  3. Off Topic
  4. vedirekt Adapter Verbindungsproblem
    6.0k
140 Beiträge 7 Kommentatoren 20.8k Aufrufe 4 Beobachtet
    @laser sagte in vedirekt Adapter Verbindungsproblem:
    Den Rest kann ich nicht mehr kopieren.
    dann starte diag nochmal
    Laser
    schrieb am zuletzt editiert von Laser
    @homoran mal sehen, ob das was wird...
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 400 Rev 1.1
    Architecture    : aarch64
    Docker          : false
    Virtualization  : none
    Distributor ID: Debian
    Description:    Debian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     18:20:10 up  1:31,  1 user,  load average: 0.58, 0.85, 0.84
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=40.4'C
    volt=0.9360V
    *** Time and Time Zones ***
                   Local time: Thu 2023-05-04 18:20:10 CEST
               Universal time: Thu 2023-05-04 16:20:10 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    otto
    /home/otto
    otto adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            3.8G        1.8G        1.1G        1.0M        921M        1.9G
    Swap:            99M          0B         99M
    Total:          3.9G        1.8G        1.2G
             3793 M total memory
             1787 M used memory
             2042 M active memory
              518 M inactive memory
             1083 M free memory
               87 M buffer memory
              834 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4      110G  5.2G  101G   5% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     759M  1.1M  758M   1% /run
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    /dev/sda1      vfat      255M   31M  225M  13% /boot
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Thu May  4 16:48:24 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=D8:3A:DD:0F:ED:4A vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=34877f34-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Thu May  4 16:48:27 2023] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
    [Thu May  4 16:48:27 2023] EXT4-fs (sda2): write access will be enabled during recovery
    [Thu May  4 16:48:28 2023] EXT4-fs (sda2): orphan cleanup on readonly fs
    [Thu May  4 16:48:28 2023] EXT4-fs (sda2): 1 orphan inode deleted
    [Thu May  4 16:48:28 2023] EXT4-fs (sda2): recovery complete
    [Thu May  4 16:48:28 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Thu May  4 16:48:28 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Thu May  4 16:48:30 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
    TARGET  SOURCE    FSTYPE OPTIONS
    /       /dev/sda2 ext4   rw,noatime
    `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.1G    /var/
    405M    /var/log
    360M    /var/cache
    355M    /var/cache/apt
    345M    /var/log/journal/007bdc1de22f4392961e44836db9bdcf
    Archived and active journals take up 344.0M in the file system.
    /opt/iobroker/backups:
    4.0K    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.1G    /opt/iobroker/iobroker-data/
    796M    /opt/iobroker/iobroker-data/history
    147M    /opt/iobroker/iobroker-data/files
    68M     /opt/iobroker/iobroker-data/backup-objects
    51M     /opt/iobroker/iobroker-data/files/javascript.admin
    33M     /opt/iobroker/iobroker-data/objects.jsonl
    9.1M    /opt/iobroker/iobroker-data/files/echarts.admin/static/js/2.bbf74d5f.chunk.js.map
    8.9M    /opt/iobroker/iobroker-data/files/echarts/static/js/2.3d2d025f.chunk.js.map
    8.9M    /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/2.3d2d025f.chunk.js.map
    6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c9.chunk.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.16.0
    /usr/bin/node           v18.16.0
    /usr/bin/npm            9.5.1
    /usr/bin/npx            9.5.1
    nodejs:
      Installed: 18.16.0-deb-1nodesource1
      Candidate: 18.16.0-deb-1nodesource1
      Version table:
     *** 18.16.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     6.1.4
    Adapters from github:   3
    Adapter State
    + system.adapter.admin.1                  : admin                 : raspberrypiIO64                          -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alias-manager.0          : alias-manager         : raspberrypiIO64                          - disabled
    + system.adapter.backitup.0               : backitup              : raspberrypiIO64                          -  enabled
    + system.adapter.discovery.0              : discovery             : raspberrypiIO64                          -  enabled
    + system.adapter.echarts.0                : echarts               : raspberrypiIO64                          -  enabled
