  4. HD voll kein Zugriff mehr
43 Beiträge 8 Kommentatoren 5.1k Aufrufe 6 Beobachtet
  • M Mariatschi0815
    So, was lange wehrt.
    Also ich hab mich dazu entschlossen den Pi neu aufzusetzen. Jetzt hakt es aber schon. Ich habe ein 64bit System aufgesetzt und bisher nur den iobroker und mosquitto installiert.
    Wenn ich jetzt einen service restart von mosquitto durchführe kommt folgende Meldung:
    Job for mosquitto.service failed because the control process exited with error code.
    See "systemctl status mosquitto.service" and "journalctl -xe" for details.
    systemctl gibt folgendes aus:
    ● mosquitto.service - Mosquitto MQTT Broker
         Loaded: loaded (/lib/systemd/system/mosquitto.service; enabled; vendor pre>
         Active: failed (Result: exit-code) since Wed 2023-08-30 15:26:28 CEST; 3mi>
           Docs: man:mosquitto.conf(5)
                 man:mosquitto(8)
        Process: 13710 ExecStartPre=/bin/mkdir -m 740 -p /var/log/mosquitto (code=e>
        Process: 13711 ExecStartPre=/bin/chown mosquitto /var/log/mosquitto (code=e>
        Process: 13712 ExecStartPre=/bin/mkdir -m 740 -p /run/mosquitto (code=exite>
        Process: 13713 ExecStartPre=/bin/chown mosquitto /run/mosquitto (code=exite>
        Process: 13714 ExecStart=/usr/sbin/mosquitto -c /etc/mosquitto/mosquitto.co>
       Main PID: 13714 (code=exited, status=3)
            CPU: 32ms
    Aug 30 15:26:28 Pi4-ioBroker systemd[1]: mosquitto.service: Scheduled restart j>
    Aug 30 15:26:28 Pi4-ioBroker systemd[1]: Stopped Mosquitto MQTT Broker.
    Aug 30 15:26:28 Pi4-ioBroker systemd[1]: mosquitto.service: Start request repea>
    Aug 30 15:26:28 Pi4-ioBroker systemd[1]: mosquitto.service: Failed with result >
    Aug 30 15:26:28 Pi4-ioBroker systemd[1]: Failed to start Mosquitto MQTT Broker.
    und journalctl das:
    ░░ Subject: A stop job for unit mosquitto.service has finished
    ░░ Defined-By: systemd
    ░░ Support: https://www.debian.org/support
    ░░ A stop job for unit mosquitto.service has finished.
    ░░ The job identifier is 5224 and the job result is done.
    ░░ Subject: Unit failed
    ░░ The unit mosquitto.service has entered the 'failed' state with result 'exit->
    ░░ Subject: A start job for unit mosquitto.service has failed
    ░░ A start job for unit mosquitto.service has finished with a failure.
    ░░ The job identifier is 5224 and the job result is failed.
    Was ich schon herausfinden konnte ist, dass wohl der Port 1883 bereits belegt sein könnte. Allerdings wüsste ich nicht wovon und ich bin noch nicht fit genug, um zu prüfen was den Port alles nutzt.
    Ich habe noch keinen Restore durchgeführt, der iobroker ist also noch blank.
    Und diese mosquitto version:
    mosquitto version 2.0.11
    mosquitto is an MQTT v5.0/v3.1.1/v3.1 broker.
    Könnt ihr mir helfen?
    Gruß Martin
    crunchipC Offline
    crunchipC Offline
    @mariatschi0815 sagte in HD voll kein Zugriff mehr:
    sudo netstat -tulpen
    • M Mariatschi0815
                   man:mosquitto(8)
              CPU: 32ms
      und journalctl das:
      Gruß Martin
      Moin,
      ist noch keine direkte Hilfe, aber mach dein Terminal immer auf maximale Größe, damit Log Meldungen nicht wie bei dir abgeschnitten sind.
      Bernd
        Mariatschi0815
        @crunchip said in HD voll kein Zugriff mehr:
        Bringt mir das, bömische Dörfer.
