  4. [SourceAnalytix 0.4.8-Final] Released !
    apollon77A
2.3k Beiträge 184 Kommentatoren 1.6m Aufrufe 153 Beobachtet
  • W Willi-Wunder
    @crunchip sagte in [SourceAnalytix 0.4.8-Final] Released !:
    iob list adapters
    pi@iobroker:~ $ iob list adapters
    system.adapter.admin                   : admin          - v6.12.0
    system.adapter.backitup                : backitup       - v2.8.7
    system.adapter.discovery               : discovery      - v4.2.0
    system.adapter.ds18b20                 : ds18b20        - v2.0.5
    system.adapter.flot                    : flot           - v1.12.0
    system.adapter.fullcalendar            : fullcalendar   - v2.2.6
    system.adapter.history                 : history        - v3.0.1
    system.adapter.icons-material-png      : icons-material-png - v0.1.0
    system.adapter.icons-open-icon-library-png: icons-open-icon-library-png - v0.1.3
    system.adapter.influxdb                : influxdb       - v3.2.0
    system.adapter.info                    : info           - v2.0.0
    system.adapter.javascript              : javascript     - v7.1.6
    system.adapter.luxtronik1              : luxtronik1     - v0.3.5
    system.adapter.mqtt                    : mqtt           - v5.1.0
    system.adapter.operating-hours         : operating-hours - v1.0.6
    system.adapter.rpi2                    : rpi2           - v1.3.2
    system.adapter.shelly                  : shelly         - v6.6.1
    system.adapter.simple-api              : simple-api     - v2.7.2
    system.adapter.socketio                : socketio       - v6.6.0
    system.adapter.sourceanalytix          : sourceanalytix - v0.4.14
    system.adapter.tahoma                  : tahoma         - v0.10.2
    system.adapter.telegram                : telegram       - v3.0.0
    system.adapter.telegram-menu           : telegram-menu  - v1.5.1
    system.adapter.text2command            : text2command   - v3.0.2
    system.adapter.vis                     : vis            - v1.5.4
    system.adapter.vis-bars                : vis-bars       - v0.1.4
    system.adapter.vis-colorpicker         : vis-colorpicker - v2.0.3
    system.adapter.vis-google-fonts        : vis-google-fonts - v1.0.4
    system.adapter.vis-history             : vis-history    - v1.0.0
    system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.4.0
    system.adapter.vis-inventwo            : vis-inventwo   - v3.3.3
    system.adapter.vis-jqui-mfd            : vis-jqui-mfd   - v1.0.12
    system.adapter.vis-materialdesign      : vis-materialdesign - v0.5.9
    system.adapter.web                     : web            - v6.1.10
    system.adapter.ws                      : ws             - v2.5.8
    pi@iobroker:~ $
    crunchipC
    crunchipC
    Developer Global Moderator Most Active Forum Testing
    #2103
    @willi-wunder sagte in [SourceAnalytix 0.4.8-Final] Released !:
    oder nochmal löschen und dann installieren
    iob del sourceanalytix
    W 1 Antwort Letzte Antwort
    • W Willi-Wunder
      @crunchip
      Über Github hat er den Adapter auch nicht gefunden. Über Benutzerdefiniert hat es jetzt geklappt. Seltsam, geht aber jetzt wieder.
      Vielen Dank.
      crunchipC
      crunchipC
      #2104
      dann bin ich der Meinung das da mit deinem Netzwerk immer noch etwas nicht passt
      SegwayS 1 Antwort Letzte Antwort
        W
        W
        Willi-Wunder
        schrieb am zuletzt editiert von Willi-Wunder
        #2105
        Nachdem ich das gemacht habe, wird er auch wieder angezeigt.
        Allerdings sind jetzt meine Daten aus dem Adapter mit gelöscht worden. Wieder das Backup einspielen oder kann ich diese wieder anderweitig herstellen? Sorry, bewege mich momentan auf Neuland um das System neu aufzusetzen.....
        • W Willi-Wunder
          crunchipC
          crunchipC
          #2106
          hätte er auch so müssen
          ja und ja
          theoretisch könnte man es auch einzeln zurückholen, da wie du aber schreibst, Neuland, ist es am einfachsten das backup zurück zu spielen
            @fichte ich seh das die Werte im 10 sec Takt rein kommen, ausser hier
            das ist dann genau dein Sprung
            ansonsten fällt mir nichts weiter auf
            F
            F
            Fichte
            #2107
            @crunchip Genau das ist ja das kuriose... Keine AUffälligkeit oder sonstiges...
