  4. io Broker startet nicht mehr
    6.6k
59 Beiträge 7 Kommentatoren 8.6k Aufrufe 6 Beobachtet
  • CodierknechtC Codierknecht
    @mrnight
    iobroker diag tut's?
    Wie alt ist denn Deine Installation?
    MrNight
    @codierknecht sagte in io Broker startet nicht mehr:
    iobroker diag
    MAX11905:~ MAX$ ./iobroker diag
    iobroker [command]
    Commands:
    iobroker setup Setup ioBroker
    iobroker start [all|<adapter>.<instance>|<adapter>] Starts the js-controller or a specified adapter instance or all instances of an adapter
    iobroker stop [<adapter>.<instance>|<adapter>] stops the js-controller or a specified adapter instance or all instances of an adapter
    iobroker restart [<adapter>.<instance>|<adapter>] Restarts js-controller or a specified adapter instance or all instances of an adapter [aliases: r]
    iobroker debug <adapter>[.<instance>] Starts a Node.js debugging session for the adapter instance
    iobroker info Shows the host info
    iobroker logs [<adapter>] Monitor log
    iobroker add <adapter> [desiredNumber] Add instance of adapter [aliases: a]
    iobroker install <adapter> Installs a specified adapter [aliases: i]
    iobroker rebuild [<module>] Rebuild all native modules or path
    iobroker url <url> [<name>] Install adapter from specified url, e.g. GitHub, if a package name is provided instead of an url, it will be installed from npm
    iobroker del <adapter> Remove adapter and all instances from this host [aliases: delete]
    iobroker del <adapter>.<instance> Remove adapter instance [aliases: delete]
    iobroker update [<repositoryUrl>] Update repository and list adapters
    iobroker upgrade Upgrade management
    iobroker upload [all|<adapter>] Upload management [aliases: u]
    iobroker object Object management [aliases: o]
    iobroker state State management [aliases: s]
    iobroker message <adapter>[.instance] <command> [<message>] Send message to adapter instance/s
    iobroker list <type> [<filter>] List all entries, like objects
    iobroker chmod <mode> <file> Change file rights
    iobroker chown <user> <group> <file> Change file ownership
    iobroker touch <file> Touch file
    iobroker rm <file> Remove file
    iobroker file File management
    iobroker user User commands
    iobroker group group management
    iobroker host <hostname> Set host to given hostname
    iobroker set <adapter>.<instance> Change settings of adapter config
    iobroker license <license.file or license.text> Update license by given file
    iobroker cert Certificate management
    iobroker clean <yes> Clears all objects and states
    iobroker backup Create backup
    iobroker restore <backup name or path> Restore a specified backup
    iobroker validate <backup name or path> Validate a specified backup
    iobroker status [all|<adapter>.<instance>] Status of ioBroker or adapter instance [aliases: isrun]
    iobroker repo Show repo information
    iobroker uuid Show uuid of the installation [aliases: id]
    iobroker unsetup Reset license, installation secret and language
    iobroker fix Execute the installation fixer script, this updates your ioBroker installation
    iobroker nodejs-update [<major-version>] Upgrade the Node.JS installation to the current LTS
    iobroker multihost Multihost management
    iobroker compact compact group management
    iobroker plugin Plugin management
    iobroker vendor <passphrase> [<vendor.json>] Update the vendor information using given passphrase
    iobroker version [<adapter>] Show version of js-controller or specified adapter [aliases: v]
    Options:
    --help Show help [boolean]
    MAX11905:~ MAX$
    MAX11905:~ MAX$
    die installation ist schon ne zeit her...mehre Jahre
    Und danke allgemein für eure Hilfe.
    • M MrNight
      iobroker diag
      iobroker [command]
      Commands:
      Options:
      MAX11905:~ MAX$
      MAX11905:~ MAX$
      @mrnight
      Unter Linux richtet sich das alles ein, wenn man den
      iob fix
      ausführt. Ob und wie das unter MacOS funktioniert kann ich aber nicht sagen.
