  3. Off Topic
  4. vedirekt Adapter Verbindungsproblem
    6.0k
140 Beiträge 7 Kommentatoren 20.8k Aufrufe 4 Beobachtet
  • L Laser
    @Thomas-Braun OK, werde neu anlegen. Muß nur noch die "richtige" Beschreibung finden. Nur das Repostery neu anlegen, nicht die Installationen löschen und neu machen?
    gefunden:
    wget -qO- https://repos.influxdata.com/influxdb.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdb.gpg > /dev/null
    export DISTRIB_ID=$(lsb_release -si); export DISTRIB_CODENAME=$(lsb_release -sc)
    echo "deb [signed-by=/etc/apt/trusted.gpg.d/influxdb.gpg] https://repos.influxdata.com/${DISTRIB_ID,,} ${DISTRIB_CODENAME} stable" | sudo tee /etc/apt/sources.list.d/influxdb.list > /dev/null
    sudo apt-get update && sudo apt-get install influxdb2
    otto@raspberrypiIO64:~ $ sudo apt-get update
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:5 https://repos.influxdata.com/debian stable InRelease
    Hit:6 https://deb.nodesource.com/node_18.x bullseye InRelease
    Get:7 https://repos.influxdata.com/debian bullseye InRelease [7,031 B]
    Hit:8 https://packages.grafana.com/enterprise/deb stable InRelease
    Err:7 https://repos.influxdata.com/debian bullseye InRelease
      The following signatures couldn't be verified because the public key is not available: NO_PUB                                               KEY D8FF8E1F7DF8B07E
    Reading package lists... Done
    W: GPG error: https://repos.influxdata.com/debian bullseye InRelease: The following signatures                                                couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    E: The repository 'https://repos.influxdata.com/debian bullseye InRelease' is not signed.
    N: Updating from such a repository can't be done securely, and is therefore disabled by default                                               .
    N: See apt-secure(8) manpage for repository creation and user configuration details.
    #66
    @laser
    Ist eigentlich was für einen anderen Threads. Ich sehe aber nicht, dass du die alte .list-Datei gelöscht hast.
    Hier steht mehr dazu drin:
    https://forum.iobroker.net/topic/62040/linux-debian-grafana-repo-muss-aktualisiert-werden
    L 1 Antwort Letzte Antwort
      @laser
      Laser
      schrieb am zuletzt editiert von Laser
      #67
      @thomas-braun die alte Datei habe ich mit Nano geöffnet und geleert. Reicht das nicht?
      Das Grafana Repo habe ich nach der Anleitung im Link neu angelegt. Influx wird immer noch angemeckert!
      • L Laser
        #68
        @laser sagte in vedirekt Adapter Verbindungsproblem:
        Reicht das nicht?
        Die muss gelöscht werden.
        Und die alten Keys auch.
          Reicht das nicht?
          Laser
          #69
          @thomas-braun Aussage:
          Das sicherste ist IMMER den Anleitungen direkt auf den Herstellerseiten zu folgen.
          Hier für InfluxDB2:
          Installation InfluxDB2für verschiedene Systeme
          Da steht alles mögliche, aber nicht wie man die alten Keys löscht. Werde weitersuchen...
          EDIT- jetzt scheint Alles OK zu sein. Keine Fehlermeldungen bei apt update.
          • L Laser
            Hier für InfluxDB2:
            #70
            Stimmt überwiegend. Es findet sich auch auf den influxdb-Seiten entsprechendes.
              Laser
              #71
              Das eigentliche Problem, der Adapter wird immer "gelb" Meldung "error" im log besteht aber immer noch.
