  3. Off Topic
  4. Grafana
  5. Fritzbox mit Grafana visualisieren [Version 2022]
    6.7k
Geplant Angeheftet Gesperrt Verschoben Grafana
144 Beiträge 12 Kommentatoren 35.3k Aufrufe 16 Beobachtet
  • Damrak2022D Damrak2022
    @thomas-braun Jetzt scheint es zu gehen,, sind aber noch viele errors drin:
    (.venv) pi@homebridge:/opt/fritzinfluxdb $ ./fritzinfluxdb.py
    2022-04-23 00:14:07,252 - INFO: Done parsing config file
    2022-04-23 00:14:07,265 - INFO: Database <db> not found, trying to create it
    2022-04-23 00:14:07,276 - INFO: Connection to InfluxDB established and database present
    2022-04-23 00:14:08,899 - INFO: Successfully connected to FritzBox
    2022-04-23 00:14:08,900 - INFO: Starting main loop
    2022-04-23 00:14:09,201 - ERROR: Requested invalid action 'GetInfo' for service: WANDSLInterfaceConfig
    2022-04-23 00:14:09,212 - ERROR: Requested invalid action 'GetStatisticsTotal' for service: WANDSLInterfaceConfig
    2022-04-23 00:14:09,313 - ERROR: Requested invalid action 'GetInfo' for service: WANPPPConnection:1
    2022-04-23 00:14:09,314 - ERROR: Encountered problems while requesting data. Data might be incomplete.
    2022-04-23 00:14:18,832 - ERROR: Requested invalid action 'GetInfo' for service: WANDSLInterfaceConfig
    2022-04-23 00:14:18,844 - ERROR: Requested invalid action 'GetStatisticsTotal' for service: WANDSLInterfaceConfig
    2022-04-23 00:14:18,943 - ERROR: Requested invalid action 'GetInfo' for service: WANPPPConnection:1
    2022-04-23 00:14:18,943 - ERROR: Encountered problems while requesting data. Data might be incomplete.
    2022-04-23 00:14:28,634 - ERROR: Requested invalid action 'GetInfo' for service: WANDSLInterfaceConfig
    2022-04-23 00:14:28,679 - ERROR: Requested invalid action 'GetStatisticsTotal' for service: WANDSLInterfaceConfig
    2022-04-23 00:14:28,777 - ERROR: Requested invalid action 'GetInfo' for service: WANPPPConnection:1
    2022-04-23 00:14:28,777 - ERROR: Encountered problems while requesting data. Data might be incomplete.
    Ich habe in der .ini noch keinen Datenbanknamen vergeben.
    #121
    @damrak2022 sagte in Fritzbox mit Grafana visualisieren [Version 2022]:
    Ich denke da muss jetzt der user und dessen Passwort auf der Fritzbox angegeben werden. Sonst kann der Kram nicht von dort ausgelesen werden.
      Damrak2022D Offline
      Damrak2022D Offline
      Damrak2022
      schrieb am zuletzt editiert von Damrak2022
      #122
      @thomas-braun Der ist drin. Ich schaue mal was ich noch hinbekomme. Ansonsten frage ich heute nochmal bei Dir ich.
      Bis dann und Danke
      Mit besten Grüßen
      Andy
        Bis dann und Danke
        #123
        @damrak2022
        Ist das ein Kabelanschluss?
        WANDSLInterfaceConfig hört sich nach DSL an. Das dürfte auf einer FritzCable-Box nicht vorhanden sein.
          @damrak2022
          Damrak2022D Offline
          Damrak2022D Offline
          Damrak2022
          #124
          @thomas-braun Jepp, da gibt es auch schon einiges bei Github, weil die Anleitung sich wohl mehr auf eine DSL Box bezieht, aber viele eine 6591 Cable, so wie ich haben.
          Ich habe da auch schon gepostet und hoffe, das sich irgendwann auch eine Cable Box vollständig abfragen lässt. Jetzt werde ich mal versuchen das Grafana Dashboard zu realisieren.
          Mit besten Grüßen
          Andy
            #125
            @damrak2022 said in Fritzbox mit Grafana visualisieren [Version 2022]:
            2022-04-23 00:14:07,265 - INFO: Database <db> not found, trying to create it 2022-04-23 00:14:07,276 - INFO: Connection to InfluxDB established and database present
            doch Du hattest den Standard in der "fritzinfluxdb.ini", daher heißt Deine Datenbank in "influxdb" jetzt "db".
