  4. Test Adapter BMW/Mini v4.x.x
    6.8k
1.1k Beiträge 103 Kommentatoren 377.4k Aufrufe 89 Beobachtet
  • T tombox
    nochmal installieren
    Marc BergM Online
    Marc BergM Online
    Marc Berg
    #561
    @tombox sagte in Test Adapter BMW/Mini v2.0.0:
    nochmal
    Eine Fehlermeldung wird nun nicht mehr angezeigt, es wird ein Objekt mit der ID
      "_id": "bmw.0.Wxxx.chargingSessions.2023-12.costsGroupedByCurrency.~ 20_65 EUR",
    angelegt.
    • Marc BergM Marc Berg
      nochmal
      angelegt.
      mike1429
      #562
      @marc-berg
      Kann das bestätigen
      • M mike1429
        @marc-berg
        Kann das bestätigen
        mike1429
        #563
        @mike1429
        Hmmm....
        admin.0
        2023-12-30 22:21:19.047 error Cannot subscribe "bmw.0.xxxxxxxxxxxxx.chargingSessions.2023-11.costsGroupedByCurrency.~ 24,78 EUR": Error The pattern "bmw.0.xxxxxxxxxxxxx.chargingSessions.2023-11.costsGroupedByCurrency.~ 24,78 EUR" is not a valid ID pattern
        host.buanet-iobroker1-Server
        2023-12-30 22:21:19.045 warn States 127.0.0.1:47846 Error from InMemDB: Error: The pattern "bmw.0.xxxxxxxxxxxxx.chargingSessions.2023-11.costsGroupedByCurrency.~ 24,78 EUR" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2470:15) at StatesInMemoryServer.handleSubscribe (/opt/iobroker/node_modules/@iobroker/db-base/src/lib/inMemFileDB.ts:324:59) at StatesInMemoryServer._subscribeForClient (/opt/iobroker/node_modules/@iobroker/db-states-file/src/lib/states/statesInMemFileDB.js:258:14) at RedisHandler.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-jsonl/src/lib/states/statesInMemServerRedis.js:395:26) at RedisHandler.emit (node:events:513:28) at RedisHandler.emit (node:domain:489:12) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/db-base/src/lib/redisHandler.ts:209:37) at processImmediate (node:internal/timers:466:21)
        admin.0
        2023-12-30 22:21:19.042 error Invalid pattern on subscribe: The pattern "bmw.0.xxxxxxxxxxxxx.chargingSessions.2023-11.costsGroupedByCurrency.~ 13,52 EUR" is not a valid ID pattern
        • M mike1429
          @mike1429
          Hmmm....
          admin.0
          admin.0
          tombox
          #564
          @mike1429 Nochmal installieren
          • JB_SullivanJ Offline
            JB_Sullivan
            #565
            Läßt sich z.Zt. über die Katze nicht aktualisieren.
            $ iobroker url TA2k/ioBroker.bmw --host GLT --debug
            Server Cannot start inMem-states on port 9000: Failed to lock DB file "C:\ioBroker\GLT\iobroker-data\states.jsonl"!
            ERROR: Process exited with code 24
            • L Offline
              lessthanmore
              schrieb am zuletzt editiert von lessthanmore
              #566
              Bei mir lässt es sich über die Katze installieren.
              Allerdings bekomme ich nun folgende Warnung recht unregelmäßig bei einem Interval von 10 Minuten.
              bmw.0
              2024-01-01 16:56:10.239	warn	Out of call volume quota. Quota will be replenished in 00:03:50.
              bmw.0
              2024-01-01 14:46:10.219	warn	Out of call volume quota. Quota will be replenished in 00:13:50.
              bmw.0
              2024-01-01 12:46:10.181	warn	Out of call volume quota. Quota will be replenished in 00:13:50.
              • L lessthanmore
                bmw.0
                bmw.0
                bmw.0
                Marc BergM Online
                Marc BergM Online
                Marc Berg
                #567
                @lessthanmore sagte in Test Adapter BMW/Mini v2.0.0:
                Das kommt, wenn der Adapter ein paar mal hintereinander neu gestartet wurde, verschwindet dann aber nach Ablauf der Zeit.
                L 1 Antwort Letzte Antwort
                  lessthanmore
                  #568
                  @marc-berg Die Instanz wurde eigentlich nicht neugestartet.
                  Die Meldung kommt auch nicht jede Stunde.
                  Aber ich lasse ihn mal laufen.
                  Danke.
                  • L lessthanmore
                    Danke.
                    Marc BergM Online
                    Marc BergM Online
                    Marc Berg
                    #569
                    Ich dachte, du hättest den Adapter neu installiert? Das ist ja in jedem Fall mit einem Neustart verbunden.
