  3. Off Topic
  4. Grafana
  5. Grafana / InfluxDB / VIS
    6.8k
Geplant Angeheftet Gesperrt Verschoben Grafana
91 Beiträge 8 Kommentatoren 11.6k Aufrufe 6 Beobachtet
  • K kimukao
    @djmarc75 said in Grafana / InfluxDB / VIS:
    systemctl status grafana-server.service
    zeigt was?
    ● grafana-server.service - Grafana instance
         Loaded: error (Reason: Unit grafana-server.service failed to load properly: Device >
         Active: active (running) since Fri 2022-07-01 15:45:07 CEST; 5h 7min ago
           Docs: http://docs.grafana.org
       Main PID: 17903 (grafana-server)
            CPU: 21.510s
         CGroup: /system.slice/grafana-server.service
                 └─17903 /usr/sbin/grafana-server --config=/etc/grafana/grafana.ini --pidfil>
    Jul 01 20:48:36 raspberrypi grafana-server[17903]: t=2022-07-01T20:48:36+0200 lvl=info m>
    Jul 01 20:48:48 raspberrypi grafana-server[17903]: t=2022-07-01T20:48:48+0200 lvl=info m>
    Jul 01 20:49:25 raspberrypi grafana-server[17903]: t=2022-07-01T20:49:25+0200 lvl=info m>
    Jul 01 20:49:37 raspberrypi grafana-server[17903]: t=2022-07-01T20:49:37+0200 lvl=info m>
    Jul 01 20:50:15 raspberrypi grafana-server[17903]: t=2022-07-01T20:50:15+0200 lvl=info m>
    Jul 01 20:50:26 raspberrypi grafana-server[17903]: t=2022-07-01T20:50:26+0200 lvl=info m>
    Jul 01 20:51:04 raspberrypi grafana-server[17903]: t=2022-07-01T20:51:04+0200 lvl=info m>
    Jul 01 20:51:16 raspberrypi grafana-server[17903]: t=2022-07-01T20:51:16+0200 lvl=info m>
    Jul 01 20:51:53 raspberrypi grafana-server[17903]: t=2022-07-01T20:51:53+0200 lvl=info m>
    Jul 01 20:52:05 raspberrypi grafana-server[17903]: t=2022-07-01T20:52:05+0200 lvl=info m>
    lines 1-19/19 (END)
    DJMarc75D Offline
    DJMarc75D Offline
    DJMarc75
    @kimukao hmpf.
    Hast Du Dein System schonmal rebootet?
    Lehrling seit 1975 !!!
    • DJMarc75D DJMarc75
      @kimukao hmpf.
      kimukao
      @djmarc75 Gestern. Seitdem hab ich ja die Probleme. Vorher lief's.
      • K kimukao
        DJMarc75D Offline
        DJMarc75D Offline
        DJMarc75
        @kimukao sagte in Grafana / InfluxDB / VIS:
        Gestern
        Na dann mach doch einfach nochmal, schadet ja nicht.
        • GlasfaserG Offline
          GlasfaserG Offline
          @DJMarc75
          müßte da nicht die Uhrzeit vom neustart drin stehen !?
          • GlasfaserG Glasfaser
            @DJMarc75
            DJMarc75D Offline
            DJMarc75D Offline
            DJMarc75
            #66
            @glasfaser sagte in Grafana / InfluxDB / VIS:
            gekonnt überlesen, aber eigentlich schon 🙄
            Scheint vieles geheim zu sein 😁
            GlasfaserG K 2 Antworten Letzte Antwort
              GlasfaserG Offline
              GlasfaserG Offline
              #67
              @djmarc75
              mal sehen , was der reboot bringt
              ich denke mal das wars ....
                @djmarc75
                kimukao
                #68
                @glasfaser said in Grafana / InfluxDB / VIS:
                Leider nein..
                  kimukao
                  #69
                  Wahrscheinlich, weil ich kurz vorher die ini Datei angepasst und neu gespeichert hatte?
