  4. HD voll kein Zugriff mehr
43 Beiträge 8 Kommentatoren 5.1k Aufrufe 6 Beobachtet
  • M Mariatschi0815
    So, was lange wehrt.
    Also ich hab mich dazu entschlossen den Pi neu aufzusetzen. Jetzt hakt es aber schon. Ich habe ein 64bit System aufgesetzt und bisher nur den iobroker und mosquitto installiert.
    Wenn ich jetzt einen service restart von mosquitto durchführe kommt folgende Meldung:
    Job for mosquitto.service failed because the control process exited with error code.
    See "systemctl status mosquitto.service" and "journalctl -xe" for details.
    systemctl gibt folgendes aus:
    ● mosquitto.service - Mosquitto MQTT Broker
         Loaded: loaded (/lib/systemd/system/mosquitto.service; enabled; vendor pre>
         Active: failed (Result: exit-code) since Wed 2023-08-30 15:26:28 CEST; 3mi>
           Docs: man:mosquitto.conf(5)
                 man:mosquitto(8)
        Process: 13710 ExecStartPre=/bin/mkdir -m 740 -p /var/log/mosquitto (code=e>
        Process: 13711 ExecStartPre=/bin/chown mosquitto /var/log/mosquitto (code=e>
        Process: 13712 ExecStartPre=/bin/mkdir -m 740 -p /run/mosquitto (code=exite>
        Process: 13713 ExecStartPre=/bin/chown mosquitto /run/mosquitto (code=exite>
        Process: 13714 ExecStart=/usr/sbin/mosquitto -c /etc/mosquitto/mosquitto.co>
       Main PID: 13714 (code=exited, status=3)
            CPU: 32ms
    Aug 30 15:26:28 Pi4-ioBroker systemd[1]: mosquitto.service: Scheduled restart j>
    Aug 30 15:26:28 Pi4-ioBroker systemd[1]: Stopped Mosquitto MQTT Broker.
    Aug 30 15:26:28 Pi4-ioBroker systemd[1]: mosquitto.service: Start request repea>
    Aug 30 15:26:28 Pi4-ioBroker systemd[1]: mosquitto.service: Failed with result >
    Aug 30 15:26:28 Pi4-ioBroker systemd[1]: Failed to start Mosquitto MQTT Broker.
    und journalctl das:
    ░░ Subject: A stop job for unit mosquitto.service has finished
    ░░ Defined-By: systemd
    ░░ Support: https://www.debian.org/support
    ░░ A stop job for unit mosquitto.service has finished.
    ░░ The job identifier is 5224 and the job result is done.
    ░░ Subject: Unit failed
    ░░ The unit mosquitto.service has entered the 'failed' state with result 'exit->
    ░░ Subject: A start job for unit mosquitto.service has failed
    ░░ A start job for unit mosquitto.service has finished with a failure.
    ░░ The job identifier is 5224 and the job result is failed.
    Was ich schon herausfinden konnte ist, dass wohl der Port 1883 bereits belegt sein könnte. Allerdings wüsste ich nicht wovon und ich bin noch nicht fit genug, um zu prüfen was den Port alles nutzt.
    Ich habe noch keinen Restore durchgeführt, der iobroker ist also noch blank.
    Und diese mosquitto version:
    mosquitto version 2.0.11
    mosquitto is an MQTT v5.0/v3.1.1/v3.1 broker.
    Könnt ihr mir helfen?
    Gruß Martin
    @mariatschi0815 sagte in HD voll kein Zugriff mehr:
    Moin,
    ist noch keine direkte Hilfe, aber mach dein Terminal immer auf maximale Größe, damit Log Meldungen nicht wie bei dir abgeschnitten sind.
    Bernd
      sudo netstat -tulpen
      Mariatschi0815
      @crunchip said in HD voll kein Zugriff mehr:
      Bringt mir das, bömische Dörfer.