        @mrnight
        iob fix
        MrNight
        schrieb am zuletzt editiert von MrNight
        @thomas-braun @Codierknecht
        node:internal/modules/cjs/loader:1228
        throw err;
        Error: Cannot find module '/Users/MAX/node_modules/iobroker.js-controller/lib/setup'
        Require stack:
        • /Users/MAX/iob
          at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15)
          at Module._load (node:internal/modules/cjs/loader:1051:27)
          at Module.require (node:internal/modules/cjs/loader:1311:19)
          at require (node:internal/modules/helpers:179:18)
          at Object.<anonymous> (/Users/MAX/iob:2:1)
          at Module._compile (node:internal/modules/cjs/loader:1469:14)
          at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
          at Module.load (node:internal/modules/cjs/loader:1288:32)
          at Module._load (node:internal/modules/cjs/loader:1104:12)
          at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:173:12) {
          code: 'MODULE_NOT_FOUND',
          requireStack: [ '/Users/MAX/iob' ]
        Node.js v20.18.2
        das kommt dann...
        • Samson71S Offline
          Samson71S Offline
          Samson71
          @mrnight
          Bitte setze Protokolle und Logs in Code-Tags </>.
          Lang genug bist Du dabei und solltest das kennen.
          Markus
          Bitte beachten:
            MrNight
            @Codierknecht @Thomas-Braun
            code_text
            iobroker fix
            Options:
            Das kommt bei iobroker update:
            code_text
            Used repository: beta
            Adapter    "admin"        : 7.4.19   , installed 5.4.9  [Updatable]
            Adapter    "alexa2"       : 3.26.7   , installed 3.19.7 [Updatable]
            Adapter    "backitup"     : 3.0.31   , installed 2.4.12 [Updatable]
            Adapter    "cloud"        : 5.0.1    , installed 4.2.2  [Updatable]
            Adapter    "email"        : 1.3.1    , installed 1.1.3  [Updatable]
            Adapter    "harmony"      : 1.5.0    , installed 1.2.2  [Updatable]
            Adapter    "hm-rpc"       : 2.0.2    , installed 1.15.15 [Updatable]
            Adapter    "hmip"         : 1.26.5   , installed 1.20.0 [Updatable]
            Adapter    "hue"          : 3.14.1   , installed 3.14.1
            Adapter    "iot"          : 3.4.5    , installed 3.4.5
            Adapter    "javascript"   : 8.9.1    , installed 6.0.1  [Updatable]
            Controller "js-controller": 7.0.6    , installed 7.0.6
            Adapter    "musiccast"    : 1.1.4    , installed 1.1.4
            Adapter    "owntracks"    : 1.1.0    , installed 1.0.3  [Updatable]
            Adapter    "pushover"     : 4.1.0    , installed 2.1.0  [Updatable]
            Adapter    "sayit"        : 5.0.0    , installed 1.12.6 [Updatable]
            Adapter    "scenes"       : 4.0.1    , installed 4.0.1
            Adapter    "simple-api"   : 2.8.0    , installed 2.7.1  [Updatable]
            Adapter    "telegram"     : 4.0.0    , installed 1.14.1 [Updatable]
            Adapter    "text2command" : 3.0.3    , installed 3.0.3
            Adapter    "vis"          : 1.5.6    , installed 1.4.15 [Updatable]
            Adapter    "web"          : 6.3.1    , installed 3.4.16 [Updatable]
            Adapter    "yahka"        : 1.0.9    , installed 0.11.0 [Updatable]
            • M MrNight
              code_text
              iobroker fix
              Options:
              code_text
              @mrnight sagte in io Broker startet nicht mehr:
              ernsthaft?
              soooo alte Versionen?
              und dann node so neu?
              das passt nicht.
              bring mal alles auf Stand
              ich weiß nicht ob der fixer aus meiner Signatur besser läuft.
              probiers mal
              CodierknechtC M 2 Antworten Letzte Antwort
                ernsthaft?
                das passt nicht.
                probiers mal
                CodierknechtC Offline
                Codierknecht
                @homoran sagte in io Broker startet nicht mehr:
                Das ist so alt und verstrubbelt, da würde wohl eher 'ne Neuinstallation Sinn machen ;-)
                HmIP|ZigBee|Tasmota|Unifi
                Zabbix Certified Specialist
                  ernsthaft?
                  das passt nicht.
                  probiers mal
                  MrNight
                  das system ist die ganze zeit vernünftig gelaufen.
                  1. wie kann ich das nun auf Stand bringen?
                    2.wie funktioniert das mit deinem Installationsfixer?
                  HomoranH ? W 4 Antworten Letzte Antwort
                  • M MrNight
                    Dieser Beitrag wurde gelöscht!