            Ich benne das teil mal um...
            • F Fichte
              crunchipC
              crunchipC
              #2108
              @fichte sagte in [SourceAnalytix 0.4.8-Final] Released !:
              Keine AUffälligkeit
              ja doch, dir fehlt ein Leistungseintrag um 18:51:05
              folge dessen bzw weiß nicht ob das der Fehler ist, hast du zumindest dann deinen fehlerhaften Zählerstand um 18:51:15
              F 2 Antworten Letzte Antwort
                Keine AUffälligkeit
                F
                F
                Fichte
                #2109
                Keine AUffälligkeit
                Dann stell ich es mal auf 20 sekunden und schau mal was passiert...
                • W
                  W
                  Willi-Wunder
                  #2110
                  ja und ja
                  Hab jetzt das Backup von HistoryDB + InfluxDB eingespielt, bei Objekte Sourceanalytix kommen aber nicht alle Daten, fehlen die Jahre 2021,2022......nur 2023 ist jetzt wieder da. Hab ja noch zugriff auf das alte System. Wo kann ich mit WinSCP die Daten finden?
                  Da sind die Daten nicht drin, oder?
                  Hat sicher erledigt, jetzt ist alles da !!! :-)
                  • DutchmanD Dutchman
                    Hi all,
                    Nach etwas länger er Abwesenheit, wodurch die Entwicklung und bugfixes leider auf sich warten liessen, haben wir die letzten tage sehr viel erreicht :)
                    Nach einigen intensiven Abenden und guter Hilfe in der Analyse und dazu seligen Unterstützung aus der community, erfreut es mich SourceAnalytix 0.4.8-RC.1. ankündigen zu dürfen!
                    Nach Erwartung wird die finale version (SourceAnalytix 0.4.8-RC.1) am Wochenende zum beta testen freigegeben.
                    Bis dahin könnt ihr bereits vergnügen mit der (SourceAnalytix 0.4.8-alpha.135) welche bereits ausgiebig in unserem. Discord Zusammen mit viel nterstuetzng getestet wurde
                    Sollte ihr dennoch Fehler finden bitte ich darum diese hier, oder besser noch auf GitHub, zu melden damit wir zusammen eine stabile version realisieren können.
                    Feuer die weitere Entwicklung und feedback bin ich auf ech angewiesen :)
                    Siehe troubleshoot Sektion !
                    Kan ich mithelfen ? JA! und zwar auf 2 art und weisen :
                    1. den adapter testen und in hier eure Ergebnisse bzw Problemen mitteilen.
                      Das hilft in der Entwicklung und vervolstaendigung der Documentation.
                    2. mir log daten zukommen lassen ueber Fehler odder warnings. Wie geht das ?
                      Ich habe einen centralen logging server wo ihr automatisch die logs hinschicken koennen, im jetzigen moment empfangen ich bereits (nur fuer diese adapter) von 3 Mitglieder die daten.
                      Wollt ihr mitmachen? Sehr gerne :), wie ? :
                    • Forum (PN)
                    • Telegram (@RaffiDuck)
                    • Discord (DutchmanNL oder im channel SourceAnalytix)
                    Ich freue mich sehr über die tatkräftige Unterstützung und feedback der community !