            VG
            Bernd
              VG
              Bernd
              Damrak2022D Offline
              Damrak2022D Offline
              Damrak2022
              #126
              @dp20eic Ich danke Dir, das klappt jetzt glücklicherweise alles
              Mit besten Grüßen
              Andy
              Rene RR 1 Antwort Letzte Antwort
                Rene RR Offline
                Rene RR Offline
                Rene R
                schrieb am zuletzt editiert von Rene R
                #127
                @damrak2022
                Kannst du mir vielleicht helfen ich bekomme es nicht am laufen was hast du bei dir in der .ini alles drin???
                Habe ne fritzbox 6490
                So läuft aber bekomme keine daten..
                (.venv) pi@raspberrypi:/opt/fritzinfluxdb $ python3 ./fritzinfluxdb.py
                2022-09-02 23:07:51,955 - INFO: Starting fritzinfluxdb v1.0.1 (2022-08-22)
                2022-09-02 23:07:51,957 - INFO: Done reading config files
                2022-09-02 23:07:52,011 - INFO: Successfully parsed config
                2022-09-02 23:07:52,024 - INFO: Connection to InfluxDB 1.8.10 established and database present
                2022-09-02 23:07:53,656 - INFO: Successfully established FritzBox TR-069 session
                2022-09-02 23:07:54,735 - INFO: Successfully established FritzBox Lua session
                2022-09-02 23:07:54,735 - INFO: Successfully connected to FritzBox '192.168.178.1' (fritzbox) Model: FRITZ!Box 6490 Cable - FW: 7.29
                2022-09-02 23:07:54,741 - INFO: Starting main loop
                2022-09-02 23:07:55,460 - INFO: Requested invalid action 'GetInfo' for service: WANDSLInterfaceConfig
                2022-09-02 23:07:55,460 - INFO: Querying action 'GetInfo' will be disabled
                2022-09-02 23:07:55,474 - INFO: Requested invalid action 'GetStatisticsTotal' for service: WANDSLInterfaceConfig
                2022-09-02 23:07:55,475 - INFO: Querying action 'GetStatisticsTotal' will be disabled
                2022-09-02 23:07:55,488 - INFO: Requested invalid action 'X_AVM-DE_GetDSLInfo' for service: WANDSLInterfaceConfig
                2022-09-02 23:07:55,488 - INFO: Querying action 'X_AVM-DE_GetDSLInfo' will be disabled
                2022-09-02 23:07:55,488 - INFO: All actions for service 'WANDSLInterfaceConfig' are unavailable. Disabling service.
                2022-09-02 23:07:55,544 - INFO: Requested invalid action 'GetInfo' for service: WANPPPConnection:1
                2022-09-02 23:07:55,544 - INFO: Querying action 'GetInfo' will be disabled
                2022-09-02 23:07:55,545 - INFO: All actions for service 'WANPPPConnection:1' are unavailable. Disabling service.
                2022-09-02 23:08:19,603 - INFO: Unable to request FritzBox Lua service 'DSL Info'
                2022-09-02 23:08:19,603 - INFO: FritzBox Lua service 'DSL Info' will be disabled.
                Rene
                  Wieso nicht installiert?
                  was kommt wenn du es so probierst?
                  sudo apt-get remove --auto-remove grafana
                  bzw zeig mal zuvor die Ausgabe von
                  apt policy grafana
                  frampF Offline
                  frampF Offline
                  framp
                  schrieb am zuletzt editiert von framp
                  #128
                  Unhandled python exception in init callback: OSError: fritzcollectd: Failed to connect to fritz.box", was mir sagt das mein FritzOS wohl zu neu ist.
                  Ich hatte das Problem auch. Allerdings liegt es nicht an einer zu neuen FB sondern daran, dass der Connect etwas laenger dauert und fritzcollectd keinen Connect Retry hat. Den habe ich eingebaut und schon ist die Fehlermeldung weg :-). Der Fix steht ich hier in meinem Fork zur allgemeinen Verfuegung.
                  Jan 28 23:53:22 raspberrypi-bullseye-docker-64 collectd[547]: fritzcollectd: Connecting to FRITZ Box ...
