vedirekt Adapter Verbindungsproblem
@homoran mal sehen, ob das was wird...
======== Start marking the full check here =========
Skript v.2023-04-16 *** BASE SYSTEM *** Model : Raspberry Pi 400 Rev 1.1 Architecture : aarch64 Docker : false Virtualization : none Distributor ID: Debian Description: Debian GNU/Linux 11 (bullseye) Release: 11 Codename: bullseye PRETTY_NAME="Debian GNU/Linux 11 (bullseye)" NAME="Debian GNU/Linux" VERSION_ID="11" VERSION="11 (bullseye)" VERSION_CODENAME=bullseye ID=debian HOME_URL="https://www.debian.org/" SUPPORT_URL="https://www.debian.org/support" BUG_REPORT_URL="https://bugs.debian.org/" Systemuptime and Load: 18:20:10 up 1:31, 1 user, load average: 0.58, 0.85, 0.84 CPU threads: 4 Raspberry only: throttled=0x0 Other values than 0x0 hint to temperature/voltage problems temp=40.4'C volt=0.9360V *** Time and Time Zones *** Local time: Thu 2023-05-04 18:20:10 CEST Universal time: Thu 2023-05-04 16:20:10 UTC RTC time: n/a Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** User and Groups *** otto /home/otto otto adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker *** X-Server-Setup *** X-Server: false Desktop: Terminal: tty Boot Target: multi-user.target *** MEMORY *** total used free shared buff/cache available Mem: 3.8G 1.8G 1.1G 1.0M 921M 1.9G Swap: 99M 0B 99M Total: 3.9G 1.8G 1.2G 3793 M total memory 1787 M used memory 2042 M active memory 518 M inactive memory 1083 M free memory 87 M buffer memory 834 M swap cache 99 M total swap 0 M used swap 99 M free swap Raspberry only: oom events: 0 lifetime oom required: 0 Mbytes total time in oom handler: 0 ms max time spent in oom handler: 0 ms *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on /dev/root ext4 110G 5.2G 101G 5% / devtmpfs devtmpfs 1.7G 0 1.7G 0% /dev tmpfs tmpfs 1.9G 0 1.9G 0% /dev/shm tmpfs tmpfs 759M 1.1M 758M 1% /run tmpfs tmpfs 5.0M 0 5.0M 0% /run/lock /dev/sda1 vfat 255M 31M 225M 13% /boot tmpfs tmpfs 380M 0 380M 0% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Thu May 4 16:48:24 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_hdmi=1 smsc95xx.macaddr=D8:3A:DD:0F:ED:4A vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000 console=ttyS0,115200 console=tty1 root=PARTUUID=34877f34-02 rootfstype=ext4 fsck.repair=yes rootwait [Thu May 4 16:48:27 2023] EXT4-fs (sda2): INFO: recovery required on readonly filesystem [Thu May 4 16:48:27 2023] EXT4-fs (sda2): write access will be enabled during recovery [Thu May 4 16:48:28 2023] EXT4-fs (sda2): orphan cleanup on readonly fs [Thu May 4 16:48:28 2023] EXT4-fs (sda2): 1 orphan inode deleted [Thu May 4 16:48:28 2023] EXT4-fs (sda2): recovery complete [Thu May 4 16:48:28 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none. [Thu May 4 16:48:28 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2. [Thu May 4 16:48:30 2023] EXT4-fs (sda2): re-mounted. Quota mode: none. Show mounted filesystems (real ones only): TARGET SOURCE FSTYPE OPTIONS / /dev/sda2 ext4 rw,noatime `-/boot /dev/sda1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 1.1G /var/ 405M /var/log 360M /var/cache 355M /var/cache/apt 345M /var/log/journal/007bdc1de22f4392961e44836db9bdcf Archived and active journals take up 344.0M in the file system. /opt/iobroker/backups: 4.0K /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 1.1G /opt/iobroker/iobroker-data/ 796M /opt/iobroker/iobroker-data/history 147M /opt/iobroker/iobroker-data/files 68M /opt/iobroker/iobroker-data/backup-objects 51M /opt/iobroker/iobroker-data/files/javascript.admin The five largest files in iobroker-data are: 33M /opt/iobroker/iobroker-data/objects.jsonl 9.1M /opt/iobroker/iobroker-data/files/echarts.admin/static/js/2.bbf74d5f.chunk.js.map 8.9M /opt/iobroker/iobroker-data/files/echarts/static/js/2.3d2d025f.chunk.js.map 8.9M /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/2.3d2d025f.chunk.js.map 6.9M /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c9.chunk.js.map *** NodeJS-Installation *** /usr/bin/nodejs v18.16.0 /usr/bin/node v18.16.0 /usr/bin/npm 9.5.1 /usr/bin/npx 9.5.1 nodejs: Installed: 18.16.0-deb-1nodesource1 Candidate: 18.16.0-deb-1nodesource1 Version table: *** 18.16.0-deb-1nodesource1 500 500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages 100 /var/lib/dpkg/status 12.22.12~dfsg-1~deb11u4 500 500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages 12.22.12~dfsg-1~deb11u3 500 500 http://deb.debian.org/debian bullseye/main arm64 Packages Temp directories causing npm8 problem: 0 No problems detected *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl MULTIHOSTSERVICE/enabled: false Core adapters versions js-controller: 4.0.24 admin: 6.3.5 javascript: 6.1.4 Adapters from github: 3 Adapter State + system.adapter.admin.1 : admin : raspberrypiIO64 - enabled, port: 8081, bind: 0.0.0.0, run as: admin system.adapter.alias-manager.0 : alias-manager : raspberrypiIO64 - disabled + system.adapter.backitup.0 : backitup : raspberrypiIO64 - enabled + system.adapter.discovery.0 : discovery : raspberrypiIO64 - enabled + system.adapter.echarts.0 : echarts : raspberrypiIO64 - enabled system.adapter.flot.0 : flot : raspberrypiIO64 - disabled + system.adapter.history.0 : history : raspberrypiIO64 - enabled + system.adapter.hm-rega.0 : hm-rega : raspberrypiIO64 - enabled + system.adapter.hm-rpc.0 : hm-rpc : raspberrypiIO64 - enabled, port: 0 + system.adapter.hm-rpc.1 : hm-rpc : raspberrypiIO64 - enabled, port: 0 + system.adapter.influxdb.0 : influxdb : raspberrypiIO64 - enabled, port: 8086 + system.adapter.info.0 : info : raspberrypiIO64 - enabled + system.adapter.javascript.0 : javascript : raspberrypiIO64 - enabled + system.adapter.modbus.0 : modbus : raspberrypiIO64 - enabled + system.adapter.mqtt.0 : mqtt : raspberrypiIO64 - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.net-tools.0 : net-tools : raspberrypiIO64 - enabled + system.adapter.opendtu.0 : opendtu : raspberrypiIO64 - enabled + system.adapter.owfs.0 : owfs : raspberrypiIO64 - enabled, port: 4304 + system.adapter.rpi2.0 : rpi2 : raspberrypiIO64 - enabled + system.adapter.shelly.1 : shelly : raspberrypiIO64 - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.simple-api.0 : simple-api : raspberrypiIO64 - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.sourceanalytix.0 : sourceanalytix : raspberrypiIO64 - enabled + system.adapter.vedirect.0 : vedirect : raspberrypiIO64 - enabled system.adapter.vis-bars.0 : vis-bars : raspberrypiIO64 - enabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : raspberrypiIO64 - enabled system.adapter.vis.0 : vis : raspberrypiIO64 - enabled + system.adapter.web.0 : web : raspberrypiIO64 - enabled, port: 8082, bind: 0.0.0.0, run as: admin system.adapter.zigbee.0 : zigbee : raspberrypiIO64 - disabled, port: /dev/ttyACM0 + instance is alive Enabled adapters with bindings + system.adapter.admin.1 : admin : raspberrypiIO64 - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.hm-rpc.0 : hm-rpc : raspberrypiIO64 - enabled, port: 0 + system.adapter.hm-rpc.1 : hm-rpc : raspberrypiIO64 - enabled, port: 0 + system.adapter.influxdb.0 : influxdb : raspberrypiIO64 - enabled, port: 8086 + system.adapter.mqtt.0 : mqtt : raspberrypiIO64 - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.owfs.0 : owfs : raspberrypiIO64 - enabled, port: 4304 + system.adapter.shelly.1 : shelly : raspberrypiIO64 - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.simple-api.0 : simple-api : raspberrypiIO64 - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.web.0 : web : raspberrypiIO64 - enabled, port: 8082, bind: 0.0.0.0, run as: admin ioBroker-Repositories stable : http://download.iobroker.net/sources-dist.json beta : http://download.iobroker.net/sources-dist-latest.json Active repo(s): stable Installed ioBroker-Instances Used repository: stable Adapter "admin" : 6.3.5 , installed 6.3.5 Adapter "alias-manager": 1.2.4 , installed 1.2.4 Adapter "backitup" : 2.6.19 , installed 2.6.19 Adapter "discovery" : 3.1.0 , installed 3.1.0 Adapter "echarts" : 1.0.12 , installed 1.0.12 Adapter "flot" : 1.11.0 , installed 1.11.0 Adapter "history" : 2.2.4 , installed 2.2.4 Adapter "hm-rega" : 3.0.46 , installed 3.0.46 Adapter "hm-rpc" : 1.15.16 , installed 1.15.16 Adapter "influxdb" : 3.2.0 , installed 3.2.0 Adapter "info" : 1.9.26 , installed 1.9.26 Adapter "javascript" : 6.1.4 , installed 6.1.4 Controller "js-controller": 4.0.24 , installed 4.0.24 Adapter "modbus" : 5.0.11 , installed 5.0.11 Adapter "mqtt" : 4.0.7 , installed 4.0.7 Adapter "net-tools" : 0.2.0 , installed 0.2.0 Adapter "owfs" : 0.7.0 , installed 0.7.0 Adapter "rpi2" : 1.3.2 , installed 1.3.2 Adapter "shelly" : 6.3.1 , installed 6.3.1 Adapter "simple-api" : 2.7.2 , installed 2.7.2 Adapter "socketio" : 4.2.0 , installed 4.2.0 Adapter "vis" : 1.4.16 , installed 1.4.16 Adapter "vis-bars" : 0.1.4 , installed 0.1.4 Adapter "vis-hqwidgets": 1.3.0 , installed 1.3.0 Adapter "web" : 4.3.0 , installed 4.3.0 Adapter "ws" : 1.3.0 , installed 1.3.0 Adapter "zigbee" : 1.8.10 , installed 1.8.10 Objects and States Please stand by - This may take a while Objects: 5675 States: 5142 *** OS-Repositories and Updates *** W: GPG error: https://repos.influxdata.com/debian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E E: The repository 'https://repos.influxdata.com/debian bullseye InRelease' is not signed. Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 1001 16707 1298/io.mqtt.0 tcp 0 0 0.0.0.0:9001 0.0.0.0:* LISTEN 1001 12139 868/iobroker.js-con tcp 0 0 0.0.0.0:9000 0.0.0.0:* LISTEN 1001 13121 868/iobroker.js-con tcp 0 0 192.168.2.54:2001 0.0.0.0:* LISTEN 1001 15732 1240/io.hm-rpc.1 tcp 0 0 192.168.2.54:2010 0.0.0.0:* LISTEN 1001 17534 1226/io.hm-rpc.0 tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 12972 578/sshd: /usr/sbin tcp6 0 0 :::8082 :::* LISTEN 1001 19169 2135/io.web.0 tcp6 0 0 :::8081 :::* LISTEN 1001 15537 1092/io.admin.1 tcp6 0 0 :::8087 :::* LISTEN 1001 18684 1675/io.simple-api. tcp6 0 0 :::8086 :::* LISTEN 999 12104 709/influxd tcp6 0 0 :::3000 :::* LISTEN 111 13154 867/grafana tcp6 0 0 :::22 :::* LISTEN 0 12974 578/sshd: /usr/sbin udp 0 0 0.0.0.0:49615 0.0.0.0:* 108 14575 413/avahi-daemon: r udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 14573 413/avahi-daemon: r udp 0 0 0.0.0.0:5683 0.0.0.0:* 1001 16844 1531/io.shelly.1 udp 0 0 0.0.0.0:68 0.0.0.0:* 0 14051 706/dhcpcd udp6 0 0 :::546 :::* 0 12997 706/dhcpcd udp6 0 0 :::40016 :::* 108 14576 413/avahi-daemon: r udp6 0 0 :::5353 :::* 108 14574 413/avahi-daemon: r *** Log File - Last 25 Lines *** 2023-05-04 18:20:50.571 - warn: shelly.1 (1531) [authEnabled] 192.168.2.6 (shellyswitch25 / shellyswitch25-68C63AFA870D / SHSW-25#68C63AFA870D#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-04 18:20:50.659 - warn: shelly.1 (1531) [authEnabled] 192.168.2.5 (shellyswitch25 / shellyswitch25-68C63AFA51AA / SHSW-25#68C63AFA51AA#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-04 18:20:50.844 - warn: shelly.1 (1531) [authEnabled] 192.168.2.12 (shellyswitch25 / shellyswitch25-3C6105E462D5 / SHSW-25#3C6105E462D5#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-04 18:20:52.045 - warn: shelly.1 (1531) [authEnabled] 192.168.2.52 (shellyem3 / shellyem3-485519D7986A / SHEM-3#485519D7986A#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-04 18:20:55.665 - warn: shelly.1 (1531) [authEnabled] 192.168.2.56 (shellyem / shellyem-244CAB419A03 / SHEM#244CAB419A03#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-04 18:20:55.751 - warn: shelly.1 (1531) [authEnabled] 192.168.2.9 (shellyswitch25 / shellyswitch25-3C6105E3A7AF / SHSW-25#3C6105E3A7AF#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-04 18:20:55.991 - warn: shelly.1 (1531) [authEnabled] 192.168.2.5 (shellyswitch25 / shellyswitch25-68C63AFA51AA / SHSW-25#68C63AFA51AA#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-04 18:20:55.997 - warn: shelly.1 (1531) [authEnabled] 192.168.2.6 (shellyswitch25 / shellyswitch25-68C63AFA870D / SHSW-25#68C63AFA870D#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-04 18:20:56.216 - warn: shelly.1 (1531) [authEnabled] 192.168.2.12 (shellyswitch25 / shellyswitch25-3C6105E462D5 / SHSW-25#3C6105E462D5#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-04 18:20:57.313 - warn: shelly.1 (1531) [authEnabled] 192.168.2.52 (shellyem3 / shellyem3-485519D7986A / SHEM-3#485519D7986A#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-04 18:21:00.811 - warn: shelly.1 (1531) [authEnabled] 192.168.2.56 (shellyem / shellyem-244CAB419A03 / SHEM#244CAB419A03#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-04 18:21:01.092 - warn: shelly.1 (1531) [authEnabled] 192.168.2.9 (shellyswitch25 / shellyswitch25-3C6105E3A7AF / SHSW-25#3C6105E3A7AF#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-04 18:21:01.411 - warn: shelly.1 (1531) [authEnabled] 192.168.2.5 (shellyswitch25 / shellyswitch25-68C63AFA51AA / SHSW-25#68C63AFA51AA#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-04 18:21:01.464 - warn: shelly.1 (1531) [authEnabled] 192.168.2.6 (shellyswitch25 / shellyswitch25-68C63AFA870D / SHSW-25#68C63AFA870D#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-04 18:21:01.536 - warn: shelly.1 (1531) [authEnabled] 192.168.2.12 (shellyswitch25 / shellyswitch25-3C6105E462D5 / SHSW-25#3C6105E462D5#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-04 18:21:02.591 - warn: shelly.1 (1531) [authEnabled] 192.168.2.52 (shellyem3 / shellyem3-485519D7986A / SHEM-3#485519D7986A#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-04 18:21:03.445 - info: javascript.0 (1172) script.js.Heizung.GPIO-IOTag: IstTag: true 2023-05-04 18:21:03.445 - info: javascript.0 (1172) script.js.Heizung.GPIO-IOTag: istNacht: false 2023-05-04 18:21:03.446 - info: javascript.0 (1172) script.js.Heizung.GPIO-IOTag: DPNacht IO: true 2023-05-04 18:21:03.446 - info: javascript.0 (1172) script.js.Heizung.GPIO-IOTag: change GP23 2023-05-04 18:21:05.914 - warn: shelly.1 (1531) [authEnabled] 192.168.2.56 (shellyem / shellyem-244CAB419A03 / SHEM#244CAB419A03#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-04 18:21:06.275 - warn: shelly.1 (1531) [authEnabled] 192.168.2.9 (shellyswitch25 / shellyswitch25-3C6105E3A7AF / SHSW-25#3C6105E3A7AF#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-04 18:21:06.743 - warn: shelly.1 (1531) [authEnabled] 192.168.2.5 (shellyswitch25 / shellyswitch25-68C63AFA51AA / SHSW-25#68C63AFA51AA#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-04 18:21:06.779 - warn: shelly.1 (1531) [authEnabled] 192.168.2.6 (shellyswitch25 / shellyswitch25-68C63AFA870D / SHSW-25#68C63AFA870D#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-04 18:21:07.971 - warn: shelly.1 (1531) [authEnabled] 192.168.2.52 (shellyem3 / shellyem3-485519D7986A / SHEM-3#485519D7986A#1): This device is not protected via restricted login (see adapter documentation for details) ============ Mark until here for C&P ============= iob diag has finished.@laser aah, du hast nochmal editiert!