      system.adapter.flot.0                   : flot                  : raspberrypiIO64                          - disabled
    + system.adapter.history.0                : history               : raspberrypiIO64                          -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : raspberrypiIO64                          -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypiIO64                          -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypiIO64                          -  enabled, port: 0
    + system.adapter.influxdb.0               : influxdb              : raspberrypiIO64                          -  enabled, port: 8086
    + system.adapter.info.0                   : info                  : raspberrypiIO64                          -  enabled
    + system.adapter.javascript.0             : javascript            : raspberrypiIO64                          -  enabled
    + system.adapter.modbus.0                 : modbus                : raspberrypiIO64                          -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : raspberrypiIO64                          -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.net-tools.0              : net-tools             : raspberrypiIO64                          -  enabled
    + system.adapter.opendtu.0                : opendtu               : raspberrypiIO64                          -  enabled
    + system.adapter.owfs.0                   : owfs                  : raspberrypiIO64                          -  enabled, port: 4304
    + system.adapter.rpi2.0                   : rpi2                  : raspberrypiIO64                          -  enabled
    + system.adapter.shelly.1                 : shelly                : raspberrypiIO64                          -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : raspberrypiIO64                          -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypiIO64                          -  enabled
    + system.adapter.vedirect.0               : vedirect              : raspberrypiIO64                          -  enabled
      system.adapter.vis-bars.0               : vis-bars              : raspberrypiIO64                          -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypiIO64                          -  enabled
      system.adapter.vis.0                    : vis                   : raspberrypiIO64                          -  enabled
    + system.adapter.web.0                    : web                   : raspberrypiIO64                          -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.zigbee.0                 : zigbee                : raspberrypiIO64                          - disabled, port: /dev/ttyACM0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "alias-manager": 1.2.4    , installed 1.2.4
    Adapter    "backitup"     : 2.6.19   , installed 2.6.19
    Adapter    "echarts"      : 1.0.12   , installed 1.0.12
    Adapter    "flot"         : 1.11.0   , installed 1.11.0
    Adapter    "history"      : 2.2.4    , installed 2.2.4
    Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
    Adapter    "hm-rpc"       : 1.15.16  , installed 1.15.16
    Adapter    "javascript"   : 6.1.4    , installed 6.1.4
    Adapter    "modbus"       : 5.0.11   , installed 5.0.11
    Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "owfs"         : 0.7.0    , installed 0.7.0
    Adapter    "shelly"       : 6.3.1    , installed 6.3.1
    Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
    Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
    Objects and States
    Objects:        5675
    States:         5142
    W: GPG error: https://repos.influxdata.com/debian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    E: The repository 'https://repos.influxdata.com/debian bullseye InRelease' is not signed.
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       16707      1298/io.mqtt.0
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       12139      868/iobroker.js-con
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       13121      868/iobroker.js-con
    tcp        0      0 192.168.2.54:2001       0.0.0.0:*               LISTEN      1001       15732      1240/io.hm-rpc.1
    tcp        0      0 192.168.2.54:2010       0.0.0.0:*               LISTEN      1001       17534      1226/io.hm-rpc.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12972      578/sshd: /usr/sbin
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       19169      2135/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15537      1092/io.admin.1
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       18684      1675/io.simple-api.