                  Jan 28 23:53:22 raspberrypi-bullseye-docker-64 collectd[547]: fritzcollectd: Retrying in 3 seconds ...
                  Jan 28 23:53:25 raspberrypi-bullseye-docker-64 collectd[547]: fritzcollectd: Connecting to FRITZ Box ...
                  Jan 28 23:53:25 raspberrypi-bullseye-docker-64 collectd[547]: fritzcollectd: Retrying in 3 seconds ...
                  Jan 28 23:53:28 raspberrypi-bullseye-docker-64 collectd[547]: fritzcollectd: Connecting to FRITZ Box ...
                  Jan 28 23:53:33 raspberrypi-bullseye-docker-64 collectd[547]: Initialization complete, entering read-loop.
                    @damrak2022 les mal nochmal deinen ersten Beitrag, zwecks warnmeldung
                    I Offline
                    I Offline
                    iobroJB
                    schrieb am zuletzt editiert von iobroJB
                    #129
                    @crunchip Hallo, ich antworte jetzt einfach mal Dir.
                    Ich habe noch wenig Erfahrung mit iobroker und grafana,
                    habe aber nach der obigen Anweisung hier und den weiteren Hilfen in diesem Beitrag, die Installationen denke ich richtig hinbekommen.
                    Da das BeispielDashboard in obigen Beitrag nicht mehr aufrufbar ist, habe ich aus einem anderen Beitrag hier (ganz am Ende des Textes) das Dashboard hier importiert.
                    Leider zeigt Grafana keine Werte an, obwohl ich die vorhandene influxdb zugewiesen habe und auch den Wert für die FritzBox entsprechend ausgewählt habe.
                    Habe ich noch etwas vergessen, übersehen oder falsch gemacht?
                    Ich bitte um Eure Hilfe, danke.
                    ? crunchipC 2 Antworten Letzte Antwort
                    • I iobroJB
                      #130
                      @iobrojb
                      Moin,
                      warum bist Du nicht nach dem offiziellen Installations Doku vorgegangen fritzinfluxdb?
                      Benutzt Du influxDB V. 1.8 oder influxDB V.2.x?
                      Welche Version setzt Du von fritzinfluxdb ein (Aktuell ist 1.2.1)
                      Ist influxDB auch der korrekte Name der Datenbank, Zeig mal die zu fitzinfluxdb passende Konfiguration /opt/fritzinfluxdb/fritzinfluxdb.ini
                      !!!Achtung!!! da können User und Passwort im Klartext stehen
                      Installations Beispiel für Ubuntu, sieh obigen link
                      sudo apt-get install python3-virtualenv
                      cd /opt
                      git clone https://github.com/bb-Ricardo/fritzinfluxdb.git
                      cd fritzinfluxdb
                      virtualenv -p python3 .venv
                      . .venv/bin/activate
                      pip3 install -r requirements.txt
                      modify your configuration and test it
                      ./fritzinfluxdb.py
                      Wenn Du das ganze über systemd startest, was sagt dir
                      # systemctl status fritzinfluxdb.service
                      Bei mir sieht das so aus:
                      [dp20eic@loki fritzinfluxdb]$ systemctl status fritzinfluxdb.service
                      * fritzinfluxdb.service - Fritz to InfluxDB daemon
                           Loaded: loaded (/usr/lib/systemd/system/fritzinfluxdb.service; enabled; preset: disabled)
                           Active: active (running) since Wed 2023-02-01 17:11:39 CET; 3min 5s ago
                         Main PID: 187969 (python)
                            Tasks: 1 (limit: 38366)
                           Memory: 34.4M
                           CGroup: /system.slice/fritzinfluxdb.service
                                   `-187969 /opt/fritzinfluxdb/.venv/bin/python /opt/fritzinfluxdb/fritzinfluxdb.py -d