Ich bin kein Linux Crack, aber folgendes fällt mit auf
@laser sagte in vedirekt Adapter Verbindungsproblem:
Dein Dateisystem hat einen Schuss.
ist kein ioBroker Thema, aber deine influxdb ist nicht sauber installiert
läuft die auch noch auf dem Pi?
@homoran Die Influx 2.7 DB läuft auf dem PI. Habe ich neu installiert. Ist aber für mich absolutes Neuland.
Repostery ist nicht signiert. Jetzt habe ich zig Anleitungen gelesen. Vermutlich nie die "Richtige". Stand in irgendeiner, das kann man ignorieren. Muß aber nicht richtig sein.
Werde dieses Repostery löschen.
Werte werden in die DB geschrieben, kann sie auch mit grafana auslesen.======== Start marking the full check here ========= Skript v.2023-04-16 *** BASE SYSTEM *** Model : Raspberry Pi 400 Rev 1.1 Architecture : aarch64 Docker : false Virtualization : none Distributor ID: Debian Description: Debian GNU/Linux 11 (bullseye) Release: 11 Codename: bullseye PRETTY_NAME="Debian GNU/Linux 11 (bullseye)" NAME="Debian GNU/Linux" VERSION_ID="11" VERSION="11 (bullseye)" VERSION_CODENAME=bullseye ID=debian HOME_URL="https://www.debian.org/" SUPPORT_URL="https://www.debian.org/support" BUG_REPORT_URL="https://bugs.debian.org/" Systemuptime and Load: 11:16:51 up 18:28, 1 user, load average: 0.52, 0.67, 0.78 CPU threads: 4 Raspberry only: throttled=0x0 Other values than 0x0 hint to temperature/voltage problems temp=39.9'C volt=0.9360V *** Time and Time Zones *** Local time: Fri 2023-05-05 11:16:52 CEST Universal time: Fri 2023-05-05 09:16:52 UTC RTC time: n/a Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** User and Groups *** otto /home/otto otto adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker *** X-Server-Setup *** X-Server: false Desktop: Terminal: tty Boot Target: multi-user.target *** MEMORY *** total used free shared buff/cache available Mem: 3.8G 2.0G 723M 1.0M 1.1G 1.7G Swap: 99M 0B 99M Total: 3.9G 2.0G 823M 3793 M total memory 1988 M used memory 2247 M active memory 649 M inactive memory 723 M free memory 90 M buffer memory 991 M swap cache 99 M total swap 0 M used swap 99 M free swap Raspberry only: oom events: 0 lifetime oom required: 0 Mbytes total time in oom handler: 0 ms max time spent in oom handler: 0 ms *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on /dev/root ext4 110G 5.2G 101G 5% / devtmpfs devtmpfs 1.7G 0 1.7G 0% /dev tmpfs tmpfs 1.9G 0 1.9G 0% /dev/shm tmpfs tmpfs 759M 1.1M 758M 1% /run tmpfs tmpfs 5.0M 0 5.0M 0% /run/lock /dev/sda1 vfat 255M 31M 225M 13% /boot //192.168.2.57/backup cifs 95G 12G 83G 13% /opt/iobroker/backups tmpfs tmpfs 380M 0 380M 0% /run/user/1000 Messages concerning ext4 filesystem in dmesg: Show mounted filesystems (real ones only): TARGET SOURCE FSTYPE OPTIONS / /dev/sda2 ext4 rw,noatime |-/boot /dev/sda1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro `-/opt/iobroker/backups //192.168.2.57/backup cifs rw,relatime,vers=3.0,cache=strict,username=iobroker,uid=1001,noforceuid,gid=1001,noforcegid,addr=192.168.2.57,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1,closetimeo=5 Files in neuralgic directories: /var: 1.1G /var/ 418M /var/log 361M /var/cache 355M /var/cache/apt 353M /var/log/journal/007bdc1de22f4392961e44836db9bdcf Archived and active journals take up 352.0M in the file system. /opt/iobroker/backups: 368M /opt/iobroker/backups/ 88K /opt/iobroker/backups/otto 20K /opt/iobroker/backups/guest 4.0K /opt/iobroker/backups/otto/.config/htop 4.0K /opt/iobroker/backups/otto/.config /opt/iobroker/iobroker-data: 1.1G /opt/iobroker/iobroker-data/ 800M /opt/iobroker/iobroker-data/history 147M /opt/iobroker/iobroker-data/files 68M /opt/iobroker/iobroker-data/backup-objects 51M /opt/iobroker/iobroker-data/files/javascript.admin The five largest files in iobroker-data are: 12M /opt/iobroker/iobroker-data/objects.jsonl 9.1M /opt/iobroker/iobroker-data/files/echarts.admin/static/js/2.bbf74d5f.chunk.js.map 8.9M /opt/iobroker/iobroker-data/files/echarts/static/js/2.3d2d025f.chunk.js.map 8.9M /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/2.3d2d025f.chunk.js.map 8.4M /opt/iobroker/iobroker-data/states.jsonl *** NodeJS-Installation *** /usr/bin/nodejs v18.16.0 /usr/bin/node v18.16.0 /usr/bin/npm 9.5.1 /usr/bin/npx 9.5.1 nodejs: Installed: 18.16.0-deb-1nodesource1 Candidate: 18.16.0-deb-1nodesource1 Version table: *** 18.16.0-deb-1nodesource1 500 500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages 100 /var/lib/dpkg/status 12.22.12~dfsg-1~deb11u4 500 500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages 12.22.12~dfsg-1~deb11u3 500 500 http://deb.debian.org/debian bullseye/main arm64 Packages Temp directories causing npm8 problem: 0 No problems detected *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl MULTIHOSTSERVICE/enabled: false Core adapters versions js-controller: 4.0.24 admin: 6.3.5 javascript: 6.1.4 Adapters from github: 3 Adapter State + system.adapter.admin.1 : admin : raspberrypiIO64 - enabled, port: 8081, bind: 0.0.0.0, run as: admin system.adapter.alias-manager.0 : alias-manager : raspberrypiIO64 - disabled + system.adapter.backitup.0 : backitup : raspberrypiIO64 - enabled + system.adapter.discovery.0 : discovery : raspberrypiIO64 - enabled + system.adapter.echarts.0 : echarts : raspberrypiIO64 - enabled system.adapter.flot.0 : flot : raspberrypiIO64 - disabled + system.adapter.history.0 : history : raspberrypiIO64 - enabled + system.adapter.hm-rega.0 : hm-rega : raspberrypiIO64 - enabled + system.adapter.hm-rpc.0 : hm-rpc : raspberrypiIO64 - enabled, port: 0 + system.adapter.hm-rpc.1 : hm-rpc : raspberrypiIO64 - enabled, port: 0 + system.adapter.influxdb.0 : influxdb : raspberrypiIO64 - enabled, port: 8086 + system.adapter.info.0 : info : raspberrypiIO64 - enabled + system.adapter.javascript.0 : javascript : raspberrypiIO64 - enabled + system.adapter.modbus.0 : modbus : raspberrypiIO64 - enabled + system.adapter.mqtt.0 : mqtt : raspberrypiIO64 - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.net-tools.0 : net-tools : raspberrypiIO64 - enabled + system.adapter.opendtu.0 : opendtu : raspberrypiIO64 - enabled + system.adapter.owfs.0 : owfs : raspberrypiIO64 - enabled, port: 4304 + system.adapter.rpi2.0 : rpi2 : raspberrypiIO64 - enabled + system.adapter.shelly.1 : shelly : raspberrypiIO64 - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.simple-api.0 : simple-api : raspberrypiIO64 - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.sourceanalytix.0 : sourceanalytix : raspberrypiIO64 - enabled + system.adapter.vedirect.0 : vedirect : raspberrypiIO64 - enabled system.adapter.vis-bars.0 : vis-bars : raspberrypiIO64 - enabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : raspberrypiIO64 - enabled system.adapter.vis.0 : vis : raspberrypiIO64 - enabled + system.adapter.web.0 : web : raspberrypiIO64 - enabled, port: 8082, bind: 0.0.0.0, run as: admin system.adapter.zigbee.0 : zigbee : raspberrypiIO64 - disabled, port: /dev/ttyACM0 + instance is alive Enabled adapters with bindings + system.adapter.admin.1 : admin : raspberrypiIO64 - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.hm-rpc.0 : hm-rpc : raspberrypiIO64 - enabled, port: 0 + system.adapter.hm-rpc.1 : hm-rpc : raspberrypiIO64 - enabled, port: 0 + system.adapter.influxdb.0 : influxdb : raspberrypiIO64 - enabled, port: 8086 + system.adapter.mqtt.0 : mqtt : raspberrypiIO64 - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.owfs.0 : owfs : raspberrypiIO64 - enabled, port: 4304 + system.adapter.shelly.1 : shelly : raspberrypiIO64 - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.simple-api.0 : simple-api : raspberrypiIO64 - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.web.0 : web : raspberrypiIO64 - enabled, port: 8082, bind: 0.0.0.0, run as: admin ioBroker-Repositories stable : http://download.iobroker.net/sources-dist.json beta : http://download.iobroker.net/sources-dist-latest.json Active repo(s): stable Installed ioBroker-Instances Used repository: stable Adapter "admin" : 6.3.5 , installed 6.3.5 Adapter "alias-manager": 1.2.4 , installed 1.2.4 Adapter "backitup" : 2.6.19 , installed 2.6.19 Adapter "discovery" : 3.1.0 , installed 3.1.0 Adapter "echarts" : 1.0.12 , installed 1.0.12 Adapter "flot" : 1.11.0 , installed 1.11.0 Adapter "history" : 2.2.4 , installed 2.2.4 Adapter "hm-rega" : 3.0.46 , installed 3.0.46 Adapter "hm-rpc" : 1.15.16 , installed 1.15.16 Adapter "influxdb" : 3.2.0 , installed 3.2.0 Adapter "info" : 1.9.26 , installed 1.9.26 Adapter "javascript" : 6.1.4 , installed 6.1.4 Controller "js-controller": 4.0.24 , installed 4.0.24 Adapter "modbus" : 5.0.11 , installed 5.0.11 Adapter "mqtt" : 4.0.7 , installed 4.0.7 Adapter "net-tools" : 0.2.0 , installed 0.2.0 Adapter "owfs" : 0.7.0 , installed 0.7.0 Adapter "rpi2" : 1.3.2 , installed 1.3.2 Adapter "shelly" : 6.3.1 , installed 6.3.1 Adapter "simple-api" : 2.7.2 , installed 2.7.2 Adapter "socketio" : 4.2.0 , installed 4.2.0 Adapter "vis" : 1.4.16 , installed 1.4.16 Adapter "vis-bars" : 0.1.4 , installed 0.1.4 Adapter "vis-hqwidgets": 1.3.0 , installed 1.3.0 Adapter "web" : 4.3.0 , installed 4.3.0 Adapter "ws" : 1.3.0 , installed 1.3.0 Adapter "zigbee" : 1.8.10 , installed 1.8.10 Objects and States Please stand by - This may take a while Objects: 5675 States: 5142 *** OS-Repositories and Updates *** Hit:1 http://deb.debian.org/debian bullseye InRelease Hit:2 http://deb.debian.org/debian bullseye-updates InRelease Hit:3 http://security.debian.org/debian-security bullseye-security InRelease Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease Hit:5 https://repos.influxdata.com/debian stable InRelease Hit:6 https://deb.nodesource.com/node_18.x bullseye InRelease Hit:7 https://packages.grafana.com/enterprise/deb stable InRelease Reading package lists... Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 1001 16707 1298/io.mqtt.0 tcp 0 0 0.0.0.0:9001 0.0.0.0:* LISTEN 1001 12139 868/iobroker.js-con tcp 0 0 0.0.0.0:9000 0.0.0.0:* LISTEN 1001 13121 868/iobroker.js-con tcp 0 0 192.168.2.54:2001 0.0.0.0:* LISTEN 1001 15732 1240/io.hm-rpc.1 tcp 0 0 192.168.2.54:2010 0.0.0.0:* LISTEN 1001 17534 1226/io.hm-rpc.0 tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 12972 578/sshd: /usr/sbin tcp6 0 0 :::8082 :::* LISTEN 1001 19169 2135/io.web.0 tcp6 0 0 :::8081 :::* LISTEN 1001 15537 1092/io.admin.1 tcp6 0 0 :::8087 :::* LISTEN 1001 18684 1675/io.simple-api. tcp6 0 0 :::8086 :::* LISTEN 999 12104 709/influxd tcp6 0 0 :::3000 :::* LISTEN 111 13154 867/grafana tcp6 0 0 :::22 :::* LISTEN 0 12974 578/sshd: /usr/sbin udp 0 0 0.0.0.0:49615 0.0.0.0:* 108 14575 413/avahi-daemon: r udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 14573 413/avahi-daemon: r udp 0 0 0.0.0.0:5683 0.0.0.0:* 1001 16844 1531/io.shelly.1 udp 0 0 0.0.0.0:68 0.0.0.0:* 0 14051 706/dhcpcd udp6 0 0 :::546 :::* 0 12997 706/dhcpcd udp6 0 0 :::40016 :::* 108 14576 413/avahi-daemon: r udp6 0 0 :::5353 :::* 108 14574 413/avahi-daemon: r *** Log File - Last 25 Lines *** 2023-05-05 11:17:42.324 - warn: host.raspberrypiIO64 "system.host.debian11" is offline 2023-05-05 11:17:45.107 - warn: shelly.1 (1531) [authEnabled] 192.168.2.56 (shellyem / shellyem-244CAB419A03 / SHEM#244CAB419A03#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-05 11:17:45.328 - warn: shelly.1 (1531) [authEnabled] 192.168.2.12 (shellyswitch25 / shellyswitch25-3C6105E462D5 / SHSW-25#3C6105E462D5#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-05 11:17:45.370 - warn: shelly.1 (1531) [authEnabled] 192.168.2.9 (shellyswitch25 / shellyswitch25-3C6105E3A7AF / SHSW-25#3C6105E3A7AF#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-05 11:17:45.376 - warn: shelly.1 (1531) [authEnabled] 192.168.2.6 (shellyswitch25 / shellyswitch25-68C63AFA870D / SHSW-25#68C63AFA870D#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-05 11:17:45.467 - warn: shelly.1 (1531) [authEnabled] 192.168.2.5 (shellyswitch25 / shellyswitch25-68C63AFA51AA / SHSW-25#68C63AFA51AA#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-05 11:17:45.780 - warn: shelly.1 (1531) [authEnabled] 192.168.2.52 (shellyem3 / shellyem3-485519D7986A / SHEM-3#485519D7986A#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-05 11:17:50.202 - warn: shelly.1 (1531) [authEnabled] 192.168.2.56 (shellyem / shellyem-244CAB419A03 / SHEM#244CAB419A03#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-05 11:17:50.635 - warn: shelly.1 (1531) [authEnabled] 192.168.2.12 (shellyswitch25 / shellyswitch25-3C6105E462D5 / SHSW-25#3C6105E462D5#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-05 11:17:50.810 - warn: shelly.1 (1531) [authEnabled] 192.168.2.5 (shellyswitch25 / shellyswitch25-68C63AFA51AA / SHSW-25#68C63AFA51AA#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-05 11:17:50.823 - warn: shelly.1 (1531) [authEnabled] 192.168.2.6 (shellyswitch25 / shellyswitch25-68C63AFA870D / SHSW-25#68C63AFA870D#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-05 11:17:51.282 - warn: shelly.1 (1531) [authEnabled] 192.168.2.9 (shellyswitch25 / shellyswitch25-3C6105E3A7AF / SHSW-25#3C6105E3A7AF#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-05 11:17:51.733 - warn: shelly.1 (1531) [authEnabled] 192.168.2.52 (shellyem3 / shellyem3-485519D7986A / SHEM-3#485519D7986A#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-05 11:17:55.380 - warn: shelly.1 (1531) [authEnabled] 192.168.2.56 (shellyem / shellyem-244CAB419A03 / SHEM#244CAB419A03#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-05 11:17:55.856 - warn: shelly.1 (1531) [authEnabled] 192.168.2.12 (shellyswitch25 / shellyswitch25-3C6105E462D5 / SHSW-25#3C6105E462D5#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-05 11:17:56.280 - warn: shelly.1 (1531) [authEnabled] 192.168.2.6 (shellyswitch25 / shellyswitch25-68C63AFA870D / SHSW-25#68C63AFA870D#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-05 11:17:56.351 - warn: shelly.1 (1531) [authEnabled] 192.168.2.5 (shellyswitch25 / shellyswitch25-68C63AFA51AA / SHSW-25#68C63AFA51AA#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-05 11:17:56.494 - warn: shelly.1 (1531) [authEnabled] 192.168.2.9 (shellyswitch25 / shellyswitch25-3C6105E3A7AF / SHSW-25#3C6105E3A7AF#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-05 11:17:57.185 - warn: shelly.1 (1531) [authEnabled] 192.168.2.52 (shellyem3 / shellyem3-485519D7986A / SHEM-3#485519D7986A#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-05 11:18:00.477 - warn: shelly.1 (1531) [authEnabled] 192.168.2.56 (shellyem / shellyem-244CAB419A03 / SHEM#244CAB419A03#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-05 11:18:01.245 - warn: shelly.1 (1531) [authEnabled] 192.168.2.12 (shellyswitch25 / shellyswitch25-3C6105E462D5 / SHSW-25#3C6105E462D5#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-05 11:18:01.593 - warn: shelly.1 (1531) [authEnabled] 192.168.2.6 (shellyswitch25 / shellyswitch25-68C63AFA870D / SHSW-25#68C63AFA870D#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-05 11:18:01.784 - warn: shelly.1 (1531) [authEnabled] 192.168.2.9 (shellyswitch25 / shellyswitch25-3C6105E3A7AF / SHSW-25#3C6105E3A7AF#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-05 11:18:01.789 - warn: shelly.1 (1531) [authEnabled] 192.168.2.5 (shellyswitch25 / shellyswitch25-68C63AFA51AA / SHSW-25#68C63AFA51AA#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-05 11:18:02.523 - warn: shelly.1 (1531) [authEnabled] 192.168.2.52 (shellyem3 / shellyem3-485519D7986A / SHEM-3#485519D7986A#1): This device is not protected via restricted login (see adapter documentation for details) ============ Mark until here for C&P ============= iob diag has finished. Press any key for a summary -
Werte werden in die DB geschrieben, kann sie auch mit grafana auslesen.======== Start marking the full check here ========= Skript v.2023-04-16 *** BASE SYSTEM *** Model : Raspberry Pi 400 Rev 1.1 Architecture : aarch64 Docker : false Virtualization : none Distributor ID: Debian Description: Debian GNU/Linux 11 (bullseye) Release: 11 Codename: bullseye PRETTY_NAME="Debian GNU/Linux 11 (bullseye)" NAME="Debian GNU/Linux" VERSION_ID="11" VERSION="11 (bullseye)" VERSION_CODENAME=bullseye ID=debian HOME_URL="https://www.debian.org/" SUPPORT_URL="https://www.debian.org/support" BUG_REPORT_URL="https://bugs.debian.org/" Systemuptime and Load: 11:16:51 up 18:28, 1 user, load average: 0.52, 0.67, 0.78 CPU threads: 4 Raspberry only: throttled=0x0 Other values than 0x0 hint to temperature/voltage problems temp=39.9'C volt=0.9360V *** Time and Time Zones *** Local time: Fri 2023-05-05 11:16:52 CEST Universal time: Fri 2023-05-05 09:16:52 UTC RTC time: n/a Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** User and Groups *** otto /home/otto otto adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker *** X-Server-Setup *** X-Server: false Desktop: Terminal: tty Boot Target: multi-user.target *** MEMORY *** total used free shared buff/cache available Mem: 3.8G 2.0G 723M 1.0M 1.1G 1.7G Swap: 99M 0B 99M Total: 3.9G 2.0G 823M 3793 M total memory 1988 M used memory 2247 M active memory 649 M inactive memory 723 M free memory 90 M buffer memory 991 M swap cache 99 M total swap 0 M used swap 99 M free swap Raspberry only: oom events: 0 lifetime oom required: 0 Mbytes total time in oom handler: 0 ms max time spent in oom handler: 0 ms *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on /dev/root ext4 110G 5.2G 101G 5% / devtmpfs devtmpfs 1.7G 0 1.7G 0% /dev tmpfs tmpfs 1.9G 0 1.9G 0% /dev/shm tmpfs tmpfs 759M 1.1M 758M 1% /run tmpfs tmpfs 5.0M 0 5.0M 0% /run/lock /dev/sda1 vfat 255M 31M 225M 13% /boot //192.168.2.57/backup cifs 95G 12G 83G 13% /opt/iobroker/backups tmpfs tmpfs 380M 0 380M 0% /run/user/1000 Messages concerning ext4 filesystem in dmesg: Show mounted filesystems (real ones only): TARGET SOURCE FSTYPE OPTIONS / /dev/sda2 ext4 rw,noatime |-/boot /dev/sda1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro `-/opt/iobroker/backups //192.168.2.57/backup cifs rw,relatime,vers=3.0,cache=strict,username=iobroker,uid=1001,noforceuid,gid=1001,noforcegid,addr=192.168.2.57,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1,closetimeo=5 Files in neuralgic directories: /var: 1.1G /var/ 418M /var/log 361M /var/cache 355M /var/cache/apt 353M /var/log/journal/007bdc1de22f4392961e44836db9bdcf Archived and active journals take up 352.0M in the file system. /opt/iobroker/backups: 368M /opt/iobroker/backups/ 88K /opt/iobroker/backups/otto 20K /opt/iobroker/backups/guest 4.0K /opt/iobroker/backups/otto/.config/htop 4.0K /opt/iobroker/backups/otto/.config /opt/iobroker/iobroker-data: 1.1G /opt/iobroker/iobroker-data/ 800M /opt/iobroker/iobroker-data/history 147M /opt/iobroker/iobroker-data/files 