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        12104      709/influxd
    tcp6       0      0 :::3000                 :::*                    LISTEN      111        13154      867/grafana
    tcp6       0      0 :::22                   :::*                    LISTEN      0          12974      578/sshd: /usr/sbin
    udp        0      0 0.0.0.0:49615           0.0.0.0:*                           108        14575      413/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14573      413/avahi-daemon: r
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       16844      1531/io.shelly.1
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14051      706/dhcpcd
    udp6       0      0 :::546                  :::*                                0          12997      706/dhcpcd
    udp6       0      0 :::40016                :::*                                108        14576      413/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        14574      413/avahi-daemon: r
    2023-05-04 18:20:50.571  - warn: shelly.1 (1531) [authEnabled] 192.168.2.6 (shellyswitch25 / shellyswitch25-68C63AFA870D / SHSW-25#68C63AFA870D#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-05-04 18:20:50.659  - warn: shelly.1 (1531) [authEnabled] 192.168.2.5 (shellyswitch25 / shellyswitch25-68C63AFA51AA / SHSW-25#68C63AFA51AA#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-05-04 18:20:50.844  - warn: shelly.1 (1531) [authEnabled] 192.168.2.12 (shellyswitch25 / shellyswitch25-3C6105E462D5 / SHSW-25#3C6105E462D5#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-05-04 18:20:52.045  - warn: shelly.1 (1531) [authEnabled] 192.168.2.52 (shellyem3 / shellyem3-485519D7986A / SHEM-3#485519D7986A#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-05-04 18:20:55.665  - warn: shelly.1 (1531) [authEnabled] 192.168.2.56 (shellyem / shellyem-244CAB419A03 / SHEM#244CAB419A03#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-05-04 18:20:55.751  - warn: shelly.1 (1531) [authEnabled] 192.168.2.9 (shellyswitch25 / shellyswitch25-3C6105E3A7AF / SHSW-25#3C6105E3A7AF#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-05-04 18:20:55.991  - warn: shelly.1 (1531) [authEnabled] 192.168.2.5 (shellyswitch25 / shellyswitch25-68C63AFA51AA / SHSW-25#68C63AFA51AA#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-05-04 18:20:55.997  - warn: shelly.1 (1531) [authEnabled] 192.168.2.6 (shellyswitch25 / shellyswitch25-68C63AFA870D / SHSW-25#68C63AFA870D#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-05-04 18:20:56.216  - warn: shelly.1 (1531) [authEnabled] 192.168.2.12 (shellyswitch25 / shellyswitch25-3C6105E462D5 / SHSW-25#3C6105E462D5#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-05-04 18:20:57.313  - warn: shelly.1 (1531) [authEnabled] 192.168.2.52 (shellyem3 / shellyem3-485519D7986A / SHEM-3#485519D7986A#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-05-04 18:21:00.811  - warn: shelly.1 (1531) [authEnabled] 192.168.2.56 (shellyem / shellyem-244CAB419A03 / SHEM#244CAB419A03#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-05-04 18:21:01.092  - warn: shelly.1 (1531) [authEnabled] 192.168.2.9 (shellyswitch25 / shellyswitch25-3C6105E3A7AF / SHSW-25#3C6105E3A7AF#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-05-04 18:21:01.411  - warn: shelly.1 (1531) [authEnabled] 192.168.2.5 (shellyswitch25 / shellyswitch25-68C63AFA51AA / SHSW-25#68C63AFA51AA#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-05-04 18:21:01.464  - warn: shelly.1 (1531) [authEnabled] 192.168.2.6 (shellyswitch25 / shellyswitch25-68C63AFA870D / SHSW-25#68C63AFA870D#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-05-04 18:21:01.536  - warn: shelly.1 (1531) [authEnabled] 192.168.2.12 (shellyswitch25 / shellyswitch25-3C6105E462D5 / SHSW-25#3C6105E462D5#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-05-04 18:21:02.591  - warn: shelly.1 (1531) [authEnabled] 192.168.2.52 (shellyem3 / shellyem3-485519D7986A / SHEM-3#485519D7986A#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-05-04 18:21:03.445  - info: javascript.0 (1172) script.js.Heizung.GPIO-IOTag: IstTag: true
    2023-05-04 18:21:03.445  - info: javascript.0 (1172) script.js.Heizung.GPIO-IOTag: istNacht: false
    2023-05-04 18:21:03.446  - info: javascript.0 (1172) script.js.Heizung.GPIO-IOTag: DPNacht IO: true
    2023-05-04 18:21:03.446  - info: javascript.0 (1172) script.js.Heizung.GPIO-IOTag: change GP23
    2023-05-04 18:21:05.914  - warn: shelly.1 (1531) [authEnabled] 192.168.2.56 (shellyem / shellyem-244CAB419A03 / SHEM#244CAB419A03#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-05-04 18:21:06.275  - warn: shelly.1 (1531) [authEnabled] 192.168.2.9 (shellyswitch25 / shellyswitch25-3C6105E3A7AF / SHSW-25#3C6105E3A7AF#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-05-04 18:21:06.743  - warn: shelly.1 (1531) [authEnabled] 192.168.2.5 (shellyswitch25 / shellyswitch25-68C63AFA51AA / SHSW-25#68C63AFA51AA#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-05-04 18:21:06.779  - warn: shelly.1 (1531) [authEnabled] 192.168.2.6 (shellyswitch25 / shellyswitch25-68C63AFA870D / SHSW-25#68C63AFA870D#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-05-04 18:21:07.971  - warn: shelly.1 (1531) [authEnabled] 192.168.2.52 (shellyem3 / shellyem3-485519D7986A / SHEM-3#485519D7986A#1): This device is not protected via restricted login (see adapter documentation for details)
    iob diag has finished.
