  4. io Broker startet nicht mehr
    6.6k
59 Beiträge 7 Kommentatoren 8.6k Aufrufe 6 Beobachtet
    @mrnight sagte in io Broker startet nicht mehr:
    das spuckt er nun aktuell raus bei ./iob diag
    Das muss aber auch auf einem Mac dann anders aussehen.
    MrNight
    wenn ich nur "iob diag" eingebe im Terminal kommt
    (-bash: iob: command not found)
    • M MrNight
      CodierknechtC Offline
      Codierknecht
      @mrnight
      iobroker diag tut's?
      Wie alt ist denn Deine Installation?
      HmIP|ZigBee|Tasmota|Unifi
      Zabbix Certified Specialist
      • CodierknechtC Codierknecht
        @mrnight
        MrNight
        @codierknecht sagte in io Broker startet nicht mehr:
        iobroker diag
        MAX11905:~ MAX$ ./iobroker diag
        iobroker [command]
        Commands:
        iobroker setup Setup ioBroker
        iobroker start [all|<adapter>.<instance>|<adapter>] Starts the js-controller or a specified adapter instance or all instances of an adapter
        iobroker stop [<adapter>.<instance>|<adapter>] stops the js-controller or a specified adapter instance or all instances of an adapter
        iobroker restart [<adapter>.<instance>|<adapter>] Restarts js-controller or a specified adapter instance or all instances of an adapter [aliases: r]
        iobroker debug <adapter>[.<instance>] Starts a Node.js debugging session for the adapter instance
        iobroker info Shows the host info
        iobroker logs [<adapter>] Monitor log
        iobroker add <adapter> [desiredNumber] Add instance of adapter [aliases: a]
        iobroker install <adapter> Installs a specified adapter [aliases: i]
        iobroker rebuild [<module>] Rebuild all native modules or path
        iobroker url <url> [<name>] Install adapter from specified url, e.g. GitHub, if a package name is provided instead of an url, it will be installed from npm
        iobroker del <adapter> Remove adapter and all instances from this host [aliases: delete]
        iobroker del <adapter>.<instance> Remove adapter instance [aliases: delete]
        iobroker update [<repositoryUrl>] Update repository and list adapters
        iobroker upgrade Upgrade management
        iobroker upload [all|<adapter>] Upload management [aliases: u]
        iobroker object Object management [aliases: o]
        iobroker state State management [aliases: s]
        iobroker message <adapter>[.instance] <command> [<message>] Send message to adapter instance/s
        iobroker list <type> [<filter>] List all entries, like objects
        iobroker chmod <mode> <file> Change file rights
        iobroker chown <user> <group> <file> Change file ownership
        iobroker touch <file> Touch file
        iobroker rm <file> Remove file
        iobroker file File management
        iobroker user User commands
        iobroker group group management
        iobroker host <hostname> Set host to given hostname
        iobroker set <adapter>.<instance> Change settings of adapter config
        iobroker license <license.file or license.text> Update license by given file
        iobroker cert Certificate management
        iobroker clean <yes> Clears all objects and states
        iobroker backup Create backup
        iobroker restore <backup name or path> Restore a specified backup
        iobroker validate <backup name or path> Validate a specified backup
        iobroker status [all|<adapter>.<instance>] Status of ioBroker or adapter instance [aliases: isrun]
        iobroker repo Show repo information
        iobroker uuid Show uuid of the installation [aliases: id]
        iobroker unsetup Reset license, installation secret and language
        iobroker fix Execute the installation fixer script, this updates your ioBroker installation
        iobroker nodejs-update [<major-version>] Upgrade the Node.JS installation to the current LTS
        iobroker multihost Multihost management
        iobroker compact compact group management
        iobroker plugin Plugin management
        iobroker vendor <passphrase> [<vendor.json>] Update the vendor information using given passphrase
        iobroker version [<adapter>] Show version of js-controller or specified adapter [aliases: v]
        Options:
        --help Show help [boolean]
        MAX11905:~ MAX$
        MAX11905:~ MAX$
        die installation ist schon ne zeit her...mehre Jahre
        Und danke allgemein für eure Hilfe.
