  4. Test Adapter OpenDTU
    2.4k
    4.4k
dtuhoymilesopendtusolar
457 Beiträge 47 Kommentatoren 165.0k Aufrufe 42 Beobachtet
  • FriedhofsblondF Friedhofsblond
    Hm, was sagt mir das Log?:
    2023-04-14 13:59:55.345 - debug: opendtu.0 (2001) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2023-04-14 13:59:55.366 - debug: opendtu.0 (2001) Objects client ready ... initialize now
    2023-04-14 13:59:55.368 - debug: opendtu.0 (2001) Objects create System PubSub Client
    2023-04-14 13:59:55.368 - debug: opendtu.0 (2001) Objects create User PubSub Client
    2023-04-14 13:59:55.378 - debug: opendtu.0 (2001) Objects client initialize lua scripts
    2023-04-14 13:59:55.382 - debug: opendtu.0 (2001) Objects connected to redis: 127.0.0.1:9001
    2023-04-14 13:59:55.394 - debug: opendtu.0 (2001) Redis States: Use Redis connection: 127.0.0.1:9000
    2023-04-14 13:59:55.399 - debug: opendtu.0 (2001) States create System PubSub Client
    2023-04-14 13:59:55.400 - debug: opendtu.0 (2001) States create User PubSub Client
    2023-04-14 13:59:55.406 - debug: opendtu.0 (2001) States connected to redis: 127.0.0.1:9000
    2023-04-14 13:59:55.470 - info: opendtu.0 (2001) starting. Version 0.1.4 (non-npm: o0shojo0o/ioBroker.opendtu#b92c7de2d0ab38296f6e1c401d63fbb7fad4829a) in /opt/iobroker/node_modules/iobroker.opendtu, node: v16.19.1, js-controller: 4.0.24
    2023-04-14 13:59:55.496 - error: opendtu.0 (2001) SyntaxError: The URL contains a fragment identifier
    2023-04-14 13:59:55.498 - error: opendtu.0 (2001) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2023-04-14 13:59:55.499 - error: opendtu.0 (2001) unhandled promise rejection: Cannot read properties of undefined (reading 'on')
    2023-04-14 13:59:55.501 - error: opendtu.0 (2001) TypeError: Cannot read properties of undefined (reading 'on')
    at Opendtu.startWebsocket (/opt/iobroker/node_modules/iobroker.opendtu/main.js:137:18)
    at Opendtu.onReady (/opt/iobroker/node_modules/iobroker.opendtu/main.js:46:14)
    at Opendtu.emit (node:events:513:28)
    at /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8232:26
    2023-04-14 13:59:55.501 - error: opendtu.0 (2001) Cannot read properties of undefined (reading 'on')
    2023-04-14 13:59:55.511 - info: opendtu.0 (2001) terminating
    2023-04-14 13:59:55.512 - warn: opendtu.0 (2001) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2023-04-14 13:59:56.068 - error: host.homeserv instance system.adapter.opendtu.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2023-04-14 13:59:56.069 - info: host.homeserv Restart adapter system.adapter.opendtu.0 because enabled
    2023-04-14 14:00:26.102 - info: host.homeserv instance system.adapter.opendtu.0 started with pid 2126
    2023-04-14 14:00:26.906 - debug: opendtu.0 (2126) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2023-04-14 14:00:26.939 - debug: opendtu.0 (2126) Objects client ready ... initialize now
    2023-04-14 14:00:26.940 - debug: opendtu.0 (2126) Objects create System PubSub Client
    2023-04-14 14:00:26.941 - debug: opendtu.0 (2126) Objects create User PubSub Client
    2023-04-14 14:00:26.950 - debug: opendtu.0 (2126) Objects client initialize lua scripts
    2023-04-14 14:00:26.954 - debug: opendtu.0 (2126) Objects connected to redis: 127.0.0.1:9001
    2023-04-14 14:00:26.964 - debug: opendtu.0 (2126) Redis States: Use Redis connection: 127.0.0.1:9000
    2023-04-14 14:00:26.968 - debug: opendtu.0 (2126) States create System PubSub Client
    2023-04-14 14:00:26.969 - debug: opendtu.0 (2126) States create User PubSub Client
    2023-04-14 14:00:26.974 - debug: opendtu.0 (2126) States connected to redis: 127.0.0.1:9000
    2023-04-14 14:00:27.023 - info: opendtu.0 (2126) starting. Version 0.1.4 (non-npm: o0shojo0o/ioBroker.opendtu#b92c7de2d0ab38296f6e1c401d63fbb7fad4829a) in /opt/iobroker/node_modules/iobroker.opendtu, node: v16.19.1, js-controller: 4.0.24
    2023-04-14 14:00:27.048 - error: opendtu.0 (2126) SyntaxError: The URL contains a fragment identifier
    2023-04-14 14:00:27.050 - error: opendtu.0 (2126) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2023-04-14 14:00:27.050 - error: opendtu.0 (2126) unhandled promise rejection: Cannot read properties of undefined (reading 'on')
    2023-04-14 14:00:27.053 - error: opendtu.0 (2126) TypeError: Cannot read properties of undefined (reading 'on')
    2023-04-14 14:00:27.053 - error: opendtu.0 (2126) Cannot read properties of undefined (reading 'on')
    2023-04-14 14:00:27.063 - info: opendtu.0 (2126) terminating
    2023-04-14 14:00:27.064 - warn: opendtu.0 (2126) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2023-04-14 14:00:27.619 - error: host.homeserv instance system.adapter.opendtu.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2023-04-14 14:00:27.620 - info: host.homeserv Restart adapter system.adapter.opendtu.0 because enabled
    crunchipC Offline
    crunchipC Offline
    #121
    @friedhofsblond auch das beachtet?