    • L Laser
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Docker          : false
      Release:        11
      Codename:       bullseye
      VERSION_ID="11"
      ID=debian
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      temp=40.4'C
      volt=0.9360V
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      otto
      /home/otto
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            99M          0B         99M
               3793 M total memory
               1787 M used memory
               1083 M free memory
                 87 M buffer memory
                834 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      1.1G    /var/
      405M    /var/log
      360M    /var/cache
      355M    /var/cache/apt
      /usr/bin/npm            9.5.1
      /usr/bin/npx            9.5.1
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.3.5
      javascript:     6.1.4
      Adapter State
      + instance is alive
      Objects and States
      Objects:        5675
      States:         5142
      Pending Updates: 0
      @laser aah, du hast nochmal editiert!
      Ich bin kein Linux Crack, aber folgendes fällt mit auf
      Dein Dateisystem hat einen Schuss.
      ist kein ioBroker Thema, aber deine influxdb ist nicht sauber installiert
      läuft die auch noch auf dem Pi?
      L 1 Antwort Letzte Antwort
        Laser
        @homoran Die Influx 2.7 DB läuft auf dem PI. Habe ich neu installiert. Ist aber für mich absolutes Neuland.
        Repostery ist nicht signiert. Jetzt habe ich zig Anleitungen gelesen. Vermutlich nie die "Richtige". Stand in irgendeiner, das kann man ignorieren. Muß aber nicht richtig sein.
        Werde dieses Repostery löschen.
        Werte werden in die DB geschrieben, kann sie auch mit grafana auslesen.
        Skript v.2023-04-16
        *** BASE SYSTEM ***
        Docker          : false
        Release:        11
        Codename:       bullseye
        VERSION_ID="11"
        ID=debian
         11:16:51 up 18:28,  1 user,  load average: 0.52, 0.67, 0.78
        CPU threads: 4
        Raspberry only:
        throttled=0x0
        temp=39.9'C
        volt=0.9360V
                       Local time: Fri 2023-05-05 11:16:52 CEST
                   Universal time: Fri 2023-05-05 09:16:52 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        otto
        /home/otto
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            3.8G        2.0G        723M        1.0M        1.1G        1.7G
        Swap:            99M          0B         99M
        Total:          3.9G        2.0G        823M
                 3793 M total memory
                 1988 M used memory
                 2247 M active memory
                  649 M inactive memory
                  723 M free memory
                   90 M buffer memory
                  991 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        Filesystem            Type      Size  Used Avail Use% Mounted on
        //192.168.2.57/backup cifs       95G   12G   83G  13% /opt/iobroker/backups
        `-/opt/iobroker/backups //192.168.2.57/backup cifs   rw,relatime,vers=3.0,cache=strict,username=iobroker,uid=1001,noforceuid,gid=1001,noforcegid,addr=192.168.2.57,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1,closetimeo=5
        /var:
        1.1G    /var/
        418M    /var/log
        361M    /var/cache
        355M    /var/cache/apt
        353M    /var/log/journal/007bdc1de22f4392961e44836db9bdcf
        Archived and active journals take up 352.0M in the file system.
        368M    /opt/iobroker/backups/
        88K     /opt/iobroker/backups/otto
        20K     /opt/iobroker/backups/guest
        4.0K    /opt/iobroker/backups/otto/.config/htop
        800M    /opt/iobroker/iobroker-data/history
        12M     /opt/iobroker/iobroker-data/objects.jsonl
        8.4M    /opt/iobroker/iobroker-data/states.jsonl
        /usr/bin/npm            9.5.1
        /usr/bin/npx            9.5.1
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.3.5
        javascript:     6.1.4
        Adapter State
        + instance is alive
        Objects and States
        Objects:        5675
        States:         5142
        Hit:1 http://deb.debian.org/debian bullseye InRelease
        Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:5 https://repos.influxdata.com/debian stable InRelease
        Hit:6 https://deb.nodesource.com/node_18.x bullseye InRelease
        Hit:7 https://packages.grafana.com/enterprise/deb stable InRelease
        Reading package lists...