                      Feb 01 17:11:40 loki fritzinfluxdb[187969]: INFO: Connection to InfluxDB 2.5.1 established and bucket is present
                      Feb 01 17:11:45 loki fritzinfluxdb[187969]: INFO: Unknown FritzBox link type 'Ethernet'. Please report this link type as issue to the gi>
                      Feb 01 17:11:45 loki fritzinfluxdb[187969]: INFO: Successfully established FritzBox TR-069 session
                      Feb 01 17:11:46 loki fritzinfluxdb[187969]: INFO: Successfully established FritzBox Lua session
                      Feb 01 17:11:46 loki fritzinfluxdb[187969]: INFO: Successfully connected to FritzBox '192.168.178.1' (fritz.box) Model: FRITZ!Box 7590 (>
                      Feb 01 17:11:46 loki fritzinfluxdb[187969]: /opt/fritzinfluxdb/fritzinfluxdb.py:141: DeprecationWarning: There is no current event loop
                      Feb 01 17:11:46 loki fritzinfluxdb[187969]:   loop = asyncio.get_event_loop()
                      Feb 01 17:11:46 loki fritzinfluxdb[187969]: INFO: Starting main loop
                      Feb 01 17:11:48 loki fritzinfluxdb[187969]: INFO: Service 'DSL Info (Fritz!OS 7.29 - latest)' not applicable for this FritzBox Model Lin>
                      Feb 01 17:11:48 loki fritzinfluxdb[187969]: INFO: Service 'Cable Info (Fritz!OS 7.29 - latest)' not applicable for this FritzBox Model L>
                      Die original Dashboards liegen, wenn Du alles richtig gemacht hast unter den jeweiligen Ordnern für influx1 / influx2
                      [dp20eic@loki ~]$ ls -la /opt/fritzinfluxdb/grafana/
                      total 555
                      drwxr-xr-x 4 root root      6 Jan 25 14:00 .
                      drwxr-xr-x 7 root root     18 Jan 25 14:03 ..
                      -rw-r--r-- 1 root root 356744 Jan 25 14:00 grafana_dashboard.png
                      -rw-r--r-- 1 root root 164338 Jan 25 14:00 grafana_home-automation_dashboard.png
                      drwxr-xr-x 2 root root      5 Jan 25 14:00 influx1_dashboards
                      drwxr-xr-x 2 root root      6 Jan 25 14:00 influx2_dashboards
                      !!!Achtung!!!
                      fritzinfluxdb für influxDb V. 1.8 wird vom Developer nicht mehr weiter entwickelt.
                      VG
                      Bernd
                      • I iobroJB
                        crunchipC Offline
                        crunchipC Offline
                        #131
                        @iobrojb sagte in Fritzbox mit Grafana visualisieren [Version 2022]:
                        Sind denn auch Daten in der Datenbank?
                        Ich hatte das wie weiter oben geschrieben, per upnp Adapter laufen, der die Daten holte und die query's im Dashboard entsprechend angepasst.
                        Nutze das allerdings seit rund 3 Jahren nicht mehr
                          @iobrojb
                          Moin,
                          cd /opt
                          cd fritzinfluxdb
                          ./fritzinfluxdb.py
                               Memory: 34.4M
                          total 555
                          !!!Achtung!!!
                          VG
                          Bernd
                          Maxtor62
                          schrieb am zuletzt editiert von Maxtor62
                          #132
                          @dp20eic
                          hi, ist ein alter Thread aber ich versuch es trotzdem.
                          Ich habe jetzt schon Proxmox LXC Container mit Debian 11 + 12, Ubuntu 22.04 + 23.04 versucht das Teil ans Laufen zu bringen.
                          Auch mit nem Docker auf dem Synology NAS hab ich es versucht. Was soll ich sagen? Es klappt einfach nicht. Kann das an meiner Fritte liegen. Das ist die 7590 AX. Wäre super, wenn mir jemand noch n Tipp geben könnte. Hier die Logs dazu.