    Es wir die Version von 15.02.2023 oder neuer benötigt!
    FriedhofsblondF 1 Antwort Letzte Antwort
      FriedhofsblondF Offline
      Friedhofsblond
      #122
      @crunchip
      hm, sorry was meinst du jetzt?
      IdleBitI 1 Antwort Letzte Antwort
        @crunchip
        IdleBitI Offline
        IdleBitI Offline
        IdleBit
        #123
        @friedhofsblond Zeig mal deine Einstellungen vom Adapter, sieht so aus ob da was faul ist.
        • FriedhofsblondF Offline
          Friedhofsblond
          #124
          @idlebit
            @idlebit
            IdleBitI Offline
            IdleBitI Offline
            IdleBit
            #125
            @friedhofsblond kann es sein das sich Leerzeichen eingeschlichen haben?
            Also bei der IP z.B.
            • IdleBitI IdleBit
              Friedhofsblond
              schrieb am zuletzt editiert von Friedhofsblond
              #126
              @idlebit
              hm,
              nö habe die instanz nochmal gelöscht und eine neue erzeugt.
              Dann alles händisch sauber eingetragen - kein Erfolg.
              Kein Port hinter der IP:
                @idlebit
                hm,
                IdleBitI Offline
                IdleBitI Offline
                IdleBit
                schrieb am zuletzt editiert von IdleBit
                #127
                @friedhofsblond Port 80 ist default bei HTTP und wird daher nicht dargestellt.
                Muss Du bitte eine vollen Logmitschnitt mal posten von start bis zum Ende.
                Kann mir das aber erst später ansehen, habe jetzt erstmal andere Verpflichtungen.
                • IdleBitI IdleBit
                  Friedhofsblond
                  #128
                  @idlebit
                  Jo alles klar - kein Druck :D
                    @idlebit
                    Friedhofsblond
                    #129
                    so habs gefunden.
                    Es lag am Passwort - keine Sonderzeichen !! bei mir "#" :(
                      so habs gefunden.
                      IdleBitI Offline
                      IdleBitI Offline
                      IdleBit
                      #130
                      @friedhofsblond Mal mal bitte auf GitHub ein Issues dafür auf. Werde mir das dann ansehen.
                      • I Offline
                        I Offline
                        indie
                        schrieb am zuletzt editiert von indie
                        #131
                        Hallo zusammen, ich hab ein Problem mit dem Adapter und sowohl die neueste Firmware von opendtu geflasht, als auch das passende node.js drauf und die aktuelle Adapter Installation drauf. Das Problem trat auch mit einer älteren Firmware Version von opendtu schon auf, ich hatte gehofft, dass es mit der neuen Version gelöst wäre, aber nach ca 18 Stunden Betrieb ging das ganze schon wieder los: nach einer Weile ganz normalem Betriebs wird im Adapter eine unhandled exception geworfen und der Adapter Gerät dann in eine "restart loop", sodass iobroker den Adapter killt, nachdem 4-5 Mal in 1,5 min neu gestartet wurde.
                        Das logfile zu dem Fehler im Adapter in iobroker ist folgendes (nur eine "Fehlerinstanz", diese tritt dann mehrfach nacheinander auf). 2 hinweise noch zur Fehler Eingrenzung:
                        1. Mqtt ist in opendtu aus, zufriff läuft über http.
                        2. Im Kontext des Fehlers verändern sich die Namen der 2 verbundenen wechselrichter in der Webansicht und enthalten plötzlich seltsame Sonderzeichen oder werden komplett durch solche ersetzt.
                        Ein Ansatz könnte sein, dass es einen overflow beim opendtu gibt, der zb durch nicht geschlossene web connections Auftritt und durch den Adapter ausgelöst wird?
                        Würde mich sehr freuen, wenn ich einen Tipp von euch bekomme oder mit der Fehlerbeschreibung die Weiterentwicklung des Adapters unterstützten kann :-)
                        Vielen Dank!
                        Edit: hab es auch auf GitHub als issue geöffnet
                        2023-04-18 12:56:52.639 error The id is empty! Please provide a valid id.
