  3. Off Topic
  4. Grafana
  5. Grafana / InfluxDB / VIS
    6.8k
Geplant Angeheftet Gesperrt Verschoben Grafana
91 Beiträge 8 Kommentatoren 11.6k Aufrufe 6 Beobachtet
  • DJMarc75D DJMarc75
    @kimukao sagte in Grafana / InfluxDB / VIS:
    systemctl status grafana-server.service
    zeigt was?
    kimukao
    #61
    @djmarc75 said in Grafana / InfluxDB / VIS:
    zeigt was?
    ● grafana-server.service - Grafana instance
         Loaded: error (Reason: Unit grafana-server.service failed to load properly: Device >
         Active: active (running) since Fri 2022-07-01 15:45:07 CEST; 5h 7min ago
           Docs: http://docs.grafana.org
       Main PID: 17903 (grafana-server)
            CPU: 21.510s
         CGroup: /system.slice/grafana-server.service
                 └─17903 /usr/sbin/grafana-server --config=/etc/grafana/grafana.ini --pidfil>
    Jul 01 20:48:36 raspberrypi grafana-server[17903]: t=2022-07-01T20:48:36+0200 lvl=info m>
    Jul 01 20:48:48 raspberrypi grafana-server[17903]: t=2022-07-01T20:48:48+0200 lvl=info m>
    Jul 01 20:49:25 raspberrypi grafana-server[17903]: t=2022-07-01T20:49:25+0200 lvl=info m>
    Jul 01 20:49:37 raspberrypi grafana-server[17903]: t=2022-07-01T20:49:37+0200 lvl=info m>
    Jul 01 20:50:15 raspberrypi grafana-server[17903]: t=2022-07-01T20:50:15+0200 lvl=info m>
    Jul 01 20:50:26 raspberrypi grafana-server[17903]: t=2022-07-01T20:50:26+0200 lvl=info m>
    Jul 01 20:51:04 raspberrypi grafana-server[17903]: t=2022-07-01T20:51:04+0200 lvl=info m>
    Jul 01 20:51:16 raspberrypi grafana-server[17903]: t=2022-07-01T20:51:16+0200 lvl=info m>
    Jul 01 20:51:53 raspberrypi grafana-server[17903]: t=2022-07-01T20:51:53+0200 lvl=info m>
    Jul 01 20:52:05 raspberrypi grafana-server[17903]: t=2022-07-01T20:52:05+0200 lvl=info m>
    lines 1-19/19 (END)
    • K kimukao
      zeigt was?
              CPU: 21.510s
      lines 1-19/19 (END)
      DJMarc75D Offline
      DJMarc75D Offline
      DJMarc75
      #62
      @kimukao hmpf.
      Hast Du Dein System schonmal rebootet?
      Lehrling seit 1975 !!!
      K 1 Antwort Letzte Antwort
        @kimukao hmpf.
        kimukao
        #63
        @djmarc75 Gestern. Seitdem hab ich ja die Probleme. Vorher lief's.
        • K kimukao
          DJMarc75D Offline
          DJMarc75D Offline
          DJMarc75
          #64
          Gestern
          Na dann mach doch einfach nochmal, schadet ja nicht.
          • GlasfaserG Offline
            GlasfaserG Offline
            Glasfaser
            #65
            @DJMarc75
            müßte da nicht die Uhrzeit vom neustart drin stehen !?
            • GlasfaserG Glasfaser
              @DJMarc75
              DJMarc75D Offline
              DJMarc75D Offline
              DJMarc75
              #66
              @glasfaser sagte in Grafana / InfluxDB / VIS:
              gekonnt überlesen, aber eigentlich schon 🙄
              Scheint vieles geheim zu sein 😁
              GlasfaserG K 2 Antworten Letzte Antwort
                GlasfaserG Offline
                GlasfaserG Offline
                Glasfaser
                #67
                @djmarc75
                mal sehen , was der reboot bringt
                ich denke mal das wars ....