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13806      565/sshd: /usr/sbin
      tcp6       0      0 :::22                   :::*                    LISTEN      0          13808      565/sshd: /usr/sbin
      udp        0      0 0.0.0.0:54872           0.0.0.0:*                           108        13697      387/avahi-daemon: r
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13816      718/dhcpcd
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13695      387/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          15484      718/dhcpcd
      udp6       0      0 :::35589                :::*                                108        13698      387/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                108        13696      387/avahi-daemon: r
      HomoranH crunchipC 2 Antworten Letzte Antwort
      • M Mariatschi0815
        bömische Dörfer.
        aber keine Hausnummer 1883
        • M Mariatschi0815
          crunchipC Offline
          crunchipC Offline
          @mariatschi0815 das war nur der Hinweis wie man prüfen kann welche Ports belegt sind
          da ja noch kein iobroker installiert ist, gibt es auch keine Portbelegung 1883.
          wie hast du denn mosquitto installiert?
            Mariatschi0815
            @crunchip Installiert ist er schon. Nur noch im Urzustand.
            Nach der Doku von "haus-automatisierung".
            sudo apt install mosquitto
            Dann die user-password-datei erstellt
            sudo nano mosquitto_passwords
            Die Datei habe ich dann nach /etc/mosquitto verschoben
            in der access.conf habe ich dann
            allow_anonymous false
            password_file /etc/mosquitto/mosquitto_passwords
            eingefügt.
            Die Rechte vergeben
            sudo chown root:root /etc/mosquitto/mosquitto_passwords
            Und zum Schuss noch in der mosquitto.conf
            listener 1883
            eingefügt.
            • M Mariatschi0815
              eingefügt.
              Die Rechte vergeben
              listener 1883
              eingefügt.
              crunchipC Offline
              crunchipC Offline
              @mariatschi0815 also ähnlich wie hier https://www.elektronik-kompendium.de/sites/raspberry-pi/2709041.htm
              zeig mal die Ausgabe, dein Terminal Fenster aber bitte auf volle Breite
              sudo systemctl enable mosquitto
              sudo systemctl start mosquitto
              sudo systemctl status mosquitto
                Mariatschi0815
                Synchronizing state of mosquitto.service with SysV service script with /lib/systemd/systemd-sysv-install.
                Executing: /lib/systemd/systemd-sysv-install enable mosquitto
                     Loaded: loaded (/lib/systemd/system/mosquitto.service; enabled; vendor preset: enabled)
                     Active: failed (Result: exit-code) since Wed 2023-08-30 19:08:38 CEST; 41s ago
                             man:mosquitto(8)
                    Process: 14475 ExecStartPre=/bin/mkdir -m 740 -p /var/log/mosquitto (code=exited, status=0/SUCCESS)
                    Process: 14476 ExecStartPre=/bin/chown mosquitto /var/log/mosquitto (code=exited, status=0/SUCCESS)
                    Process: 14477 ExecStartPre=/bin/mkdir -m 740 -p /run/mosquitto (code=exited, status=0/SUCCESS)
                    Process: 14478 ExecStartPre=/bin/chown mosquitto /run/mosquitto (code=exited, status=0/SUCCESS)
                    Process: 14479 ExecStart=/usr/sbin/mosquitto -c /etc/mosquitto/mosquitto.conf (code=exited, status=3)
                   Main PID: 14479 (code=exited, status=3)
                        CPU: 32ms
                Aug 30 19:08:38 Pi4-ioBroker systemd[1]: mosquitto.service: Scheduled restart job, restart counter is at 5.
                Aug 30 19:08:38 Pi4-ioBroker systemd[1]: Stopped Mosquitto MQTT Broker.
                Aug 30 19:08:38 Pi4-ioBroker systemd[1]: mosquitto.service: Start request repeated too quickly.
                Aug 30 19:08:38 Pi4-ioBroker systemd[1]: mosquitto.service: Failed with result 'exit-code'.
                Aug 30 19:08:38 Pi4-ioBroker systemd[1]: Failed to start Mosquitto MQTT Broker.