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13806      565/sshd: /usr/sbin
        tcp6       0      0 :::22                   :::*                    LISTEN      0          13808      565/sshd: /usr/sbin
        udp        0      0 0.0.0.0:54872           0.0.0.0:*                           108        13697      387/avahi-daemon: r
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13816      718/dhcpcd
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13695      387/avahi-daemon: r
        udp6       0      0 :::546                  :::*                                0          15484      718/dhcpcd
        udp6       0      0 :::35589                :::*                                108        13698      387/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                108        13696      387/avahi-daemon: r
        HomoranH crunchipC 2 Antworten Letzte Antwort
        • M Mariatschi0815
          bömische Dörfer.
          aber keine Hausnummer 1883
          • M Mariatschi0815
            crunchipC Offline
            crunchipC Offline
            @mariatschi0815 das war nur der Hinweis wie man prüfen kann welche Ports belegt sind
            da ja noch kein iobroker installiert ist, gibt es auch keine Portbelegung 1883.
            wie hast du denn mosquitto installiert?
              Mariatschi0815
              @crunchip Installiert ist er schon. Nur noch im Urzustand.
              Nach der Doku von "haus-automatisierung".
              sudo apt install mosquitto
              Dann die user-password-datei erstellt
              sudo nano mosquitto_passwords
              Die Datei habe ich dann nach /etc/mosquitto verschoben
              in der access.conf habe ich dann
              allow_anonymous false
              password_file /etc/mosquitto/mosquitto_passwords
              eingefügt.
              Die Rechte vergeben
              sudo chown root:root /etc/mosquitto/mosquitto_passwords
              Und zum Schuss noch in der mosquitto.conf
              listener 1883
              eingefügt.
              • M Mariatschi0815
                eingefügt.
                Die Rechte vergeben
                listener 1883
                eingefügt.
                crunchipC Offline
                crunchipC Offline
                @mariatschi0815 also ähnlich wie hier https://www.elektronik-kompendium.de/sites/raspberry-pi/2709041.htm
                zeig mal die Ausgabe, dein Terminal Fenster aber bitte auf volle Breite
                sudo systemctl enable mosquitto
                sudo systemctl start mosquitto
                sudo systemctl status mosquitto
                  Mariatschi0815
                  Synchronizing state of mosquitto.service with SysV service script with /lib/systemd/systemd-sysv-install.
                  Executing: /lib/systemd/systemd-sysv-install enable mosquitto
                       Loaded: loaded (/lib/systemd/system/mosquitto.service; enabled; vendor preset: enabled)
                       Active: failed (Result: exit-code) since Wed 2023-08-30 19:08:38 CEST; 41s ago
                               man:mosquitto(8)
                      Process: 14475 ExecStartPre=/bin/mkdir -m 740 -p /var/log/mosquitto (code=exited, status=0/SUCCESS)
                      Process: 14476 ExecStartPre=/bin/chown mosquitto /var/log/mosquitto (code=exited, status=0/SUCCESS)
                      Process: 14477 ExecStartPre=/bin/mkdir -m 740 -p /run/mosquitto (code=exited, status=0/SUCCESS)
                      Process: 14478 ExecStartPre=/bin/chown mosquitto /run/mosquitto (code=exited, status=0/SUCCESS)
                      Process: 14479 ExecStart=/usr/sbin/mosquitto -c /etc/mosquitto/mosquitto.conf (code=exited, status=3)
                     Main PID: 14479 (code=exited, status=3)
                          CPU: 32ms
                  Aug 30 19:08:38 Pi4-ioBroker systemd[1]: mosquitto.service: Scheduled restart job, restart counter is at 5.
                  Aug 30 19:08:38 Pi4-ioBroker systemd[1]: Stopped Mosquitto MQTT Broker.
                  Aug 30 19:08:38 Pi4-ioBroker systemd[1]: mosquitto.service: Start request repeated too quickly.
                  Aug 30 19:08:38 Pi4-ioBroker systemd[1]: mosquitto.service: Failed with result 'exit-code'.
                  Aug 30 19:08:38 Pi4-ioBroker systemd[1]: Failed to start Mosquitto MQTT Broker.