        Pending Updates: 0
        2023-05-05 11:17:42.324  - warn: host.raspberrypiIO64 "system.host.debian11" is offline
        2023-05-05 11:17:45.107  - warn: shelly.1 (1531) [authEnabled] 192.168.2.56 (shellyem / shellyem-244CAB419A03 / SHEM#244CAB419A03#1): This device is not protected via restricted login (see adapter documentation for details)
        2023-05-05 11:17:45.328  - warn: shelly.1 (1531) [authEnabled] 192.168.2.12 (shellyswitch25 / shellyswitch25-3C6105E462D5 / SHSW-25#3C6105E462D5#1): This device is not protected via restricted login (see adapter documentation for details)
        2023-05-05 11:17:45.370  - warn: shelly.1 (1531) [authEnabled] 192.168.2.9 (shellyswitch25 / shellyswitch25-3C6105E3A7AF / SHSW-25#3C6105E3A7AF#1): This device is not protected via restricted login (see adapter documentation for details)
        2023-05-05 11:17:45.376  - warn: shelly.1 (1531) [authEnabled] 192.168.2.6 (shellyswitch25 / shellyswitch25-68C63AFA870D / SHSW-25#68C63AFA870D#1): This device is not protected via restricted login (see adapter documentation for details)
        2023-05-05 11:17:45.467  - warn: shelly.1 (1531) [authEnabled] 192.168.2.5 (shellyswitch25 / shellyswitch25-68C63AFA51AA / SHSW-25#68C63AFA51AA#1): This device is not protected via restricted login (see adapter documentation for details)
        2023-05-05 11:17:45.780  - warn: shelly.1 (1531) [authEnabled] 192.168.2.52 (shellyem3 / shellyem3-485519D7986A / SHEM-3#485519D7986A#1): This device is not protected via restricted login (see adapter documentation for details)
        2023-05-05 11:17:50.202  - warn: shelly.1 (1531) [authEnabled] 192.168.2.56 (shellyem / shellyem-244CAB419A03 / SHEM#244CAB419A03#1): This device is not protected via restricted login (see adapter documentation for details)
        2023-05-05 11:17:50.635  - warn: shelly.1 (1531) [authEnabled] 192.168.2.12 (shellyswitch25 / shellyswitch25-3C6105E462D5 / SHSW-25#3C6105E462D5#1): This device is not protected via restricted login (see adapter documentation for details)
        2023-05-05 11:17:50.810  - warn: shelly.1 (1531) [authEnabled] 192.168.2.5 (shellyswitch25 / shellyswitch25-68C63AFA51AA / SHSW-25#68C63AFA51AA#1): This device is not protected via restricted login (see adapter documentation for details)
        2023-05-05 11:17:50.823  - warn: shelly.1 (1531) [authEnabled] 192.168.2.6 (shellyswitch25 / shellyswitch25-68C63AFA870D / SHSW-25#68C63AFA870D#1): This device is not protected via restricted login (see adapter documentation for details)
        2023-05-05 11:17:51.282  - warn: shelly.1 (1531) [authEnabled] 192.168.2.9 (shellyswitch25 / shellyswitch25-3C6105E3A7AF / SHSW-25#3C6105E3A7AF#1): This device is not protected via restricted login (see adapter documentation for details)
        2023-05-05 11:17:51.733  - warn: shelly.1 (1531) [authEnabled] 192.168.2.52 (shellyem3 / shellyem3-485519D7986A / SHEM-3#485519D7986A#1): This device is not protected via restricted login (see adapter documentation for details)
        2023-05-05 11:17:55.380  - warn: shelly.1 (1531) [authEnabled] 192.168.2.56 (shellyem / shellyem-244CAB419A03 / SHEM#244CAB419A03#1): This device is not protected via restricted login (see adapter documentation for details)
        2023-05-05 11:17:55.856  - warn: shelly.1 (1531) [authEnabled] 192.168.2.12 (shellyswitch25 / shellyswitch25-3C6105E462D5 / SHSW-25#3C6105E462D5#1): This device is not protected via restricted login (see adapter documentation for details)
        2023-05-05 11:17:56.280  - warn: shelly.1 (1531) [authEnabled] 192.168.2.6 (shellyswitch25 / shellyswitch25-68C63AFA870D / SHSW-25#68C63AFA870D#1): This device is not protected via restricted login (see adapter documentation for details)
