  4. [Tester gesucht] WireGuard UI Installer
    6.7k
68 Beiträge 11 Kommentatoren 11.2k Aufrufe 14 Beobachtet
  • CrunkFXC CrunkFX
    @dslraser zeig mal bitte den output von:
    ls /boot
    dslraserD Offline
    dslraserD Offline
    dslraser
    @crunkfx sagte in [Tester gesucht] WireGuard UI Installer:
    ls /boot
    root@tinkerboard:/opt/wireguard-ui# cd
    root@tinkerboard:~# ls /boot
    armbianEnv.txt                  boot.scr                  dtb                           System.map-5.10.0-9-rt-armmp  uInitrd-5.10.60-rockchip
    armbian_first_run.txt.template  cmdline.txt               dtb-5.10.60-rockchip          System.map-5.10.60-rockchip   vmlinuz-5.10.0-9-rt-armmp
    boot.bmp                        config-5.10.0-9-rt-armmp  initrd.img-5.10.0-9-rt-armmp  uInitrd                       vmlinuz-5.10.60-rockchip
    boot.cmd                        config-5.10.60-rockchip   initrd.img-5.10.60-rockchip   uInitrd-5.10.0-9-rt-armmp     zImage
    root@tinkerboard:~#
    CrunkFXC 1 Antwort Letzte Antwort
    • dslraserD dslraser
      ls /boot
      root@tinkerboard:~#
      CrunkFXC Offline
      CrunkFXC Offline
      CrunkFX
      Forum Testing
      @dslraser Kannst du einmal das docker Installationsscript Ausführen:
      curl -fsSL https://get.docker.com | sh
      • CrunkFXC CrunkFX
        dslraserD Offline
        dslraserD Offline
        dslraser
        root@tinkerboard:~# curl -fsSL https://get.docker.com | sh
        # Executing docker install script, commit: 93d2499759296ac1f9c510605fef85052a2c32be
        Warning: the "docker" command appears to already exist on this system.
        If you already have Docker installed, this script can cause trouble, which is
        why we're displaying this warning and provide the opportunity to cancel the
        installation.
        If you installed the current Docker package using this script and are using it
        again to update Docker, you can safely ignore this message.
        You may press Ctrl+C now to abort this script.
        + sleep 20
        + sh -c apt-get update -qq >/dev/null
        + sh -c DEBIAN_FRONTEND=noninteractive apt-get install -y -qq apt-transport-https ca-certificates curl >/dev/null
        + sh -c curl -fsSL "https://download.docker.com/linux/debian/gpg" | gpg --dearmor --yes -o /usr/share/keyrings/docker-archive-keyring.gpg
        + sh -c echo "deb [arch=armhf signed-by=/usr/share/keyrings/docker-archive-keyring.gpg] https://download.docker.com/linux/debian bullseye stable" > /etc/apt/sources.list.d/docker.list
        + sh -c DEBIAN_FRONTEND=noninteractive apt-get install -y -qq --no-install-recommends  docker-ce-cli docker-ce >/dev/null
        + version_gte 20.10
        + [ -z  ]
        + return 0
        + sh -c DEBIAN_FRONTEND=noninteractive apt-get install -y -qq docker-ce-rootless-extras >/dev/null
        + sh -c docker version
        Client: Docker Engine - Community
        Version:           20.10.11
        API version:       1.41
        Go version:        go1.16.9
        Git commit:        dea9396
        Built:             Thu Nov 18 00:37:17 2021
        OS/Arch:           linux/arm
        Context:           default
        Experimental:      true
        Server: Docker Engine - Community
        Engine:
         Version:          20.10.11
         API version:      1.41 (minimum version 1.12)
         Git commit:       847da18
         Built:            Thu Nov 18 00:35:33 2021
         OS/Arch:          linux/arm
         Experimental:     false
        containerd:
         Version:          1.4.12
         GitCommit:        7b11cfaabd73bb80907dd23182b9347b4245eb5d
        runc:
         Version:          1.0.2
         GitCommit:        v1.0.2-0-g52b36a2
        docker-init:
         Version:          0.19.0
         GitCommit:        de40ad0
        To run Docker as a non-privileged user, consider setting up the
        Docker daemon in rootless mode for your user:
           dockerd-rootless-setuptool.sh install
        Visit https://docs.docker.com/go/rootless/ to learn about rootless mode.
        To run the Docker daemon as a fully privileged service, but granting non-root
        users access, refer to https://docs.docker.com/go/daemon-access/
        WARNING: Access to the remote API on a privileged Docker daemon is equivalent
                to root access on the host. Refer to the 'Docker daemon attack surface'
                documentation for details: https://docs.docker.com/go/attack-surface/
        Ich installiere WG mit Deinem Script jetzt dann nochmal ? (hatte ich gerade deinstalliert)
          installation.