68M /opt/iobroker/iobroker-data/backup-objects 51M /opt/iobroker/iobroker-data/files/javascript.admin The five largest files in iobroker-data are: 12M /opt/iobroker/iobroker-data/objects.jsonl 9.1M /opt/iobroker/iobroker-data/files/echarts.admin/static/js/2.bbf74d5f.chunk.js.map 8.9M /opt/iobroker/iobroker-data/files/echarts/static/js/2.3d2d025f.chunk.js.map 8.9M /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/2.3d2d025f.chunk.js.map 8.4M /opt/iobroker/iobroker-data/states.jsonl *** NodeJS-Installation *** /usr/bin/nodejs v18.16.0 /usr/bin/node v18.16.0 /usr/bin/npm 9.5.1 /usr/bin/npx 9.5.1 nodejs: Installed: 18.16.0-deb-1nodesource1 Candidate: 18.16.0-deb-1nodesource1 Version table: *** 18.16.0-deb-1nodesource1 500 500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages 100 /var/lib/dpkg/status 12.22.12~dfsg-1~deb11u4 500 500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages 12.22.12~dfsg-1~deb11u3 500 500 http://deb.debian.org/debian bullseye/main arm64 Packages Temp directories causing npm8 problem: 0 No problems detected *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl MULTIHOSTSERVICE/enabled: false Core adapters versions js-controller: 4.0.24 admin: 6.3.5 javascript: 6.1.4 Adapters from github: 3 Adapter State + system.adapter.admin.1 : admin : raspberrypiIO64 - enabled, port: 8081, bind: 0.0.0.0, run as: admin system.adapter.alias-manager.0 : alias-manager : raspberrypiIO64 - disabled + system.adapter.backitup.0 : backitup : raspberrypiIO64 - enabled + system.adapter.discovery.0 : discovery : raspberrypiIO64 - enabled + system.adapter.echarts.0 : echarts : raspberrypiIO64 - enabled system.adapter.flot.0 : flot : raspberrypiIO64 - disabled + system.adapter.history.0 : history : raspberrypiIO64 - enabled + system.adapter.hm-rega.0 : hm-rega : raspberrypiIO64 - enabled + system.adapter.hm-rpc.0 : hm-rpc : raspberrypiIO64 - enabled, port: 0 + system.adapter.hm-rpc.1 : hm-rpc : raspberrypiIO64 - enabled, port: 0 + system.adapter.influxdb.0 : influxdb : raspberrypiIO64 - enabled, port: 8086 + system.adapter.info.0 : info : raspberrypiIO64 - enabled + system.adapter.javascript.0 : javascript : raspberrypiIO64 - enabled + system.adapter.modbus.0 : modbus : raspberrypiIO64 - enabled + system.adapter.mqtt.0 : mqtt : raspberrypiIO64 - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.net-tools.0 : net-tools : raspberrypiIO64 - enabled + system.adapter.opendtu.0 : opendtu : raspberrypiIO64 - enabled + system.adapter.owfs.0 : owfs : raspberrypiIO64 - enabled, port: 4304 + system.adapter.rpi2.0 : rpi2 : raspberrypiIO64 - enabled + system.adapter.shelly.1 : shelly : raspberrypiIO64 - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.simple-api.0 : simple-api : raspberrypiIO64 - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.sourceanalytix.0 : sourceanalytix : raspberrypiIO64 - enabled + system.adapter.vedirect.0 : vedirect : raspberrypiIO64 - enabled system.adapter.vis-bars.0 : vis-bars : raspberrypiIO64 - enabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : raspberrypiIO64 - enabled system.adapter.vis.0 : vis : raspberrypiIO64 - enabled + system.adapter.web.0 : web : raspberrypiIO64 - enabled, port: 8082, bind: 0.0.0.0, run as: admin system.adapter.zigbee.0 : zigbee : raspberrypiIO64 - disabled, port: /dev/ttyACM0 + instance is alive Enabled adapters with bindings + system.adapter.admin.1 : admin : raspberrypiIO64 - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.hm-rpc.0 : hm-rpc : raspberrypiIO64 - enabled, port: 0 + system.adapter.hm-rpc.1 : hm-rpc : raspberrypiIO64 - enabled, port: 0 + system.adapter.influxdb.0 : influxdb : raspberrypiIO64 - enabled, port: 8086 + system.adapter.mqtt.0 : mqtt : raspberrypiIO64 - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.owfs.0 : owfs : raspberrypiIO64 - enabled, port: 4304 + system.adapter.shelly.1 : shelly : raspberrypiIO64 - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.simple-api.0 : simple-api : raspberrypiIO64 - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.web.0 : web : raspberrypiIO64 - enabled, port: 8082, bind: 0.0.0.0, run as: admin ioBroker-Repositories stable : http://download.iobroker.net/sources-dist.json beta : http://download.iobroker.net/sources-dist-latest.json Active repo(s): stable Installed ioBroker-Instances Used repository: stable Adapter "admin" : 6.3.5 , installed 6.3.5 Adapter "alias-manager": 1.2.4 , installed 1.2.4 Adapter "backitup" : 2.6.19 , installed 2.6.19 Adapter "discovery" : 3.1.0 , installed 3.1.0 Adapter "echarts" : 1.0.12 , installed 1.0.12 Adapter "flot" : 1.11.0 , installed 1.11.0 Adapter "history" : 2.2.4 , installed 2.2.4 Adapter "hm-rega" : 3.0.46 , installed 3.0.46 Adapter "hm-rpc" : 1.15.16 , installed 1.15.16 Adapter "influxdb" : 3.2.0 , installed 3.2.0 Adapter "info" : 1.9.26 , installed 1.9.26 Adapter "javascript" : 6.1.4 , installed 6.1.4 Controller "js-controller": 4.0.24 , installed 4.0.24 Adapter "modbus" : 5.0.11 , installed 5.0.11 Adapter "mqtt" : 4.0.7 , installed 4.0.7 Adapter "net-tools" : 0.2.0 , installed 0.2.0 Adapter "owfs" : 0.7.0 , installed 0.7.0 Adapter "rpi2" : 1.3.2 , installed 1.3.2 Adapter "shelly" : 6.3.1 , installed 6.3.1 Adapter "simple-api" : 2.7.2 , installed 2.7.2 Adapter "socketio" : 4.2.0 , installed 4.2.0 Adapter "vis" : 1.4.16 , installed 1.4.16 Adapter "vis-bars" : 0.1.4 , installed 0.1.4 Adapter "vis-hqwidgets": 1.3.0 , installed 1.3.0 Adapter "web" : 4.3.0 , installed 4.3.0 Adapter "ws" : 1.3.0 , installed 1.3.0 Adapter "zigbee" : 1.8.10 , installed 1.8.10 Objects and States Please stand by - This may take a while Objects: 5675 States: 5142 *** OS-Repositories and Updates *** Hit:1 http://deb.debian.org/debian bullseye InRelease Hit:2 http://deb.debian.org/debian bullseye-updates InRelease Hit:3 http://security.debian.org/debian-security bullseye-security InRelease Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease Hit:5 https://repos.influxdata.com/debian stable InRelease Hit:6 https://deb.nodesource.com/node_18.x bullseye InRelease Hit:7 https://packages.grafana.com/enterprise/deb stable InRelease Reading package lists... Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 1001 16707 1298/io.mqtt.0 tcp 0 0 0.0.0.0:9001 0.0.0.0:* LISTEN 1001 12139 868/iobroker.js-con tcp 0 0 0.0.0.0:9000 0.0.0.0:* LISTEN 1001 13121 868/iobroker.js-con tcp 0 0 192.168.2.54:2001 0.0.0.0:* LISTEN 1001 15732 1240/io.hm-rpc.1 tcp 0 0 192.168.2.54:2010 0.0.0.0:* LISTEN 1001 17534 1226/io.hm-rpc.0 tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 12972 578/sshd: /usr/sbin tcp6 0 0 :::8082 :::* LISTEN 1001 19169 2135/io.web.0 tcp6 0 0 :::8081 :::* LISTEN 1001 15537 1092/io.admin.1 tcp6 0 0 :::8087 :::* LISTEN 1001 18684 1675/io.simple-api. tcp6 0 0 :::8086 :::* LISTEN 999 12104 709/influxd tcp6 0 0 :::3000 :::* LISTEN 111 13154 867/grafana tcp6 0 0 :::22 :::* LISTEN 0 12974 578/sshd: /usr/sbin udp 0 0 0.0.0.0:49615 0.0.0.0:* 108 14575 413/avahi-daemon: r udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 14573 413/avahi-daemon: r udp 0 0 0.0.0.0:5683 0.0.0.0:* 1001 16844 1531/io.shelly.1 udp 0 0 0.0.0.0:68 0.0.0.0:* 0 14051 706/dhcpcd udp6 0 0 :::546 :::* 0 12997 706/dhcpcd udp6 0 0 :::40016 :::* 108 14576 413/avahi-daemon: r udp6 0 0 :::5353 :::* 108 14574 413/avahi-daemon: r *** Log File - Last 25 Lines *** 2023-05-05 11:17:42.324 - warn: host.raspberrypiIO64 "system.host.debian11" is offline 2023-05-05 11:17:45.107 - warn: shelly.1 (1531) [authEnabled] 192.168.2.56 (shellyem / shellyem-244CAB419A03 / SHEM#244CAB419A03#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-05 11:17:45.328 - warn: shelly.1 (1531) [authEnabled] 192.168.2.12 (shellyswitch25 / shellyswitch25-3C6105E462D5 / SHSW-25#3C6105E462D5#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-05 11:17:45.370 - warn: shelly.1 (1531) [authEnabled] 192.168.2.9 (shellyswitch25 / shellyswitch25-3C6105E3A7AF / SHSW-25#3C6105E3A7AF#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-05 11:17:45.376 - warn: shelly.1 (1531) [authEnabled] 192.168.2.6 (shellyswitch25 / shellyswitch25-68C63AFA870D / SHSW-25#68C63AFA870D#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-05 11:17:45.467 - warn: shelly.1 (1531) [authEnabled] 192.168.2.5 (shellyswitch25 / shellyswitch25-68C63AFA51AA / SHSW-25#68C63AFA51AA#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-05 11:17:45.780 - warn: shelly.1 (1531) [authEnabled] 192.168.2.52 (shellyem3 / shellyem3-485519D7986A / SHEM-3#485519D7986A#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-05 11:17:50.202 - warn: shelly.1 (1531) [authEnabled] 192.168.2.56 (shellyem / shellyem-244CAB419A03 / SHEM#244CAB419A03#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-05 11:17:50.635 - warn: shelly.1 (1531) [authEnabled] 192.168.2.12 (shellyswitch25 / shellyswitch25-3C6105E462D5 / SHSW-25#3C6105E462D5#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-05 11:17:50.810 - warn: shelly.1 (1531) [authEnabled] 192.168.2.5 (shellyswitch25 / shellyswitch25-68C63AFA51AA / SHSW-25#68C63AFA51AA#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-05 11:17:50.823 - warn: shelly.1 (1531) [authEnabled] 192.168.2.6 (shellyswitch25 / shellyswitch25-68C63AFA870D / SHSW-25#68C63AFA870D#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-05 11:17:51.282 - warn: shelly.1 (1531) [authEnabled] 192.168.2.9 (shellyswitch25 / shellyswitch25-3C6105E3A7AF / SHSW-25#3C6105E3A7AF#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-05 11:17:51.733 - warn: shelly.1 (1531) [authEnabled] 192.168.2.52 (shellyem3 / shellyem3-485519D7986A / SHEM-3#485519D7986A#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-05 11:17:55.380 - warn: shelly.1 (1531) [authEnabled] 192.168.2.56 (shellyem / shellyem-244CAB419A03 / SHEM#244CAB419A03#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-05 11:17:55.856 - warn: shelly.1 (1531) [authEnabled] 192.168.2.12 (shellyswitch25 / shellyswitch25-3C6105E462D5 / SHSW-25#3C6105E462D5#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-05 11:17:56.280 - warn: shelly.1 (1531) [authEnabled] 192.168.2.6 (shellyswitch25 / shellyswitch25-68C63AFA870D / SHSW-25#68C63AFA870D#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-05 11:17:56.351 - warn: shelly.1 (1531) [authEnabled] 192.168.2.5 (shellyswitch25 / shellyswitch25-68C63AFA51AA / SHSW-25#68C63AFA51AA#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-05 11:17:56.494 - warn: shelly.1 (1531) [authEnabled] 192.168.2.9 (shellyswitch25 / shellyswitch25-3C6105E3A7AF / SHSW-25#3C6105E3A7AF#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-05 11:17:57.185 - warn: shelly.1 (1531) [authEnabled] 192.168.2.52 (shellyem3 / shellyem3-485519D7986A / SHEM-3#485519D7986A#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-05 11:18:00.477 - warn: shelly.1 (1531) [authEnabled] 192.168.2.56 (shellyem / shellyem-244CAB419A03 / SHEM#244CAB419A03#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-05 11:18:01.245 - warn: shelly.1 (1531) [authEnabled] 192.168.2.12 (shellyswitch25 / shellyswitch25-3C6105E462D5 / SHSW-25#3C6105E462D5#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-05 11:18:01.593 - warn: shelly.1 (1531) [authEnabled] 192.168.2.6 (shellyswitch25 / shellyswitch25-68C63AFA870D / SHSW-25#68C63AFA870D#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-05 11:18:01.784 - warn: shelly.1 (1531) [authEnabled] 192.168.2.9 (shellyswitch25 / shellyswitch25-3C6105E3A7AF / SHSW-25#3C6105E3A7AF#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-05 11:18:01.789 - warn: shelly.1 (1531) [authEnabled] 192.168.2.5 (shellyswitch25 / shellyswitch25-68C63AFA51AA / SHSW-25#68C63AFA51AA#1): This device is not protected via restricted login (see adapter documentation for details) 2023-05-05 11:18:02.523 - warn: shelly.1 (1531) [authEnabled] 192.168.2.52 (shellyem3 / shellyem3-485519D7986A / SHEM-3#485519D7986A#1): This device is not protected via restricted login (see adapter documentation for details) ============ Mark until here for C&P ============= iob diag has finished. Press any key for a summary@laser sagte in vedirekt Adapter Verbindungsproblem:
Werde dieses Repostery löschen.Du solltest es gescheit neu anlegen. Ist hier im Forum auch schon in einem Thread behandelt worden. Gleiches gilt für das grafana-Repo.
@Thomas-Braun OK, werde neu anlegen. Muß nur noch die "richtige" Beschreibung finden. Nur das Repostery neu anlegen, nicht die Installationen löschen und neu machen?