        2023-05-05 11:17:56.351  - warn: shelly.1 (1531) [authEnabled] 192.168.2.5 (shellyswitch25 / shellyswitch25-68C63AFA51AA / SHSW-25#68C63AFA51AA#1): This device is not protected via restricted login (see adapter documentation for details)
        2023-05-05 11:17:56.494  - warn: shelly.1 (1531) [authEnabled] 192.168.2.9 (shellyswitch25 / shellyswitch25-3C6105E3A7AF / SHSW-25#3C6105E3A7AF#1): This device is not protected via restricted login (see adapter documentation for details)
        2023-05-05 11:17:57.185  - warn: shelly.1 (1531) [authEnabled] 192.168.2.52 (shellyem3 / shellyem3-485519D7986A / SHEM-3#485519D7986A#1): This device is not protected via restricted login (see adapter documentation for details)
        2023-05-05 11:18:00.477  - warn: shelly.1 (1531) [authEnabled] 192.168.2.56 (shellyem / shellyem-244CAB419A03 / SHEM#244CAB419A03#1): This device is not protected via restricted login (see adapter documentation for details)
        2023-05-05 11:18:01.245  - warn: shelly.1 (1531) [authEnabled] 192.168.2.12 (shellyswitch25 / shellyswitch25-3C6105E462D5 / SHSW-25#3C6105E462D5#1): This device is not protected via restricted login (see adapter documentation for details)
        2023-05-05 11:18:01.593  - warn: shelly.1 (1531) [authEnabled] 192.168.2.6 (shellyswitch25 / shellyswitch25-68C63AFA870D / SHSW-25#68C63AFA870D#1): This device is not protected via restricted login (see adapter documentation for details)
        2023-05-05 11:18:01.784  - warn: shelly.1 (1531) [authEnabled] 192.168.2.9 (shellyswitch25 / shellyswitch25-3C6105E3A7AF / SHSW-25#3C6105E3A7AF#1): This device is not protected via restricted login (see adapter documentation for details)
        2023-05-05 11:18:01.789  - warn: shelly.1 (1531) [authEnabled] 192.168.2.5 (shellyswitch25 / shellyswitch25-68C63AFA51AA / SHSW-25#68C63AFA51AA#1): This device is not protected via restricted login (see adapter documentation for details)
        2023-05-05 11:18:02.523  - warn: shelly.1 (1531) [authEnabled] 192.168.2.52 (shellyem3 / shellyem3-485519D7986A / SHEM-3#485519D7986A#1): This device is not protected via restricted login (see adapter documentation for details)
        Press any key for a summary
        • L Laser
          Skript v.2023-04-16
          *** BASE SYSTEM ***
          Docker          : false
          Release:        11
          Codename:       bullseye
          VERSION_ID="11"
          ID=debian
          CPU threads: 4
          Raspberry only:
          throttled=0x0
          temp=39.9'C
          volt=0.9360V
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          otto
          /home/otto
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:            99M          0B         99M
                   3793 M total memory
                   1988 M used memory
                    723 M free memory
                     90 M buffer memory
                    991 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FILESYSTEM ***
          /var:
          1.1G    /var/
          418M    /var/log
          361M    /var/cache
          355M    /var/cache/apt
          /usr/bin/npm            9.5.1
          /usr/bin/npx            9.5.1
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.3.5
          javascript:     6.1.4
          Adapter State
          + instance is alive
          Objects and States
          Objects:        5675
          States:         5142
          Pending Updates: 0
          Du solltest es gescheit neu anlegen. Ist hier im Forum auch schon in einem Thread behandelt worden. Gleiches gilt für das grafana-Repo.
          • derAlffD Offline
            derAlffD Offline
            derAlff
            @Laser hast du eventuell ein GX (Cerbo, Pi mit VenusOS, …) in deiner PV Installation?
