  3. Off Topic
  4. Grafana
  5. Fritzbox mit Grafana visualisieren [Version 2022]
  • NEWS Räume und Funktionen in einem Durchlauf: der Assistent in Admin 8 (mit Video)
  • NEWS: Neu im Admin, zentrale Verwaltung für Passwörter und Schlüssel
  • Neue Adresse: die ioBroker-Webseite liegt jetzt auf iobroker.com
Geplant Angeheftet Gesperrt Verschoben Grafana
144 Beiträge 12 Kommentatoren 39.5k Aufrufe 16 Beobachtet
    @damrak2022
    Wenn die Datei richtig ist:
    sudo apt update
    sudo apt autoremove
    sudo apt full-upgrade
    Damrak2022D
    Damrak2022D
    Damrak2022
    schrieb am zuletzt editiert von Damrak2022
    #101
    @thomas-braun sagte in Fritzbox mit Grafana visualisieren [Version 2022]:
    pi@homebridge:~ $ sudo nano /etc/apt/sources.list.d/grafana.list
    pi@homebridge:~ $ sudo apt update
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:3 https://packages.grafana.com/oss/deb stable InRelease
    Hit:4 https://repos.influxdata.com/debian bullseye InRelease
    Hit:5 https://deb.nodesource.com/node_14.x bullseye InRelease
    Hit:6 https://archive.raspbian.org/raspbian buster InRelease
    Hit:7 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
    Reading package lists... Done
    Building dependency tree... Done
    5 packages can be upgraded. Run 'apt list --upgradable' to see them.
    pi@homebridge:~ $ sudo apt autoremove
    The following packages will be REMOVED:
      libpython2-dev libpython2-stdlib libpython2.7 libpython2.7-dev
      libpython2.7-minimal libpython2.7-stdlib python2 python2-dev python2-minimal
      python2.7 python2.7-dev python2.7-minimal
    0 upgraded, 0 newly installed, 12 to remove and 5 not upgraded.
    After this operation, 27.2 MB disk space will be freed.
    Do you want to continue? [Y/n] y
    (Reading database ... 68557 files and directories currently installed.)
    Removing python2-dev (2.7.18-3) ...
    Removing libpython2-dev:armhf (2.7.18-3) ...
    Removing python2 (2.7.18-3) ...
    Removing libpython2-stdlib:armhf (2.7.18-3) ...
    Removing python2.7-dev (2.7.18-8) ...
    Removing libpython2.7-dev:armhf (2.7.18-8) ...
    Removing libpython2.7:armhf (2.7.18-8) ...
    Removing python2.7 (2.7.18-8) ...
    Removing libpython2.7-stdlib:armhf (2.7.18-8) ...
    Removing python2-minimal (2.7.18-3) ...
    Removing python2.7-minimal (2.7.18-8) ...
    Unlinking and removing bytecode for runtime python2.7
    Removing libpython2.7-minimal:armhf (2.7.18-8) ...
    Processing triggers for man-db (2.9.4-2) ...
    Processing triggers for mailcap (3.69) ...
    Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u2) ...
    pi@homebridge:~ $ sudo apt full-upgrade
    Calculating upgrade... Done
    The following packages will be upgraded:
      libraspberrypi-bin libraspberrypi-dev libraspberrypi-doc libraspberrypi0
      pi-bluetooth
    5 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    Need to get 501 kB of archives.
    After this operation, 5,120 B of additional disk space will be used.
    Get:1 http://archive.raspberrypi.org/debian bullseye/main armhf libraspberrypi-dev armhf 1:2+git20220324~090146+c4fd1b8-1 [177 kB]
    Get:2 http://archive.raspberrypi.org/debian bullseye/main armhf libraspberrypi-bin armhf 1:2+git20220324~090146+c4fd1b8-1 [149 kB]
    Get:3 http://archive.raspberrypi.org/debian bullseye/main armhf libraspberrypi0 armhf 1:2+git20220324~090146+c4fd1b8-1 [167 kB]
    Get:4 http://archive.raspberrypi.org/debian bullseye/main armhf libraspberrypi-doc all 1:2+git20220324~090146+c4fd1b8-1 [1,908 B]
    Get:5 http://archive.raspberrypi.org/debian bullseye/main armhf pi-bluetooth all 0.1.19 [5,764 B]
    Fetched 501 kB in 0s (1,731 kB/s)
    Reading changelogs... Done
    (Reading database ... 67657 files and directories currently installed.)