              Habe jetzt versucht, mit einem Script den Adapter zu restarten, wenn "error " im Log steht. Ob das nun elegant ist? Geht es auch einfacher? Das Bash- Script befindet sich in /opt und enthält nur den Befehl :
              sudo iobroker restart vedirect.0
              // Script zum Erkennen des "error" im Adapter vedirekt
              onLog('vedirect' && 'error', data => {
                  var SSH = require('simple-ssh');
              var ssh = new SSH({
                  host: '192.168.2.54',
                  user: 'name',
                  pass: 'passwort'
                  setState('javascript.0.Logik.ErrorVE'/*ErrorVE*/,1)
                  console.log('VE Err: ' + "1");
                      // Adapter stoppen/starten (Beispiel):
                  ssh.exec("bash /opt/verestart.sh").start();
              DJMarc75D Thomas BraunT 2 Antworten Letzte Antwort
              • L Laser
                var ssh = new SSH({
                    user: 'name',
                    pass: 'passwort'
                DJMarc75D Offline
                DJMarc75D Offline
                DJMarc75
                #72
                Lehrling seit 1975 !!!
                • DJMarc75D DJMarc75
                  Laser
                  #73
                  @djmarc75 also ohne das "zwischengeschaltete" shell-script . Hatte bei meinem ersten Versuch nicht geklappt, aber werde ich morgen früh gleich probieren!
                  • L Laser
                    var ssh = new SSH({
                        user: 'name',
                        pass: 'passwort'
                    #74
                    Hab ich behauptet das dein Problem damit aus der Welt sei?
                    Und ich werde vermutlich nie verstehen wo der Schwachsinn mit sudo iobroker herkommt.
                    Davon abgesehen gehören solche Skripte auch nicht nach /opt sondern in das Home des Users.
                    L lobomauL 2 Antworten Letzte Antwort
                      Laser
                      #75
                      @thomas-braun Bleib ganz ruhig! Es ist doch kein Angriff auf Dich! Das Ganze ist mit der heißen Nadel gestrickt. Das Script schiebe ich in das home- Verzeichnis. Der Ordnung halber. "Sudo iobroker" braucht es eigentlich nicht. Darf nicht sein, ist besser. Passiert manchmal einfach. Für mich ist auschlaggebend, daß ich eine Lösung habe, die erst mal funktioniert. Ich hoffe ja, das Problem mit der USB Schnittstelle ist irgendwann einmal behoben. Dann verschwindet das Script in der Mülltonne. Mit dem "Sudo" in guter Gesellschaft.
                      • L Laser
                        #76
                        @laser Hallo!?
                        iobroker Befehle dürfen grundsätzlich ncht mit sudo eingeleitet werden Da kann das ganze Rechtegefüge wieder in die Knie gehen.
                        und den ganzen restlichen Erguss kann ich überhaupt nicht sinnvoll zuordnen
                        Du hast aber schon verstanden dass dein Dateisystem irgendwo etwas verloren hatte?
                          @laser Hallo!?
                          Laser
                          #77
                          @homoran Das mit dem Dateisystem habe ich zur Kenntnis genommen, aber nicht verstanden. Das mit dem Sudo schon. Der Rest ist zwischen Rasen Mähen und Feuerholz holen für den nächsten Winter entstanden. Weil der vedirekt Adapter immer wieder gestört war. Es geht jetzt. Der ganze Klimbim mit dem simple-ssh ist eingefügt, weil ich es auf die Schnelle nicht anders hinbekommen habe. Es funktioniert. Das ist entscheidend. Besser geht immer und immer wieder. Es werden ganze Industrie- Leitsysteme mit 10000 bekannten Fehlern verkauft. Sie tuen ihren Dienst und werden seit 20 Jahren nachgebessert. Von Riesen- Firmen.
                          • L Laser
                            #78
                            ich kann mich nur wiederholen: liest du was du schreibst?
                            • bei der automatischen Überprüfung wurden verwaiste (orphan), nicht mehr zuordbare, Dateifragmente gefunden die gelöscht wurden.
                              • Die können überall fehlen.