          + sleep 20
          + version_gte 20.10
          + [ -z  ]
          + return 0
          Version:           20.10.11
          API version:       1.41
          Git commit:        dea9396
          OS/Arch:           linux/arm
          Context:           default
          Experimental:      true
          Engine:
           Version:          20.10.11
           Git commit:       847da18
           OS/Arch:          linux/arm
           Experimental:     false
          containerd:
           Version:          1.4.12
          runc:
           Version:          1.0.2
          docker-init:
           Version:          0.19.0
           GitCommit:        de40ad0
          CrunkFXC Offline
          CrunkFXC Offline
          CrunkFX
          Forum Testing
          @dslraser Versuch nochmal
          Reboot
          cd /opt/wireguard-ui
          docker-compose up
          • CrunkFXC CrunkFX
            Reboot
            docker-compose up
            dslraserD Offline
            dslraserD Offline
            dslraser
            docker-compose up
            root@tinkerboard:~# cd /opt/wireguard-ui
            root@tinkerboard:/opt/wireguard-ui# docker-compose up
            ERROR: Couldn't connect to Docker daemon at http+docker://localhost - is it running?
            If it's at a non-standard location, specify the URL with the DOCKER_HOST environment variable.
              docker-compose up
              CrunkFXC Offline
              CrunkFXC Offline
              CrunkFX
              Forum Testing
              @dslraser Das ist leider ein armbian Problem, ich werde bei mir ein Test Setup aufbauen und den installer erweitern. Wenn ich es schaffe noch bis Tagesende
              ScroungerS dslraserD 2 Antworten Letzte Antwort
              • CrunkFXC CrunkFX
                ScroungerS Offline
                ScroungerS Offline
                Scrounger
                @crunkfx
                Hab es heute auch mal getestet - funktioniert wunderbar, vielen Dank dafür!
                • CrunkFXC CrunkFX
                  dslraserD Offline
                  dslraserD Offline
                  dslraser
                  Konntest Du schon was testen?
                  CrunkFXC 2 Antworten Letzte Antwort
                    CrunkFXC Offline
                    CrunkFXC Offline
                    CrunkFX
                    Forum Testing
                    @dslraser Ja ich bin aktuell dabei das ganze ohne Docker auszulegen, da das auf den ARM und Proxmox Plattformen nur Probleme macht. Allerdings ist das etwas aufwendiger als gehofft. Ich bin gerade in der Testphase
                    • CrunkFXC CrunkFX
                      CrunkFXC Offline
                      CrunkFXC Offline
                      CrunkFX
                      Forum Testing
                      @crunkfx Mal kurz OffTopic: könnt ihr aktuell auf Github Zugreifen?
                      IdleBitI 1 Antwort Letzte Antwort
                      • CrunkFXC CrunkFX
                        IdleBitI Offline
                        IdleBitI Offline
                        IdleBit
                        @crunkfx Nein ich auch nicht :(
                          CrunkFXC Offline
                          CrunkFXC Offline
                          CrunkFX
                          Forum Testing
                          @dslraser @BBTown
                          Ich habe nun den Installer komplett Entdockert😳(Steht so bestimmt im Duden!).
                          Wer testen möchte und bereits die Docker Variante am laufen hat macht folgendes:
                          docker stop wgui
                          docker rm wgui
                          Anschließend für alle:
                          wget https://raw.githubusercontent.com/KleSecGmbH/ioBroker/dev/wireguard/installer-wgui.sh -O installer-wgui.sh && bash installer-wgui.sh
                          Die Konfigdaten liegen im Ordner:
                          /opt/wireguard-ui/db
                          wer damit spielen möchte.
                          NegaleinN dslraserD BBTownB 4 Antworten Letzte Antwort
                          • CrunkFXC CrunkFX
                            @dslraser @BBTown
                            docker stop wgui
                            docker rm wgui
                            NegaleinN Offline
                            NegaleinN Offline
                            Negalein
                            läuft und alles alte (User, etc.) sind noch da! :)
                            ° Fixer ---> iob fix
                            • CrunkFXC CrunkFX
                              @dslraser @BBTown
                              docker stop wgui
                              docker rm wgui
                              dslraserD Offline
                              dslraserD Offline
                              dslraser
                              @dslraser @BBTown
                              docker stop wgui
                              docker rm wgui
                              Ich bin noch unterwegs. Wenn ich heute Abend zu Hause bin werde ich es probieren.
                              Vielen Dank für Deine Mühe.
                              • David G.D Online
                                David G.D Online
                                David G.
                                Hey,
                                wollte es auch mal testen.
                                Bei mir kommt:
                                pi@iobroker: wget https://raw.githubusercontent.com/KleSecGmbH/ioBroker/dev/wireguard/installer-wgui.sh -O installer-wgui.sh && bash installer-wgui.sh
                                --2021-11-28 10:40:47--  https://raw.githubusercontent.com/KleSecGmbH/ioBroker/dev/wireguard/installer-wgui.sh
                                Auflösen des Hostnamens raw.githubusercontent.com (raw.githubusercontent.com)… 185.199.111.133, 185.199.110.133, 185.199.109.133, ...
                                Verbindungsaufbau zu raw.githubusercontent.com (raw.githubusercontent.com)|185.199.111.133|:443 … verbunden.