                  • K kimukao
                    GlasfaserG Offline
                    GlasfaserG Offline
                    #70
                    @kimukao
                    dann stimmt deine Systemuhrzeit nicht ..... die Änderung war doch erst vorhin
                      @kimukao
                      kimukao
                      #71
                      nach der Zeit kann ich später noch schauen. Jetzt hätte ich gerne erstmal wieder meine VIS am Laufen
                      DJMarc75D Thomas BraunT 2 Antworten Letzte Antwort
                      • K kimukao
                        DJMarc75D Offline
                        DJMarc75D Offline
                        DJMarc75
                        #72
                        Nicht Dein ernst jetzt ??!!
                        Systemzeit ist WICHTIG !
                        Aber bevor ich mir jetzt die ganzen Posts durchlese und wahrscheinlich eh nix finde: Auf welchem System läuft denn das Ganze?
                          kimukao
                          #73
                          Raspberry Pi 4 mit 4GB RAM, Sandisk 32GB SD Karte, LAN Anschluss, Deconz Conbee2 Stick
                          Iobroker und Grafana auf demselben pi
                          • K kimukao
                            DJMarc75D Offline
                            DJMarc75D Offline
                            DJMarc75
                            #74
                            influx hoffentlich auch 😀
                              kimukao
                              #75
                              klar
                              K DJMarc75D 2 Antworten Letzte Antwort
                              • K kimukao
                                klar
                                kimukao
                                #76
                                Was haltet Ihr denn davon?
                                grafana-server start
                                Grafana-server Init Failed: Could not find config defaults, make sure homepath command line parameter is set or working directory is homepath
                                • K kimukao
                                  #77
                                  Korrekte Zeit ist keine Kosmetik. Gerade bei Server/Netzwerkgeschichten ist das unerlässlich.
                                  • K kimukao
                                    na klar, die grafana.ini anpassen
                                    sudo nano /etc/grafana/grafana.ini
                                    und dann folgendes quasi aktivieren (so solls dann aussehen)
                                    [security]
                                    allow_embedding = true
                                    [auth.anonymous]
                                    enabled = true
                                    org_name = Main Org.
                                    org_role = Viewer
                                    [users]
                                    allow_sign_up = false
                                    musst halt viel scrollen und dann natürlich abspeichern und den grafana-dienst neu starten
                                    Mega. Danke. Hab alle Änderungen vorgenommen und ini Datei gespeichert. Tatsächlich entsprach das wohl alles nicht mehr der ursprünglichen Konfiguration. Warum kann ich mir nicht erklären. Habe Grafana nicht neu aufgesetzt. Wenn ich versuche, Grafana mit dem Befehl
                                    sudo service grafana-server restart
                                    neu zu starten kommt
                                    Failed to restart grafana-server.service: Unit grafana-server.service failed to load properly: Device or resource busy.
                                    See system logs and 'systemctl status grafana-server.service' for details.
                                    In der VIS werden die Diagramme auch noch nicht angezeigt (trotz Cache leeren).
                                    crunchipC Offline
                                    crunchipC Offline
                                    #78
                                    aber doch nicht 1:1, oder?
                                    der org name muss ersetzt werden mit deinem vergebenen
                                      GlasfaserG Offline
                                      #79
                                      @kimukao
                                      ini Datei defekt , durch deine Änderung !
                                      • K kimukao
                                        klar
                                        DJMarc75D Offline
                                        DJMarc75D Offline
                                        DJMarc75
                                        #80
                                        @kimukao
                                        Hast Du vorhin auch wirklich nur die Änderungen in der grafana.ini vorgenommen, welche ich Dir geschrieben habe? Weil diese Fehlermeldung von oben ist mir absolut unbekannt. Und jetzt auch schonmal probiert den direkten Link zum Dashboard/Panel in Safari eingegeben ?
                                          DJMarc75D Offline
                                          DJMarc75D Offline
                                          DJMarc75
                                          #81
                                          @crunchip sagte in Grafana / InfluxDB / VIS:
                                          Ja, dachte eigentlich er kennt sich ein wenig aus.
