  4. Test Adapter powerfox v0.0.2-x
    5.4k
powerfoxenergy meterenergy monitorenergy
147 Beiträge 28 Kommentatoren 29.9k Aufrufe 23 Beobachtet
    @atari sagte in Test Adapter powerfox v0.0.2-x:
    Hat jemand eine Idee?
    Zeig mal die Langfassung von
    iob diag
    ATARI
    #121
    mit Langfassung meinst Du die "Summary"?
    ATARI
    Raspberry Pi 5B (ioB via pi OS_lite(64bit) | Synology NAS (ioB via Docker)
    Fibaro Home Center 2 & Home Center 3 | Homematic IP | EMS-ESP32 Gateway
    Aeotec Z-Wave | Tuya 4 in 1 Gateway | Zigbee & BLE Gateway
      ATARI
      #122
                           v.2023-06-20
         Static hostname: pi
               Icon name: computer
              Machine ID: xxxxxxxxxxxxxxxxxxxx
                 Boot ID: xxxxxxxxxxxxxxxxxxxx
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v8+
            Architecture: arm64
      Installation:           native
      Kernel:                 aarch64
      Userland:               arm64
      Timezone:               Europe/Berlin (CEST, +0200)
      User-ID:                1000
      X-Server:               false
      Boot Target:            multi-user.target
      Pending OS-Updates:     0
      Pending iob updates:    0
      Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                              /usr/bin/node           v18.17.1
                              /usr/bin/npm            9.6.7
                              /usr/bin/npx            9.6.7
      Recommended versions are nodejs 18.x.y and npm 9.x.y
      MEMORY:
      Mem:            7.8G        1.4G        5.7G        1.0M        640M        6.2G
      Swap:            99M          0B         99M
      Total:          7.9G        1.4G        5.8G
      Active iob-Instances:   18
      Active repo(s): stable
      ioBroker Core:          js-controller           5.0.12
                              admin                   6.10.1
      Objects type: jsonl
      States  type: jsonl
      + system.adapter.admin.0                  : admin                 : pi                                       -  enabled, port: 8081, bind: 0.0.0
      + system.adapter.web.0                    : web                   : pi                                       -  enabled, port: 8082, bind: 0.0.0
      Objects:                6327
      States:                 4833
      Size of iob-Database:
      22M     /opt/iobroker/iobroker-data/objects.jsonl
      3.0M    /opt/iobroker/iobroker-data/states.jsonl
      ATARI
      • A ATARI
        #123
        Nein, die Langfassung ist die Langfassung, 'Summary' ist die Zusammenfassung.
          ATARI
          #124
          Skript v.2023-06-20
          *** BASE SYSTEM ***
             Static hostname: pi
                   Icon name: computer
                  Machine ID: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                     Boot ID: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                Architecture: arm64
          Model           : Raspberry Pi 4 Model B Rev 1.5
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : arm64
          Systemuptime and Load:
           16:10:12 up  5:12,  1 user,  load average: 0.44, 0.82, 1.35
          CPU threads: 4
          Raspberry only:
          throttled=0x0
          Other values than 0x0 hint to temperature/voltage problems
          temp=40.9'C
          volt=0.9360V
          *** Time and Time Zones ***
                         Local time: Mon 2023-09-25 16:10:12 CEST
                     Universal time: Mon 2023-09-25 14:10:12 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          admin
          /home/admin
          admin adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
          *** X-Server-Setup ***
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            7.8G        1.4G        5.7G        1.0M        717M        6.3G
          Swap:            99M          0B         99M
                   7812 M total memory
                   1394 M used memory
                   1476 M active memory
                    479 M inactive memory
                   5700 M free memory
                     76 M buffer memory
                    641 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          lifetime oom required: 0 Mbytes
          total time in oom handler: 0 ms
          max time spent in oom handler: 0 ms
          *** FILESYSTEM ***
          /dev/root      ext4       59G  3.2G   53G   6% /
          devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
          tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
          tmpfs          tmpfs     1.6G  1.1M  1.6G   1% /run
          /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
          tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
          [Mon Sep 25 10:58:06 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:66:1B:1C vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=b80df8ab-02 rootfstype=ext4 fsck.repair=yes rootwait
          [Mon Sep 25 10:58:07 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
          [Mon Sep 25 10:58:07 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
          [Mon Sep 25 10:58:09 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
          Show mounted filesystems (real ones only):
          TARGET  SOURCE         FSTYPE OPTIONS
          /       /dev/mmcblk0p2 ext4   rw,noatime
          `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          634M    /var/
          207M    /var/log
          193M    /var/log/journal/a8c446969d5b4d38975daa054bdd92b5
          180M    /var/cache
          Archived and active journals take up 192.0M in the file system.