                    Aktuelle Test Version SourceAnalytix 0.4.8
                    Veröffentlichungsdatum 20.01.2021
                    Release candidate planned 28.02.2021
                    Github Link https://github.com/iobroker-community-adapters/ioBroker.sourceanalytix
                    Alpha & Beta support Discord SourceAnalytix
                    0.4.8 (2021-01-20)
                    Breaking changes
                    • (Dutchman) Breaking!!! Move current values to currentYear #135
                    • (Dutchman & ToTXR4Y) MajorChange !: Replaced Current_Reading with CumulativeReading 226
                    New Features
                    • (Dutchman) Code cleanup
                    • (Dutchman) Add back "currentYear"
                    • (Dutchman) (debug) Logging improved
                    • (Dutchman) Weekly reset of weekdays
                    • (Dutchman) Calculation for all states
                    • (Dutchman) change default log-level to info
                    • (Dutchman) Calculation for previous states #242
                    • (Dutchman) Optimized error reporting (Sentry)
                    • (Dutchman) Removed unneeded settings in configuration
                    • (Dutchman) Implemented new configuration for "currentYear"
                    • (Dutchman & ToTXR4Y) implement "05_currentYear" in year root folder #280
                    • (Dutchman) Implemented category cumulative values under year statistics
                    • (Dutchman & ToTXR4Y) implement cached memory slot for initialisation value #226
                    • (Dutchman & ToTXR4Y) Implement log messages if state attributes are changed
                    • (Dutchman & ToTXR4Y) Implement automatically detection of currency from admin settings #247
                    BugFixes
                    • (Dutchman) Bugfix : dev: 0 bug workaround
                    • (Dutchman) Do not round cumulated reading
                    • (Dutchman) Bugfix : delete states in create function
                    • (Dutchman) Bugfix : quarters.1 has no existing object
                    • (Dutchman) Bugfix : Calculations for "previous" values
                    • (Dutchman) Bugfix : Incorrect initialisation for states
                    • (Dutchman) Bugfix : Avoid NULL & 0 values at night reset
                    • (Dutchman) Bugfix : 05_currentYear has no existing object
                    • (Dutchman) Bugfix : Avoid calculation of non-Initialised states
                    • (Dutchman) Bugfix : Cannot read property 'stateDetails' of null
                    • (Dutchman) Correct error handling of "Watt" state initialisation
                    • (Dutchman) Bugfix : Ensure a proper reset and init of Watt values
                    • (Dutchman) Bugfix : Avoid loop if init value is set and > reading
                    • (Dutchman) Bugfix : Caught sentry error : Alias xxxxx has no target
                    • (Dutchman & ToTXR4Y) Bugfix : Rebuild calculation logic which solves :
                      • Watt values : Ensure proper reading start (0 instead of current watt value)
                        Watt values : Ensure proper reading calculation with exponent (0 instead of current watt value) #281
                      • All calculations : correct handling of device reset (if value is reset or 0)
                    • (Dutchman) Bugfix : Incorrect initialisation for Watt values with 0 input
                    • (Dutchman) Bugfix : Only create cumulatedXXX in year statistics if activated
                    • (Dutchman) Bugfix : Incorrect warn message if configuration for objects is changed
                    • (Dutchman) Bugfix : Error {Is not a number, cannot continue calculation} if value = 0
                    • (Dutchman) Bugfix : Throw error if value is NULL for troubleshooting instead of handling incorrect calculation
                    • (Dutchman) Bugfix : Ensure daily reset does not destroy cumulative memory value (Fixes NULL values for Watt after night reset)
                    SegwayS
                    SegwayS
                    Segway
                    #2111
                    @dutchman
                    Ist der Adapter noch nicht im stable ? Ich finde den gar nicht auf meinem Prod.-System ?
                    Laut Adapterliste noch Alpha ???
                    Da schliesst sich die Frage an ob der Adapter wenn ich den aktiviere, aus der Vergangenheit sich die Werte holt und berechnet oder erst ab Zeitpunkt des Aktivieren ? (Ich vermute letzteres)
                    Gruß Dirk
                    • SegwayS Segway
                      @dutchman
                      crunchipC
                      crunchipC
                      #2112
                      @segway berechnet wird ab start/aktivieren
                      nein, ist nicht im stable, installierbar per npm/github
                        SegwayS
                        SegwayS
                        Segway
                        schrieb am zuletzt editiert von Segway
                        #2113
                        Das ist bei mir genauso ! Ist meiner Meinung nach auch richtig.
                        Iobroker ist bei mir rein auf Stable eingestellt (auf meinem Prod. System) und dann ist es mMn nur logisch dass auch per npm oder Github kein Adapter der NICHT im stable ist angezeigt wird. Wäre schlimm wenn es so wäre.
                        Einzig der manuelle weg sprich per Benutzerdefiniert und Github-Link sollte funktionieren, aber das mach ich nunmal nicht, da auf meinem Prof-System nur stable Versionen erscheinen.
                        Nicht falsch verstehen, aber ein Adapter der so lange schon läuft und seit "zig-Monaten" es nicht schafft ins stable zu kommen .... find ich schon komisch --- bitte, wirklich nicht falsch verstehen, aber es gerade bei solchen Projekten (Lob und Adapter & OpenSource generell) halte ich mich strikt an meine Regeln, ansonsten hätte ich ein lustiges Sammelsurium mit alpha, beta und was weiss ich noch für Ständen.
                        Ich finde es halt sehr schade dass ein Thread (und somit Adapter) mit Final - Released es nicht in den stable schafft :-(
                        Ich würde ja meine Hilfe anbieten aber ich verstehe halt von dem ganzen Zeugs nix ... dafür ist mein Hirn nicht gebaut :-)
                        Gruß Dirk
                        • SegwayS Segway
                          crunchipC
                          crunchipC
                          #2114
                          @segway das liegt daran, das der Adapter noch das ein oder andere Problem bereitet(welches aber nicht bei jedem auftritt und so auch nicht einfach aus der Welt zu schaffen ist.
