erst ein iob repo show
                                      • M MrNight
                                        @mrnight Nach etwas wühlen im Forum
                                        iob repo list
                                        iob repo unset UNGEWÜNSCHTES_REPO
                                        iob repo set GEWÜNSCHTES_REPO
                                        Der erste Befehl zeigt dir von dir vergebenen Namen der Repos an
                                        der nächste deaktiviert das aktuelle, müsste bei dir beta heissen.
                                        der letzte aktiviert dann das, was stable sein müsste
                                        • M MrNight
                                          @ilovegym
                                          @mrnight ok, alles gut.. das naechste Mal weisste bescheid.. ist immer hinterher mehr arbeit, was altes up to daten als alle eck mal rum zu schauen.. :)
                                          Beim Mac sowieso wieder n Thema.. ganz speziell..