                                HTTP-Anforderung gesendet, auf Antwort wird gewartet … 200 OK
                                Länge: 7758 (7,6K) [text/plain]
                                Wird in »installer-wgui.sh« gespeichert.
                                installer-wgui.sh     0%[                    ]       0  --.-KB/s
                                installer-wgui.sh   100%[===================>]   7,58K  --.-KB/s    in 0,001s
                                2021-11-28 10:40:47 (11,3 MB/s) - »installer-wgui.sh« gespeichert [7758/7758]
                                E: Sperrdatei /var/lib/dpkg/lock-frontend konnte nicht geöffnet werden. - open (13: Keine Berechtigung)
                                E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), are you root?
                                pi@iobroker:~ $
                                EDIT:
                                Diese Meldung bekommeich über meinen SSH-Client an Smartphone. Mit Putty passiert garnichts. Man drückt Enter und die Zeile mit wget verschwindet einfach.
                                • David G.D David G.
                                  Hey,
                                  Bei mir kommt:
                                  pi@iobroker:~ $
                                  EDIT:
                                  CrunkFXC Offline
                                  CrunkFXC Offline
                                  CrunkFX
                                  Forum Testing
                                  @david-g Versuch mal vor bash sudo zu schreiben.
                                  • CrunkFXC CrunkFX
                                    David G.D Online
                                    David G.D Online
                                    David G.
                                    @crunkfx
                                    Jetzt kommt was.
                                    Aber auch mit Fehler:
                                    wireguard-ui-install V1.0.3 Stand 27.11.2021     @2021 forum.
                                    ┌─────────────────Wollen Sie fortfahren?───────────────────┐
                                    │ Dieser Installer wird Wireguard-UI, sowie alle           │   │ notwendigen Pakete und Paketquellen laden und            │
                                    │ installieren.                                            │
                                    │               <  Ja  >        < Nein >                   │
                                    #### 1.   Updates werden geholt und Installiert
                                    #apt update wird ausgführt
                                    WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
                                    #Erfolgreich
                                    #apt upgrade wird ausgführt
                                    #Erfolgreich
                                    #### 3.   WireGuard-UI wird installiert
                                    mkdir: das Verzeichnis „/opt/wireguard-ui“ kann nicht angelegt werden: Die Datei existiert bereits
                                    --2021-11-28 14:03:52--  https://raw.githubusercontent.com/KleSecGmbH/ioBroker/main/wireguard/wgui.path
                                    Auflösen des Hostnamens raw.githubusercontent.com (raw.githubusercontent.com)… 185.199.111.133, 185.199.109.133, 185.199.110.133, ...
                                    Länge: 143 [text/plain]
                                    Wird in »/etc/systemd/system/wgui.path« gespeichert.
                                    /etc/systemd/sy 100%[======>]     143  --.-KB/s    in 0s
                                    2021-11-28 14:03:52 (2,99 MB/s) - »/etc/systemd/system/wgui.path« gespeichert [143/143]
                                    --2021-11-28 14:03:52--  https://raw.githubusercontent.com/KleSecGmbH/ioBroker/main/wireguard/wgui.service
                                    Länge: 172 [text/plain]
                                    Wird in »/etc/systemd/system/wgui.service« gespeichert.
                                    ┌─────────────────────────ERROR────────────────────────────┐   │ Ups. Irgendwas ist da schiefgeleufen ;(                  │   │                                                          │
                                    │                         <  OK  >                         │
                                      @crunkfx
                                      Jetzt kommt was.
                                      │ installieren.                                            │
                                      │               <  Ja  >        < Nein >                   │
                                      #Erfolgreich
                                      #Erfolgreich
                                      │                         <  OK  >                         │
                                      CrunkFXC Offline
                                      CrunkFXC Offline
                                      CrunkFX
                                      Forum Testing
                                      @david-g Zeig mal den Output von:
                                      systemctl start wireguard-ui
                                      • CrunkFXC CrunkFX
                                        David G.D Online
                                        David G.D Online
                                        David G.
                                        @crunkfx
                                        Last login: Sun Nov 28 14:03:37 2021 from 192.168.99.77
                                        pi@iobroker:~ $ systemctl start wireguard-ui
                                        ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ===
                                        Legitimierung ist zum Starten von »wireguard-ui.service« notwendig.
                                        Authenticating as: ,,, (pi)
                                        Password:
                                        Mit pw:
                                        Last login: Sun Nov 28 14:08:42 2021 from 192.168.99.77
                                        Password:
                                        ==== AUTHENTICATION COMPLETE ===
                                        pi@iobroker:~ $
                                        EDIT:
                                        Tippfehler im PW
                                          @crunkfx
                                          Password:
                                          Mit pw:
                                          Password:
                                          pi@iobroker:~ $
                                          EDIT:
                                          Tippfehler im PW
                                          CrunkFXC Offline
                                          CrunkFXC Offline
                                          CrunkFX
                                          Forum Testing
                                          schrieb am zuletzt editiert von CrunkFX
                                          @david-g nochmal bitte aber mit sudo