            Proxmox 8
            ioBroker im LXC (Master)
            2x ioBrober auf RPi (3&4) als Zigbee Gateway (Slave)
            Paperless-ngx in VM
            OMV6 in VM
            Linux auf allen Endgeräten (Windows verbannt)
            • derAlffD derAlff
              Laser
              @Thomas-Braun OK, werde neu anlegen. Muß nur noch die "richtige" Beschreibung finden. Nur das Repostery neu anlegen, nicht die Installationen löschen und neu machen?
              gefunden:
              wget -qO- https://repos.influxdata.com/influxdb.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdb.gpg > /dev/null
              export DISTRIB_ID=$(lsb_release -si); export DISTRIB_CODENAME=$(lsb_release -sc)
              echo "deb [signed-by=/etc/apt/trusted.gpg.d/influxdb.gpg] https://repos.influxdata.com/${DISTRIB_ID,,} ${DISTRIB_CODENAME} stable" | sudo tee /etc/apt/sources.list.d/influxdb.list > /dev/null
              sudo apt-get update && sudo apt-get install influxdb2
              otto@raspberrypiIO64:~ $ sudo apt-get update
              Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
              Hit:2 http://deb.debian.org/debian bullseye InRelease
              Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
              Get:7 https://repos.influxdata.com/debian bullseye InRelease [7,031 B]
              Hit:8 https://packages.grafana.com/enterprise/deb stable InRelease
              Err:7 https://repos.influxdata.com/debian bullseye InRelease
                The following signatures couldn't be verified because the public key is not available: NO_PUB                                               KEY D8FF8E1F7DF8B07E
              Reading package lists... Done
              N: Updating from such a repository can't be done securely, and is therefore disabled by default                                               .
              N: See apt-secure(8) manpage for repository creation and user configuration details.
              • L Laser
                gefunden:
                #66
                @laser
                Ist eigentlich was für einen anderen Threads. Ich sehe aber nicht, dass du die alte .list-Datei gelöscht hast.
                Hier steht mehr dazu drin:
                https://forum.iobroker.net/topic/62040/linux-debian-grafana-repo-muss-aktualisiert-werden
                  @laser
                  Laser
                  #67
                  @thomas-braun die alte Datei habe ich mit Nano geöffnet und geleert. Reicht das nicht?
                  Das Grafana Repo habe ich nach der Anleitung im Link neu angelegt. Influx wird immer noch angemeckert!
                  • L Laser
                    #68
                    Reicht das nicht?
                    Die muss gelöscht werden.
                    Und die alten Keys auch.
                      Reicht das nicht?
                      Laser
                      #69
                      @thomas-braun Aussage:
                      Das sicherste ist IMMER den Anleitungen direkt auf den Herstellerseiten zu folgen.
                      Hier für InfluxDB2:
                      Installation InfluxDB2für verschiedene Systeme
                      Da steht alles mögliche, aber nicht wie man die alten Keys löscht. Werde weitersuchen...
                      EDIT- jetzt scheint Alles OK zu sein. Keine Fehlermeldungen bei apt update.
                      • L Laser
                        Hier für InfluxDB2:
                        #70
                        Stimmt überwiegend. Es findet sich auch auf den influxdb-Seiten entsprechendes.
                          Laser
                          #71
                          Das eigentliche Problem, der Adapter wird immer "gelb" Meldung "error" im log besteht aber immer noch.
                          Habe jetzt versucht, mit einem Script den Adapter zu restarten, wenn "error " im Log steht. Ob das nun elegant ist? Geht es auch einfacher? Das Bash- Script befindet sich in /opt und enthält nur den Befehl :
                          sudo iobroker restart vedirect.0
                          // Script zum Erkennen des "error" im Adapter vedirekt
                          onLog('vedirect' && 'error', data => {
                              var SSH = require('simple-ssh');
                          var ssh = new SSH({
                              host: '192.168.2.54',
                              user: 'name',
                              pass: 'passwort'
                              setState('javascript.0.Logik.ErrorVE'/*ErrorVE*/,1)
                              console.log('VE Err: ' + "1");
                                  // Adapter stoppen/starten (Beispiel):
                              ssh.exec("bash /opt/verestart.sh").start();
                          DJMarc75D Thomas BraunT 2 Antworten Letzte Antwort
                          • L Laser
                            var ssh = new SSH({
                                user: 'name',
                                pass: 'passwort'
                            DJMarc75D Offline
                            DJMarc75D Offline
                            DJMarc75
                            #72
                            Lehrling seit 1975 !!!