          /opt/iobroker/backups:
          38M     /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          242M    /opt/iobroker/iobroker-data/
          113M    /opt/iobroker/iobroker-data/files
          88M     /opt/iobroker/iobroker-data/backup-objects
          52M     /opt/iobroker/iobroker-data/files/javascript.admin
          34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
          27M     /opt/iobroker/iobroker-data/objects.jsonl
          21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
          16M     /opt/iobroker/iobroker-data/states.jsonl
          8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js
          7.1M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.f22de4ab.chunk.js.map
          *** NodeJS-Installation ***
          /usr/bin/npm            9.6.7
          /usr/bin/npx            9.6.7
          nodejs:
            Installed: 18.17.1-deb-1nodesource1
            Candidate: 18.17.1-deb-1nodesource1
            Version table:
           *** 18.17.1-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
                  100 /var/lib/dpkg/status
               12.22.12~dfsg-1~deb11u4 500
                  500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
               12.22.12~dfsg-1~deb11u3 500
                  500 http://deb.debian.org/debian bullseye/main arm64 Packages
          No problems detected
          npm ERR! code ELSPROBLEMS
          npm ERR! missing: http@^0.0.1-security, required by iobroker.javascript@7.1.4
          npm ERR! missing: modbus-serial@^8.0.13, required by iobroker.javascript@7.1.4
          npm ERR! missing: serial@^0.0.9, required by iobroker.javascript@7.1.4
          npm ERR! missing: usb@^2.10.0, required by iobroker.javascript@7.1.4
          npm ERR! A complete log of this run can be found in: /home/admin/.npm/_logs/2023-09-25T14_10_18_185Z-debug-0.log
          Errors in npm tree: 0
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          No configuration change needed.
          Multihost discovery server: disabled
          Discovery authentication:   enabled
          Persistent activation:      disabled
          Objects:                    jsonl on 127.0.0.1
          States:                     jsonl on 127.0.0.1
          Core adapters versions
          js-controller:  5.0.12
          admin:          6.10.1
          javascript:     7.1.4
          Adapters from github:   1
          Adapter State
          + system.adapter.admin.0                  : admin                 : pi                                       -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.alexa2.0                 : alexa2                : pi                                       -  enabled
          + system.adapter.backitup.0               : backitup              : pi                                       -  enabled
          + system.adapter.discovery.0              : discovery             : pi                                       -  enabled
          + system.adapter.email.0                  : email                 : pi                                       -  enabled
          + system.adapter.fb-checkpresence.0       : fb-checkpresence      : pi                                       -  enabled
            system.adapter.feiertage.0              : feiertage             : pi                                       -  enabled
          + system.adapter.followthesun.0           : followthesun          : pi                                       -  enabled
            system.adapter.homepilot.0              : homepilot             : pi                                       - disabled
          + system.adapter.info.0                   : info                  : pi                                       -  enabled
          + system.adapter.javascript.0             : javascript            : pi                                       -  enabled
            system.adapter.netatmo-crawler.0        : netatmo-crawler       : pi                                       -  enabled
          + system.adapter.netatmo.0                : netatmo               : pi                                       -  enabled
            system.adapter.powerfox2.0              : powerfox2             : pi                                       -  enabled
            system.adapter.schoolfree.0             : schoolfree            : pi                                       -  enabled
          + system.adapter.shelly.0                 : shelly                : pi                                       -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.simple-api.0             : simple-api            : pi                                       -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
          + system.adapter.smartgarden.0            : smartgarden           : pi                                       -  enabled