                          Wenn ich mich recht entsinne, war der Adapter in einer vorherigen/älteren Version mal im stable.
                          Aktuell wird der Adapter komplett neu geschrieben, von daher musst du dich noch ein wenig gedulden.
                          alternativen wären, je nachdem was du genau suchst/vor hast
                          https://github.com/iobroker-community-adapters/ioBroker.statistics
                          oder
                          https://github.com/Omega236/ioBroker.valuetrackerovertime
                            Keine AUffälligkeit
                            F
                            F
                            Fichte
                            #2115
                            Keine AUffälligkeit
                            Ich hab es jetzt über die Weinachtstage auf 20 sekunden gestellt. Aber nix da... immer der gleiche fehler... Ich teste mal noch 1-2 sachen... aber solangsam weiss ich auch nicht mehr 🙄
                            Aber dir Trotzdem noch ein frohes fest
                            • F Fichte
                              Keine AUffälligkeit
                              crunchipC
                              crunchipC
                              #2116
                              und sind da auch wieder zeitliche Sprünge/Aussetzer festzustellen?
                                F
                                F
                                Fichte
                                #2117
                                Die History war aus 🙄
                                Fange noch mal neu an 😬
                                Er hat ab dem Fehler weiter gemacht und bei soviel zahlen sagt Copy/Paste Error 🤣 🤣
                                • P
                                  P
                                  PrinzEisenherz1
                                  #2118
                                  Wann kann denn mit dem neu geschrieben Adapter gerechnet werden? 😁
                                  Gruß Johnny
                                  Intel-NUC mit ProxMox: ioBroker,SQL, logging Strom- Gas- u. Wasserzähler;10Zoll Tab im Flur für VIS; weiteres: Homematic CCU2, Homeduino, Kameras, selbstgebaute Wetterstation;
                                  • P PrinzEisenherz1
                                    Gruß Johnny
                                    crunchipC
                                    crunchipC
                                    #2119
                                    @prinzeisenherz1 dieses Jahr wohl nimmer😜
                                    P 1 Antwort Letzte Antwort
                                      P
                                      P
                                      PrinzEisenherz1
                                      #2120
                                      @crunchip lach....mit der Antwort hab ich jetzt nicht gerechnet 😉
                                        F
                                        F
                                        Fichte
                                        #2121
                                        Der Fehler tritt immer und immer wieder auf 🙄
                                        Aus dem Log vom Source:
                                        Aus dem Log vom Wert:
                                        Ich kann mir da echt keinen reim draus bilden wieso der Sourceanalytix den Sprung macht... Eigentlich hat er doch keine Grundlage dafür...
                                        • F Fichte
                                          Hallo zusammen
                                          Ich lese einen Stromzähler via SML Tasmota aus (Watt).
                                          Ab einen gewissen Punkt Springt Sourceanalytix um und schreibt Utopische werte
                                          Ich hab die schon die Werte gelöscht und auch die einstellung dazu noch einmal komplett neu gemacht.
                                          Aber ab irgend einen Punkt Springt er dann auf solche werte.
                                          Habe via History die Daten mit gelogt um zu schauen ob es nicht an Utopischen leistungswerten liegt, aber da ist alles Super und nie ein wert Über 12000 Watt.
                                          Habe noch andere Geräte wie EM3 und Gosund etc. und dort funktioniert alles super.
                                          Hat oder hatte jemand schon das selbe Problem und/oder gibt es hier eine Lösung.?
                                          Liebe Grüße
                                          D
                                          D
                                          derelvis
                                          #2122
                                          @fichte Sehr seltsamer Effekt!
                                          Ich lese auch mit Tasmota meinen Zweirichtungszähler aus. Welche Werte liefert denn deiner?
                                          Bei meinem bekomme ich Gesamtverbrauch (kWh), Gesamteinspeisung (kWh) und aktueller Verbrauch/Einspeisung (W).
                                          Meine Einstellung sind an sich identisch mit deinen für die beiden Datenpunkte Gesamt-Verbrauch und Gesamt-Einspeisung außer, dass ich als Einheit für total_in und total_out kWh gewählt habe.
                                          Lässt du SA auf den Datenpunkt mit dem aktuellen Wert rechnen oder warum in W?
                                          F joergeliJ 2 Antworten Letzte Antwort
                                          83.9k