                            • DJMarc75D DJMarc75
                              Laser
                              #73
                              @djmarc75 also ohne das "zwischengeschaltete" shell-script . Hatte bei meinem ersten Versuch nicht geklappt, aber werde ich morgen früh gleich probieren!
                              • L Laser
                                var ssh = new SSH({
                                    user: 'name',
                                    pass: 'passwort'
                                #74
                                Hab ich behauptet das dein Problem damit aus der Welt sei?
                                Und ich werde vermutlich nie verstehen wo der Schwachsinn mit sudo iobroker herkommt.
                                Davon abgesehen gehören solche Skripte auch nicht nach /opt sondern in das Home des Users.
                                L lobomauL 2 Antworten Letzte Antwort
                                  Laser
                                  #75
                                  @thomas-braun Bleib ganz ruhig! Es ist doch kein Angriff auf Dich! Das Ganze ist mit der heißen Nadel gestrickt. Das Script schiebe ich in das home- Verzeichnis. Der Ordnung halber. "Sudo iobroker" braucht es eigentlich nicht. Darf nicht sein, ist besser. Passiert manchmal einfach. Für mich ist auschlaggebend, daß ich eine Lösung habe, die erst mal funktioniert. Ich hoffe ja, das Problem mit der USB Schnittstelle ist irgendwann einmal behoben. Dann verschwindet das Script in der Mülltonne. Mit dem "Sudo" in guter Gesellschaft.
                                  • L Laser
                                    #76
                                    @laser Hallo!?
                                    iobroker Befehle dürfen grundsätzlich ncht mit sudo eingeleitet werden Da kann das ganze Rechtegefüge wieder in die Knie gehen.
                                    und den ganzen restlichen Erguss kann ich überhaupt nicht sinnvoll zuordnen
                                    Du hast aber schon verstanden dass dein Dateisystem irgendwo etwas verloren hatte?
                                      @laser Hallo!?
                                      Laser
                                      #77
                                      @homoran Das mit dem Dateisystem habe ich zur Kenntnis genommen, aber nicht verstanden. Das mit dem Sudo schon. Der Rest ist zwischen Rasen Mähen und Feuerholz holen für den nächsten Winter entstanden. Weil der vedirekt Adapter immer wieder gestört war. Es geht jetzt. Der ganze Klimbim mit dem simple-ssh ist eingefügt, weil ich es auf die Schnelle nicht anders hinbekommen habe. Es funktioniert. Das ist entscheidend. Besser geht immer und immer wieder. Es werden ganze Industrie- Leitsysteme mit 10000 bekannten Fehlern verkauft. Sie tuen ihren Dienst und werden seit 20 Jahren nachgebessert. Von Riesen- Firmen.
                                      • L Laser
                                        #78
                                        ich kann mich nur wiederholen: liest du was du schreibst?
                                        • bei der automatischen Überprüfung wurden verwaiste (orphan), nicht mehr zuordbare, Dateifragmente gefunden die gelöscht wurden.
                                          • Die können überall fehlen.
                                        • du findest kein /dev/by-id mehr
                                        • du hast Meldungen zu USB im syslog
                                        • du hast Probleme mit deinem USB
                                        • du bekommst Fehlermeldungen dass falsche Wertetypen geschrieben werden, wenn angeblich weder ein Gerät angeschlossen ist, noch die Instanz läuft
                                        • du bekommst angeblich Meldungen der Logstufe Info nur im debug-Modus, nicht im Modus Info
                                        ich würde dem gesamten System nicht mehr vertrauen
                                          Laser
                                          #79
                                          @homoran dem ganzen System nicht mehr vertrauen. Das tue ich auch nicht. Also nochmal neu aufsetzen? Zum 25. Mal. Nicht, daß ich mich vor der Arbeit scheue. Irgend ein Problem ist bisher immer wieder aufgetaucht. Weil das ganze Linux/ IO-Broker Gestrick kein ausgereiftes System ist. Bastelkram eben. 100 Anleitungen. 99 davon veraltet. Das birgt einfach Gefahren. Auch bei der Neuinstallation.