    Preparing to unpack .../libraspberrypi-dev_1%3a2+git20220324~090146+c4fd1b8-1_armhf.deb ...
    Unpacking libraspberrypi-dev (1:2+git20220324~090146+c4fd1b8-1) over (1:2+git20211125~155417+14b90ff-3) ...
    Preparing to unpack .../libraspberrypi-bin_1%3a2+git20220324~090146+c4fd1b8-1_armhf.deb ...
    Unpacking libraspberrypi-bin (1:2+git20220324~090146+c4fd1b8-1) over (1:2+git20211125~155417+14b90ff-3) ...
    Preparing to unpack .../libraspberrypi0_1%3a2+git20220324~090146+c4fd1b8-1_armhf.deb ...
    Unpacking libraspberrypi0:armhf (1:2+git20220324~090146+c4fd1b8-1) over (1:2+git20211125~155417+14b90ff-3) ...
    Preparing to unpack .../libraspberrypi-doc_1%3a2+git20220324~090146+c4fd1b8-1_all.deb ...
    Unpacking libraspberrypi-doc (1:2+git20220324~090146+c4fd1b8-1) over (1:2+git20211125~155417+14b90ff-3) ...
    Preparing to unpack .../pi-bluetooth_0.1.19_all.deb ...
    Unpacking pi-bluetooth (0.1.19) over (0.1.18) ...
    Setting up pi-bluetooth (0.1.19) ...
    Setting up libraspberrypi0:armhf (1:2+git20220324~090146+c4fd1b8-1) ...
    Setting up libraspberrypi-bin (1:2+git20220324~090146+c4fd1b8-1) ...
    Setting up libraspberrypi-dev (1:2+git20220324~090146+c4fd1b8-1) ...
    Setting up libraspberrypi-doc (1:2+git20220324~090146+c4fd1b8-1) ...
    pi@homebridge:~ $
    pi@homebridge:/opt/fritzinfluxdb $ ./fritzinfluxdb.py
    Traceback (most recent call last):
      File "/opt/fritzinfluxdb/./fritzinfluxdb.py", line 18, in <module>
        import fritzconnection
    ModuleNotFoundError: No module named 'fritzconnection'
    Mit besten Grüßen
    Andy
    • Damrak2022D Damrak2022
        pi-bluetooth
      pi@homebridge:~ $
      Thomas BraunT
      Thomas BraunT
      #102
      @damrak2022
      Da fehlt wie @crunchip (und die verlinkte Anleitung) schreibt
      pip install fritzconnection
        @damrak2022 sagte in Fritzbox mit Grafana visualisieren [Version 2022]:
        pi@homebridge:/opt/fritzinfluxdb $ ./fritzinfluxdb.py Traceback (most recent call last): File "/opt/fritzinfluxdb/./fritzinfluxdb.py", line 18, in <module> import fritzconnection ModuleNotFoundError: No module named 'fritzconnection' pi@homebridge:/opt/fritzinfluxdb $
        also bist du doch da im richtigen Verzeichnis, pi@homebridge:/opt/fritzinfluxdb $ ./fritzinfluxdb.py
        so wie ich das lese, fehlt dir fritzconnection
        Damrak2022D
        Damrak2022D
        Damrak2022
        #103
        @crunchip sagte in Fritzbox mit Grafana visualisieren [Version 2022]:
        pip
        pi@homebridge:/opt/fritzinfluxdb $ pip install fritzconnection
        Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
        Requirement already satisfied: fritzconnection in /home/pi/.local/lib/python3.9/site-packages (1.3.3)
        Requirement already satisfied: requests>=2.22.0 in /usr/local/lib/python3.9/dist-packages (from fritzconnection) (2.22.0)
        Requirement already satisfied: urllib3!=1.25.0,!=1.25.1,<1.26,>=1.21.1 in /usr/local/lib/python3.9/dist-packages (from requests>=2.22.0->fritzconnection) (1.25.11)
        Requirement already satisfied: idna<2.9,>=2.5 in /usr/local/lib/python3.9/dist-packages (from requests>=2.22.0->fritzconnection) (2.8)
        Requirement already satisfied: certifi>=2017.4.17 in /usr/lib/python3/dist-packages (from requests>=2.22.0->fritzconnection) (2020.6.20)
        Requirement already satisfied: chardet<3.1.0,>=3.0.2 in /usr/local/lib/python3.9/dist-packages (from requests>=2.22.0->fritzconnection) (3.0.4)
        Mit besten Grüßen
        Andy
          pip
          Thomas BraunT
          Thomas BraunT
          #104
          Ich vermute, das liegt in /home/pi/.local falsch.