                          (.venv) stefan@helper:/opt/fritzinfluxdb$ ./fritzinfluxdb.py
                          2023-10-31 18:15:40,918 - INFO: Starting fritzinfluxdb v1.2.1 (2023-01-26)
                          2023-10-31 18:15:40,918 - INFO: Done reading config files
                          2023-10-31 18:15:40,938 - INFO: Successfully parsed config
                          2023-10-31 18:15:40,940 - INFO: Connection to InfluxDB 2 established
                          2023-10-31 18:15:46,412 - INFO: Successfully established FritzBox TR-069 session
                          2023-10-31 18:15:47,135 - INFO: Successfully established FritzBox Lua session
                          2023-10-31 18:15:47,136 - INFO: Successfully connected to FritzBox '192.168.178.1' (fritz.box) Model: FRITZ!Box 7590 AX (DSL) - FW: 7.                                     57
                          2023-10-31 18:15:47,136 - INFO: Starting main loop
                          2023-10-31 18:15:59,125 - INFO: Service 'Cable Info (Fritz!OS 7.29 - latest)' not applicable for this FritzBox Model Link type 'DSL'
                          2023-10-31 18:16:00,134 - ERROR: Unable to convert FritzBox Lua value '0-673710080' for 'ha_alert' to '<class 'int'>': invalid literal                                      for int() with base 10: '0-673710080'
                          2023-10-31 18:16:00,134 - ERROR: Unable to convert FritzBox Lua value '0-1865154560' for 'ha_alert' to '<class 'int'>': invalid litera                                     l for int() with base 10: '0-1865154560'
                          2023-10-31 18:16:24,525 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                          2023-10-31 18:16:30,738 - ERROR: Unable to convert FritzBox Lua value '0-673710080' for 'ha_alert' to '<class 'int'>': invalid literal                                      for int() with base 10: '0-673710080'
                          2023-10-31 18:16:30,738 - ERROR: Unable to convert FritzBox Lua value '0-1865154560' for 'ha_alert' to '<class 'int'>': invalid litera                                     l for int() with base 10: '0-1865154560'
                          2023-10-31 18:16:30,767 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                          2023-10-31 18:16:35,802 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                          2023-10-31 18:16:40,870 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                          2023-10-31 18:16:45,920 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                          2023-10-31 18:16:50,991 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                          2023-10-31 18:16:56,016 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                          2023-10-31 18:17:02,085 - ERROR: Unable to convert FritzBox Lua value '0-673710080' for 'ha_alert' to '<class 'int'>': invalid literal                                      for int() with base 10: '0-673710080'
                          2023-10-31 18:17:02,085 - ERROR: Unable to convert FritzBox Lua value '0-1865154560' for 'ha_alert' to '<class 'int'>': invalid litera                                     l for int() with base 10: '0-1865154560'
                          2023-10-31 18:17:03,083 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                          2023-10-31 18:17:08,623 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                          2023-10-31 18:17:14,134 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                          2023-10-31 18:17:19,203 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                          2023-10-31 18:17:24,889 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                          2023-10-31 18:17:30,976 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                          2023-10-31 18:17:33,338 - ERROR: Unable to convert FritzBox Lua value '0-673710080' for 'ha_alert' to '<class 'int'>': invalid literal                                      for int() with base 10: '0-673710080'
                          2023-10-31 18:17:33,339 - ERROR: Unable to convert FritzBox Lua value '0-1865154560' for 'ha_alert' to '<class 'int'>': invalid litera                                     l for int() with base 10: '0-1865154560'
                          2023-10-31 18:17:36,381 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                          2023-10-31 18:17:41,420 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                          2023-10-31 18:17:46,463 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                          2023-10-31 18:17:51,571 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                          2023-10-31 18:17:56,971 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                          2023-10-31 18:18:02,262 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                          2023-10-31 18:18:05,602 - ERROR: Unable to convert FritzBox Lua value '0-673710080' for 'ha_alert' to '<class 'int'>': invalid literal                                      for int() with base 10: '0-673710080'
                          2023-10-31 18:18:05,602 - ERROR: Unable to convert FritzBox Lua value '0-1865154560' for 'ha_alert' to '<class 'int'>': invalid litera                                     l for int() with base 10: '0-1865154560'
                          2023-10-31 18:18:07,437 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                          2023-10-31 18:18:17,150 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                          2023-10-31 18:18:22,474 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                          2023-10-31 18:18:29,000 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                          2023-10-31 18:18:35,006 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                          2023-10-31 18:18:36,383 - ERROR: Unable to convert FritzBox Lua value '0-673710080' for 'ha_alert' to '<class 'int'>': invalid literal                                      for int() with base 10: '0-673710080'
                          2023-10-31 18:18:36,383 - ERROR: Unable to convert FritzBox Lua value '0-1865154560' for 'ha_alert' to '<class 'int'>': invalid litera                                     l for int() with base 10: '0-1865154560'
                          2023-10-31 18:18:40,422 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                          2023-10-31 18:18:45,471 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                          2023-10-31 18:18:51,073 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                          2023-10-31 18:18:56,581 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                          ^C2023-10-31 18:19:01,953 - INFO: Received exit signal SIGINT...