          + system.adapter.sonos.0                  : sonos                 : pi                                       -  enabled
          + system.adapter.sony-bravia.0            : sony-bravia           : pi                                       -  enabled
          + system.adapter.sony-bravia.1            : sony-bravia           : pi                                       -  enabled
          + system.adapter.tr-064.0                 : tr-064                : pi                                       -  enabled
          + system.adapter.web.0                    : web                   : pi                                       -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + instance is alive
          ioBroker-Repositories
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 6.10.1   , installed 6.10.1
          Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
          Adapter    "backitup"     : 2.8.1    , installed 2.8.1
          Adapter    "discovery"    : 3.1.0    , installed 3.1.0
          Adapter    "email"        : 1.2.0    , installed 1.2.0
          Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
          Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
          Adapter    "followthesun" : 0.4.2    , installed 0.4.2
          Adapter    "homepilot"    : 1.1.6    , installed 1.1.6
          Adapter    "info"         : 1.9.26   , installed 1.9.26
          Adapter    "javascript"   : 7.1.4    , installed 7.1.4
          Controller "js-controller": 5.0.12   , installed 5.0.12
          Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
          Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
          Adapter    "powerfox2"    : 0.0.12   , installed 0.0.12
          Adapter    "schoolfree"   : 1.1.2    , installed 1.1.2
          Adapter    "shelly"       : 6.4.1    , installed 6.4.1
          Adapter    "smartgarden"  : 2.0.0    , installed 2.0.0
          Adapter    "socketio"     : 6.5.5    , installed 6.5.5
          Adapter    "sonos"        : 2.3.1    , installed 2.3.1
          Adapter    "sony-bravia"  : 1.0.9    , installed 1.0.9
          Adapter    "tr-064"       : 4.2.18   , installed 4.2.18
          Adapter    "web"          : 6.1.2    , installed 6.1.2
          Adapter    "ws"           : 2.5.5    , installed 2.5.5
          Objects and States
          Objects:        6757
          States:         5200
          Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
          Hit:2 http://deb.debian.org/debian bullseye InRelease
          Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
          Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       143047     20981/iobroker.js-c
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       143040     20981/iobroker.js-c
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13563      544/sshd: /usr/sbin
          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       145602     21318/io.simple-api
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       147174     21470/io.web.0
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       143101     21000/io.admin.0
          tcp6       0      0 :::3500                 :::*                    LISTEN      1001       143148     21084/io.sonos.0
          tcp6       0      0 :::22                   :::*                    LISTEN      0          13565      544/sshd: /usr/sbin
          udp        0      0 192.168.0.101:5353      0.0.0.0:*                           1001       145461     21169/io.tr-064.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15368      394/avahi-daemon: r
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       144211     21065/io.shelly.0
          udp        0      0 0.0.0.0:51391           0.0.0.0:*                           1001       155154     21065/io.shelly.0
          udp        0      0 0.0.0.0:60589           0.0.0.0:*                           108        15370      394/avahi-daemon: r
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          11804      737/dhcpcd
          udp6       0      0 :::546                  :::*                                0          12706      737/dhcpcd
          udp6       0      0 :::5353                 :::*                                108        15369      394/avahi-daemon: r
          udp6       0      0 :::51198                :::*                                108        15371      394/avahi-daemon: r
          2023-09-25 16:10:34.690  - info: javascript.0 (21042) script.js.common.Huawei.get_data: Triggering read of inverter 1 at address 37100 with length 114
          2023-09-25 16:10:37.690  - info: javascript.0 (21042) script.js.common.Huawei.get_data: Triggering read of inverter 1 at address 32000 with length 116
          2023-09-25 16:10:40.040  - info: host.pi instance system.adapter.powerfox2.0 started with pid 23068