          Von python hab ich aber offen gesagt nicht viel Ahnung.
          Weiß nicht ob das da einfach weggelöscht werden kann oder ob das per
          pip uninstall fritzconnection
          Im Home von pi zu deinstallieren ist.
            Damrak2022D
            Damrak2022D
            Damrak2022
            #105
            Also da ist es jetzt raus
            pi@homebridge:~ $ pip uninstall fritzconnection
            Found existing installation: fritzconnection 1.3.3
            Uninstalling fritzconnection-1.3.3:
              Would remove:
                /home/pi/.local/lib/python3.9/site-packages/fritzconnection-1.3.3.dist-info/*
            Proceed (y/n)? y
              Successfully uninstalled fritzconnection-1.3.3
            pi@homebridge:~ $
            Also installiere ich es jetzt unter fritzinfluxdb direkt?
            Mit besten Grüßen
            Andy
              pip
              crunchipC
              crunchipC
              Developer Global Moderator Most Active Forum Testing
              #106
              Hier zu installieren, wäre aber das falsche Verzeichnis
                Damrak2022D
                Damrak2022D
                Damrak2022
                #107
                @crunchip Dann verstehe ich die gesamte Anleitung nicht. Hast Du dir die mal angeschaut?
                https://blog.gwarg.de/2022/01/22/fritzbox-mit-grafana-visualisieren-version-2022/
                Ich habe zwar nicht viel Ahnung, kann mir aber nicht vorstellen das ich da soviel missverstanden habe.
                Mit besten Grüßen
                Andy
                    Would remove:
                  Proceed (y/n)? y
                  pi@homebridge:~ $
                  crunchipC
                  crunchipC
                  #108
                  Nein, das gibt es doch noch gar nicht, das verzeichnis wird doch erst später erstellt
                    Thomas BraunT
                    Thomas BraunT
                    #109
                    @damrak2022
                    export PATH=/home/pi/.local/lib:$PATH
                      crunchipC
                      crunchipC
                      #110
                      Ja, da steht
                      Erst Fritzconnection
                      sudo apt install python3-pip
                        Ja, da steht
                        Damrak2022D
                        Damrak2022D
                        Damrak2022
                        #111
                        @crunchip Genau so habe ich das der Reihe nach installiert
                        Mit besten Grüßen
                        Andy
                          Thomas BraunT
                          Thomas BraunT
                          #112
                          @damrak2022
                          Bei mir läuft's durch:
                          Successfully installed fritzconnection-1.9.1 influxdb-5.3.1 msgpack-1.0.3 python-dateutil-2.8.2 pytz-2022.1
                            @damrak2022
                            Damrak2022D
                            Damrak2022D
                            Damrak2022
                            #113
                            @thomas-braun Wenn ich den exakt so eingebe springt er sofort zum nächsten
                            pi@homebridge:~ $ export PATH=/home/pi/.local/lib:$PATH
                            pi@homebridge:~ $
                            Mit besten Grüßen
                            Andy
                              pi@homebridge:~ $
                              Thomas BraunT
                              Thomas BraunT
                              #114
                              Das soll so sein.
                                crunchipC
                                crunchipC
                                #115
                                @damrak2022 les mal nochmal deinen ersten Beitrag, zwecks warnmeldung
                                Damrak2022D I 2 Antworten Letzte Antwort
                                  Damrak2022D
                                  Damrak2022D
                                  Damrak2022
                                  #116
                                  @crunchip Ich werde jetzt nochmal die 5 Befehle aus der Anleitung nacheinander eingeben.
                                  Ansonsten mache ich morgen weiter
                                  # Erst Fritzconnection
                                  # Dann Fritz InfluxDB
                                  sudo apt install virtualenv python3-lxml git
                                  cd /opt
                                  sudo git clone https://github.com/yunity/fritzinfluxdb.git
                                  cd fritzinfluxdb
                                  sudo virtualenv --system-site-packages -p python3 .venv
                                  . .venv/bin/activate
                                  # ab hier im (.venv)-modus
                                  pip3 install -r requirements.txt
                                  Vielleicht bringt es ja was
                                  Erstmal DANKE an Euch
                                  Mit besten Grüßen
                                  Andy
                                    cd /opt
                                    cd fritzinfluxdb
                                    Thomas BraunT
                                    Thomas BraunT
                                    #117
                                    @damrak2022 @crunchip
                                    Ich merk gerade, das mit dem export in den $PATH war unnötig. Wird ja über die venv gemacht.