                    • M MrNight
                      @mrnight stell erst mal das Repo auf stable
                      dann machst du nochmsl iob update
                      • M MrNight
                        trotzdem alle 4 Wochen updates machen. Normalerweise haette da der grosse schwarze Boxhandschuh aus'm Monitor kommen muessen.. :)
                        Dein Betriebssystem muss doch auch updates bekommen...
                          MrNight
                          wie kann ich das auf Repo auf stable setzen? wenn ich doch nicht mehr auf die Oberfläche komme?
                          Bitte nicht schlagen.😞
                            MrNight
                            @ilovegym
                            ja da der Mac mini nur für IObroker im Einsatz ist ..... und ich nicht Updates machen wollte vom Mac und dann was nicht mehr Kompatibel ist.... habe ich es gelassen. 🙄
                            Nun ist der Rechner auch auf den neusten Stand. Nochmals passiert das mir nicht.
                            • M MrNight
                              @mrnight :man-shrugging:
                              irgendwas wie iob repo set stable
                              mach mal erst ein iob repo show
                              • M MrNight
                                @mrnight Nach etwas wühlen im Forum
                                iob repo list
                                iob repo unset UNGEWÜNSCHTES_REPO
                                iob repo set GEWÜNSCHTES_REPO
                                Der erste Befehl zeigt dir von dir vergebenen Namen der Repos an
                                der nächste deaktiviert das aktuelle, müsste bei dir beta heissen.
                                der letzte aktiviert dann das, was stable sein müsste
                                • M MrNight
                                  @ilovegym
                                  @mrnight ok, alles gut.. das naechste Mal weisste bescheid.. ist immer hinterher mehr arbeit, was altes up to daten als alle eck mal rum zu schauen.. :)
                                  Beim Mac sowieso wieder n Thema.. ganz speziell..
                                    iob repo list
                                    MrNight
                                    @Homoran
                                    So sieht es nun aus.
                                    MAX11905:~ MAX$ ./iobroker repo set 0
                                    Repository "stable" set as active.
                                    Nun habe ich versucht zb. den Admin adapter mit
                                    ./iobroker upgrade admin
                                    die Adapter einzeln zu Updaten
                                    max11905:~ max$ ./iobroker upgrade admin
                                    This upgrade of "admin" will at least introduce the following changes:
                                    -> 7.4.10:
                                    Corrected JSON-Config tables
                                    Corrected translation on the update adapter dialog
                                    -> 7.4.8:
                                    Show latest/stable labels by updating/downgrading of adapters
                                    Corrected selection of chinese language
                                    -> 7.4.7:
                                    Corrected the rendering of custom JSON config components
                                    Corrected the news dialog for multi-line messages
                                    -> 7.4.4:
                                    Showed value in object edit dialog
                                    -> 7.4.3:
                                    Changed information box on the hosts tab
                                    Corrected some errors in JsonConfig library
                                    Added flag expertMode to hide JSON config controls for non-experts
                                    Corrected cloud icon for admin
                                    Added old dialog names to adapter-react-v5 again
                                    -> 7.4.2:
                                    Made improvement for JSONConfig components
                                    Added clear button to text area JSON config component
                                    -> 7.4.1:
                                    BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                                    Would you like to upgrade admin from @5.4.9 to @7.4.10 now? [(y)es, (n)o]:
                                    wenn ich dann auf "Y" startet er auch den Installationsprozess .
                                    Nur wenn ich dann "iobroker Update" mache. Kommt wieder das die Version 5.4.9 Installiert ist .😞
                                    • M MrNight
                                      W Offline
                                      W Offline
                                      warp735
                                      Und dann fällt dir auf einmal ein: "Heute qualm ich mal n Update rein, oder was?!"
                                      • W warp735
                                        Samson71S Offline
                                        Samson71S Offline
                                        Samson71
                                        @warp735
                                        Echt hilfreich so ein sinnloses Nachtreten an 34er Stelle.
                                        Markus
                                        Bitte beachten:
                                        • M MrNight
                                          @Homoran
                                          -> 7.4.10:
                                          -> 7.4.8:
                                          -> 7.4.7:
                                          -> 7.4.4:
                                          -> 7.4.3:
                                          -> 7.4.2:
                                          -> 7.4.1:
                                          zeigen!
                                          ggf. stimmen irgendwelche Abhängigkeiten nicht.
                                          Ich fürchte auch, dass du den controller von einer ebenso antiken Verdion direkt auf due v7 gehoben hast, was nicht vorgesehen ist, und zu Kollateralschäden führt