                  @djmarc75
                  kimukao
                  #68
                  @glasfaser said in Grafana / InfluxDB / VIS:
                  Leider nein..
                    kimukao
                    #69
                    Wahrscheinlich, weil ich kurz vorher die ini Datei angepasst und neu gespeichert hatte?
                    • K kimukao
                      GlasfaserG Offline
                      GlasfaserG Offline
                      Glasfaser
                      #70
                      @kimukao
                      dann stimmt deine Systemuhrzeit nicht ..... die Änderung war doch erst vorhin
                        @kimukao
                        kimukao
                        #71
                        nach der Zeit kann ich später noch schauen. Jetzt hätte ich gerne erstmal wieder meine VIS am Laufen
                        DJMarc75D Thomas BraunT 2 Antworten Letzte Antwort
                        • K kimukao
                          DJMarc75D Offline
                          DJMarc75D Offline
                          DJMarc75
                          #72
                          Nicht Dein ernst jetzt ??!!
                          Systemzeit ist WICHTIG !
                          Aber bevor ich mir jetzt die ganzen Posts durchlese und wahrscheinlich eh nix finde: Auf welchem System läuft denn das Ganze?
                            kimukao
                            #73
                            Raspberry Pi 4 mit 4GB RAM, Sandisk 32GB SD Karte, LAN Anschluss, Deconz Conbee2 Stick
                            Iobroker und Grafana auf demselben pi
                            • K kimukao
                              DJMarc75D Offline
                              DJMarc75D Offline
                              DJMarc75
                              #74
                              influx hoffentlich auch 😀
                                kimukao
                                #75
                                klar
                                K DJMarc75D 2 Antworten Letzte Antwort
                                • K kimukao
                                  klar
                                  kimukao
                                  #76
                                  Was haltet Ihr denn davon?
                                  grafana-server start
                                  Grafana-server Init Failed: Could not find config defaults, make sure homepath command line parameter is set or working directory is homepath
                                  • K kimukao
                                    #77
                                    Korrekte Zeit ist keine Kosmetik. Gerade bei Server/Netzwerkgeschichten ist das unerlässlich.
                                    • K kimukao
                                      na klar, die grafana.ini anpassen
                                      sudo nano /etc/grafana/grafana.ini
                                      und dann folgendes quasi aktivieren (so solls dann aussehen)
                                      [security]
                                      allow_embedding = true
                                      [auth.anonymous]
                                      enabled = true
                                      org_name = Main Org.
                                      org_role = Viewer
                                      [users]
                                      allow_sign_up = false
                                      musst halt viel scrollen und dann natürlich abspeichern und den grafana-dienst neu starten
                                      Mega. Danke. Hab alle Änderungen vorgenommen und ini Datei gespeichert. Tatsächlich entsprach das wohl alles nicht mehr der ursprünglichen Konfiguration. Warum kann ich mir nicht erklären. Habe Grafana nicht neu aufgesetzt. Wenn ich versuche, Grafana mit dem Befehl
                                      sudo service grafana-server restart
                                      neu zu starten kommt
                                      Failed to restart grafana-server.service: Unit grafana-server.service failed to load properly: Device or resource busy.
                                      See system logs and 'systemctl status grafana-server.service' for details.
                                      In der VIS werden die Diagramme auch noch nicht angezeigt (trotz Cache leeren).
                                      crunchipC Offline
                                      crunchipC Offline
                                      #78
                                      aber doch nicht 1:1, oder?
                                      der org name muss ersetzt werden mit deinem vergebenen
                                        GlasfaserG Offline
                                        Glasfaser
                                        #79
                                        @kimukao
                                        ini Datei defekt , durch deine Änderung !
                                        • K kimukao
                                          klar
                                          DJMarc75D Offline
                                          DJMarc75D Offline
                                          DJMarc75
                                          #80
                                          @kimukao
                                          Hast Du vorhin auch wirklich nur die Änderungen in der grafana.ini vorgenommen, welche ich Dir geschrieben habe? Weil diese Fehlermeldung von oben ist mir absolut unbekannt. Und jetzt auch schonmal probiert den direkten Link zum Dashboard/Panel in Safari eingegeben ?