                • M Mariatschi0815
                               man:mosquitto(8)
                          CPU: 32ms
                  crunchipC Offline
                  crunchipC Offline
                  @mariatschi0815 irgendwas passt da nicht, ich würde es nochmal löschen und neu installieren
                  das löscht mosquitto
                  sudo apt remove mosquitto
                  das löscht auch die config mit
                  sudo apt purge mosquitto
                    Mariatschi0815
                    @crunchip Die Neuinstallation hat geholfen. Mir ist hier aufgefallen, dass ein Ordner nicht gelöscht werden konnte unter /etc/mosquitto/conf.d/. Hier war einmal meine access.conf drin und dann noch eine custom.conf vermutlich lag es daran? Jedenfalls läuft mosquitto jetzt!
                    Vielen Dank!
                      Mariatschi0815
                      schrieb am zuletzt editiert von Mariatschi0815
                      Mal noch ein Anliegen hinterher, ich habe jetzt den restore durchgeführt.
                      Müssten im
                      iob logs --watch
                      jetzt nicht "wild" adapter installiert werden?
                      Die letzten logs sehen so aus:
                      2023-08-30 00:15:46.426  - info: host.Pi4-ioBroker instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                      2023-08-30 00:15:46.431  - info: host.Pi4-ioBroker instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                      2023-08-30 00:15:46.431  - info: host.Pi4-ioBroker All instances are stopped.
                      2023-08-30 00:15:46.650  - info: host.Pi4-ioBroker terminated
                      Edit: Mein Fehler... ich muss den iobroker natürlich auch starten...
                      • M Mariatschi0815
                        Müssten im
                        iob logs --watch
                        @mariatschi0815
                        Das log ist von heute morgen 0:15.
                          @mariatschi0815
                          Mariatschi0815
                          @thomas-braun Wie im "Edit" erwähnt, hätte ich mal
                          iob start
                          ausführen müssen... jetzt rennt das Ding gerade los.
                            Mariatschi0815
                            N'abend Community,
                            ich möchte den Thread hier nochmal reaktivieren. Ich hatte ja meinen iob neu aufgesetzt und erstmal darauf verzichtet neue influx-Daten zu schreiben. Heute hatte ich mal wieder etwas Luft und habe meine Infux wieder reaktiviert. Ich schreibe also seit gut 30 min Daten.
                            Jetzt ist mir aufgefallen, dass mein Influx-Ordner auf dem RPi schon wieder 6,6GB einnimmt... ohne das ich Daten geloggt habe... wieder unter dem Pfad:
                            /var/lib/influxdb/engine/data/3f3100e8b1af48b5/autogen
                            Der ja damals schon dafür gesorgt hat, das meine SD übergequollen ist. Jetzt ist mein "Fach-Englisch" und meine Kenntnis über die Infux nicht besonders gut... und ich werde im Netz nicht so recht fündig...
                            Die Daten unter "autogen" werden aber offensichtlich alle 6h geloggt. Weiß jemand was das ist und wie ich das Problem beheben kann? Es sind wohl "nur" irgendwelche Statistik-Daten.
                            Gruß Martin
                            Marc BergM ? 2 Antworten Letzte Antwort
                            • M Mariatschi0815
                              N'abend Community,
                              Gruß Martin
                              Marc BergM Online
                              Marc BergM Online
                              Marc Berg
                              Das ist eigentlich immer das gleiche Problem:
                              https://forum.iobroker.net/post/1030110
                              • M Mariatschi0815
                                N'abend Community,
                                Gruß Martin
                                Moin,
                                wenn Du den Fred wieder aufmachst, solltest Du vielleicht auch noch mal sagen, was Du wie installiert hast, also Version usw.
                                Und was hat man Dir damals geraten?
                                Bernd
                                  Moin,
                                  Bernd
                                  Mariatschi0815
                                  @dp20eic Das ich mir ansehen soll, welche Daten ich logge. Offensichtlich lag es ja aber nicht an den Daten.
                                  • Marc BergM Marc Berg
                                    Mariatschi0815
                                    @marc-berg Achso und großes Dankeschön, bin jetzt beim ausmisten. :D