          2023-09-25 16:10:40.700  - info: javascript.0 (21042) script.js.common.Huawei.get_data: Triggering read of inverter 1 at address 37000 with length 68
          2023-09-25 16:10:41.836  - error: host.pi instance system.adapter.powerfox2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          2023-09-25 16:10:43.701  - info: javascript.0 (21042) script.js.common.Huawei.get_data: Triggering read of inverter 1 at address 37700 with length 100
          2023-09-25 16:10:46.701  - info: javascript.0 (21042) script.js.common.Huawei.get_data: Triggering read of inverter 1 at address 37800 with length 100
          2023-09-25 16:10:49.701  - info: javascript.0 (21042) script.js.common.Huawei.get_data: Triggering read of inverter 1 at address 38200 with length 100
          2023-09-25 16:10:50.043  - info: host.pi instance system.adapter.powerfox2.0 started with pid 23102
          2023-09-25 16:10:51.201  - error: host.pi instance system.adapter.powerfox2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          2023-09-25 16:10:52.701  - info: javascript.0 (21042) script.js.common.Huawei.get_data: Triggering read of inverter 1 at address 38300 with length 100
          2023-09-25 16:10:55.701  - info: javascript.0 (21042) script.js.common.Huawei.get_data: Triggering read of inverter 1 at address 38400 with length 100
          2023-09-25 16:10:56.976  - info: javascript.0 (21042) script.js.common.Huawei.Sonnen_Azimuth: -131.5
          2023-09-25 16:10:58.702  - info: javascript.0 (21042) script.js.common.Huawei.get_data: Triggering read of inverter 1 at address 35300 with length 40
          2023-09-25 16:11:00.066  - info: host.pi instance system.adapter.powerfox2.0 started with pid 23135
          2023-09-25 16:11:01.134  - error: host.pi instance system.adapter.powerfox2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          2023-09-25 16:11:01.702  - info: javascript.0 (21042) script.js.common.Huawei.get_data: Processing new data...
          2023-09-25 16:11:01.710  - info: javascript.0 (21042) script.js.common.Huawei.get_data: Processing done!
          2023-09-25 16:11:01.711  - info: javascript.0 (21042) script.js.common.Huawei.get_data: Triggering read of inverter 1 at address 30000 with length 81
          2023-09-25 16:11:04.703  - info: javascript.0 (21042) script.js.common.Huawei.get_data: Triggering read of inverter 1 at address 37100 with length 114
          2023-09-25 16:11:07.704  - info: javascript.0 (21042) script.js.common.Huawei.get_data: Triggering read of inverter 1 at address 32000 with length 116
          2023-09-25 16:11:10.048  - info: host.pi instance system.adapter.powerfox2.0 started with pid 23556
          2023-09-25 16:11:10.705  - info: javascript.0 (21042) script.js.common.Huawei.get_data: Triggering read of inverter 1 at address 37000 with length 68
          2023-09-25 16:11:11.332  - error: host.pi instance system.adapter.powerfox2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          2023-09-25 16:11:13.705  - info: javascript.0 (21042) script.js.common.Huawei.get_data: Triggering read of inverter 1 at address 37700 with length 100
          ATARI
          • A ATARI
            Skript v.2023-06-20
            *** BASE SYSTEM ***
               Static hostname: pi
                     Icon name: computer
                  Architecture: arm64
            Docker          : false
            Kernel          : aarch64
            Userland        : arm64
            CPU threads: 4
            Raspberry only:
            throttled=0x0
            temp=40.9'C
            volt=0.9360V
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            admin
            /home/admin
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Swap:            99M          0B         99M
                     7812 M total memory
                     1394 M used memory
                     5700 M free memory
                       76 M buffer memory
                      641 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            Raspberry only:
            oom events: 0
            *** FILESYSTEM ***
            /var:
            634M    /var/
            207M    /var/log
            180M    /var/cache
            /usr/bin/npm            9.6.7
            /usr/bin/npx            9.6.7
            nodejs:
              Version table:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          6.10.1
            javascript:     7.1.4
            Adapter State
            + instance is alive
            Objects and States
            Objects:        6757
            States:         5200
            Pending Updates: 0
            #125
            Installier den nochmal:
            iobroker upgrade iobroker.javascript@7.1.4
            A 1 Antwort Letzte Antwort
              ATARI
              schrieb am zuletzt editiert von ATARI
              #126
              JS Upgrade ändert nix.