        • M MrNight
          iobroker diag
          iobroker [command]
          Commands:
          Options:
          MAX11905:~ MAX$
          MAX11905:~ MAX$
          @mrnight
          Unter Linux richtet sich das alles ein, wenn man den
          iob fix
          ausführt. Ob und wie das unter MacOS funktioniert kann ich aber nicht sagen.
            @mrnight
            iob fix
            MrNight
            schrieb am zuletzt editiert von MrNight
            @thomas-braun @Codierknecht
            node:internal/modules/cjs/loader:1228
            throw err;
            Error: Cannot find module '/Users/MAX/node_modules/iobroker.js-controller/lib/setup'
            Require stack:
            • /Users/MAX/iob
              at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15)
              at Module._load (node:internal/modules/cjs/loader:1051:27)
              at Module.require (node:internal/modules/cjs/loader:1311:19)
              at require (node:internal/modules/helpers:179:18)
              at Object.<anonymous> (/Users/MAX/iob:2:1)
              at Module._compile (node:internal/modules/cjs/loader:1469:14)
              at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
              at Module.load (node:internal/modules/cjs/loader:1288:32)
              at Module._load (node:internal/modules/cjs/loader:1104:12)
              at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:173:12) {
              code: 'MODULE_NOT_FOUND',
              requireStack: [ '/Users/MAX/iob' ]
            Node.js v20.18.2
            das kommt dann...
            • Samson71S Offline
              Samson71S Offline
              Samson71
              @mrnight
              Bitte setze Protokolle und Logs in Code-Tags </>.
              Lang genug bist Du dabei und solltest das kennen.
              Markus
              Bitte beachten:
                MrNight
                @Codierknecht @Thomas-Braun
                code_text
                iobroker fix
                Options:
                Das kommt bei iobroker update:
                code_text
                Used repository: beta
                Adapter    "admin"        : 7.4.19   , installed 5.4.9  [Updatable]
                Adapter    "alexa2"       : 3.26.7   , installed 3.19.7 [Updatable]
                Adapter    "backitup"     : 3.0.31   , installed 2.4.12 [Updatable]
                Adapter    "cloud"        : 5.0.1    , installed 4.2.2  [Updatable]
                Adapter    "email"        : 1.3.1    , installed 1.1.3  [Updatable]
                Adapter    "harmony"      : 1.5.0    , installed 1.2.2  [Updatable]
                Adapter    "hm-rpc"       : 2.0.2    , installed 1.15.15 [Updatable]
                Adapter    "hmip"         : 1.26.5   , installed 1.20.0 [Updatable]
                Adapter    "hue"          : 3.14.1   , installed 3.14.1
                Adapter    "iot"          : 3.4.5    , installed 3.4.5
                Adapter    "javascript"   : 8.9.1    , installed 6.0.1  [Updatable]
                Controller "js-controller": 7.0.6    , installed 7.0.6
                Adapter    "musiccast"    : 1.1.4    , installed 1.1.4
                Adapter    "owntracks"    : 1.1.0    , installed 1.0.3  [Updatable]
                Adapter    "pushover"     : 4.1.0    , installed 2.1.0  [Updatable]
                Adapter    "sayit"        : 5.0.0    , installed 1.12.6 [Updatable]
                Adapter    "scenes"       : 4.0.1    , installed 4.0.1
                Adapter    "simple-api"   : 2.8.0    , installed 2.7.1  [Updatable]
                Adapter    "telegram"     : 4.0.0    , installed 1.14.1 [Updatable]
                Adapter    "text2command" : 3.0.3    , installed 3.0.3
                Adapter    "vis"          : 1.5.6    , installed 1.4.15 [Updatable]
                Adapter    "web"          : 6.3.1    , installed 3.4.16 [Updatable]
                Adapter    "yahka"        : 1.0.9    , installed 0.11.0 [Updatable]
                • M MrNight
                  code_text
                  iobroker fix
                  Options:
                  code_text
                  ernsthaft?
                  soooo alte Versionen?
                  und dann node so neu?
                  das passt nicht.
                  bring mal alles auf Stand
                  ich weiß nicht ob der fixer aus meiner Signatur besser läuft.
                  probiers mal
                  CodierknechtC M 2 Antworten Letzte Antwort
                    ernsthaft?
                    das passt nicht.
                    probiers mal
                    Codierknecht
                    @homoran sagte in io Broker startet nicht mehr:
                    Das ist so alt und verstrubbelt, da würde wohl eher 'ne Neuinstallation Sinn machen ;-)
                      ernsthaft?
                      das passt nicht.
                      probiers mal
                      MrNight
                      das system ist die ganze zeit vernünftig gelaufen.