                          2023-10-31 18:19:01,954 - INFO: Cancelling 4 outstanding tasks
                          2023-10-31 18:19:01,955 - INFO: Closed FritzBox TR-069 connection
                          2023-10-31 18:19:01,955 - INFO: Closed FritzBox Lua connection
                          2023-10-31 18:19:01,955 - INFO: Closed InfluxDB session
                          2023-10-31 18:19:01,955 - INFO: Successfully shutdown fritzinfluxdb
                          Die Datenbank wird kurz mit Daten gefüttert, die ich auch mit Grafana darstellen sehe, aber nach ca. einer Minute sind die Daten wieder weg, N/A.
                          Wer meint er ist was, hat aufgehört was zu werden
                          ? 1 Antwort Letzte Antwort
                          • M Maxtor62
                            @dp20eic
                            #133
                            @maxtor62 sagte in Fritzbox mit Grafana visualisieren [Version 2022]:
                            Moin,
                            wie ist die FritzBox eingerichtet, welchen User nutzt Du zum Login?
                            Die Einrichtung im LX Container hast Du nach Vorgabe wie auf der Github Seite gemacht, also auch fritzconnection und alle Python Module installiert?
                            Zeig mal die fritzinfluxdb.ini aber nimm vorher den User und das Passwort raus, oder x es aus
                            VG
                            Bernd
                              Moin,
                              VG
                              Bernd
                              Maxtor62
                              #134
                              @dp20eic
                              hi sorry für meine Ungeduld. Hab halt schon so viel probiert.
                              Auf der Fritte hab ich extra ein User eingerichtet den ich dafür nehme. Hat alle Rechte.
                              Die Einrichtung habe ich jedes Mal genau so wie Du oder auf Github beschrieben, gemacht.
                              Fritzconnection und alle Python Module installiert.
                              Hier die fritzinfluxdb.ini
                              [influxdb]
                              # requires a hostname or IP which points to your InfluxDB instance
                              hostname = 192.168.178.139
                              # define the port your InfluxDB instance is listening on
                              port = 8086
                              # weather TLS encryption is enabled or disabled
                              #tls_enabled = false
                              # set this to 'true' to enforces TLS certificate validation
                              #verify_tls = false
                              # set a measurement name which is used to write the data to InfluxDB
                              # If this is changed from the default then it also has to be changed
                              # from the default value during the Grafana dashboard installation
                              measurement_name = fritzbox
                              # The amount of days the data should be stored in InfluxDB.
                              # Older data will be deleted.
                              # Attention: THIS IS ONLY CONFIGURED ON NEW DB/BUCKET CREATION!
                              data_retention_days = 365
                              # define which InfluxDB version you are using
                              version = 2
                              ##### InfluxDB version 1.x options
                              # username and password to use to write data to InfluxDB
                              username =
                              password =
                              # defines the InfluxDB database to write the data to
                              # if the credentials permit to create databases then this
                              # will be created automatically
                              database =
                              ##### InfluxDB version 2.x options
                              # requires an InfluxDB API token with permissions to write to the desired bucket
                              token = RRoG5NJBBUqnql1OKaHuxo3d2xqz0YpA-2AOO-fviu1Ft5mpafJizebVkpiQdGxwdtQvDv3AUJvXWLMreSQ1NA==