              Der Adapter erkennt zwar meinen PowerFox als Gerät
              (somit ist die Anmeldung korrekt) aber es werden unter
              "/Objekte/powerfox2/0/devices" keine weiteren Datenpunkte
              angelegt.
              ATARI
              • A ATARI
                angelegt.
                #127
                @atari
                Sind die Fehlermeldungen nun weg?
                Hast du den
                iob fix
                mal ausgeführt?
                Du könntest auch den 'node fix' aus meiner Signatur ausführen, dann wärst du auch an der Stelle auf dem aktuellen Stand.
                A 3 Antworten Letzte Antwort
                  @atari
                  Hast du den
                  iob fix
                  mal ausgeführt?
                  ATARI
                  #128
                  Die Fehlermeldungen bzgl. JavaScript 'modbus-serial' etc. sind weg.
                  iob fix
                  "...schon rauf und runter..."
                  iob stop
                  iob update
                  iob fix
                  iob ubgrade self
                  iob start
                  sudo apt update && sudo apt upgrade...
                  das Alles mit und ohne abschließendem sudo reboot,
                  Host-Neustart, Adapter-Neustart, Adapter gelöscht, neuinstalliert,
                  auch ältere Versionen, aus dem GitHub.... usw.
                  Werde mal Dein 'node fix' testen.
                  ATARI
                    @atari
                    Hast du den
                    iob fix
                    mal ausgeführt?
                    ATARI
                    #129
                    @thomas-braun sagte in Test Adapter powerfox v0.0.2-x:
                    Nach Deinem 'node fix' ist Node.js und NPM sind jetzt 'top aktuell', leider ändert auch das nichts an dem Prob. mit powerfox2.
                    Wie gesagt, mein powerfox Gerät wird erkannt und ist 'aktiviert'.
                    Unter: '/Objekte/powerfox2/0/devices/' wird aber kein weiterer Datenpunkt erstellt.
                    Bin nach dem 'Tod' meines TinkerBoards S bin ich bewusst, wegen besserem Support und höherer Kompatibiltät, auf Raspi umgestiegen...,
                    und nun so'n scheiß...
                    ATARI
                      @atari
                      Hast du den
                      iob fix
                      mal ausgeführt?
                      ATARI
                      #130
                      @thomas-braun (nicht persönlich nehmen)
                      Habe jetzt, nur zum Testen, das akt. Raspi OS (64bit lite) und akt. ioB auf einer anderen microSD installiert. (btw. erneut nach Deiner hervorgenden Installationsanleitung aus diesem Forum)
                      Neues ioB mit:
                      node.js v18.17.1
                      npm v9.6.7
                      js-controller v4.0.24
                      -> powerfox2 funktioniert, auch nach admin update auf v6.10.x.
                      Leider funktioniert nach einem Restore des letzten Backups, über BackItUp, ioBroker nicht mehr. Über ssh ist der Raspi weiterhin erreichbar, aber über :8081 nicht. Evtl. diff. zwischen js-controller.
                      ATARI
                      • A ATARI
                        Neues ioB mit:
                        node.js v18.17.1
                        npm v9.6.7
                        #131
                        Logisch. Hat ja auch nichts miteinander zu tun.