                            • du findest kein /dev/by-id mehr
                            • du hast Meldungen zu USB im syslog
                            • du hast Probleme mit deinem USB
                            • du bekommst Fehlermeldungen dass falsche Wertetypen geschrieben werden, wenn angeblich weder ein Gerät angeschlossen ist, noch die Instanz läuft
                            • du bekommst angeblich Meldungen der Logstufe Info nur im debug-Modus, nicht im Modus Info
                            ich würde dem gesamten System nicht mehr vertrauen
                              Laser
                              #79
                              @homoran dem ganzen System nicht mehr vertrauen. Das tue ich auch nicht. Also nochmal neu aufsetzen? Zum 25. Mal. Nicht, daß ich mich vor der Arbeit scheue. Irgend ein Problem ist bisher immer wieder aufgetaucht. Weil das ganze Linux/ IO-Broker Gestrick kein ausgereiftes System ist. Bastelkram eben. 100 Anleitungen. 99 davon veraltet. Das birgt einfach Gefahren. Auch bei der Neuinstallation.
                              • L Laser
                                #80
                                ich bin jetzt raus!
                                du bist nach 10 Jahren und bei 30.000 Usern der erste der das geschafft hat
                                  ich bin jetzt raus!
                                  Laser
                                  #81
                                  @homoran Ein System ist so gut, wie es dokumentiert ist. Und wer will behaupten, daß dieses System auch nur annähernd gut dokumentiert ist? Es ist ja kostenlos, wird immer wieder argumentiert. OK, aber man bezahlt es mit Lebenszeit. Es kann von niemanden als Einzelperson oder Gruppe erwartet werden, die ganzen alten, fehlerhaften Videos und Anleitungen zu entfernen. Das wäre aber enorm wichtig. Wenn jemand irgendwann etwas erstellt hat, was heute nicht mehr passt- raus mit dem Mist! Diese Arbeit macht sich einfach niemand. Der Misthaufen wird immer größer. Da durchzublicken, ist mir (anderen muß es nicht so gehen) nicht möglich.
                                  So, wie ein Raucher achtlos seinen Zigarettenstummel wegwirft, Plastikabfälle ins Meer geworfen werden, so werden Videos erstellt. Und bleiben für alle Ewigkeit.
                                  -2
                                  • L Laser
                                    #82
                                    Ja, und du bist offenbar der Ober-Bastler.
                                    Wenig Ahnung, viel Meinung.
                                    • L Laser
                                      DJMarc75D Offline
                                      DJMarc75D Offline
                                      DJMarc75
                                      #83
                                      Mit dieser Stimmungsmache wird es in Zukunft schwierig sein potentielle Hilfe zu erwarten.
                                        Laser
                                        #84
                                        @thomas-braun Ich behaupte auch nicht, der Oberschlaue zu sein. Deshalb stelle ich hier auch blöde Fragen! Ich bin nur ein gemeiner Anwender. Etwas mehr Organisation und Zusammenarbeit in der Dokumentation würde dem sicher riesigen Arbeitsaufwand, der in dem System steckt, sicher gut tun. Wer soll denn rausfinden, welcher Weg bei eine Installation der Richtige ist? OK, ich sehe mir ältere Beiträge nicht an, weil sie vermutlich nicht mehr gültig sind.
                                        Ich installiere gerade neu. Auf einem Weg mit 100 Abzweigungen.
                                        Ich rede jetzt nicht von der IOBroker Installation. Die ist durch das Script sehr vereinfacht. So gut wie Windows installieren! Der Rest (Datenbank) ist noch offen.
                                        Was gut geholfen hat: https://www.youtube.com/watch?v=abV4YRHXb5I
                                        • L Laser
                                          Laser
                                          #85
                                          @DJMarc75
                                          Mit "Misthaufen" meine ich nicht IOBroker und sein Forum, sondern das Internet incl. Youtube allgemein. Da werden Beiträge eingestellt, Videos veröffentlicht. Die Ersteller kümmern sich aber nicht um die Pflege Ihrer Beiträge. Durch die Unmengen an veralteten Beiträgen entsteht eben ein "Misthaufen". Das läßt sich auch nicht schönreden. Das wird immer unübersichtlicher. Da müßte auch mal etwas gelöscht werden. Vom Ersteller. Auch von angesehenen Leuten habe ich Beiträge geöffnet. Danach influx installiert. War aber absolut veraltet. Da kommt eben so etwas raus. Da kommt natürlich gleich der Einwurf: "man muß es eben richtig machen dann geht es auch". Toller Ratschlag!