                              # a valid InfluxDB organisation needs to be defined which is used during login
                              organisation = home
                              # defines the InfluxDB bucket to write the data to
                              # if the credentials permit to create buckets then this
                              bucket = fritzbox
                              ### [fritzbox]
                              ### Controls the parameters for connecting to your InfluxDB instance.
                              [fritzbox]
                              # changes the default FritzBox IP
                              # username and password to connect to the FritzBox
                              username = XXXX
                              password = XXXX
                              # Define the port the FritzBox is listening on
                              # change to 49443 if you use ssl
                              port = 49000
                              # weather TLS encryption is enabled or disabled (will set port to 49443 if port is undefined)
                              # set this to 'true' to enforces TLS certificate validation (only affects Lua sessions)
                              #verify_tls = false
                              # defines the InfluxDB measurement tag which is used
                              # to tag data from this FritzBox
                              #box_tag = fritz.box
                              # Define the FritzBox time zone. Used to convert dates/times from FritzBox to correct UTC Timestamp
                              timezone = Europe/Berlin
                              # the maximum of time in seconds which a connection to the FritzBox is allowed to take
                              connect_timeout = 30
                              # interval to request data from FritzBox in seconds
                              # the value CAN'T be lower then 10 seconds
                              request_interval = 30
                              # EOF
                              Danke und Grüße
                              • M Maxtor62
                                @dp20eic
                                [influxdb]
                                port = 8086
                                #verify_tls = false
                                version = 2
                                username =
                                password =
                                database =
                                organisation = home
                                bucket = fritzbox
                                ### [fritzbox]
                                [fritzbox]
                                username = XXXX
                                password = XXXX
                                port = 49000
                                #verify_tls = false
                                # EOF
                                Danke und Grüße
                                #135
                                Moin,
                                also da sehe ich erst einmal keine Klinke.
                                Ich habe mal nach dem im Log aufgeführten Fehler ha_alert im Source auf Github gesucht, das kommt wohl aus dem Bereich homeauto.py, jetzt kann ich damit aber auch nicht mehr anfangen, ob das jetzt an der FritzBox liegt, oder ob die Version 7.57 da für die AX eine Macke hat oder ob Du da vielleicht Geräte in Samrt Home eingerichtet hast und deswegen der Fehler kommt.
                                Warte einfach mal ab, was bb-Ricardo zu dem Fehler sagt.
                                VG
                                Bernd
                                  Moin,
                                  VG
                                  Bernd
                                  Maxtor62
                                  #136
                                  @dp20eic
                                  ok, danke für Deine Mühe. Im SmatHome hab ich nur Fritz Geräte über DECT eingerichtet, außer die drei Rollladen Motoren. Die sind von BoxControl, was auch über DECT läuft. Da sollte die Fritte ja kein Problem haben.
                                  Ich werde mich in Geduld üben.
                                  Grüße
                                  Stefan
                                  • M Maxtor62
                                    @dp20eic
                                    Grüße
                                    Stefan
                                    #137
                                    Moin,
                                    na dann kann es ja doch sein, dass da etwas nicht korrekt eingerichtet oder installiert ist. Du solltest mal gleich dein issuse auf Github mit allen Informationen erweitern, damit bb-Ricardo nicht erst noch nachfragen muss, verzögert dann ja nur zusätzlich.
                                    VG
                                    Bernd
                                      Moin,
                                      VG
                                      Bernd
                                      Maxtor62
                                      #138
                                      @dp20eic
                                      es ist unglaublich.
                                      FritzBox boot tut gut.
                                      Jetzt funktioniert alles.
                                      Danke Dir noch mal.
                                      Grüße
                                      Stefan
                                      • M Maxtor62
                                        @dp20eic
                                        es ist unglaublich.
                                        Danke Dir noch mal.
                                        Grüße
                                        Stefan
                                        #139
                                        Danke Dir noch mal.
                                        Moin,
                                        bidde schön, ist aber nicht meine Verdienst, Du kannst Dich bei bb-Ricardo bedanken.
                                        Und ja, mach mal, tut ein Boot gut :)
                                        VG
                                        Bernd
                                          @damrak2022 vllt kommst du hiermit besser zurecht
                                          M Online
                                          M Online
                                          michihorn
                                          #140
                                          @crunchip Hallo hab mal mitgelesen, bei der Anleitung die Du empfohlen hast, scheitere ich schon bei sudo pip install fritzcollectd mit folgender Meldung:
                                          error: externally-managed-environment
                                          × This environment is externally managed
                                          ╰─> To install Python packages system-wide, try apt install
                                              python3-xyz, where xyz is the package you are trying to
                                              install.
                                              If you wish to install a non-Debian-packaged Python package,
                                              create a virtual environment using python3 -m venv path/to/venv.
                                              Then use path/to/venv/bin/python and path/to/venv/bin/pip. Make
                                              sure you have python3-full installed.
                                              For more information visit http://rptl.io/venv
                                          note: If you believe this is a mistake, please contact your Python installation or OS distribution provider. You can override this, at the risk of breaking your Python installation or OS, by passing --break-system-packages.
                                          hint: See PEP 668 for the detailed specification.
                                          Hast du ne Ahnung was ich tun muss?
                                          Michael