                                    Naja, egal, ist beim nächsten Neustart eh weg.
                                      Damrak2022D
                                      Damrak2022D
                                      Damrak2022
                                      #118
                                      @thomas-braun Es hat bei mir wahrscheinlich was mit der Warnmeldung nach dem Befehl der frzconnection installation zu tun:
                                      pi@homebridge:~ $ pip install fritzconnection
                                      Collecting fritzconnection
                                        Using cached https://www.piwheels.org/simple/fritzconnection/fritzconnection-1.9.1-py3-none-any.whl (50 kB)
                                      Installing collected packages: fritzconnection
                                        WARNING: The scripts fritzcall, fritzconnection, fritzhomeauto, fritzhosts, fritzmonitor, fritzphonebook, fritzstatus and fritzwlan are installed in '/home/pi/.local/bin' which is not on PATH.
                                        Consider adding this directory to PATH or, if you prefer to suppress this warning, use --no-warn-script-location.
                                      Anscheinen muss ich hier was korrigieren, obwohl es seit die Installation sei erfolgreich
                                      Mit besten Grüßen
                                      Andy
                                        Thomas BraunT
                                        Thomas BraunT
                                        #119
                                        @damrak2022
                                        Nee, das ist okay.
                                          @damrak2022
                                          Nee, das ist okay.
                                          Damrak2022D
                                          Damrak2022D
                                          Damrak2022
                                          #120
                                          @thomas-braun Jetzt scheint es zu gehen,, sind aber noch viele errors drin:
                                          (.venv) pi@homebridge:/opt/fritzinfluxdb $ ./fritzinfluxdb.py
                                          2022-04-23 00:14:07,252 - INFO: Done parsing config file
                                          2022-04-23 00:14:07,265 - INFO: Database <db> not found, trying to create it
                                          2022-04-23 00:14:07,276 - INFO: Connection to InfluxDB established and database present
                                          2022-04-23 00:14:08,899 - INFO: Successfully connected to FritzBox
                                          2022-04-23 00:14:08,900 - INFO: Starting main loop
                                          2022-04-23 00:14:09,201 - ERROR: Requested invalid action 'GetInfo' for service: WANDSLInterfaceConfig
                                          2022-04-23 00:14:09,212 - ERROR: Requested invalid action 'GetStatisticsTotal' for service: WANDSLInterfaceConfig
                                          2022-04-23 00:14:09,313 - ERROR: Requested invalid action 'GetInfo' for service: WANPPPConnection:1
                                          2022-04-23 00:14:09,314 - ERROR: Encountered problems while requesting data. Data might be incomplete.
                                          2022-04-23 00:14:18,832 - ERROR: Requested invalid action 'GetInfo' for service: WANDSLInterfaceConfig
                                          2022-04-23 00:14:18,844 - ERROR: Requested invalid action 'GetStatisticsTotal' for service: WANDSLInterfaceConfig
                                          2022-04-23 00:14:18,943 - ERROR: Requested invalid action 'GetInfo' for service: WANPPPConnection:1
                                          2022-04-23 00:14:18,943 - ERROR: Encountered problems while requesting data. Data might be incomplete.
                                          2022-04-23 00:14:28,634 - ERROR: Requested invalid action 'GetInfo' for service: WANDSLInterfaceConfig
                                          2022-04-23 00:14:28,679 - ERROR: Requested invalid action 'GetStatisticsTotal' for service: WANDSLInterfaceConfig
                                          2022-04-23 00:14:28,777 - ERROR: Requested invalid action 'GetInfo' for service: WANPPPConnection:1
                                          2022-04-23 00:14:28,777 - ERROR: Encountered problems while requesting data. Data might be incomplete.
                                          Ich habe in der .ini noch keinen Datenbanknamen vergeben.
                                          Mit besten Grüßen
                                          Andy
                                          Thomas BraunT ? 2 Antworten Letzte Antwort
                                          83.9k
                                          1.4m