                      1. wie kann ich das nun auf Stand bringen?
                        2.wie funktioniert das mit deinem Installationsfixer?
                      HomoranH ? W 4 Antworten Letzte Antwort
                      • M MrNight
                        Dieser Beitrag wurde gelöscht!
                        • M MrNight
                          @mrnight stell erst mal das Repo auf stable
                          dann machst du nochmsl iob update
                          • M MrNight
                            trotzdem alle 4 Wochen updates machen. Normalerweise haette da der grosse schwarze Boxhandschuh aus'm Monitor kommen muessen.. :)
                            Dein Betriebssystem muss doch auch updates bekommen...
                              MrNight
                              wie kann ich das auf Repo auf stable setzen? wenn ich doch nicht mehr auf die Oberfläche komme?
                              Bitte nicht schlagen.😞
                                MrNight
                                @ilovegym
                                ja da der Mac mini nur für IObroker im Einsatz ist ..... und ich nicht Updates machen wollte vom Mac und dann was nicht mehr Kompatibel ist.... habe ich es gelassen. 🙄
                                Nun ist der Rechner auch auf den neusten Stand. Nochmals passiert das mir nicht.
                                • M MrNight
                                  @mrnight :man-shrugging:
                                  irgendwas wie iob repo set stable
                                  mach mal erst ein iob repo show
                                  • M MrNight
                                    @mrnight Nach etwas wühlen im Forum
                                    iob repo list
                                    iob repo unset UNGEWÜNSCHTES_REPO
                                    iob repo set GEWÜNSCHTES_REPO
                                    Der erste Befehl zeigt dir von dir vergebenen Namen der Repos an
                                    der nächste deaktiviert das aktuelle, müsste bei dir beta heissen.
                                    der letzte aktiviert dann das, was stable sein müsste
                                    • M MrNight
                                      @ilovegym
                                      @mrnight ok, alles gut.. das naechste Mal weisste bescheid.. ist immer hinterher mehr arbeit, was altes up to daten als alle eck mal rum zu schauen.. :)
                                      Beim Mac sowieso wieder n Thema.. ganz speziell..
                                        iob repo list
                                        MrNight
                                        @Homoran
                                        So sieht es nun aus.
                                        MAX11905:~ MAX$ ./iobroker repo set 0
                                        Repository "stable" set as active.
                                        Nun habe ich versucht zb. den Admin adapter mit
                                        ./iobroker upgrade admin
                                        die Adapter einzeln zu Updaten
                                        max11905:~ max$ ./iobroker upgrade admin
                                        This upgrade of "admin" will at least introduce the following changes:
                                        -> 7.4.10:
                                        Corrected JSON-Config tables
                                        Corrected translation on the update adapter dialog
                                        -> 7.4.8:
                                        Show latest/stable labels by updating/downgrading of adapters
                                        Corrected selection of chinese language
                                        -> 7.4.7:
                                        Corrected the rendering of custom JSON config components
                                        Corrected the news dialog for multi-line messages
                                        -> 7.4.4:
                                        Showed value in object edit dialog
                                        -> 7.4.3:
                                        Changed information box on the hosts tab
                                        Corrected some errors in JsonConfig library
                                        Added flag expertMode to hide JSON config controls for non-experts
                                        Corrected cloud icon for admin
                                        Added old dialog names to adapter-react-v5 again
                                        -> 7.4.2:
                                        Made improvement for JSONConfig components
                                        Added clear button to text area JSON config component
                                        -> 7.4.1:
                                        BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                                        Would you like to upgrade admin from @5.4.9 to @7.4.10 now? [(y)es, (n)o]:
                                        wenn ich dann auf "Y" startet er auch den Installationsprozess .
                                        Nur wenn ich dann "iobroker Update" mache. Kommt wieder das die Version 5.4.9 Installiert ist .😞
                                        • M MrNight
                                          W Offline
                                          W Offline
                                          warp735
                                          Und dann fällt dir auf einmal ein: "Heute qualm ich mal n Update rein, oder was?!"