                  • M Mariatschi0815
                                 man:mosquitto(8)
                            CPU: 32ms
                    crunchipC Offline
                    crunchipC Offline
                    @mariatschi0815 irgendwas passt da nicht, ich würde es nochmal löschen und neu installieren
                    das löscht mosquitto
                    sudo apt remove mosquitto
                    das löscht auch die config mit
                    sudo apt purge mosquitto
                      Mariatschi0815
                      @crunchip Die Neuinstallation hat geholfen. Mir ist hier aufgefallen, dass ein Ordner nicht gelöscht werden konnte unter /etc/mosquitto/conf.d/. Hier war einmal meine access.conf drin und dann noch eine custom.conf vermutlich lag es daran? Jedenfalls läuft mosquitto jetzt!
                      Vielen Dank!
                        Mariatschi0815
                        schrieb am zuletzt editiert von Mariatschi0815
                        Mal noch ein Anliegen hinterher, ich habe jetzt den restore durchgeführt.
                        Müssten im
                        iob logs --watch
                        jetzt nicht "wild" adapter installiert werden?
                        Die letzten logs sehen so aus:
                        2023-08-30 00:15:46.426  - info: host.Pi4-ioBroker instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                        2023-08-30 00:15:46.431  - info: host.Pi4-ioBroker instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                        2023-08-30 00:15:46.431  - info: host.Pi4-ioBroker All instances are stopped.
                        2023-08-30 00:15:46.650  - info: host.Pi4-ioBroker terminated
                        Edit: Mein Fehler... ich muss den iobroker natürlich auch starten...
                        • M Mariatschi0815
                          Müssten im
                          iob logs --watch
                          @mariatschi0815
                          Das log ist von heute morgen 0:15.
                            @mariatschi0815
                            Mariatschi0815
                            @thomas-braun Wie im "Edit" erwähnt, hätte ich mal
                            iob start
                            ausführen müssen... jetzt rennt das Ding gerade los.
                              Mariatschi0815
                              N'abend Community,
                              ich möchte den Thread hier nochmal reaktivieren. Ich hatte ja meinen iob neu aufgesetzt und erstmal darauf verzichtet neue influx-Daten zu schreiben. Heute hatte ich mal wieder etwas Luft und habe meine Infux wieder reaktiviert. Ich schreibe also seit gut 30 min Daten.
                              Jetzt ist mir aufgefallen, dass mein Influx-Ordner auf dem RPi schon wieder 6,6GB einnimmt... ohne das ich Daten geloggt habe... wieder unter dem Pfad:
                              /var/lib/influxdb/engine/data/3f3100e8b1af48b5/autogen
                              Der ja damals schon dafür gesorgt hat, das meine SD übergequollen ist. Jetzt ist mein "Fach-Englisch" und meine Kenntnis über die Infux nicht besonders gut... und ich werde im Netz nicht so recht fündig...
                              Die Daten unter "autogen" werden aber offensichtlich alle 6h geloggt. Weiß jemand was das ist und wie ich das Problem beheben kann? Es sind wohl "nur" irgendwelche Statistik-Daten.
                              Gruß Martin
                              Marc BergM ? 2 Antworten Letzte Antwort
                              • M Mariatschi0815
                                N'abend Community,
                                Gruß Martin
                                Marc BergM Online
                                Marc BergM Online
                                Marc Berg
                                Das ist eigentlich immer das gleiche Problem:
                                https://forum.iobroker.net/post/1030110
                                • M Mariatschi0815
                                  N'abend Community,
                                  Gruß Martin
                                  Moin,
                                  wenn Du den Fred wieder aufmachst, solltest Du vielleicht auch noch mal sagen, was Du wie installiert hast, also Version usw.
                                  Und was hat man Dir damals geraten?
                                  Bernd
                                    Moin,
                                    Bernd
                                    Mariatschi0815
                                    @dp20eic Das ich mir ansehen soll, welche Daten ich logge. Offensichtlich lag es ja aber nicht an den Daten.
                                    • Marc BergM Marc Berg
                                      Mariatschi0815
                                      @marc-berg Achso und großes Dankeschön, bin jetzt beim ausmisten. :D