                    • lobomauL lobomau
                      Edit.: ich hab das untere hinterher par Handy-App gemacht. Hat bestimmt zwei M inuten gedauert bis das Licht kurz anging. Kann also bei mir an etwas anderem liegen.
                      @tombox ich teste grad die remotes:
                      Horn auf true:
                      bmw.0	2021-08-03 18:03:43.208	error	(29538) {"error":{"code":302,"description":"(SmartPhoneUtil-A-302) External service failed. "}}
                      bmw.0	2021-08-03 18:03:43.208	error	(29538) Error: Request failed with status code 500
                      light_flash gleicher Fehler:
                      bmw.0	2021-08-03 18:05:02.428	error	(29538) {"error":{"code":302,"description":"(SmartPhoneUtil-A-302) External service failed. "}}
                      bmw.0	2021-08-03 18:05:02.427	error	(29538) Error: Request failed with status code 500
                      tombox
                      #570
                      die GitHub version kann jetzt service demands und trips abrufen bitte mal testen ob das so sinn macht
                      bahnuhrB vowillV 2 Antworten Letzte Antwort
                      • T tombox
                        bahnuhrB Online
                        bahnuhrB Online
                        bahnuhr
                        #571
                        Habe gerade von git installiert.
                        Unter den Objekten finde ich nix zu:
                        Wo sollen diese sein ?
                        Danke.
                        • bahnuhrB bahnuhr
                          tombox
                          #572
                          wird beim start erstellt
                            JB_Sullivan
                            #573
                            servicedemands und trips sind bei mir vorhanden. Allerdings ist bei den chargingsessions einiges durcheinander gekommen.
                            In jeden Monatsblock haben sich auch die Ladungen des jeweiligen Vormonat rein gemogelt. Also in 11/23 auch ein Teil der 10/23er Daten und in 12/23 auch wiederum ein Teil der 11/23er Daten - usw. Betrifft bei mir alle Sessions, seit ich das Fahrzeug in Besitz habe.
                            • JB_SullivanJ JB_Sullivan
                              tombox
                              #574
                              @jb_sullivan ein debug log mit den rohen charging sessions wäre interessant via mail
                              tombox2020@gmail.com
                              • T tombox
                                vowillV Offline
                                vowillV Offline
                                vowill
                                schrieb am zuletzt editiert von vowill
                                #575
                                @tombox
                                2.8.0 funktioniert bei mir bestens, VIELEN DANK! Die DPs unter bmw.0.xxx.servicedemands enthalten jetzt die Daten analog den früheren DPs unter bmw.0.VIN.properties.serviceRequiredxx.
                                Super!
                                ioBroker im lxc auf NUC / Aktive Instanzen: 38
                                K 1 Antwort Letzte Antwort
                                • vowillV vowill
                                  @tombox
                                  Super!
                                  Karacho
                                  schrieb am zuletzt editiert von Karacho
                                  #576
                                  bei mir zeigt der Adapter 2 DP falsch oder nicht an:
                                  Und zwar
                                  • Ladestatus als "invalid", lädt aber
                                  • Chargerconnected "false" ist aber "true"
                                  remaining charging time wird richtig mit 299minangezeigt....
                                  Was läuft falsch?
                                  In der Vergangenheit waren die DP richtig.
                                  Karacho
                                  lobomauL 1 Antwort Letzte Antwort
                                  • K Karacho
                                    Und zwar
                                    Was läuft falsch?
                                    Karacho
                                    lobomauL Offline
                                    lobomauL Offline
                                    lobomau
                                    #577
                                    @karacho bei mir sind die DPs korrekt. Ich habe Adapterversion 2.7.0. Stable ist 2.5.7.
                                    Host: NUC8i3 mit Proxmox:
                                    • Slave: Pi4
                                    • T tombox
                                      mike1429
                                      #578
                                      @tombox
                                      Bei mir ist die letzte Charging Session von Ende März. Andere Werte sind aktuell. Wo finde ich die jetzt? Oder was ist falsch? Version 2.8.0
                                      • M mike1429
                                        @tombox
                                        mike1429
                                        #579
                                        @mike1429
                                        Sieht jemand die Charging Sessions? Oder wird diese Funktion nicht mehr unterstützt?
                                        • M mike1429
                                          @mike1429
                                          lobomauL Offline
                                          lobomauL Offline
                                          lobomau
                                          schrieb am zuletzt editiert von lobomau
                                          #580
                                          @mike1429 sidht bei mir auch so aus. Letzte ChargingSession 28.3.24.
                                          Und chargingstatistics ging bei mir bis 2024-02.
                                          Habe beide Ordner gelöscht. Waren über 4500 Einträge (die ich nie gebraucht habe).
                                          • Slave: Pi4