gefunden:
wget -qO- https://repos.influxdata.com/influxdb.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdb.gpg > /dev/null export DISTRIB_ID=$(lsb_release -si); export DISTRIB_CODENAME=$(lsb_release -sc) echo "deb [signed-by=/etc/apt/trusted.gpg.d/influxdb.gpg] https://repos.influxdata.com/${DISTRIB_ID,,} ${DISTRIB_CODENAME} stable" | sudo tee /etc/apt/sources.list.d/influxdb.list > /dev/null sudo apt-get update && sudo apt-get install influxdb2otto@raspberrypiIO64:~ $ sudo apt-get update Hit:1 http://security.debian.org/debian-security bullseye-security InRelease Hit:2 http://deb.debian.org/debian bullseye InRelease Hit:3 http://deb.debian.org/debian bullseye-updates InRelease Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease Hit:5 https://repos.influxdata.com/debian stable InRelease Hit:6 https://deb.nodesource.com/node_18.x bullseye InRelease Get:7 https://repos.influxdata.com/debian bullseye InRelease [7,031 B] Hit:8 https://packages.grafana.com/enterprise/deb stable InRelease Err:7 https://repos.influxdata.com/debian bullseye InRelease The following signatures couldn't be verified because the public key is not available: NO_PUB KEY D8FF8E1F7DF8B07E Reading package lists... Done W: GPG error: https://repos.influxdata.com/debian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E E: The repository 'https://repos.influxdata.com/debian bullseye InRelease' is not signed. N: Updating from such a repository can't be done securely, and is therefore disabled by default . N: See apt-secure(8) manpage for repository creation and user configuration details. -
gefunden:
wget -qO- https://repos.influxdata.com/influxdb.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdb.gpg > /dev/null export DISTRIB_ID=$(lsb_release -si); export DISTRIB_CODENAME=$(lsb_release -sc) echo "deb [signed-by=/etc/apt/trusted.gpg.d/influxdb.gpg] https://repos.influxdata.com/${DISTRIB_ID,,} ${DISTRIB_CODENAME} stable" | sudo tee /etc/apt/sources.list.d/influxdb.list > /dev/null sudo apt-get update && sudo apt-get install influxdb2otto@raspberrypiIO64:~ $ sudo apt-get update Hit:1 http://security.debian.org/debian-security bullseye-security InRelease Hit:2 http://deb.debian.org/debian bullseye InRelease Hit:3 http://deb.debian.org/debian bullseye-updates InRelease Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease Hit:5 https://repos.influxdata.com/debian stable InRelease Hit:6 https://deb.nodesource.com/node_18.x bullseye InRelease Get:7 https://repos.influxdata.com/debian bullseye InRelease [7,031 B] Hit:8 https://packages.grafana.com/enterprise/deb stable InRelease Err:7 https://repos.influxdata.com/debian bullseye InRelease The following signatures couldn't be verified because the public key is not available: NO_PUB KEY D8FF8E1F7DF8B07E Reading package lists... Done W: GPG error: https://repos.influxdata.com/debian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E E: The repository 'https://repos.influxdata.com/debian bullseye InRelease' is not signed. N: Updating from such a repository can't be done securely, and is therefore disabled by default . N: See apt-secure(8) manpage for repository creation and user configuration details.Ist eigentlich was für einen anderen Threads. Ich sehe aber nicht, dass du die alte .list-Datei gelöscht hast.
Hier steht mehr dazu drin:
https://forum.iobroker.net/topic/62040/linux-debian-grafana-repo-muss-aktualisiert-werden
@thomas-braun die alte Datei habe ich mit Nano geöffnet und geleert. Reicht das nicht?
Das Grafana Repo habe ich nach der Anleitung im Link neu angelegt. Influx wird immer noch angemeckert! -
Das Grafana Repo habe ich nach der Anleitung im Link neu angelegt. Influx wird immer noch angemeckert!@laser sagte in vedirekt Adapter Verbindungsproblem:
Reicht das nicht?
Die muss gelöscht werden.
Und die alten Keys auch. -
Reicht das nicht?
Und die alten Keys auch.@thomas-braun Aussage:
Das sicherste ist IMMER den Anleitungen direkt auf den Herstellerseiten zu folgen.Hier für InfluxDB2:
Installation InfluxDB2für verschiedene SystemeDa steht alles mögliche, aber nicht wie man die alten Keys löscht. Werde weitersuchen...
EDIT- jetzt scheint Alles OK zu sein. Keine Fehlermeldungen bei apt update.
Stimmt überwiegend. Es findet sich auch auf den influxdb-Seiten entsprechendes.
Das eigentliche Problem, der Adapter wird immer "gelb" Meldung "error" im log besteht aber immer noch.
Habe jetzt versucht, mit einem Script den Adapter zu restarten, wenn "error " im Log steht. Ob das nun elegant ist? Geht es auch einfacher? Das Bash- Script befindet sich in /opt und enthält nur den Befehl :
sudo iobroker restart vedirect.0// Script zum Erkennen des "error" im Adapter vedirekt onLog('vedirect' && 'error', data => { var SSH = require('simple-ssh'); var ssh = new SSH({ host: '192.168.2.54', user: 'name', pass: 'passwort' }); setState('javascript.0.Logik.ErrorVE'/*ErrorVE*/,1) console.log('VE Err: ' + "1"); // Adapter stoppen/starten (Beispiel): ssh.exec("bash /opt/verestart.sh").start(); }); -
sudo iobroker restart vedirect.0// Script zum Erkennen des "error" im Adapter vedirekt onLog('vedirect' && 'error', data => { var SSH = require('simple-ssh'); var ssh = new SSH({ host: '192.168.2.54', user: 'name', pass: 'passwort' }); setState('javascript.0.Logik.ErrorVE'/*ErrorVE*/,1) console.log('VE Err: ' + "1"); // Adapter stoppen/starten (Beispiel): ssh.exec("bash /opt/verestart.sh").start(); });@laser sagte in vedirekt Adapter Verbindungsproblem:
Hab ich behauptet das dein Problem damit aus der Welt sei?
Und ich werde vermutlich nie verstehen wo der Schwachsinn mit
sudo iobrokerherkommt.
Davon abgesehen gehören solche Skripte auch nicht nach /opt sondern in das Home des Users. -
Davon abgesehen gehören solche Skripte auch nicht nach /opt sondern in das Home des Users.@thomas-braun Bleib ganz ruhig! Es ist doch kein Angriff auf Dich! Das Ganze ist mit der heißen Nadel gestrickt. Das Script schiebe ich in das home- Verzeichnis. Der Ordnung halber. "Sudo iobroker" braucht es eigentlich nicht. Darf nicht sein, ist besser. Passiert manchmal einfach. Für mich ist auschlaggebend, daß ich eine Lösung habe, die erst mal funktioniert. Ich hoffe ja, das Problem mit der USB Schnittstelle ist irgendwann einmal behoben. Dann verschwindet das Script in der Mülltonne. Mit dem "Sudo" in guter Gesellschaft.
@laser Hallo!?
iobroker Befehle dürfen grundsätzlich ncht mit sudo eingeleitet werden Da kann das ganze Rechtegefüge wieder in die Knie gehen.und den ganzen restlichen Erguss kann ich überhaupt nicht sinnvoll zuordnen
Du hast aber schon verstanden dass dein Dateisystem irgendwo etwas verloren hatte?
@laser Hallo!?
@homoran Das mit dem Dateisystem habe ich zur Kenntnis genommen, aber nicht verstanden. Das mit dem Sudo schon. Der Rest ist zwischen Rasen Mähen und Feuerholz holen für den nächsten Winter entstanden. Weil der vedirekt Adapter immer wieder gestört war. Es geht jetzt. Der ganze Klimbim mit dem simple-ssh ist eingefügt, weil ich es auf die Schnelle nicht anders hinbekommen habe. Es funktioniert. Das ist entscheidend. Besser geht immer und immer wieder. Es werden ganze Industrie- Leitsysteme mit 10000 bekannten Fehlern verkauft. Sie tuen ihren Dienst und werden seit 20 Jahren nachgebessert. Von Riesen- Firmen.
ich kann mich nur wiederholen: liest du was du schreibst?
- bei der automatischen Überprüfung wurden verwaiste (orphan), nicht mehr zuordbare, Dateifragmente gefunden die gelöscht wurden.
- Die können überall fehlen.
- du findest kein /dev/by-id mehr
- du hast Meldungen zu USB im syslog
- du hast Probleme mit deinem USB
- du bekommst Fehlermeldungen dass falsche Wertetypen geschrieben werden, wenn angeblich weder ein Gerät angeschlossen ist, noch die Instanz läuft
- du bekommst angeblich Meldungen der Logstufe Info nur im debug-Modus, nicht im Modus Info
ich würde dem gesamten System nicht mehr vertrauen
@homoran dem ganzen System nicht mehr vertrauen. Das tue ich auch nicht. Also nochmal neu aufsetzen? Zum 25. Mal. Nicht, daß ich mich vor der Arbeit scheue. Irgend ein Problem ist bisher immer wieder aufgetaucht. Weil das ganze Linux/ IO-Broker Gestrick kein ausgereiftes System ist. Bastelkram eben. 100 Anleitungen. 99 davon veraltet. Das birgt einfach Gefahren. Auch bei der Neuinstallation.