                        opendtu.0
                        2023-04-18 12:56:52.638 error Error: The id is empty! Please provide a valid id. at Utils.validateId (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/utils.js:114:19) at Opendtu.extendObject (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1935:23) at /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2126:16 at new Promise (<anonymous>) at Opendtu.extendObjectAsync (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2125:16) at DataController.processInverterData (/opt/iobroker/node_modules/iobroker.opendtu/lib/dataController.js:23:36) at Opendtu.processMessage (/opt/iobroker/node_modules/iobroker.opendtu/main.js:163:28) at WebSocket.<anonymous> (/opt/iobroker/node_modules/iobroker.opendtu/main.js:142:18) at WebSocket.emit (node:events:525:35) at Receiver.receiverOnMessage (/opt/iobroker/node_modules/ws/lib/websocket.js:1184:20)
                        opendtu.0
                        2023-04-18 12:56:52.634 error unhandled promise rejection: The id is empty! Please provide a valid id.
                        opendtu.0
                        2023-04-18 12:56:52.616 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        • I indie
                          Vielen Dank!
                          opendtu.0
                          opendtu.0
                          opendtu.0
                          #132
                          @indie
                          Wie hast du die beiden denn benannt? Versuch mal Umlaute oder ggf. sonstige 'Sonderzeichen' zu vermeiden.
                          Irgendwas ist da wohl nicht eingetragen. Hast du für die Panele auch schöne Namen vergeben?
                            @indie
                            I Offline
                            I Offline
                            indie
                            #133
                            @thomas-braun eigentlich ja, "Garagendach" und "Balkon". Hier sollte eigentlich das Problem nicht liegen 🤔... Ah ja und die panele (also strings der Wechselrichter) habe ich nicht umbenannt (also weiterhin "string 1" und "2").
                            • I indie
                              #134
                              @indie Die meinte ich. Trag da mal just for fun irgendwas simples ein.
                              Dick & Doof, Bonny & Clyde, Tom & Jerry oder sowas. ;-)
                                I Offline
                                I Offline
                                indie
                                #135
                                @thomas-braun okay, ich mache alles, was helfen kann, auch wenn ich nicht sehe, wie das helfen kann...(klar, es steht jetzt etwas an einer Stelle, wo vorher nichts stand, das war aber btw vor dem Firmware Update inkl. Reflash anders, da hatte ich jeweils einen Namen für die Strings). Mal sehen ...evtl kann man aus dem langen logeintrag ja rauslesen, wo genau der Fehler Auftritt, aber mir fehlt da der konkrete Einblick in den Code (bzw die Fähigkeit dazu)
                                • I indie
                                  I Offline
                                  I Offline
                                  indie
                                  #136
                                  Kurzes Update: nachdem ich in der dtu das refresh interval von 2s auf 5s gesetzt habe und jeder String einen Namen bekommen hat, tritt das Problem seit 30h schon nicht mehr auf. Ich gehe also davon aus, dass die dtu tatsächlich mit der Last überfordert war und der Fehler im Adapter durch fehlerhafte Übertragung von der dtu ausgelöst wurde. Ich entschuldige mich für die falsche Verdächtigung des Adapters und habe auch auf GitHub das issue geschlossen :-). Danke für die Hilfe!
                                  L I crunchipC 3 Antworten Letzte Antwort
                                  • I indie
                                    lars72
                                    #137
                                    Hallo, ich habe eine dumme Anfängerfrage:
                                    Wo und wie installiere ich den Adapter OpenDTU? Habe den Raspberry erst seit gestern und ich weiß, dass ich nicht viel weiss ;-)
                                    Ich brauche da eine genaue Befehlsanleitung für die Konsole / Eingabeaufforderung.
                                    Vielen Dank schon mal,
                                    Lars
                                    • L lars72
                                      Lars
                                      #138
                                      @lars72
                                      Es muss der Experten-Modus aktiviert sein.
                                      L 1 Antwort Letzte Antwort
                                        @lars72
                                        lars72
                                        #139
                                        Vielen Dank! Hat geklappt.
                                        • I indie
                                          I Offline
                                          I Offline
                                          indie
                                          #140
                                          @indie Leider war ich zu voreilig. Das Problem tritt weiterhin auf. Problem tritt immer im Zusammenhang mit dem Event auf, dass fast sekündlich neue Websockets eröffnet werden. Was das auslösende Moment ist, weiß ich nicht. Ich google mir aktuell mal was zusammen (auch im openDTU Projekt selbst, natürlich). Ich versuche mal, den Wifi Kanal 2.4GHz bei meiner Fritzbox fest zu setzen, da wurden immer mal wieder Wifi Probleme mit berichtet (hab ich eigentlich nicht, könnte aber vllt die x-fache Neueröffnung von WebSockets auslösen?!?).
                                          Eine Frage wäre, in welchem Intervall vom openDTU Adapter die Web API der openDTU aufgerufen wird? Kann man das konfigurieren?