                        iob diag
                        sagt?
                          iob diag
                          sagt?
                          ATARI
                          #132
                          sorry Thomas, aber ich bastel jetzt seit 4 Tagen an dem Prob. herum.
                          Habe das Test-System wieder gelöscht.
                          Da ich noch einen ioBroker auf einer Synology DS habe und ich z.Zt. nur 2 Datenpunkte vom powerfox brauche,
                          habe ich das Ganze jetzt erstmal mit MQTT (Syno DS -> Raspi) gelöst.
                          Vllt. finde ich in den nächsten Tage ja nochmal die Muse...
                          Schon merkwürdig, das es auf der Syno mit gleichen Versionen funktioniert.
                          Vielen Dank für Deinen Support!
                          ATARI
                            ATARI
                            #133
                            ...es lies mir dann doch keine Ruhe...
                            • Pi OS Lite(64bit) neu geflasht
                            • sudo apt update && sudo apt full-upgrade
                            • sudo reboot
                            • curl -sLf https://iobroker.net/install.sh | bash -
                            • iob diag (unauffällig)
                            • curl https://raw.githubusercontent.com/Grothesk242/iob_diag/main/iob_node_update > iob_node_update chmod 744 iob_node_update ./iob_node_update
                            • iobroker Assistent absolviert
                            • Update Adapter admin.0 auf v6.10.1
                            • Adapter powerfox2 (v0.0.12) installiert, ### volle Funktion ###
                            • danach den js-controller von v4.0.24 auf v5.0.12 aktualisiert
                            Jetzt ist alles 'hübsch'. Nun muss ich nur noch alle anderen Adapter
                            wieder nachinstallieren.
                            ATARI
                            F 1 Antwort Letzte Antwort
                            • A ATARI
                              • sudo reboot
                              Flopsi
                              #134
                              ist es normal das in dem Datenpunkt
                              powerfox2.0.devices......currentFeedIn
                              kein Wert bzw. der Wert 0 W angezeigt wird, ich hätte hier den Einspeisewert meines Balkonkraftwerkes erwartet ....
                              • F Flopsi
                                ATARI
                                #135
                                @Flopsi vermutlich ist Dein Eigenverbrauch höher als die Einspeiseleistung der PV-Anlage.
                                Einen 2-Wege Zähler hast Du?
                                Ich speise gerade 6 Watt ein, weil mein Eigenbedarf die Solarleistung "frisst".
                                ATARI
                                • A ATARI
                                  Flopsi
                                  schrieb am zuletzt editiert von Flopsi
                                  #136
                                  @atari
                                  ja der Eigenverbracuh ist höher als die Einspeisung, einen 2 Wege Zähler habe ich
                                  OK schade dachte man würde sehen können was mein Balkonkraftwerk aktuell macht
                                  ich speise 36 Watt nach meinem Zwischenstecker ein auch mega LOL
                                  • F Flopsi
                                    @atari
                                    ATARI
                                    #137
                                    @flopsi sagte in Test Adapter powerfox v0.0.2-x:
                                    Gibt es für Deine PV-Analge kein Adapter im ioBroker?
                                    Damit könntest Du die Werte direkt auslesen.
                                    ATARI
                                    • A ATARI
                                      Flopsi
                                      #138
                                      @atari
                                      habe einen Wechselrichter von hoymiles... der mit 600 Watt der hat kein W-Lan muss, da einen Adapter für kaufen oder so ein DTU teil ...
                                      habe noch nicht geschaut welcher Adapter da passen könnte ....
                                      • F Flopsi
                                        @atari
                                        #139
                                        @flopsi
                                        Ich kann da opendtu empfehlen.
                                          @flopsi
                                          Flopsi
                                          #140
                                          opendtu
                                          OK welcher Bausatz wäre das (das gibt es ja schon unterschiede)
